[U-Boot] [PATCH 4/6] Poseidon Board Support
Added include/configs/poseidon.h file.
Signed-off-by: Vivek Dalal v.dalal@samsung.com --- include/configs/poseidon.h | 293 +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ 1 file changed, 293 insertions(+)
diff --git a/include/configs/poseidon.h b/include/configs/poseidon.h index e69de29..d2ccbfa 100644 --- a/include/configs/poseidon.h +++ b/include/configs/poseidon.h @@ -0,0 +1,286 @@ +/* + * (C) Copyright 2009-2010 + * Samsung Electronics, <www.samsung.com> + * Vivek Dalal v.dalal@samsung.com + * + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +/* + * High Level Configuration Options + */ +#define CONFIG_ARM1136 1 /* This is an arm1136 CPU core */ +#define CONFIG_OMAP 1 /* in a TI OMAP core */ +#define CONFIG_OMAP24XX 1 /* which is a 24XX */ +#define CONFIG_OMAP243X 1 /* which is in a 243X */ +#define CONFIG_2430 1 +#define CONFIG_POSEIDON 1 + +/* Clock config for target */ +#define PRCM_CONFIG_I 1 /* DRAM-166MHz OneNAND-83MHz*/ +#ifdef CONFIG_SYS_NOR_BOOT +#undef CONFIG_SYS_USE_NOR +#define CONFIG_SYS_USE_NOR 1 +#endif + +#define CONFIG_SYS_USE_UBI +#include <asm/arch/omap24xx.h> /* get chip and board defs */ + +#define V_SCLK 13000000 + +/* input clock of PLL */ +/* the OMAP24XX SDP has 12MHz, 13MHz, or 19.2Mhz crystal input */ +#define CONFIG_SYS_CLK_FREQ V_SCLK + +#undef CONFIG_USE_IRQ /* no support for IRQs */ +#define CONFIG_MISC_INIT_R + +#define CONFIG_CMDLINE_TAG 1 /* enable passing of ATAGs */ +#define CONFIG_SETUP_MEMORY_TAGS 1 +#define CONFIG_INITRD_TAG 1 +#define CONFIG_REVISION_TAG 1 + +/* + * TFTP Dump Command support + */ + +/* + * Size of malloc() pool + */ +/* Total Size of Environment Sector */ +#define CONFIG_ENV_SIZE SZ_256K +/* Total Size of Environment Sector */ +#define CONFIG_ENV_SIZE_4K SZ_256K +/* Total Size of Environment Sector of FLEX */ +#define CONFIG_ENV_SIZE_FLEX SZ_256K + +#define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + SZ_2M) +/* size in bytes reserved for initial data */ +#define CONFIG_SYS_GBL_DATA_SIZE 128 + +/* + * SMC91c96 Etherent + */ +#define CONFIG_DRIVER_LAN91C96 +#define CONFIG_LAN91C96_BASE (DEBUG_BASE+0x300) +#define CONFIG_LAN91C96_EXT_PHY +/* + * Hardware drivers + */ + +/* + * NS16550 Configuration + */ +#define V_NS16550_CLK (48000000) /* 48MHz (APLL96/2) */ + +#define CONFIG_SYS_NS16550 +#define CONFIG_SYS_NS16550_SERIAL +#define CONFIG_SYS_NS16550_REG_SIZE (-4) +#define CONFIG_SYS_NS16550_CLK V_NS16550_CLK +#define CONFIG_SYS_NS16550_COM1 OMAP24XX_UART1 + +/* + * select serial console configuration + */ +#define CONFIG_SERIAL1 1 /* UART1 on SDP */ +/* allow to overwrite serial and ethaddr */ +#define CONFIG_ENV_OVERWRITE +#define CONFIG_CONS_INDEX 1 +#define CONFIG_BAUDRATE 115200 +#define CONFIG_SYS_BAUDRATE_TABLE {4800, 9600, 19200, 38400, 57600, 115200} + +/* Config CMD*/ + +/* this must be included AFTER the definition of CONFIG_COMMANDS (if any) */ +#include <config_cmd_default.h> + +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_DIAG +#define CONFIG_CMD_ONENAND 1 + +#ifdef CONFIG_SYS_USE_UBI +#define CONFIG_CMD_JFFS2 +#define CONFIG_CMD_UBI +#define CONFIG_RBTREE +#define CONFIG_MTD_PARTITIONS +#endif + +#undef CONFIG_CMD_AUTOSCRIPT + +#ifndef CONFIG_SYS_USE_NOR +# undef CONFIG_CMD_FLASH +# undef CONFIG_CMD_IMLS +#endif + +#define CONFIG_BOOTP_MASK CONFIG_BOOTP_DEFAULT +#define CONFIG_BOOTDELAY 1 + +#define CONFIG_NETMASK 255.255.255.0 +#define CONFIG_IPADDR 192.168.200.11 +#define CONFIG_SERVERIP 192.168.200.1 +#define CONFIG_BOOTFILE "uImage" +#define CONFIG_ETHADDR 00:0E:99:00:24:20 + +#define CONFIG_SYS_MEM "mem=128" + +#ifdef CONFIG_SYS_USE_UBI +#define CONFIG_SYS_UBI "ubi.mtd=4" +#else +#define CONFIG_SYS_UBI "" +#endif + +#define CONFIG_BOOTARGS "root=/dev/nfs rw " CONFIG_SYS_MEM \ + " console=ttyS0,115200n8" \ + " ip=192.168.116.25:192.168.116.1:192.168.116.1:255.255.255.0:" \ + "apollon:eth0:off nfsroot=/tftpboot/nfsroot profile=2 " \ + CONFIG_SYS_UBI + +#define CONFIG_EXTRA_ENV_SETTINGS \ + "Image=tftp 0x80008000 Image; go 0x80008000\0" \ + "zImage=tftp 0x80180000 zImage; go 0x80180000\0" \ + "uImage=tftp 0x80180000 uImage; bootm 0x80180000\0" \ + "uboot=tftp 0x80008000 u-boot.bin; go 0x80008000\0" \ + "xloader=tftp 0x80180000 x-load.bin; " \ + " cp.w 0x80180000 0x00000400 0x1000; go 0x00000400\0" \ + "syncmode50=mw.w 0x1e442 0xc0c4; mw 0x6800a060 0xe30d1201\0" \ + "syncmode=mw.w 0x1e442 0xe0f4; mw 0x6800a060 0xe30d1201\0" \ + "norboot=cp32 0x18040000 0x80008000 0x200000; go 0x80008000\0" \ + "oneboot=onenand read 0x80008000 0x40000 0x200000; go 0x80008000\0" \ + "onesyncboot=run syncmode oneboot\0" \ + "updateb=tftp 0x80180000 u-boot-onenand.bin; " \ + " onenand erase 0x0 0x20000; onenand write 0x80180000 0x0 0x20000\0" \ + "ubi=setenv bootargs ${bootargs} ubi.mtd=4 ${mtdparts}; run uImage\0" \ + "bootcmd=run uboot\0" + +/* + * Miscellaneous configurable options + */ +#define V_PROMPT "Poseidon # " + +#define CONFIG_SYS_LONGHELP /* undef to save memory */ +#define CONFIG_SYS_PROMPT V_PROMPT +#define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ +/* Print Buffer Size */ +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE+sizeof(CONFIG_SYS_PROMPT)+16) +#define CONFIG_SYS_MAXARGS 16 /* max number of command args */ +/* Boot Argument Buffer Size */ +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE +/* memtest works on */ +#define CONFIG_SYS_MEMTEST_START (OMAP24XX_SDRC_CS0) +#define CONFIG_SYS_MEMTEST_END (OMAP24XX_SDRC_CS0+SZ_31M) + +#undef CONFIG_SYS_CLKS_IN_HZ /* everything, incl board info, in Hz */ +/* default load address */ +#define CONFIG_SYS_LOAD_ADDR (OMAP24XX_SDRC_CS0) + +/* The 2420 has 12 GP timers, they can be driven by the SysClk (12/13/19.2) + * or by 32KHz clk, or from external sig. This rate is divided by a local + * divisor. + */ +#define V_PVT 7 /* use with 12MHz/128 */ +#define CONFIG_SYS_TIMERBASE OMAP24XX_GPT2 +#define CONFIG_SYS_PTV V_PVT /* 2^(pvt+1) */ +#define CONFIG_SYS_HZ ((CONFIG_SYS_CLK_FREQ)/(2 << CONFIG_SYS_PTV)) + +/*----------------------------------------------------------------------- + * Stack sizes + * + * The stack sizes are set up in start.S using the settings below + */ +#define CONFIG_STACKSIZE SZ_128K /* regular stack */ +#ifdef CONFIG_USE_IRQ +# define CONFIG_STACKSIZE_IRQ SZ_4K /* IRQ stack */ +# define CONFIG_STACKSIZE_FIQ SZ_4K /* FIQ stack */ +#endif + +/*----------------------------------------------------------------------- + * Physical Memory Map + */ +#define CONFIG_NR_DRAM_BANKS 2 /* CS1 may or may not be populated */ +#define PHYS_SDRAM_1 OMAP24XX_SDRC_CS0 +#define PHYS_SDRAM_1_SIZE SZ_128M +#define PHYS_SDRAM_2 OMAP2420_SDRC_CS1 + +/*----------------------------------------------------------------------- + * FLASH and environment organization + */ + +/* Configure the PISMO - REV A Version is as follows */ +#define PISMO_CS0 PISMO_SIBLEY0 +#define PISMO_CS1 PISMO_SIBLEY1 +#define PISMO_CS2 PISMO_ONENAND +#define PROC_NOR_SIZE GPMC_SIZE_64M +#define PROC_NAND_SIZE GPMC_SIZE_64M +#define PROC_ONENAND_SIZE GPMC_SIZE_16M +#define PISMO_SIB0_SIZE GPMC_SIZE_64M +#define PISMO_SIB1_SIZE GPMC_SIZE_64M +#define PISMO_ONEN_SIZE GPMC_SIZE_128M +#define DBG_MPDB_SIZE GPMC_SIZE_16M +#define PISMO_PCMCIA_SIZE GPMC_SIZE_128M + +/*----------------------------------------------------------------------- + * FLASH and environment organization + */ +#ifdef CONFIG_SYS_USE_NOR +/* OneNAND boot, NOR has CS3, But NOR has CS0 when NOR boot */ +# define CONFIG_SYS_FLASH_BASE 0x18000000 +# define CONFIG_SYS_MAX_FLASH_BANKS 1 +# define CONFIG_SYS_MAX_FLASH_SECT 1024 +/*----------------------------------------------------------------------- + * CFI FLASH driver setup + */ +/* Flash memory is CFI compliant */ +# define CONFIG_SYS_FLASH_CFI 1 +# define CONFIG_FLASH_CFI_DRIVER 1 /* Use drivers/cfi_flash.c */ +/* Use buffered writes (~10x faster) */ +/* #define CONFIG_SYS_FLASH_USE_BUFFER_WRITE 1 */ +/* Use h/w sector protection*/ +# define CONFIG_SYS_FLASH_PROTECTION 1 + +#else /* !CONFIG_SYS_USE_NOR */ +# define CONFIG_SYS_NO_FLASH 1 +#endif /* CONFIG_SYS_USE_NOR */ + + +#define CONFIG_SYS_ONENAND_BASE 0x00000000 +#define CONFIG_SYS_MONITOR_LEN SZ_256K /* U-Boot image size */ + +#define CONFIG_ENV_IS_IN_ONENAND 1 + +#define CONFIG_ENV_ADDR 0x00020000 +#define CONFIG_ENV_ADDR_4K 0x00040000 +#define CONFIG_ENV_ADDR_FLEX 0x00040000 + +#ifdef CONFIG_SYS_USE_UBI +#define CONFIG_CMD_MTDPARTS +#define MTDIDS_DEFAULT "onenand0=onenand" +#define MTDPARTS_DEFAULT "mtdparts=onenand:128k(bootloader)," \ + "128k(params)," \ + "2m(kernel)," \ + "16m(rootfs)," \ + "32m(fs)," \ + "-(ubifs)" +#endif + + +#endif /* __CONFIG_H */
Vivek
