[U-Boot] [PATCH v2 0/3] Do not hard-code the command name 'make' in higher-level tools
Masahiro Yamada (3): scripts: add scripts/show-gnu-make to get GNU Make command name MAKEALL: make sure to invoke GNU Make buildman: make sure to invoke GNU Make
MAKEALL | 12 +++++++++--- scripts/show-gnu-make | 25 +++++++++++++++++++++++++ tools/buildman/builder.py | 6 ++++-- tools/buildman/control.py | 9 ++++++++- 4 files changed, 46 insertions(+), 6 deletions(-) create mode 100755 scripts/show-gnu-make
U-Boot is expected to be built on various platforms.
We should keep in mind that the command 'make' is not always GNU Make, while all the makefiles are written for GNU Make.
For example, on Linux, people generally do:
make <board>_config; make
But FreeBSD folks do
gmake <board>_config; gmake
(The command 'make' on FreeBSD is BSD Make, not GNU Make)
It is not a good idea to hard-code the command name 'make' in MAKEALL or buildman.
They should call this helper script and get the command name for GNU Make.
Signed-off-by: Masahiro Yamada yamada.m@jp.panasonic.com ---
Changes in v2: - Use dashes for filename - Show the command name instead of invoking make. It allows us to check the command name once at startup (and error out if no GNU Make is found.)
scripts/show-gnu-make | 25 +++++++++++++++++++++++++ 1 file changed, 25 insertions(+) create mode 100755 scripts/show-gnu-make
diff --git a/scripts/show-gnu-make b/scripts/show-gnu-make new file mode 100755 index 0000000..26271b5 --- /dev/null +++ b/scripts/show-gnu-make @@ -0,0 +1,25 @@ +#!/bin/sh +# +# Show the command name for GNU Make +# +# U-Boot is supposed to be built on various platforms. +# One problem is that the command 'make' is not always GNU Make. +# (For ex. the command name for GNU Make on FreeBSD is usually 'gmake'.) +# It is not a good idea to hard-code the command name in scripts +# where where GNU Make is expected. +# Call this helper script to get the command name for GNU Make. +# +# SPDX-License-Identifier: GPL-2.0+ +# + +gnu_make= + +for m in make gmake +do + if $m --version 2>/dev/null | grep -q GNU; then + echo $m + exit 0 + fi +done + +exit 1
Since the command name 'make' may not be GNU Make on some platforms such as FreeBSD, MAKEALL should call scripts/show-gnu-make to get the command name for GNU MAKE (and error out if it is not found).
The GNU Make should be searched after parsing options because we want to allow "MAKEALL -h" even if GNU Make is missing on the system.
Changes in v2: - Check GNU Make only once at startup. It seems more reasonable because MAKEALL generally invokes make over and over again.
MAKEALL | 12 +++++++++--- 1 file changed, 9 insertions(+), 3 deletions(-)
diff --git a/MAKEALL b/MAKEALL index 37ef71e..9510982 100755 --- a/MAKEALL +++ b/MAKEALL @@ -162,6 +162,12 @@ while true ; do echo "Internal error!" >&2 ; exit 1 ;; esac done + +GNU_MAKE=$(scripts/show-gnu-make) || { + echo "GNU Make not found" >&2 + exit 1 +} + # echo "Remaining arguments:" # for arg do echo '--> '"`$arg'" ; done
@@ -633,11 +639,11 @@ build_target() { target_arch=$(get_target_arch ${target}) eval cross_toolchain=$CROSS_COMPILE_`echo $target_arch | tr '[:lower:]' '[:upper:]'` if [ "${cross_toolchain}" ] ; then - MAKE="make CROSS_COMPILE=${cross_toolchain}" + MAKE="$GNU_MAKE CROSS_COMPILE=${cross_toolchain}" elif [ "${CROSS_COMPILE}" ] ; then - MAKE="make CROSS_COMPILE=${CROSS_COMPILE}" + MAKE="$GNU_MAKE CROSS_COMPILE=${CROSS_COMPILE}" else - MAKE=make + MAKE=$GNU_MAKE fi
if [ "${output_dir}" != "." ] ; then
Changes in v2:
Signed-off-by: Masahiro Yamada yamada.m@jp.panasonic.com Acked-by: Simon Glass sjg@chromium.org
Since the command name 'make' may not be GNU Make on some platforms such as FreeBSD, buildman should call scripts/show-gnu-make to get the command name for GNU MAKE (and error out if it is not found).
Signed-off-by: Masahiro Yamada yamada.m@jp.panasonic.com Acked-by: Simon Glass sjg@chromium.org Tested-by: Jeroen Hofstee jeroen@myspectrum.nl ---
Changes in v2: - Check GNU Make only once at startup. It seems more reasonable because buildman generally invokes make over and over again.
tools/buildman/builder.py | 6 ++++-- tools/buildman/control.py | 9 ++++++++- 2 files changed, 12 insertions(+), 3 deletions(-)
diff --git a/tools/buildman/builder.py b/tools/buildman/builder.py index 4a2d753..4987fc9 100644 --- a/tools/buildman/builder.py +++ b/tools/buildman/builder.py @@ -546,7 +546,7 @@ class Builder: self.func_sizes = func_sizes
def __init__(self, toolchains, base_dir, git_dir, num_threads, num_jobs, - checkout=True, show_unknown=True, step=1): + gnu_make='make', checkout=True, show_unknown=True, step=1): """Create a new Builder object
Args: @@ -555,6 +555,7 @@ class Builder: git_dir: Git directory containing source repository num_threads: Number of builder threads to run num_jobs: Number of jobs to run at once (passed to make as -j) + gnu_make: the command name of GNU Make. checkout: True to check out source, False to skip that step. This is used for testing. show_unknown: Show unknown boards (those not built) in summary @@ -566,6 +567,7 @@ class Builder: self.threads = [] self.active = True self.do_make = self.Make + self.gnu_make = gnu_make self.checkout = checkout self.num_threads = num_threads self.num_jobs = num_jobs @@ -667,7 +669,7 @@ class Builder: args: Arguments to pass to make kwargs: Arguments to pass to command.RunPipe() """ - cmd = ['make'] + list(args) + cmd = [self.gnu_make] + list(args) result = command.RunPipe([cmd], capture=True, capture_stderr=True, cwd=cwd, raise_on_error=False, **kwargs) return result diff --git a/tools/buildman/control.py b/tools/buildman/control.py index d2f4102..fd6f197 100644 --- a/tools/buildman/control.py +++ b/tools/buildman/control.py @@ -14,6 +14,7 @@ import gitutil import patchstream import terminal import toolchain +import command
def GetPlural(count): """Returns a plural 's' if count is not 1""" @@ -144,10 +145,16 @@ def DoBuildman(options, args): if not options.step: options.step = len(series.commits) - 1
+ gnu_make = command.Output(os.path.join(options.git, + 'scripts/show-gnu-make')).rstrip() + if not gnu_make: + print >> sys.stderr, 'GNU Make not found' + sys.exit(1) + # Create a new builder with the selected options output_dir = os.path.join(options.output_dir, options.branch) builder = Builder(toolchains, output_dir, options.git_dir, - options.threads, options.jobs, checkout=True, + options.threads, options.jobs, gnu_make=gnu_make, checkout=True, show_unknown=options.show_unknown, step=options.step) builder.force_config_on_failure = not options.quick
Masahiro Yamada
