[U-Boot] mtdparts not agreeing wiht fw_printenv
I am quite confused about partitions in my NAND flash.
Linux can mount my rootfs, so partitions make sense to the kernel, but from the shell fw_printenv can't read the uboot environment, not matter what I use in /etc/fw_env.config.
uboot is reading the proper uboot env, and booting the system.
I am using u-boot-2013.01, buildroot-2011.11, 2.6.30 kernel, at91sam9g20ek.
/proc/cmdline: mem=64M console=ttyS0,115200 mtdparts=atmel_nand:0x0020000@0x00000000(bootstrap1)ro,0x0040000@0x00020000(uboot1)ro,0x01A0000@0x00060000(env1)ro,0x0200000@0x00200000(linux1),0x7C00000@0x00400000(rootfs1),0x0020000@0x08000000(bootstrap2)ro,0x0040000@0x08020000(uboot2)ro,0x01A0000@0x08060000(env2)ro,0x0200000@0x08200000(linux2),-@0x08400000(rootfs2);spi0.1-AT45DB642x:0x004200@0x0(bootstrap3)ro,0x004200@0x4200(env3)ro,0x039C00@0x8400(uboot3)ro,0x252000@0x42000(linux3),-@0x294000(rootfs3) root=/dev/mtdblock9 rw rootfstype=jffs2
/proc/mtd dev: size erasesize name mtd0: 00020000 00020000 "bootstrap1" mtd1: 00040000 00020000 "uboot1" mtd2: 001a0000 00020000 "env1" mtd3: 00200000 00020000 "linux1" mtd4: 07c00000 00020000 "rootfs1" mtd5: 00020000 00020000 "bootstrap2" mtd6: 00040000 00020000 "uboot2" mtd7: 001a0000 00020000 "env2" mtd8: 00200000 00020000 "linux2" mtd9: 07c00000 00020000 "rootfs2" mtd10: 00004200 00000420 "bootstrap3" mtd11: 00004200 00000420 "env3" mtd12: 00039c00 00000420 "uboot3" mtd13: 00252000 00000420 "linux3" mtd14: 005ac000 00000420 "rootfs3"
dmesg shows: NAND device: Manufacturer ID: 0x2c, Chip ID: 0xda (Micron NAND 256MiB 3,3V 8-bit) AT91 NAND: 8-bit, Software ECC Scanning device for bad blocks 10 cmdlinepart partitions found on MTD device atmel_nand Creating 10 MTD partitions on "atmel_nand": 0x000000000000-0x000000020000 : "bootstrap1" 0x000000020000-0x000000060000 : "uboot1" 0x000000060000-0x000000200000 : "env1" 0x000000200000-0x000000400000 : "linux1" 0x000000400000-0x000008000000 : "rootfs1" 0x000008000000-0x000008020000 : "bootstrap2" 0x000008020000-0x000008060000 : "uboot2" 0x000008060000-0x000008200000 : "env2" 0x000008200000-0x000008400000 : "linux2" 0x000008400000-0x000010000000 : "rootfs2" atmel_spi atmel_spi.0: Atmel SPI Controller at 0xfffc8000 (irq 12) mtd_dataflash spi0.1: AT45DB642x (8448 KBytes) pagesize 1056 bytes (OTP) 5 cmdlinepart partitions found on MTD device spi0.1-AT45DB642x Creating 5 MTD partitions on "spi0.1-AT45DB642x": 0x000000000000-0x000000004200 : "bootstrap3" 0x000000004200-0x000000008400 : "env3" 0x000000008400-0x000000042000 : "uboot3" 0x000000042000-0x000000294000 : "linux3" 0x000000294000-0x000000840000 : "rootfs3"
I purposefully created more /dev/mtd devices than mtdparts would require, in order to find which partitions actually contain the uboot env.
I used od -t xz /dev/mtd# to find the uboot environment partitions, Then used dd if=/dev/mtd# of=mtd#_env.bin to store the contents, so I could compare them.
/dev/mtd4 and /dev/mtd5 create binary equivalent dumps of env1 /dev/mtd14 and /dev/mtd15 create binary equivalent dumps of env2.
/etc/fw_env.config does not like either of those, saying the crc does not checkout.
/etc/fw_env.config: /dev/mtd2 0x0 0x20000 0x20000 /dev/mtd2 0x20000 0x20000 0x20000
fw_printenv Output: Warning: Bad CRC, using default environment ....
Can someone help explain this or what I might be doing wrong?
Dear John Stile,
That means that all settings were incorrect.
^^^^^^ mtd2
^^^^^^ mtd7
^^^^^^ mtd11
What's that? This makes no sense to me - either you have a single copy of the environment, or two (in case of redudant env). Three copies is not a supported configuration.
mtdparts does not "require" anything. You configure your systems as needed, and then set mtdparts to match that setting. SO the setting comes first (starting in your head or - probably better - on a sheet of paper), and then you set mtdparts as needed.
The names and use of your partitions is in serious mismatch. Fix this first!
Well, if you find the environment in /dev/mtd4 and /dev/mtd5, then you should use these in the fw_env.config
Dear Wolfgang Denk , On Thu, 2013-03-07 at 07:52 +0100, Wolfgang Denk wrote:
Dear John Stile,
All settings where not incorrect.
^^^^^^ mtd2
^^^^^^ mtd7
^^^^^^ mtd11
Right. Even without the /dev/mtd character device files, the system boots. This post comes way after a lot of work on paper.
The problem turned out to be due to my /dev/mtd character device files had sequential minor numbers.
Like I said, I think, even those did not work. When I created my /dev/mtd character device files to use even minor numbers, I was able to see my env in /dev/mtd2 /dev/mtd7 using od: od -t xz /dev/mtd2 od -t xz /dev/mtd7 And fw_printenv also worked.
One site said read-write device will have even minor numbers.
Since I am using a 2.6.30 kernel, without tmpdevfs, I rely on buildroot's target/generic/device_table_dev.txt to generate my devices, and it was there I had not set the proper values: # MTD stuff # <name> <type> <mode> <uid> <gid> <major> <minor> <start> <inc> <count> /dev/mtd c 640 0 0 90 0 0 2 20
Thank you for your help.
John Stile
