[U-Boot-Users] [MIPS] cpu/mips/config.mk: Fix GNU assembler minor version picker
Current trick to pick up GNU assembler minor version does not work with the latest binutils (2007-03-01 or later) due to ${PKGVERSION} now default to "(GNU Binutils) ".
$ sde-as --version |grep "GNU assembler" GNU assembler 2.15.94 mipssde-6.02.02-20050602 $ sde-as --version |grep "GNU assembler" |awk '{print $3}' 2.15.94 $ sde-as --version |grep "GNU assembler" |awk '{print $3}' |awk -F. '{print $2}' 15 $
$ mips-linux-as --version |grep "GNU assembler" GNU assembler (GNU Binutils) 2.18 $ mips-linux-as --version |grep "GNU assembler" |awk '{print $3}' (GNU $ mips-linux-as --version |grep "GNU assembler" |awk '{print $3}' |awk -F. '{print $2}' (no output) $
As a result of above, you'll see many noises with such binutils:
make -C cpu/mips/ /bin/sh: line 0: [: : integer expression expected /bin/sh: line 0: [: : integer expression expected make[1]: Entering directory `/home/skuribay/devel/u-boot.git/cpu/mips' mips-linux-gcc -D__ASSEMBLY__ -g -Os -D__KERNEL__ -DTEXT_BASE=0xB0000000 -I/home/skuribay/devel/u-boot.git/include -fno-builtin -ffreestanding -nostdinc -isystem /home/skuribay/devel/buildroot/build_mips/staging_dir/usr/bin/../lib/gcc/mips-linux-uclibc/4.2.1/include -pipe -DCONFIG_MIPS -D__MIPS__ -G 0 -mabicalls -fpic -pipe -msoft-float -march=4kc -mtune=4kc -EB -c -o incaip_wdt.o incaip_wdt.S /bin/sh: line 0: [: : integer expression expected mips-linux-gcc -D__ASSEMBLY__ -g -Os -D__KERNEL__ -DTEXT_BASE=0xB0000000 -I/home/skuribay/devel/u-boot.git/include -fno-builtin -ffreestanding -nostdinc -isystem /home/skuribay/devel/buildroot/build_mips/staging_dir/usr/bin/../lib/gcc/mips-linux-uclibc/4.2.1/include -pipe -DCONFIG_MIPS -D__MIPS__ -G 0 -mabicalls -fpic -pipe -msoft-float -march=4kc -mtune=4kc -EB -c -o cache.o cache.S /bin/sh: line 0: [: : integer expression expected mips-linux-gcc -g -Os -D__KERNEL__ -DTEXT_BASE=0xB0000000 -I/home/skuribay/devel/u-boot.git/include -fno-builtin -ffreestanding -nostdinc -isystem /home/skuribay/devel/buildroot/build_mips/staging_dir/usr/bin/../lib/gcc/mips-linux-uclibc/4.2.1/include -pipe -DCONFIG_MIPS -D__MIPS__ -G 0 -mabicalls -fpic -pipe -msoft-float -march=4kc -mtune=4kc -EB -Wall -Wstrict-prototypes -c -o asc_serial.o asc_serial.c /bin/sh: line 0: [: : integer expression expected
This patch simplifies the trick and makes it work with both versions of gas. I also replace an expensive `awk (or gawk)' with `cut'.
Signed-off-by: Shinya Kuribayashi skuribay@ruby.dti.ne.jp ---
cpu/mips/config.mk | 3 +-- 1 files changed, 1 insertions(+), 2 deletions(-)
diff --git a/cpu/mips/config.mk b/cpu/mips/config.mk index 487c4eb..ad03bd6 100644 --- a/cpu/mips/config.mk +++ b/cpu/mips/config.mk @@ -20,8 +20,7 @@ # Foundation, Inc., 59 Temple Place, Suite 330, Boston, # MA 02111-1307 USA # -v=$(shell \ -$(CROSS_COMPILE)as --version|grep "GNU assembler"|awk '{print $$3}'|awk -F . '{print $$2}') +v=$(shell $(AS) --version |grep "GNU assembler" |cut -d. -f2) MIPSFLAGS=$(shell \ if [ "$v" -lt "14" ]; then \ echo "-mcpu=4kc"; \
Shinya Kuribayashi
