[PATCHv2] fpga_load: pass compatible string
Instead of ignoring the mandatory fpga compatible string, let the different implementations decide how to handle it
Signed-off-by: Jorge Ramirez-Ortiz jorge@foundries.io Reviewed-by: Simon Glass sjg@chromium.org --- RFC v1->v2: added function comment
cmd/fpga.c | 8 ++++---- common/image.c | 4 ++-- common/spl/spl_fit.c | 4 +--- drivers/fpga/fpga.c | 14 +++++++++++--- include/fpga.h | 3 ++- 5 files changed, 20 insertions(+), 13 deletions(-)
diff --git a/cmd/fpga.c b/cmd/fpga.c index 3fdd0b35e8..f3ed1fcdff 100644 --- a/cmd/fpga.c +++ b/cmd/fpga.c @@ -178,7 +178,7 @@ static int do_fpga_load(struct cmd_tbl *cmdtp, int flag, int argc, if (ret) return ret;
- return fpga_load(dev, (void *)fpga_data, data_size, BIT_FULL); + return fpga_load(dev, (void *)fpga_data, data_size, BIT_FULL, NULL); }
static int do_fpga_loadb(struct cmd_tbl *cmdtp, int flag, int argc, @@ -209,7 +209,7 @@ static int do_fpga_loadp(struct cmd_tbl *cmdtp, int flag, int argc, if (ret) return ret;
- return fpga_load(dev, (void *)fpga_data, data_size, BIT_PARTIAL); + return fpga_load(dev, (void *)fpga_data, data_size, BIT_PARTIAL, NULL); } #endif
@@ -315,7 +315,7 @@ static int do_fpga_loadmk(struct cmd_tbl *cmdtp, int flag, int argc, data_size = image_get_data_size(hdr); } return fpga_load(dev, (void *)data, data_size, - BIT_FULL); + BIT_FULL, NULL); } #endif #if defined(CONFIG_FIT) @@ -355,7 +355,7 @@ static int do_fpga_loadmk(struct cmd_tbl *cmdtp, int flag, int argc, return CMD_RET_FAILURE; }
- return fpga_load(dev, fit_data, data_size, BIT_FULL); + return fpga_load(dev, fit_data, data_size, BIT_FULL, NULL); } #endif default: diff --git a/common/image.c b/common/image.c index e199d61a4c..97f3deda24 100644 --- a/common/image.c +++ b/common/image.c @@ -1516,14 +1516,14 @@ int boot_get_fpga(int argc, char *const argv[], bootm_headers_t *images, img_len, BIT_FULL); if (err) err = fpga_load(devnum, (const void *)img_data, - img_len, BIT_FULL); + img_len, BIT_FULL, NULL); } else { name = "partial"; err = fpga_loadbitstream(devnum, (char *)img_data, img_len, BIT_PARTIAL); if (err) err = fpga_load(devnum, (const void *)img_data, - img_len, BIT_PARTIAL); + img_len, BIT_PARTIAL, NULL); }
if (err) diff --git a/common/spl/spl_fit.c b/common/spl/spl_fit.c index f41abca0cc..4db22efd8c 100644 --- a/common/spl/spl_fit.c +++ b/common/spl/spl_fit.c @@ -566,11 +566,9 @@ static int spl_fit_upload_fpga(struct spl_fit_info *ctx, int node, compatible = fdt_getprop(ctx->fit, node, "compatible", NULL); if (!compatible) warn_deprecated("'fpga' image without 'compatible' property"); - else if (strcmp(compatible, "u-boot,fpga-legacy")) - printf("Ignoring compatible = %s property\n", compatible);
ret = fpga_load(0, (void *)fpga_image->load_addr, fpga_image->size, - BIT_FULL); + BIT_FULL, compatible); if (ret) { printf("%s: Cannot load the image to the FPGA\n", __func__); return ret; diff --git a/drivers/fpga/fpga.c b/drivers/fpga/fpga.c index fe3dfa1233..0b03ebbbef 100644 --- a/drivers/fpga/fpga.c +++ b/drivers/fpga/fpga.c @@ -250,9 +250,11 @@ int fpga_loads(int devnum, const void *buf, size_t size, #endif
/* - * Generic multiplexing code + * Generic multiplexing code: + * Each architecture must handle the mandatory FPGA DT compatible property. */ -int fpga_load(int devnum, const void *buf, size_t bsize, bitstream_type bstype) +int fpga_load(int devnum, const void *buf, size_t bsize, bitstream_type bstype, + const char *compatible) { int ret_val = FPGA_FAIL; /* assume failure */ const fpga_desc *desc = fpga_validate(devnum, buf, bsize, @@ -263,13 +265,16 @@ int fpga_load(int devnum, const void *buf, size_t bsize, bitstream_type bstype) case fpga_xilinx: #if defined(CONFIG_FPGA_XILINX) ret_val = xilinx_load(desc->devdesc, buf, bsize, - bstype); + bstype, compatible); #else fpga_no_sup((char *)__func__, "Xilinx devices"); #endif break; case fpga_altera: #if defined(CONFIG_FPGA_ALTERA) + if (strcmp(compatible, "u-boot,fpga-legacy")) + printf("Ignoring compatible = %s property\n", + compatible); ret_val = altera_load(desc->devdesc, buf, bsize); #else fpga_no_sup((char *)__func__, "Altera devices"); @@ -277,6 +282,9 @@ int fpga_load(int devnum, const void *buf, size_t bsize, bitstream_type bstype) break; case fpga_lattice: #if defined(CONFIG_FPGA_LATTICE) + if (strcmp(compatible, "u-boot,fpga-legacy")) + printf("Ignoring compatible = %s property\n", + compatible); ret_val = lattice_load(desc->devdesc, buf, bsize); #else fpga_no_sup((char *)__func__, "Lattice devices"); diff --git a/include/fpga.h b/include/fpga.h index ec5144334d..e351097ae5 100644 --- a/include/fpga.h +++ b/include/fpga.h @@ -63,8 +63,9 @@ int fpga_add(fpga_type devtype, void *desc); int fpga_count(void); const fpga_desc *const fpga_get_desc(int devnum); int fpga_is_partial_data(int devnum, size_t img_len); +/* the DT compatible property must be handled by the different FPGA archs */ int fpga_load(int devnum, const void *buf, size_t bsize, - bitstream_type bstype); + bitstream_type bstype, const char *compatible); int fpga_fsload(int devnum, const void *buf, size_t size, fpga_fs_info *fpga_fsinfo); int fpga_loads(int devnum, const void *buf, size_t size,
Jorge Ramirez-Ortiz
