[PATCH v6 0/6] arm: mvebu: Support for 98DX25xx/98DX35xx (AlleyCat5)
These patches are based on Marvell's bootloader for the AlleyCat5/5X which was based on u-boot 2018.03. I've split that code into consumable chunks and dropped as much unnecessary stuff as I can. I've also tried to sync the device trees as much as possible with the support that will land in Linux 6.0 although there are still some differences
Changes in v6: - Set CONFIG_DEFAULT_DEVICE_TREE and CONFIG_TEXT_BASE
Changes in v5: - Minor white space cleanups - Collect review from Stefan - Minor fixup for checkpatch.pl complaint - Remove unused bpard_{early,late}_init{,_r,_f} functions - Remove CPNFIG_PCI and CONFIG_E1000 as the PCI interface is not currently working (requires more vendor code) - Use CONFIG_OF_SEPARATE instead of CONFIG_OF_EMBED
Changes in v4: - Collect r-by from Stefan - Remove unused mvebu_get_nand_clock() (will return in a later series) - Remove unnecessary #ifdefs - Misc style cleanups - Replace CONFIG_MVEBU_SAR with simpler code implemented directly in soc.c based around get_sar_freq which the 32-bit platforms already use. - Move CONFIG_DISPLAY_BOARDINFO_LATE and CONFIG_ENV_OVERWRITE to the defconfig. - Remove CONFIG_BAUDRATE as this is already set in the default config - Remove CONFIG_USB_MAX_CONTROLLER_COUNT as this is not needed with DM_USB - Remove CONFIG_PREBOOT as we don't have anything to run - Remove commented out CONFIG_BOARD_EARLY_INIT_R - Remove DEBUG_UART configuration - Remove unnecessary console environment variable - Remove CONFIG_MVEBU_SAR
Changes in v3: - Remove unnecessary changes to RX descriptor handling - Use dev_get_dma_range() to parse dma-ranges property from parent device. - Remove unnecessary dma-ranges property from ethernet nodes (mvneta now correctly parses the property from the parent node). - Keep soc_print_clock_info and soc_print_device_info local to alleycat5. - Remove MMC and UBIFS distroboot options (MMC driver is not currently functional, NAND is not populated on the RD-AC5X board) - Remove unnecessary Ethernet configuration - Remove unnecessary NAND configuration - Remove memory node from dts so the value passed by the DDR FW will be used
Changes in v2: - Use distro boot by default - remove unnecessary SPI-NOR partitions
Chris Packham (6): arm: mvebu: Don't use CONFIG_TIMER on ARM64 net: mvneta: Add support for AlleyCat5 usb: ehci: ehci-marvell: Support for marvell,ac5-ehci pinctrl: mvebu: Add AlleyCat5 support arm: mvebu: Support for 98DX25xx/98DX35xx SoC arm: mvebu: Add RD-AC5X board
arch/arm/Kconfig | 2 +- arch/arm/dts/Makefile | 3 +- arch/arm/dts/ac5-98dx25xx.dtsi | 277 +++++++++++++++++++ arch/arm/dts/ac5-98dx35xx-rd.dts | 129 +++++++++ arch/arm/dts/ac5-98dx35xx.dtsi | 17 ++ arch/arm/mach-mvebu/Kconfig | 13 +- arch/arm/mach-mvebu/Makefile | 1 + arch/arm/mach-mvebu/alleycat5/Makefile | 8 + arch/arm/mach-mvebu/alleycat5/cpu.c | 124 +++++++++ arch/arm/mach-mvebu/alleycat5/soc.c | 298 +++++++++++++++++++++ arch/arm/mach-mvebu/alleycat5/soc.h | 7 + arch/arm/mach-mvebu/arm64-common.c | 5 + arch/arm/mach-mvebu/include/mach/cpu.h | 4 + board/Marvell/mvebu_alleycat-5/MAINTAINERS | 6 + board/Marvell/mvebu_alleycat-5/Makefile | 3 + board/Marvell/mvebu_alleycat-5/board.c | 13 + configs/mvebu_ac5_rd_defconfig | 81 ++++++ drivers/net/Kconfig | 2 +- drivers/net/mvneta.c | 43 ++- drivers/pinctrl/mvebu/Kconfig | 2 +- drivers/usb/host/Kconfig | 1 + drivers/usb/host/ehci-marvell.c | 53 +++- include/configs/mvebu_alleycat-5.h | 42 +++ 23 files changed, 1120 insertions(+), 14 deletions(-) create mode 100644 arch/arm/dts/ac5-98dx25xx.dtsi create mode 100644 arch/arm/dts/ac5-98dx35xx-rd.dts create mode 100644 arch/arm/dts/ac5-98dx35xx.dtsi create mode 100644 arch/arm/mach-mvebu/alleycat5/Makefile create mode 100644 arch/arm/mach-mvebu/alleycat5/cpu.c create mode 100644 arch/arm/mach-mvebu/alleycat5/soc.c create mode 100644 arch/arm/mach-mvebu/alleycat5/soc.h create mode 100644 board/Marvell/mvebu_alleycat-5/MAINTAINERS create mode 100644 board/Marvell/mvebu_alleycat-5/Makefile create mode 100644 board/Marvell/mvebu_alleycat-5/board.c create mode 100644 configs/mvebu_ac5_rd_defconfig create mode 100644 include/configs/mvebu_alleycat-5.h
The 64-bit mvebu SoCs don't have a suitable timer driver so add a !ARM64 condition to the select.
Fixes: 7b530bb19e ("arm: mvebu: Use CONFIG_TIMER on all MVEBU & KIRKWOOD platforms") Signed-off-by: Chris Packham judge.packham@gmail.com ---
(no changes since v1)
arch/arm/Kconfig | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index 453bef900e..7866e8f3c4 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -640,7 +640,7 @@ config ARCH_MVEBU select SPL_DM_SPI if SPL select SPL_DM_SPI_FLASH if SPL select SPL_TIMER if SPL - select TIMER + select TIMER if !ARM64 select OF_CONTROL select OF_SEPARATE select SPI
- select TIMER
- select TIMER if !ARM64 select OF_CONTROL select OF_SEPARATE select SPI
Thanks, Stefan
Add support for the AlleyCat5 SoC. This lacks the mbus from the other users of the mvneta.c driver so a new compatible string is needed to allow for a different window configuration.
Signed-off-by: Chris Packham judge.packham@gmail.com Reviewed-by: Stefan Roese sr@denx.de ---
(no changes since v3)
drivers/net/Kconfig | 2 +- drivers/net/mvneta.c | 43 ++++++++++++++++++++++++++++++++++++++++++- 2 files changed, 43 insertions(+), 2 deletions(-)
diff --git a/drivers/net/Kconfig b/drivers/net/Kconfig index 6bbbadc5ee..8df3dce6df 100644 --- a/drivers/net/Kconfig +++ b/drivers/net/Kconfig @@ -448,7 +448,7 @@ config MVGBE
config MVNETA bool "Marvell Armada XP/385/3700 network interface support" - depends on ARMADA_XP || ARMADA_38X || ARMADA_3700 + depends on ARMADA_XP || ARMADA_38X || ARMADA_3700 || ALLEYCAT_5 select PHYLIB select DM_MDIO help diff --git a/drivers/net/mvneta.c b/drivers/net/mvneta.c index d2c42c4396..0fbfad11d4 100644 --- a/drivers/net/mvneta.c +++ b/drivers/net/mvneta.c @@ -91,6 +91,8 @@ DECLARE_GLOBAL_DATA_PTR; #define MVNETA_WIN_SIZE_MASK (0xffff0000) #define MVNETA_BASE_ADDR_ENABLE 0x2290 #define MVNETA_BASE_ADDR_ENABLE_BIT 0x1 +#define MVNETA_AC5_CNM_DDR_TARGET 0x2 +#define MVNETA_AC5_CNM_DDR_ATTR 0xb #define MVNETA_PORT_ACCESS_PROTECT 0x2294 #define MVNETA_PORT_ACCESS_PROTECT_WIN0_RW 0x3 #define MVNETA_PORT_CONFIG 0x2400 @@ -282,6 +284,8 @@ struct mvneta_port { struct gpio_desc phy_reset_gpio; struct gpio_desc sfp_tx_disable_gpio; #endif + + uintptr_t dma_base; /* base address for DMA address decoding */ };
/* The mvneta_tx_desc and mvneta_rx_desc structures describe the @@ -1343,6 +1347,29 @@ static void mvneta_conf_mbus_windows(struct mvneta_port *pp) mvreg_write(pp, MVNETA_BASE_ADDR_ENABLE, win_enable); }
+static void mvneta_conf_ac5_cnm_xbar_windows(struct mvneta_port *pp) +{ + int i; + + /* Clear all windows */ + for (i = 0; i < 6; i++) { + mvreg_write(pp, MVNETA_WIN_BASE(i), 0); + mvreg_write(pp, MVNETA_WIN_SIZE(i), 0); + + if (i < 4) + mvreg_write(pp, MVNETA_WIN_REMAP(i), 0); + } + + /* + * Setup window #0 base 0x0 to target XBAR port 2 (AMB2), attribute 0xb, size 4GB + * AMB2 address decoder remaps 0x0 to DDR 64 bit base address + */ + mvreg_write(pp, MVNETA_WIN_BASE(0), + (MVNETA_AC5_CNM_DDR_ATTR << 8) | MVNETA_AC5_CNM_DDR_TARGET); + mvreg_write(pp, MVNETA_WIN_SIZE(0), 0xffff0000); + mvreg_write(pp, MVNETA_BASE_ADDR_ENABLE, 0x3e); +} + /* Power up the port */ static int mvneta_port_power_up(struct mvneta_port *pp, int phy_mode) { @@ -1525,7 +1552,7 @@ static int mvneta_recv(struct udevice *dev, int flags, uchar **packetp) * No cache invalidation needed here, since the rx_buffer's are * located in a uncached memory region */ - *packetp = data; + *packetp = data + pp->dma_base;
/* * Only mark one descriptor as free @@ -1544,6 +1571,10 @@ static int mvneta_probe(struct udevice *dev) struct ofnode_phandle_args sfp_args; #endif void *bd_space; + phys_addr_t cpu; + dma_addr_t bus; + u64 size; + int ret;
/* * Allocate buffer area for descs and rx_buffers. This is only @@ -1577,9 +1608,18 @@ static int mvneta_probe(struct udevice *dev) /* Configure MBUS address windows */ if (device_is_compatible(dev, "marvell,armada-3700-neta")) mvneta_bypass_mbus_windows(pp); + else if (device_is_compatible(dev, "marvell,armada-ac5-neta")) + mvneta_conf_ac5_cnm_xbar_windows(pp); else mvneta_conf_mbus_windows(pp);
+ /* fetch dma ranges property */ + ret = dev_get_dma_range(dev, &cpu, &bus, &size); + if (!ret) + pp->dma_base = cpu; + else + pp->dma_base = 0; + #if CONFIG_IS_ENABLED(DM_GPIO) if (!dev_read_phandle_with_args(dev, "sfp", NULL, 0, 0, &sfp_args) && ofnode_is_enabled(sfp_args.node)) @@ -1620,6 +1660,7 @@ static const struct eth_ops mvneta_ops = {
static const struct udevice_id mvneta_ids[] = { { .compatible = "marvell,armada-370-neta" }, + { .compatible = "marvell,armada-ac5-neta" }, { .compatible = "marvell,armada-xp-neta" }, { .compatible = "marvell,armada-3700-neta" }, { }
Changes in v3:
int i;
if (i < 4)
*packetp = data;
*packetp = data + pp->dma_base; /* * Only mark one descriptor as free
phys_addr_t cpu;
dma_addr_t bus;
u64 size;
int ret; /* * Allocate buffer area for descs and rx_buffers. This is only
if (!ret)
pp->dma_base = cpu;
else
pp->dma_base = 0;
-- 2.38.1
Reviewed-by: Ramon Fried rfried.dev@gmail.com
Hi Ramon,
Changes in v3:
int i;
if (i < 4)
- /* Power up the port */ static int mvneta_port_power_up(struct mvneta_port *pp, int phy_mode) {
*packetp = data;
phys_addr_t cpu;
dma_addr_t bus;
u64 size;
if (!ret)
pp->dma_base = cpu;
else
pp->dma_base = 0;
-- 2.38.1
Thanks. But sorry, I already applied this patch via the marvell tree. I hope this okay. I will try to wait a bit longer next time for networks related patches.
Thanks, Stefan
Unlike the other 64-bit mvebu SoCs the AlleyCat5 uses the older ehci block from the 32-bit SoCs. Adapt the ehci-marvell.c driver to cope with the fact that the ac5 does not have the mbus infrastructure the 32-bit SoCs have and ensure USB_EHCI_IS_TDI is selected.
(no changes since v5)
drivers/usb/host/Kconfig | 1 + drivers/usb/host/ehci-marvell.c | 53 ++++++++++++++++++++++++++++----- 2 files changed, 46 insertions(+), 8 deletions(-)
diff --git a/drivers/usb/host/Kconfig b/drivers/usb/host/Kconfig index 1aabe062fb..c750b0207d 100644 --- a/drivers/usb/host/Kconfig +++ b/drivers/usb/host/Kconfig @@ -178,6 +178,7 @@ config USB_EHCI_MARVELL depends on ARCH_MVEBU || ARCH_KIRKWOOD || ARCH_ORION5X default y select USB_EHCI_IS_TDI if !ARM64 + select USB_EHCI_IS_TDI if ALLEYCAT_5 ---help--- Enables support for the on-chip EHCI controller on MVEBU SoCs.
diff --git a/drivers/usb/host/ehci-marvell.c b/drivers/usb/host/ehci-marvell.c index b7e60c690a..6093c8fb0b 100644 --- a/drivers/usb/host/ehci-marvell.c +++ b/drivers/usb/host/ehci-marvell.c @@ -48,12 +48,17 @@ struct ehci_mvebu_priv { fdt_addr_t hcd_base; };
+#define USB_TO_DRAM_TARGET_ID 0x2 +#define USB_TO_DRAM_ATTR_ID 0x0 +#define USB_DRAM_BASE 0x00000000 +#define USB_DRAM_SIZE 0xfff /* don't overrun u-boot source (was 0xffff) */ + /* * Once all the older Marvell SoC's (Orion, Kirkwood) are converted * to the common mvebu archticture including the mbus setup, this * will be the only function needed to configure the access windows */ -static void usb_brg_adrdec_setup(void *base) +static void usb_brg_adrdec_setup(struct udevice *dev, void *base) { const struct mbus_dram_target_info *dram; int i; @@ -65,16 +70,34 @@ static void usb_brg_adrdec_setup(void *base) writel(0, base + USB_WINDOW_BASE(i)); }
- for (i = 0; i < dram->num_cs; i++) { - const struct mbus_dram_window *cs = dram->cs + i; + if (device_is_compatible(dev, "marvell,ac5-ehci")) { + /* + * use decoding window to map dram address seen by usb to 0x0 + */
/* Write size, attributes and target id to control register */ - writel(((cs->size - 1) & 0xffff0000) | (cs->mbus_attr << 8) | - (dram->mbus_dram_target_id << 4) | 1, - base + USB_WINDOW_CTRL(i)); + writel((USB_DRAM_SIZE << 16) | (USB_TO_DRAM_ATTR_ID << 8) | + (USB_TO_DRAM_TARGET_ID << 4) | 1, + base + USB_WINDOW_CTRL(0));
/* Write base address to base register */ - writel(cs->base, base + USB_WINDOW_BASE(i)); + writel(USB_DRAM_BASE, base + USB_WINDOW_BASE(0)); + + debug("## AC5 decoding windows, ctrl[%p]=0x%x, base[%p]=0x%x\n", + base + USB_WINDOW_CTRL(0), readl(base + USB_WINDOW_CTRL(0)), + base + USB_WINDOW_BASE(0), readl(base + USB_WINDOW_BASE(0))); + } else { + for (i = 0; i < dram->num_cs; i++) { + const struct mbus_dram_window *cs = dram->cs + i; + + /* Write size, attributes and target id to control register */ + writel(((cs->size - 1) & 0xffff0000) | (cs->mbus_attr << 8) | + (dram->mbus_dram_target_id << 4) | 1, + base + USB_WINDOW_CTRL(i)); + + /* Write base address to base register */ + writel(cs->base, base + USB_WINDOW_BASE(i)); + } } }
@@ -126,7 +149,7 @@ static int ehci_mvebu_probe(struct udevice *dev) if (device_is_compatible(dev, "marvell,armada-3700-ehci")) marvell_ehci_ops.powerup_fixup = marvell_ehci_powerup_fixup; else - usb_brg_adrdec_setup((void *)priv->hcd_base); + usb_brg_adrdec_setup(dev, (void *)priv->hcd_base);
hccr = (struct ehci_hccr *)(priv->hcd_base + 0x100); hcor = (struct ehci_hcor *) @@ -136,6 +159,19 @@ static int ehci_mvebu_probe(struct udevice *dev) (uintptr_t)hccr, (uintptr_t)hcor, (uintptr_t)HC_LENGTH(ehci_readl(&hccr->cr_capbase)));
+#define PHY_CALIB_OFFSET 0x808 + /* + * Trigger calibration during each usb start/reset: + * BIT 13 to 0, and then to 1 + */ + if (device_is_compatible(dev, "marvell,ac5-ehci")) { + void *phy_calib_reg = (void *)(priv->hcd_base + PHY_CALIB_OFFSET); + u32 val = readl(phy_calib_reg) & (~BIT(13)); + + writel(val, phy_calib_reg); + writel(val | BIT(13), phy_calib_reg); + } + return ehci_register(dev, hccr, hcor, &marvell_ehci_ops, 0, USB_INIT_HOST); } @@ -143,6 +179,7 @@ static int ehci_mvebu_probe(struct udevice *dev) static const struct udevice_id ehci_usb_ids[] = { { .compatible = "marvell,orion-ehci", }, { .compatible = "marvell,armada-3700-ehci", }, + { .compatible = "marvell,ac5-ehci", }, { } };
This uses the same IP block as the Armada-8K SoCs.
(no changes since v4)
drivers/pinctrl/mvebu/Kconfig | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/pinctrl/mvebu/Kconfig b/drivers/pinctrl/mvebu/Kconfig index 574fb4dfb0..7c51d138c8 100644 --- a/drivers/pinctrl/mvebu/Kconfig +++ b/drivers/pinctrl/mvebu/Kconfig @@ -15,7 +15,7 @@ config PINCTRL_ARMADA_37XX Marvell's Armada-37xx SoC.
config PINCTRL_ARMADA_8K - depends on ARMADA_8K && PINCTRL_FULL + depends on (ARMADA_8K || ALLEYCAT_5) && PINCTRL_FULL bool "Armada 7k/8k pin control driver" help Support pin multiplexing and pin configuration control on
Add support for the Allecat5/Alleycat5X SoC. These are L3 switches with an integrated CPU (referred to as the CnM block in Marvell's documentation). These have dual ARMv8.2 CPUs (Cortex-A55). This support has been ported from Marvell's SDK which is based on a much older version of U-Boot.
Changes in v5: - Minor fixup for checkpatch.pl complaint
Changes in v4: - Remove unused mvebu_get_nand_clock() (will return in a later series) - Remove unnecessary #ifdefs - Misc style cleanups - Replace CONFIG_MVEBU_SAR with simpler code implemented directly in soc.c based around get_sar_freq which the 32-bit platforms already use.
Changes in v3: - Remove unnecessary dma-ranges property from ethernet nodes (mvneta now correctly parses the property from the parent node). - Keep soc_print_clock_info and soc_print_device_info local to alleycat5.
arch/arm/dts/ac5-98dx25xx.dtsi | 277 +++++++++++++++++++++++ arch/arm/dts/ac5-98dx35xx.dtsi | 17 ++ arch/arm/mach-mvebu/Kconfig | 4 + arch/arm/mach-mvebu/Makefile | 1 + arch/arm/mach-mvebu/alleycat5/Makefile | 8 + arch/arm/mach-mvebu/alleycat5/cpu.c | 124 ++++++++++ arch/arm/mach-mvebu/alleycat5/soc.c | 298 +++++++++++++++++++++++++ arch/arm/mach-mvebu/alleycat5/soc.h | 7 + arch/arm/mach-mvebu/arm64-common.c | 5 + arch/arm/mach-mvebu/include/mach/cpu.h | 4 + 10 files changed, 745 insertions(+) create mode 100644 arch/arm/dts/ac5-98dx25xx.dtsi create mode 100644 arch/arm/dts/ac5-98dx35xx.dtsi create mode 100644 arch/arm/mach-mvebu/alleycat5/Makefile create mode 100644 arch/arm/mach-mvebu/alleycat5/cpu.c create mode 100644 arch/arm/mach-mvebu/alleycat5/soc.c create mode 100644 arch/arm/mach-mvebu/alleycat5/soc.h
diff --git a/arch/arm/dts/ac5-98dx25xx.dtsi b/arch/arm/dts/ac5-98dx25xx.dtsi new file mode 100644 index 0000000000..3c68355f32 --- /dev/null +++ b/arch/arm/dts/ac5-98dx25xx.dtsi @@ -0,0 +1,277 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Device Tree For AC5. + * + * Copyright (C) 2021 Marvell + * Copyright (C) 2022 Allied Telesis Labs + */ + +#include <dt-bindings/gpio/gpio.h> +#include <dt-bindings/interrupt-controller/arm-gic.h> + +/ { + model = "Marvell AC5 SoC"; + compatible = "marvell,ac5"; + interrupt-parent = <&gic>; + #address-cells = <2>; + #size-cells = <2>; + + cpus { + #address-cells = <2>; + #size-cells = <0>; + + cpu-map { + cluster0 { + core0 { + cpu = <&cpu0>; + }; + core1 { + cpu = <&cpu1>; + }; + }; + }; + + cpu0: cpu@0 { + device_type = "cpu"; + compatible = "arm,cortex-a55"; + reg = <0x0 0x0>; + enable-method = "psci"; + next-level-cache = <&l2>; + }; + + cpu1: cpu@1 { + device_type = "cpu"; + compatible = "arm,cortex-a55"; + reg = <0x0 0x100>; + enable-method = "psci"; + next-level-cache = <&l2>; + }; + + l2: l2-cache { + compatible = "cache"; + }; + }; + + psci { + compatible = "arm,psci-0.2"; + method = "smc"; + }; + + timer { + compatible = "arm,armv8-timer"; + interrupts = <GIC_PPI 9 IRQ_TYPE_LEVEL_HIGH>, + <GIC_PPI 8 IRQ_TYPE_LEVEL_HIGH>, + <GIC_PPI 10 IRQ_TYPE_LEVEL_HIGH>, + <GIC_PPI 7 IRQ_TYPE_LEVEL_HIGH>; + }; + + pmu { + compatible = "arm,armv8-pmuv3"; + interrupts = <GIC_PPI 12 IRQ_TYPE_LEVEL_HIGH>; + }; + + soc { + compatible = "simple-bus"; + #address-cells = <2>; + #size-cells = <2>; + ranges; + dma-ranges; + + internal-regs@7f000000 { + #address-cells = <1>; + #size-cells = <1>; + compatible = "simple-bus"; + /* 16M internal register @ 0x7f00_0000 */ + ranges = <0x0 0x0 0x7f000000 0x1000000>; + dma-coherent; + + uart0: serial@12000 { + compatible = "snps,dw-apb-uart"; + reg = <0x12000 0x100>; + reg-shift = <2>; + interrupts = <GIC_SPI 83 IRQ_TYPE_LEVEL_HIGH>; + reg-io-width = <1>; + clocks = <&cnm_clock>; + status = "okay"; + }; + + uart1: serial@12100 { + compatible = "snps,dw-apb-uart"; + reg = <0x12100 0x100>; + reg-shift = <2>; + reg-io-width = <1>; + clocks = <&cnm_clock>; + status = "disabled"; + }; + + uart2: serial@12200 { + compatible = "snps,dw-apb-uart"; + reg = <0x12200 0x100>; + reg-shift = <2>; + reg-io-width = <1>; + clocks = <&cnm_clock>; + status = "disabled"; + }; + + uart3: serial@12300 { + compatible = "snps,dw-apb-uart"; + reg = <0x12300 0x100>; + reg-shift = <2>; + reg-io-width = <1>; + clocks = <&cnm_clock>; + status = "disabled"; + }; + + mdio: mdio@22004 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "marvell,orion-mdio"; + reg = <0x22004 0x4>; + clocks = <&cnm_clock>; + }; + + i2c0: i2c@11000 { + compatible = "marvell,mv78230-i2c"; + reg = <0x11000 0x20>; + #address-cells = <1>; + #size-cells = <0>; + + clocks = <&cnm_clock>; + clock-names = "core"; + interrupts = <GIC_SPI 87 IRQ_TYPE_LEVEL_HIGH>; + clock-frequency=<100000>; + status = "disabled"; + }; + + i2c1: i2c@11100 { + compatible = "marvell,mv78230-i2c"; + reg = <0x11100 0x20>; + #address-cells = <1>; + #size-cells = <0>; + + clocks = <&cnm_clock>; + clock-names = "core"; + interrupts = <GIC_SPI 88 IRQ_TYPE_LEVEL_HIGH>; + clock-frequency=<100000>; + status = "disabled"; + }; + + gpio0: gpio@18100 { + compatible = "marvell,orion-gpio"; + reg = <0x18100 0x40>; + ngpios = <32>; + gpio-controller; + #gpio-cells = <2>; + status = "okay"; + }; + + gpio1: gpio@18140 { + reg = <0x18140 0x40>; + compatible = "marvell,orion-gpio"; + ngpios = <14>; + gpio-controller; + #gpio-cells = <2>; + status = "okay"; + }; + }; + + /* + * Dedicated section for devices behind 32bit controllers so we + * can configure specific DMA mapping for them + */ + behind-32bit-controller@7f000000 { + compatible = "simple-bus"; + #address-cells = <0x2>; + #size-cells = <0x2>; + ranges = <0x0 0x0 0x0 0x7f000000 0x0 0x1000000>; + /* Host phy ram starts at 0x200M */ + dma-ranges = <0x0 0x0 0x2 0x0 0x1 0x0>; + dma-coherent; + + eth0: ethernet@20000 { + compatible = "marvell,armada-ac5-neta"; + reg = <0x0 0x20000 0x0 0x4000>; + interrupts = <GIC_SPI 45 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cnm_clock>; + phy-mode = "sgmii"; + status = "disabled"; + }; + + eth1: ethernet@24000 { + compatible = "marvell,armada-ac5-neta"; + reg = <0x0 0x24000 0x0 0x4000>; + interrupts = <GIC_SPI 55 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cnm_clock>; + phy-mode = "sgmii"; + status = "disabled"; + }; + + usb0: usb@80000 { + compatible = "marvell,ac5-ehci"; + reg = <0x0 0x80000 0x0 0x500>; + interrupts = <GIC_SPI 67 IRQ_TYPE_LEVEL_HIGH>; + status = "disabled"; + }; + + usb1: usb@a0000 { + compatible = "marvell,ac5-ehci"; + reg = <0x0 0xa0000 0x0 0x500>; + interrupts = <GIC_SPI 69 IRQ_TYPE_LEVEL_HIGH>; + status = "disabled"; + }; + }; + + pinctrl0: pinctrl@80020100 { + compatible = "marvell,mvebu-pinctrl"; + reg = <0 0x80020100 0 0x20>; + pin-count = <46>; + max-func = <0xf>; + status = "okay"; + }; + + spi0: spi@805a0000 { + compatible = "marvell,armada-3700-spi"; + reg = <0x0 0x805a0000 0x0 0x50>; + #address-cells = <0x1>; + #size-cells = <0x0>; + clocks = <&spi_clock>; + interrupts = <GIC_SPI 90 IRQ_TYPE_LEVEL_HIGH>; + num-cs = <1>; + status = "disabled"; + }; + + spi1: spi@805a8000 { + compatible = "marvell,armada-3700-spi"; + reg = <0x0 0x805a8000 0x0 0x50>; + #address-cells = <0x1>; + #size-cells = <0x0>; + clocks = <&spi_clock>; + interrupts = <GIC_SPI 91 IRQ_TYPE_LEVEL_HIGH>; + num-cs = <1>; + status = "disabled"; + }; + + gic: interrupt-controller@80600000 { + compatible = "arm,gic-v3"; + #interrupt-cells = <3>; + interrupt-controller; + reg = <0x0 0x80600000 0x0 0x10000>, /* GICD */ + <0x0 0x80660000 0x0 0x40000>; /* GICR */ + interrupts = <GIC_PPI 6 IRQ_TYPE_LEVEL_HIGH>; + }; + }; + + clocks { + cnm_clock: cnm-clock { + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <328000000>; + }; + + spi_clock: spi-clock { + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <200000000>; + }; + }; +}; diff --git a/arch/arm/dts/ac5-98dx35xx.dtsi b/arch/arm/dts/ac5-98dx35xx.dtsi new file mode 100644 index 0000000000..2ab72f854b --- /dev/null +++ b/arch/arm/dts/ac5-98dx35xx.dtsi @@ -0,0 +1,17 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Device Tree For AC5X. + * + * Copyright (C) 2022 Allied Telesis Labs + */ + +#include "ac5-98dx25xx.dtsi" + +/ { + model = "Marvell AC5X SoC"; + compatible = "marvell,ac5x", "marvell,ac5"; +}; + +&cnm_clock { + clock-frequency = <325000000>; +}; diff --git a/arch/arm/mach-mvebu/Kconfig b/arch/arm/mach-mvebu/Kconfig index fe6b785d0b..e2c98dffe2 100644 --- a/arch/arm/mach-mvebu/Kconfig +++ b/arch/arm/mach-mvebu/Kconfig @@ -50,6 +50,10 @@ config ARMADA_8K bool select ARM64
+config ALLEYCAT_5 + bool + select ARM64 + # Armada PLL frequency (used for NAND clock generation) config SYS_MVEBU_PLL_CLOCK int diff --git a/arch/arm/mach-mvebu/Makefile b/arch/arm/mach-mvebu/Makefile index 406a9ee8f6..a23511b113 100644 --- a/arch/arm/mach-mvebu/Makefile +++ b/arch/arm/mach-mvebu/Makefile @@ -6,6 +6,7 @@ ifdef CONFIG_ARM64
obj-$(CONFIG_ARMADA_3700) += armada3700/ obj-$(CONFIG_ARMADA_8K) += armada8k/ +obj-$(CONFIG_ALLEYCAT_5) += alleycat5/ obj-y += arm64-common.o
else # CONFIG_ARM64 diff --git a/arch/arm/mach-mvebu/alleycat5/Makefile b/arch/arm/mach-mvebu/alleycat5/Makefile new file mode 100644 index 0000000000..b897ad089a --- /dev/null +++ b/arch/arm/mach-mvebu/alleycat5/Makefile @@ -0,0 +1,8 @@ +# +# Copyright (C) 2016 Stefan Roese sr@denx.de +# +# SPDX-License-Identifier: GPL-2.0+ +# + +obj-y = cpu.o +obj-y += soc.o diff --git a/arch/arm/mach-mvebu/alleycat5/cpu.c b/arch/arm/mach-mvebu/alleycat5/cpu.c new file mode 100644 index 0000000000..cc7f9794c5 --- /dev/null +++ b/arch/arm/mach-mvebu/alleycat5/cpu.c @@ -0,0 +1,124 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2018 Marvell International Ltd. + */ + +#include <common.h> +#include <dm.h> +#include <fdtdec.h> +#include <linux/libfdt.h> +#include <asm/io.h> +#include <asm/system.h> +#include <asm/arch/cpu.h> +#include <linux/sizes.h> +#include <asm/armv8/mmu.h> +#include "soc.h" + +DECLARE_GLOBAL_DATA_PTR; + +#define RAM_SIZE SZ_1G + +static struct mm_region ac5_mem_map[] = { + { + /* RAM */ + .phys = CONFIG_SYS_SDRAM_BASE, + .virt = CONFIG_SYS_SDRAM_BASE, + .attrs = PTE_BLOCK_MEMTYPE(MT_NORMAL) | + PTE_BLOCK_INNER_SHARE + }, + { + /* MMIO regions */ + .phys = 0x00000000, + .virt = 0xa0000000, + .size = 0x100000, + + .attrs = PTE_BLOCK_MEMTYPE(MT_DEVICE_NGNRNE) | + PTE_BLOCK_NON_SHARE | + PTE_BLOCK_PXN | PTE_BLOCK_UXN + }, + { + /* MMIO regions */ + .phys = 0x100000, + .virt = 0x100000, + .size = 0x3ff00000, + + .attrs = PTE_BLOCK_MEMTYPE(MT_DEVICE_NGNRNE) | + PTE_BLOCK_NON_SHARE | + PTE_BLOCK_PXN | PTE_BLOCK_UXN + }, + { + /* MMIO regions */ + .phys = 0x7F000000, + .virt = 0x7F000000, + .size = 0x21000000, + + .attrs = PTE_BLOCK_MEMTYPE(MT_DEVICE_NGNRNE) | + PTE_BLOCK_NON_SHARE | + PTE_BLOCK_PXN | PTE_BLOCK_UXN + }, + { + 0, + } +}; + +struct mm_region *mem_map = ac5_mem_map; + +void reset_cpu(void) +{ +} + +int print_cpuinfo(void) +{ + soc_print_device_info(); + soc_print_clock_info(); + + return 0; +} + +int alleycat5_dram_init(void) +{ +#define SCRATCH_PAD_REG 0x80010018 + int ret; + + /* override DDR_FW size if DTS is set with size */ + ret = fdtdec_setup_mem_size_base(); + if (ret == -EINVAL) + gd->ram_size = readl(SCRATCH_PAD_REG) * 4ULL; + + /* if DRAM size == 0, print error message */ + if (gd->ram_size == 0) { + pr_err("DRAM size not initialized - check DRAM configuration\n"); + printf("\n Using temporary DRAM size of 512MB.\n\n"); + gd->ram_size = SZ_512M; + } + + ac5_mem_map[0].size = gd->ram_size; + + return 0; +} + +int alleycat5_dram_init_banksize(void) +{ + /* + * Config single DRAM bank + */ + gd->bd->bi_dram[0].start = CONFIG_SYS_SDRAM_BASE; + gd->bd->bi_dram[0].size = gd->ram_size; + + return 0; +} + +int timer_init(void) +{ + return 0; +} + +/* + * get_ref_clk + * + * return: reference clock in MHz + */ +u32 get_ref_clk(void) +{ + return 25; +} diff --git a/arch/arm/mach-mvebu/alleycat5/soc.c b/arch/arm/mach-mvebu/alleycat5/soc.c new file mode 100644 index 0000000000..efbef233a1 --- /dev/null +++ b/arch/arm/mach-mvebu/alleycat5/soc.c @@ -0,0 +1,298 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2018 Marvell International Ltd. + */ + +#include <common.h> +#include <asm/arch-armada8k/cache_llc.h> +#include <asm/io.h> +#include <asm/arch/cpu.h> +#include <asm/arch/soc.h> +#include <dm/device.h> + +#define DEVICE_ID_REG 0x7F90004C +#define DEVICE_ID_MASK 0xffff0 +#define REV_ID_MASK 0xf +#define DEVICE_ID_OFFSET 4 +#define REV_ID_OFFSET 0 + +#define DEVICE_SAR_REG 0x944F8204 + +#define DEVICE_ID_SUB_REV (MVEBU_REGISTER(0x2400230)) +#define DEVICE_ID_SUB_REV_OFFSET 7 +#define DEVICE_ID_SUB_REV_MASK (0xffff << DEVICE_ID_SUB_REV_OFFSET) + +#define AC5X_DEV_ID 0x9800 + +struct soc_info { + u32 dev_id; + u32 rev_id; + char *soc_name; +}; + +static struct soc_info soc_info_table[] = { + /* Two reserved entries for unidentified devices - don't change */ + { 0xB4FF, 0x0, "Unidentified Alleycat5"}, + { 0x98FF, 0x0, "Unidentified Alleycat5x"}, + + { 0xB400, 0x2, "Alleycat5-plus 98DX2538-A2"}, + { 0xB401, 0x2, "Alleycat5-plus 98DX2535-A2"}, + { 0xB402, 0x2, "Alleycat5-plus 98DX2532-A2"}, + { 0xB403, 0x2, "Alleycat5-plus 98DX2531-A2"}, + { 0xB408, 0x2, "Alleycat5 98DX2528-A2"}, + { 0xB409, 0x2, "Alleycat5 98DX2525-A2"}, + { 0xB40A, 0x2, "Alleycat5 98DX2522-A2"}, + { 0xB40B, 0x2, "Alleycat5 98DX2521-A2"}, + { 0xB410, 0x2, "Alleycat5-lite 98DX2518-A2"}, + { 0xB411, 0x2, "Alleycat5-lite 98DX2515-A2"}, + { 0xB412, 0x2, "Alleycat5-lite 98DX2512-A2"}, + { 0xB413, 0x2, "Alleycat5-lite 98DX2511-A2"}, + + { 0xB400, 0x1, "Alleycat5-plus 98DX2538-A1"}, + { 0xB401, 0x1, "Alleycat5-plus 98DX2535-A1"}, + { 0xB402, 0x1, "Alleycat5-plus 98DX2532-A1"}, + { 0xB403, 0x1, "Alleycat5-plus 98DX2531-A1"}, + { 0xB408, 0x1, "Alleycat5 98DX2528-A1"}, + { 0xB409, 0x1, "Alleycat5 98DX2525-A1"}, + { 0xB40A, 0x1, "Alleycat5 98DX2522-A1"}, + { 0xB40B, 0x1, "Alleycat5 98DX2521-A1"}, + { 0xB410, 0x1, "Alleycat5-lite 98DX2518-A1"}, + { 0xB411, 0x1, "Alleycat5-lite 98DX2515-A1"}, + { 0xB412, 0x1, "Alleycat5-lite 98DX2512-A1"}, + { 0xB413, 0x1, "Alleycat5-lite 98DX2511-A1"}, + { 0x9800, 0x1, "Alleycat5X 98DX3500M-A1"}, + { 0x9806, 0x1, "Alleycat5X 98DX3501M-A1"}, + { 0x9801, 0x1, "Alleycat5X 98DX3510M-A1"}, + { 0x9802, 0x1, "Alleycat5X 98DX3520M-A1"}, + { 0x9803, 0x1, "Alleycat5X 98DX3530M-A1"}, + { 0x9804, 0x1, "Alleycat5X 98DX3540M-A1"}, + { 0x9805, 0x1, "Alleycat5X 98DX3550M-A1"}, + { 0x9820, 0x1, "Alleycat5X 98DX3500-A1"}, + { 0x9826, 0x1, "Alleycat5X 98DX3501-A1"}, + { 0x9821, 0x1, "Alleycat5X 98DX3510-A1"}, + { 0x9861, 0x1, "Alleycat5X 98DX3510H-A1"}, + { 0x9841, 0x1, "Alleycat5X 98DX3510MH-A1"}, + { 0x9822, 0x1, "Alleycat5X 98DX3520-A1"}, + { 0x9823, 0x1, "Alleycat5X 98DX3530-A1"}, + { 0x9863, 0x1, "Alleycat5X 98DX3530H-A1"}, + { 0x9824, 0x1, "Alleycat5X 98DX3540-A1"}, + { 0x9825, 0x1, "Alleycat5X 98DX3550-A1"}, + + { 0xB400, 0x0, "Alleycat5-plus 98DX2538-A0"}, + { 0xB401, 0x0, "Alleycat5-plus 98DX2535-A0"}, + { 0xB402, 0x0, "Alleycat5-plus 98DX2532-A0"}, + { 0xB403, 0x0, "Alleycat5-plus 98DX2531-A0"}, + { 0xB408, 0x0, "Alleycat5 98DX2528-A0"}, + { 0xB409, 0x0, "Alleycat5 98DX2525-A0"}, + { 0xB40A, 0x0, "Alleycat5 98DX2522-A0"}, + { 0xB40B, 0x0, "Alleycat5 98DX2521-A0"}, + { 0xB410, 0x0, "Alleycat5-lite 98DX2518-A0"}, + { 0xB411, 0x0, "Alleycat5-lite 98DX2515-A0"}, + { 0xB412, 0x0, "Alleycat5-lite 98DX2512-A0"}, + { 0xB413, 0x0, "Alleycat5-lite 98DX2511-A0"}, + { 0x9800, 0x0, "Alleycat5X 98DX3500M-A0"}, + { 0x9806, 0x0, "Alleycat5X 98DX3501M-A0"}, + { 0x9801, 0x0, "Alleycat5X 98DX3510M-A0"}, + { 0x9802, 0x0, "Alleycat5X 98DX3520M-A0"}, + { 0x9803, 0x0, "Alleycat5X 98DX3530M-A0"}, + { 0x9804, 0x0, "Alleycat5X 98DX3540M-A0"}, + { 0x9805, 0x0, "Alleycat5X 98DX3550M-A0"}, + { 0x9820, 0x0, "Alleycat5X 98DX3500-A0"}, + { 0x9826, 0x0, "Alleycat5X 98DX3501-A0"}, + { 0x9821, 0x0, "Alleycat5X 98DX3510-A0"}, + { 0x9861, 0x0, "Alleycat5X 98DX3510H-A0"}, + { 0x9841, 0x0, "Alleycat5X 98DX3510MH-A0"}, + { 0x9822, 0x0, "Alleycat5X 98DX3520-A0"}, + { 0x9823, 0x0, "Alleycat5X 98DX3530-A0"}, + { 0x9863, 0x0, "Alleycat5X 98DX3530H-A0"}, + { 0x9824, 0x0, "Alleycat5X 98DX3540-A0"}, + { 0x9825, 0x0, "Alleycat5X 98DX3550-A0"}, +}; + +#define BIT_VAL(b) ((1ULL << ((b) + 1)) - 1) +#define BIT_RANGE(bl, bh) (BIT_VAL(bh) - BIT_VAL((bl) - 1)) + +#define PLL_MAX_CHOICE 4 + +#define CPU_TYPE_AC5 0 +#define CPU_TYPE_AC5x 1 +#define CPU_TYPE_LAST 2 + +enum mvebu_sar_opts { + SAR_CPU_FREQ = 0, + SAR_DDR_FREQ, + SAR_AP_FABRIC_FREQ, + SAR_CP_FABRIC_FREQ, + SAR_CP0_PCIE0_CLK, + SAR_CP0_PCIE1_CLK, + SAR_CP1_PCIE0_CLK, + SAR_CP1_PCIE1_CLK, + SAR_BOOT_SRC, + SAR_MAX_IDX +}; + +static const u32 pll_freq_tbl[CPU_TYPE_LAST][SAR_AP_FABRIC_FREQ + 1][PLL_MAX_CHOICE] = { + [CPU_TYPE_AC5] = { + [SAR_CPU_FREQ] = { + 800, 1200, 1400, 1000 + }, + [SAR_DDR_FREQ] = { + 1200, 800, 0, 0 + }, + [SAR_AP_FABRIC_FREQ] = { + 396, 290, 197, 0 + }, + }, + [CPU_TYPE_AC5x] = { + [SAR_CPU_FREQ] = { + 800, 1200, 1500, 1600 + }, + [SAR_DDR_FREQ] = { + 1200, 800, 0, 0 + }, + [SAR_AP_FABRIC_FREQ] = { + 0, 0, 0, 0 + } + } +}; + +static const u32 soc_sar_masks_tbl[CPU_TYPE_LAST][SAR_AP_FABRIC_FREQ + 1] = { + [CPU_TYPE_AC5] = { + [SAR_CPU_FREQ] = BIT_RANGE(18, 20), + [SAR_DDR_FREQ] = BIT_RANGE(16, 17), + [SAR_AP_FABRIC_FREQ] = BIT_RANGE(22, 23), + }, + [CPU_TYPE_AC5x] = { + [SAR_CPU_FREQ] = BIT_RANGE(8, 10), + [SAR_DDR_FREQ] = BIT_RANGE(6, 7), + [SAR_AP_FABRIC_FREQ] = 1, + }, +}; + +static int get_soc_type_rev(u32 *type, u32 *rev) +{ + *type = (readl(DEVICE_ID_REG) & DEVICE_ID_MASK) >> DEVICE_ID_OFFSET; + *rev = (readl(DEVICE_ID_REG) & REV_ID_MASK) >> REV_ID_OFFSET; + + return 0; +} + +static void get_one_sar_freq(int cpu_type, u32 sar_reg_val, enum mvebu_sar_opts sar_opt, u32 *freq) +{ + u32 mask; + unsigned char choice; + + mask = soc_sar_masks_tbl[cpu_type][sar_opt]; + choice = (sar_reg_val & mask) >> (__builtin_ffs(mask) - 1); + *freq = pll_freq_tbl[cpu_type][sar_opt][choice]; +} + +void get_sar_freq(struct sar_freq_modes *sar_freq) +{ + int cpu_type; + u32 soc_type, rev; + u32 sar_reg_val = readl(DEVICE_SAR_REG); + + get_soc_type_rev(&soc_type, &rev); + cpu_type = (soc_type & 0xFF00) == AC5X_DEV_ID ? CPU_TYPE_AC5x : CPU_TYPE_AC5; + + get_one_sar_freq(cpu_type, sar_reg_val, SAR_CPU_FREQ, &sar_freq->p_clk); + get_one_sar_freq(cpu_type, sar_reg_val, SAR_AP_FABRIC_FREQ, &sar_freq->nb_clk); + get_one_sar_freq(cpu_type, sar_reg_val, SAR_DDR_FREQ, &sar_freq->d_clk); +} + +static int get_soc_table_index(u32 *index) +{ + u32 soc_type; + u32 rev, i, ret = 1; + + *index = 0; + get_soc_type_rev(&soc_type, &rev); + + for (i = 0; i < ARRAY_SIZE(soc_info_table) && ret != 0; i++) { + if (soc_type != soc_info_table[i].dev_id || + rev != soc_info_table[i].rev_id) + continue; + + *index = i; + ret = 0; + } + + if (ret && ((soc_type & 0xFF00) == AC5X_DEV_ID)) + *index = 1; + + return ret; +} + +static int get_soc_name(char **soc_name) +{ + u32 index; + + get_soc_table_index(&index); + *soc_name = soc_info_table[index].soc_name; + + return 0; +} + +/* Print device's SoC name and AP & CP information */ +void soc_print_device_info(void) +{ + char *soc_name = NULL; + + get_soc_name(&soc_name); + + printf("SoC: %s\n", soc_name); +} + +void soc_print_clock_info(void) +{ + struct sar_freq_modes sar_freq; + + get_sar_freq(&sar_freq); + printf("Clock: CPU %4d MHz\n", sar_freq.p_clk); + printf("\tDDR %4d MHz\n", sar_freq.d_clk); + printf("\tFABRIC %4d MHz\n", sar_freq.nb_clk); + printf("\tMSS %4d MHz\n", 200); +} + +/* + * Override of __weak int mach_cpu_init(void) : + * SoC/machine dependent CPU setup + */ +int mach_cpu_init(void) +{ + u32 phy_i; + u64 new_val, phy_base = 0x7F080800; + + /* Init USB PHY */ +#define USB_STEPPING 0x20000 +#define WRITE_MASK(addr, mask, val) \ + { new_val = (readl(addr) & (~(mask))) | (val);\ + writel(new_val, addr); } + + for (phy_i = 0; phy_i < 2; phy_i++, phy_base += USB_STEPPING) { + WRITE_MASK(phy_base + 0x4, 0x3, 0x2); + WRITE_MASK(phy_base + 0xC, 0x3000000, 0x2000000); + WRITE_MASK(phy_base + 0x1C, 0x3, 0x2); + WRITE_MASK(phy_base + 0x0, 0x1FF007F, 0x600005); + WRITE_MASK(phy_base + 0xC, 0x000F000, 0x0002000); + /* Calibration Threshold Setting = 4*/ + WRITE_MASK(phy_base + 0x8, 0x700, 0x400) + WRITE_MASK(phy_base + 0x14, 0x000000F, 0x000000a); + /* Change AMP to 4*/ + WRITE_MASK(phy_base + 0xC, 0x3700000, 0x3400000); + WRITE_MASK(phy_base + 0x4, 0x3, 0x3); + /* Impedance calibration triggering is performed by USB probe */ + } + + return 0; +} + +int arch_misc_init(void) +{ + u32 type, rev; + + get_soc_type_rev(&type, &rev); + + return 0; +} diff --git a/arch/arm/mach-mvebu/alleycat5/soc.h b/arch/arm/mach-mvebu/alleycat5/soc.h new file mode 100644 index 0000000000..97663d2c01 --- /dev/null +++ b/arch/arm/mach-mvebu/alleycat5/soc.h @@ -0,0 +1,7 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ + +#ifndef _ALLEYCAT5_SOC_H +#define _ALLEYCAT5_SOC_H +void soc_print_device_info(void); +void soc_print_clock_info(void); +#endif /* _ALLEYCAT5_SOC_H */ diff --git a/arch/arm/mach-mvebu/arm64-common.c b/arch/arm/mach-mvebu/arm64-common.c index 63f6af5fe8..e3098a7ca8 100644 --- a/arch/arm/mach-mvebu/arm64-common.c +++ b/arch/arm/mach-mvebu/arm64-common.c @@ -53,6 +53,8 @@ __weak int dram_init_banksize(void) return a8k_dram_init_banksize(); else if (CONFIG_IS_ENABLED(ARMADA_3700)) return a3700_dram_init_banksize(); + else if (CONFIG_IS_ENABLED(ALLEYCAT_5)) + return alleycat5_dram_init_banksize(); else return fdtdec_setup_memory_banksize(); } @@ -68,6 +70,9 @@ __weak int dram_init(void) if (CONFIG_IS_ENABLED(ARMADA_3700)) return a3700_dram_init();
+ if (CONFIG_IS_ENABLED(ALLEYCAT_5)) + return alleycat5_dram_init(); + if (fdtdec_setup_mem_size_base() != 0) return -EINVAL;
diff --git a/arch/arm/mach-mvebu/include/mach/cpu.h b/arch/arm/mach-mvebu/include/mach/cpu.h index b127fce865..c17c2440f1 100644 --- a/arch/arm/mach-mvebu/include/mach/cpu.h +++ b/arch/arm/mach-mvebu/include/mach/cpu.h @@ -174,6 +174,10 @@ int a3700_dram_init_banksize(void); /* A3700 PCIe regions fixer for device tree */ int a3700_fdt_fix_pcie_regions(void *blob);
+/* Alleycat5 dram functions */ +int alleycat5_dram_init(void); +int alleycat5_dram_init_banksize(void); + /* * get_ref_clk *
The RD-AC5X-32G16HVG6HLG-A0 development board main components and features include: * Main 12V/54V power supply * 270 Gbps throughput packet processor on the main board * DDR4: * SR1: 2GB DDR4 2400MT/S(1GB x 2 pcs ) with ECC(1GB x 1 pcs) * SR2: 4GB DDR4 2400MT/S(2GB x 2 pcs ) with ECC(2GB x 1 pcs) * PCB co-layout with 4GB device to support 8GB (Dual CS) requirement * 16GB eMMC (Samsung KLMAG1JETD-B041006) * 16MB SPI NOR(GD25Q127C) * 32 x 1000 Base-T interfaces * 16 x 2500 Base-T interfaces * SR1: 88E2540*4 * SR2: 88E2580*1+88E2540*2 * Six (6) x 25G Base-R SFP28 interfaces * One (1) x RJ-45 console connector, interfacing to the on board UART * One (1) x USB Type-A connector, interfacing to the USB 2.0 port (0) * One (1) x USB Type-mini B connector, interfacing to the USB 2.0 port (1) * One (1) x RJ-45 1G Base-T Management port, interfacing to the host port (shared with PCIe) Connected to 88E1512 Gigabit Ethernet Phy * One (1) x Oculink port, interfacing to the PCIe port for external CPU connection * POE 802.3AT support on Port 1 ~ Port 32, 802.3BT support on Port 33 ~ Port 48 (Microsemi PD69208T4, PD69208M or TI TPS2388,TPS23881 solution) * POE total power budget 780W * LED interfaces per network port/POE * LED interfaces (common) showing system status * PTP TC mode Supported (Reserved M.2 connector to support BC mode)
Changes in v5: - Remove unused bpard_{early,late}_init{,_r,_f} functions - Remove CPNFIG_PCI and CONFIG_E1000 as the PCI interface is not currently working (requires more vendor code) - Use CONFIG_OF_SEPARATE instead of CONFIG_OF_EMBED
Changes in v4: - Move CONFIG_DISPLAY_BOARDINFO_LATE and CONFIG_ENV_OVERWRITE to the defconfig. - Remove CONFIG_BAUDRATE as this is already set in the default config - Remove CONFIG_USB_MAX_CONTROLLER_COUNT as this is not needed with DM_USB - Remove CONFIG_PREBOOT as we don't have anything to run - Remove commented out CONFIG_BOARD_EARLY_INIT_R - Remove DEBUG_UART configuration - Remove unnecessary console environment variable - Remove CONFIG_MVEBU_SAR
Changes in v3: - Remove MMC and UBIFS distroboot options (MMC driver is not currently functional, NAND is not populated on the RD-AC5X board) - Remove unnecessary Ethernet configuration - Remove unnecessary NAND configuration - Remove memory node from dts so the value passed by the DDR FW will be used
arch/arm/dts/Makefile | 3 +- arch/arm/dts/ac5-98dx35xx-rd.dts | 129 +++++++++++++++++++++ arch/arm/mach-mvebu/Kconfig | 9 +- board/Marvell/mvebu_alleycat-5/MAINTAINERS | 6 + board/Marvell/mvebu_alleycat-5/Makefile | 3 + board/Marvell/mvebu_alleycat-5/board.c | 13 +++ configs/mvebu_ac5_rd_defconfig | 81 +++++++++++++ include/configs/mvebu_alleycat-5.h | 42 +++++++ 8 files changed, 284 insertions(+), 2 deletions(-) create mode 100644 arch/arm/dts/ac5-98dx35xx-rd.dts create mode 100644 board/Marvell/mvebu_alleycat-5/MAINTAINERS create mode 100644 board/Marvell/mvebu_alleycat-5/Makefile create mode 100644 board/Marvell/mvebu_alleycat-5/board.c create mode 100644 configs/mvebu_ac5_rd_defconfig create mode 100644 include/configs/mvebu_alleycat-5.h
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 791838733c..b52077cddc 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -278,7 +278,8 @@ dtb-$(CONFIG_ARCH_MVEBU) += \ cn9132-db-A.dtb \ cn9132-db-B.dtb \ cn9130-crb-A.dtb \ - cn9130-crb-B.dtb + cn9130-crb-B.dtb \ + ac5-98dx35xx-rd.dtb endif
dtb-$(CONFIG_ARCH_SYNQUACER) += synquacer-sc2a11-developerbox.dtb diff --git a/arch/arm/dts/ac5-98dx35xx-rd.dts b/arch/arm/dts/ac5-98dx35xx-rd.dts new file mode 100644 index 0000000000..d9f217cd4a --- /dev/null +++ b/arch/arm/dts/ac5-98dx35xx-rd.dts @@ -0,0 +1,129 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Device Tree For RD-AC5X. + * + * Copyright (C) 2021 Marvell + * Copyright (C) 2022 Allied Telesis Labs + */ +/* + * Device Tree file for Marvell Alleycat 5X development board + * This board file supports the B configuration of the board + */ + +/dts-v1/; + +#include "ac5-98dx35xx.dtsi" + +/ { + model = "Marvell RD-AC5X Board"; + compatible = "marvell,rd-ac5x", "marvell,ac5x", "marvell,ac5"; + + aliases { + serial0 = &uart0; + spiflash0 = &spiflash0; + gpio0 = &gpio0; + gpio1 = &gpio1; + ethernet0 = ð0; + ethernet1 = ð1; + spi0 = &spi0; + i2c0 = &i2c0; + i2c1 = &i2c1; + usb0 = &usb0; + usb1 = &usb1; + pinctrl0 = &pinctrl0; + sar-reg0 = "/config-space/sar-reg"; + }; + + usb1phy: usb-phy { + compatible = "usb-nop-xceiv"; + #phy-cells = <0>; + }; + + chosen { + stdout-path = "serial0:115200n8"; + }; +}; + +&uart0 { + status = "okay"; +}; + +&mdio { + phy0: ethernet-phy@0 { + reg = <0>; + }; +}; + +&i2c0 { + status = "okay"; +}; + +&i2c1 { + status = "okay"; +}; + +ð0 { + status = "okay"; + phy-handle = <&phy0>; +}; + +/* USB0 is a host USB */ +&usb0 { + status = "okay"; +}; + +/* USB1 is a peripheral USB */ +&usb1 { + status = "okay"; + phys = <&usb1phy>; + phy-names = "usb-phy"; + dr_mode = "peripheral"; +}; + +&spi0 { + status = "okay"; + + spiflash0: flash@0 { + compatible = "jedec,spi-nor"; + spi-max-frequency = <50000000>; + spi-tx-bus-width = <1>; /* 1-single, 2-dual, 4-quad */ + spi-rx-bus-width = <1>; /* 1-single, 2-dual, 4-quad */ + reg = <0>; + + #address-cells = <1>; + #size-cells = <1>; + }; +}; + +&pinctrl0 { + /* + * MPP Bus: MPP# mode# + * eMMC [0-11] 0x1 + * SPI[0] [12-17] 0x1 + * TSEN_INT [18] 0x1 + * DEV_INIT [19] 0x1 + * SPI[1] [20-23] 0x3 + * UART[1] [24-25] 0x3 + * I2C[0] [26-27] 0x1 + * XSMI[0] [28-29] 0x1 // SCH use SMI[0], reversed due to CPSS problem + * SMI[1] [30-31] 0x2 // SCH use XSMI[1], reversed due to CPSS problem + * UART[0] [32-33] 0x1 + * OOB_SMI [34-35] 0x1 + * PTP_CLK0_OUT [36] 0x1 + * PTP_PULSE_OUT [37] 0x1 + * RCVR_CLK_OUT [38] 0x1 + * GPIO(in/out) [39] 0x0 + * GPIO(in/out) [40] 0x0 + * PTP_REF_CLK [41] 0x1 + * PTP_CLK0 [42] 0x1 + * LED0_CLK [43] 0x1 + * LED0_STB [44] 0x1 + * LED0_DATA [45] 0x1 + */ + /* 0 1 2 3 4 5 6 7 8 9 */ + pin-func = < 1 1 1 1 1 1 1 1 1 1 + 1 1 1 1 1 1 1 1 1 1 + 3 3 3 3 3 3 1 1 1 1 + 2 2 1 1 1 1 1 1 1 0 + 0 1 1 1 1 1 >; +}; diff --git a/arch/arm/mach-mvebu/Kconfig b/arch/arm/mach-mvebu/Kconfig index e2c98dffe2..594e9a03d9 100644 --- a/arch/arm/mach-mvebu/Kconfig +++ b/arch/arm/mach-mvebu/Kconfig @@ -98,7 +98,7 @@ config CUSTOMER_BOARD_SUPPORT bool
choice - prompt "Armada XP/375/38x/3700/7K/8K board select" + prompt "Armada XP/375/38x/3700/7K/8K/Alleycat-5 board select" optional
config TARGET_CLEARFOG @@ -150,6 +150,10 @@ config TARGET_MVEBU_ARMADA_8K select BOARD_LATE_INIT imply SCSI
+config TARGET_MVEBU_ALLEYCAT5 + bool "Support AlleyCat 5 platforms" + select ALLEYCAT_5 + config TARGET_OCTEONTX2_CN913x bool "Support CN913x platforms" select ARMADA_8K @@ -258,6 +262,7 @@ config SYS_BOARD default "x530" if TARGET_X530 default "db-xc3-24g4xg" if TARGET_DB_XC3_24G4XG default "crs3xx-98dx3236" if TARGET_CRS3XX_98DX3236 + default "mvebu_alleycat-5" if TARGET_MVEBU_ALLEYCAT5
config SYS_CONFIG_NAME default "clearfog" if TARGET_CLEARFOG @@ -278,6 +283,7 @@ config SYS_CONFIG_NAME default "x530" if TARGET_X530 default "db-xc3-24g4xg" if TARGET_DB_XC3_24G4XG default "crs3xx-98dx3236" if TARGET_CRS3XX_98DX3236 + default "mvebu_alleycat-5" if TARGET_MVEBU_ALLEYCAT5
config SYS_VENDOR default "Marvell" if TARGET_DB_MV784MP_GP @@ -297,6 +303,7 @@ config SYS_VENDOR default "gdsys" if TARGET_CONTROLCENTERDC default "alliedtelesis" if TARGET_X530 default "mikrotik" if TARGET_CRS3XX_98DX3236 + default "Marvell" if TARGET_MVEBU_ALLEYCAT5
config SYS_SOC default "mvebu" diff --git a/board/Marvell/mvebu_alleycat-5/MAINTAINERS b/board/Marvell/mvebu_alleycat-5/MAINTAINERS new file mode 100644 index 0000000000..480c07c5f0 --- /dev/null +++ b/board/Marvell/mvebu_alleycat-5/MAINTAINERS @@ -0,0 +1,6 @@ +RD-AC5X BOARD +M: Chris Packham chris.packham@alliedtelesis.co.nz +S: Maintained +F: board/Marvell/mvebu_alleycat-5/ +F: include/configs/mvebu_alleycat-5.h +F: configs/mvebu_ac5_rd_defconfig diff --git a/board/Marvell/mvebu_alleycat-5/Makefile b/board/Marvell/mvebu_alleycat-5/Makefile new file mode 100644 index 0000000000..29254b4d64 --- /dev/null +++ b/board/Marvell/mvebu_alleycat-5/Makefile @@ -0,0 +1,3 @@ +# SPDX-License-Identifier: GPL-2.0+ + +obj-y := board.o diff --git a/board/Marvell/mvebu_alleycat-5/board.c b/board/Marvell/mvebu_alleycat-5/board.c new file mode 100644 index 0000000000..619cd6c6cd --- /dev/null +++ b/board/Marvell/mvebu_alleycat-5/board.c @@ -0,0 +1,13 @@ +// SPDX-License-Identifier: GPL-2.0+ + +#include <common.h> +#include <asm/global_data.h> + +DECLARE_GLOBAL_DATA_PTR; + +int board_init(void) +{ + gd->bd->bi_boot_params = CONFIG_SYS_SDRAM_BASE + 0x100; + + return 0; +} diff --git a/configs/mvebu_ac5_rd_defconfig b/configs/mvebu_ac5_rd_defconfig new file mode 100644 index 0000000000..9235a398c5 --- /dev/null +++ b/configs/mvebu_ac5_rd_defconfig @@ -0,0 +1,81 @@ +CONFIG_ARM=y +CONFIG_ARCH_CPU_INIT=y +CONFIG_ARCH_MVEBU=y +CONFIG_TEXT_BASE=0x200000000 +CONFIG_SYS_MALLOC_LEN=0x900000 +CONFIG_TARGET_MVEBU_ALLEYCAT5=y +CONFIG_ENV_SIZE=0x10000 +CONFIG_ENV_OFFSET=0x400000 +CONFIG_ENV_SECT_SIZE=0x10000 +CONFIG_DM_GPIO=y +CONFIG_DEFAULT_DEVICE_TREE="ac5-98dx35xx-rd" +CONFIG_SYS_LOAD_ADDR=0x202000000 +CONFIG_SYS_MEMTEST_START=0x200800000 +CONFIG_SYS_MEMTEST_END=0x200ffffff +CONFIG_DISTRO_DEFAULTS=y +CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y +CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x200FF0000 +# CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_FIT=y +CONFIG_BOOTDELAY=-1 +CONFIG_SYS_CONSOLE_ENV_OVERWRITE=y +CONFIG_SYS_CONSOLE_INFO_QUIET=y +CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_ARCH_EARLY_INIT_R=y +CONFIG_ARCH_MISC_INIT=y +CONFIG_CMD_BOOTZ=y +CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS=10 +CONFIG_CMD_MEMTEST=y +# CONFIG_CMD_FLASH is not set +CONFIG_CMD_GPIO=y +CONFIG_CMD_I2C=y +CONFIG_CMD_MMC=y +CONFIG_CMD_PCI=y +CONFIG_CMD_SPI=y +CONFIG_CMD_USB=y +# CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_CACHE=y +CONFIG_CMD_TIME=y +CONFIG_CMD_MVEBU_BUBT=y +CONFIG_CMD_REGULATOR=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_UBI=y +CONFIG_MAC_PARTITION=y +CONFIG_ENV_OVERWRITE=y +CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_CLK=y +CONFIG_CLK_MVEBU=y +CONFIG_DM_PCA953X=y +CONFIG_DM_I2C=y +CONFIG_SYS_I2C_MVTWSI=y +CONFIG_MISC=y +CONFIG_MMC_SDHCI=y +CONFIG_MMC_SDHCI_XENON=y +CONFIG_MTD=y +CONFIG_SPI_FLASH_GIGADEVICE=y +CONFIG_SPI_FLASH_MACRONIX=y +CONFIG_SPI_FLASH_SPANSION=y +CONFIG_SPI_FLASH_STMICRO=y +CONFIG_PHY_MARVELL=y +CONFIG_PHY_GIGE=y +CONFIG_MVNETA=y +CONFIG_MVMDIO=y +CONFIG_PHY=y +CONFIG_PINCTRL=y +CONFIG_PINCTRL_ARMADA_8K=y +CONFIG_DM_REGULATOR_FIXED=y +CONFIG_DM_REGULATOR_GPIO=y +CONFIG_DM_RTC=y +CONFIG_DM_SCSI=y +CONFIG_SYS_NS16550=y +CONFIG_MVEBU_A3700_SPI=y +CONFIG_DM_THERMAL=y +CONFIG_USB=y +CONFIG_USB_XHCI_HCD=y +CONFIG_USB_EHCI_HCD=y +CONFIG_USB_HOST_ETHER=y +CONFIG_USB_ETHER_ASIX=y +CONFIG_USB_ETHER_ASIX88179=y +CONFIG_USB_ETHER_MCS7830=y +CONFIG_USB_ETHER_RTL8152=y +CONFIG_USB_ETHER_SMSC95XX=y diff --git a/include/configs/mvebu_alleycat-5.h b/include/configs/mvebu_alleycat-5.h new file mode 100644 index 0000000000..41bdfae6c3 --- /dev/null +++ b/include/configs/mvebu_alleycat-5.h @@ -0,0 +1,42 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright (C) 2018 Marvell International Ltd + */ + +#ifndef _CONFIG_MVEBU_ALLEYCAY_5_H +#define _CONFIG_MVEBU_ALLEYCAY_5_H + +#include <asm/arch/soc.h> + +/* additions for new ARM relocation support */ +#define CONFIG_SYS_SDRAM_BASE 0x200000000 + +#define CONFIG_SYS_BAUDRATE_TABLE { 9600, 19200, 38400, 57600, \ + 115200, 230400, 460800, 921600 } + +/* Default Env vars */ +#define CONFIG_IPADDR 0.0.0.0 /* In order to cause an error */ +#define CONFIG_SERVERIP 0.0.0.0 /* In order to cause an error */ +#define CONFIG_NETMASK 255.255.255.0 +#define CONFIG_GATEWAYIP 0.0.0.0 +#define CONFIG_ROOTPATH "/srv/nfs/" /* Default Dir for NFS */ + +#define BOOT_TARGET_DEVICES(func) \ + func(USB, usb, 0) \ + func(DHCP, dhcp, na) + +#include <config_distro_bootcmd.h> + +#define CONFIG_EXTRA_ENV_SETTINGS \ + BOOTENV \ + "kernel_addr_r=0x202000000\0" \ + "fdt_addr_r=0x201000000\0" \ + "ramdisk_addr_r=0x206000000\0" \ + "fdtfile=marvell/" CONFIG_DEFAULT_DEVICE_TREE ".dtb\0" + +/* + * High Level Configuration Options (easy to change) + */ +#define CONFIG_SYS_TCLK 325000000 + +#endif /* _CONFIG_MVEBU_ALLEYCAY_5_H */
Changes in v6:
Changes in v5:
Changes in v4:
Changes in v3:
Changes in v2:
Applied to u-boot-marvell/master
Thanks, Stefan
Chris Packham
Ramon Fried
Stefan Roese
