[U-Boot] Samsung I2C driver
Hi Przemyslaw,
At present this driver has a few implementations and supports non-device-tree and non-driver model. From I can see the odroid and perhaps one other platform need conversion and then all of this old stuff can be removed. Do you have any plans to look at this?
Hello Simon,
On 12/07/2015 02:07 PM, Simon Glass wrote:
Hi Przemyslaw,
Yes, this driver is very dirty and needs a big clean-up, however at present I don't have time for doing this.
I can see that there are few boards that are using the old version of this driver. I suppose that the "COMPAT" layer can be enabled for those boards and everything should work as previous, right?
I can help you with the testing for Trats/Trats2/OdroidU3 if you want move it on your own. I could take care of this, but no sooner than in the new year.
+David, who is the vcma9 maintainer.
Hi Przemyslaw,
On 7 December 2015 at 07:00, Przemyslaw Marczak p.marczak@samsung.com wrote:
Hello Simon,
Hi Przemyslaw,
I can leave it to you for when you have time. David are you able to move your board to driver model for i2c?
To be frank, I don't know it (yet). Being a total DM novice, it is difficult for me to estimate the amount of effort needed to do the conversion.
Is it really possible to convert just the I2C subsystem to DM and keep the rest as is?
Dave
Hi David,
On 11 December 2015 at 05:07, David Müller (ELSOFT AG) d.mueller@elsoft.ch wrote:
Yes, you can define CONFIG_DM_I2C to do this. But you will always need CONFIG_DM and on exynos you will need a device tree - hopefully you have one from Linux for your board.
Hi Przemyslaw,
Hello Simon,
Hi Przemyslaw,
That's ok for me. I have plan to do few things around this task and I think, that David will have enough time to move his board to dm before I finish all my tasks.
Hello
I'm currently implementing DM support in the s3c24xx serial driver and activating DM support for the VCMA9 board using
CONFIG_DM=y CONFIG_DM_SERIAL=y CONFIG_OF_CONTROL=y CONFIG_OF_EMBED=y CONFIG_DEFAULT_DEVICE_TREE="s3c24xx-vcma9"
This results in the following problem:
CC drivers/i2c/s3c24x0_i2c.o drivers/i2c/s3c24x0_i2c.c: In function 'process_nodes': drivers/i2c/s3c24x0_i2c.c:1024:12: error: 'PINMUX_FLAG_HS_MODE' undeclared (first use in this function) drivers/i2c/s3c24x0_i2c.c:1024:12: note: each undeclared identifier is reported only once for each function it appears in drivers/i2c/s3c24x0_i2c.c:1035:3: warning: implicit declaration of function 'pinmux_decode_periph_id' [-Wimplicit-function-declaration] drivers/i2c/s3c24x0_i2c.c:1041:3: warning: implicit declaration of function 'exynos_pinmux_config' [-Wimplicit-function-declaration] make[1]: *** [drivers/i2c/s3c24x0_i2c.o] Error 1
Do you have an updated version of the s3c24xx I2C driver available yet?
Thanks
Hi David,
On 20 February 2016 at 00:04, David Müller (ELSOFT AG) d.mueller@elsoft.ch wrote:
Hello
This seems to be because:
#if (defined CONFIG_EXYNOS4 || defined CONFIG_EXYNOS5) #include <asm/arch/clk.h> #include <asm/arch/cpu.h> #include <asm/arch/pinmux.h> #else #include <asm/arch/s3c24x0_cpu.h> #endif
so perhaps you need to check if the pinmux needs to be defined for your chip?
Przemyslaw Marczak
