[U-Boot] [PATCH v2 0/5] usb: Extend ehci and ohci generic drivers
v2: _ add needed reset_request() in RESET framework _ add error path in ehci/ohci-generic to disable clocks and to assert resets _ add .remove callback with clocks, resets and phy release _ split the replacement of printf() by error() in an independant patch Patrice Chotard (5): reset: add reset_request() usb: host: add error path and remove callback in ehci-generic usb: host: extend generic EHCI driver with PHY usb: host: replace printf() by error() in ehci-generic usb: host: extend generic OHCI with CLOCK, RESET and PHY
drivers/reset/reset-uclass.c | 9 ++++ drivers/usb/host/ehci-generic.c | 96 +++++++++++++++++++++++++++++++++------ drivers/usb/host/ohci-generic.c | 99 +++++++++++++++++++++++++++++++++++++++-- include/reset.h | 9 ++++ 4 files changed, 197 insertions(+), 16 deletions(-)
This is needed in error path to assert previously deasserted reset by using a saved reset_ctl reference.
Signed-off-by: Patrice Chotard patrice.chotard@st.com --- drivers/reset/reset-uclass.c | 9 +++++++++ include/reset.h | 9 +++++++++ 2 files changed, 18 insertions(+)
diff --git a/drivers/reset/reset-uclass.c b/drivers/reset/reset-uclass.c index e92b24f..916f210 100644 --- a/drivers/reset/reset-uclass.c +++ b/drivers/reset/reset-uclass.c @@ -98,6 +98,15 @@ int reset_get_by_name(struct udevice *dev, const char *name, return reset_get_by_index(dev, index, reset_ctl); }
+int reset_request(struct reset_ctl *reset_ctl) +{ + struct reset_ops *ops = reset_dev_ops(reset_ctl->dev); + + debug("%s(reset_ctl=%p)\n", __func__, reset_ctl); + + return ops->request(reset_ctl); +} + int reset_free(struct reset_ctl *reset_ctl) { struct reset_ops *ops = reset_dev_ops(reset_ctl->dev); diff --git a/include/reset.h b/include/reset.h index f45fcf8..4f2e35f 100644 --- a/include/reset.h +++ b/include/reset.h @@ -100,6 +100,15 @@ int reset_get_by_name(struct udevice *dev, const char *name, struct reset_ctl *reset_ctl);
/** + * reset_request - Request a reset signal. + * + * @reset_ctl: A reset control struct. + * + * @return 0 if OK, or a negative error code. + */ +int reset_request(struct reset_ctl *reset_ctl); + +/** * reset_free - Free a previously requested reset signal. * * @reset_ctl: A reset control struct that was previously successfully
Add error path to disable enabled clocks and to assert deasserted resets Populate the remove callback
Signed-off-by: Patrice Chotard patrice.chotard@st.com --- v2: _ split previous path 1, add error path and .remove callback
drivers/usb/host/ehci-generic.c | 81 +++++++++++++++++++++++++++++++++++------ 1 file changed, 70 insertions(+), 11 deletions(-)
diff --git a/drivers/usb/host/ehci-generic.c b/drivers/usb/host/ehci-generic.c index 2190adb..0c29f63 100644 --- a/drivers/usb/host/ehci-generic.c +++ b/drivers/usb/host/ehci-generic.c @@ -11,6 +11,9 @@ #include <dm.h> #include "ehci.h"
+#define EHCI_MAX_CLOCKS 3 +#define EHCI_MAX_RESETS 3 + /* * Even though here we don't explicitly use "struct ehci_ctrl" * ehci_register() expects it to be the first thing that resides in @@ -18,35 +21,74 @@ */ struct generic_ehci { struct ehci_ctrl ctrl; + struct clk clks[EHCI_MAX_CLOCKS]; + struct reset_ctl resets[EHCI_MAX_RESETS]; };
+static void ehci_assert_resets(struct udevice *dev) { + struct generic_ehci *priv = dev_get_priv(dev); + struct reset_ctl reset; + int i; + + for (i = EHCI_MAX_RESETS; i >= 0; --i) { + reset = priv->resets[i]; + + if (reset.dev) { + reset_request(&reset); + reset_assert(&reset); + reset_free(&reset); + } + } +} + +static void ehci_disable_clocks(struct udevice *dev) { + struct generic_ehci *priv = dev_get_priv(dev); + struct clk clk; + int i; + + for (i = EHCI_MAX_CLOCKS; i >= 0; --i) { + clk = priv->clks[i]; + + if (clk.dev) { + clk_request(clk.dev, &clk); + clk_disable(&clk); + clk_free(&clk); + } + } +} + static int ehci_usb_probe(struct udevice *dev) { + struct generic_ehci *priv = dev_get_priv(dev); struct ehci_hccr *hccr; struct ehci_hcor *hcor; - int i; + int i, ret;
- for (i = 0; ; i++) { - struct clk clk; - int ret; + for (i = 0; i < EHCI_MAX_CLOCKS; i++) { + struct clk clk = priv->clks[i];
ret = clk_get_by_index(dev, i, &clk); if (ret < 0) break; - if (clk_enable(&clk)) + if (clk_enable(&clk)) { printf("failed to enable clock %d\n", i); + clk_free(&clk); + goto clk_err; + } clk_free(&clk); }
- for (i = 0; ; i++) { - struct reset_ctl reset; - int ret; + for (i = 0; i < EHCI_MAX_RESETS ; i++) { + struct reset_ctl reset = priv->resets[i];
ret = reset_get_by_index(dev, i, &reset); if (ret < 0) break; - if (reset_deassert(&reset)) + if (reset_deassert(&reset)) { printf("failed to deassert reset %d\n", i); + reset_free(&reset); + goto reset_err; + } reset_free(&reset); }
@@ -54,7 +96,24 @@ static int ehci_usb_probe(struct udevice *dev) hcor = (struct ehci_hcor *)((uintptr_t)hccr + HC_LENGTH(ehci_readl(&hccr->cr_capbase)));
- return ehci_register(dev, hccr, hcor, NULL, 0, USB_INIT_HOST); + ret = ehci_register(dev, hccr, hcor, NULL, 0, USB_INIT_HOST); + if (!ret) + return ret; + +reset_err: + ehci_assert_resets(dev); +clk_err: + ehci_disable_clocks(dev); + + return ret; +} + +static int ehci_usb_remove(struct udevice *dev) { + + ehci_assert_resets(dev); + ehci_disable_clocks(dev); + + return ehci_deregister(dev); }
static const struct udevice_id ehci_usb_ids[] = { @@ -67,7 +126,7 @@ U_BOOT_DRIVER(ehci_generic) = { .id = UCLASS_USB, .of_match = ehci_usb_ids, .probe = ehci_usb_probe, - .remove = ehci_deregister, + .remove = ehci_usb_remove, .ops = &ehci_usb_ops, .priv_auto_alloc_size = sizeof(struct generic_ehci), .flags = DM_FLAG_ALLOC_PRIV_DMA,
And then someone invents controller with four resets and this whole thing ... breaks.
- Even though here we don't explicitly use "struct ehci_ctrl"
- ehci_register() expects it to be the first thing that resides in
- struct clk clks[EHCI_MAX_CLOCKS];
- struct reset_ctl resets[EHCI_MAX_RESETS];
- struct generic_ehci *priv = dev_get_priv(dev);
- int i;
- for (i = EHCI_MAX_RESETS; i >= 0; --i) {
Why start from the end ?
if (reset.dev) {
reset_free(&reset);
- struct clk clk;
- int i;
- for (i = EHCI_MAX_CLOCKS; i >= 0; --i) {
if (clk.dev) {
clk_disable(&clk);
clk_free(&clk);
- struct generic_ehci *priv = dev_get_priv(dev); struct ehci_hccr *hccr; struct ehci_hcor *hcor;
- int i;
- int i, ret;
struct clk clk;
int ret;
clk_free(&clk);
goto clk_err;
clk_free(&clk); }}
int ret;
reset_free(&reset);
goto reset_err;
reset_free(&reset); }}
- ret = ehci_register(dev, hccr, hcor, NULL, 0, USB_INIT_HOST);
- if (!ret)
return ret;
+reset_err:
- ehci_assert_resets(dev);
+clk_err:
- ehci_disable_clocks(dev);
- return ret;
- return ehci_deregister(dev);
- .remove = ehci_usb_remove, .ops = &ehci_usb_ops, .priv_auto_alloc_size = sizeof(struct generic_ehci), .flags = DM_FLAG_ALLOC_PRIV_DMA,
Hi Marek
OK i will use a more generic solution based on list
- int i;
Simply to assert resets in reverse order they have been deasserted. Is it a problematic ?
Thanks
Patrice
if (reset.dev) {
reset_free(&reset);
- struct clk clk;
- int i;
if (clk.dev) {
clk_disable(&clk);
clk_free(&clk);
- int i;
- int i, ret;
struct clk clk;
int ret;
clk_free(&clk);
goto clk_err;
clk_free(&clk); }}
int ret;
reset_free(&reset);
goto reset_err;
- if (!ret)
return ret;
+reset_err:
+clk_err:
- return ret;
Hi Patrice,
Please see below.
You could pass priv instead of dev to avoid this line.
int i;
if (reset.dev) {
reset_free(&reset);
struct clk clk;
int i;
Do you think it is worth adding a function in the uclass to do this to a list of clks?
if (clk.dev) {
clk_disable(&clk);
clk_free(&clk);
int i;
int i, ret;
struct clk clk;
int ret;
struct clk clk = priv->clks[i]; ret = clk_get_by_index(dev, i, &clk); if (ret < 0) break;
clk_free(&clk);
goto clk_err;
} clk_free(&clk); }
int ret;
struct reset_ctl reset = priv->resets[i]; ret = reset_get_by_index(dev, i, &reset); if (ret < 0) break;
reset_free(&reset);
goto reset_err;
if (!ret)
return ret;
+reset_err:
+clk_err:
return ret;
-- 1.9.1
Hi Simon
On 05/15/2017 05:03 AM, Simon Glass wrote:
Hi Patrice,
Please see below.
Agree, will fix it
int i;
if (reset.dev) {
reset_free(&reset);
struct clk clk;
int i;
I will have a look at this
Patrice
if (clk.dev) {
clk_disable(&clk);
clk_free(&clk);
int i;
int i, ret;
struct clk clk;
int ret;
clk_free(&clk);
goto clk_err;
} clk_free(&clk); }
int ret;
reset_free(&reset);
goto reset_err;
if (!ret)
return ret;
+reset_err:
+clk_err:
return ret;
-- 1.9.1
Add support of generic PHY framework
v2: _ split previous path 1, add generic PHY framework
drivers/usb/host/ehci-generic.c | 11 +++++++++++ 1 file changed, 11 insertions(+)
diff --git a/drivers/usb/host/ehci-generic.c b/drivers/usb/host/ehci-generic.c index 0c29f63..0000808 100644 --- a/drivers/usb/host/ehci-generic.c +++ b/drivers/usb/host/ehci-generic.c @@ -6,6 +6,8 @@
#include <common.h> #include <clk.h> +#include <fdtdec.h> +#include <generic-phy.h> #include <reset.h> #include <asm/io.h> #include <dm.h> @@ -23,6 +25,7 @@ struct generic_ehci { struct ehci_ctrl ctrl; struct clk clks[EHCI_MAX_CLOCKS]; struct reset_ctl resets[EHCI_MAX_RESETS]; + struct phy phy; };
static void ehci_assert_resets(struct udevice *dev) { @@ -92,6 +95,10 @@ static int ehci_usb_probe(struct udevice *dev) reset_free(&reset); }
+ if (!generic_phy_get_by_index(dev, 0, &priv->phy)) + if (generic_phy_init(&priv->phy)) + error("failed to init usb phy %d\n", i); + hccr = map_physmem(dev_get_addr(dev), 0x100, MAP_NOCACHE); hcor = (struct ehci_hcor *)((uintptr_t)hccr + HC_LENGTH(ehci_readl(&hccr->cr_capbase))); @@ -100,6 +107,8 @@ static int ehci_usb_probe(struct udevice *dev) if (!ret) return ret;
+ generic_phy_exit(&priv->phy); + reset_err: ehci_assert_resets(dev); clk_err: @@ -109,7 +118,9 @@ clk_err: }
static int ehci_usb_remove(struct udevice *dev) { + struct generic_ehci *priv = dev_get_priv(dev);
+ generic_phy_exit(&priv->phy); ehci_assert_resets(dev); ehci_disable_clocks(dev);
- struct phy phy;
- if (!generic_phy_get_by_index(dev, 0, &priv->phy))
- hccr = map_physmem(dev_get_addr(dev), 0x100, MAP_NOCACHE); hcor = (struct ehci_hcor *)((uintptr_t)hccr + HC_LENGTH(ehci_readl(&hccr->cr_capbase)));
- generic_phy_exit(&priv->phy);
So you probe the EHCI controller driver and then you disable it's PHY ? That's a bit odd, isn't it ?
Hi Marek
- struct phy phy;
The PHY is disabled in case of ehci_register() didn't succeed.
Patrice
Hi Patrice,
struct phy phy;
Can you check for the error you expect here when it is not present? I think it might be -ENOENT? That way you are not ignoring a real error.
Shouldn't you return the error here? I don't think USB will work without the PHY.
-- 1.9.1
Hi Simon
Hi Patrice,
struct phy phy;
ok
Agree, i forgot it
Thanks
Patrice
-- 1.9.1
v2: _ create this independant path for printf() replacement
drivers/usb/host/ehci-generic.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/usb/host/ehci-generic.c b/drivers/usb/host/ehci-generic.c index 0000808..39b56de 100644 --- a/drivers/usb/host/ehci-generic.c +++ b/drivers/usb/host/ehci-generic.c @@ -74,7 +74,7 @@ static int ehci_usb_probe(struct udevice *dev) if (ret < 0) break; if (clk_enable(&clk)) { - printf("failed to enable clock %d\n", i); + error("failed to enable clock %d\n", i); clk_free(&clk); goto clk_err; } @@ -88,7 +88,7 @@ static int ehci_usb_probe(struct udevice *dev) if (ret < 0) break; if (reset_deassert(&reset)) { - printf("failed to deassert reset %d\n", i); + error("failed to deassert reset %d\n", i); reset_free(&reset); goto reset_err; }
Commit message does not explain WHY this change is needed. In fact ... commit message is missing altogether ...
}error("failed to enable clock %d\n", i); clk_free(&clk); goto clk_err;
}error("failed to deassert reset %d\n", i); reset_free(&reset); goto reset_err;
Yes it really helps to have a commit message!
-- Best regards, Marek Vasut
Hi Marek
Yes, my bad i forget it, i will add it in the v3
Thanks
Patrice
Add CLOCK, RESET and generic PHY frameworks support
v2: _ add error path management _ add .remove callback
drivers/usb/host/ohci-generic.c | 99 +++++++++++++++++++++++++++++++++++++++-- 1 file changed, 96 insertions(+), 3 deletions(-)
diff --git a/drivers/usb/host/ohci-generic.c b/drivers/usb/host/ohci-generic.c index f3307f4..f86e223 100644 --- a/drivers/usb/host/ohci-generic.c +++ b/drivers/usb/host/ohci-generic.c @@ -5,26 +5,119 @@ */
#include <common.h> +#include <clk.h> #include <dm.h> +#include <fdtdec.h> +#include <generic-phy.h> +#include <reset.h> + #include "ohci.h"
#if !defined(CONFIG_USB_OHCI_NEW) # error "Generic OHCI driver requires CONFIG_USB_OHCI_NEW" #endif
+#define OHCI_MAX_CLOCKS 3 +#define OHCI_MAX_RESETS 3 + struct generic_ohci { ohci_t ohci; + struct clk clks[OHCI_MAX_CLOCKS]; + struct reset_ctl resets[OHCI_MAX_RESETS]; + struct phy phy; };
+static void ohci_assert_resets(struct udevice *dev) { + struct generic_ohci *priv = dev_get_priv(dev); + struct reset_ctl reset; + int i; + + for (i = OHCI_MAX_RESETS; i >= 0; --i) { + reset = priv->resets[i]; + + if (reset.dev) { + reset_request(&reset); + reset_assert(&reset); + reset_free(&reset); + } + } +} + +static void ohci_disable_clocks(struct udevice *dev) { + struct generic_ohci *priv = dev_get_priv(dev); + struct clk clk; + int i; + + for (i = OHCI_MAX_CLOCKS; i >= 0; --i) { + clk = priv->clks[i]; + + if (clk.dev) { + clk_request(clk.dev, &clk); + clk_disable(&clk); + clk_free(&clk); + } + } +} + static int ohci_usb_probe(struct udevice *dev) { struct ohci_regs *regs = (struct ohci_regs *)dev_get_addr(dev); + struct generic_ohci *priv = dev_get_priv(dev); + int i, ret; + + for (i = 0; i < OHCI_MAX_CLOCKS; i++) { + struct clk clk = priv->clks[i];
- return ohci_register(dev, regs); + ret = clk_get_by_index(dev, i, &clk); + if (ret < 0) + break; + if (clk_enable(&clk)) { + error("failed to enable clock %d\n", i); + clk_free(&clk); + goto clk_err; + } + clk_free(&clk); + } + + for (i = 0; i < OHCI_MAX_RESETS ; i++) { + struct reset_ctl reset = priv->resets[i]; + + ret = reset_get_by_index(dev, i, &reset); + if (ret < 0) + break; + if (reset_deassert(&reset)) { + error("failed to deassert reset %d\n", i); + reset_free(&reset); + goto reset_err; + } + reset_free(&reset); + } + + if (!generic_phy_get_by_index(dev, 0, &priv->phy)) + if (generic_phy_init(&priv->phy)) + error("failed to init usb phy %d\n", i); + + ret = ohci_register(dev, regs); + if (!ret) + return ret; + + generic_phy_exit(&priv->phy); + +reset_err: + ohci_assert_resets(dev); +clk_err: + ohci_disable_clocks(dev); + + return ret; }
-static int ohci_usb_remove(struct udevice *dev) -{ +static int ohci_usb_remove(struct udevice *dev) { + struct generic_ohci *priv = dev_get_priv(dev); + + generic_phy_exit(&priv->phy); + ohci_assert_resets(dev); + ohci_disable_clocks(dev); + return ohci_deregister(dev); }
#include "ohci.h"
struct phy phy;
int i;
if (reset.dev) {
reset_free(&reset);
Don't you need error checking here?
struct clk clk;
int i;
if (clk.dev) {
clk_disable(&clk);
clk_free(&clk);
int i, ret;
if (ret < 0)
break;
clk_free(&clk);
goto clk_err;
clk_free(&clk);
if (ret < 0)
break;
reset_free(&reset);
goto reset_err;
reset_free(&reset);
if (!ret)
return ret;
+reset_err:
+clk_err:
return ret;
-- 1.9.1
Patrice CHOTARD
