[U-Boot-Users] error when compile U-Boot
Hi,all.
I try to compile U-Boot (version u-boot-1.1.2), after #make all
and there print mistake as :
arm-linux-gcc -Wa,-gstabs -D__ASSEMBLY__ -g -Os -fno-strict-aliasing -fno-common -ffixed-r8 -mshort-load-bytes -msoft-float -D__KERNEL__ -DTEXT_BASE=0xa3080000 -I/root/download/u-boot-1.1.1/include -fno-builtin -ffreestanding -nostdinc -isystem /usr/lib/gcc-lib/i386-redhat-linux/3.3.2/include -pipe -DCONFIG_ARM -D__ARM__ -mapcs-32 -march=armv5 -mtune=strongarm1100 -c -o cpu/pxa/start.o /root/download/u-boot-1.1.1/cpu/pxa/start.S /root/download/u-boot-1.1.1/cpu/pxa/start.S: Assembler messages: /root/download/u-boot-1.1.1/cpu/pxa/start.S:121: Error: internal_relocation (type: OFFSET_IMM) not fixed up /root/download/u-boot-1.1.1/cpu/pxa/start.S:122: Error: internal_relocation (type: OFFSET_IMM) not fixed up /root/download/u-boot-1.1.1/cpu/pxa/start.S:143: Error: internal_relocation (type: OFFSET_IMM) not fixed up /root/download/u-boot-1.1.1/cpu/pxa/start.S:145: Error: internal_relocation (type: OFFSET_IMM) not fixed up /root/download/u-boot-1.1.1/cpu/pxa/start.S:360: Error: internal_relocation (type: OFFSET_IMM) not fixed up
my arm-linux-gcc's version is 3.2.1 . Is it the problem from? I hear that if using version 2.X.X will work , is it? How can I overcome the problem using arm-linux-gcc(ver 3.2.1)?
Thanks !
Kenton Lau
Kenton Lau
