[PATCH 1/1] doc: fix doc/develop/logging.rst
Sphinx 3 builds fail due to doc/develop/logging.rst producing duplicate labels.
Include logging.h only once in the API section and use cross-references for the enums log_level_t and log_category_t.
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- doc/api/index.rst | 1 + doc/api/logging.rst | 6 ++++++ doc/develop/logging.rst | 13 +++---------- 3 files changed, 10 insertions(+), 10 deletions(-) create mode 100644 doc/api/logging.rst
diff --git a/doc/api/index.rst b/doc/api/index.rst index cbecd10755..ea02aa5715 100644 --- a/doc/api/index.rst +++ b/doc/api/index.rst @@ -10,6 +10,7 @@ U-Boot API documentation efi getopt linker_lists + logging pinctrl rng sandbox diff --git a/doc/api/logging.rst b/doc/api/logging.rst new file mode 100644 index 0000000000..1e6cbc4931 --- /dev/null +++ b/doc/api/logging.rst @@ -0,0 +1,6 @@ +.. SPDX-License-Identifier: GPL-2.0+ + +Logging API +=========== + +.. kernel-doc:: include/log.h diff --git a/doc/develop/logging.rst b/doc/develop/logging.rst index 7fdd1132ef..60c18c5b3a 100644 --- a/doc/develop/logging.rst +++ b/doc/develop/logging.rst @@ -26,8 +26,7 @@ Logging levels
There are a number logging levels available.
-.. kernel-doc:: include/log.h - :identifiers: log_level_t +See enum :c:type:`log_level_t`
Logging category ---------------- @@ -36,8 +35,7 @@ Logging can come from a wide variety of places within U-Boot. Each log message has a category which is intended to allow messages to be filtered according to their source.
-.. kernel-doc:: include/log.h - :identifiers: log_category_t +See enum :c:type:`log_category_t`
Enabling logging ---------------- @@ -67,7 +65,7 @@ to enable building in of all logging statements in a single file. Put it at the top of the file, before any #includes.
To actually get U-Boot to output this you need to also set the default logging -level - e.g. set CONFIG_LOG_DEFAULT_LEVEL to 7 (:c:type:`LOGL_DEBUG`) or more. +level - e.g. set CONFIG_LOG_DEFAULT_LEVEL to 7 (:c:data:`LOGL_DEBUG`) or more. Otherwise debug output is suppressed and will not be generated.
Using DEBUG @@ -290,8 +288,3 @@ number dropped due to them being generated before the log system was ready. Add a printf() format string pragma so that log statements are checked properly
Add a command to delete existing log records. - -Logging API ------------ -.. kernel-doc:: include/log.h - :internal: -- 2.29.2
