[U-Boot] db-88f6820-amc board fails to boot with latest u-boot master
I just tried UART booting db-88f6820-amc with the latest u-boot master and it fails to reach the normal u-boot prompt. I don't know if this affects the normal SPI booting.
I've bisected down to commit 94084eea3bd3 ("tools: kwbimage: Fix dest addr").
Reverting this gets things working again, but I'm guessing it'll break secure boot. Should the size adjustment be conditional on something? Does db-88f6820-amc_defconfig need something that the other armada configs have enabled?
Thanks, Chris
Hi Chris,
Thanks for checking and reporting.
Might be, not sure.
I don't think so.
Mario, could you please take a look at this so that we find a solution for the upcoming release?
Thanks, Stefan
On Tue, Feb 14, 2017 at 7:36 AM, Stefan Roese sr@denx.de wrote:
Hi Chris,
Might be, not sure.
I don't think so.
I'll take a look. The quick-fix solution would be to only do the address adjustment if secure boot is active.
But the weird thing is that the address should not matter for the non-secure boot images, since for them the SPL (which is run from a BIN header) directly loads and starts the main U-Boot, hence the BootROM's image loading process is completely bypassed, and the destination address from the header is never used. Does the db-88f6820-amc do anything different in that regard?
Thanks, Stefan
Hi Chris,
Might be, not sure.
I don't think so.
No the amc board is pretty standard. Just doesn't have the extra SATA and PCI-e stuff you get on the bigger GP board.
I notice in that commit series you talk about the .img file. But the default build target is u-boot-spl.kwb[1]. That's what I've always loaded onto the armada boards.
-- [1] - http://git.denx.de/?p=u-boot.git;a=blob;f=arch/arm/mach-mvebu/include/mach/c...
On Tue, Feb 14, 2017 at 10:26 AM, Chris Packham judge.packham@gmail.com wrote:
Hi Chris,
Might be, not sure.
I don't think so.
OK, thanks for clarifying.
Well, I just tried it with our GP board, and it works with and without the address adjustment, as expected.
Caveat: I'm booting from an SD card (I changed the U-Boot config around to build a suitable image). There definitely are *some* differences between the boot flows on different boot mediums (I never got the jump back into the BootROM to work on SD boot, for example). So if you boot from another medium, this might be the problem.
The u-boot-spl.kwb is the correct image. But this image contains the u-boot.img as a payload. And since this image has the header prepended, we have to subtract the header size from the destination address, so that the entry point lines up correctly if we want to jump back into the BootROM (which is necessary for secure boot to work). But for boards that don't jump back into the BootROM, this doesn't matter, since the BootROM doesn't actually load the main U-Boot in this case, but the SPL does (and the SPL doesn't care about some address in a SoC-specific header; hence my consternation).
-- [1] - http://git.denx.de/?p=u-boot.git;a=blob;f=arch/arm/mach-mvebu/include/mach/c... _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de http://lists.denx.de/mailman/listinfo/u-boot
Hi Chris,
Might be, not sure.
I don't think so.
For the AMC board my only option is SPI (still haven't tried that with a "broken" build) and UART. UART definitely fails for me.
Maybe this is UART boot specific. The addressing is probably a bit special and secure boot probably does not apply. Up to now it's been neat trick that kwboot can patch the image on the fly. Maybe it needs to be a bit smarter. I note that Marvell's build process actually produces a separate -uart version of the image, maybe this is why.
On Wed, Feb 15, 2017 at 11:56 AM, Chris Packham judge.packham@gmail.com wrote:
Hi Chris,
Might be, not sure.
I don't think so.
And now I have tried SPI and that works. So this is indeed UART specific.
Hi Chris,
Might be, not sure.
I don't think so.
I think the problem is commit f4db6c976cf8 ("arm: mvebu: Add runtime detection of UART (xmodem) boot-mode") and commit 94084eea3bd3 ("tools: kwbimage: Fix dest addr") conflict and end up taking off too much when using kwboot. I'll try removing the destaddr adjustment from kwboot and see where I get to.
Commit 94084eea3bd3 ("tools: kwbimage: Fix dest addr") changed kwbimage to do this adjustment. So now the adjustment in kwboot is not needed (and would prevent UART booting for images generated by the new kwbimage). Remove the destaddr adjustment in kwboot.
Signed-off-by: Chris Packham judge.packham@gmail.com ---
tools/kwboot.c | 8 -------- 1 file changed, 8 deletions(-)
diff --git a/tools/kwboot.c b/tools/kwboot.c index 26b394963cd8..8a421cda4ea5 100644 --- a/tools/kwboot.c +++ b/tools/kwboot.c @@ -664,14 +664,6 @@ kwboot_img_patch_hdr(void *img, size_t size) hdr_v0->srcaddr = hdr_v0->ext ? sizeof(struct kwb_header) : sizeof(*hdr_v0); - } else { - /* - * Subtract mkimage header size from destination address - * as this header is not expected by the Marvell BootROM. - * This way, the execution address is identical to the - * one the image is compiled for (TEXT_BASE). - */ - hdr->destaddr = hdr->destaddr - sizeof(struct image_header); }
hdr->checksum = kwboot_img_csum8(hdr, hdrsz) - csum;
} else {
Applied to u-boot-marvell/master
Thanks, Stefan
Hi Chris,
On 14.02.2017 02:48, Chris Packham wrote: > > I just tried UART booting db-88f6820-amc with the latest u-boot master > and it fails to reach the normal u-boot prompt. I don't know if this > affects the normal SPI booting. > > I've bisected down to commit 94084eea3bd3 ("tools: kwbimage: Fix dest > addr").
> Reverting this gets things working again, but I'm guessing it'll break > secure boot. Should the size adjustment be conditional on something?
Might be, not sure.
> Does db-88f6820-amc_defconfig need something that the other armada > configs have enabled?
I don't think so.
Thanks for working on this, Chris. I'll pull your kwboot patch shortly so that its included in the upcoming release.
Thanks, Stefan
Chris Packham
Mario Six
Stefan Roese
