[U-Boot] [PATCH 1/4] powerpc: ppc4xx: Add missing type for SYS_MALLOC_F_LEN in Kconfig
Otherwise this symbol will not be created in the .config.
Signed-off-by: Stefan Roese sr@denx.de Cc: Simon Glass sjg@chromium.org --- board/amcc/canyonlands/Kconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/board/amcc/canyonlands/Kconfig b/board/amcc/canyonlands/Kconfig index bfdf17a..97df3f8 100644 --- a/board/amcc/canyonlands/Kconfig +++ b/board/amcc/canyonlands/Kconfig @@ -36,6 +36,7 @@ config DM_SERIAL default y
config SYS_MALLOC_F_LEN + hex "Size of the malloc() pool for use before relocation." default 0x400
config DEBUG_UART_BASE
This is necessary, as ppc4xx has the reset vector located at the end of the U-Boot image. This needs to be flashed to the end of the NOR flash. Adding the dtb to the main U-Boot image will break booting on ppc4xx. This patch now embeds the dtb in the U-Boot image instead.
Signed-off-by: Stefan Roese sr@denx.de Cc: Simon Glass sjg@chromium.org --- configs/canyonlands_defconfig | 2 +- configs/glacier_defconfig | 2 +- configs/glacier_ramboot_defconfig | 2 +- 3 files changed, 3 insertions(+), 3 deletions(-)
diff --git a/configs/canyonlands_defconfig b/configs/canyonlands_defconfig index 6f6cf14..44d4fbd 100644 --- a/configs/canyonlands_defconfig +++ b/configs/canyonlands_defconfig @@ -4,4 +4,4 @@ CONFIG_TARGET_CANYONLANDS=y CONFIG_CANYONLANDS=y CONFIG_DEFAULT_DEVICE_TREE="canyonlands" CONFIG_OF_CONTROL=y -CONFIG_OF_SEPARATE=y +CONFIG_OF_EMBED=y diff --git a/configs/glacier_defconfig b/configs/glacier_defconfig index e67fa32..d318f82 100644 --- a/configs/glacier_defconfig +++ b/configs/glacier_defconfig @@ -4,4 +4,4 @@ CONFIG_TARGET_CANYONLANDS=y CONFIG_GLACIER=y CONFIG_DEFAULT_DEVICE_TREE="glacier" CONFIG_OF_CONTROL=y -CONFIG_OF_SEPARATE=y +CONFIG_OF_EMBED=y diff --git a/configs/glacier_ramboot_defconfig b/configs/glacier_ramboot_defconfig index e5b402e..f8363b2 100644 --- a/configs/glacier_ramboot_defconfig +++ b/configs/glacier_ramboot_defconfig @@ -5,4 +5,4 @@ CONFIG_TARGET_CANYONLANDS=y CONFIG_GLACIER=y CONFIG_DEFAULT_DEVICE_TREE="glacier" CONFIG_OF_CONTROL=y -CONFIG_OF_SEPARATE=y +CONFIG_OF_EMBED=y
These additional nodes need to be provided to get U-Boot to boot correctly on the Canyonlands / Glacier board:
- chosen path to the console-uart - reg-shift set to 0 in the uart device nodes
Signed-off-by: Stefan Roese sr@denx.de Cc: Simon Glass sjg@chromium.org --- arch/powerpc/dts/canyonlands.dts | 6 ++++++ arch/powerpc/dts/glacier.dts | 3 +++ 2 files changed, 9 insertions(+)
diff --git a/arch/powerpc/dts/canyonlands.dts b/arch/powerpc/dts/canyonlands.dts index 2ec9762..0a2f5d7 100644 --- a/arch/powerpc/dts/canyonlands.dts +++ b/arch/powerpc/dts/canyonlands.dts @@ -22,6 +22,10 @@ serial1 = &UART1; };
+ chosen { + stdout-path = &UART0; + }; + cpus { #address-cells = <1>; #size-cells = <0>; @@ -280,6 +284,7 @@
UART0: serial@ef600300 { device_type = "serial"; + reg-shift = <0>; compatible = "ns16550"; reg = <0xef600300 0x00000008>; virtual-reg = <0xef600300>; @@ -291,6 +296,7 @@
UART1: serial@ef600400 { device_type = "serial"; + reg-shift = <0>; compatible = "ns16550"; reg = <0xef600400 0x00000008>; virtual-reg = <0xef600400>; diff --git a/arch/powerpc/dts/glacier.dts b/arch/powerpc/dts/glacier.dts index 3e7ce2c..bb4e819 100644 --- a/arch/powerpc/dts/glacier.dts +++ b/arch/powerpc/dts/glacier.dts @@ -251,6 +251,7 @@
UART1: serial@ef600400 { device_type = "serial"; + reg-shift = <0>; compatible = "ns16550"; reg = <0xef600400 0x00000008>; virtual-reg = <0xef600400>; @@ -262,6 +263,7 @@
UART2: serial@ef600500 { device_type = "serial"; + reg-shift = <0>; compatible = "ns16550"; reg = <0xef600500 0x00000008>; virtual-reg = <0xef600500>; @@ -273,6 +275,7 @@
UART3: serial@ef600600 { device_type = "serial"; + reg-shift = <0>; compatible = "ns16550"; reg = <0xef600600 0x00000008>; virtual-reg = <0xef600600>;
This also displays the "Board:" line in the bootup text with the generic board support code.
Signed-off-by: Stefan Roese sr@denx.de Cc: Simon Glass sjg@chromium.org --- board/amcc/canyonlands/Kconfig | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/board/amcc/canyonlands/Kconfig b/board/amcc/canyonlands/Kconfig index 97df3f8..3dc76ae 100644 --- a/board/amcc/canyonlands/Kconfig +++ b/board/amcc/canyonlands/Kconfig @@ -29,6 +29,10 @@ config ARCHES
endchoice
+config DISPLAY_BOARDINFO + bool + default y + config DM default y
Is there another patch which adds this in the top level Kconfig?
- Simon
No, not yet. At least not to my knowledge. Sorry, I missed adding it there. I'm still not used to adding the options correctly to Kconfig.
Thanks, Stefan
Hi Stefan,
I need to respin the series that added this option, so that this patch isn't needed.
Stefan Roese
