[U-Boot-Users] [PATCH: u-boot-fdt] Fix serious pointer bug with bootm and reserve map.
What was suppose to be a stack variable was declared as a pointer, overwriting random memory. Also moved the libfdt.a requirement into the main Makefile. That is The U-Boot Way.
Signed-off-by: Gerald Van Baren vanbaren@cideas.com --- Makefile | 1 + board/mpc8360emds/config.mk | 5 ----- common/fdt_support.c | 4 ++-- 3 files changed, 3 insertions(+), 7 deletions(-)
diff --git a/Makefile b/Makefile index 9a27bc2..94cda54 100644 --- a/Makefile +++ b/Makefile @@ -219,6 +219,7 @@ LIBS += $(shell if [ -d post/cpu/$(CPU) ]; then echo \ LIBS += $(shell if [ -d post/board/$(BOARDDIR) ]; then echo \ "post/board/$(BOARDDIR)/libpost$(BOARD).a"; fi) LIBS += common/libcommon.a +LIBS += libfdt/libfdt.a LIBS += $(BOARDLIBS)
LIBS := $(addprefix $(obj),$(LIBS)) diff --git a/board/mpc8360emds/config.mk b/board/mpc8360emds/config.mk index 5801a5f..9ace886 100644 --- a/board/mpc8360emds/config.mk +++ b/board/mpc8360emds/config.mk @@ -26,8 +26,3 @@ #
TEXT_BASE = 0xFE000000 - -# -# Additional board-specific libraries -# -BOARDLIBS = libfdt/libfdt.a diff --git a/common/fdt_support.c b/common/fdt_support.c index 91b729f..69099c4 100644 --- a/common/fdt_support.c +++ b/common/fdt_support.c @@ -56,7 +56,7 @@ int fdt_chosen(void *fdt, ulong initrd_start, ulong initrd_end, int force) }
if (initrd_start && initrd_end) { - struct fdt_reserve_entry *re; + struct fdt_reserve_entry re; int used; int total; int j; @@ -77,7 +77,7 @@ int fdt_chosen(void *fdt, ulong initrd_start, ulong initrd_end, int force) */ for (j = 0; j < used; j++) { err = fdt_get_reservemap(fdt, j, &re); - if (re->address == initrd_start) { + if (re.address == initrd_start) { break; } }
Jerry Van Baren
