[U-Boot] [PATCH] mx28evk: Fix PSWITCH key position
Fix the position for PSWITCH key.
The good benefit of doing this is that boot time is greatly reduced: from 5 seconds to less then 1 second.
Signed-off-by: Fabio Estevam fabio.estevam@freescale.com --- doc/README.mx28evk | 2 +- 1 files changed, 1 insertions(+), 1 deletions(-)
diff --git a/doc/README.mx28evk b/doc/README.mx28evk index c6c3d37..571dfda 100644 --- a/doc/README.mx28evk +++ b/doc/README.mx28evk @@ -17,7 +17,7 @@ Jumper configuration To boot MX28EVK from an SD card, set the boot mode DIP switches as:
* Boot Mode Select: 1 0 0 1 (Boot from SD card Slot 0 - U42) - * JTAG PSWITCH RESET: To the left (reset enabled) + * JTAG PSWITCH RESET: To the right (reset disabled) * Battery Source: Down * Wall 5V: Up * VDD 5V: To the left (off)
Dear Fabio Estevam,
- JTAG PSWITCH RESET: To the left (reset enabled)
- JTAG PSWITCH RESET: To the right (reset disabled)
- Battery Source: Down
- Wall 5V: Up
- VDD 5V: To the left (off)
Thanks
Acked-by: Marek Vasut marex@denx.de
Best regards, Marek Vasut
Fabio Estevam
