[U-Boot] [PATCH 00/17] Convert some imx6 boards to DM_VIDEO
This series starts conversion of ipuv3 driver to DM_VIDEO. It has been tested on apalis_imx6 module with LVDS display attached and on wandboard with HDMI display.
With applied "[PATCH 17/17] imx6: wandboard: convert to DM_MMC" building wandboard target doesn't work. To fix this please apply patches [1], [2] and enable CONFIG_AHCI and CONFIG_DM_SCSI in wandboard_defconfig.
[1] http://patchwork.ozlabs.org/patch/1050141 [2] http://patchwork.ozlabs.org/patch/1050143
Anatolij Gustschin (17): video: ipuv3: add DM_VIDEO support video: move ipuv3 files to subdirectory imx: move CONFIG_VIDEO_IPUV3 to defconfigs imx6: dts: add 'u-boot,dm-pre-reloc' to soc and ipu nodes apalis_imx6: convert to DM_VIDEO imx6: icore: convert to DM_VIDEO imx6: ge_bx50v3: convert to DM_VIDEO colibri_imx6: convert to DM_VIDEO mx6sabresd: convert to DM_VIDEO mx6sabreauto: convert to DM_VIDEO imx6: wandboard: add device tree imx6: wandboard: convert to DM_GPIO and enable pinctrl driver imx6: wandboard: convert to DM_USB imx6: wandboard: convert to DM_VIDEO imx6: wandboard: convert to DM_PMIC imx6: wandboard: convert to DM_I2C imx6: wandboard: convert to DM_MMC
arch/arm/dts/imx6dl-wandboard-revb1.dts | 18 + arch/arm/dts/imx6qdl-wandboard-revb1.dtsi | 41 +++ arch/arm/dts/imx6qdl-wandboard.dtsi | 380 ++++++++++++++++++++++ arch/arm/dts/imx6qdl.dtsi | 2 + arch/arm/include/asm/mach-imx/video.h | 1 + arch/arm/mach-imx/video.c | 25 +- board/wandboard/MAINTAINERS | 3 + board/wandboard/spl.c | 92 ++++++ board/wandboard/wandboard.c | 160 +++------ configs/apalis_imx6_defconfig | 4 +- configs/aristainetos2_defconfig | 1 + configs/aristainetos2b_defconfig | 1 + configs/aristainetos_defconfig | 1 + configs/cgtqmx6eval_defconfig | 1 + configs/cm_fx6_defconfig | 1 + configs/colibri_imx6_defconfig | 3 +- configs/dms-ba16-1g_defconfig | 1 + configs/dms-ba16_defconfig | 1 + configs/ge_bx50v3_defconfig | 2 + configs/gwventana_emmc_defconfig | 1 + configs/gwventana_gw5904_defconfig | 1 + configs/gwventana_nand_defconfig | 1 + configs/imx6dl_icore_nand_defconfig | 2 +- configs/imx6q_icore_nand_defconfig | 2 +- configs/imx6qdl_icore_mmc_defconfig | 2 +- configs/imx6qdl_icore_nand_defconfig | 2 +- configs/m53menlo_defconfig | 1 + configs/marsboard_defconfig | 1 + configs/mx51evk_defconfig | 1 + configs/mx53cx9020_defconfig | 1 + configs/mx53loco_defconfig | 1 + configs/mx53ppd_defconfig | 1 + configs/mx6cuboxi_defconfig | 1 + configs/mx6qsabrelite_defconfig | 1 + configs/mx6sabreauto_defconfig | 3 +- configs/mx6sabresd_defconfig | 3 +- configs/nitrogen6dl2g_defconfig | 1 + configs/nitrogen6dl_defconfig | 1 + configs/nitrogen6q2g_defconfig | 1 + configs/nitrogen6q_defconfig | 1 + configs/nitrogen6s1g_defconfig | 1 + configs/nitrogen6s_defconfig | 1 + configs/novena_defconfig | 1 + configs/riotboard_defconfig | 1 + configs/riotboard_spl_defconfig | 1 + configs/tbs2910_defconfig | 1 + configs/wandboard_defconfig | 18 +- drivers/video/Kconfig | 9 +- drivers/video/Makefile | 2 +- drivers/video/imx/Kconfig | 8 + drivers/video/imx/Makefile | 6 + drivers/video/{ => imx}/ipu.h | 0 drivers/video/{ => imx}/ipu_common.c | 0 drivers/video/{ => imx}/ipu_disp.c | 0 drivers/video/{ => imx}/ipu_regs.h | 0 drivers/video/{ => imx}/mxc_ipuv3_fb.c | 89 ++++- drivers/video/{ => imx}/mxcfb.h | 0 include/configs/advantech_dms-ba16.h | 1 - include/configs/apalis_imx6.h | 1 - include/configs/aristainetos-common.h | 1 - include/configs/cgtqmx6eval.h | 1 - include/configs/cm_fx6.h | 1 - include/configs/colibri_imx6.h | 1 - include/configs/embestmx6boards.h | 1 - include/configs/ge_bx50v3.h | 8 - include/configs/gw_ventana.h | 1 - include/configs/m53menlo.h | 1 - include/configs/mx51evk.h | 1 - include/configs/mx53cx9020.h | 1 - include/configs/mx53loco.h | 1 - include/configs/mx53ppd.h | 5 - include/configs/mx6cuboxi.h | 1 - include/configs/mx6sabre_common.h | 1 - include/configs/nitrogen6x.h | 1 - include/configs/novena.h | 1 - include/configs/tbs2910.h | 1 - include/configs/wandboard.h | 18 - 77 files changed, 766 insertions(+), 187 deletions(-) create mode 100644 arch/arm/dts/imx6dl-wandboard-revb1.dts create mode 100644 arch/arm/dts/imx6qdl-wandboard-revb1.dtsi create mode 100644 arch/arm/dts/imx6qdl-wandboard.dtsi create mode 100644 drivers/video/imx/Kconfig create mode 100644 drivers/video/imx/Makefile rename drivers/video/{ => imx}/ipu.h (100%) rename drivers/video/{ => imx}/ipu_common.c (100%) rename drivers/video/{ => imx}/ipu_disp.c (100%) rename drivers/video/{ => imx}/ipu_regs.h (100%) rename drivers/video/{ => imx}/mxc_ipuv3_fb.c (88%) rename drivers/video/{ => imx}/mxcfb.h (100%)
Extend the driver to build with DM_VIDEO enabled. DTS files must additionally include 'u-boot,dm-pre-reloc' property in soc and ipu nodes to enable driver binding to ipu device.
Signed-off-by: Anatolij Gustschin agust@denx.de --- arch/arm/include/asm/mach-imx/video.h | 1 + arch/arm/mach-imx/video.c | 25 +++++--- drivers/video/Kconfig | 14 ++--- drivers/video/mxc_ipuv3_fb.c | 87 +++++++++++++++++++++++++++ 4 files changed, 113 insertions(+), 14 deletions(-)
diff --git a/arch/arm/include/asm/mach-imx/video.h b/arch/arm/include/asm/mach-imx/video.h index 812e6f85e4..d1a14ad7d3 100644 --- a/arch/arm/include/asm/mach-imx/video.h +++ b/arch/arm/include/asm/mach-imx/video.h @@ -26,4 +26,5 @@ extern size_t display_count; #endif
int ipu_set_ldb_clock(int rate); +int ipu_displays_init(void); #endif diff --git a/arch/arm/mach-imx/video.c b/arch/arm/mach-imx/video.c index 953fe53cb4..22a371a212 100644 --- a/arch/arm/mach-imx/video.c +++ b/arch/arm/mach-imx/video.c @@ -4,6 +4,17 @@ #include <linux/errno.h> #include <asm/mach-imx/video.h>
+#ifdef CONFIG_IMX_HDMI +#include <asm/arch/mxc_hdmi.h> +#include <asm/io.h> + +int detect_hdmi(struct display_info_t const *dev) +{ + struct hdmi_regs *hdmi = (struct hdmi_regs *)HDMI_ARB_BASE_ADDR; + return readb(&hdmi->phy_stat0) & HDMI_DVI_STAT; +} +#endif + int board_video_skip(void) { int i; @@ -42,6 +53,11 @@ int board_video_skip(void) displays[i].mode.name, displays[i].mode.xres, displays[i].mode.yres); + +#ifdef CONFIG_IMX_HDMI + if (!strcmp(displays[i].mode.name, "HDMI")) + imx_enable_hdmi_phy(); +#endif } else printf("LCD %s cannot be configured: %d\n", displays[i].mode.name, ret); @@ -53,12 +69,7 @@ int board_video_skip(void) return ret; }
-#ifdef CONFIG_IMX_HDMI -#include <asm/arch/mxc_hdmi.h> -#include <asm/io.h> -int detect_hdmi(struct display_info_t const *dev) +int ipu_displays_init(void) { - struct hdmi_regs *hdmi = (struct hdmi_regs *)HDMI_ARB_BASE_ADDR; - return readb(&hdmi->phy_stat0) & HDMI_DVI_STAT; + return board_video_skip(); } -#endif diff --git a/drivers/video/Kconfig b/drivers/video/Kconfig index 2eac4b6381..73a2402f41 100644 --- a/drivers/video/Kconfig +++ b/drivers/video/Kconfig @@ -538,6 +538,13 @@ config VIDEO_TEGRA124
source "drivers/video/bridge/Kconfig"
+config VIDEO_IPUV3 + bool "i.MX IPUv3 Core video support" + depends on (VIDEO || DM_VIDEO) && (MX5 || MX6) + help + This enables framebuffer driver for i.MX processors working + on the IPUv3(Image Processing Unit) internal graphic processor. + config VIDEO bool "Enable legacy video support" depends on !DM_VIDEO @@ -547,13 +554,6 @@ config VIDEO model. Video drivers typically provide a colour text console and cursor.
-config VIDEO_IPUV3 - bool "i.MX IPUv3 Core video support" - depends on VIDEO && MX6 - help - This enables framebuffer driver for i.MX processors working - on the IPUv3(Image Processing Unit) internal graphic processor. - config CFB_CONSOLE bool "Enable colour frame buffer console" depends on VIDEO diff --git a/drivers/video/mxc_ipuv3_fb.c b/drivers/video/mxc_ipuv3_fb.c index 23cd55de47..5b3ba7b3a9 100644 --- a/drivers/video/mxc_ipuv3_fb.c +++ b/drivers/video/mxc_ipuv3_fb.c @@ -17,6 +17,7 @@ #include <linux/list.h> #include <linux/fb.h> #include <asm/io.h> +#include <asm/mach-imx/video.h> #include <malloc.h> #include <video_fb.h> #include "videomodes.h" @@ -24,6 +25,9 @@ #include "mxcfb.h" #include "ipu_regs.h"
+#include <dm.h> +#include <video.h> + DECLARE_GLOBAL_DATA_PTR;
static int mxcfb_map_video_memory(struct fb_info *fbi); @@ -401,8 +405,14 @@ static int mxcfb_map_video_memory(struct fb_info *fbi) fbi->fix.line_length; } fbi->fix.smem_len = roundup(fbi->fix.smem_len, ARCH_DMA_MINALIGN); + +#if CONFIG_IS_ENABLED(DM_VIDEO) + fbi->screen_base = (char *)gd->video_bottom; +#else fbi->screen_base = (char *)memalign(ARCH_DMA_MINALIGN, fbi->fix.smem_len); +#endif + fbi->fix.smem_start = (unsigned long)fbi->screen_base; if (fbi->screen_base == 0) { puts("Unable to allocate framebuffer memory\n"); @@ -416,7 +426,9 @@ static int mxcfb_map_video_memory(struct fb_info *fbi)
fbi->screen_size = fbi->fix.smem_len;
+#if CONFIG_IS_ENABLED(VIDEO) gd->fb_base = fbi->fix.smem_start; +#endif
/* Clear the screen */ memset((char *)fbi->screen_base, 0, fbi->fix.smem_len); @@ -611,3 +623,78 @@ int ipuv3_fb_init(struct fb_videomode const *mode,
return 0; } + +#if CONFIG_IS_ENABLED(DM_VIDEO) +enum { + /* Maximum display size we support */ + LCD_MAX_WIDTH = 1920, + LCD_MAX_HEIGHT = 1080, + LCD_MAX_LOG2_BPP = VIDEO_BPP16, +}; + +static int ipuv3_video_probe(struct udevice *dev) +{ + struct video_uc_platdata *plat = dev_get_uclass_platdata(dev); + struct video_priv *uc_priv = dev_get_uclass_priv(dev); + u32 fb_start, fb_end; + int ret; + + debug("%s() plat: base 0x%lx, size 0x%x\n", + __func__, plat->base, plat->size); + + ret = ipu_probe(); + if (ret) + return ret; + + ret = ipu_displays_init(); + if (ret < 0) + return ret; + + ret = mxcfb_probe(gpixfmt, gdisp, gmode); + if (ret < 0) + return ret; + + uc_priv->xsize = gmode->xres; + uc_priv->ysize = gmode->yres; + uc_priv->bpix = LCD_MAX_LOG2_BPP; + + /* Enable dcache for the frame buffer */ + fb_start = plat->base & ~(MMU_SECTION_SIZE - 1); + fb_end = plat->base + plat->size; + fb_end = ALIGN(fb_end, 1 << MMU_SECTION_SHIFT); + mmu_set_region_dcache_behaviour(fb_start, fb_end - fb_start, + DCACHE_WRITEBACK); + video_set_flush_dcache(dev, true); + + return 0; +} + +struct ipuv3_video_priv { + ulong regs; +}; + +static int ipuv3_video_bind(struct udevice *dev) +{ + struct video_uc_platdata *plat = dev_get_uclass_platdata(dev); + + plat->size = LCD_MAX_WIDTH * LCD_MAX_HEIGHT * + (1 << LCD_MAX_LOG2_BPP) / 8; + + return 0; +} + +static const struct udevice_id ipuv3_video_ids[] = { + { .compatible = "fsl,imx6q-ipu" }, + { } +}; + +U_BOOT_DRIVER(ipuv3_video) = { + .name = "ipuv3_video", + .id = UCLASS_VIDEO, + .of_match = ipuv3_video_ids, + .bind = ipuv3_video_bind, + .probe = ipuv3_video_probe, + .priv_auto_alloc_size = sizeof(struct ipuv3_video_priv), + .flags = DM_FLAG_PRE_RELOC, +}; +#endif /* CONFIG_DM_VIDEO */
Extend the driver to build with DM_VIDEO enabled. DTS files must additionally include 'u-boot,dm-pre-reloc' property in soc and ipu nodes to enable driver binding to ipu device. Signed-off-by: Anatolij Gustschin agust@denx.de
Applied to u-boot-imx, -next, thanks !
Best regards, Stefano Babic
Place ipuv3 files and headers in custom driver subdirectory.
Signed-off-by: Anatolij Gustschin agust@denx.de --- drivers/video/Kconfig | 7 +------ drivers/video/Makefile | 2 +- drivers/video/imx/Kconfig | 8 ++++++++ drivers/video/imx/Makefile | 6 ++++++ drivers/video/{ => imx}/ipu.h | 0 drivers/video/{ => imx}/ipu_common.c | 0 drivers/video/{ => imx}/ipu_disp.c | 0 drivers/video/{ => imx}/ipu_regs.h | 0 drivers/video/{ => imx}/mxc_ipuv3_fb.c | 2 +- drivers/video/{ => imx}/mxcfb.h | 0 10 files changed, 17 insertions(+), 8 deletions(-) create mode 100644 drivers/video/imx/Kconfig create mode 100644 drivers/video/imx/Makefile rename drivers/video/{ => imx}/ipu.h (100%) rename drivers/video/{ => imx}/ipu_common.c (100%) rename drivers/video/{ => imx}/ipu_disp.c (100%) rename drivers/video/{ => imx}/ipu_regs.h (100%) rename drivers/video/{ => imx}/mxc_ipuv3_fb.c (99%) rename drivers/video/{ => imx}/mxcfb.h (100%)
diff --git a/drivers/video/Kconfig b/drivers/video/Kconfig index 73a2402f41..53871f864f 100644 --- a/drivers/video/Kconfig +++ b/drivers/video/Kconfig @@ -538,12 +538,7 @@ config VIDEO_TEGRA124
-config VIDEO_IPUV3 - bool "i.MX IPUv3 Core video support" - depends on (VIDEO || DM_VIDEO) && (MX5 || MX6) - help - This enables framebuffer driver for i.MX processors working - on the IPUv3(Image Processing Unit) internal graphic processor. +source "drivers/video/imx/Kconfig"
config VIDEO bool "Enable legacy video support" diff --git a/drivers/video/Makefile b/drivers/video/Makefile index 671f037c35..349a207035 100644 --- a/drivers/video/Makefile +++ b/drivers/video/Makefile @@ -46,7 +46,7 @@ obj-$(CONFIG_VIDEO_DA8XX) += da8xx-fb.o videomodes.o obj-$(CONFIG_VIDEO_DW_HDMI) += dw_hdmi.o obj-$(CONFIG_VIDEO_EFI) += efi.o obj-$(CONFIG_VIDEO_FSL_DCU_FB) += fsl_dcu_fb.o videomodes.o -obj-$(CONFIG_VIDEO_IPUV3) += mxc_ipuv3_fb.o ipu_common.o ipu_disp.o +obj-$(CONFIG_VIDEO_IPUV3) += imx/ obj-$(CONFIG_VIDEO_IVYBRIDGE_IGD) += ivybridge_igd.o obj-$(CONFIG_VIDEO_LCD_ANX9804) += anx9804.o obj-$(CONFIG_VIDEO_LCD_HITACHI_TX18D42VM) += hitachi_tx18d42vm_lcd.o diff --git a/drivers/video/imx/Kconfig b/drivers/video/imx/Kconfig new file mode 100644 index 0000000000..c33620e075 --- /dev/null +++ b/drivers/video/imx/Kconfig @@ -0,0 +1,8 @@ + +config VIDEO_IPUV3 + bool "i.MX IPUv3 Core video support" + depends on (VIDEO || DM_VIDEO) && (MX5 || MX6) + help + This enables framebuffer driver for i.MX processors working + on the IPUv3(Image Processing Unit) internal graphic processor. + diff --git a/drivers/video/imx/Makefile b/drivers/video/imx/Makefile new file mode 100644 index 0000000000..179ea651fe --- /dev/null +++ b/drivers/video/imx/Makefile @@ -0,0 +1,6 @@ +# SPDX-License-Identifier: GPL-2.0+ +# +# (C) Copyright 2000-2007 +# Wolfgang Denk, DENX Software Engineering, wd@denx.de. + +obj-y += mxc_ipuv3_fb.o ipu_common.o ipu_disp.o diff --git a/drivers/video/ipu.h b/drivers/video/imx/ipu.h similarity index 100% rename from drivers/video/ipu.h rename to drivers/video/imx/ipu.h diff --git a/drivers/video/ipu_common.c b/drivers/video/imx/ipu_common.c similarity index 100% rename from drivers/video/ipu_common.c rename to drivers/video/imx/ipu_common.c diff --git a/drivers/video/ipu_disp.c b/drivers/video/imx/ipu_disp.c similarity index 100% rename from drivers/video/ipu_disp.c rename to drivers/video/imx/ipu_disp.c diff --git a/drivers/video/ipu_regs.h b/drivers/video/imx/ipu_regs.h similarity index 100% rename from drivers/video/ipu_regs.h rename to drivers/video/imx/ipu_regs.h diff --git a/drivers/video/mxc_ipuv3_fb.c b/drivers/video/imx/mxc_ipuv3_fb.c similarity index 99% rename from drivers/video/mxc_ipuv3_fb.c rename to drivers/video/imx/mxc_ipuv3_fb.c index 5b3ba7b3a9..3e38d4bdcc 100644 --- a/drivers/video/mxc_ipuv3_fb.c +++ b/drivers/video/imx/mxc_ipuv3_fb.c @@ -20,7 +20,7 @@ #include <asm/mach-imx/video.h> #include <malloc.h> #include <video_fb.h> -#include "videomodes.h" +#include "../videomodes.h" #include "ipu.h" #include "mxcfb.h" #include "ipu_regs.h" diff --git a/drivers/video/mxcfb.h b/drivers/video/imx/mxcfb.h similarity index 100% rename from drivers/video/mxcfb.h rename to drivers/video/imx/mxcfb.h
Place ipuv3 files and headers in custom driver subdirectory. Signed-off-by: Anatolij Gustschin agust@denx.de
Signed-off-by: Anatolij Gustschin agust@denx.de --- configs/apalis_imx6_defconfig | 1 + configs/aristainetos2_defconfig | 1 + configs/aristainetos2b_defconfig | 1 + configs/aristainetos_defconfig | 1 + configs/cgtqmx6eval_defconfig | 1 + configs/cm_fx6_defconfig | 1 + configs/colibri_imx6_defconfig | 1 + configs/dms-ba16-1g_defconfig | 1 + configs/dms-ba16_defconfig | 1 + configs/ge_bx50v3_defconfig | 2 ++ configs/gwventana_emmc_defconfig | 1 + configs/gwventana_gw5904_defconfig | 1 + configs/gwventana_nand_defconfig | 1 + configs/m53menlo_defconfig | 1 + configs/marsboard_defconfig | 1 + configs/mx51evk_defconfig | 1 + configs/mx53cx9020_defconfig | 1 + configs/mx53loco_defconfig | 1 + configs/mx53ppd_defconfig | 1 + configs/mx6cuboxi_defconfig | 1 + configs/mx6qsabrelite_defconfig | 1 + configs/mx6sabreauto_defconfig | 1 + configs/mx6sabresd_defconfig | 1 + configs/nitrogen6dl2g_defconfig | 1 + configs/nitrogen6dl_defconfig | 1 + configs/nitrogen6q2g_defconfig | 1 + configs/nitrogen6q_defconfig | 1 + configs/nitrogen6s1g_defconfig | 1 + configs/nitrogen6s_defconfig | 1 + configs/novena_defconfig | 1 + configs/riotboard_defconfig | 1 + configs/riotboard_spl_defconfig | 1 + configs/tbs2910_defconfig | 1 + configs/wandboard_defconfig | 1 + include/configs/advantech_dms-ba16.h | 1 - include/configs/apalis_imx6.h | 1 - include/configs/aristainetos-common.h | 1 - include/configs/cgtqmx6eval.h | 1 - include/configs/cm_fx6.h | 1 - include/configs/colibri_imx6.h | 1 - include/configs/embestmx6boards.h | 1 - include/configs/ge_bx50v3.h | 6 ------ include/configs/gw_ventana.h | 1 - include/configs/m53menlo.h | 1 - include/configs/mx51evk.h | 1 - include/configs/mx53cx9020.h | 1 - include/configs/mx53loco.h | 1 - include/configs/mx53ppd.h | 5 ----- include/configs/mx6cuboxi.h | 1 - include/configs/mx6sabre_common.h | 1 - include/configs/nitrogen6x.h | 1 - include/configs/novena.h | 1 - include/configs/tbs2910.h | 1 - include/configs/wandboard.h | 1 - 54 files changed, 35 insertions(+), 29 deletions(-)
diff --git a/configs/apalis_imx6_defconfig b/configs/apalis_imx6_defconfig index 1ab5edc966..60ca8a5147 100644 --- a/configs/apalis_imx6_defconfig +++ b/configs/apalis_imx6_defconfig @@ -82,5 +82,6 @@ CONFIG_CI_UDC=y CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_USB_HOST_ETHER=y CONFIG_VIDEO=y +CONFIG_VIDEO_IPUV3=y CONFIG_FAT_WRITE=y CONFIG_OF_LIBFDT_OVERLAY=y diff --git a/configs/aristainetos2_defconfig b/configs/aristainetos2_defconfig index f7de4e3b9a..60be6ba17b 100644 --- a/configs/aristainetos2_defconfig +++ b/configs/aristainetos2_defconfig @@ -51,6 +51,7 @@ CONFIG_MXC_SPI=y CONFIG_USB=y CONFIG_USB_STORAGE=y CONFIG_VIDEO=y +CONFIG_VIDEO_IPUV3=y # CONFIG_VIDEO_SW_CURSOR is not set CONFIG_IMX_WATCHDOG=y CONFIG_OF_LIBFDT=y diff --git a/configs/aristainetos2b_defconfig b/configs/aristainetos2b_defconfig index ff21f1f2c4..64f56ab58e 100644 --- a/configs/aristainetos2b_defconfig +++ b/configs/aristainetos2b_defconfig @@ -51,6 +51,7 @@ CONFIG_MXC_SPI=y CONFIG_USB=y CONFIG_USB_STORAGE=y CONFIG_VIDEO=y +CONFIG_VIDEO_IPUV3=y # CONFIG_VIDEO_SW_CURSOR is not set CONFIG_IMX_WATCHDOG=y CONFIG_OF_LIBFDT=y diff --git a/configs/aristainetos_defconfig b/configs/aristainetos_defconfig index 950f9f6baa..757d6ccb42 100644 --- a/configs/aristainetos_defconfig +++ b/configs/aristainetos_defconfig @@ -50,6 +50,7 @@ CONFIG_MXC_SPI=y CONFIG_USB=y CONFIG_USB_STORAGE=y CONFIG_VIDEO=y +CONFIG_VIDEO_IPUV3=y # CONFIG_VIDEO_SW_CURSOR is not set CONFIG_IMX_WATCHDOG=y CONFIG_OF_LIBFDT=y diff --git a/configs/cgtqmx6eval_defconfig b/configs/cgtqmx6eval_defconfig index 99c581b2de..fb99c6c73c 100644 --- a/configs/cgtqmx6eval_defconfig +++ b/configs/cgtqmx6eval_defconfig @@ -72,5 +72,6 @@ CONFIG_CI_UDC=y CONFIG_USB_HOST_ETHER=y CONFIG_USB_ETHER_ASIX=y CONFIG_VIDEO=y +CONFIG_VIDEO_IPUV3=y # CONFIG_VIDEO_SW_CURSOR is not set CONFIG_OF_LIBFDT=y diff --git a/configs/cm_fx6_defconfig b/configs/cm_fx6_defconfig index c8d1e83111..abdfc7f705 100644 --- a/configs/cm_fx6_defconfig +++ b/configs/cm_fx6_defconfig @@ -76,4 +76,5 @@ CONFIG_DM_USB=y CONFIG_USB_KEYBOARD=y CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y CONFIG_VIDEO=y +CONFIG_VIDEO_IPUV3=y CONFIG_FDT_FIXUP_PARTITIONS=y diff --git a/configs/colibri_imx6_defconfig b/configs/colibri_imx6_defconfig index df5a7be39f..611f9f0950 100644 --- a/configs/colibri_imx6_defconfig +++ b/configs/colibri_imx6_defconfig @@ -78,5 +78,6 @@ CONFIG_CI_UDC=y CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_USB_HOST_ETHER=y CONFIG_VIDEO=y +CONFIG_VIDEO_IPUV3=y CONFIG_FAT_WRITE=y CONFIG_OF_LIBFDT_OVERLAY=y diff --git a/configs/dms-ba16-1g_defconfig b/configs/dms-ba16-1g_defconfig index a2f4395b9e..845e75f145 100644 --- a/configs/dms-ba16-1g_defconfig +++ b/configs/dms-ba16-1g_defconfig @@ -51,5 +51,6 @@ CONFIG_USB_GADGET_PRODUCT_NUM=0xa4a5 CONFIG_CI_UDC=y CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_VIDEO=y +CONFIG_VIDEO_IPUV3=y # CONFIG_VIDEO_SW_CURSOR is not set CONFIG_OF_LIBFDT=y diff --git a/configs/dms-ba16_defconfig b/configs/dms-ba16_defconfig index 2784c1268e..c04786a974 100644 --- a/configs/dms-ba16_defconfig +++ b/configs/dms-ba16_defconfig @@ -50,5 +50,6 @@ CONFIG_USB_GADGET_PRODUCT_NUM=0xa4a5 CONFIG_CI_UDC=y CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_VIDEO=y +CONFIG_VIDEO_IPUV3=y # CONFIG_VIDEO_SW_CURSOR is not set CONFIG_OF_LIBFDT=y diff --git a/configs/ge_bx50v3_defconfig b/configs/ge_bx50v3_defconfig index 22349a08c7..91782b06a8 100644 --- a/configs/ge_bx50v3_defconfig +++ b/configs/ge_bx50v3_defconfig @@ -60,3 +60,5 @@ CONFIG_DM_GPIO=y CONFIG_DM_SPI=y CONFIG_DM_SPI_FLASH=y CONFIG_OF_BOARD_SETUP=y +CONFIG_VIDEO=y +CONFIG_VIDEO_IPUV3=y diff --git a/configs/gwventana_emmc_defconfig b/configs/gwventana_emmc_defconfig index 07171c7009..2e04127014 100644 --- a/configs/gwventana_emmc_defconfig +++ b/configs/gwventana_emmc_defconfig @@ -84,6 +84,7 @@ CONFIG_USB_HOST_ETHER=y CONFIG_USB_ETHER_ASIX=y CONFIG_USB_ETHER_SMSC95XX=y CONFIG_VIDEO=y +CONFIG_VIDEO_IPUV3=y # CONFIG_VIDEO_SW_CURSOR is not set CONFIG_HEXDUMP=y CONFIG_OF_LIBFDT=y diff --git a/configs/gwventana_gw5904_defconfig b/configs/gwventana_gw5904_defconfig index 0ed2209e3b..275aa89ed6 100644 --- a/configs/gwventana_gw5904_defconfig +++ b/configs/gwventana_gw5904_defconfig @@ -88,6 +88,7 @@ CONFIG_USB_HOST_ETHER=y CONFIG_USB_ETHER_ASIX=y CONFIG_USB_ETHER_SMSC95XX=y CONFIG_VIDEO=y +CONFIG_VIDEO_IPUV3=y # CONFIG_VIDEO_SW_CURSOR is not set CONFIG_HEXDUMP=y CONFIG_OF_LIBFDT=y diff --git a/configs/gwventana_nand_defconfig b/configs/gwventana_nand_defconfig index 57e4a999ab..477d205bc3 100644 --- a/configs/gwventana_nand_defconfig +++ b/configs/gwventana_nand_defconfig @@ -87,6 +87,7 @@ CONFIG_USB_HOST_ETHER=y CONFIG_USB_ETHER_ASIX=y CONFIG_USB_ETHER_SMSC95XX=y CONFIG_VIDEO=y +CONFIG_VIDEO_IPUV3=y # CONFIG_VIDEO_SW_CURSOR is not set CONFIG_HEXDUMP=y CONFIG_OF_LIBFDT=y diff --git a/configs/m53menlo_defconfig b/configs/m53menlo_defconfig index 5555e05030..e830b2c92e 100644 --- a/configs/m53menlo_defconfig +++ b/configs/m53menlo_defconfig @@ -64,6 +64,7 @@ CONFIG_USB_ETHER_ASIX=y CONFIG_USB_ETHER_MCS7830=y CONFIG_USB_ETHER_SMSC95XX=y CONFIG_VIDEO=y +CONFIG_VIDEO_IPUV3=y # CONFIG_VIDEO_SW_CURSOR is not set CONFIG_IMX_WATCHDOG=y CONFIG_FAT_WRITE=y diff --git a/configs/marsboard_defconfig b/configs/marsboard_defconfig index 48bec11c10..30d765946e 100644 --- a/configs/marsboard_defconfig +++ b/configs/marsboard_defconfig @@ -33,5 +33,6 @@ CONFIG_USB=y CONFIG_USB_HOST_ETHER=y CONFIG_USB_ETHER_ASIX=y CONFIG_VIDEO=y +CONFIG_VIDEO_IPUV3=y # CONFIG_VIDEO_SW_CURSOR is not set CONFIG_OF_LIBFDT=y diff --git a/configs/mx51evk_defconfig b/configs/mx51evk_defconfig index e93e81f3c3..dc0b3b3f77 100644 --- a/configs/mx51evk_defconfig +++ b/configs/mx51evk_defconfig @@ -31,5 +31,6 @@ CONFIG_USB_HOST_ETHER=y CONFIG_USB_ETHER_ASIX=y CONFIG_USB_ETHER_SMSC95XX=y CONFIG_VIDEO=y +CONFIG_VIDEO_IPUV3=y # CONFIG_VIDEO_SW_CURSOR is not set CONFIG_OF_LIBFDT=y diff --git a/configs/mx53cx9020_defconfig b/configs/mx53cx9020_defconfig index 07f3a23028..831d50925f 100644 --- a/configs/mx53cx9020_defconfig +++ b/configs/mx53cx9020_defconfig @@ -32,4 +32,5 @@ CONFIG_PINCTRL=y CONFIG_PINCTRL_IMX5=y CONFIG_MXC_UART=y CONFIG_VIDEO=y +CONFIG_VIDEO_IPUV3=y # CONFIG_VIDEO_SW_CURSOR is not set diff --git a/configs/mx53loco_defconfig b/configs/mx53loco_defconfig index 4e161371e3..776fc8bab4 100644 --- a/configs/mx53loco_defconfig +++ b/configs/mx53loco_defconfig @@ -32,5 +32,6 @@ CONFIG_USB_ETHER_ASIX=y CONFIG_USB_ETHER_MCS7830=y CONFIG_USB_ETHER_SMSC95XX=y CONFIG_VIDEO=y +CONFIG_VIDEO_IPUV3=y # CONFIG_VIDEO_SW_CURSOR is not set CONFIG_OF_LIBFDT=y diff --git a/configs/mx53ppd_defconfig b/configs/mx53ppd_defconfig index db31d817aa..2a6183b77b 100644 --- a/configs/mx53ppd_defconfig +++ b/configs/mx53ppd_defconfig @@ -39,6 +39,7 @@ CONFIG_RTC_S35392A=y CONFIG_USB=y CONFIG_USB_STORAGE=y CONFIG_VIDEO=y +CONFIG_VIDEO_IPUV3=y # CONFIG_VIDEO_SW_CURSOR is not set CONFIG_IMX_WATCHDOG=y CONFIG_OF_LIBFDT=y diff --git a/configs/mx6cuboxi_defconfig b/configs/mx6cuboxi_defconfig index 506e3a71df..f1c2fd4dba 100644 --- a/configs/mx6cuboxi_defconfig +++ b/configs/mx6cuboxi_defconfig @@ -39,5 +39,6 @@ CONFIG_DM_THERMAL=y CONFIG_USB=y CONFIG_USB_KEYBOARD=y CONFIG_VIDEO=y +CONFIG_VIDEO_IPUV3=y # CONFIG_VIDEO_SW_CURSOR is not set CONFIG_OF_LIBFDT=y diff --git a/configs/mx6qsabrelite_defconfig b/configs/mx6qsabrelite_defconfig index 2666340615..3d0e57d087 100644 --- a/configs/mx6qsabrelite_defconfig +++ b/configs/mx6qsabrelite_defconfig @@ -55,5 +55,6 @@ CONFIG_CI_UDC=y CONFIG_USB_ETHER=y CONFIG_USB_ETH_CDC=y CONFIG_VIDEO=y +CONFIG_VIDEO_IPUV3=y # CONFIG_VIDEO_SW_CURSOR is not set CONFIG_OF_LIBFDT=y diff --git a/configs/mx6sabreauto_defconfig b/configs/mx6sabreauto_defconfig index f51b5af7ab..e52ad368d2 100644 --- a/configs/mx6sabreauto_defconfig +++ b/configs/mx6sabreauto_defconfig @@ -83,4 +83,5 @@ CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_USB_HOST_ETHER=y CONFIG_USB_ETHER_ASIX=y CONFIG_VIDEO=y +CONFIG_VIDEO_IPUV3=y # CONFIG_VIDEO_SW_CURSOR is not set diff --git a/configs/mx6sabresd_defconfig b/configs/mx6sabresd_defconfig index ac879a3d20..ea34217e1c 100644 --- a/configs/mx6sabresd_defconfig +++ b/configs/mx6sabresd_defconfig @@ -94,4 +94,5 @@ CONFIG_CI_UDC=y CONFIG_USB_HOST_ETHER=y CONFIG_USB_ETHER_ASIX=y CONFIG_VIDEO=y +CONFIG_VIDEO_IPUV3=y # CONFIG_VIDEO_SW_CURSOR is not set diff --git a/configs/nitrogen6dl2g_defconfig b/configs/nitrogen6dl2g_defconfig index af59a71d3b..a5c1e7a492 100644 --- a/configs/nitrogen6dl2g_defconfig +++ b/configs/nitrogen6dl2g_defconfig @@ -57,5 +57,6 @@ CONFIG_CI_UDC=y CONFIG_USB_ETHER=y CONFIG_USB_ETH_CDC=y CONFIG_VIDEO=y +CONFIG_VIDEO_IPUV3=y # CONFIG_VIDEO_SW_CURSOR is not set CONFIG_OF_LIBFDT=y diff --git a/configs/nitrogen6dl_defconfig b/configs/nitrogen6dl_defconfig index 9072c04446..6fe9e9da20 100644 --- a/configs/nitrogen6dl_defconfig +++ b/configs/nitrogen6dl_defconfig @@ -57,5 +57,6 @@ CONFIG_CI_UDC=y CONFIG_USB_ETHER=y CONFIG_USB_ETH_CDC=y CONFIG_VIDEO=y +CONFIG_VIDEO_IPUV3=y # CONFIG_VIDEO_SW_CURSOR is not set CONFIG_OF_LIBFDT=y diff --git a/configs/nitrogen6q2g_defconfig b/configs/nitrogen6q2g_defconfig index b92d27a475..b8fb34ca25 100644 --- a/configs/nitrogen6q2g_defconfig +++ b/configs/nitrogen6q2g_defconfig @@ -59,5 +59,6 @@ CONFIG_CI_UDC=y CONFIG_USB_ETHER=y CONFIG_USB_ETH_CDC=y CONFIG_VIDEO=y +CONFIG_VIDEO_IPUV3=y # CONFIG_VIDEO_SW_CURSOR is not set CONFIG_OF_LIBFDT=y diff --git a/configs/nitrogen6q_defconfig b/configs/nitrogen6q_defconfig index 3b8cc6ad2f..3c4c386101 100644 --- a/configs/nitrogen6q_defconfig +++ b/configs/nitrogen6q_defconfig @@ -59,5 +59,6 @@ CONFIG_CI_UDC=y CONFIG_USB_ETHER=y CONFIG_USB_ETH_CDC=y CONFIG_VIDEO=y +CONFIG_VIDEO_IPUV3=y # CONFIG_VIDEO_SW_CURSOR is not set CONFIG_OF_LIBFDT=y diff --git a/configs/nitrogen6s1g_defconfig b/configs/nitrogen6s1g_defconfig index 36cfe2196c..9c0356b3a9 100644 --- a/configs/nitrogen6s1g_defconfig +++ b/configs/nitrogen6s1g_defconfig @@ -57,5 +57,6 @@ CONFIG_CI_UDC=y CONFIG_USB_ETHER=y CONFIG_USB_ETH_CDC=y CONFIG_VIDEO=y +CONFIG_VIDEO_IPUV3=y # CONFIG_VIDEO_SW_CURSOR is not set CONFIG_OF_LIBFDT=y diff --git a/configs/nitrogen6s_defconfig b/configs/nitrogen6s_defconfig index 40c09d7ab6..dc104bab56 100644 --- a/configs/nitrogen6s_defconfig +++ b/configs/nitrogen6s_defconfig @@ -57,5 +57,6 @@ CONFIG_CI_UDC=y CONFIG_USB_ETHER=y CONFIG_USB_ETH_CDC=y CONFIG_VIDEO=y +CONFIG_VIDEO_IPUV3=y # CONFIG_VIDEO_SW_CURSOR is not set CONFIG_OF_LIBFDT=y diff --git a/configs/novena_defconfig b/configs/novena_defconfig index 4c9c1cb9eb..103d9183cb 100644 --- a/configs/novena_defconfig +++ b/configs/novena_defconfig @@ -58,6 +58,7 @@ CONFIG_USB_HOST_ETHER=y CONFIG_USB_ETHER_ASIX=y CONFIG_USB_ETHER_SMSC95XX=y CONFIG_VIDEO=y +CONFIG_VIDEO_IPUV3=y # CONFIG_VIDEO_SW_CURSOR is not set CONFIG_FAT_WRITE=y CONFIG_OF_LIBFDT=y diff --git a/configs/riotboard_defconfig b/configs/riotboard_defconfig index a9191ad846..cdfc5c6a16 100644 --- a/configs/riotboard_defconfig +++ b/configs/riotboard_defconfig @@ -33,5 +33,6 @@ CONFIG_USB=y CONFIG_USB_HOST_ETHER=y CONFIG_USB_ETHER_ASIX=y CONFIG_VIDEO=y +CONFIG_VIDEO_IPUV3=y # CONFIG_VIDEO_SW_CURSOR is not set CONFIG_OF_LIBFDT=y diff --git a/configs/riotboard_spl_defconfig b/configs/riotboard_spl_defconfig index 2298d5b615..8d67599469 100644 --- a/configs/riotboard_spl_defconfig +++ b/configs/riotboard_spl_defconfig @@ -42,6 +42,7 @@ CONFIG_USB=y CONFIG_USB_HOST_ETHER=y CONFIG_USB_ETHER_ASIX=y CONFIG_VIDEO=y +CONFIG_VIDEO_IPUV3=y # CONFIG_VIDEO_SW_CURSOR is not set CONFIG_OF_LIBFDT=y CONFIG_SPL_OF_LIBFDT=y diff --git a/configs/tbs2910_defconfig b/configs/tbs2910_defconfig index 78beb9a522..ad37daa98f 100644 --- a/configs/tbs2910_defconfig +++ b/configs/tbs2910_defconfig @@ -55,4 +55,5 @@ CONFIG_USB_GADGET_PRODUCT_NUM=0xa4a5 CONFIG_CI_UDC=y CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_VIDEO=y +CONFIG_VIDEO_IPUV3=y CONFIG_OF_LIBFDT=y diff --git a/configs/wandboard_defconfig b/configs/wandboard_defconfig index 5725487446..9a67e63132 100644 --- a/configs/wandboard_defconfig +++ b/configs/wandboard_defconfig @@ -42,5 +42,6 @@ CONFIG_MII=y CONFIG_DM_THERMAL=y CONFIG_USB=y CONFIG_VIDEO=y +CONFIG_VIDEO_IPUV3=y # CONFIG_VIDEO_SW_CURSOR is not set CONFIG_OF_LIBFDT=y diff --git a/include/configs/advantech_dms-ba16.h b/include/configs/advantech_dms-ba16.h index 0c9de6125d..382750986d 100644 --- a/include/configs/advantech_dms-ba16.h +++ b/include/configs/advantech_dms-ba16.h @@ -227,7 +227,6 @@
/* Framebuffer */ #ifdef CONFIG_VIDEO -#define CONFIG_VIDEO_IPUV3 #define CONFIG_VIDEO_BMP_RLE8 #define CONFIG_SPLASH_SCREEN #define CONFIG_SPLASH_SCREEN_ALIGN diff --git a/include/configs/apalis_imx6.h b/include/configs/apalis_imx6.h index c8aa1bdddf..fc72a55255 100644 --- a/include/configs/apalis_imx6.h +++ b/include/configs/apalis_imx6.h @@ -80,7 +80,6 @@ #define CONFIG_USBD_HS
/* Framebuffer and LCD */ -#define CONFIG_VIDEO_IPUV3 #define CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE #define CONFIG_VIDEO_BMP_RLE8 #define CONFIG_SPLASH_SCREEN diff --git a/include/configs/aristainetos-common.h b/include/configs/aristainetos-common.h index ca974c015f..3d0e7cf5d9 100644 --- a/include/configs/aristainetos-common.h +++ b/include/configs/aristainetos-common.h @@ -193,7 +193,6 @@ /* UBI support */
/* Framebuffer */ -#define CONFIG_VIDEO_IPUV3 /* check this console not needed, after test remove it */ #define CONFIG_VIDEO_BMP_RLE8 #define CONFIG_SPLASH_SCREEN diff --git a/include/configs/cgtqmx6eval.h b/include/configs/cgtqmx6eval.h index e01bf5bf1b..ac3b96a200 100644 --- a/include/configs/cgtqmx6eval.h +++ b/include/configs/cgtqmx6eval.h @@ -63,7 +63,6 @@ #define CONFIG_USBD_HS
/* Framebuffer */ -#define CONFIG_VIDEO_IPUV3 #define CONFIG_VIDEO_BMP_RLE8 #define CONFIG_SPLASH_SCREEN #define CONFIG_SPLASH_SCREEN_ALIGN diff --git a/include/configs/cm_fx6.h b/include/configs/cm_fx6.h index f7e82dfbdb..3aafa7e815 100644 --- a/include/configs/cm_fx6.h +++ b/include/configs/cm_fx6.h @@ -220,7 +220,6 @@ #define CONFIG_SYS_SPI_U_BOOT_OFFS (64 * 1024)
/* Display */ -#define CONFIG_VIDEO_IPUV3 #define CONFIG_IMX_HDMI
#define CONFIG_SPLASH_SCREEN diff --git a/include/configs/colibri_imx6.h b/include/configs/colibri_imx6.h index a6a823ee1f..802270e401 100644 --- a/include/configs/colibri_imx6.h +++ b/include/configs/colibri_imx6.h @@ -71,7 +71,6 @@ #define CONFIG_USBD_HS
/* Framebuffer and LCD */ -#define CONFIG_VIDEO_IPUV3 #define CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE #define CONFIG_VIDEO_BMP_RLE8 #define CONFIG_SPLASH_SCREEN diff --git a/include/configs/embestmx6boards.h b/include/configs/embestmx6boards.h index 7e7de4dae6..d8935499c1 100644 --- a/include/configs/embestmx6boards.h +++ b/include/configs/embestmx6boards.h @@ -97,7 +97,6 @@ #endif
/* Framebuffer */ -#define CONFIG_VIDEO_IPUV3 #define CONFIG_VIDEO_BMP_RLE8 #define CONFIG_SPLASH_SCREEN #define CONFIG_SPLASH_SCREEN_ALIGN diff --git a/include/configs/ge_bx50v3.h b/include/configs/ge_bx50v3.h index a5d7cb1be0..cc6a4f9bac 100644 --- a/include/configs/ge_bx50v3.h +++ b/include/configs/ge_bx50v3.h @@ -208,13 +208,7 @@ #define CONFIG_SYS_FSL_USDHC_NUM 3
/* Framebuffer */ -#define CONFIG_VIDEO #ifdef CONFIG_VIDEO -#define CONFIG_VIDEO_IPUV3 -#define CONFIG_CFB_CONSOLE -#define CONFIG_VGA_AS_SINGLE_DEVICE -#define CONFIG_SYS_CONSOLE_FG_COL 0xFF -#define CONFIG_SYS_CONSOLE_BG_COL 0x00 #define CONFIG_HIDE_LOGO_VERSION #define CONFIG_IMX_HDMI #define CONFIG_IMX_VIDEO_SKIP diff --git a/include/configs/gw_ventana.h b/include/configs/gw_ventana.h index 6e23fa29b3..d1fabc64dc 100644 --- a/include/configs/gw_ventana.h +++ b/include/configs/gw_ventana.h @@ -136,7 +136,6 @@ #define CONFIG_NETCONSOLE
/* Framebuffer and LCD */ -#define CONFIG_VIDEO_IPUV3 #define CONFIG_VIDEO_LOGO #define CONFIG_IMX_HDMI #define CONFIG_IMX_VIDEO_SKIP diff --git a/include/configs/m53menlo.h b/include/configs/m53menlo.h index 51456fbe55..84d061339e 100644 --- a/include/configs/m53menlo.h +++ b/include/configs/m53menlo.h @@ -138,7 +138,6 @@ * LCD */ #ifdef CONFIG_VIDEO -#define CONFIG_VIDEO_IPUV3 #define CONFIG_VIDEO_BMP_RLE8 #define CONFIG_VIDEO_BMP_GZIP #define CONFIG_SPLASH_SCREEN diff --git a/include/configs/mx51evk.h b/include/configs/mx51evk.h index eb172c97b3..9bf9773c69 100644 --- a/include/configs/mx51evk.h +++ b/include/configs/mx51evk.h @@ -68,7 +68,6 @@
/* Framebuffer and LCD */ #define CONFIG_PREBOOT -#define CONFIG_VIDEO_IPUV3 #define CONFIG_VIDEO_BMP_RLE8 #define CONFIG_SPLASH_SCREEN #define CONFIG_BMP_16BPP diff --git a/include/configs/mx53cx9020.h b/include/configs/mx53cx9020.h index 3ed5ee3c57..1e3ea88b77 100644 --- a/include/configs/mx53cx9020.h +++ b/include/configs/mx53cx9020.h @@ -161,7 +161,6 @@
/* Framebuffer and LCD */ #define CONFIG_PREBOOT -#define CONFIG_VIDEO_IPUV3 #define CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE #define CONFIG_VIDEO_BMP_RLE8 #define CONFIG_SPLASH_SCREEN diff --git a/include/configs/mx53loco.h b/include/configs/mx53loco.h index 816164e87e..2d18f05423 100644 --- a/include/configs/mx53loco.h +++ b/include/configs/mx53loco.h @@ -178,7 +178,6 @@
/* Framebuffer and LCD */ #define CONFIG_PREBOOT -#define CONFIG_VIDEO_IPUV3 #define CONFIG_VIDEO_BMP_RLE8 #define CONFIG_SPLASH_SCREEN #define CONFIG_BMP_16BPP diff --git a/include/configs/mx53ppd.h b/include/configs/mx53ppd.h index 5b97fe9843..f002324fdd 100644 --- a/include/configs/mx53ppd.h +++ b/include/configs/mx53ppd.h @@ -215,9 +215,4 @@ #define CONFIG_PWM_IMX #define CONFIG_IMX6_PWM_PER_CLK 66666000
-/* Framebuffer and LCD */ -#ifdef CONFIG_VIDEO - #define CONFIG_VIDEO_IPUV3 -#endif - #endif /* __CONFIG_H */ diff --git a/include/configs/mx6cuboxi.h b/include/configs/mx6cuboxi.h index a62e14f7c6..7b4ae2102e 100644 --- a/include/configs/mx6cuboxi.h +++ b/include/configs/mx6cuboxi.h @@ -35,7 +35,6 @@ #define CONFIG_PHY_ATHEROS
/* Framebuffer */ -#define CONFIG_VIDEO_IPUV3 #define CONFIG_VIDEO_BMP_RLE8 #define CONFIG_SPLASH_SCREEN #define CONFIG_SPLASH_SCREEN_ALIGN diff --git a/include/configs/mx6sabre_common.h b/include/configs/mx6sabre_common.h index 711aa82f9c..73888c7f4f 100644 --- a/include/configs/mx6sabre_common.h +++ b/include/configs/mx6sabre_common.h @@ -192,7 +192,6 @@ #endif
/* Framebuffer */ -#define CONFIG_VIDEO_IPUV3 #define CONFIG_VIDEO_BMP_RLE8 #define CONFIG_SPLASH_SCREEN #define CONFIG_SPLASH_SCREEN_ALIGN diff --git a/include/configs/nitrogen6x.h b/include/configs/nitrogen6x.h index c364442244..e8a6c6697c 100644 --- a/include/configs/nitrogen6x.h +++ b/include/configs/nitrogen6x.h @@ -65,7 +65,6 @@ #define CONFIG_MXC_USB_FLAGS 0
/* Framebuffer and LCD */ -#define CONFIG_VIDEO_IPUV3 #define CONFIG_VIDEO_BMP_RLE8 #define CONFIG_SPLASH_SCREEN #define CONFIG_SPLASH_SCREEN_ALIGN diff --git a/include/configs/novena.h b/include/configs/novena.h index 25736f3c03..bb5bf808c2 100644 --- a/include/configs/novena.h +++ b/include/configs/novena.h @@ -125,7 +125,6 @@
/* Video output */ #ifdef CONFIG_VIDEO -#define CONFIG_VIDEO_IPUV3 #define CONFIG_VIDEO_BMP_RLE8 #define CONFIG_SPLASH_SCREEN #define CONFIG_BMP_16BPP diff --git a/include/configs/tbs2910.h b/include/configs/tbs2910.h index 2d4b9c9bfe..761be0987b 100644 --- a/include/configs/tbs2910.h +++ b/include/configs/tbs2910.h @@ -58,7 +58,6 @@
/* Framebuffer */ #ifdef CONFIG_VIDEO -#define CONFIG_VIDEO_IPUV3 #define CONFIG_VIDEO_BMP_RLE8 #define CONFIG_IMX_HDMI #define CONFIG_IMX_VIDEO_SKIP diff --git a/include/configs/wandboard.h b/include/configs/wandboard.h index b03a1c550c..e6d1fcacf5 100644 --- a/include/configs/wandboard.h +++ b/include/configs/wandboard.h @@ -65,7 +65,6 @@
u-boot,dm-pre-reloc is required for reserving video memory when binding DM_VIDEO driver.
Signed-off-by: Anatolij Gustschin agust@denx.de --- arch/arm/dts/imx6qdl.dtsi | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/arch/arm/dts/imx6qdl.dtsi b/arch/arm/dts/imx6qdl.dtsi index e4daf15088..c0a9478008 100644 --- a/arch/arm/dts/imx6qdl.dtsi +++ b/arch/arm/dts/imx6qdl.dtsi @@ -145,6 +145,7 @@ compatible = "simple-bus"; interrupt-parent = <&gpc>; ranges; + u-boot,dm-pre-reloc;
dma_apbh: dma-apbh@110000 { compatible = "fsl,imx6q-dma-apbh", "fsl,imx28-dma-apbh"; @@ -1261,6 +1262,7 @@ <&clks IMX6QDL_CLK_IPU1_DI1>; clock-names = "bus", "di0", "di1"; resets = <&src 2>; + u-boot,dm-pre-reloc;
ipu1_csi0: port@0 { reg = <0>;
u-boot,dm-pre-reloc is required for reserving video memory when binding DM_VIDEO driver. Signed-off-by: Anatolij Gustschin agust@denx.de
Enable DM_VIDEO in defconfig.
Signed-off-by: Anatolij Gustschin agust@denx.de --- configs/apalis_imx6_defconfig | 3 ++- 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/configs/apalis_imx6_defconfig b/configs/apalis_imx6_defconfig index 60ca8a5147..06695208bc 100644 --- a/configs/apalis_imx6_defconfig +++ b/configs/apalis_imx6_defconfig @@ -81,7 +81,8 @@ CONFIG_USB_GADGET_PRODUCT_NUM=0x4000 CONFIG_CI_UDC=y CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_USB_HOST_ETHER=y -CONFIG_VIDEO=y +CONFIG_DM_VIDEO=y +CONFIG_SYS_WHITE_ON_BLACK=y CONFIG_VIDEO_IPUV3=y CONFIG_FAT_WRITE=y CONFIG_OF_LIBFDT_OVERLAY=y
Enable DM_VIDEO in defconfig. Signed-off-by: Anatolij Gustschin agust@denx.de
Enable DM_VIDEO in defconfigs.
Signed-off-by: Anatolij Gustschin agust@denx.de --- configs/imx6dl_icore_nand_defconfig | 2 +- configs/imx6q_icore_nand_defconfig | 2 +- configs/imx6qdl_icore_mmc_defconfig | 2 +- configs/imx6qdl_icore_nand_defconfig | 2 +- 4 files changed, 4 insertions(+), 4 deletions(-)
diff --git a/configs/imx6dl_icore_nand_defconfig b/configs/imx6dl_icore_nand_defconfig index c34c515080..d81f00faec 100644 --- a/configs/imx6dl_icore_nand_defconfig +++ b/configs/imx6dl_icore_nand_defconfig @@ -49,5 +49,5 @@ CONFIG_PINCTRL=y CONFIG_PINCTRL_IMX6=y CONFIG_MXC_UART=y CONFIG_IMX_THERMAL=y -CONFIG_VIDEO=y +CONFIG_DM_VIDEO=y CONFIG_VIDEO_IPUV3=y diff --git a/configs/imx6q_icore_nand_defconfig b/configs/imx6q_icore_nand_defconfig index cf149d615b..8702426561 100644 --- a/configs/imx6q_icore_nand_defconfig +++ b/configs/imx6q_icore_nand_defconfig @@ -50,5 +50,5 @@ CONFIG_PINCTRL=y CONFIG_PINCTRL_IMX6=y CONFIG_MXC_UART=y CONFIG_IMX_THERMAL=y -CONFIG_VIDEO=y +CONFIG_DM_VIDEO=y CONFIG_VIDEO_IPUV3=y diff --git a/configs/imx6qdl_icore_mmc_defconfig b/configs/imx6qdl_icore_mmc_defconfig index 68ad1c6d20..a8b0c6ef49 100644 --- a/configs/imx6qdl_icore_mmc_defconfig +++ b/configs/imx6qdl_icore_mmc_defconfig @@ -67,5 +67,5 @@ CONFIG_PINCTRL_IMX6=y CONFIG_DEBUG_UART_MXC=y CONFIG_MXC_UART=y CONFIG_IMX_THERMAL=y -CONFIG_VIDEO=y +CONFIG_DM_VIDEO=y CONFIG_VIDEO_IPUV3=y diff --git a/configs/imx6qdl_icore_nand_defconfig b/configs/imx6qdl_icore_nand_defconfig index cf149d615b..8702426561 100644 --- a/configs/imx6qdl_icore_nand_defconfig +++ b/configs/imx6qdl_icore_nand_defconfig @@ -50,5 +50,5 @@ CONFIG_PINCTRL=y CONFIG_PINCTRL_IMX6=y CONFIG_MXC_UART=y CONFIG_IMX_THERMAL=y -CONFIG_VIDEO=y +CONFIG_DM_VIDEO=y CONFIG_VIDEO_IPUV3=y
Enable DM_VIDEO in defconfigs. Signed-off-by: Anatolij Gustschin agust@denx.de
Signed-off-by: Anatolij Gustschin agust@denx.de --- configs/ge_bx50v3_defconfig | 2 +- include/configs/ge_bx50v3.h | 2 -- 2 files changed, 1 insertion(+), 3 deletions(-)
diff --git a/configs/ge_bx50v3_defconfig b/configs/ge_bx50v3_defconfig index 91782b06a8..da8a5ee28d 100644 --- a/configs/ge_bx50v3_defconfig +++ b/configs/ge_bx50v3_defconfig @@ -60,5 +60,5 @@ CONFIG_DM_GPIO=y CONFIG_DM_SPI=y CONFIG_DM_SPI_FLASH=y CONFIG_OF_BOARD_SETUP=y -CONFIG_VIDEO=y +CONFIG_DM_VIDEO=y CONFIG_VIDEO_IPUV3=y diff --git a/include/configs/ge_bx50v3.h b/include/configs/ge_bx50v3.h index cc6a4f9bac..8762d7e095 100644 --- a/include/configs/ge_bx50v3.h +++ b/include/configs/ge_bx50v3.h @@ -208,12 +208,10 @@ #define CONFIG_SYS_FSL_USDHC_NUM 3
/* Framebuffer */ -#ifdef CONFIG_VIDEO #define CONFIG_HIDE_LOGO_VERSION #define CONFIG_IMX_HDMI #define CONFIG_IMX_VIDEO_SKIP #define CONFIG_CMD_BMP -#endif
#define CONFIG_PWM_IMX #define CONFIG_IMX6_PWM_PER_CLK 66000000
Signed-off-by: Anatolij Gustschin agust@denx.de --- configs/colibri_imx6_defconfig | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/configs/colibri_imx6_defconfig b/configs/colibri_imx6_defconfig index 611f9f0950..bf05c68807 100644 --- a/configs/colibri_imx6_defconfig +++ b/configs/colibri_imx6_defconfig @@ -77,7 +77,7 @@ CONFIG_USB_GADGET_PRODUCT_NUM=0x4000 CONFIG_CI_UDC=y CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_USB_HOST_ETHER=y -CONFIG_VIDEO=y +CONFIG_DM_VIDEO=y CONFIG_VIDEO_IPUV3=y CONFIG_FAT_WRITE=y CONFIG_OF_LIBFDT_OVERLAY=y
Signed-off-by: Anatolij Gustschin agust@denx.de --- configs/mx6sabresd_defconfig | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/configs/mx6sabresd_defconfig b/configs/mx6sabresd_defconfig index ea34217e1c..825218c0d6 100644 --- a/configs/mx6sabresd_defconfig +++ b/configs/mx6sabresd_defconfig @@ -93,6 +93,6 @@ CONFIG_USB_GADGET_PRODUCT_NUM=0xa4a5 CONFIG_CI_UDC=y CONFIG_USB_HOST_ETHER=y CONFIG_USB_ETHER_ASIX=y -CONFIG_VIDEO=y +CONFIG_DM_VIDEO=y CONFIG_VIDEO_IPUV3=y # CONFIG_VIDEO_SW_CURSOR is not set
Hi Anatolij,
I am running the latest tree from Stefano and I do not have LVDS output after this patch.
If I revert it, then LVDS output is normal again.
Any ideas?
Thanks
Hi Fabio,
On Mon, 16 Sep 2019 15:18:34 -0300 Fabio Estevam festevam@gmail.com wrote: ...
Any ideas?
Most probably this is because there was no user of the video device when booting and therefore the video driver was not probed/bound. Please try do display some bitmap with bmp command or try to switch to the video console by command "setenv stdout vidconsole0". Then, the video device will be probed and you should see the LVDS output.
-- Anatolij
Hi Fabio,
On Mon, 16 Sep 2019 21:21:38 +0200 Anatolij Gustschin agust@denx.de wrote:
Hi Fabio,
Any ideas?
There is an example how boards can enforce using video device when booting, e.g. for displaying splash image. Please see commit f0be8ff45fb8 (ARM: imx: m53menlo: Convert to DM VIDEO).
I'm not happy that it requires to extend the board code for this and would prefer if it could be in common code. But this is what we have now.
-- Anatolij
Hi Anatolij,
Here is what I tried:
=> setenv stdout vidconsole0 ## Error inserting "stdout" variable, errno=22
Then I see garbage on the LVDS panel.
Any ideas as to why setting "stdout" failed?
Thanks
Hi Fabio,
On Tue, 17 Sep 2019 09:32:37 -0300 Fabio Estevam festevam@gmail.com wrote:
Hi Anatolij,
Does "setenv stdout vidconsole" work? I think I've suggested wrong command, sorry. "vidconsole0" is the driver instance name for the first video console, "vidconsole" is the correct name for console device on framebuffer.
-- Anatolij
Signed-off-by: Anatolij Gustschin agust@denx.de --- configs/mx6sabreauto_defconfig | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/configs/mx6sabreauto_defconfig b/configs/mx6sabreauto_defconfig index e52ad368d2..bcb3f314b1 100644 --- a/configs/mx6sabreauto_defconfig +++ b/configs/mx6sabreauto_defconfig @@ -82,6 +82,6 @@ CONFIG_CI_UDC=y CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_USB_HOST_ETHER=y CONFIG_USB_ETHER_ASIX=y -CONFIG_VIDEO=y +CONFIG_DM_VIDEO=y CONFIG_VIDEO_IPUV3=y # CONFIG_VIDEO_SW_CURSOR is not set
Add device trees from Linux in preparation for driver model conversions.
Signed-off-by: Anatolij Gustschin agust@denx.de --- arch/arm/dts/imx6dl-wandboard-revb1.dts | 18 ++ arch/arm/dts/imx6qdl-wandboard-revb1.dtsi | 41 ++++ arch/arm/dts/imx6qdl-wandboard.dtsi | 279 ++++++++++++++++++++++ board/wandboard/MAINTAINERS | 3 + configs/wandboard_defconfig | 3 +- 5 files changed, 343 insertions(+), 1 deletion(-) create mode 100644 arch/arm/dts/imx6dl-wandboard-revb1.dts create mode 100644 arch/arm/dts/imx6qdl-wandboard-revb1.dtsi create mode 100644 arch/arm/dts/imx6qdl-wandboard.dtsi
diff --git a/arch/arm/dts/imx6dl-wandboard-revb1.dts b/arch/arm/dts/imx6dl-wandboard-revb1.dts new file mode 100644 index 0000000000..738db4fc77 --- /dev/null +++ b/arch/arm/dts/imx6dl-wandboard-revb1.dts @@ -0,0 +1,18 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright 2013 Freescale Semiconductor, Inc. + * + * Author: Fabio Estevam fabio.estevam@freescale.com + */ +/dts-v1/; +#include "imx6dl.dtsi" +#include "imx6qdl-wandboard-revb1.dtsi" + +/ { + model = "Wandboard i.MX6 Dual Lite Board rev B1"; + compatible = "wand,imx6dl-wandboard", "fsl,imx6dl"; + + memory@10000000 { + reg = <0x10000000 0x40000000>; + }; +}; diff --git a/arch/arm/dts/imx6qdl-wandboard-revb1.dtsi b/arch/arm/dts/imx6qdl-wandboard-revb1.dtsi new file mode 100644 index 0000000000..855dc6f9df --- /dev/null +++ b/arch/arm/dts/imx6qdl-wandboard-revb1.dtsi @@ -0,0 +1,41 @@ +/* + * Copyright 2013 Freescale Semiconductor, Inc. + * + * Author: Fabio Estevam fabio.estevam@freescale.com + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License version 2 as + * published by the Free Software Foundation. + * + */ + +#include "imx6qdl-wandboard.dtsi" + +&iomuxc { + pinctrl-0 = <&pinctrl_hog>; + + imx6qdl-wandboard { + pinctrl_hog: hoggrp { + fsl,pins = < + MX6QDL_PAD_GPIO_2__GPIO1_IO02 0x80000000 /* uSDHC1 CD */ + MX6QDL_PAD_EIM_DA9__GPIO3_IO09 0x80000000 /* uSDHC3 CD */ + MX6QDL_PAD_EIM_EB1__GPIO2_IO29 0x0f0b0 /* WL_REF_ON */ + MX6QDL_PAD_EIM_A25__GPIO5_IO02 0x0f0b0 /* WL_RST_N */ + MX6QDL_PAD_ENET_RXD1__GPIO1_IO26 0x000b0 /* WL_REG_ON */ + MX6QDL_PAD_ENET_TXD1__GPIO1_IO29 0x80000000 /* WL_HOST_WAKE */ + MX6QDL_PAD_ENET_TXD0__GPIO1_IO30 0x80000000 /* WL_WAKE */ + MX6QDL_PAD_EIM_D29__GPIO3_IO29 0x80000000 /* RGMII_nRST */ + MX6QDL_PAD_EIM_DA13__GPIO3_IO13 0x80000000 /* BT_ON */ + MX6QDL_PAD_EIM_DA14__GPIO3_IO14 0x80000000 /* BT_WAKE */ + MX6QDL_PAD_EIM_DA15__GPIO3_IO15 0x80000000 /* BT_HOST_WAKE */ + >; + }; + }; +}; + +&usdhc2 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_usdhc2>; + non-removable; + status = "okay"; +}; diff --git a/arch/arm/dts/imx6qdl-wandboard.dtsi b/arch/arm/dts/imx6qdl-wandboard.dtsi new file mode 100644 index 0000000000..381bf61fcd --- /dev/null +++ b/arch/arm/dts/imx6qdl-wandboard.dtsi @@ -0,0 +1,279 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright 2013 Freescale Semiconductor, Inc. + * + * Author: Fabio Estevam fabio.estevam@freescale.com + */ + +#include <dt-bindings/gpio/gpio.h> + +/ { + sound { + compatible = "fsl,imx6-wandboard-sgtl5000", + "fsl,imx-audio-sgtl5000"; + model = "imx6-wandboard-sgtl5000"; + ssi-controller = <&ssi1>; + audio-codec = <&codec>; + audio-routing = + "MIC_IN", "Mic Jack", + "Mic Jack", "Mic Bias", + "Headphone Jack", "HP_OUT"; + mux-int-port = <1>; + mux-ext-port = <3>; + }; + + sound-spdif { + compatible = "fsl,imx-audio-spdif"; + model = "imx-spdif"; + spdif-controller = <&spdif>; + spdif-out; + }; + + reg_2p5v: regulator-2p5v { + compatible = "regulator-fixed"; + regulator-name = "2P5V"; + regulator-min-microvolt = <2500000>; + regulator-max-microvolt = <2500000>; + regulator-always-on; + }; + + reg_3p3v: regulator-3p3v { + compatible = "regulator-fixed"; + regulator-name = "3P3V"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-always-on; + }; + + reg_usb_otg_vbus: regulator-usbotgvbus { + compatible = "regulator-fixed"; + regulator-name = "usb_otg_vbus"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_usbotgvbus>; + gpio = <&gpio3 22 GPIO_ACTIVE_LOW>; + }; +}; + +&audmux { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_audmux>; + status = "okay"; +}; + +&hdmi { + ddc-i2c-bus = <&i2c1>; + status = "okay"; +}; + +&i2c1 { + clock-frequency = <100000>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c1>; + status = "okay"; +}; + +&i2c2 { + clock-frequency = <100000>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c2>; + status = "okay"; + + codec: sgtl5000@a { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_mclk>; + compatible = "fsl,sgtl5000"; + reg = <0x0a>; + clocks = <&clks IMX6QDL_CLK_CKO>; + VDDA-supply = <®_2p5v>; + VDDIO-supply = <®_3p3v>; + lrclk-strength = <3>; + }; +}; + +&iomuxc { + pinctrl-names = "default"; + + imx6qdl-wandboard { + + pinctrl_audmux: audmuxgrp { + fsl,pins = < + MX6QDL_PAD_CSI0_DAT7__AUD3_RXD 0x130b0 + MX6QDL_PAD_CSI0_DAT4__AUD3_TXC 0x130b0 + MX6QDL_PAD_CSI0_DAT5__AUD3_TXD 0x110b0 + MX6QDL_PAD_CSI0_DAT6__AUD3_TXFS 0x130b0 + >; + }; + + pinctrl_enet: enetgrp { + fsl,pins = < + MX6QDL_PAD_ENET_MDIO__ENET_MDIO 0x1b0b0 + MX6QDL_PAD_ENET_MDC__ENET_MDC 0x1b0b0 + MX6QDL_PAD_RGMII_TXC__RGMII_TXC 0x1b030 + MX6QDL_PAD_RGMII_TD0__RGMII_TD0 0x1b030 + MX6QDL_PAD_RGMII_TD1__RGMII_TD1 0x1b030 + MX6QDL_PAD_RGMII_TD2__RGMII_TD2 0x1b030 + MX6QDL_PAD_RGMII_TD3__RGMII_TD3 0x1b030 + MX6QDL_PAD_RGMII_TX_CTL__RGMII_TX_CTL 0x1b030 + MX6QDL_PAD_ENET_REF_CLK__ENET_TX_CLK 0x1b0b0 + MX6QDL_PAD_RGMII_RXC__RGMII_RXC 0x1b030 + MX6QDL_PAD_RGMII_RD0__RGMII_RD0 0x1b030 + MX6QDL_PAD_RGMII_RD1__RGMII_RD1 0x1b030 + MX6QDL_PAD_RGMII_RD2__RGMII_RD2 0x1b030 + MX6QDL_PAD_RGMII_RD3__RGMII_RD3 0x1b030 + MX6QDL_PAD_RGMII_RX_CTL__RGMII_RX_CTL 0x1b030 + MX6QDL_PAD_GPIO_16__ENET_REF_CLK 0x4001b0a8 + MX6QDL_PAD_GPIO_6__ENET_IRQ 0x000b1 + >; + }; + + pinctrl_i2c1: i2c1grp { + fsl,pins = < + MX6QDL_PAD_EIM_D21__I2C1_SCL 0x4001b8b1 + MX6QDL_PAD_EIM_D28__I2C1_SDA 0x4001b8b1 + >; + }; + + pinctrl_i2c2: i2c2grp { + fsl,pins = < + MX6QDL_PAD_KEY_COL3__I2C2_SCL 0x4001b8b1 + MX6QDL_PAD_KEY_ROW3__I2C2_SDA 0x4001b8b1 + >; + }; + + pinctrl_mclk: mclkgrp { + fsl,pins = < + MX6QDL_PAD_GPIO_0__CCM_CLKO1 0x130b0 + >; + }; + + pinctrl_spdif: spdifgrp { + fsl,pins = < + MX6QDL_PAD_ENET_RXD0__SPDIF_OUT 0x1b0b0 + >; + }; + + pinctrl_uart1: uart1grp { + fsl,pins = < + MX6QDL_PAD_CSI0_DAT10__UART1_TX_DATA 0x1b0b1 + MX6QDL_PAD_CSI0_DAT11__UART1_RX_DATA 0x1b0b1 + >; + }; + + pinctrl_uart3: uart3grp { + fsl,pins = < + MX6QDL_PAD_EIM_D24__UART3_TX_DATA 0x1b0b1 + MX6QDL_PAD_EIM_D25__UART3_RX_DATA 0x1b0b1 + MX6QDL_PAD_EIM_D23__UART3_CTS_B 0x1b0b1 + MX6QDL_PAD_EIM_EB3__UART3_RTS_B 0x1b0b1 + >; + }; + + pinctrl_usbotg: usbotggrp { + fsl,pins = < + MX6QDL_PAD_GPIO_1__USB_OTG_ID 0x17059 + >; + }; + + pinctrl_usbotgvbus: usbotgvbusgrp { + fsl,pins = < + MX6QDL_PAD_EIM_D22__GPIO3_IO22 0x130b0 + >; + }; + + pinctrl_usdhc1: usdhc1grp { + fsl,pins = < + MX6QDL_PAD_SD1_CMD__SD1_CMD 0x17059 + MX6QDL_PAD_SD1_CLK__SD1_CLK 0x10059 + MX6QDL_PAD_SD1_DAT0__SD1_DATA0 0x17059 + MX6QDL_PAD_SD1_DAT1__SD1_DATA1 0x17059 + MX6QDL_PAD_SD1_DAT2__SD1_DATA2 0x17059 + MX6QDL_PAD_SD1_DAT3__SD1_DATA3 0x17059 + >; + }; + + pinctrl_usdhc2: usdhc2grp { + fsl,pins = < + MX6QDL_PAD_SD2_CMD__SD2_CMD 0x17059 + MX6QDL_PAD_SD2_CLK__SD2_CLK 0x10059 + MX6QDL_PAD_SD2_DAT0__SD2_DATA0 0x17059 + MX6QDL_PAD_SD2_DAT1__SD2_DATA1 0x17059 + MX6QDL_PAD_SD2_DAT2__SD2_DATA2 0x17059 + MX6QDL_PAD_SD2_DAT3__SD2_DATA3 0x17059 + >; + }; + + pinctrl_usdhc3: usdhc3grp { + fsl,pins = < + MX6QDL_PAD_SD3_CMD__SD3_CMD 0x17059 + MX6QDL_PAD_SD3_CLK__SD3_CLK 0x10059 + MX6QDL_PAD_SD3_DAT0__SD3_DATA0 0x17059 + MX6QDL_PAD_SD3_DAT1__SD3_DATA1 0x17059 + MX6QDL_PAD_SD3_DAT2__SD3_DATA2 0x17059 + MX6QDL_PAD_SD3_DAT3__SD3_DATA3 0x17059 + >; + }; + }; +}; + +&fec { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_enet>; + phy-mode = "rgmii"; + phy-reset-gpios = <&gpio3 29 GPIO_ACTIVE_LOW>; + interrupts-extended = <&gpio1 6 IRQ_TYPE_LEVEL_HIGH>, + <&intc 0 119 IRQ_TYPE_LEVEL_HIGH>; + fsl,err006687-workaround-present; + status = "okay"; +}; + +&spdif { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_spdif>; + status = "okay"; +}; + +&ssi1 { + status = "okay"; +}; + +&uart1 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_uart1>; + status = "okay"; +}; + +&uart3 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_uart3>; + uart-has-rtscts; + status = "okay"; +}; + +&usbh1 { + status = "okay"; +}; + +&usbotg { + vbus-supply = <®_usb_otg_vbus>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_usbotg>; + disable-over-current; + dr_mode = "otg"; + status = "okay"; +}; + +&usdhc1 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_usdhc1>; + cd-gpios = <&gpio1 2 GPIO_ACTIVE_LOW>; + status = "okay"; +}; + +&usdhc3 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_usdhc3>; + cd-gpios = <&gpio3 9 GPIO_ACTIVE_LOW>; + status = "okay"; +}; diff --git a/board/wandboard/MAINTAINERS b/board/wandboard/MAINTAINERS index d7cbae8f95..00a31a9346 100644 --- a/board/wandboard/MAINTAINERS +++ b/board/wandboard/MAINTAINERS @@ -1,6 +1,9 @@ WANDBOARD BOARD M: Fabio Estevam fabio.estevam@nxp.com S: Maintained +F: arch/arm/dts/imx6qdl-wandboard.dtsi +F: arch/arm/dts/imx6qdl-wandboard-revb1.dtsi +F: arch/arm/dts/imx6dl-wandboard-revb1.dts F: board/wandboard/ F: include/configs/wandboard.h F: configs/wandboard_defconfig diff --git a/configs/wandboard_defconfig b/configs/wandboard_defconfig index 9a67e63132..9307ea6c64 100644 --- a/configs/wandboard_defconfig +++ b/configs/wandboard_defconfig @@ -32,6 +32,8 @@ CONFIG_CMD_SATA=y CONFIG_CMD_USB=y CONFIG_CMD_CACHE=y CONFIG_CMD_EXT4_WRITE=y +CONFIG_OF_CONTROL=y +CONFIG_DEFAULT_DEVICE_TREE="imx6dl-wandboard-revb1" CONFIG_ENV_IS_IN_MMC=y CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y CONFIG_DM=y @@ -44,4 +46,3 @@ CONFIG_USB=y CONFIG_VIDEO=y CONFIG_VIDEO_IPUV3=y # CONFIG_VIDEO_SW_CURSOR is not set -CONFIG_OF_LIBFDT=y
Add device trees from Linux in preparation for driver model conversions. Signed-off-by: Anatolij Gustschin agust@denx.de
Enable DM_GPIO and pinctrl in defconfig and add gpio_request() calls where required.
Signed-off-by: Anatolij Gustschin agust@denx.de --- board/wandboard/wandboard.c | 12 ++++++++++++ configs/wandboard_defconfig | 3 +++ 2 files changed, 15 insertions(+)
diff --git a/board/wandboard/wandboard.c b/board/wandboard/wandboard.c index 6af1b45882..e0d5769131 100644 --- a/board/wandboard/wandboard.c +++ b/board/wandboard/wandboard.c @@ -131,12 +131,14 @@ static void setup_iomux_enet(void) if (with_pmic) { SETUP_IOMUX_PADS(enet_ar8035_power_pads); /* enable AR8035 POWER */ + gpio_request(ETH_PHY_AR8035_POWER, "PHY_POWER"); gpio_direction_output(ETH_PHY_AR8035_POWER, 0); } /* wait until 3.3V of PHY and clock become stable */ mdelay(10);
/* Reset AR8031 PHY */ + gpio_request(ETH_PHY_RESET, "PHY_RESET"); gpio_direction_output(ETH_PHY_RESET, 0); mdelay(10); gpio_set_value(ETH_PHY_RESET, 1); @@ -170,6 +172,11 @@ int board_mmc_init(bd_t *bis) int ret; u32 index = 0;
+#if !CONFIG_IS_ENABLED(DM_MMC) + gpio_request(USDHC1_CD_GPIO, "USDHC1_CD"); + gpio_request(USDHC3_CD_GPIO, "USDHC3_CD"); +#endif + /* * Following map is done: * (U-Boot device node) (Physical Port) @@ -356,6 +363,8 @@ static void enable_fwadapt_7wvga(struct display_info_t const *dev) { SETUP_IOMUX_PADS(fwadapt_7wvga_pads);
+ gpio_request(IMX_GPIO_NR(2, 10), "DISP0_BKLEN"); + gpio_request(IMX_GPIO_NR(2, 11), "DISP0_VDDEN"); gpio_direction_output(IMX_GPIO_NR(2, 10), 1); gpio_direction_output(IMX_GPIO_NR(2, 11), 1); } @@ -418,6 +427,7 @@ static void setup_display(void)
/* Disable LCD backlight */ SETUP_IOMUX_PAD(PAD_DI0_PIN4__GPIO4_IO20); + gpio_request(IMX_GPIO_NR(4, 20), "LCD_BKLEN"); gpio_direction_input(IMX_GPIO_NR(4, 20)); } #endif /* CONFIG_VIDEO_IPUV3 */ @@ -548,6 +558,8 @@ int board_init(void)
int checkboard(void) { + gpio_request(REV_DETECTION, "REV_DETECT"); + if (is_revd1()) puts("Board: Wandboard rev D1\n"); else if (is_revc1()) diff --git a/configs/wandboard_defconfig b/configs/wandboard_defconfig index 9307ea6c64..11cf4415ae 100644 --- a/configs/wandboard_defconfig +++ b/configs/wandboard_defconfig @@ -38,9 +38,12 @@ CONFIG_ENV_IS_IN_MMC=y CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y CONFIG_DM=y CONFIG_DWC_AHSATA=y +CONFIG_DM_GPIO=y CONFIG_FSL_ESDHC=y CONFIG_PHYLIB=y CONFIG_MII=y +CONFIG_PINCTRL=y +CONFIG_PINCTRL_IMX6=y CONFIG_DM_THERMAL=y CONFIG_USB=y CONFIG_VIDEO=y
Enable DM_GPIO and pinctrl in defconfig and add gpio_request() calls where required. Signed-off-by: Anatolij Gustschin agust@denx.de
Drop CONFIG_USB_MAX_CONTROLLER_COUNT and enable DM_USB in defconfig.
Signed-off-by: Anatolij Gustschin agust@denx.de --- configs/wandboard_defconfig | 1 + include/configs/wandboard.h | 1 - 2 files changed, 1 insertion(+), 1 deletion(-)
diff --git a/configs/wandboard_defconfig b/configs/wandboard_defconfig index 11cf4415ae..9e13d7f67c 100644 --- a/configs/wandboard_defconfig +++ b/configs/wandboard_defconfig @@ -46,6 +46,7 @@ CONFIG_PINCTRL=y CONFIG_PINCTRL_IMX6=y CONFIG_DM_THERMAL=y CONFIG_USB=y +CONFIG_DM_USB=y CONFIG_VIDEO=y CONFIG_VIDEO_IPUV3=y # CONFIG_VIDEO_SW_CURSOR is not set diff --git a/include/configs/wandboard.h b/include/configs/wandboard.h index e6d1fcacf5..e01e3e3669 100644 --- a/include/configs/wandboard.h +++ b/include/configs/wandboard.h @@ -51,7 +51,6 @@ #define CONFIG_SYS_FSL_ESDHC_ADDR 0
/* USB Configs */ -#define CONFIG_USB_MAX_CONTROLLER_COUNT 2 #define CONFIG_MXC_USB_PORTSC (PORT_PTS_UTMI | PORT_PTS_PTW) #define CONFIG_MXC_USB_FLAGS 0
Drop CONFIG_USB_MAX_CONTROLLER_COUNT and enable DM_USB in defconfig. Signed-off-by: Anatolij Gustschin agust@denx.de
Signed-off-by: Anatolij Gustschin agust@denx.de --- configs/wandboard_defconfig | 2 +- include/configs/wandboard.h | 2 -- 2 files changed, 1 insertion(+), 3 deletions(-)
diff --git a/configs/wandboard_defconfig b/configs/wandboard_defconfig index 9e13d7f67c..c4018cce4a 100644 --- a/configs/wandboard_defconfig +++ b/configs/wandboard_defconfig @@ -47,6 +47,6 @@ CONFIG_PINCTRL_IMX6=y CONFIG_DM_THERMAL=y CONFIG_USB=y CONFIG_DM_USB=y -CONFIG_VIDEO=y +CONFIG_DM_VIDEO=y CONFIG_VIDEO_IPUV3=y # CONFIG_VIDEO_SW_CURSOR is not set diff --git a/include/configs/wandboard.h b/include/configs/wandboard.h index e01e3e3669..13a9fd2450 100644 --- a/include/configs/wandboard.h +++ b/include/configs/wandboard.h @@ -63,7 +63,6 @@ #define CONFIG_PHY_ATHEROS
/* Framebuffer */ -#ifdef CONFIG_VIDEO #define CONFIG_VIDEO_BMP_RLE8 #define CONFIG_SPLASH_SCREEN #define CONFIG_SPLASH_SCREEN_ALIGN @@ -72,7 +71,6 @@ #define CONFIG_VIDEO_BMP_LOGO #define CONFIG_IMX_HDMI #define CONFIG_IMX_VIDEO_SKIP -#endif
#define CONFIG_EXTRA_ENV_SETTINGS \ "console=ttymxc0\0" \
Enable DM_PMIC_PFUZE100 driver and add PMIC description to DTS. Rework power_init_board() code.
Signed-off-by: Anatolij Gustschin agust@denx.de --- arch/arm/dts/imx6qdl-wandboard.dtsi | 101 ++++++++++++++++++++++++++++ board/wandboard/wandboard.c | 38 ++++++----- configs/wandboard_defconfig | 2 + include/configs/wandboard.h | 6 -- 4 files changed, 125 insertions(+), 22 deletions(-)
diff --git a/arch/arm/dts/imx6qdl-wandboard.dtsi b/arch/arm/dts/imx6qdl-wandboard.dtsi index 381bf61fcd..4d03d49fde 100644 --- a/arch/arm/dts/imx6qdl-wandboard.dtsi +++ b/arch/arm/dts/imx6qdl-wandboard.dtsi @@ -90,6 +90,107 @@ VDDIO-supply = <®_3p3v>; lrclk-strength = <3>; }; + + pmic: pfuze100@8 { + compatible = "fsl,pfuze100"; + reg = <0x08>; + + regulators { + sw1a_reg: sw1ab { + regulator-min-microvolt = <300000>; + regulator-max-microvolt = <1875000>; + regulator-boot-on; + regulator-always-on; + regulator-ramp-delay = <6250>; + }; + + sw1c_reg: sw1c { + regulator-min-microvolt = <300000>; + regulator-max-microvolt = <1875000>; + regulator-boot-on; + regulator-always-on; + regulator-ramp-delay = <6250>; + }; + + sw2_reg: sw2 { + regulator-min-microvolt = <800000>; + regulator-max-microvolt = <3300000>; + regulator-boot-on; + regulator-always-on; + regulator-ramp-delay = <6250>; + }; + + sw3a_reg: sw3a { + regulator-min-microvolt = <400000>; + regulator-max-microvolt = <1975000>; + regulator-boot-on; + regulator-always-on; + }; + + sw3b_reg: sw3b { + regulator-min-microvolt = <400000>; + regulator-max-microvolt = <1975000>; + regulator-boot-on; + regulator-always-on; + }; + + sw4_reg: sw4 { + regulator-min-microvolt = <800000>; + regulator-max-microvolt = <3300000>; + regulator-always-on; + }; + + swbst_reg: swbst { + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5150000>; + }; + + snvs_reg: vsnvs { + regulator-min-microvolt = <1000000>; + regulator-max-microvolt = <3000000>; + regulator-boot-on; + regulator-always-on; + }; + + vref_reg: vrefddr { + regulator-boot-on; + regulator-always-on; + }; + + vgen1_reg: vgen1 { + regulator-min-microvolt = <800000>; + regulator-max-microvolt = <1550000>; + }; + + vgen2_reg: vgen2 { + regulator-min-microvolt = <800000>; + regulator-max-microvolt = <1550000>; + }; + + vgen3_reg: vgen3 { + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3300000>; + }; + + vgen4_reg: vgen4 { + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3300000>; + regulator-always-on; + }; + + vgen5_reg: vgen5 { + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3300000>; + regulator-always-on; + }; + + vgen6_reg: vgen6 { + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3300000>; + regulator-always-on; + }; + }; + }; };
&iomuxc { diff --git a/board/wandboard/wandboard.c b/board/wandboard/wandboard.c index e0d5769131..23589df932 100644 --- a/board/wandboard/wandboard.c +++ b/board/wandboard/wandboard.c @@ -453,24 +453,30 @@ int board_early_init_f(void)
int power_init_board(void) { - struct pmic *p; - u32 reg; - - /* configure PFUZE100 PMIC */ - power_pfuze100_init(PMIC_I2C_BUS); - p = pmic_get("PFUZE100"); - if (p && !pmic_probe(p)) { - pmic_reg_read(p, PFUZE100_DEVICEID, ®); - printf("PMIC: PFUZE100 ID=0x%02x\n", reg); - with_pmic = true; - - /* Set VGEN2 to 1.5V and enable */ - pmic_reg_read(p, PFUZE100_VGEN2VOL, ®); - reg &= ~(LDO_VOL_MASK); - reg |= (LDOA_1_50V | (1 << (LDO_EN))); - pmic_reg_write(p, PFUZE100_VGEN2VOL, reg); + struct udevice *dev; + int reg, ret; + + puts("PMIC: "); + + ret = pmic_get("pfuze100", &dev); + if (ret < 0) { + printf("pmic_get() ret %d\n", ret); + return 0; }
+ reg = pmic_reg_read(dev, PFUZE100_DEVICEID); + if (reg < 0) { + printf("pmic_reg_read() ret %d\n", reg); + return 0; + } + printf("PMIC: PFUZE100 ID=0x%02x\n", reg); + with_pmic = true; + + /* Set VGEN2 to 1.5V and enable */ + reg = pmic_reg_read(dev, PFUZE100_VGEN2VOL); + reg &= ~(LDO_VOL_MASK); + reg |= (LDOA_1_50V | (1 << (LDO_EN))); + pmic_reg_write(dev, PFUZE100_VGEN2VOL, reg); return 0; }
diff --git a/configs/wandboard_defconfig b/configs/wandboard_defconfig index c4018cce4a..63f2639bd3 100644 --- a/configs/wandboard_defconfig +++ b/configs/wandboard_defconfig @@ -44,6 +44,8 @@ CONFIG_PHYLIB=y CONFIG_MII=y CONFIG_PINCTRL=y CONFIG_PINCTRL_IMX6=y +CONFIG_DM_PMIC=y +CONFIG_DM_PMIC_PFUZE100=y CONFIG_DM_THERMAL=y CONFIG_USB=y CONFIG_DM_USB=y diff --git a/include/configs/wandboard.h b/include/configs/wandboard.h index 13a9fd2450..aeb66ad454 100644 --- a/include/configs/wandboard.h +++ b/include/configs/wandboard.h @@ -40,12 +40,6 @@ #define CONFIG_SYS_I2C_MXC_I2C3 /* enable I2C bus 3 */ #define CONFIG_SYS_I2C_SPEED 100000
-/* PMIC */ -#define CONFIG_POWER -#define CONFIG_POWER_I2C -#define CONFIG_POWER_PFUZE100 -#define CONFIG_POWER_PFUZE100_I2C_ADDR 0x08 - /* MMC Configuration */ #define CONFIG_SYS_FSL_USDHC_NUM 2 #define CONFIG_SYS_FSL_ESDHC_ADDR 0
Enable DM_PMIC_PFUZE100 driver and add PMIC description to DTS. Rework power_init_board() code. Signed-off-by: Anatolij Gustschin agust@denx.de
Allow building with DM_I2C enabled.
Signed-off-by: Anatolij Gustschin agust@denx.de --- board/wandboard/wandboard.c | 23 ++++++++++++++++++----- configs/wandboard_defconfig | 5 +++++ include/configs/wandboard.h | 8 -------- 3 files changed, 23 insertions(+), 13 deletions(-)
diff --git a/board/wandboard/wandboard.c b/board/wandboard/wandboard.c index 23589df932..c0902abe38 100644 --- a/board/wandboard/wandboard.c +++ b/board/wandboard/wandboard.c @@ -355,8 +355,21 @@ static void do_enable_hdmi(struct display_info_t const *dev)
static int detect_i2c(struct display_info_t const *dev) { +#ifdef CONFIG_DM_I2C + struct udevice *bus, *udev; + int rc; + + rc = uclass_get_device_by_seq(UCLASS_I2C, dev->bus, &bus); + if (rc) + return rc; + rc = dm_i2c_probe(bus, dev->addr, 0, &udev); + if (rc) + return 0; + return 1; +#else return (0 == i2c_set_bus_num(dev->bus)) && (0 == i2c_probe(dev->addr)); +#endif }
static void enable_fwadapt_7wvga(struct display_info_t const *dev) @@ -547,13 +560,13 @@ int board_init(void) gd->bd->bi_boot_params = PHYS_SDRAM + 0x100;
#if defined(CONFIG_VIDEO_IPUV3) - setup_i2c(1, CONFIG_SYS_I2C_SPEED, 0x7f, &mx6dl_i2c2_pad_info); + setup_i2c(1, CONFIG_SYS_MXC_I2C1_SPEED, 0x7f, &mx6dl_i2c2_pad_info); if (is_mx6dq() || is_mx6dqp()) { - setup_i2c(1, CONFIG_SYS_I2C_SPEED, 0x7f, &mx6q_i2c2_pad_info); - setup_i2c(2, CONFIG_SYS_I2C_SPEED, 0x7f, &mx6q_i2c3_pad_info); + setup_i2c(1, CONFIG_SYS_MXC_I2C1_SPEED, 0x7f, &mx6q_i2c2_pad_info); + setup_i2c(2, CONFIG_SYS_MXC_I2C2_SPEED, 0x7f, &mx6q_i2c3_pad_info); } else { - setup_i2c(1, CONFIG_SYS_I2C_SPEED, 0x7f, &mx6dl_i2c2_pad_info); - setup_i2c(2, CONFIG_SYS_I2C_SPEED, 0x7f, &mx6dl_i2c3_pad_info); + setup_i2c(1, CONFIG_SYS_MXC_I2C1_SPEED, 0x7f, &mx6dl_i2c2_pad_info); + setup_i2c(2, CONFIG_SYS_MXC_I2C2_SPEED, 0x7f, &mx6dl_i2c3_pad_info); }
setup_display(); diff --git a/configs/wandboard_defconfig b/configs/wandboard_defconfig index 63f2639bd3..9d9fbffbbd 100644 --- a/configs/wandboard_defconfig +++ b/configs/wandboard_defconfig @@ -39,6 +39,11 @@ CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y CONFIG_DM=y CONFIG_DWC_AHSATA=y CONFIG_DM_GPIO=y +CONFIG_DM_I2C=y +CONFIG_SYS_I2C_MXC=y +CONFIG_SYS_I2C_MXC_I2C1=y +CONFIG_SYS_I2C_MXC_I2C2=y +CONFIG_SYS_I2C_MXC_I2C3=y CONFIG_FSL_ESDHC=y CONFIG_PHYLIB=y CONFIG_MII=y diff --git a/include/configs/wandboard.h b/include/configs/wandboard.h index aeb66ad454..2e6262f0f4 100644 --- a/include/configs/wandboard.h +++ b/include/configs/wandboard.h @@ -32,14 +32,6 @@ #define CONFIG_SYS_MEMTEST_START 0x10000000 #define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_MEMTEST_START + 500 * SZ_1M)
-/* I2C Configs */ -#define CONFIG_SYS_I2C -#define CONFIG_SYS_I2C_MXC -#define CONFIG_SYS_I2C_MXC_I2C1 /* enable I2C bus 1 */ -#define CONFIG_SYS_I2C_MXC_I2C2 /* enable I2C bus 2 */ -#define CONFIG_SYS_I2C_MXC_I2C3 /* enable I2C bus 3 */ -#define CONFIG_SYS_I2C_SPEED 100000 - /* MMC Configuration */ #define CONFIG_SYS_FSL_USDHC_NUM 2 #define CONFIG_SYS_FSL_ESDHC_ADDR 0
Allow building with DM_I2C enabled. Signed-off-by: Anatolij Gustschin agust@denx.de
Move SDHC init to SPL code since it is not required with DM_MMC. Enable DM_MMC support.
Signed-off-by: Anatolij Gustschin agust@denx.de --- board/wandboard/spl.c | 92 +++++++++++++++++++++++++++++++++++ board/wandboard/wandboard.c | 97 ------------------------------------- configs/wandboard_defconfig | 1 + 3 files changed, 93 insertions(+), 97 deletions(-)
diff --git a/board/wandboard/spl.c b/board/wandboard/spl.c index 9c3350019c..000cb109fc 100644 --- a/board/wandboard/spl.c +++ b/board/wandboard/spl.c @@ -422,4 +422,96 @@ void board_init_f(ulong dummy) /* DDR initialization */ spl_dram_init(); } + +#define USDHC1_CD_GPIO IMX_GPIO_NR(1, 2) +#define USDHC3_CD_GPIO IMX_GPIO_NR(3, 9) + +#define USDHC_PAD_CTRL (PAD_CTL_PUS_47K_UP | \ + PAD_CTL_SPEED_LOW | PAD_CTL_DSE_80ohm | \ + PAD_CTL_SRE_FAST | PAD_CTL_HYS) + +static struct fsl_esdhc_cfg usdhc_cfg[2] = { + {USDHC3_BASE_ADDR}, + {USDHC1_BASE_ADDR}, +}; + +static iomux_v3_cfg_t const usdhc1_pads[] = { + IOMUX_PADS(PAD_SD1_CLK__SD1_CLK | MUX_PAD_CTRL(USDHC_PAD_CTRL)), + IOMUX_PADS(PAD_SD1_CMD__SD1_CMD | MUX_PAD_CTRL(USDHC_PAD_CTRL)), + IOMUX_PADS(PAD_SD1_DAT0__SD1_DATA0 | MUX_PAD_CTRL(USDHC_PAD_CTRL)), + IOMUX_PADS(PAD_SD1_DAT1__SD1_DATA1 | MUX_PAD_CTRL(USDHC_PAD_CTRL)), + IOMUX_PADS(PAD_SD1_DAT2__SD1_DATA2 | MUX_PAD_CTRL(USDHC_PAD_CTRL)), + IOMUX_PADS(PAD_SD1_DAT3__SD1_DATA3 | MUX_PAD_CTRL(USDHC_PAD_CTRL)), + /* Carrier MicroSD Card Detect */ + IOMUX_PADS(PAD_GPIO_2__GPIO1_IO02 | MUX_PAD_CTRL(NO_PAD_CTRL)), +}; + +static iomux_v3_cfg_t const usdhc3_pads[] = { + IOMUX_PADS(PAD_SD3_CLK__SD3_CLK | MUX_PAD_CTRL(USDHC_PAD_CTRL)), + IOMUX_PADS(PAD_SD3_CMD__SD3_CMD | MUX_PAD_CTRL(USDHC_PAD_CTRL)), + IOMUX_PADS(PAD_SD3_DAT0__SD3_DATA0 | MUX_PAD_CTRL(USDHC_PAD_CTRL)), + IOMUX_PADS(PAD_SD3_DAT1__SD3_DATA1 | MUX_PAD_CTRL(USDHC_PAD_CTRL)), + IOMUX_PADS(PAD_SD3_DAT2__SD3_DATA2 | MUX_PAD_CTRL(USDHC_PAD_CTRL)), + IOMUX_PADS(PAD_SD3_DAT3__SD3_DATA3 | MUX_PAD_CTRL(USDHC_PAD_CTRL)), + /* SOM MicroSD Card Detect */ + IOMUX_PADS(PAD_EIM_DA9__GPIO3_IO09 | MUX_PAD_CTRL(NO_PAD_CTRL)), +}; + +int board_mmc_getcd(struct mmc *mmc) +{ + struct fsl_esdhc_cfg *cfg = (struct fsl_esdhc_cfg *)mmc->priv; + int ret = 0; + + switch (cfg->esdhc_base) { + case USDHC1_BASE_ADDR: + ret = !gpio_get_value(USDHC1_CD_GPIO); + break; + case USDHC3_BASE_ADDR: + ret = !gpio_get_value(USDHC3_CD_GPIO); + break; + } + + return ret; +} + +int board_mmc_init(bd_t *bis) +{ + int ret; + u32 index = 0; + + /* + * Following map is done: + * (U-Boot device node) (Physical Port) + * mmc0 SOM MicroSD + * mmc1 Carrier board MicroSD + */ + for (index = 0; index < CONFIG_SYS_FSL_USDHC_NUM; ++index) { + switch (index) { + case 0: + SETUP_IOMUX_PADS(usdhc3_pads); + usdhc_cfg[0].sdhc_clk = mxc_get_clock(MXC_ESDHC3_CLK); + usdhc_cfg[0].max_bus_width = 4; + gpio_direction_input(USDHC3_CD_GPIO); + break; + case 1: + SETUP_IOMUX_PADS(usdhc1_pads); + usdhc_cfg[1].sdhc_clk = mxc_get_clock(MXC_ESDHC_CLK); + usdhc_cfg[1].max_bus_width = 4; + gpio_direction_input(USDHC1_CD_GPIO); + break; + default: + printf("Warning: you configured more USDHC controllers" + "(%d) then supported by the board (%d)\n", + index + 1, CONFIG_SYS_FSL_USDHC_NUM); + return -EINVAL; + } + + ret = fsl_esdhc_initialize(bis, &usdhc_cfg[index]); + if (ret) + return ret; + } + + return 0; +} + #endif diff --git a/board/wandboard/wandboard.c b/board/wandboard/wandboard.c index c0902abe38..69fbc8b690 100644 --- a/board/wandboard/wandboard.c +++ b/board/wandboard/wandboard.c @@ -22,8 +22,6 @@ #include <asm/io.h> #include <linux/sizes.h> #include <common.h> -#include <fsl_esdhc.h> -#include <mmc.h> #include <miiphy.h> #include <netdev.h> #include <phy.h> @@ -37,10 +35,6 @@ DECLARE_GLOBAL_DATA_PTR; PAD_CTL_SPEED_MED | PAD_CTL_DSE_40ohm | \ PAD_CTL_SRE_FAST | PAD_CTL_HYS)
-#define USDHC_PAD_CTRL (PAD_CTL_PUS_47K_UP | \ - PAD_CTL_SPEED_LOW | PAD_CTL_DSE_80ohm | \ - PAD_CTL_SRE_FAST | PAD_CTL_HYS) - #define ENET_PAD_CTRL (PAD_CTL_PUS_100K_UP | \ PAD_CTL_SPEED_MED | PAD_CTL_DSE_40ohm | PAD_CTL_HYS)
@@ -48,8 +42,6 @@ DECLARE_GLOBAL_DATA_PTR; PAD_CTL_SPEED_MED | PAD_CTL_DSE_40ohm | PAD_CTL_HYS | \ PAD_CTL_ODE | PAD_CTL_SRE_FAST)
-#define USDHC1_CD_GPIO IMX_GPIO_NR(1, 2) -#define USDHC3_CD_GPIO IMX_GPIO_NR(3, 9) #define ETH_PHY_RESET IMX_GPIO_NR(3, 29) #define ETH_PHY_AR8035_POWER IMX_GPIO_NR(7, 13) #define REV_DETECTION IMX_GPIO_NR(2, 28) @@ -68,28 +60,6 @@ static iomux_v3_cfg_t const uart1_pads[] = { IOMUX_PADS(PAD_CSI0_DAT11__UART1_RX_DATA | MUX_PAD_CTRL(UART_PAD_CTRL)), };
-static iomux_v3_cfg_t const usdhc1_pads[] = { - IOMUX_PADS(PAD_SD1_CLK__SD1_CLK | MUX_PAD_CTRL(USDHC_PAD_CTRL)), - IOMUX_PADS(PAD_SD1_CMD__SD1_CMD | MUX_PAD_CTRL(USDHC_PAD_CTRL)), - IOMUX_PADS(PAD_SD1_DAT0__SD1_DATA0 | MUX_PAD_CTRL(USDHC_PAD_CTRL)), - IOMUX_PADS(PAD_SD1_DAT1__SD1_DATA1 | MUX_PAD_CTRL(USDHC_PAD_CTRL)), - IOMUX_PADS(PAD_SD1_DAT2__SD1_DATA2 | MUX_PAD_CTRL(USDHC_PAD_CTRL)), - IOMUX_PADS(PAD_SD1_DAT3__SD1_DATA3 | MUX_PAD_CTRL(USDHC_PAD_CTRL)), - /* Carrier MicroSD Card Detect */ - IOMUX_PADS(PAD_GPIO_2__GPIO1_IO02 | MUX_PAD_CTRL(NO_PAD_CTRL)), -}; - -static iomux_v3_cfg_t const usdhc3_pads[] = { - IOMUX_PADS(PAD_SD3_CLK__SD3_CLK | MUX_PAD_CTRL(USDHC_PAD_CTRL)), - IOMUX_PADS(PAD_SD3_CMD__SD3_CMD | MUX_PAD_CTRL(USDHC_PAD_CTRL)), - IOMUX_PADS(PAD_SD3_DAT0__SD3_DATA0 | MUX_PAD_CTRL(USDHC_PAD_CTRL)), - IOMUX_PADS(PAD_SD3_DAT1__SD3_DATA1 | MUX_PAD_CTRL(USDHC_PAD_CTRL)), - IOMUX_PADS(PAD_SD3_DAT2__SD3_DATA2 | MUX_PAD_CTRL(USDHC_PAD_CTRL)), - IOMUX_PADS(PAD_SD3_DAT3__SD3_DATA3 | MUX_PAD_CTRL(USDHC_PAD_CTRL)), - /* SOM MicroSD Card Detect */ - IOMUX_PADS(PAD_EIM_DA9__GPIO3_IO09 | MUX_PAD_CTRL(NO_PAD_CTRL)), -}; - static iomux_v3_cfg_t const enet_pads[] = { IOMUX_PADS(PAD_ENET_MDIO__ENET_MDIO | MUX_PAD_CTRL(ENET_PAD_CTRL)), IOMUX_PADS(PAD_ENET_MDC__ENET_MDC | MUX_PAD_CTRL(ENET_PAD_CTRL)), @@ -145,73 +115,6 @@ static void setup_iomux_enet(void) udelay(100); }
-static struct fsl_esdhc_cfg usdhc_cfg[2] = { - {USDHC3_BASE_ADDR}, - {USDHC1_BASE_ADDR}, -}; - -int board_mmc_getcd(struct mmc *mmc) -{ - struct fsl_esdhc_cfg *cfg = (struct fsl_esdhc_cfg *)mmc->priv; - int ret = 0; - - switch (cfg->esdhc_base) { - case USDHC1_BASE_ADDR: - ret = !gpio_get_value(USDHC1_CD_GPIO); - break; - case USDHC3_BASE_ADDR: - ret = !gpio_get_value(USDHC3_CD_GPIO); - break; - } - - return ret; -} - -int board_mmc_init(bd_t *bis) -{ - int ret; - u32 index = 0; - -#if !CONFIG_IS_ENABLED(DM_MMC) - gpio_request(USDHC1_CD_GPIO, "USDHC1_CD"); - gpio_request(USDHC3_CD_GPIO, "USDHC3_CD"); -#endif - - /* - * Following map is done: - * (U-Boot device node) (Physical Port) - * mmc0 SOM MicroSD - * mmc1 Carrier board MicroSD - */ - for (index = 0; index < CONFIG_SYS_FSL_USDHC_NUM; ++index) { - switch (index) { - case 0: - SETUP_IOMUX_PADS(usdhc3_pads); - usdhc_cfg[0].sdhc_clk = mxc_get_clock(MXC_ESDHC3_CLK); - usdhc_cfg[0].max_bus_width = 4; - gpio_direction_input(USDHC3_CD_GPIO); - break; - case 1: - SETUP_IOMUX_PADS(usdhc1_pads); - usdhc_cfg[1].sdhc_clk = mxc_get_clock(MXC_ESDHC_CLK); - usdhc_cfg[1].max_bus_width = 4; - gpio_direction_input(USDHC1_CD_GPIO); - break; - default: - printf("Warning: you configured more USDHC controllers" - "(%d) then supported by the board (%d)\n", - index + 1, CONFIG_SYS_FSL_USDHC_NUM); - return -EINVAL; - } - - ret = fsl_esdhc_initialize(bis, &usdhc_cfg[index]); - if (ret) - return ret; - } - - return 0; -} - static int ar8031_phy_fixup(struct phy_device *phydev) { unsigned short val; diff --git a/configs/wandboard_defconfig b/configs/wandboard_defconfig index 9d9fbffbbd..7f64ea65b1 100644 --- a/configs/wandboard_defconfig +++ b/configs/wandboard_defconfig @@ -44,6 +44,7 @@ CONFIG_SYS_I2C_MXC=y CONFIG_SYS_I2C_MXC_I2C1=y CONFIG_SYS_I2C_MXC_I2C2=y CONFIG_SYS_I2C_MXC_I2C3=y +CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y CONFIG_PHYLIB=y CONFIG_MII=y
Move SDHC init to SPL code since it is not required with DM_MMC. Enable DM_MMC support. Signed-off-by: Anatolij Gustschin agust@denx.de
Applied to u-boot-imx, -next, thanks !
Best regards, Stefano Babic
Hi Anatolij,
On Mon, Mar 18, 2019 at 7:30 PM Anatolij Gustschin agust@denx.de wrote:
This series starts conversion of ipuv3 driver to DM_VIDEO. It has been tested on apalis_imx6 module with LVDS display attached and on wandboard with HDMI display.
With applied "[PATCH 17/17] imx6: wandboard: convert to DM_MMC" building wandboard target doesn't work. To fix this please apply patches [1], [2] and enable CONFIG_AHCI and CONFIG_DM_SCSI in wandboard_defconfig.
[1] http://patchwork.ozlabs.org/patch/1050141 [2] http://patchwork.ozlabs.org/patch/1050143
Anatolij Gustschin (17): video: ipuv3: add DM_VIDEO support video: move ipuv3 files to subdirectory imx: move CONFIG_VIDEO_IPUV3 to defconfigs imx6: dts: add 'u-boot,dm-pre-reloc' to soc and ipu nodes apalis_imx6: convert to DM_VIDEO imx6: icore: convert to DM_VIDEO imx6: ge_bx50v3: convert to DM_VIDEO colibri_imx6: convert to DM_VIDEO mx6sabresd: convert to DM_VIDEO mx6sabreauto: convert to DM_VIDEO imx6: wandboard: add device tree
Thanks for converting wandboard to DM.
I haven't had a chance to test this series yet, but I am wondering if the SPL size can still fit in the 64k of the internal RAM available on mx6solo.
Do you know?
Thanks
Hi Fabio,
On Wed, 20 Mar 2019 10:25:02 -0300 Fabio Estevam festevam@gmail.com wrote: ...
Do you know?
I've tested on wandboard with MX6Solo, the SPL size was 47 KiB.
Thanks, Anatolij
Hi Anatolij,
Excellent! That's great news, thanks :-)
Anatolij Gustschin
Fabio Estevam
sbabic@denx.de
