[U-Boot] [PATCH] armv8: fsl-layerscape: use IS_ENABLED()
We have to use IS_ENABLED() otherwise the compiler will throw an error if CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT is not set.
Signed-off-by: Michael Walle michael@walle.cc --- arch/arm/include/asm/arch-fsl-layerscape/fsl_icid.h | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/arm/include/asm/arch-fsl-layerscape/fsl_icid.h b/arch/arm/include/asm/arch-fsl-layerscape/fsl_icid.h index 37e2fe4e66..522c7b89df 100644 --- a/arch/arm/include/asm/arch-fsl-layerscape/fsl_icid.h +++ b/arch/arm/include/asm/arch-fsl-layerscape/fsl_icid.h @@ -166,7 +166,7 @@ extern int fman_icid_tbl_sz;
#define SET_SEC_JR_ICID_ENTRY(jr_num, streamid) \ SET_ICID_ENTRY( \ - (CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT && \ + (IS_ENABLED(CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT) && \ (FSL_SEC_JR##jr_num##_OFFSET == \ SEC_JR3_OFFSET + CONFIG_SYS_FSL_SEC_OFFSET) \ ? NULL \
-----Original Message----- From: U-Boot u-boot-bounces@lists.denx.de On Behalf Of Michael Walle Sent: Monday, October 21, 2019 11:03 PM To: u-boot@lists.denx.de Cc: Tom Rini trini@konsulko.com Subject: [U-Boot] [PATCH] armv8: fsl-layerscape: use IS_ENABLED()
\ (FSL_SEC_JR##jr_num##_OFFSET == \ SEC_JR3_OFFSET + CONFIG_SYS_FSL_SEC_OFFSET) \ ? NULL \ -- 2.20.1
__
Similar patch : https://patchwork.ozlabs.org/patch/1179214/ posted before Changing state to "not applicable"
--priyankajain
Michael Walle
Priyanka Jain
