[U-Boot] [PATCH] omap3: emif|sdrc: use a single global data define
DECLARE_GLOBAL_DATA_PTR declarations in functions are inherently troublesome with various compilers (e.g. gcc 4.5)
Signed-off-by: Nishanth Menon nm@ti.com --- Similar to the fix I did in: http://marc.info/?t=128803773500004&r=1&w=2 for OMAP4 arch/arm/cpu/armv7/omap3/emif4.c | 3 +-- arch/arm/cpu/armv7/omap3/sdrc.c | 3 +-- 2 files changed, 2 insertions(+), 4 deletions(-)
diff --git a/arch/arm/cpu/armv7/omap3/emif4.c b/arch/arm/cpu/armv7/omap3/emif4.c index 2227576..3085637 100644 --- a/arch/arm/cpu/armv7/omap3/emif4.c +++ b/arch/arm/cpu/armv7/omap3/emif4.c @@ -29,6 +29,7 @@ #include <asm/arch/sys_proto.h> #include <asm/arch/emif4.h>
+DECLARE_GLOBAL_DATA_PTR; extern omap3_sysinfo sysinfo;
static emif4_t *emif4_base = (emif4_t *)OMAP34XX_SDRC_BASE; @@ -139,7 +140,6 @@ void do_emif4_init(void) */ int dram_init(void) { - DECLARE_GLOBAL_DATA_PTR; unsigned int size0 = 0, size1 = 0;
size0 = get_sdr_cs_size(CS0); @@ -157,7 +157,6 @@ int dram_init(void)
void dram_init_banksize (void) { - DECLARE_GLOBAL_DATA_PTR; unsigned int size0 = 0, size1 = 0;
size0 = get_sdr_cs_size(CS0); diff --git a/arch/arm/cpu/armv7/omap3/sdrc.c b/arch/arm/cpu/armv7/omap3/sdrc.c index a4979ce..2a7970b 100644 --- a/arch/arm/cpu/armv7/omap3/sdrc.c +++ b/arch/arm/cpu/armv7/omap3/sdrc.c @@ -37,6 +37,7 @@ #include <asm/arch/mem.h> #include <asm/arch/sys_proto.h>
static struct sdrc *sdrc_base = (struct sdrc *)OMAP34XX_SDRC_BASE; @@ -172,7 +173,6 @@ void do_sdrc_init(u32 cs, u32 early) */ int dram_init(void) { - DECLARE_GLOBAL_DATA_PTR; unsigned int size0 = 0, size1 = 0;
size0 = get_sdr_cs_size(CS0); @@ -194,7 +194,6 @@ int dram_init(void)
Applied to u-boot-ti
Regards, Sandeep
Nishanth Menon
Paulraj, Sandeep
