[U-Boot] [PATCH v2] spl, spl_nor: fix compiler warning
executing "tools/buildman/buildman mpc5xx" drops this warning:
common/spl/spl_nor.c: In function 'spl_nor_load_image': common/spl/spl_nor.c:26:10: warning: assignment discards 'const' qualifier from pointer target type [enabled by default]
fix this.
Signed-off-by: Heiko Schocher hs@denx.de
Changes in v2: - add comment from Masahiro Yamada: - add const to "struct image_header *header;" - change subject prefix from "powerpc, mpc5xx" to "spl, spl_nor"
common/spl/spl_nor.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/common/spl/spl_nor.c b/common/spl/spl_nor.c index 2c0e8e0..c2fee01 100644 --- a/common/spl/spl_nor.c +++ b/common/spl/spl_nor.c @@ -17,7 +17,7 @@ void spl_nor_load_image(void)
#ifdef CONFIG_SPL_OS_BOOT if (!spl_start_uboot()) { - struct image_header *header; + const struct image_header *header;
/* * Load Linux from its location in NOR flash to its defined
fix this.
Heiko Schocher
