[U-Boot] [PATCH v7] mmc: atmel_sdhci: Convert to the driver model support
Convert the driver to the driver model while retaining the existing legacy code. This allows the driver to support boards that have converted to driver model as well as those that have not.
Signed-off-by: Wenyou Yang wenyou.yang@atmel.com Reviewed-by: Simon Glass sjg@chromium.org ---
Changes in v7: - Add support for using driver model for block devices and MMC operations. - Change clk_client.h -> clk.h to adapt to clk API conversion.
Changes in v6: - Remove unnecessary white space. - Use sdhci_read(), instead of readl(). - Remove the local variables min_clk.
Changes in v5: - Add Reviewed-by tag.
Changes in v4: - Update the clk API based on [PATCH] clk: convert API to match reset/mailbox fstyle (http://patchwork.ozlabs.org/patch/625342/). - Remove check on dev_get_parent() return. - Fixed the return value, such as -ENODEV->-EINVAL.
Changes in v3: - Remove the redundant log print.
Changes in v2: - Add clock support, include enabling peripheral clock and generated clock. - Retain the existing legacy code to support boards which have not converted to driver model.
drivers/mmc/Kconfig | 10 ++++ drivers/mmc/atmel_sdhci.c | 125 ++++++++++++++++++++++++++++++++++++++++++++++ include/sdhci.h | 2 + 3 files changed, 137 insertions(+)
diff --git a/drivers/mmc/Kconfig b/drivers/mmc/Kconfig index 79cf18f..49b325e 100644 --- a/drivers/mmc/Kconfig +++ b/drivers/mmc/Kconfig @@ -34,6 +34,16 @@ config MSM_SDHCI SD 3.0 specifications. Both SD and eMMC devices are supported. Card-detect gpios are not supported.
+config ATMEL_SDHCI + bool "Atmel SDHCI controller support" + depends on DM_MMC && BLK && DM_MMC_OPS && ARCH_AT91 + help + This enables support for the Atmel SDHCI controller, which supports + the embedded MultiMedia Card (e.MMC) Specification V4.51, the SD + Memory Card Specification V3.0, and the SDIO V3.0 specification. + It is compliant with the SD Host Controller Standard V3.0 + specification. + config ROCKCHIP_DWMMC bool "Rockchip SD/MMC controller support" depends on DM_MMC && OF_CONTROL diff --git a/drivers/mmc/atmel_sdhci.c b/drivers/mmc/atmel_sdhci.c index 24b68b6..977f6ef 100644 --- a/drivers/mmc/atmel_sdhci.c +++ b/drivers/mmc/atmel_sdhci.c @@ -6,12 +6,15 @@ */
#include <common.h> +#include <clk.h> +#include <dm.h> #include <malloc.h> #include <sdhci.h> #include <asm/arch/clk.h>
#define ATMEL_SDHC_MIN_FREQ 400000
+#ifndef CONFIG_DM_MMC int atmel_sdhci_init(void *regbase, u32 id) { struct sdhci_host *host; @@ -38,3 +41,125 @@ int atmel_sdhci_init(void *regbase, u32 id)
return 0; } + +#else + +DECLARE_GLOBAL_DATA_PTR; + +struct atmel_sdhci_plat { + struct mmc_config cfg; + struct mmc mmc; +}; + +static int atmel_sdhci_probe(struct udevice *dev) +{ + struct mmc_uclass_priv *upriv = dev_get_uclass_priv(dev); + struct atmel_sdhci_plat *plat = dev_get_platdata(dev); + struct sdhci_host *host = dev_get_priv(dev); + u32 max_clk; + u32 caps, caps_1; + u32 clk_base, clk_mul; + u32 gck_rate; + struct udevice *dev_clk; + struct clk clk; + int periph, ret; + + ret = clk_get_by_index(dev, 0, &clk); + if (ret) + return ret; + + periph = fdtdec_get_uint(gd->fdt_blob, clk.dev->of_offset, "reg", -1); + if (periph < 0) + return -EINVAL; + + dev_clk = dev_get_parent(clk.dev); + ret = clk_request(dev_clk, &clk); + if (ret) + return ret; + + clk.id = periph; + ret = clk_enable(&clk); + if (ret) + return ret; + + host->name = (char *)dev->name; + host->ioaddr = (void *)dev_get_addr(dev); + + host->quirks = 0; + host->version = sdhci_readw(host, SDHCI_HOST_VERSION); + + host->bus_width = fdtdec_get_int(gd->fdt_blob, dev->of_offset, + "bus-width", 4); + + caps = sdhci_readl(host, SDHCI_CAPABILITIES); + clk_base = (caps & SDHCI_CLOCK_V3_BASE_MASK) >> SDHCI_CLOCK_BASE_SHIFT; + caps_1 = sdhci_readl(host, SDHCI_CAPABILITIES_1); + clk_mul = (caps_1 & SDHCI_CLOCK_MUL_MASK) >> SDHCI_CLOCK_MUL_SHIFT; + gck_rate = clk_base * 1000000 * (clk_mul + 1); + + ret = clk_get_by_index(dev, 1, &clk); + if (ret) + return ret; + + periph = fdtdec_get_uint(gd->fdt_blob, clk.dev->of_offset, "reg", -1); + if (periph < 0) + return -EINVAL; + + dev_clk = dev_get_parent(clk.dev); + ret = clk_request(dev_clk, &clk); + if (ret) + return ret; + + clk.id = periph; + ret = clk_set_rate(&clk, gck_rate); + if (ret) + return ret; + + max_clk = clk_get_rate(&clk); + if (!max_clk) + return -EINVAL; + + ret = sdhci_setup_cfg(&plat->cfg, dev->name, host->bus_width, + caps, max_clk, ATMEL_SDHC_MIN_FREQ, + host->version, host->quirks, 0); + if (ret) + return ret; + + host->mmc = &plat->mmc; + host->mmc->dev = dev; + host->mmc->priv = host; + upriv->mmc = host->mmc; + + clk_free(&clk); + + return sdhci_probe(dev); +} + +static int atmel_sdhci_bind(struct udevice *dev) +{ + struct atmel_sdhci_plat *plat = dev_get_platdata(dev); + int ret; + + ret = sdhci_bind(dev, &plat->mmc, &plat->cfg); + if (ret) + return ret; + + return 0; +} + +static const struct udevice_id atmel_sdhci_ids[] = { + { .compatible = "atmel,sama5d2-sdhci" }, + { } +}; + +U_BOOT_DRIVER(atmel_sdhci_drv) = { + .name = "atmel_sdhci", + .id = UCLASS_MMC, + .of_match = atmel_sdhci_ids, + .ops = &sdhci_ops, + .bind = atmel_sdhci_bind, + .probe = atmel_sdhci_probe, + .priv_auto_alloc_size = sizeof(struct sdhci_host), + .platdata_auto_alloc_size = sizeof(struct atmel_sdhci_plat), +}; +#endif diff --git a/include/sdhci.h b/include/sdhci.h index c4d3b55..fdc0032 100644 --- a/include/sdhci.h +++ b/include/sdhci.h @@ -166,6 +166,8 @@ #define SDHCI_CAN_64BIT 0x10000000
#define SDHCI_CAPABILITIES_1 0x44 +#define SDHCI_CLOCK_MUL_MASK 0x00FF0000 +#define SDHCI_CLOCK_MUL_SHIFT 16
#define SDHCI_MAX_CURRENT 0x48
Hi Wenyuo,
Changes in v7:
Changes in v6:
Changes in v5:
Changes in v4:
Changes in v3:
Changes in v2:
+config ATMEL_SDHCI
- bool "Atmel SDHCI controller support"
- depends on DM_MMC && BLK && DM_MMC_OPS && ARCH_AT91
- help
specification.
If it doesn't use DM_MMC, then doesn't it need to include dm.h?
return 0; }
+#else
- struct mmc_config cfg;
- struct mmc mmc;
- struct mmc_uclass_priv *upriv = dev_get_uclass_priv(dev);
- struct atmel_sdhci_plat *plat = dev_get_platdata(dev);
- struct sdhci_host *host = dev_get_priv(dev);
- u32 max_clk;
- u32 caps, caps_1;
- u32 clk_base, clk_mul;
- u32 gck_rate;
- struct udevice *dev_clk;
- struct clk clk;
- int periph, ret;
- ret = clk_get_by_index(dev, 0, &clk);
- if (ret)
return ret;
- periph = fdtdec_get_uint(gd->fdt_blob, clk.dev->of_offset, "reg", -1);
- if (periph < 0)
return -EINVAL;
periph is just used to pass to clk.id. it looks meaningless. As i already mentioned, you can make more cleaner than now.
- dev_clk = dev_get_parent(clk.dev);
- ret = clk_request(dev_clk, &clk);
- if (ret)
return ret;
- clk.id = periph;
- ret = clk_enable(&clk);
- if (ret)
return ret;
- host->name = (char *)dev->name;
Needs the type casting?
- host->ioaddr = (void *)dev_get_addr(dev);
- host->quirks = 0;
- host->version = sdhci_readw(host, SDHCI_HOST_VERSION);
- host->bus_width = fdtdec_get_int(gd->fdt_blob, dev->of_offset,
"bus-width", 4);
- caps = sdhci_readl(host, SDHCI_CAPABILITIES);
- clk_base = (caps & SDHCI_CLOCK_V3_BASE_MASK) >> SDHCI_CLOCK_BASE_SHIFT;
- caps_1 = sdhci_readl(host, SDHCI_CAPABILITIES_1);
- clk_mul = (caps_1 & SDHCI_CLOCK_MUL_MASK) >> SDHCI_CLOCK_MUL_SHIFT;
- gck_rate = clk_base * 1000000 * (clk_mul + 1);
gck_rate can be over u32 boundary, doesn't?
- ret = clk_get_by_index(dev, 1, &clk);
- if (ret)
return ret;
It can reuse the above clock get sequence.
If reuse this sequence, lines can be reduced.
My suggestion is
1. Make atmel_sdhci_get_clk(..., int index), it should be returned "struct clk" type.
2. Then the below sequence should be included in function,
atmel_sdhci_get_clk(..., int index) {
clk_get_by_index(dev, index, &clk); ...
return clk; }
How about?
Best Regards, Jaehoon Chung
- if (periph < 0)
return -EINVAL;
- if (ret)
return ret;
- clk.id = periph;
- ret = clk_set_rate(&clk, gck_rate);
- if (ret)
return ret;
- max_clk = clk_get_rate(&clk);
- if (!max_clk)
return -EINVAL;
- ret = sdhci_setup_cfg(&plat->cfg, dev->name, host->bus_width,
- if (ret)
return ret;
- host->mmc = &plat->mmc;
- host->mmc->dev = dev;
- host->mmc->priv = host;
- upriv->mmc = host->mmc;
- clk_free(&clk);
- return sdhci_probe(dev);
- int ret;
- ret = sdhci_bind(dev, &plat->mmc, &plat->cfg);
- if (ret)
return ret;
- { .compatible = "atmel,sama5d2-sdhci" },
- .name = "atmel_sdhci",
- .id = UCLASS_MMC,
- .of_match = atmel_sdhci_ids,
- .ops = &sdhci_ops,
- .bind = atmel_sdhci_bind,
- .probe = atmel_sdhci_probe,
- .priv_auto_alloc_size = sizeof(struct sdhci_host),
- .platdata_auto_alloc_size = sizeof(struct atmel_sdhci_plat),
On 20 July 2016 at 22:16, Jaehoon Chung jh80.chung@samsung.com wrote:
Hi Wenyuo,
Changes in v7:
Changes in v6:
Changes in v5:
Changes in v4:
Changes in v3:
Changes in v2:
+config ATMEL_SDHCI
help
specification.
Please don't put #idefs around header files, particularly this one. It just clutters the code. We can put logic in header files if needed. Eventually most files will include dm.h.
Hi Wenyuo,
Changes in v7:
Changes in v6:
Changes in v5:
Changes in v4:
Changes in v3:
Changes in v2:
+config ATMEL_SDHCI
help
specification.
Agreed! Thanks for explanation.
Hi Jaehoon,
-----Original Message----- From: Jaehoon Chung [mailto:jh80.chung@samsung.com] Sent: 2016年7月21日 12:17 To: Wenyou Yang wenyou.yang@atmel.com; U-Boot Mailing List <u- boot@lists.denx.de> Cc: Pantelis Antoniou panto@antoniou-consulting.com; Andreas Bießmann andreas@biessmann.org; Simon Glass sjg@chromium.org Subject: Re: [PATCH v7] mmc: atmel_sdhci: Convert to the driver model support
Hi Wenyuo,
Changes in v7:
Changes in v6:
Changes in v5:
Changes in v4:
Changes in v3:
Changes in v2:
+config ATMEL_SDHCI
- help
specification.
return 0; }
+#else
- struct mmc mmc;
+static int atmel_sdhci_probe(struct udevice *dev) {
- u32 max_clk;
- u32 caps, caps_1;
- u32 gck_rate;
- struct clk clk;
- int periph, ret;
- if (ret)
return ret;
- if (periph < 0)
return -EINVAL;
There is a litter difference from usual clock structure for Atmel clock driver.
The periph value is got from a child node, then is assigned to its parent clock node.
- if (ret)
return ret;
- clk.id = periph;
- if (ret)
return ret;
Accepted.
- host->quirks = 0;
"bus-width", 4);
Accepted.
- if (ret)
return ret;
My suggestion is
return clk; }
How about?
Good ideas, thanks a lot.
- if (periph < 0)
return -EINVAL;
- if (ret)
return ret;
- clk.id = periph;
- if (ret)
return ret;
- if (!max_clk)
return -EINVAL;
- if (ret)
return ret;
- clk_free(&clk);
+static int atmel_sdhci_bind(struct udevice *dev) {
- int ret;
- if (ret)
return ret;
- .id = UCLASS_MMC,
- .platdata_auto_alloc_size = sizeof(struct atmel_sdhci_plat), };
Best Regards, Wenyou Yang
Jaehoon Chung
Wenyou Yang
Wenyou.Yang@microchip.com
