[U-Boot] [PATCH sunxi-tools v2 0/2] Support unified u-boot SPL for SD cards and FEL mode
An updated variant of the older patch http://lists.denx.de/pipermail/u-boot/2015-February/204024.html
These patches are not for the u-boot code (unless u-boot decides to cannibalize the 'fel' tool later) but still provide a glue layer between the Allwinner BROM code and the u-boot SPL code. And need to play nice with both of them.
The updated 'fel' tool is supposed to be used together with u-boot v2015.04 and provide support for booting regular u-boot SPL binaries over USB via FEL mode. So that a special u-boot sunxi FEL configuration can be eventually dropped in the future.
The usage instructions are in the 'New method of booting u-boot over USB (u-boot v2015.04 and later versions)' section of the linux-sunxi wiki page http://linux-sunxi.org/index.php?title=FEL/USBBoot&oldid=12979
It temporarily moves the BROM data from the first 32 KiB of SRAM into a different SRAM section before calling the SPL code. And then moves it back before returning from the SPL back to the FEL code in BROM. This provides a contiguous 32 KiB block in the beginning of SRAM for use by the SPL. And in the case if an extra SRAM section is not available, we can at least "defragmemnt" the free memory areas and still provide a contiguous ~21 KiB block to the SPL in the beginning of SRAM.
This code is also available in the following branch: https://github.com/ssvb/sunxi-tools/commits/20150206-fel-large-spl-support
Siarhei Siamashka (2): fel: Split 'aw_fel_get_version' into 'get' and 'print' variants fel: New command for loading U-Boot SPL binaries in eGON format
fel-to-spl-thunk.S | 172 +++++++++++++++++++++++++++++++ fel-to-spl-thunk.h | 69 +++++++++++++ fel.c | 291 +++++++++++++++++++++++++++++++++++++++++++++++++---- 3 files changed, 510 insertions(+), 22 deletions(-) create mode 100644 fel-to-spl-thunk.S create mode 100644 fel-to-spl-thunk.h
Now aw_fel_get_version() can get the SoC ID for internal usage from the other functions. And aw_fel_print_version() is used to print the formatted string to stdout.
Signed-off-by: Siarhei Siamashka siarhei.siamashka@gmail.com --- Changes in v2: - This code has been isolated into a separate patch. No other changes.
fel.c | 53 +++++++++++++++++++++++++++++++---------------------- 1 file changed, 31 insertions(+), 22 deletions(-)
diff --git a/fel.c b/fel.c index c21d6ec..542bf4b 100644 --- a/fel.c +++ b/fel.c @@ -41,6 +41,17 @@ struct aw_usb_request { char pad[10]; } __attribute__((packed));
+struct aw_fel_version { + char signature[8]; + uint32_t soc_id; /* 0x00162300 */ + uint32_t unknown_0a; /* 1 */ + uint16_t protocol; /* 1 */ + uint8_t unknown_12; /* 0x44 */ + uint8_t unknown_13; /* 0x08 */ + uint32_t scratchpad; /* 0x7e00 */ + uint32_t pad[2]; /* unused */ +} __attribute__((packed)); + static const int AW_USB_READ = 0x11; static const int AW_USB_WRITE = 0x12;
@@ -136,32 +147,27 @@ void aw_read_fel_status(libusb_device_handle *usb) aw_usb_read(usb, &buf, sizeof(buf)); }
-void aw_fel_get_version(libusb_device_handle *usb) +void aw_fel_get_version(libusb_device_handle *usb, struct aw_fel_version *buf) { - struct aw_fel_version { - char signature[8]; - uint32_t soc_id; /* 0x00162300 */ - uint32_t unknown_0a; /* 1 */ - uint16_t protocol; /* 1 */ - uint8_t unknown_12; /* 0x44 */ - uint8_t unknown_13; /* 0x08 */ - uint32_t scratchpad; /* 0x7e00 */ - uint32_t pad[2]; /* unused */ - } __attribute__((packed)) buf; - aw_send_fel_request(usb, AW_FEL_VERSION, 0, 0); - aw_usb_read(usb, &buf, sizeof(buf)); + aw_usb_read(usb, buf, sizeof(*buf)); aw_read_fel_status(usb);
- buf.soc_id = le32toh(buf.soc_id); - buf.unknown_0a = le32toh(buf.unknown_0a); - buf.protocol = le32toh(buf.protocol); - buf.scratchpad = le16toh(buf.scratchpad); - buf.pad[0] = le32toh(buf.pad[0]); - buf.pad[1] = le32toh(buf.pad[1]); + buf->soc_id = (le32toh(buf->soc_id) >> 8) & 0xFFFF; + buf->unknown_0a = le32toh(buf->unknown_0a); + buf->protocol = le32toh(buf->protocol); + buf->scratchpad = le16toh(buf->scratchpad); + buf->pad[0] = le32toh(buf->pad[0]); + buf->pad[1] = le32toh(buf->pad[1]); +} + +void aw_fel_print_version(libusb_device_handle *usb) +{ + struct aw_fel_version buf; + aw_fel_get_version(usb, &buf);
const char *soc_name="unknown"; - switch ((buf.soc_id >> 8) & 0xFFFF) { + switch (buf.soc_id) { case 0x1623: soc_name="A10";break; case 0x1625: soc_name="A13";break; case 0x1633: soc_name="A31";break; @@ -170,7 +176,10 @@ void aw_fel_get_version(libusb_device_handle *usb) case 0x1639: soc_name="A80";break; }
- printf("%.8s soc=%08x(%s) %08x ver=%04x %02x %02x scratchpad=%08x %08x %08x\n", buf.signature, buf.soc_id, soc_name, buf.unknown_0a, buf.protocol, buf.unknown_12, buf.unknown_13, buf.scratchpad, buf.pad[0], buf.pad[1]); + printf("%.8s soc=%08x(%s) %08x ver=%04x %02x %02x scratchpad=%08x %08x %08x\n", + buf.signature, buf.soc_id, soc_name, buf.unknown_0a, + buf.protocol, buf.unknown_12, buf.unknown_13, + buf.scratchpad, buf.pad[0], buf.pad[1]); }
void aw_fel_read(libusb_device_handle *usb, uint32_t offset, void *buf, size_t len) @@ -387,7 +396,7 @@ int main(int argc, char **argv) aw_fel_execute(handle, strtoul(argv[2], NULL, 0)); skip=3; } else if (strncmp(argv[1], "ver", 3) == 0 && argc > 1) { - aw_fel_get_version(handle); + aw_fel_print_version(handle); skip=1; } else if (strcmp(argv[1], "write") == 0 && argc > 3) { size_t size;
Now it is possible to load and execute the same U-Boot SPL, as used for booting from SD cards. Just a different delivery method (a USB OTG cable instead of an SD card) for handling exactly the same content.
The only argument for this new command is the name of the SPL binary file (with a eGON header generated by the 'mksunxiboot' tool). Now the 'fel' tool can be run as:
fel spl u-boot-sunxi-with-spl.bin
Before this change, the SPL was only able to use the memory between addresses 0x2000 and ~0x5D00, totalling to something like ~15 KiB. This is the biggest contiguous area in SRAM, which is not used by the FEL code from the BROM. Unfortunately, it is rather small. And also the unusual starting offset was making it difficult to use the same SPL binary for booting from the SD card and via FEL.
There are surely more unused parts of SRAM, but they are scattered across multiple locations, primarily because the FEL code from the BROM sets up two stacks at inconvenient locations (the IRQ handler stack at 0x2000, and a regular stack at 0x7000). Essentially, the problem to solve here is to ensure a sufficiently large and consistent SRAM address space for the SPL without any potentially SoC specific holes in the case of booting over USB via FEL.
This is achieved by injecting special entry/exit thunk code, which is moving the data in SRAM to provide a contiguous space for the SPL at the beginning of SRAM, while still preserving the the data from the BROM elsewhere. When the SPL tries to return control back to the FEL code in the BROM, the thunk code moves the data back to its original place. Additionally, the eGON checksum is verified to ensure that no data corruption has happened due to some unexpected clash with the FEL protocol code from the BROM.
So the thunk code takes care of the address space allocation uglyness and provides the U-Boot SPL with a somewhat nicer abstraction. Now the FEL booted SPL on A10/A13/A20/A31 can use up to 32 KiB of SRAM because the BROM data is saved to different SRAM section. There is also generic code, which does not rely on extra SRAM sections, but just glues together the unused free space from both BROM FEL stacks to provide something like ~21 KiB to the SPL.
Signed-off-by: Siarhei Siamashka siarhei.siamashka@gmail.com --- Changes in v2: - Return to the BROM FEL code instead of trying to re-start it by jumping to the 0xffff0020 address. The USB connection re-initialization is too unreliable in practice. - Detect if the cache is enabled and refuse to work in this case - Overwrite the "eGON.BT0" signature in memory with "eGON.FEL" if everything is fine. And overwrite it with "eGON.BAD" if a checksum error had been detected.
fel-to-spl-thunk.S | 172 ++++++++++++++++++++++++++++++++++++++ fel-to-spl-thunk.h | 69 ++++++++++++++++ fel.c | 238 +++++++++++++++++++++++++++++++++++++++++++++++++++++ 3 files changed, 479 insertions(+) create mode 100644 fel-to-spl-thunk.S create mode 100644 fel-to-spl-thunk.h
diff --git a/fel-to-spl-thunk.S b/fel-to-spl-thunk.S new file mode 100644 index 0000000..93350b3 --- /dev/null +++ b/fel-to-spl-thunk.S @@ -0,0 +1,172 @@ +/* + * Copyright © 2015 Siarhei Siamashka siarhei.siamashka@gmail.com + * + * Permission is hereby granted, free of charge, to any person obtaining a + * copy of this software and associated documentation files (the "Software"), + * to deal in the Software without restriction, including without limitation + * the rights to use, copy, modify, merge, publish, distribute, sublicense, + * and/or sell copies of the Software, and to permit persons to whom the + * Software is furnished to do so, subject to the following conditions: + * + * The above copyright notice and this permission notice (including the next + * paragraph) shall be included in all copies or substantial portions of the + * Software. + * + * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR + * IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY, + * FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL + * THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER + * LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING + * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER + * DEALINGS IN THE SOFTWARE. + */ + +/*************************************************************************/ +/* Usage instructions: "ruby -x fel-to-spl-thunk.S > fel-to-spl-thunk.h" */ +/*************************************************************************/ + +#if 0 +#!/usr/bin/env ruby + +def tool_exists(tool_name) + `which #{tool_name} > /dev/null 2>&1` + return $?.to_i == 0 +end + +toolchains = [ + "arm-none-eabi-", + "arm-linux-gnueabihf-", + "arm-none-linux-gnueabi-", + "armv7a-hardfloat-linux-gnueabi-", +] + +toolchain = toolchains.find { |toolchain| tool_exists("#{toolchain}gcc") } +abort "Can't find any ARM crosscompiler\n" unless toolchain + +system("#{toolchain}gcc -o #{$PROGRAM_NAME}.o -c #{$PROGRAM_NAME}") +exit($?.to_i) if $?.to_i != 0 + +`#{toolchain}objdump -d #{$PROGRAM_NAME}.o`.each_line {|l| + next unless l =~ /(\h+):\s+(\h+)\s+(\S+)\s+([^;]*)/ + printf("\t0x%s, /* %8s: %-10s %-28s */\n", $2, $1, $3, $4.strip) +} + +__END__ +#endif + +/*************************************************************************/ + +BUF1 .req r0 +BUF2 .req r1 +TMP1 .req r2 +TMP2 .req r3 +SWAPTBL .req r4 +FULLSIZE .req r5 +BUFSIZE .req r6 +CHECKSUM .req r7 + +entry_point: + b setup_stack + +stack_begin: + nop + nop + nop + nop + nop + nop + nop + nop +stack_end: + nop + + /* A function, which walks the table and swaps all buffers */ +swap_all_buffers: + adr SWAPTBL, swaptbl_start +swap_next_buffer: + ldr BUF1, [SWAPTBL], #4 + ldr BUF2, [SWAPTBL], #4 + ldr BUFSIZE, [SWAPTBL], #4 + cmp BUFSIZE, #0 + bxeq lr +swap_next_word: + ldr TMP1, [BUF1] + ldr TMP2, [BUF2] + subs BUFSIZE, BUFSIZE, #4 + str TMP1, [BUF2], #4 + str TMP2, [BUF1], #4 + bne swap_next_word + b swap_next_buffer + +setup_stack: /* Save the original SP, LR and CPSR to stack */ + adr BUF1, stack_end + str sp, [BUF1, #-4]! + mov sp, BUF1 + mrs TMP1, cpsr + push {TMP1, lr} + + /* Disable IRQ and FIQ */ + orr TMP1, #0xc0 + msr cpsr_c, TMP1 + + /* Check if the instructions or data cache is enabled */ + mrc p15, 0, TMP1, c1, c0, 0 + movw TMP2, #((1 << 12) | (1 << 2)) + tst TMP1, TMP2 + bne cache_is_unsupported + + bl swap_all_buffers + +verify_checksum: + movw CHECKSUM, #0x6c39 + movt CHECKSUM, #0x5f0a + mov BUF1, #0 + ldr FULLSIZE, [BUF1, #16] +check_next_word: + ldr TMP1, [BUF1], #4 + subs FULLSIZE, FULLSIZE, #4 + add CHECKSUM, CHECKSUM, TMP1 + bne check_next_word + + mov BUF1, #0 + ldr TMP1, [BUF1, #12] + subs CHECKSUM, CHECKSUM, TMP1, lsl #1 + bne checksum_is_bad + + /* Change 'eGON.BT0' -> 'eGON.FEL' */ + mov BUF1, #0 + movw TMP1, (('F' << 8) + '.') + movt TMP1, (('L' << 8) + 'E') + str TMP1, [BUF1, #8] + + /* Call the SPL code */ + dsb + isb + blx BUF1 + + /* Return back to FEL */ + b return_to_fel + +cache_is_unsupported: + /* Bail out if cache is enabled and change 'eGON.BT0' -> 'eGON.???' */ + mov BUF1, #0 + movw TMP1, (('?' << 8) + '.') + movt TMP1, (('?' << 8) + '?') + str TMP1, [BUF1, #8] + b return_to_fel + +checksum_is_bad: + /* The checksum test failed, so change 'eGON.BT0' -> 'eGON.BAD' */ + mov BUF1, #0 + movw TMP1, (('B' << 8) + '.') + movt TMP1, (('D' << 8) + 'A') + str TMP1, [BUF1, #8] + +return_to_fel: + bl swap_all_buffers + pop {TMP1, lr} + msr cpsr_c, TMP1 /* Restore the original CPSR */ + ldr sp, [sp] + bx lr + +swaptbl_start: diff --git a/fel-to-spl-thunk.h b/fel-to-spl-thunk.h new file mode 100644 index 0000000..08e90e7 --- /dev/null +++ b/fel-to-spl-thunk.h @@ -0,0 +1,69 @@ + 0xea000015, /* 0: b 5c <setup_stack> */ + 0xe1a00000, /* 4: nop */ + 0xe1a00000, /* 8: nop */ + 0xe1a00000, /* c: nop */ + 0xe1a00000, /* 10: nop */ + 0xe1a00000, /* 14: nop */ + 0xe1a00000, /* 18: nop */ + 0xe1a00000, /* 1c: nop */ + 0xe1a00000, /* 20: nop */ + 0xe1a00000, /* 24: nop */ + 0xe28f40e4, /* 28: add r4, pc, #228 */ + 0xe4940004, /* 2c: ldr r0, [r4], #4 */ + 0xe4941004, /* 30: ldr r1, [r4], #4 */ + 0xe4946004, /* 34: ldr r6, [r4], #4 */ + 0xe3560000, /* 38: cmp r6, #0 */ + 0x012fff1e, /* 3c: bxeq lr */ + 0xe5902000, /* 40: ldr r2, [r0] */ + 0xe5913000, /* 44: ldr r3, [r1] */ + 0xe2566004, /* 48: subs r6, r6, #4 */ + 0xe4812004, /* 4c: str r2, [r1], #4 */ + 0xe4803004, /* 50: str r3, [r0], #4 */ + 0x1afffff9, /* 54: bne 40 <swap_next_word> */ + 0xeafffff3, /* 58: b 2c <swap_next_buffer> */ + 0xe24f0040, /* 5c: sub r0, pc, #64 */ + 0xe520d004, /* 60: str sp, [r0, #-4]! */ + 0xe1a0d000, /* 64: mov sp, r0 */ + 0xe10f2000, /* 68: mrs r2, CPSR */ + 0xe92d4004, /* 6c: push {r2, lr} */ + 0xe38220c0, /* 70: orr r2, r2, #192 */ + 0xe121f002, /* 74: msr CPSR_c, r2 */ + 0xee112f10, /* 78: mrc 15, 0, r2, cr1, cr0, {0} */ + 0xe3013004, /* 7c: movw r3, #4100 */ + 0xe1120003, /* 80: tst r2, r3 */ + 0x1a000014, /* 84: bne dc <cache_is_unsupported> */ + 0xebffffe6, /* 88: bl 28 <swap_all_buffers> */ + 0xe3067c39, /* 8c: movw r7, #27705 */ + 0xe3457f0a, /* 90: movt r7, #24330 */ + 0xe3a00000, /* 94: mov r0, #0 */ + 0xe5905010, /* 98: ldr r5, [r0, #16] */ + 0xe4902004, /* 9c: ldr r2, [r0], #4 */ + 0xe2555004, /* a0: subs r5, r5, #4 */ + 0xe0877002, /* a4: add r7, r7, r2 */ + 0x1afffffb, /* a8: bne 9c <check_next_word> */ + 0xe3a00000, /* ac: mov r0, #0 */ + 0xe590200c, /* b0: ldr r2, [r0, #12] */ + 0xe0577082, /* b4: subs r7, r7, r2, lsl #1 */ + 0x1a00000c, /* b8: bne f0 <checksum_is_bad> */ + 0xe3a00000, /* bc: mov r0, #0 */ + 0xe304262e, /* c0: movw r2, #17966 */ + 0xe3442c45, /* c4: movt r2, #19525 */ + 0xe5802008, /* c8: str r2, [r0, #8] */ + 0xf57ff04f, /* cc: dsb sy */ + 0xf57ff06f, /* d0: isb sy */ + 0xe12fff30, /* d4: blx r0 */ + 0xea000008, /* d8: b 100 <return_to_fel> */ + 0xe3a00000, /* dc: mov r0, #0 */ + 0xe3032f2e, /* e0: movw r2, #16174 */ + 0xe3432f3f, /* e4: movt r2, #16191 */ + 0xe5802008, /* e8: str r2, [r0, #8] */ + 0xea000003, /* ec: b 100 <return_to_fel> */ + 0xe3a00000, /* f0: mov r0, #0 */ + 0xe304222e, /* f4: movw r2, #16942 */ + 0xe3442441, /* f8: movt r2, #17473 */ + 0xe5802008, /* fc: str r2, [r0, #8] */ + 0xebffffc8, /* 100: bl 28 <swap_all_buffers> */ + 0xe8bd4004, /* 104: pop {r2, lr} */ + 0xe121f002, /* 108: msr CPSR_c, r2 */ + 0xe59dd000, /* 10c: ldr sp, [sp] */ + 0xe12fff1e, /* 110: bx lr */ diff --git a/fel.c b/fel.c index 542bf4b..d18a1d8 100644 --- a/fel.c +++ b/fel.c @@ -29,6 +29,7 @@ #include <stdlib.h> #include <stdio.h> #include <errno.h> +#include <unistd.h>
#include "endian_compat.h"
@@ -294,6 +295,237 @@ void aw_fel_fill(libusb_device_handle *usb, uint32_t offset, size_t size, unsign aw_fel_write(usb, buf, offset, size); }
+/* + * The 'sram_swap_buffers' structure is used to describe information about + * two buffers in SRAM, the content of which needs to be exchanged before + * calling the U-Boot SPL code and then exchanged again before returning + * control back to the FEL code from the BROM. + */ + +typedef struct { + uint32_t buf1; /* BROM buffer */ + uint32_t buf2; /* backup storage location */ + uint32_t size; /* buffer size */ +} sram_swap_buffers; + +/* + * Each SoC variant may have its own list of memory buffers to be exchanged + * and the information about the placement of the thunk code, which handles + * the transition of execution from the BROM FEL code to the U-Boot SPL and + * back. + * + * Note: the entries in the 'swap_buffers' tables need to be sorted by 'buf1' + * addresses. And the 'buf1' addresses are the BROM data buffers, while 'buf2' + * addresses are the intended backup locations. + */ +typedef struct { + uint32_t soc_id; /* ID of the SoC */ + uint32_t thunk_addr; /* Address of the thunk code */ + uint32_t thunk_size; /* Maximal size of the thunk code */ + sram_swap_buffers *swap_buffers; +} soc_sram_info; + +/* + * The FEL code from BROM in A10/A13/A20 sets up two stacks for itself. One + * at 0x2000 (and growing down) for the IRQ handler. And another one at 0x7000 + * (and also growing down) for the regular code. In order to use the whole + * 32 KiB in the A1/A2 sections of SRAM, we need to temporarily move these + * stacks elsewhere. And the addresses above 0x7000 are also a bit suspicious, + * so it might be safer to backup the 0x7000-0x8000 area too. On A10/A13/A20 + * we can use the SRAM section A3 (0x8000) for this purpose. + */ +sram_swap_buffers a10_a13_a20_sram_swap_buffers[] = { + { .buf1 = 0x01800, .buf2 = 0x8000, .size = 0x800 }, + { .buf1 = 0x05C00, .buf2 = 0x8800, .size = 0x8000 - 0x5C00 }, + { 0 } /* End of the table */ +}; + +/* + * A31 is very similar to A10/A13/A20, except that it has no SRAM at 0x8000. + * So we use the SRAM section at 0x44000 instead. This is the memory, which + * is normally shared with the OpenRISC core (should we do an extra check to + * ensure that this core is powered off and can't interfere?). + */ +sram_swap_buffers a31_sram_swap_buffers[] = { + { .buf1 = 0x01800, .buf2 = 0x44000, .size = 0x800 }, + { .buf1 = 0x05C00, .buf2 = 0x44800, .size = 0x8000 - 0x5C00 }, + { 0 } /* End of the table */ +}; + +soc_sram_info soc_sram_info_table[] = { + { + .soc_id = 0x1623, /* Allwinner A10 */ + .thunk_addr = 0xAE00, .thunk_size = 0x200, + .swap_buffers = a10_a13_a20_sram_swap_buffers, + }, + { + .soc_id = 0x1625, /* Allwinner A13 */ + .thunk_addr = 0xAE00, .thunk_size = 0x200, + .swap_buffers = a10_a13_a20_sram_swap_buffers, + }, + { + .soc_id = 0x1651, /* Allwinner A20 */ + .thunk_addr = 0xAE00, .thunk_size = 0x200, + .swap_buffers = a10_a13_a20_sram_swap_buffers, + }, + { + .soc_id = 0x1633, /* Allwinner A31 */ + .thunk_addr = 0x46E00, .thunk_size = 0x200, + .swap_buffers = a31_sram_swap_buffers, + }, + { 0 } /* End of the table */ +}; + +/* + * This generic record assumes BROM with similar properties to A10/A13/A20/A31, + * but no extra SRAM sections beyond 0x8000. It also assumes that the IRQ + * handler stack usage never exceeds 0x400 bytes. + * + * The users may or may not hope that the 0x7000-0x8000 area is also unused + * by the BROM and re-purpose it for the SPL stack. + * + * The size limit for the ".text + .data" sections is ~21 KiB. + */ +sram_swap_buffers generic_sram_swap_buffers[] = { + { .buf1 = 0x01C00, .buf2 = 0x5800, .size = 0x400 }, + { 0 } /* End of the table */ +}; + +soc_sram_info generic_sram_info = { + .thunk_addr = 0x5680, .thunk_size = 0x180, + .swap_buffers = generic_sram_swap_buffers, +}; + +soc_sram_info *aw_fel_get_sram_info(libusb_device_handle *usb) +{ + int i; + struct aw_fel_version buf; + + aw_fel_get_version(usb, &buf); + + for (i = 0; soc_sram_info_table[i].swap_buffers; i++) + if (soc_sram_info_table[i].soc_id == buf.soc_id) + return &soc_sram_info_table[i]; + + printf("Warning: no 'soc_sram_info' data for your SoC (id=%04X)\n", + buf.soc_id); + return &generic_sram_info; +} + +static uint32_t fel_to_spl_thunk[] = { + #include "fel-to-spl-thunk.h" +}; + +void aw_fel_write_and_execute_spl(libusb_device_handle *usb, + uint8_t *buf, size_t len) +{ + soc_sram_info *sram_info = aw_fel_get_sram_info(usb); + sram_swap_buffers *swap_buffers; + char header_signature[9] = { 0 }; + size_t i, thunk_size; + uint32_t *thunk_buf; + uint32_t spl_checksum, spl_len, spl_len_limit = 0x8000; + uint32_t *buf32 = (uint32_t *)buf; + uint32_t written = 0; + + if (!sram_info || !sram_info->swap_buffers) { + fprintf(stderr, "SPL: Unsupported SoC type\n"); + exit(1); + } + + if (len < 32 || memcmp(buf + 4, "eGON.BT0", 8) != 0) { + fprintf(stderr, "SPL: eGON header is not found\n"); + exit(1); + } + + spl_checksum = 2 * le32toh(buf32[3]) - 0x5F0A6C39; + spl_len = le32toh(buf32[4]); + + if (spl_len > len || (spl_len % 4) != 0) { + fprintf(stderr, "SPL: bad length in the eGON header\n"); + exit(1); + } + + len = spl_len; + for (i = 0; i < len / 4; i++) + spl_checksum -= le32toh(buf32[i]); + + if (spl_checksum != 0) { + fprintf(stderr, "SPL: checksum check failed\n"); + exit(1); + } + + swap_buffers = sram_info->swap_buffers; + for (i = 0; swap_buffers[i].size; i++) { + if (swap_buffers[i].buf2 < spl_len_limit) + spl_len_limit = swap_buffers[i].buf2; + if (len > 0 && written < swap_buffers[i].buf1) { + uint32_t tmp = swap_buffers[i].buf1 - written; + if (tmp > len) + tmp = len; + aw_fel_write(usb, buf, written, tmp); + written += tmp; + buf += tmp; + len -= tmp; + } + if (len > 0 && written == swap_buffers[i].buf1) { + uint32_t tmp = swap_buffers[i].size; + if (tmp > len) + tmp = len; + aw_fel_write(usb, buf, swap_buffers[i].buf2, tmp); + written += tmp; + buf += tmp; + len -= tmp; + } + } + + /* Clarify the SPL size limitations, and bail out if they are not met */ + if (sram_info->thunk_addr < spl_len_limit) + spl_len_limit = sram_info->thunk_addr; + + if (spl_len > spl_len_limit) { + fprintf(stderr, "SPL: too large (need %d, have %d)\n", + (int)spl_len, (int)spl_len_limit); + exit(1); + } + + /* Write the remaining part of the SPL */ + if (len > 0) + aw_fel_write(usb, buf, written, len); + + thunk_size = sizeof(fel_to_spl_thunk) + (i + 1) * sizeof(*swap_buffers); + + if (thunk_size > sram_info->thunk_size) { + fprintf(stderr, "SPL: bad thunk size (need %d, have %d)\n", + (int)sizeof(fel_to_spl_thunk), sram_info->thunk_size); + exit(1); + } + + thunk_buf = malloc(thunk_size); + memcpy(thunk_buf, fel_to_spl_thunk, sizeof(fel_to_spl_thunk)); + memcpy(thunk_buf + sizeof(fel_to_spl_thunk) / sizeof(uint32_t), + swap_buffers, (i + 1) * sizeof(*swap_buffers)); + + for (i = 0; i < thunk_size / sizeof(uint32_t); i++) + thunk_buf[i] = htole32(thunk_buf[i]); + + aw_fel_write(usb, thunk_buf, sram_info->thunk_addr, thunk_size); + aw_fel_execute(usb, sram_info->thunk_addr); + + free(thunk_buf); + + /* TODO: Try to find and fix the bug, which needs this workaround */ + usleep(250000); + + /* Read back the result and check if everything was fine */ + aw_fel_read(usb, 4, header_signature, 8); + if (strcmp(header_signature, "eGON.FEL") != 0) { + fprintf(stderr, "SPL: failure code '%s'\n", + header_signature); + exit(1); + } +} + static int aw_fel_get_endpoint(libusb_device_handle *usb) { struct libusb_device *dev = libusb_get_device(usb); @@ -352,6 +584,7 @@ int main(int argc, char **argv) " ver[sion] Show BROM version\n" " clear address length Clear memory\n" " fill address length value Fill memory\n" + " spl file Load and execute U-Boot SPL\n" , argv[0] ); } @@ -417,6 +650,11 @@ int main(int argc, char **argv) } else if (strcmp(argv[1], "fill") == 0 && argc > 3) { aw_fel_fill(handle, strtoul(argv[2], NULL, 0), strtoul(argv[3], NULL, 0), (unsigned char)strtoul(argv[4], NULL, 0)); skip=4; + } else if (strcmp(argv[1], "spl") == 0 && argc > 2) { + size_t size; + uint8_t *buf = load_file(argv[2], &size); + aw_fel_write_and_execute_spl(handle, buf, size); + skip=2; } else { fprintf(stderr,"Invalid command %s\n", argv[1]); exit(1);
Hi Siarhei,
On 8 February 2015 at 19:37, Siarhei Siamashka siarhei.siamashka@gmail.com wrote:
It's an interesting idea actually - I wonder what people think about putting these tools in the source tree. I suspect it could get a bit out of hand? But it would make it easier to keep things in sync,
[snip]
On Mon, 9 Feb 2015 15:14:51 -0700 Simon Glass sjg@chromium.org wrote:
Hi Siarhei,
Yes, keeping it is sync with the mksunxiboot program would be easier in this case.
But I searched a bit, and can see that sunxi-tools is already packaged in some linux distributions, for example:
https://packages.debian.org/search?keywords=sunxi-tools
Maybe it's better to keep the 'fel' tool in the 'sunxi-tools' package and just make sure that it gets reasonably well supported in linux distributions.
In addition, there might be other bootloaders or "bare metal" users. I have found this very cool project, which relies on the FEL mode and allows to run code on the OpenRISC core in Allwinner A31:
https://github.com/skristiansson/ar100-info
What's particularly interesting is that it apparently had the DRAM controller support for A31 (sun6i) even before this was implemented in u-boot :)
These patches are not for the u-boot code (unless u-boot decides to cannibalize the 'fel' tool later) but still provide a glue layerHi, between the Allwinner BROM code and the u-boot SPL code. And need to play nice with both of them.
Thanks for your work on this, ACK to both patches, feel free to push them.
One question, the new wiki instructions say that for the latest upstream u-boot _felconfig is no longer necessary, but Simon's patches to fix FEL support upstream contain some #ifdef FEL in start.S to skip some lowlevel init when in FEL mode, does that mean that skipping this is no longer necessary ?
Regards,
Hans
Thanks, pushed to sunxi-tool
Skipping is not necessary if we save/restore some additional registers instead. I'm just applying extra changes on top of Simon's patches, and it works (the wiki page links to the git branch with these changes). This is discussed at
http://lists.denx.de/pipermail/u-boot/2015-February/204361.html
Hans de Goede
Siarhei Siamashka
