[U-Boot] [PATCH v3] crypto/fsl: fix BLOB encapsulation and decapsulation
The blob_encap and blob_decap functions were not flushing the dcache before passing data to CAAM/DMA and not invalidating the dcache when getting data back. Therefore, blob encapsulation and decapsulation failed with errors like the following due to data cache incoherency: "40000006: DECO: desc idx 0: Invalid KEY command"
To ensure coherency, we require the key_mod, src and dst buffers to be aligned to the cache line size and flush/invalidate the memory regions. The same requirements apply to the job descriptor.
Tested on an i.MX6Q board.
Signed-off-by: Clemens Gruber clemens.gruber@pqgruber.com ---
Changes since v2: - Removed copying to aligned buffers and require addresses to be aligned - Added function comments and notes about the alignment requirements - Added parentheses around BLOB_SIZE macro parameter x - Adapted commit text
Changes since v1: - Moved BLOB_SIZE define to be available for all platforms (Fabio)
drivers/crypto/fsl/fsl_blob.c | 103 ++++++++++++++++++++++++++++++++++++------ include/fsl_sec.h | 4 +- 2 files changed, 91 insertions(+), 16 deletions(-)
diff --git a/drivers/crypto/fsl/fsl_blob.c b/drivers/crypto/fsl/fsl_blob.c index 38c6f9486b..cb315dfd89 100644 --- a/drivers/crypto/fsl/fsl_blob.c +++ b/drivers/crypto/fsl/fsl_blob.c @@ -7,63 +7,138 @@
#include <common.h> #include <malloc.h> +#include <memalign.h> #include <fsl_sec.h> #include <linux/errno.h> #include "jobdesc.h" #include "desc.h" #include "jr.h"
+/** + * blob_decap() - Decapsulate the data from a blob + * @key_mod: - Key modifier address + * @src: - Source address (blob) + * @dst: - Destination address (data) + * @len: - Size of decapsulated data + * + * Note: Start and end of the key_mod, src and dst buffers have to be aligned to + * the cache line size (ARCH_DMA_MINALIGN) for the CAAM operation to succeed. + * + * Returns zero on success, negative on error. + */ int blob_decap(u8 *key_mod, u8 *src, u8 *dst, u32 len) { - int ret, i = 0; + int ret, size, i = 0; u32 *desc;
+ if (!IS_ALIGNED((uintptr_t)key_mod, ARCH_DMA_MINALIGN) || + !IS_ALIGNED((uintptr_t)src, ARCH_DMA_MINALIGN) || + !IS_ALIGNED((uintptr_t)dst, ARCH_DMA_MINALIGN)) { + puts("Error: blob_decap: Address arguments are not aligned!\n"); + return -EINVAL; + } + printf("\nDecapsulating blob to get data\n"); - desc = malloc(sizeof(int) * MAX_CAAM_DESCSIZE); + desc = malloc_cache_aligned(sizeof(int) * MAX_CAAM_DESCSIZE); if (!desc) { debug("Not enough memory for descriptor allocation\n"); - return -1; + return -ENOMEM; }
+ size = ALIGN(16, ARCH_DMA_MINALIGN); + flush_dcache_range((unsigned long)key_mod, + (unsigned long)key_mod + size); + + size = ALIGN(BLOB_SIZE(len), ARCH_DMA_MINALIGN); + flush_dcache_range((unsigned long)src, + (unsigned long)src + size); + inline_cnstr_jobdesc_blob_decap(desc, key_mod, src, dst, len);
debug("Descriptor dump:\n"); for (i = 0; i < 14; i++) debug("Word[%d]: %08x\n", i, *(desc + i)); + + size = ALIGN(sizeof(int) * MAX_CAAM_DESCSIZE, ARCH_DMA_MINALIGN); + flush_dcache_range((unsigned long)desc, + (unsigned long)desc + size); + ret = run_descriptor_jr(desc);
- if (ret) - printf("Error in Decapsulation %d\n", ret); - else - printf("Decapsulation Success\n"); + if (ret) { + printf("Error in blob decapsulation: %d\n", ret); + } else { + size = ALIGN(len, ARCH_DMA_MINALIGN); + invalidate_dcache_range((unsigned long)dst, + (unsigned long)dst + size); + + puts("Blob decapsulation successful.\n"); + }
free(desc); return ret; }
+/** + * blob_encap() - Encapsulate the data as a blob + * @key_mod: - Key modifier address + * @src: - Source address (data) + * @dst: - Destination address (blob) + * @len: - Size of data to be encapsulated + * + * Note: Start and end of the key_mod, src and dst buffers have to be aligned to + * the cache line size (ARCH_DMA_MINALIGN) for the CAAM operation to succeed. + * + * Returns zero on success, negative on error. + */ int blob_encap(u8 *key_mod, u8 *src, u8 *dst, u32 len) { - int ret, i = 0; + int ret, size, i = 0; u32 *desc;
+ if (!IS_ALIGNED((uintptr_t)key_mod, ARCH_DMA_MINALIGN) || + !IS_ALIGNED((uintptr_t)src, ARCH_DMA_MINALIGN) || + !IS_ALIGNED((uintptr_t)dst, ARCH_DMA_MINALIGN)) { + puts("Error: blob_encap: Address arguments are not aligned!\n"); + return -EINVAL; + } + printf("\nEncapsulating data to form blob\n"); - desc = malloc(sizeof(int) * MAX_CAAM_DESCSIZE); + desc = malloc_cache_aligned(sizeof(int) * MAX_CAAM_DESCSIZE); if (!desc) { debug("Not enough memory for descriptor allocation\n"); - return -1; + return -ENOMEM; }
+ size = ALIGN(16, ARCH_DMA_MINALIGN); + flush_dcache_range((unsigned long)key_mod, + (unsigned long)key_mod + size); + + size = ALIGN(len, ARCH_DMA_MINALIGN); + flush_dcache_range((unsigned long)src, + (unsigned long)src + size); + inline_cnstr_jobdesc_blob_encap(desc, key_mod, src, dst, len);
- if (ret) - printf("Error in Encapsulation %d\n", ret); - else - printf("Encapsulation Success\n"); + if (ret) { + printf("Error in blob encapsulation: %d\n", ret); + } else { + size = ALIGN(BLOB_SIZE(len), ARCH_DMA_MINALIGN); + invalidate_dcache_range((unsigned long)dst, + (unsigned long)dst + size); + + puts("Blob encapsulation successful.\n"); + }
free(desc); return ret; diff --git a/include/fsl_sec.h b/include/fsl_sec.h index 61c671d6c7..a2f5f5a5f1 100644 --- a/include/fsl_sec.h +++ b/include/fsl_sec.h @@ -215,6 +215,8 @@ struct sg_entry { #define SG_ENTRY_OFFSET_SHIFT 0 };
+#define BLOB_SIZE(x) ((x) + 32 + 16) /* Blob buffer size */ + #if defined(CONFIG_MX6) || defined(CONFIG_MX7) /* Job Ring Base Address */ #define JR_BASE_ADDR(x) (CONFIG_SYS_FSL_SEC_ADDR + 0x1000 * (x + 1)) @@ -274,8 +276,6 @@ struct sg_entry { #define PERM 0x0000B008 /* Clear on release, lock SMAP * lock SMAG group 1 Blob */
-#define BLOB_SIZE(x) (x + 32 + 16) /* Blob buffer size */ - /* HAB WRAPPED KEY header */ #define WRP_HDR_SIZE 0x08 #define HDR_TAG 0x81
This has passed Travis-CI here, and I will apply it directly if there's no objections, thanks!
-----Original Message----- From: Clemens Gruber [mailto:clemens.gruber@pqgruber.com] Sent: Monday, January 08, 2018 12:56 AM To: York Sun york.sun@nxp.com Cc: u-boot@lists.denx.de; Fabio Estevam fabio.estevam@nxp.com; Tom Rini trini@konsulko.com; Vini Pillai vinitha.pillai@nxp.com; Ruchika Gupta ruchika.gupta@nxp.com; Breno Matheus Lima breno.lima@nxp.com; Fabio Estevam festevam@gmail.com; Sumit Garg sumit.garg@nxp.com; Arun Pathak arun.pathak@nxp.com; Jaiprakash Singh jaiprakash.singh@nxp.com; Clemens Gruber clemens.gruber@pqgruber.com Subject: [PATCH v3] crypto/fsl: fix BLOB encapsulation and decapsulation
Changes since v2:
Changes since v1:
Reviewed-by: Sumit Garg sumit.garg@nxp.com
Reviewed-by: Sumit Garg sumit.garg@nxp.com Signed-off-by: Clemens Gruber clemens.gruber@pqgruber.com
Clemens Gruber
Sumit Garg
