[U-Boot] [PATCH] fsl/sleep: updated the deep sleep framework for QorIQ platforms
With the introducing of generic board and ARM-based cores, current deep sleep framework doesn't work anymore. This patch will convert the current framework to adapt this change. Basically it does: 1. Converts all the Freescale's DDR driver to support deep sleep. 2. Added basic framework support for ARM-based and PPC-based cores separately.
Signed-off-by: Tang Yuantian Yuantian.Tang@freescale.com --- board/freescale/common/Makefile | 6 +++ board/freescale/common/arm_sleep.c | 95 ++++++++++++++++++++++++++++++++++ board/freescale/common/mpc85xx_sleep.c | 88 +++++++++++++++++++++++++++++++ board/freescale/common/sleep.h | 21 ++++++++ drivers/ddr/fsl/arm_ddr_gen3.c | 45 +++++++++++++--- drivers/ddr/fsl/fsl_ddr_gen4.c | 44 ++++++++++++++-- drivers/ddr/fsl/mpc85xx_ddr_gen3.c | 67 +++++++++--------------- include/fsl_ddr_sdram.h | 12 +++-- 8 files changed, 322 insertions(+), 56 deletions(-) create mode 100644 board/freescale/common/arm_sleep.c create mode 100644 board/freescale/common/mpc85xx_sleep.c create mode 100644 board/freescale/common/sleep.h
diff --git a/board/freescale/common/Makefile b/board/freescale/common/Makefile index 32b5a3b..d1b6e3c 100644 --- a/board/freescale/common/Makefile +++ b/board/freescale/common/Makefile @@ -36,6 +36,12 @@ endif
obj-$(CONFIG_FSL_DIU_CH7301) += diu_ch7301.o
+ifdef CONFIG_ARM +obj-$(CONFIG_DEEP_SLEEP) += arm_sleep.o +else +obj-$(CONFIG_DEEP_SLEEP) += mpc85xx_sleep.o +endif + obj-$(CONFIG_FSL_DCU_SII9022A) += dcu_sii9022a.o
obj-$(CONFIG_MPC8541CDS) += cds_pci_ft.o diff --git a/board/freescale/common/arm_sleep.c b/board/freescale/common/arm_sleep.c new file mode 100644 index 0000000..8edf878 --- /dev/null +++ b/board/freescale/common/arm_sleep.c @@ -0,0 +1,95 @@ +/* + * Copyright 2014 Freescale Semiconductor, Inc. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/io.h> +#if !defined(CONFIG_ARMV7_NONSEC) || !defined(CONFIG_ARMV7_VIRT) +#error " Deep sleep needs non-secure mode support. " +#else +#include <asm/secure.h> +#endif +#include <asm/armv7.h> +#include <asm/cache.h> + +#if defined(CONFIG_LS102XA) +#include <asm/arch/immap_ls102xa.h> +#endif + +#include "sleep.h" + +DECLARE_GLOBAL_DATA_PTR; + +void __weak board_mem_sleep_setup(void) +{ +} + +void __weak board_sleep_prepare(void) +{ +} + +bool is_warm_boot(void) +{ + struct ccsr_gur __iomem *gur = (void *)CONFIG_SYS_FSL_GUTS_ADDR; + + if (in_be32(&gur->crstsr) & DCFG_CCSR_CRSTSR_WDRFR) + return 1; + + return 0; +} + +void fsl_dp_disable_console(void) +{ + gd->flags |= GD_FLG_SILENT | GD_FLG_DISABLE_CONSOLE; +} + +/* + * When wakeup from deep sleep, the first 128 bytes space + * will be used to do DDR training which corrupts the data + * in there. This function will restore them. + */ +static void dp_ddr_restore(void) +{ + u64 *src, *dst; + int i; + struct ccsr_scfg __iomem *scfg = (void *)CONFIG_SYS_FSL_SCFG_ADDR; + + /* get the address of ddr date from SPARECR3 */ + src = (u64 *)in_le32(&scfg->sparecr[2]); + dst = (u64 *)CONFIG_SYS_SDRAM_BASE; + + for (i = 0; i < DDR_BUFF_LEN / 8; i++) + *dst++ = *src++; + + flush_dcache_all(); +} + +static void dp_resume_prepare(void) +{ + dp_ddr_restore(); + board_sleep_prepare(); + armv7_init_nonsec(); + cleanup_before_linux(); +} + +int fsl_dp_resume(void) +{ + u32 start_addr; + void (*kernel_resume)(void); + struct ccsr_scfg __iomem *scfg = (void *)CONFIG_SYS_FSL_SCFG_ADDR; + + if (!is_warm_boot()) + return 0; + + dp_resume_prepare(); + + /* Get the entry address and jump to kernel */ + start_addr = in_le32(&scfg->sparecr[1]); + debug("Entry address is 0x%08x\n", start_addr); + kernel_resume = (void (*)(void))start_addr; + secure_ram_addr(_do_nonsec_entry)(kernel_resume, 0, 0, 0); + + return 0; +} diff --git a/board/freescale/common/mpc85xx_sleep.c b/board/freescale/common/mpc85xx_sleep.c new file mode 100644 index 0000000..f924e7f --- /dev/null +++ b/board/freescale/common/mpc85xx_sleep.c @@ -0,0 +1,88 @@ +/* + * Copyright 2014 Freescale Semiconductor, Inc. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/immap_85xx.h> +#include "sleep.h" + +DECLARE_GLOBAL_DATA_PTR; + +void __weak board_mem_sleep_setup(void) +{ +} + +void __weak board_sleep_prepare(void) +{ +} + +bool is_warm_boot(void) +{ + struct ccsr_gur __iomem *gur = (void *)CONFIG_SYS_MPC85xx_GUTS_ADDR; + + if (in_be32(&gur->scrtsr[0]) & DCFG_CCSR_CRSTSR_WDRFR) + return 1; + + return 0; +} + +void fsl_dp_disable_console(void) +{ + gd->flags |= GD_FLG_SILENT | GD_FLG_DISABLE_CONSOLE; +} + +/* + * When wakeup from deep sleep, the first 128 bytes space + * will be used to do DDR training which corrupts the data + * in there. This function will restore them. + */ +static void dp_ddr_restore(void) +{ + volatile u64 *src, *dst; + int i; + struct ccsr_scfg __iomem *scfg = (void *)CONFIG_SYS_MPC85xx_SCFG; + + /* get the address of ddr date from SPARECR3 */ + src = (u64 *)in_be32(&scfg->sparecr[2]); + dst = (u64 *)CONFIG_SYS_SDRAM_BASE; + + for (i = 0; i < DDR_BUFF_LEN / 8; i++) + *dst++ = *src++; + + flush_dcache(); +} + +static void dp_resume_prepare(void) +{ + dp_ddr_restore(); + + board_sleep_prepare(); + + l2cache_init(); +#if defined(CONFIG_RAMBOOT_PBL) + disable_cpc_sram(); +#endif + enable_cpc(); +} + +int fsl_dp_resume(void) +{ + u32 start_addr; + void (*kernel_resume)(void); + struct ccsr_scfg __iomem *scfg = (void *)CONFIG_SYS_MPC85xx_SCFG; + + if (!is_warm_boot()) + return 0; + + dp_resume_prepare(); + + /* Get the entry address and jump to kernel */ + start_addr = in_be32(&scfg->sparecr[1]); + debug("Entry address is 0x%08x\n", start_addr); + kernel_resume = (void (*)(void))start_addr; + kernel_resume(); + + return 0; +} diff --git a/board/freescale/common/sleep.h b/board/freescale/common/sleep.h new file mode 100644 index 0000000..c26c542 --- /dev/null +++ b/board/freescale/common/sleep.h @@ -0,0 +1,21 @@ +/* + * Copyright 2014 Freescale Semiconductor, Inc. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __SLEEP_H +#define __SLEEP_H + +#define DCFG_CCSR_CRSTSR_WDRFR (1 << 3) +#define DDR_BUFF_LEN 128 + +/* determine if it is a wakeup from deep sleep */ +bool is_warm_boot(void); + +/* disable console output */ +void fsl_dp_disable_console(void); + +/* clean up everything and jump to kernel */ +int fsl_dp_resume(void); +#endif diff --git a/drivers/ddr/fsl/arm_ddr_gen3.c b/drivers/ddr/fsl/arm_ddr_gen3.c index 59f2fd6..c139da6 100644 --- a/drivers/ddr/fsl/arm_ddr_gen3.c +++ b/drivers/ddr/fsl/arm_ddr_gen3.c @@ -92,7 +92,6 @@ void fsl_ddr_set_memctl_regs(const fsl_ddr_cfg_regs_t *regs, ddr_out32(&ddr->timing_cfg_0, regs->timing_cfg_0); ddr_out32(&ddr->timing_cfg_1, regs->timing_cfg_1); ddr_out32(&ddr->timing_cfg_2, regs->timing_cfg_2); - ddr_out32(&ddr->sdram_cfg_2, regs->ddr_sdram_cfg_2); ddr_out32(&ddr->sdram_mode, regs->ddr_sdram_mode); ddr_out32(&ddr->sdram_mode_2, regs->ddr_sdram_mode_2); ddr_out32(&ddr->sdram_mode_3, regs->ddr_sdram_mode_3); @@ -105,9 +104,6 @@ void fsl_ddr_set_memctl_regs(const fsl_ddr_cfg_regs_t *regs, ddr_out32(&ddr->sdram_interval, regs->ddr_sdram_interval); ddr_out32(&ddr->sdram_data_init, regs->ddr_data_init); ddr_out32(&ddr->sdram_clk_cntl, regs->ddr_sdram_clk_cntl); - ddr_out32(&ddr->init_addr, regs->ddr_init_addr); - ddr_out32(&ddr->init_ext_addr, regs->ddr_init_ext_addr); - ddr_out32(&ddr->timing_cfg_4, regs->timing_cfg_4); ddr_out32(&ddr->timing_cfg_5, regs->timing_cfg_5); ddr_out32(&ddr->ddr_zq_cntl, regs->ddr_zq_cntl); @@ -128,7 +124,24 @@ void fsl_ddr_set_memctl_regs(const fsl_ddr_cfg_regs_t *regs, ddr_out32(&ddr->ddr_sdram_rcw_1, regs->ddr_sdram_rcw_1); ddr_out32(&ddr->ddr_sdram_rcw_2, regs->ddr_sdram_rcw_2); ddr_out32(&ddr->ddr_cdr1, regs->ddr_cdr1); - ddr_out32(&ddr->ddr_cdr2, regs->ddr_cdr2); +#ifdef CONFIG_DEEP_SLEEP + if (is_warm_boot()) { + ddr_out32(&ddr->sdram_cfg_2, + regs->ddr_sdram_cfg_2 & ~SDRAM_CFG2_D_INIT); + ddr_out32(&ddr->init_addr, CONFIG_SYS_SDRAM_BASE); + ddr_out32(&ddr->init_ext_addr, DDR_INIT_ADDR_EXT_UIA); + + /* DRAM VRef will not be trained */ + ddr_out32(&ddr->ddr_cdr2, + regs->ddr_cdr2 & ~DDR_CDR2_VREF_TRAIN_EN); + } else +#endif + { + ddr_out32(&ddr->sdram_cfg_2, regs->ddr_sdram_cfg_2); + ddr_out32(&ddr->init_addr, regs->ddr_init_addr); + ddr_out32(&ddr->init_ext_addr, regs->ddr_init_ext_addr); + ddr_out32(&ddr->ddr_cdr2, regs->ddr_cdr2); + } ddr_out32(&ddr->err_disable, regs->err_disable); ddr_out32(&ddr->err_int_en, regs->err_int_en); for (i = 0; i < 32; i++) { @@ -167,8 +180,20 @@ step2: udelay(500); asm volatile("dsb sy;isb");
+#ifdef CONFIG_DEEP_SLEEP + if (is_warm_boot()) { + /* enter self-refresh */ + temp_sdram_cfg = ddr_in32(&ddr->sdram_cfg_2); + temp_sdram_cfg |= SDRAM_CFG2_FRC_SR; + ddr_out32(&ddr->sdram_cfg_2, temp_sdram_cfg); + /* do board specific memory setup */ + board_mem_sleep_setup(); + + temp_sdram_cfg = (ddr_in32(&ddr->sdram_cfg) | SDRAM_CFG_BI); + } else +#endif + temp_sdram_cfg = ddr_in32(&ddr->sdram_cfg) & ~SDRAM_CFG_BI; /* Let the controller go */ - temp_sdram_cfg = ddr_in32(&ddr->sdram_cfg) & ~SDRAM_CFG_BI; ddr_out32(&ddr->sdram_cfg, temp_sdram_cfg | SDRAM_CFG_MEM_EN); asm volatile("dsb sy;isb");
@@ -211,4 +236,12 @@ step2:
if (timeout <= 0) printf("Waiting for D_INIT timeout. Memory may not work.\n"); +#ifdef CONFIG_DEEP_SLEEP + if (is_warm_boot()) { + /* exit self-refresh */ + temp_sdram_cfg = ddr_in32(&ddr->sdram_cfg_2); + temp_sdram_cfg &= ~SDRAM_CFG2_FRC_SR; + ddr_out32(&ddr->sdram_cfg_2, temp_sdram_cfg); + } +#endif } diff --git a/drivers/ddr/fsl/fsl_ddr_gen4.c b/drivers/ddr/fsl/fsl_ddr_gen4.c index e024db9..a3c01e7 100644 --- a/drivers/ddr/fsl/fsl_ddr_gen4.c +++ b/drivers/ddr/fsl/fsl_ddr_gen4.c @@ -103,7 +103,6 @@ void fsl_ddr_set_memctl_regs(const fsl_ddr_cfg_regs_t *regs, ddr_out32(&ddr->dq_map_1, regs->dq_map_1); ddr_out32(&ddr->dq_map_2, regs->dq_map_2); ddr_out32(&ddr->dq_map_3, regs->dq_map_3); - ddr_out32(&ddr->sdram_cfg_2, regs->ddr_sdram_cfg_2); ddr_out32(&ddr->sdram_cfg_3, regs->ddr_sdram_cfg_3); ddr_out32(&ddr->sdram_mode, regs->ddr_sdram_mode); ddr_out32(&ddr->sdram_mode_2, regs->ddr_sdram_mode_2); @@ -124,8 +123,6 @@ void fsl_ddr_set_memctl_regs(const fsl_ddr_cfg_regs_t *regs, ddr_out32(&ddr->sdram_md_cntl, regs->ddr_sdram_md_cntl); ddr_out32(&ddr->sdram_interval, regs->ddr_sdram_interval); ddr_out32(&ddr->sdram_data_init, regs->ddr_data_init); - ddr_out32(&ddr->init_addr, regs->ddr_init_addr); - ddr_out32(&ddr->init_ext_addr, regs->ddr_init_ext_addr); ddr_out32(&ddr->ddr_wrlvl_cntl, regs->ddr_wrlvl_cntl); #ifndef CONFIG_SYS_FSL_DDR_EMU /* @@ -147,7 +144,24 @@ void fsl_ddr_set_memctl_regs(const fsl_ddr_cfg_regs_t *regs, ddr_out32(&ddr->ddr_sdram_rcw_5, regs->ddr_sdram_rcw_5); ddr_out32(&ddr->ddr_sdram_rcw_6, regs->ddr_sdram_rcw_6); ddr_out32(&ddr->ddr_cdr1, regs->ddr_cdr1); - ddr_out32(&ddr->ddr_cdr2, regs->ddr_cdr2); +#ifdef CONFIG_DEEP_SLEEP + if (is_warm_boot()) { + ddr_out32(&ddr->sdram_cfg_2, + regs->ddr_sdram_cfg_2 & ~SDRAM_CFG2_D_INIT); + ddr_out32(&ddr->init_addr, CONFIG_SYS_SDRAM_BASE); + ddr_out32(&ddr->init_ext_addr, DDR_INIT_ADDR_EXT_UIA); + + /* DRAM VRef will not be trained */ + ddr_out32(&ddr->ddr_cdr2, + regs->ddr_cdr2 & ~DDR_CDR2_VREF_TRAIN_EN); + } else +#endif + { + ddr_out32(&ddr->sdram_cfg_2, regs->ddr_sdram_cfg_2); + ddr_out32(&ddr->init_addr, regs->ddr_init_addr); + ddr_out32(&ddr->init_ext_addr, regs->ddr_init_ext_addr); + ddr_out32(&ddr->ddr_cdr2, regs->ddr_cdr2); + } ddr_out32(&ddr->err_disable, regs->err_disable); ddr_out32(&ddr->err_int_en, regs->err_int_en); for (i = 0; i < 32; i++) { @@ -187,8 +201,20 @@ step2: mb(); isb();
+#ifdef CONFIG_DEEP_SLEEP + if (is_warm_boot()) { + /* enter self-refresh */ + temp_sdram_cfg = ddr_in32(&ddr->sdram_cfg_2); + temp_sdram_cfg |= SDRAM_CFG2_FRC_SR; + ddr_out32(&ddr->sdram_cfg_2, temp_sdram_cfg); + /* do board specific memory setup */ + board_mem_sleep_setup(); + + temp_sdram_cfg = (ddr_in32(&ddr->sdram_cfg) | SDRAM_CFG_BI); + } else +#endif + temp_sdram_cfg = ddr_in32(&ddr->sdram_cfg) & ~SDRAM_CFG_BI; /* Let the controller go */ - temp_sdram_cfg = ddr_in32(&ddr->sdram_cfg) & ~SDRAM_CFG_BI; ddr_out32(&ddr->sdram_cfg, temp_sdram_cfg | SDRAM_CFG_MEM_EN); mb(); isb(); @@ -233,4 +259,12 @@ step2:
if (timeout <= 0) printf("Waiting for D_INIT timeout. Memory may not work.\n"); +#ifdef CONFIG_DEEP_SLEEP + if (is_warm_boot()) { + /* exit self-refresh */ + temp_sdram_cfg = ddr_in32(&ddr->sdram_cfg_2); + temp_sdram_cfg &= ~SDRAM_CFG2_FRC_SR; + ddr_out32(&ddr->sdram_cfg_2, temp_sdram_cfg); + } +#endif } diff --git a/drivers/ddr/fsl/mpc85xx_ddr_gen3.c b/drivers/ddr/fsl/mpc85xx_ddr_gen3.c index 4d5572e..8f4d01a 100644 --- a/drivers/ddr/fsl/mpc85xx_ddr_gen3.c +++ b/drivers/ddr/fsl/mpc85xx_ddr_gen3.c @@ -15,8 +15,6 @@ #error Invalid setting for CONFIG_CHIP_SELECTS_PER_CTRL #endif
-DECLARE_GLOBAL_DATA_PTR; - /* * regs has the to-be-set values for DDR controller registers * ctrl_num is the DDR controller number @@ -44,16 +42,6 @@ void fsl_ddr_set_memctl_regs(const fsl_ddr_cfg_regs_t *regs, u32 save1, save2; #endif
-#ifdef CONFIG_DEEP_SLEEP - const ccsr_gur_t *gur = (void __iomem *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); - bool sleep_flag = 0; -#endif - -#ifdef CONFIG_DEEP_SLEEP - if (in_be32(&gur->scrtsr[0]) & (1 << 3)) - sleep_flag = 1; -#endif - switch (ctrl_num) { case 0: ddr = (void *)CONFIG_SYS_FSL_DDR_ADDR; @@ -130,13 +118,6 @@ void fsl_ddr_set_memctl_regs(const fsl_ddr_cfg_regs_t *regs, out_be32(&ddr->timing_cfg_0, regs->timing_cfg_0); out_be32(&ddr->timing_cfg_1, regs->timing_cfg_1); out_be32(&ddr->timing_cfg_2, regs->timing_cfg_2); -#ifdef CONFIG_DEEP_SLEEP - if (sleep_flag) - out_be32(&ddr->sdram_cfg_2, - regs->ddr_sdram_cfg_2 & ~SDRAM_CFG2_D_INIT); - else -#endif - out_be32(&ddr->sdram_cfg_2, regs->ddr_sdram_cfg_2); out_be32(&ddr->sdram_mode, regs->ddr_sdram_mode); out_be32(&ddr->sdram_mode_2, regs->ddr_sdram_mode_2); out_be32(&ddr->sdram_mode_3, regs->ddr_sdram_mode_3); @@ -149,17 +130,6 @@ void fsl_ddr_set_memctl_regs(const fsl_ddr_cfg_regs_t *regs, out_be32(&ddr->sdram_interval, regs->ddr_sdram_interval); out_be32(&ddr->sdram_data_init, regs->ddr_data_init); out_be32(&ddr->sdram_clk_cntl, regs->ddr_sdram_clk_cntl); -#ifdef CONFIG_DEEP_SLEEP - if (sleep_flag) { - out_be32(&ddr->init_addr, 0); - out_be32(&ddr->init_ext_addr, (1 << 31)); - } else -#endif - { - out_be32(&ddr->init_addr, regs->ddr_init_addr); - out_be32(&ddr->init_ext_addr, regs->ddr_init_ext_addr); - } - out_be32(&ddr->timing_cfg_4, regs->timing_cfg_4); out_be32(&ddr->timing_cfg_5, regs->timing_cfg_5); out_be32(&ddr->ddr_zq_cntl, regs->ddr_zq_cntl); @@ -180,7 +150,24 @@ void fsl_ddr_set_memctl_regs(const fsl_ddr_cfg_regs_t *regs, out_be32(&ddr->ddr_sdram_rcw_1, regs->ddr_sdram_rcw_1); out_be32(&ddr->ddr_sdram_rcw_2, regs->ddr_sdram_rcw_2); out_be32(&ddr->ddr_cdr1, regs->ddr_cdr1); - out_be32(&ddr->ddr_cdr2, regs->ddr_cdr2); +#ifdef CONFIG_DEEP_SLEEP + if (is_warm_boot()) { + out_be32(&ddr->sdram_cfg_2, + regs->ddr_sdram_cfg_2 & ~SDRAM_CFG2_D_INIT); + out_be32(&ddr->init_addr, CONFIG_SYS_SDRAM_BASE); + out_be32(&ddr->init_ext_addr, DDR_INIT_ADDR_EXT_UIA); + + /* DRAM VRef will not be trained */ + out_be32(&ddr->ddr_cdr2, + regs->ddr_cdr2 & ~DDR_CDR2_VREF_TRAIN_EN); + } else +#endif + { + out_be32(&ddr->sdram_cfg_2, regs->ddr_sdram_cfg_2); + out_be32(&ddr->init_addr, regs->ddr_init_addr); + out_be32(&ddr->init_ext_addr, regs->ddr_init_ext_addr); + out_be32(&ddr->ddr_cdr2, regs->ddr_cdr2); + } out_be32(&ddr->err_disable, regs->err_disable); out_be32(&ddr->err_int_en, regs->err_int_en); for (i = 0; i < 32; i++) { @@ -400,21 +387,17 @@ step2: asm volatile("sync;isync");
#ifdef CONFIG_DEEP_SLEEP - if (sleep_flag) { + if (is_warm_boot()) { /* enter self-refresh */ - setbits_be32(&ddr->sdram_cfg_2, (1 << 31)); + setbits_be32(&ddr->sdram_cfg_2, SDRAM_CFG2_FRC_SR); /* do board specific memory setup */ board_mem_sleep_setup(); - } -#endif - - /* Let the controller go */ -#ifdef CONFIG_DEEP_SLEEP - if (sleep_flag) temp_sdram_cfg = (in_be32(&ddr->sdram_cfg) | SDRAM_CFG_BI); - else + } else #endif temp_sdram_cfg = (in_be32(&ddr->sdram_cfg) & ~SDRAM_CFG_BI); + + /* Let the controller go */ out_be32(&ddr->sdram_cfg, temp_sdram_cfg | SDRAM_CFG_MEM_EN); asm volatile("sync;isync");
@@ -566,8 +549,8 @@ step2: } #endif /* CONFIG_SYS_FSL_ERRATUM_DDR111_DDR134 */ #ifdef CONFIG_DEEP_SLEEP - if (sleep_flag) + if (is_warm_boot()) /* exit self-refresh */ - clrbits_be32(&ddr->sdram_cfg_2, (1 << 31)); + clrbits_be32(&ddr->sdram_cfg_2, SDRAM_CFG2_FRC_SR); #endif } diff --git a/include/fsl_ddr_sdram.h b/include/fsl_ddr_sdram.h index 5b03c14..095b33e 100644 --- a/include/fsl_ddr_sdram.h +++ b/include/fsl_ddr_sdram.h @@ -114,6 +114,7 @@ typedef struct ddr4_spd_eeprom_s generic_spd_eeprom_t; #define SDRAM_CFG_2T_EN 0x00008000 #define SDRAM_CFG_BI 0x00000001
+#define SDRAM_CFG2_FRC_SR 0x80000000 #define SDRAM_CFG2_D_INIT 0x00000010 #define SDRAM_CFG2_ODT_CFG_MASK 0x00600000 #define SDRAM_CFG2_ODT_NEVER 0 @@ -163,6 +164,7 @@ typedef struct ddr4_spd_eeprom_s generic_spd_eeprom_t; #define DDR_CDR1_ODT(x) ((x & DDR_CDR1_ODT_MASK) << DDR_CDR1_ODT_SHIFT) #define DDR_CDR2_ODT(x) (x & DDR_CDR2_ODT_MASK) #define DDR_CDR2_VREF_OVRD(x) (0x00008080 | ((((x) - 37) & 0x3F) << 8)) +#define DDR_CDR2_VREF_TRAIN_EN 0x00000080
#if (defined(CONFIG_SYS_FSL_DDR_VER) && \ (CONFIG_SYS_FSL_DDR_VER >= FSL_DDR_VER_4_7)) @@ -202,6 +204,8 @@ typedef struct ddr4_spd_eeprom_s generic_spd_eeprom_t; #define DDR_CDR_ODT_120ohm 0x6 #endif
+#define DDR_INIT_ADDR_EXT_UIA (1 << 31) + /* Record of register values computed */ typedef struct fsl_ddr_cfg_regs_s { struct { @@ -414,9 +418,11 @@ static int __board_need_mem_reset(void) int board_need_mem_reset(void) __attribute__((weak, alias("__board_need_mem_reset")));
-void __weak board_mem_sleep_setup(void) -{ -} +#if defined(CONFIG_DEEP_SLEEP) +void board_mem_sleep_setup(void); +bool is_warm_boot(void); +int fsl_dp_resume(void); +#endif
/* * The 85xx boards have a common prototype for fixed_sdram so put the
A new interface is introduced to support generic board structure. Converts it to use new interface.
Signed-off-by: Tang Yuantian Yuantian.Tang@freescale.com --- board/freescale/t104xrdb/ddr.c | 19 +++++++++++++++++++ board/freescale/t104xrdb/spl.c | 19 +++---------------- board/freescale/t104xrdb/t104xrdb.c | 24 +++++++++++------------- include/configs/T104xRDB.h | 3 +++ 4 files changed, 36 insertions(+), 29 deletions(-)
diff --git a/board/freescale/t104xrdb/ddr.c b/board/freescale/t104xrdb/ddr.c index 2c331ee..5aa11b1 100644 --- a/board/freescale/t104xrdb/ddr.c +++ b/board/freescale/t104xrdb/ddr.c @@ -11,6 +11,7 @@ #include <fsl_ddr_sdram.h> #include <fsl_ddr_dimm_params.h> #include <asm/fsl_law.h> +#include <asm/mpc85xx_gpio.h> #include "ddr.h"
DECLARE_GLOBAL_DATA_PTR; @@ -109,6 +110,19 @@ found: popts->ddr_cdr2 = DDR_CDR2_ODT(DDR_CDR_ODT_75ohm); }
+#if defined(CONFIG_DEEP_SLEEP) +void board_mem_sleep_setup(void) +{ + void __iomem *cpld_base = (void *)CONFIG_SYS_CPLD_BASE; + + /* does not provide HW signals for power management */ + clrbits_8(cpld_base + 0x17, 0x40); + /* Disable MCKE isolation */ + gpio_set_value(2, 0); + udelay(1); +} +#endif + phys_size_t initdram(int board_type) { phys_size_t dram_size; @@ -124,5 +138,10 @@ phys_size_t initdram(int board_type) #else dram_size = fsl_ddr_sdram_size(); #endif + +#if defined(CONFIG_DEEP_SLEEP) && !defined(CONFIG_SPL_BUILD) + fsl_dp_resume(); +#endif + return dram_size; } diff --git a/board/freescale/t104xrdb/spl.c b/board/freescale/t104xrdb/spl.c index 3822a37..b248f3b 100644 --- a/board/freescale/t104xrdb/spl.c +++ b/board/freescale/t104xrdb/spl.c @@ -11,7 +11,7 @@ #include <mmc.h> #include <fsl_esdhc.h> #include <spi_flash.h> -#include <asm/mpc85xx_gpio.h> +#include "../common/sleep.h"
@@ -58,8 +58,8 @@ void board_init_f(ulong bootflag)
#ifdef CONFIG_DEEP_SLEEP /* disable the console if boot from deep sleep */ - if (in_be32(&gur->scrtsr[0]) & (1 << 3)) - gd->flags |= GD_FLG_SILENT | GD_FLG_DISABLE_CONSOLE; + if (is_warm_boot()) + fsl_dp_disable_console(); #endif /* compiler optimization barrier needed for GCC >= 3.4 */ __asm__ __volatile__("" : : : "memory"); @@ -126,16 +126,3 @@ void board_init_r(gd_t *gd, ulong dest_addr) nand_boot(); #endif } - -#ifdef CONFIG_DEEP_SLEEP -void board_mem_sleep_setup(void) -{ - void __iomem *cpld_base = (void *)CONFIG_SYS_CPLD_BASE; - - /* does not provide HW signals for power management */ - clrbits_8(cpld_base + 0x17, 0x40); - /* Disable MCKE isolation */ - gpio_set_value(2, 0); - udelay(1); -} -#endif diff --git a/board/freescale/t104xrdb/t104xrdb.c b/board/freescale/t104xrdb/t104xrdb.c index ddb669f..abca297 100644 --- a/board/freescale/t104xrdb/t104xrdb.c +++ b/board/freescale/t104xrdb/t104xrdb.c @@ -17,8 +17,7 @@ #include <asm/fsl_portals.h> #include <asm/fsl_liodn.h> #include <fm_eth.h> -#include <asm/mpc85xx_gpio.h> - +#include "../common/sleep.h" #include "t104xrdb.h" #include "cpld.h"
@@ -44,6 +43,16 @@ int checkboard(void) return 0; }
+int board_early_init_f(void) +{ +#if defined(CONFIG_DEEP_SLEEP) + if (is_warm_boot()) + fsl_dp_disable_console(); +#endif + + return 0; +} + int board_early_init_r(void) { #ifdef CONFIG_SYS_FLASH_BASE @@ -111,14 +120,3 @@ void ft_board_setup(void *blob, bd_t *bd) fdt_fixup_fman_ethernet(blob); #endif } - -#ifdef CONFIG_DEEP_SLEEP -void board_mem_sleep_setup(void) -{ - /* does not provide HW signals for power management */ - CPLD_WRITE(misc_ctl_status, (CPLD_READ(misc_ctl_status) & ~0x40)); - /* Disable MCKE isolation */ - gpio_set_value(2, 0); - udelay(1); -} -#endif diff --git a/include/configs/T104xRDB.h b/include/configs/T104xRDB.h index 2bb86e4..36ac66d 100644 --- a/include/configs/T104xRDB.h +++ b/include/configs/T104xRDB.h @@ -100,7 +100,10 @@
/* support deep sleep */ #define CONFIG_DEEP_SLEEP +#if defined(CONFIG_DEEP_SLEEP) +#define CONFIG_BOARD_EARLY_INIT_F #define CONFIG_SILENT_CONSOLE +#endif
#ifndef CONFIG_SYS_TEXT_BASE #define CONFIG_SYS_TEXT_BASE 0xeff40000
Applied to u-boot-mpc85xx master, awaiting upstream.
York
- Converts all the Freescale's DDR driver to support deep sleep.
- Added basic framework support for ARM-based and PPC-based
cores separately.
Applied to u-boot-fsl-qoriq master, awaiting upstream.
York
York Sun
