Re: [U-Boot] [PATCH v2 00/11] SPL support for RISC-V
Hi Lukas
From: Lukas Auer [mailto:lukas.auer@aisec.fraunhofer.de] Sent: Sunday, July 28, 2019 11:57 PM To: u-boot@lists.denx.de Cc: Atish Patra; Rick Jian-Zhi Chen(陳建志); Bin Meng; Sagar Kadam; Alistair Francis; Anup Patel; Troy Benjegerdes; Lukas Auer; Abel Vesa; Alex Kiernan; Alex Marginean; Alexander Graf; Andreas Dannenberg; Andrew F. Davis; Anup Patel; Anup Patel; Atish Patra; Chris Packham; Eugeniu Rosca; Heiko Schocher; Heinrich Schuchardt; Jagan Teki; Jean-Jacques Hiblot; Jens Wiklander; Joe Hershberger; Kever Yang; Lokesh Vutla; Lukasz Majewski; Marek Vasut; Marek Vasut; Marek Vasut; Markus Klotzbuecher; Michal Simek; Paul Burton; Peng Fan; Philipp Tomsich; Philippe Reynes; Ryder Lee; Shawn Guo; Simon Glass; Simon Goldschmidt; Stefan Roese; Stefano Babic; Tien Fong Chee; Vignesh R; Weijie Gao; Ye Li Subject: [PATCH v2 00/11] SPL support for RISC-V
This series adds support for SPL to RISC-V U-Boot. Images can be booted via OpenSBI (FW_DYNAMIC firmware) or by directly jumping to them. In the former case, OpenSBI and U-Boot proper are bundled as a FIT image and made available to U-Boot SPL. Currently, only the QEMU board enables U-Boot SPL with a dedicated configuration. It uses RAM as SPL boot device.
On many RISC-V CPUs, the device tree is provided to U-Boot by the first stage bootloader. This requires changes to U-Boot SPL (patches 1, 2 and 3), which modify the behavior on other boards as well.
To test this series, OpenSBI has to be compiled first. The fw_dynamic.bin binary must be copied into the U-Boot root directory. Alternatively, the location of the binary can be specified with the OPENSBI environment variable. U-Boot can then be build as normal using the configuration qemu-riscv64_spl_defconfig for 64-bit builds or qemu-riscv32_spl_defconfig for 32-bit builds. The outputs from the build process are the U-Boot SPL binary (spl/u-boot-spl.bin) and the U-Boot FIT image (u-boot.itb) containing U-Boot proper and OpenSBI.
U-Boot can be run in QEMU with the following command.
qemu-system-riscv64 -nographic -machine virt -kernel spl/u-boot-spl \ -device loader,file=u-boot.itb,addr=0x80200000
Great job !
I also try to run the spl flow on ax25-ae350 platform. But encounter some problems. I am still debugging.
Following is the error message: : U-Boot SPL 2019.07-10574-ge6ef7ec-dirty (Aug 01 2019 - 10:09:45 +0800) Trying to boot from RAM
U-Boot 2019.07-10574-ge6ef7ec-dirty (Aug 01 2019 - 10:09:45 +0800)
DRAM: exception code: 5 , Load access fault , epc 1212654 , ra 1200ffe ### ERROR ### Please RESET the board ###
Do you have some comments ?
By the way, please rebase u-boot-riscv/master to avoid some conflictions from Bin's patchs.
Thanks Rick
Changes in v2:
- Rebase on master and format documentation as reStructuredText
Lukas Auer (11): fdtdec: make CONFIG_OF_PRIOR_STAGE available in SPL Makefile: support building SPL FIT images without device trees spl: fit: use U-Boot device tree when FIT image has no device tree riscv: add run mode configuration for SPL spl: support booting via RISC-V OpenSBI riscv: add SPL support riscv: support SPL stack and global data relocation riscv: add a generic FIT generator script riscv: set default FIT generator script and build target for SPL builds riscv: qemu: add SPL configuration doc: update QEMU RISC-V documentation
Kconfig | 4 +- Makefile | 8 +- arch/Kconfig | 6 ++ arch/riscv/Kconfig | 36 +++++++-- arch/riscv/cpu/ax25/Kconfig | 6 +- arch/riscv/cpu/cpu.c | 6 +- arch/riscv/cpu/generic/Kconfig | 5 +- arch/riscv/cpu/start.S | 62 ++++++++++++++- arch/riscv/cpu/u-boot-spl.lds | 82 +++++++++++++++++++ arch/riscv/include/asm/encoding.h | 2 +- arch/riscv/include/asm/spl.h | 31 ++++++++ arch/riscv/lib/Makefile | 8 +- arch/riscv/lib/mkimage_fit_opensbi.sh | 100 ++++++++++++++++++++++++ arch/riscv/lib/spl.c | 48 ++++++++++++ board/emulation/qemu-riscv/Kconfig | 10 +++ board/emulation/qemu-riscv/MAINTAINERS | 2 + board/emulation/qemu-riscv/qemu-riscv.c | 17 ++++ common/image.c | 1 + common/spl/Kconfig | 17 ++++ common/spl/Makefile | 1 + common/spl/spl.c | 8 +- common/spl/spl_fit.c | 37 ++++++--- common/spl/spl_opensbi.c | 85 ++++++++++++++++++++ configs/qemu-riscv32_spl_defconfig | 11 +++ configs/qemu-riscv64_spl_defconfig | 12 +++ doc/board/emulation/qemu-riscv.rst | 60 +++++++++++++- include/configs/qemu-riscv.h | 14 ++++ include/fdtdec.h | 2 +- include/image.h | 1 + include/opensbi.h | 40 ++++++++++ include/spl.h | 5 ++ lib/fdtdec.c | 6 +- 32 files changed, 691 insertions(+), 42 deletions(-) create mode 100644 arch/riscv/cpu/u-boot-spl.lds create mode 100644 arch/riscv/include/asm/spl.h create mode 100755 arch/riscv/lib/mkimage_fit_opensbi.sh create mode 100644 arch/riscv/lib/spl.c create mode 100644 common/spl/spl_opensbi.c create mode 100644 configs/qemu-riscv32_spl_defconfig create mode 100644 configs/qemu-riscv64_spl_defconfig create mode 100644 include/opensbi.h
-- 2.21.0
Hi Rick,
On Thu, 2019-08-01 at 11:32 +0800, Rick Chen wrote:
Hi Lukas
Great job !
Thank you!
It is difficult to judge without the exact configuration. Is your current git tree available somewhere?
The error is quite strange, because it already booted U-Boot proper. So the error does not happen in code, which has been directly modified by this series. Perhaps it is trying to initialize something twice (once in SPL and again in U-Boot proper)? Can you check at what location the error occurs?
Yes, I will do that.
Thanks, Lukas
Thanks Rick
Changes in v2:
-- 2.21.0
Hi Lukas
Hi Rick,
Hi Lukas
Great job !
Thank you!
No, it is not available yet. And you don't have the ax25-ae350 board, it is still in vain if the git tree is available.
I found that the exception occurred in get_ram_size() of ax25-ae350.c when it try to load the memory address 0x10000. But the access of 0x20000 is ok.
I try to mark the get_ram_size() and do not execute it, U-Boot proper can boot successfully as below:
U-Boot SPL 2019.07-10574-ge6ef7ec-dirty (Aug 02 2019 - 16:07:54 +0800) Trying to boot from RAM
U-Boot 2019.07-10574-ge6ef7ec-dirty (Aug 02 2019 - 16:07:54 +0800) DRAM: 1 GiB Flash: 64 MiB MMC: mmc@f0e00000: 0 Loading Environment from SPI Flash... SF: Detected mx25u1635e with page size 256 Bytes, erase size 4 KiB, total 2 MiB *** Warning - bad CRC, using default environment In: serial@f0300000 Out: serial@f0300000 Err: serial@f0300000 Net: no alias for ethernet0 Warning: mac@e0100000 (eth0) using random MAC address - 36:13:4d:06:b8:fd eth0: mac@e0100000 Hit any key to stop autoboot: 0 RISC-V #
So I tried to trace openSBI and found the BANNER of openSBI was not printed. Is it correct ?
Any idea about why the access of memory address(0x10000) will fail ? I guess it seem relative to pmp configuration. I am still tracing it ...
Thanks Rick
On Fri, Aug 2, 2019 at 2:11 PM Rick Chen rickchen36@gmail.com wrote:
Hi Lukas
Hi Rick,
Hi Lukas
Great job !
Thank you!
Yes, U-Boot SPL is passing SBI_SCRATCH_NO_BOOT_PRINTS option to OpenSBI due to which you don't see any prints. Although, error prints from OpenSBI will be still available.
If it is PMP access checks then you should get ACCESS faults error prints from OpenSBI.
Regards, Anup
Hi Rick,
Hi Lukas
Hi Rick,
Hi Lukas
Great job !
Thank you!
If you want to enable the OpenSBI banner, you can remove the option in common/spl/spl_opensbi.c.
The access violation you are seeing is strange and I am not sure why OpenSBI does not print any errors. It does seem like a problem with the PMP configuration though.
Thanks, Lukas
Hi Lukas and Anup
Hi Rick,
Hi Lukas
Hi Rick,
Hi Lukas
> From: Lukas Auer [mailto:lukas.auer@aisec.fraunhofer.de] > Sent: Sunday, July 28, 2019 11:57 PM > To: u-boot@lists.denx.de > Cc: Atish Patra; Rick Jian-Zhi Chen(陳建志); Bin Meng; Sagar Kadam; Alistair > Francis; Anup Patel; Troy Benjegerdes; Lukas Auer; Abel Vesa; Alex Kiernan; > Alex Marginean; Alexander Graf; Andreas Dannenberg; Andrew F. Davis; Anup > Patel; Anup Patel; Atish Patra; Chris Packham; Eugeniu Rosca; Heiko Schocher; > Heinrich Schuchardt; Jagan Teki; Jean-Jacques Hiblot; Jens Wiklander; Joe > Hershberger; Kever Yang; Lokesh Vutla; Lukasz Majewski; Marek Vasut; Marek > Vasut; Marek Vasut; Markus Klotzbuecher; Michal Simek; Paul Burton; Peng > Fan; Philipp Tomsich; Philippe Reynes; Ryder Lee; Shawn Guo; Simon Glass; > Simon Goldschmidt; Stefan Roese; Stefano Babic; Tien Fong Chee; Vignesh R; > Weijie Gao; Ye Li > Subject: [PATCH v2 00/11] SPL support for RISC-V > > This series adds support for SPL to RISC-V U-Boot. Images can be booted via > OpenSBI (FW_DYNAMIC firmware) or by directly jumping to them. In the > former case, OpenSBI and U-Boot proper are bundled as a FIT image and made > available to U-Boot SPL. Currently, only the QEMU board enables U-Boot SPL > with a dedicated configuration. It uses RAM as SPL boot device. > > On many RISC-V CPUs, the device tree is provided to U-Boot by the first stage > bootloader. This requires changes to U-Boot SPL (patches 1, > 2 and 3), which modify the behavior on other boards as well. > > To test this series, OpenSBI has to be compiled first. The fw_dynamic.bin > binary must be copied into the U-Boot root directory. > Alternatively, the location of the binary can be specified with the OPENSBI > environment variable. U-Boot can then be build as normal using the > configuration qemu-riscv64_spl_defconfig for 64-bit builds or > qemu-riscv32_spl_defconfig for 32-bit builds. The outputs from the build > process are the U-Boot SPL binary (spl/u-boot-spl.bin) and the U-Boot FIT > image (u-boot.itb) containing U-Boot proper and OpenSBI. > > U-Boot can be run in QEMU with the following command. > > qemu-system-riscv64 -nographic -machine virt -kernel spl/u-boot-spl \ > -device loader,file=u-boot.itb,addr=0x80200000 >
Great job !
Thank you!
I change pmpcfg0 from 0x1f18 to 0x1f1f and 0x10000 can be accessed.
========== gdb message ========== (gdb) p/x $pmpcfg0 $12 = {0x1f1f, pmp0cfg = {0x1f, a = 0x3}, pmp1cfg = {0x1f, a = 0x3}, pmp2cfg = {0x0, a = 0x0}, pmp3cfg = {0x0, a = 0x0}, pmp4cfg = {0x0, a = 0x0}, pmp5cfg = {0x0, a = 0x0}, pmp6cfg = {0x0, a = 0x0}, pmp7cfg = { 0x0, a = 0x0}}
============ u-boot message ============
Warning: mac@e0100000 (eth0) using random MAC address - ea:d7:a7:97:06:2c eth0: mac@e0100000 Hit any key to stop autoboot: 0 RISC-V # RISC-V # md.b 0x10000 00010000: ef 80 c2 00 aa 87 3e 85 6f c0 22 26 ef c2 02 22 ......>.o."&..." 00010010: 17 25 03 00 13 05 05 03 ef a0 2f 92 19 c5 41 46 .%......../...AF 00010020: 81 45 ef 80 e2 13 6f c0 e2 23 83 b7 01 00 17 25 .E....o..#.....% 00010030: 03 00 13 05 25 ff 80 67 84 6b ef a0 0f 90 a2 87 ....%..g.k...... RISC-V #
Thanks Rick
Thanks, Lukas
Anup Patel
Auer, Lukas
Rick Chen
