[U-Boot] [PATCH v2 1/3] mx6: imx-regs: Provide a structure for GPC registers
Introduce a structure for accessing the General Power Controller block (GPC) registers.
Signed-off-by: Fabio Estevam fabio.estevam@freescale.com --- Changes since v1: - None
arch/arm/include/asm/arch-mx6/imx-regs.h | 13 +++++++++++++ 1 file changed, 13 insertions(+)
diff --git a/arch/arm/include/asm/arch-mx6/imx-regs.h b/arch/arm/include/asm/arch-mx6/imx-regs.h index 2631beb..22614fc 100644 --- a/arch/arm/include/asm/arch-mx6/imx-regs.h +++ b/arch/arm/include/asm/arch-mx6/imx-regs.h @@ -419,6 +419,19 @@ struct iomuxc { u32 gpr[14]; };
+struct gpc { + u32 cntr; + u32 pgr; + u32 imr1; + u32 imr2; + u32 imr3; + u32 imr4; + u32 isr1; + u32 isr2; + u32 isr3; + u32 isr4; +}; + #define IOMUXC_GPR2_COUNTER_RESET_VAL_OFFSET 20 #define IOMUXC_GPR2_COUNTER_RESET_VAL_MASK (3<<IOMUXC_GPR2_COUNTER_RESET_VAL_OFFSET) #define IOMUXC_GPR2_LVDS_CLK_SHIFT_OFFSET 16
Let PCI on mx6solox also be supported.
Signed-off-by: Fabio Estevam fabio.estevam@freescale.com --- Changes since v1: - Put the definition of gpc inside CONFIG_MX6SX ifdef - Use setbits_le32 to configure register CNTR - Improve comments in the code
arch/arm/cpu/armv7/mx6/clock.c | 9 ++++++++ arch/arm/include/asm/arch-mx6/iomux.h | 9 ++++++++ drivers/pci/pcie_imx.c | 40 +++++++++++++++++++++++++++++++---- 3 files changed, 54 insertions(+), 4 deletions(-)
diff --git a/arch/arm/cpu/armv7/mx6/clock.c b/arch/arm/cpu/armv7/mx6/clock.c index abd9d61..dd628d8 100644 --- a/arch/arm/cpu/armv7/mx6/clock.c +++ b/arch/arm/cpu/armv7/mx6/clock.c @@ -504,10 +504,19 @@ int enable_pcie_clock(void) #define ANADIG_ANA_MISC1_LVDSCLK1_IBEN (1 << 12) #define ANADIG_ANA_MISC1_LVDSCLK1_OBEN (1 << 10) #define ANADIG_ANA_MISC1_LVDS1_CLK_SEL_MASK 0x0000001F +#ifndef CONFIG_MX6SX + /* lvds_clk1 is sourced from sata ref on imx6q/dl/solo */ clrsetbits_le32(&anatop_regs->ana_misc1, ANADIG_ANA_MISC1_LVDSCLK1_IBEN | ANADIG_ANA_MISC1_LVDS1_CLK_SEL_MASK, ANADIG_ANA_MISC1_LVDSCLK1_OBEN | 0xb); +#else + /* lvds_clk1 is sourced from pcie ref on imx6sx */ + clrsetbits_le32(&anatop_regs->ana_misc1, + ANADIG_ANA_MISC1_LVDSCLK1_IBEN | + ANADIG_ANA_MISC1_LVDS1_CLK_SEL_MASK, + ANADIG_ANA_MISC1_LVDSCLK1_OBEN | 0xa); +#endif
/* PCIe reference clock sourced from AXI. */ clrbits_le32(&ccm_regs->cbcmr, MXC_CCM_CBCMR_PCIE_AXI_CLK_SEL); diff --git a/arch/arm/include/asm/arch-mx6/iomux.h b/arch/arm/include/asm/arch-mx6/iomux.h index 6a4a632..c86aa31 100644 --- a/arch/arm/include/asm/arch-mx6/iomux.h +++ b/arch/arm/include/asm/arch-mx6/iomux.h @@ -19,6 +19,12 @@ #define IOMUXC_GPR1_TEST_POWERDOWN (1 << 18)
/* + * IOMUXC_GPR5 bit fields + */ +#define IOMUXC_GPR5_PCIE_BTNRST (1 << 19) +#define IOMUXC_GPR5_PCIE_PERST (1 << 18) + +/* * IOMUXC_GPR8 bit fields */ #define IOMUXC_GPR8_PCS_TX_DEEMPH_GEN1_MASK (0x3f << 0) @@ -35,12 +41,15 @@ /* * IOMUXC_GPR12 bit fields */ +#define IOMUXC_GPR12_RX_EQ_2 (0x2 << 0) +#define IOMUXC_GPR12_RX_EQ_MASK (0x7 << 0) #define IOMUXC_GPR12_LOS_LEVEL_9 (0x9 << 4) #define IOMUXC_GPR12_LOS_LEVEL_MASK (0x1f << 4) #define IOMUXC_GPR12_APPS_LTSSM_ENABLE (1 << 10) #define IOMUXC_GPR12_DEVICE_TYPE_EP (0x0 << 12) #define IOMUXC_GPR12_DEVICE_TYPE_RC (0x4 << 12) #define IOMUXC_GPR12_DEVICE_TYPE_MASK (0xf << 12) +#define IOMUXC_GPR12_TEST_POWERDOWN (1 << 30)
/* * IOMUXC_GPR13 bit fields diff --git a/drivers/pci/pcie_imx.c b/drivers/pci/pcie_imx.c index a3982c4..194da2e 100644 --- a/drivers/pci/pcie_imx.c +++ b/drivers/pci/pcie_imx.c @@ -23,13 +23,20 @@ #define PCI_ACCESS_READ 0 #define PCI_ACCESS_WRITE 1
+#ifdef CONFIG_MX6SX +#define MX6_DBI_ADDR 0x08ffc000 +#define MX6_IO_ADDR 0x08000000 +#define MX6_MEM_ADDR 0x08100000 +#define MX6_ROOT_ADDR 0x08f00000 +#else #define MX6_DBI_ADDR 0x01ffc000 -#define MX6_DBI_SIZE 0x4000 #define MX6_IO_ADDR 0x01000000 -#define MX6_IO_SIZE 0x100000 #define MX6_MEM_ADDR 0x01100000 -#define MX6_MEM_SIZE 0xe00000 #define MX6_ROOT_ADDR 0x01f00000 +#endif +#define MX6_DBI_SIZE 0x4000 +#define MX6_IO_SIZE 0x100000 +#define MX6_MEM_SIZE 0xe00000 #define MX6_ROOT_SIZE 0xfc000
/* PCIe Port Logic registers (memory-mapped) */ @@ -57,6 +64,8 @@ #define PHY_RX_OVRD_IN_LO_RX_DATA_EN (1 << 5) #define PHY_RX_OVRD_IN_LO_RX_PLL_EN (1 << 3)
+#define PCIE_PHY_PUP_REQ (1 << 7) + /* iATU registers */ #define PCIE_ATU_VIEWPORT 0x900 #define PCIE_ATU_REGION_INBOUND (0x1 << 31) @@ -421,9 +430,19 @@ static int imx_pcie_write_config(struct pci_controller *hose, pci_dev_t d, static int imx6_pcie_assert_core_reset(void) { struct iomuxc *iomuxc_regs = (struct iomuxc *)IOMUXC_BASE_ADDR; - +#if defined(CONFIG_MX6SX) + struct gpc *gpc_regs = (struct gpc *)GPC_BASE_ADDR; + + /* SSP_EN is not used on MX6SX anymore */ + setbits_le32(&iomuxc_regs->gpr[12], IOMUXC_GPR12_TEST_POWERDOWN); + /* Force PCIe PHY reset */ + setbits_le32(&iomuxc_regs->gpr[5], IOMUXC_GPR5_PCIE_BTNRST); + /* Power up PCIe PHY */ + setbits_le32(&gpc_regs->cntr, PCIE_PHY_PUP_REQ); +#else setbits_le32(&iomuxc_regs->gpr[1], IOMUXC_GPR1_TEST_POWERDOWN); clrbits_le32(&iomuxc_regs->gpr[1], IOMUXC_GPR1_REF_SSP_EN); +#endif
return 0; } @@ -441,6 +460,12 @@ static int imx6_pcie_init_phy(void) IOMUXC_GPR12_LOS_LEVEL_MASK, IOMUXC_GPR12_LOS_LEVEL_9);
+#ifdef CONFIG_MX6SX + clrsetbits_le32(&iomuxc_regs->gpr[12], + IOMUXC_GPR12_RX_EQ_MASK, + IOMUXC_GPR12_RX_EQ_2); +#endif + writel((0x0 << IOMUXC_GPR8_PCS_TX_DEEMPH_GEN1_OFFSET) | (0x0 << IOMUXC_GPR8_PCS_TX_DEEMPH_GEN2_3P5DB_OFFSET) | (20 << IOMUXC_GPR8_PCS_TX_DEEMPH_GEN2_6DB_OFFSET) | @@ -517,9 +542,16 @@ static int imx6_pcie_deassert_core_reset(void) */ mdelay(50);
+#if defined(CONFIG_MX6SX) + /* SSP_EN is not used on MX6SX anymore */ + clrbits_le32(&iomuxc_regs->gpr[12], IOMUXC_GPR12_TEST_POWERDOWN); + /* Clear PCIe PHY reset bit */ + clrbits_le32(&iomuxc_regs->gpr[5], IOMUXC_GPR5_PCIE_BTNRST); +#else /* Enable PCIe */ clrbits_le32(&iomuxc_regs->gpr[1], IOMUXC_GPR1_TEST_POWERDOWN); setbits_le32(&iomuxc_regs->gpr[1], IOMUXC_GPR1_REF_SSP_EN); +#endif
imx6_pcie_toggle_reset();
- /* lvds_clk1 is sourced from sata ref on imx6q/dl/solo */ clrsetbits_le32(&anatop_regs->ana_misc1, ANADIG_ANA_MISC1_LVDSCLK1_IBEN | ANADIG_ANA_MISC1_LVDS1_CLK_SEL_MASK, ANADIG_ANA_MISC1_LVDSCLK1_OBEN | 0xb);
+#else
- /* lvds_clk1 is sourced from pcie ref on imx6sx */
- clrsetbits_le32(&anatop_regs->ana_misc1,
Is that only 1-bit difference here ? What does the magic 0xa and 0xb stand for please ?
Best regards, Marek Vasut
+#else
Correct.
0xa means that LVDS1_CLK_SEL comes from PCIE_REF — PCIe ref clock
0xb means that LVDS1_CLK_SEL comes from SATA_REF — SATA ref clock
In this patch I have added comments for both cases, so hopefully it is clear.
+#else
Correct.
Can you maybe pull the mask out and just ORR it with the correct bit in the ifdef ? Or -- even better, can this not be done at runtime ?
Yes, I implemented the run-time approach in v3. Thanks
Tested with an Intel Wireless PCI 7260HMW card:
U-Boot 2014.10-rc1-16576-g4a8a8a8-dirty (Aug 23 2014 - 16:05:11)
CPU: Freescale i.MX6SX rev1.0 at 792 MHz Reset cause: WDOG Board: MX6SX SABRE SDB I2C: ready DRAM: 1 GiB MMC: FSL_SDHC: 0 00:01.0 - 16c3:abcd - Bridge device 01:00.0 - 8086:08b1 - Network controller
include/configs/mx6sxsabresd.h | 10 ++++++++++ 1 file changed, 10 insertions(+)
diff --git a/include/configs/mx6sxsabresd.h b/include/configs/mx6sxsabresd.h index 7967b5d..467c125 100644 --- a/include/configs/mx6sxsabresd.h +++ b/include/configs/mx6sxsabresd.h @@ -181,6 +181,16 @@ #define CONFIG_POWER_PFUZE100 #define CONFIG_POWER_PFUZE100_I2C_ADDR 0x08
+#define CONFIG_CMD_PCI +#ifdef CONFIG_CMD_PCI +#define CONFIG_PCI +#define CONFIG_PCI_PNP +#define CONFIG_PCI_SCAN_SHOW +#define CONFIG_PCIE_IMX +#define CONFIG_PCIE_IMX_PERST_GPIO IMX_GPIO_NR(2, 1) +#define CONFIG_PCIE_IMX_POWER_GPIO IMX_GPIO_NR(2, 0) +#endif + /* FLASH and environment organization */ #define CONFIG_SYS_NO_FLASH
Fabio Estevam
