[U-Boot] rtc: s35392a: encode command correctly
The 3-bit "command", or register, is encoded within the device address. Configure the device accordingly, and pass command in DM I2C read/write calls correctly.
Signed-off-by: Ian Ray ian.ray@ge.com Signed-off-by: Robert Beckett bob.beckett@collabora.com --- Note: Split out of https://patchwork.ozlabs.org/cover/1182351/. --- drivers/rtc/s35392a.c | 29 ++++++++++++++++++----------- 1 file changed, 18 insertions(+), 11 deletions(-)
diff --git a/drivers/rtc/s35392a.c b/drivers/rtc/s35392a.c index 4f478cc..3bfe481 100644 --- a/drivers/rtc/s35392a.c +++ b/drivers/rtc/s35392a.c @@ -24,11 +24,13 @@ #include <linux/bitrev.h> #include <rtc.h>
-#define S35390A_CMD_STATUS1 0x30 -#define S35390A_CMD_STATUS2 0x31 -#define S35390A_CMD_TIME1 0x32 -#define S35390A_CMD_TIME2 0x33 -#define S35390A_CMD_INT2_REG1 0x35 +#define S35390A_CHIP_ADDR 0x30 + +#define S35390A_CMD_STATUS1 0x0 +#define S35390A_CMD_STATUS2 0x1 +#define S35390A_CMD_TIME1 0x2 +#define S35390A_CMD_TIME2 0x3 +#define S35390A_CMD_INT2_REG1 0x5
#define S35390A_BYTE_YEAR 0 #define S35390A_BYTE_MONTH 1 @@ -85,11 +87,10 @@ static int s35392a_rtc_read(DEV_TYPE *dev, u8 reg, u8 *buf, int len) int ret;
#ifdef CONFIG_DM_RTC - /* TODO: we need to tweak the chip address to reg */ - ret = dm_i2c_read(dev, 0, buf, len); + ret = dm_i2c_read(dev, reg, buf, len); #else (void)dev; - ret = i2c_read(reg, 0, -1, buf, len); + ret = i2c_read(S35390A_CHIP_ADDR | reg, 0, -1, buf, len); #endif
return ret; @@ -100,11 +101,10 @@ static int s35392a_rtc_write(DEV_TYPE *dev, u8 reg, u8 *buf, int len) int ret;
#ifdef CONFIG_DM_RTC - /* TODO: we need to tweak the chip address to reg */ - ret = dm_i2c_write(dev, 0, buf, 1); + ret = dm_i2c_write(dev, reg, buf, len); #else (void)dev; - ret = i2c_write(reg, 0, 0, buf, len); + ret = i2c_write(S35390A_CHIP_ADDR | reg, 0, 0, buf, len); #endif
return ret; @@ -336,6 +336,13 @@ void rtc_init(void)
static int s35392a_probe(struct udevice *dev) { +#if defined(CONFIG_DM_RTC) + /* 3-bit "command", or register, is encoded within the device address. + */ + i2c_set_chip_offset_len(dev, 0); + i2c_set_chip_addr_offset_mask(dev, 0x7); +#endif + s35392a_rtc_init(dev); return 0; }
Ian Ray
