[U-Boot] [PATCH] ARM: HYP/non-sec: Make a variable as a local one
Defining variable gic_dist_addr as a globe one prevents some functions, which use this variable, from being used before relocation which happened in the deep sleep resume process on Freescale SoC platforms.
Signed-off-by: Tang Yuantian Yuantian.Tang@freescale.com --- arch/arm/cpu/armv7/virt-v7.c | 9 +++++++-- 1 file changed, 7 insertions(+), 2 deletions(-)
diff --git a/arch/arm/cpu/armv7/virt-v7.c b/arch/arm/cpu/armv7/virt-v7.c index 651ca40..b69fd37 100644 --- a/arch/arm/cpu/armv7/virt-v7.c +++ b/arch/arm/cpu/armv7/virt-v7.c @@ -15,8 +15,6 @@ #include <asm/io.h> #include <asm/secure.h>
-unsigned long gic_dist_addr; - static unsigned int read_id_pfr1(void) { unsigned int reg; @@ -68,6 +66,12 @@ static void kick_secondary_cpus_gic(unsigned long gicdaddr)
void __weak smp_kick_all_cpus(void) { + unsigned long gic_dist_addr; + + gic_dist_addr = get_gicd_base_address(); + if (gic_dist_addr == -1) + return; + kick_secondary_cpus_gic(gic_dist_addr); }
@@ -75,6 +79,7 @@ int armv7_init_nonsec(void) { unsigned int reg; unsigned itlinesnr, i; + unsigned long gic_dist_addr;
/* check whether the CPU supports the security extensions */ reg = read_id_pfr1();
Hi Tang,
Please fix subject / commit summary to indicate which variable is to be made local.
On Thu, 18 Sep 2014 17:12:34 +0800, Tang Yuantian Yuantian.Tang@freescale.com wrote:
- unsigned long gic_dist_addr;
- gic_dist_addr = get_gicd_base_address();
- if (gic_dist_addr == -1)
return;
- kick_secondary_cpus_gic(gic_dist_addr);
Did you check that the global was not used as a common variable between the functions?
Amicalement,
-----Original Message----- From: Albert ARIBAUD [mailto:albert.u.boot@aribaud.net] Sent: Thursday, September 18, 2014 5:44 PM To: Tang Yuantian-B29983 Cc: andre.przywara@linaro.org; ijc@hellion.org.uk; marc.zyngier@arm.com; u-boot@lists.denx.de; Jin Zhengxiong-R64188 Subject: Re: [PATCH] ARM: HYP/non-sec: Make a variable as a local one
Hi Tang,
return;
Yes, I grep it globally. It was referred by only 2 places which are both in virt-v7.c file.
I will fix the subject.
Thanks, Yuantian
Amicalement,
Albert.
Albert ARIBAUD
Tang Yuantian
Yuantian Tang
