[PATCH] spi: ti_qspi: Fix "spi-max-frequency" error path in ti_qspi_ofdata_to_platdata
struct ti_qspi_priv->max_hz is declared as unsigned int, so the following error path check will always be false, even when "spi-max-frequency" property is invalid/missing: priv->max_hz = fdtdec_get_int(blob, node, "spi-max-frequency", -1); if (priv->max_hz < 0) { ... }
Replace the fdtdec call with dev_read_u32_default() and use 0 as the default value. Error out if max_hz is zero.
Signed-off-by: Ovidiu Panait ovidiu.panait@windriver.com ---
drivers/spi/ti_qspi.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/spi/ti_qspi.c b/drivers/spi/ti_qspi.c index 5fdbb49442..91be18e0a7 100644 --- a/drivers/spi/ti_qspi.c +++ b/drivers/spi/ti_qspi.c @@ -467,8 +467,8 @@ static int ti_qspi_ofdata_to_platdata(struct udevice *bus) priv->memory_map = map_physmem(mmap_addr, mmap_size, MAP_NOCACHE); priv->mmap_size = mmap_size;
- priv->max_hz = fdtdec_get_int(blob, node, "spi-max-frequency", -1); - if (priv->max_hz < 0) { + priv->max_hz = dev_read_u32_default(bus, "spi-max-frequency", 0); + if (!priv->max_hz) { debug("Error: Max frequency missing\n"); return -ENODEV; }
Applied to u-boot-ti/for-next
Thanks and regards, Lokesh
Lokesh Vutla
Ovidiu Panait
