[U-Boot] [PATCH 1/2] arm64: ls1046a: Add sata distro boot support
Sata is equipped on ls1046a and can be a boot source. Add sata boot support as a option if available.
Signed-off-by: Tang Yuantian andy.tang@nxp.com --- include/configs/ls1046a_common.h | 13 +++++++++++++ include/configs/ls1046aqds.h | 10 ---------- include/configs/ls1046ardb.h | 12 ------------ 3 files changed, 13 insertions(+), 22 deletions(-)
diff --git a/include/configs/ls1046a_common.h b/include/configs/ls1046a_common.h index e208f7d..309bfd8 100644 --- a/include/configs/ls1046a_common.h +++ b/include/configs/ls1046a_common.h @@ -145,6 +145,18 @@ #define CONFIG_PCI_SCAN_SHOW #endif
+/* SATA */ +#ifndef SPL_NO_SATA +#define CONFIG_SCSI_AHCI_PLAT + +#define CONFIG_SYS_SATA AHCI_BASE_ADDR + +#define CONFIG_SYS_SCSI_MAX_SCSI_ID 1 +#define CONFIG_SYS_SCSI_MAX_LUN 1 +#define CONFIG_SYS_SCSI_MAX_DEVICE (CONFIG_SYS_SCSI_MAX_SCSI_ID * \ + CONFIG_SYS_SCSI_MAX_LUN) +#endif + /* Command line configuration */
/* MMC */ @@ -201,6 +213,7 @@ #include <config_distro_defaults.h> #ifndef CONFIG_SPL_BUILD #define BOOT_TARGET_DEVICES(func) \ + func(SCSI, scsi, 0) \ func(MMC, mmc, 0) \ func(USB, usb, 0) #include <config_distro_bootcmd.h> diff --git a/include/configs/ls1046aqds.h b/include/configs/ls1046aqds.h index c3b0f4d..456f61a 100644 --- a/include/configs/ls1046aqds.h +++ b/include/configs/ls1046aqds.h @@ -136,9 +136,6 @@ unsigned long get_board_ddr_clk(void); #define CFG_LPUART_EN 0x2 #endif
-/* SATA */ -#define CONFIG_SCSI_AHCI_PLAT - /* EEPROM */ #define CONFIG_ID_EEPROM #define CONFIG_SYS_I2C_EEPROM_NXID @@ -148,13 +145,6 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_SYS_EEPROM_PAGE_WRITE_BITS 3 #define CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS 5
-#define CONFIG_SYS_SATA AHCI_BASE_ADDR - -#define CONFIG_SYS_SCSI_MAX_SCSI_ID 1 -#define CONFIG_SYS_SCSI_MAX_LUN 1 -#define CONFIG_SYS_SCSI_MAX_DEVICE (CONFIG_SYS_SCSI_MAX_SCSI_ID * \ - CONFIG_SYS_SCSI_MAX_LUN) - /* * IFC Definitions */ diff --git a/include/configs/ls1046ardb.h b/include/configs/ls1046ardb.h index 784894f..f4f4fd7 100644 --- a/include/configs/ls1046ardb.h +++ b/include/configs/ls1046ardb.h @@ -209,18 +209,6 @@ #endif #endif
-/* SATA */ -#ifndef SPL_NO_SATA -#define CONFIG_SCSI_AHCI_PLAT - -#define CONFIG_SYS_SATA AHCI_BASE_ADDR - -#define CONFIG_SYS_SCSI_MAX_SCSI_ID 1 -#define CONFIG_SYS_SCSI_MAX_LUN 1 -#define CONFIG_SYS_SCSI_MAX_DEVICE (CONFIG_SYS_SCSI_MAX_SCSI_ID * \ - CONFIG_SYS_SCSI_MAX_LUN) -#endif - #ifndef SPL_NO_MISC #undef CONFIG_BOOTCOMMAND #if defined(CONFIG_QSPI_BOOT)
Sata is equipped on ls1012a and can be a boot source. Add sata boot support as a option if available.
Signed-off-by: Tang Yuantian andy.tang@nxp.com --- include/configs/ls1012a_common.h | 11 +++++++++++ include/configs/ls1012aqds.h | 10 ---------- include/configs/ls1012ardb.h | 9 --------- 3 files changed, 11 insertions(+), 19 deletions(-)
diff --git a/include/configs/ls1012a_common.h b/include/configs/ls1012a_common.h index db920bc..c57c08e 100644 --- a/include/configs/ls1012a_common.h +++ b/include/configs/ls1012a_common.h @@ -69,6 +69,16 @@ #define CONFIG_ENV_SECT_SIZE 0x40000 #endif
+/* SATA */ +#define CONFIG_SCSI_AHCI_PLAT + +#define CONFIG_SYS_SATA AHCI_BASE_ADDR + +#define CONFIG_SYS_SCSI_MAX_SCSI_ID 1 +#define CONFIG_SYS_SCSI_MAX_LUN 1 +#define CONFIG_SYS_SCSI_MAX_DEVICE (CONFIG_SYS_SCSI_MAX_SCSI_ID * \ + CONFIG_SYS_SCSI_MAX_LUN) + /* I2C */ #define CONFIG_SYS_I2C #define CONFIG_SYS_I2C_MXC @@ -90,6 +100,7 @@ #include <config_distro_defaults.h> #ifndef CONFIG_SPL_BUILD #define BOOT_TARGET_DEVICES(func) \ + func(SCSI, scsi, 0) \ func(MMC, mmc, 0) \ func(USB, usb, 0) #include <config_distro_bootcmd.h> diff --git a/include/configs/ls1012aqds.h b/include/configs/ls1012aqds.h index af5f37c..47d863a 100644 --- a/include/configs/ls1012aqds.h +++ b/include/configs/ls1012aqds.h @@ -124,16 +124,6 @@ #define CONFIG_SYS_FSL_MMC_HAS_CAPBLT_VS33 #endif
-/* SATA */ -#define CONFIG_SCSI_AHCI_PLAT - -#define CONFIG_SYS_SATA AHCI_BASE_ADDR - -#define CONFIG_SYS_SCSI_MAX_SCSI_ID 1 -#define CONFIG_SYS_SCSI_MAX_LUN 1 -#define CONFIG_SYS_SCSI_MAX_DEVICE (CONFIG_SYS_SCSI_MAX_SCSI_ID * \ - CONFIG_SYS_SCSI_MAX_LUN) - #define CONFIG_PCIE1 /* PCIE controller 1 */
#define CONFIG_PCI_SCAN_SHOW diff --git a/include/configs/ls1012ardb.h b/include/configs/ls1012ardb.h index ab139b0..438b5a6 100644 --- a/include/configs/ls1012ardb.h +++ b/include/configs/ls1012ardb.h @@ -46,15 +46,6 @@ #define CONFIG_SYS_FSL_MMC_HAS_CAPBLT_VS33 #endif
Minor change to commit message. Applied to fsl-qoriq master. Thanks.
York
York
York Sun
Yuantian Tang
