DE1-SOC LKM MAKEFILE ON U-Boot SPL 2013.01.01
HII , I AM USING A DE1-SOC BOARD THAT IS BASED ON U-Boot SPL 2013.01.01
THE BOARD IS :Altera SOCFPGA Cyclone V Board
i downloaded the console version of linux os from terasic and its working fine on the board
I am trying to load a simple lkm that prints "hello world" on the kernel , and in the makefile we need to specify the source directory location. I tried all the options and examples of makefiles that I could lay my hands on , and nothing seems to work .
in some cases it worked but when i try to load the module on the board using insmod command i get "invalid file format "
i tried to get some help in roketboard forum and in intel community forums without any success , so i thought maybe i can get help from you cause from what i understand the console ver is based on U-Boot SPL 2013.01.01
i need to know the path where are the source files located in U-Boot SPL 2013.01.01
and if you have a make file that is tested on the de1-soc maybe for compiling linux kernel modules (device drivers) i be glad for any help ,thanks in advance
The module needs to be built for exactly the same kernel version. Any difference at all in the version number will cause it to fail.
Perhaps this:
https://github.com/u-boot/u-boot/tree/u-boot-2013.01.y
That version of U-Boot probably belongs in a museum at this point! I won't ask what version Linux it is :-)
Regards, SImon
aied bebar
