[U-Boot] [PATCH v4 1/2] armv8: fsl-lsch3: add clock support for the second eSDHC
Layerscape began to use two eSDHC controllers, for example, LS1028A. They are same IP block with same reference clock. This patch is to add clock support for the second eSDHC.
Signed-off-by: Yangbo Lu yangbo.lu@nxp.com Signed-off-by: Yinbo Zhu yinbo.zhu@nxp.com --- Change in v4: Update the Copyright
arch/arm/cpu/armv8/fsl-layerscape/fsl_lsch3_speed.c | 3 ++- arch/arm/include/asm/arch-fsl-layerscape/clock.h | 3 ++- 2 files changed, 4 insertions(+), 2 deletions(-)
diff --git a/arch/arm/cpu/armv8/fsl-layerscape/fsl_lsch3_speed.c b/arch/arm/cpu/armv8/fsl-layerscape/fsl_lsch3_speed.c index bc268e207c..0985778ff9 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/fsl_lsch3_speed.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/fsl_lsch3_speed.c @@ -1,6 +1,6 @@ // SPDX-License-Identifier: GPL-2.0+ /* - * Copyright 2014-2015, Freescale Semiconductor, Inc. + * Copyright 2014-2015, 2018 Freescale Semiconductor, Inc. * * Derived from arch/power/cpu/mpc85xx/speed.c */ @@ -214,6 +214,7 @@ unsigned int mxc_get_clock(enum mxc_clock clk) return get_i2c_freq(0); #if defined(CONFIG_FSL_ESDHC) case MXC_ESDHC_CLK: + case MXC_ESDHC2_CLK: return get_sdhc_freq(0); #endif case MXC_DSPI_CLK: diff --git a/arch/arm/include/asm/arch-fsl-layerscape/clock.h b/arch/arm/include/asm/arch-fsl-layerscape/clock.h index cf058d22a9..c6e382b41b 100644 --- a/arch/arm/include/asm/arch-fsl-layerscape/clock.h +++ b/arch/arm/include/asm/arch-fsl-layerscape/clock.h @@ -1,6 +1,6 @@ /* SPDX-License-Identifier: GPL-2.0+ */ /* - * Copyright 2015 Freescale Semiconductor, Inc. + * Copyright 2015, 2018 Freescale Semiconductor, Inc. * */
@@ -14,6 +14,7 @@ enum mxc_clock { MXC_BUS_CLK, MXC_UART_CLK, MXC_ESDHC_CLK, + MXC_ESDHC2_CLK, MXC_I2C_CLK, MXC_DSPI_CLK, };
u-boot is trying to make CONFIG_BLK as a hard requirement for DM_MMC. But now it's still not.
config BLK bool "Support block devices" depends on DM default y if DM_MMC
When fsl_esdhc driver was reworked for DM_MMC support, DM_MMC without CONFIG_BLK enabled wasn't considered. This patch is to fix probe issue without CONFIG_BLK enabled.
drivers/mmc/fsl_esdhc.c | 30 +++++++++++++++++++++++++++++- 1 file changed, 29 insertions(+), 1 deletion(-)
diff --git a/drivers/mmc/fsl_esdhc.c b/drivers/mmc/fsl_esdhc.c index 9e34557d16..53277c9216 100644 --- a/drivers/mmc/fsl_esdhc.c +++ b/drivers/mmc/fsl_esdhc.c @@ -1,6 +1,6 @@ // SPDX-License-Identifier: GPL-2.0+ /* - * Copyright 2007, 2010-2011 Freescale Semiconductor, Inc + * Copyright 2007, 2010-2020 Freescale Semiconductor, Inc * Andy Fleming * * Based vaguely on the pxa mmc code: @@ -25,6 +25,10 @@ #include <asm-generic/gpio.h> #include <dm/pinctrl.h>
+#if !CONFIG_IS_ENABLED(BLK) +#include "mmc_private.h" +#endif + DECLARE_GLOBAL_DATA_PTR;
#define SDHCI_IRQ_EN_BITS (IRQSTATEN_CC | IRQSTATEN_TC | \ @@ -34,6 +38,7 @@ DECLARE_GLOBAL_DATA_PTR; IRQSTATEN_DEBE | IRQSTATEN_BRR | IRQSTATEN_BWR | \ IRQSTATEN_DINT) #define MAX_TUNING_LOOP 40 +#define ESDHC_DRIVER_STAGE_VALUE 0xffffffff
struct fsl_esdhc { uint dsaddr; /* SDMA system address register */ @@ -1448,6 +1453,9 @@ static int fsl_esdhc_probe(struct udevice *dev) fdt_addr_t addr; unsigned int val; struct mmc *mmc; +#if !CONFIG_IS_ENABLED(BLK) + struct blk_desc *bdesc; +#endif int ret;
addr = dev_read_addr(dev); @@ -1576,6 +1584,26 @@ static int fsl_esdhc_probe(struct udevice *dev) mmc = &plat->mmc; mmc->cfg = &plat->cfg; mmc->dev = dev; +#if !CONFIG_IS_ENABLED(BLK) + mmc->priv = priv; + + /* Setup dsr related values */ + mmc->dsr_imp = 0; + mmc->dsr = ESDHC_DRIVER_STAGE_VALUE; + /* Setup the universal parts of the block interface just once */ + bdesc = mmc_get_blk_desc(mmc); + bdesc->if_type = IF_TYPE_MMC; + bdesc->removable = 1; + bdesc->devnum = mmc_get_next_devnum(); + bdesc->block_read = mmc_bread; + bdesc->block_write = mmc_bwrite; + bdesc->block_erase = mmc_berase; + + /* setup initial part type */ + bdesc->part_type = mmc->cfg->part_type; + mmc_list_add(mmc); +#endif + upriv->mmc = mmc;
return esdhc_init_common(priv, mmc);
-----Original Message----- From: Yinbo Zhu yinbo.zhu@nxp.com Sent: Wednesday, May 15, 2019 3:38 PM To: York Sun york.sun@nxp.com; u-boot@lists.denx.de; Vabhav Sharma vabhav.sharma@nxp.com Cc: Yinbo Zhu yinbo.zhu@nxp.com; Xiaobo Xie xiaobo.xie@nxp.com; Jiafei Pan jiafei.pan@nxp.com; Y.b. Lu yangbo.lu@nxp.com; Jagdish Gediya jagdish.gediya@nxp.com; Prabhakar Kushwaha prabhakar.kushwaha@nxp.com; Andy Tang andy.tang@nxp.com Subject: [PATCH v4 2/2] mmc: fsl_esdhc: fix probe issue without CONFIG_BLK enabled
Adding complete history
- Copyright 2007, 2010-2011 Freescale Semiconductor, Inc
- Copyright 2007, 2010-2020 Freescale Semiconductor, Inc
- Andy Fleming
Freescale was there till 2016. After that it is NXP. So add NXP copyright.
Please resend this patch.
- Based vaguely on the pxa mmc code:
- struct blk_desc *bdesc;
+#endif int ret;
- mmc->priv = priv;
- /* Setup dsr related values */
- mmc->dsr_imp = 0;
- mmc->dsr = ESDHC_DRIVER_STAGE_VALUE;
- /* Setup the universal parts of the block interface just once */
- bdesc = mmc_get_blk_desc(mmc);
- bdesc->if_type = IF_TYPE_MMC;
- bdesc->removable = 1;
- bdesc->devnum = mmc_get_next_devnum();
- bdesc->block_read = mmc_bread;
- bdesc->block_write = mmc_bwrite;
- bdesc->block_erase = mmc_berase;
- /* setup initial part type */
- bdesc->part_type = mmc->cfg->part_type;
- mmc_list_add(mmc);
upriv->mmc = mmc;
@ Peng. Can you please ack on this patch
--pk
-----Original Message----- From: Yinbo Zhu yinbo.zhu@nxp.com Sent: Wednesday, May 15, 2019 3:38 PM To: York Sun york.sun@nxp.com; u-boot@lists.denx.de; Vabhav Sharma vabhav.sharma@nxp.com Cc: Yinbo Zhu yinbo.zhu@nxp.com; Xiaobo Xie xiaobo.xie@nxp.com; Jiafei Pan jiafei.pan@nxp.com; Y.b. Lu yangbo.lu@nxp.com; Jagdish Gediya jagdish.gediya@nxp.com; Prabhakar Kushwaha prabhakar.kushwaha@nxp.com; Andy Tang andy.tang@nxp.com Subject: [PATCH v4 1/2] armv8: fsl-lsch3: add clock support for the second eSDHC
Please maintain complete history
- Copyright 2014-2015, Freescale Semiconductor, Inc.
- Copyright 2014-2015, 2018 Freescale Semiconductor, Inc.
Freescale was there till 2016. After that it was NXP.
So please start adding NXP copyright
/* * Copyright 2017-2019 NXP */
--pk
Prabhakar Kushwaha
Yinbo Zhu
