[U-Boot] Fwd: Re: [PATCH 2/3] env_mmc: support env partition setup in runtime
Hi Pantelis, Tom,
Apparently, Dmitry has sent the message in html format...
Resending now... Sorry for that...
-------- Original Message -------- Subject: Re: [U-Boot] [PATCH 2/3] env_mmc: support env partition setup in runtime Date: Wed, 25 Jun 2014 10:42:11 +0300 From: Dmitry Lifshitz lifshitz@compulab.co.il To: Pantelis Antoniou pantelis.antoniou@gmail.com CC: u-boot@lists.denx.de, Tom Rini trini@ti.com, Igor Grinberg grinberg@compulab.co.il
Hi Pantelis,
On 06/12/2014 06:10 PM, Pantelis Antoniou wrote:
Hi Dmitry,
I took a good look at the patch and there's a problem.
On Apr 27, 2014, at 1:18 PM, Dmitry Lifshitz wrote:
Add callback with __weak annotation to allow setup of environment partition number in runtime from a board file.
Signed-off-by: Dmitry Lifshitz lifshitz@compulab.co.il Signed-off-by: Igor Grinberg grinberg@compulab.co.il
common/env_mmc.c | 35 ++++++++++++++++++++++++++--------- 1 files changed, 26 insertions(+), 9 deletions(-)
diff --git a/common/env_mmc.c b/common/env_mmc.c index 045428c..5d4b5f4 100644 --- a/common/env_mmc.c +++ b/common/env_mmc.c @@ -62,6 +62,30 @@ int env_init(void) return 0; }
+#ifdef CONFIG_SYS_MMC_ENV_PART +__weak uint mmc_get_env_part(struct mmc *mmc) +{
- return CONFIG_SYS_MMC_ENV_PART;
+static int mmc_set_env_part(struct mmc *mmc) +{
- uint part = mmc_get_env_part(mmc);
- if (part != mmc->part_num) {
if (mmc_switch_part(CONFIG_SYS_MMC_ENV_DEV, part)) {
puts("MMC partition switch failed\n");
return -1;
+} +#else +static inline int mmc_set_env_part(struct mmc *mmc) {return 0; }; +#endif
static int init_mmc_for_env(struct mmc *mmc) { if (!mmc) { @@ -74,15 +98,8 @@ static int init_mmc_for_env(struct mmc *mmc) return -1; }
Just before this hunk, we have this:
#ifdef CONFIG_SYS_MMC_ENV_PART int dev = CONFIG_SYS_MMC_ENV_DEV;
#ifdef CONFIG_SPL_BUILD dev = 0; #endif #endif
This appears to be broken for SPL in case that CONFIG_SYS_MMC_ENV_DEV is not 0.
Exactly as it was broken before the patch, right?
SPL hardcoded dev to 0, while mmc_switch_part is implicitly operating on CONFIG_SYS_MMC_ENV_DEV.
Please rework it so that the SPL case is unaffected.
This patch does not change the behavior and its purpose is not fixing the current code.
The bug describe can be fixed by later patch and possibly will require additional review and testing.
Given that this patch does not change the behavior, can it be accepted please ?
Regards,
Dmitry
-#ifdef CONFIG_SYS_MMC_ENV_PART
- if (CONFIG_SYS_MMC_ENV_PART != mmc->part_num) {
CONFIG_SYS_MMC_ENV_PART)) {
return -1;
-#endif
if (mmc_set_env_part(mmc))
return -1;
1.7.5.4
ping.
On 07/03/14 11:36, Igor Grinberg wrote:
Hi Pantelis, Tom,
Hi Pantelis,
Hi Dmitry,
return -1;
Regards,
Dmitry
return -1;
-#endif
return -1;
1.7.5.4
Igor Grinberg
