[U-Boot] [PATCH] configs: atmel: sama5d4_xplained_mmc: enable HW PMECC
NAND: BUG at drivers/mtd/nand/raw/nand_base.c:4361/nand_scan_tail()!
This board has a NAND flash enabled, and it requires the HW PMECC in order to correctly probe this flash. In the NAND flash configuration , this is selected by the GENERATE_PMECC_HEADER which is not needed for mmc configuration.
Signed-off-by: Eugen Hristev eugen.hristev@microchip.com --- configs/sama5d4_xplained_mmc_defconfig | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/configs/sama5d4_xplained_mmc_defconfig b/configs/sama5d4_xplained_mmc_defconfig index 6914c29..c232da9 100644 --- a/configs/sama5d4_xplained_mmc_defconfig +++ b/configs/sama5d4_xplained_mmc_defconfig @@ -58,6 +58,8 @@ CONFIG_DM_MMC=y CONFIG_GENERIC_ATMEL_MCI=y CONFIG_NAND=y CONFIG_NAND_ATMEL=y +CONFIG_ATMEL_NAND_HW_PMECC=y +CONFIG_PMECC_CAP=8 CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=30000000
Applied to u-boot-atmel/master
Eugen.Hristev@microchip.com
