[PATCH v3] arm: dts: am335x-evm-u-boot: Remove usb0 mode configuration
This USB port configuration is moved to 'am335x-evm.dts'.
Signed-off-by: Julien Panis jpanis@baylibre.com --- Initially, this series was submitted to fix usb0 dr_mode for am335x-icev2 and am335x-evmsk. It must be set to 'peripheral' in order to avoid 'no USB device found' error, in usb_ether_init() function.
It was finally decided to move usb0 mode configuration in kernel device trees. That's why a series was submitted for linux: https://lore.kernel.org/all/20230629-usb0-as-peripheral-v1-0-167f78a11746@ba...
As a consequence, usb0 dr_mode configuration must now be removed from 'am335x-evm-u-boot.dtsi', since this fragment needs to go in linux too. --- Changes in v3: - Remove usb0 dr_mode configuration from 'am335x-evm-u-boot.dtsi'. - Link to v2: https://lore.kernel.org/r/20230621-fix_usb_ether_init-v2-0-ff121f0e8d7a@bayl...
Changes in v2: - Drop the modification made in arch/arm/mach-omap2/am33xx/board.c - Configure usb0 dr_mode as peripheral in 'am335x-icev2-u-boot.dtsi' and 'am335x-evmsk-u-boot.dtsi' device trees. - Link to v1: https://lore.kernel.org/r/20230621-fix_usb_ether_init-v1-1-2156923994a9@bayl... --- arch/arm/dts/am335x-evm-u-boot.dtsi | 4 ---- 1 file changed, 4 deletions(-)
diff --git a/arch/arm/dts/am335x-evm-u-boot.dtsi b/arch/arm/dts/am335x-evm-u-boot.dtsi index 82a483ae3e28..42eeca8c0499 100644 --- a/arch/arm/dts/am335x-evm-u-boot.dtsi +++ b/arch/arm/dts/am335x-evm-u-boot.dtsi @@ -23,10 +23,6 @@ status = "disabled"; };
-&usb0 { - dr_mode = "peripheral"; -}; - &i2c0 { bootph-all; };
--- base-commit: 19b77d3d23966a0d6dbb3c86187765f11100fb6f change-id: 20230621-fix_usb_ether_init-4bf4f1135113
Julien Panis
