[U-Boot] [PATCH v7 7/7] mips: ath79: add AP143 reference board
Signed-off-by: Wills Wang wills.wang@live.com ---
Changes in v7: - Use KSEG1 address for debug port in ap143
Changes in v6: None Changes in v5: None Changes in v4: None Changes in v3: None Changes in v2: None
arch/mips/dts/Makefile | 1 + arch/mips/dts/ap143.dts | 43 ++++++++++++++++++++ arch/mips/dts/qca953x.dtsi | 72 ++++++++++++++++++++++++++++++++++ arch/mips/mach-ath79/Kconfig | 5 +++ board/ath79/ap143/Kconfig | 9 +++++ board/ath79/ap143/MAINTAINERS | 6 +++ board/ath79/ap143/Makefile | 5 +++ board/ath79/ap143/ap143.c | 63 ++++++++++++++++++++++++++++++ configs/ap143_defconfig | 43 ++++++++++++++++++++ include/configs/ap143.h | 91 +++++++++++++++++++++++++++++++++++++++++++ 10 files changed, 338 insertions(+) create mode 100644 arch/mips/dts/ap143.dts create mode 100644 arch/mips/dts/qca953x.dtsi create mode 100644 board/ath79/ap143/Kconfig create mode 100644 board/ath79/ap143/MAINTAINERS create mode 100644 board/ath79/ap143/Makefile create mode 100644 board/ath79/ap143/ap143.c create mode 100644 configs/ap143_defconfig create mode 100644 include/configs/ap143.h
diff --git a/arch/mips/dts/Makefile b/arch/mips/dts/Makefile index 3fd49eb..7da06c5 100644 --- a/arch/mips/dts/Makefile +++ b/arch/mips/dts/Makefile @@ -3,6 +3,7 @@ #
dtb-$(CONFIG_BOARD_AP121) += ap121.dtb +dtb-$(CONFIG_BOARD_AP143) += ap143.dtb
targets += $(dtb-y)
diff --git a/arch/mips/dts/ap143.dts b/arch/mips/dts/ap143.dts new file mode 100644 index 0000000..f53207e --- /dev/null +++ b/arch/mips/dts/ap143.dts @@ -0,0 +1,43 @@ +/* + * Copyright (C) 2015-2016 Wills Wang wills.wang@live.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +/dts-v1/; +#include "qca953x.dtsi" + +/ { + model = "AP143 Reference Board"; + compatible = "qca,ap143", "qca,qca953x"; + + aliases { + spi0 = &spi0; + serial0 = &uart0; + }; + + chosen { + stdout-path = "serial0:115200n8"; + }; +}; + +&xtal { + clock-frequency = <25000000>; +}; + +&uart0 { + status = "okay"; +}; + +&spi0 { + spi-max-frequency = <25000000>; + status = "okay"; + spi-flash@0 { + #address-cells = <1>; + #size-cells = <1>; + compatible = "spi-flash"; + memory-map = <0x9f000000 0x00800000>; + spi-max-frequency = <25000000>; + reg = <0>; + }; +}; diff --git a/arch/mips/dts/qca953x.dtsi b/arch/mips/dts/qca953x.dtsi new file mode 100644 index 0000000..8487fc9 --- /dev/null +++ b/arch/mips/dts/qca953x.dtsi @@ -0,0 +1,72 @@ +/* + * Copyright (C) 2015-2016 Wills Wang wills.wang@live.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include "skeleton.dtsi" + +/ { + compatible = "qca,qca953x"; + + #address-cells = <1>; + #size-cells = <1>; + + cpus { + #address-cells = <1>; + #size-cells = <0>; + + cpu@0 { + device_type = "cpu"; + compatible = "mips,mips24Kc"; + reg = <0>; + }; + }; + + clocks { + #address-cells = <1>; + #size-cells = <1>; + ranges; + + xtal: xtal { + #clock-cells = <0>; + compatible = "fixed-clock"; + clock-output-names = "xtal"; + }; + }; + + ahb { + compatible = "simple-bus"; + ranges; + + #address-cells = <1>; + #size-cells = <1>; + + apb { + compatible = "simple-bus"; + ranges; + + #address-cells = <1>; + #size-cells = <1>; + + uart0: uart@18020000 { + compatible = "ns16550"; + reg = <0x18020000 0x20>; + reg-shift = <2>; + clock-frequency = <25000000>; + + status = "disabled"; + }; + }; + + spi0: spi@1f000000 { + compatible = "qca,ar7100-spi"; + reg = <0x1f000000 0x10>; + + status = "disabled"; + + #address-cells = <1>; + #size-cells = <0>; + }; + }; +}; diff --git a/arch/mips/mach-ath79/Kconfig b/arch/mips/mach-ath79/Kconfig index 0fcd96a..f61efd2 100644 --- a/arch/mips/mach-ath79/Kconfig +++ b/arch/mips/mach-ath79/Kconfig @@ -34,8 +34,13 @@ config BOARD_AP121 bool "AP121 Reference Board" select SOC_AR933X
+config BOARD_AP143 + bool "AP143 Reference Board" + select SOC_QCA953X + endchoice
source "board/ath79/ap121/Kconfig" +source "board/ath79/ap143/Kconfig"
endmenu diff --git a/board/ath79/ap143/Kconfig b/board/ath79/ap143/Kconfig new file mode 100644 index 0000000..118b9b5 --- /dev/null +++ b/board/ath79/ap143/Kconfig @@ -0,0 +1,9 @@ +if BOARD_AP143 + +config SYS_BOARD + default "ap143" + +config SYS_CONFIG_NAME + default "ap143" + +endif diff --git a/board/ath79/ap143/MAINTAINERS b/board/ath79/ap143/MAINTAINERS new file mode 100644 index 0000000..d373cf8 --- /dev/null +++ b/board/ath79/ap143/MAINTAINERS @@ -0,0 +1,6 @@ +AP143 BOARD +M: Wills Wang wills.wang@live.com +S: Maintained +F: board/ath79/ap143/ +F: include/configs/ap143.h +F: configs/ap143_defconfig diff --git a/board/ath79/ap143/Makefile b/board/ath79/ap143/Makefile new file mode 100644 index 0000000..00f7837 --- /dev/null +++ b/board/ath79/ap143/Makefile @@ -0,0 +1,5 @@ +# +# SPDX-License-Identifier: GPL-2.0+ +# + +obj-y = ap143.o diff --git a/board/ath79/ap143/ap143.c b/board/ath79/ap143/ap143.c new file mode 100644 index 0000000..3be86e6 --- /dev/null +++ b/board/ath79/ap143/ap143.c @@ -0,0 +1,63 @@ +/* + * Copyright (C) 2015-2016 Wills Wang wills.wang@live.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/addrspace.h> +#include <asm/types.h> +#include <mach/ar71xx_regs.h> +#include <mach/ddr.h> +#include <debug_uart.h> + +DECLARE_GLOBAL_DATA_PTR; + +#ifdef CONFIG_BOARD_EARLY_INIT_F +int board_early_init_f(void) +{ + void __iomem *regs; + u32 val; + + regs = map_physmem(AR71XX_GPIO_BASE, AR71XX_GPIO_SIZE, + MAP_NOCACHE); + + /* + * GPIO9 as input, GPIO10 as output + */ + val = readl(regs + AR71XX_GPIO_REG_OE); + val |= QCA953X_GPIO(9); + val &= ~QCA953X_GPIO(10); + writel(val, regs + AR71XX_GPIO_REG_OE); + + /* + * Enable GPIO10 as UART0_SOUT + */ + val = readl(regs + QCA953X_GPIO_REG_OUT_FUNC2); + val &= ~QCA953X_GPIO_OUT_MUX_MASK(16); + val |= QCA953X_GPIO_OUT_MUX_UART0_SOUT << 16; + writel(val, regs + QCA953X_GPIO_REG_OUT_FUNC2); + + /* + * Enable GPIO9 as UART0_SIN + */ + val = readl(regs + QCA953X_GPIO_REG_IN_ENABLE0); + val &= ~QCA953X_GPIO_OUT_MUX_MASK(8); + val |= QCA953X_GPIO_IN_MUX_UART0_SIN << 8; + writel(val, regs + QCA953X_GPIO_REG_IN_ENABLE0); + + /* + * Enable GPIO10 output + */ + val = readl(regs + AR71XX_GPIO_REG_OUT); + val |= QCA953X_GPIO(10); + writel(val, regs + AR71XX_GPIO_REG_OUT); + +#ifdef CONFIG_DEBUG_UART + debug_uart_init(); +#endif + ddr_init(); + return 0; +} +#endif diff --git a/configs/ap143_defconfig b/configs/ap143_defconfig new file mode 100644 index 0000000..ed7e09d --- /dev/null +++ b/configs/ap143_defconfig @@ -0,0 +1,43 @@ +CONFIG_MIPS=y +CONFIG_ARCH_ATH79=y +CONFIG_BOARD_AP143=y +CONFIG_SYS_MALLOC_F_LEN=0x800 +CONFIG_SYS_NS16550=y +CONFIG_DM_SERIAL=y +CONFIG_ATH79_SPI=y +CONFIG_DM_SPI=y +CONFIG_DM_SPI_FLASH=y +CONFIG_DEFAULT_DEVICE_TREE="ap143" +CONFIG_SYS_PROMPT="ap143 # " +# CONFIG_CMD_BDI is not set +# CONFIG_CMD_CONSOLE is not set +# CONFIG_CMD_ELF is not set +# CONFIG_CMD_IMLS is not set +# CONFIG_CMD_XIMG is not set +# CONFIG_CMD_EXPORTENV is not set +# CONFIG_CMD_IMPORTENV is not set +# CONFIG_CMD_EDITENV is not set +# CONFIG_CMD_CRC32 is not set +# CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y +# CONFIG_CMD_FPGA is not set +# CONFIG_CMD_NET is not set +# CONFIG_CMD_NFS is not set +CONFIG_SPI_FLASH=y +CONFIG_SPI_FLASH_BAR=y +CONFIG_SPI_FLASH_ATMEL=y +CONFIG_SPI_FLASH_EON=y +CONFIG_SPI_FLASH_GIGADEVICE=y +CONFIG_SPI_FLASH_MACRONIX=y +CONFIG_SPI_FLASH_SPANSION=y +CONFIG_SPI_FLASH_STMICRO=y +CONFIG_SPI_FLASH_SST=y +CONFIG_SPI_FLASH_WINBOND=y +CONFIG_SPI_FLASH_DATAFLASH=y +CONFIG_SPI_FLASH_MTD=y +CONFIG_DEBUG_UART=y +CONFIG_DEBUG_UART_NS16550=y +CONFIG_DEBUG_UART_BASE=0xb8020000 +CONFIG_DEBUG_UART_CLOCK=25000000 +CONFIG_DEBUG_UART_SHIFT=2 diff --git a/include/configs/ap143.h b/include/configs/ap143.h new file mode 100644 index 0000000..6940551 --- /dev/null +++ b/include/configs/ap143.h @@ -0,0 +1,91 @@ +/* + * Copyright (C) 2015-2016 Wills Wang wills.wang@live.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +#define CONFIG_SYS_TEXT_BASE 0x9f000000 + +#define CONFIG_DISPLAY_CPUINFO +#define CONFIG_DISPLAY_BOARDINFO +#define CONFIG_BOARD_EARLY_INIT_F + +#define CONFIG_SYS_HZ 1000 +#define CONFIG_SYS_MHZ 325 +#define CONFIG_SYS_MIPS_TIMER_FREQ (CONFIG_SYS_MHZ * 1000000) + +/* Cache Configuration */ +#define CONFIG_SYS_DCACHE_SIZE 0x8000 +#define CONFIG_SYS_ICACHE_SIZE 0x10000 +#define CONFIG_SYS_CACHELINE_SIZE 32 + +#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE + +#define CONFIG_SYS_MALLOC_LEN 0x40000 +#define CONFIG_SYS_BOOTPARAMS_LEN 0x20000 + +#define CONFIG_SYS_SDRAM_BASE 0x80000000 +#define CONFIG_SYS_LOAD_ADDR 0x81000000 + +#define CONFIG_SYS_NO_FLASH + +#define CONFIG_SYS_INIT_RAM_ADDR 0xbd000000 +#define CONFIG_SYS_INIT_RAM_SIZE 0x2000 +#define CONFIG_SYS_INIT_SP_ADDR \ + (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_INIT_RAM_SIZE - 1) + +/* + * Serial Port + */ +#define CONFIG_SYS_NS16550_CLK 25000000 +#define CONFIG_BAUDRATE 115200 +#define CONFIG_SYS_BAUDRATE_TABLE \ + {9600, 19200, 38400, 57600, 115200} + +#define CONFIG_BOOTDELAY 3 +#define CONFIG_BOOTARGS "console=ttyS0,115200 " \ + "root=/dev/mtdblock2 " \ + "rootfstype=squashfs" +#define CONFIG_BOOTCOMMAND "sf probe;" \ + "mtdparts default;" \ + "bootm 0x9f300000" +#define CONFIG_LZMA +#define CONFIG_OF_LIBFDT + +#define MTDIDS_DEFAULT "nor0=spi-flash.0" +#define MTDPARTS_DEFAULT "mtdparts=spi-flash.0:" \ + "256k(u-boot),64k(u-boot-env)," \ + "2752k(rootfs),896k(uImage)," \ + "64k(NVRAM),64k(ART)" + +#define CONFIG_ENV_SPI_MAX_HZ 25000000 +#define CONFIG_ENV_IS_IN_SPI_FLASH +#define CONFIG_ENV_OFFSET 0x40000 +#define CONFIG_ENV_SECT_SIZE 0x10000 +#define CONFIG_ENV_SIZE 0x10000 + +/* + * Command + */ +#define CONFIG_CMD_MTDPARTS + +/* Miscellaneous configurable options */ +#define CONFIG_SYS_CBSIZE 256 +#define CONFIG_SYS_MAXARGS 16 +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + \ + sizeof(CONFIG_SYS_PROMPT) + 16) +#define CONFIG_SYS_LONGHELP +#define CONFIG_CMDLINE_EDITING +#define CONFIG_AUTO_COMPLETE + +/* + * Diagnostics + */ +#define CONFIG_SYS_MEMTEST_START 0x80100000 +#define CONFIG_SYS_MEMTEST_END 0x83f00000 +#define CONFIG_CMD_MEMTEST + +#endif /* __CONFIG_H */
Am Sonntag, den 17.01.2016, 02:13 +0800 schrieb Wills Wang:
my comments in patch 6/7 apply to this patch too
Changes in v7:
targets += $(dtb-y)
- Copyright (C) 2015-2016 Wills Wang wills.wang@live.com
- model = "AP143 Reference Board";
- compatible = "qca,ap143", "qca,qca953x";
- aliases {
spi0 = &spi0;
serial0 = &uart0;
- chosen {
+&xtal {
- clock-frequency = <25000000>;
+&uart0 {
- status = "okay";
+&spi0 {
- spi-max-frequency = <25000000>;
- status = "okay";
- spi-flash@0 {
#size-cells = <1>;
reg = <0>;
- compatible = "qca,qca953x";
- #address-cells = <1>;
- #size-cells = <1>;
- cpus {
#size-cells = <0>;
cpu@0 {
reg = <0>;
- clocks {
#size-cells = <1>;
ranges;
xtal: xtal {
#clock-cells = <0>;
- ahb {
ranges;
#size-cells = <1>;
apb {
ranges;
#size-cells = <1>;
reg-shift = <2>;
#size-cells = <0>;
+}; diff --git a/arch/mips/mach-ath79/Kconfig b/arch/mips/mach -ath79/Kconfig index 0fcd96a..f61efd2 100644 --- a/arch/mips/mach-ath79/Kconfig +++ b/arch/mips/mach-ath79/Kconfig @@ -34,8 +34,13 @@ config BOARD_AP121 bool "AP121 Reference Board" select SOC_AR933X
+config BOARD_AP143
- bool "AP143 Reference Board"
- select SOC_QCA953X
endchoice
+config SYS_BOARD
- default "ap143"
- default "ap143"
- void __iomem *regs;
- u32 val;
- regs = map_physmem(AR71XX_GPIO_BASE, AR71XX_GPIO_SIZE,
MAP_NOCACHE);
- val = readl(regs + AR71XX_GPIO_REG_OE);
- val |= QCA953X_GPIO(9);
- val &= ~QCA953X_GPIO(10);
- writel(val, regs + AR71XX_GPIO_REG_OE);
- val = readl(regs + QCA953X_GPIO_REG_OUT_FUNC2);
- val &= ~QCA953X_GPIO_OUT_MUX_MASK(16);
- val |= QCA953X_GPIO_OUT_MUX_UART0_SOUT << 16;
- writel(val, regs + QCA953X_GPIO_REG_OUT_FUNC2);
- val = readl(regs + QCA953X_GPIO_REG_IN_ENABLE0);
- val &= ~QCA953X_GPIO_OUT_MUX_MASK(8);
- val |= QCA953X_GPIO_IN_MUX_UART0_SIN << 8;
- writel(val, regs + QCA953X_GPIO_REG_IN_ENABLE0);
- val = readl(regs + AR71XX_GPIO_REG_OUT);
- val |= QCA953X_GPIO(10);
- writel(val, regs + AR71XX_GPIO_REG_OUT);
- debug_uart_init();
- ddr_init();
- (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_INIT_RAM_SIZE - 1)
- Serial Port
- {9600, 19200, 38400, 57600, 115200}
"bootm 0x9f300000"
-env)," \
- Command
- Diagnostics
Daniel Schwierzeck
Wills Wang
