[U-Boot] [PATCH v3 0/4] ARM: Aspeed: Add SD host controller driver
This series adds support for the SD host controller on the Aspeed ast2xxx SocS. It also enables MMC and the SD controller for the ast2500 EVB.
Changes since v2: - Remove mmc_initialize call in the ast2500 board init - Add OF_CONTROL to the ast2500 EVB configuration - Fix the clock-getting code in the driver probe function
Changes since v1: - Split the patch up - Add defconfig and devicetree changes
Eddie James (4): clk: aspeed: Add support for SD clock mmc: Add Aspeed SD controller driver configs: AST2500 EVB: Enable SD controller ARM: dts: ast2500: Add SDHCI nodes
arch/arm/dts/ast2500-evb.dts | 14 ++++ arch/arm/dts/ast2500-u-boot.dtsi | 16 +++++ arch/arm/include/asm/arch-aspeed/scu_ast2500.h | 3 + arch/arm/include/asm/gpio.h | 3 +- configs/evb-ast2500_defconfig | 8 +++ drivers/clk/aspeed/clk_ast2500.c | 27 ++++++++ drivers/mmc/Kconfig | 11 ++++ drivers/mmc/Makefile | 1 + drivers/mmc/aspeed_sdhci.c | 90 ++++++++++++++++++++++++++ drivers/pinctrl/aspeed/pinctrl_ast2500.c | 2 + 10 files changed, 174 insertions(+), 1 deletion(-) create mode 100644 drivers/mmc/aspeed_sdhci.c
Add code to enable the SD clock on the ast2500 SoC.
Reviewed-by: Cédric Le Goater clg@kaod.org Signed-off-by: Eddie James eajames@linux.ibm.com --- arch/arm/include/asm/arch-aspeed/scu_ast2500.h | 3 +++ drivers/clk/aspeed/clk_ast2500.c | 27 ++++++++++++++++++++++++++ drivers/pinctrl/aspeed/pinctrl_ast2500.c | 2 ++ 3 files changed, 32 insertions(+)
diff --git a/arch/arm/include/asm/arch-aspeed/scu_ast2500.h b/arch/arm/include/asm/arch-aspeed/scu_ast2500.h index 4988ced..8db4901 100644 --- a/arch/arm/include/asm/arch-aspeed/scu_ast2500.h +++ b/arch/arm/include/asm/arch-aspeed/scu_ast2500.h @@ -22,6 +22,8 @@ #define SCU_MPLL_POST_MASK (0x3f << SCU_MPLL_POST_SHIFT) #define SCU_PCLK_DIV_SHIFT 23 #define SCU_PCLK_DIV_MASK (7 << SCU_PCLK_DIV_SHIFT) +#define SCU_SDCLK_DIV_SHIFT 12 +#define SCU_SDCLK_DIV_MASK (7 << SCU_SDCLK_DIV_SHIFT) #define SCU_HPLL_DENUM_SHIFT 0 #define SCU_HPLL_DENUM_MASK 0x1f #define SCU_HPLL_NUM_SHIFT 5 @@ -107,6 +109,7 @@
#define SCU_CLKSTOP_MAC1 (1 << 20) #define SCU_CLKSTOP_MAC2 (1 << 21) +#define SCU_CLKSTOP_SDCLK (1 << 27)
#define SCU_D2PLL_EXT1_OFF (1 << 0) #define SCU_D2PLL_EXT1_BYPASS (1 << 1) diff --git a/drivers/clk/aspeed/clk_ast2500.c b/drivers/clk/aspeed/clk_ast2500.c index dbee13a..9249cf9 100644 --- a/drivers/clk/aspeed/clk_ast2500.c +++ b/drivers/clk/aspeed/clk_ast2500.c @@ -143,6 +143,17 @@ static ulong ast2500_clk_get_rate(struct clk *clk) rate = rate / apb_div; } break; + case BCLK_SDCLK: + { + ulong apb_div = 4 + 4 * ((readl(&priv->scu->clk_sel1) + & SCU_SDCLK_DIV_MASK) + >> SCU_SDCLK_DIV_SHIFT); + rate = ast2500_get_hpll_rate(clkin, + readl(&priv-> + scu->h_pll_param)); + rate = rate / apb_div; + } + break; case PCLK_UART1: rate = ast2500_get_uart_clk_rate(priv->scu, 1); break; @@ -436,6 +447,22 @@ static int ast2500_clk_enable(struct clk *clk) struct ast2500_clk_priv *priv = dev_get_priv(clk->dev);
switch (clk->id) { + case BCLK_SDCLK: + if (readl(&priv->scu->clk_stop_ctrl1) & SCU_CLKSTOP_SDCLK) { + ast_scu_unlock(priv->scu); + + setbits_le32(&priv->scu->sysreset_ctrl1, + SCU_SYSRESET_SDIO); + udelay(100); + clrbits_le32(&priv->scu->clk_stop_ctrl1, + SCU_CLKSTOP_SDCLK); + mdelay(10); + clrbits_le32(&priv->scu->sysreset_ctrl1, + SCU_SYSRESET_SDIO); + + ast_scu_lock(priv->scu); + } + break; /* * For MAC clocks the clock rate is * configured based on whether RGMII or RMII mode has been selected diff --git a/drivers/pinctrl/aspeed/pinctrl_ast2500.c b/drivers/pinctrl/aspeed/pinctrl_ast2500.c index ed333b9..a6e9c0d 100644 --- a/drivers/pinctrl/aspeed/pinctrl_ast2500.c +++ b/drivers/pinctrl/aspeed/pinctrl_ast2500.c @@ -58,6 +58,8 @@ static const struct ast2500_group_config ast2500_groups[] = { { "MDIO1", 3, (1 << 31) | (1 << 30) }, { "MAC2LINK", 1, (1 << 1) }, { "MDIO2", 5, (1 << 2) }, + { "SD1", 5, (1 << 0) }, + { "SD2", 5, (1 << 1) }, };
static int ast2500_pinctrl_get_groups_count(struct udevice *dev)
Add support for the Aspeed SD host controller engine.
Signed-off-by: Eddie James eajames@linux.ibm.com --- arch/arm/include/asm/gpio.h | 3 +- drivers/mmc/Kconfig | 11 ++++++ drivers/mmc/Makefile | 1 + drivers/mmc/aspeed_sdhci.c | 90 +++++++++++++++++++++++++++++++++++++++++++++ 4 files changed, 104 insertions(+), 1 deletion(-) create mode 100644 drivers/mmc/aspeed_sdhci.c
diff --git a/arch/arm/include/asm/gpio.h b/arch/arm/include/asm/gpio.h index 370031f..38a5922 100644 --- a/arch/arm/include/asm/gpio.h +++ b/arch/arm/include/asm/gpio.h @@ -1,6 +1,7 @@ #if !defined(CONFIG_ARCH_UNIPHIER) && !defined(CONFIG_ARCH_STI) && \ !defined(CONFIG_ARCH_K3) && !defined(CONFIG_ARCH_BCM6858) && \ - !defined(CONFIG_ARCH_BCM63158) && !defined(CONFIG_ARCH_ROCKCHIP) + !defined(CONFIG_ARCH_BCM63158) && !defined(CONFIG_ARCH_ROCKCHIP) && \ + !defined(CONFIG_ARCH_ASPEED) #include <asm/arch/gpio.h> #endif #include <asm-generic/gpio.h> diff --git a/drivers/mmc/Kconfig b/drivers/mmc/Kconfig index c6812f6..536f66a 100644 --- a/drivers/mmc/Kconfig +++ b/drivers/mmc/Kconfig @@ -421,6 +421,17 @@ config SPL_MMC_SDHCI_ADMA This enables support for the ADMA (Advanced DMA) defined in the SD Host Controller Standard Specification Version 3.00 in SPL.
+config MMC_SDHCI_ASPEED + bool "Aspeed SDHCI controller" + depends on ARCH_ASPEED + depends on DM_MMC + depends on MMC_SDHCI + help + Enables support for the Aspeed SDHCI 2.0 controller present on Aspeed + SoCs. This device is compatible with SD 3.0 and/or MMC 4.3 + specifications. On the AST2600, the device is also compatible with + MMC 5.1 and eMMC 3.0. + config MMC_SDHCI_ATMEL bool "Atmel SDHCI controller support" depends on ARCH_AT91 diff --git a/drivers/mmc/Makefile b/drivers/mmc/Makefile index 6cc018b..5594195 100644 --- a/drivers/mmc/Makefile +++ b/drivers/mmc/Makefile @@ -46,6 +46,7 @@ obj-$(CONFIG_JZ47XX_MMC) += jz_mmc.o
# SDHCI obj-$(CONFIG_MMC_SDHCI) += sdhci.o +obj-$(CONFIG_MMC_SDHCI_ASPEED) += aspeed_sdhci.o obj-$(CONFIG_MMC_SDHCI_ATMEL) += atmel_sdhci.o obj-$(CONFIG_MMC_SDHCI_BCM2835) += bcm2835_sdhci.o obj-$(CONFIG_MMC_SDHCI_BCMSTB) += bcmstb_sdhci.o diff --git a/drivers/mmc/aspeed_sdhci.c b/drivers/mmc/aspeed_sdhci.c new file mode 100644 index 0000000..1321ec3 --- /dev/null +++ b/drivers/mmc/aspeed_sdhci.c @@ -0,0 +1,90 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright 2019 IBM Corp. + * Eddie James eajames@linux.ibm.com + */ + +#include <common.h> +#include <clk.h> +#include <dm.h> +#include <malloc.h> +#include <sdhci.h> + +struct aspeed_sdhci_plat { + struct mmc_config cfg; + struct mmc mmc; +}; + +static int aspeed_sdhci_probe(struct udevice *dev) +{ + struct mmc_uclass_priv *upriv = dev_get_uclass_priv(dev); + struct aspeed_sdhci_plat *plat = dev_get_platdata(dev); + struct sdhci_host *host = dev_get_priv(dev); + u32 max_clk; + struct clk clk; + int ret; + + ret = clk_get_by_index(dev, 0, &clk); + if (ret) + return ret; + + ret = clk_enable(&clk); + if (ret) + goto free; + + host->name = dev->name; + host->ioaddr = (void *)devfdt_get_addr(dev); + + max_clk = clk_get_rate(&clk); + if (IS_ERR_VALUE(max_clk)) { + ret = max_clk; + goto err; + } + + host->max_clk = max_clk; + host->mmc = &plat->mmc; + host->mmc->dev = dev; + host->mmc->priv = host; + upriv->mmc = host->mmc; + + ret = sdhci_setup_cfg(&plat->cfg, host, 0, 0); + if (ret) + goto err; + + ret = sdhci_probe(dev); + if (ret) + goto err; + + return 0; + +err: + clk_disable(&clk); +free: + clk_free(&clk); + return ret; +} + +static int aspeed_sdhci_bind(struct udevice *dev) +{ + struct aspeed_sdhci_plat *plat = dev_get_platdata(dev); + + return sdhci_bind(dev, &plat->mmc, &plat->cfg); +} + +static const struct udevice_id aspeed_sdhci_ids[] = { + { .compatible = "aspeed,ast2400-sdhci" }, + { .compatible = "aspeed,ast2500-sdhci" }, + { .compatible = "aspeed,ast2600-sdhci" }, + { } +}; + +U_BOOT_DRIVER(aspeed_sdhci_drv) = { + .name = "aspeed_sdhci", + .id = UCLASS_MMC, + .of_match = aspeed_sdhci_ids, + .ops = &sdhci_ops, + .bind = aspeed_sdhci_bind, + .probe = aspeed_sdhci_probe, + .priv_auto_alloc_size = sizeof(struct sdhci_host), + .platdata_auto_alloc_size = sizeof(struct aspeed_sdhci_plat), +};
Thanks,
C.
- !defined(CONFIG_ARCH_BCM63158) && !defined(CONFIG_ARCH_ROCKCHIP) && \
- !defined(CONFIG_ARCH_ASPEED)
- bool "Aspeed SDHCI controller"
- depends on ARCH_ASPEED
- depends on DM_MMC
- depends on MMC_SDHCI
- help
- Copyright 2019 IBM Corp.
- Eddie James eajames@linux.ibm.com
- struct mmc_config cfg;
- struct mmc mmc;
- struct mmc_uclass_priv *upriv = dev_get_uclass_priv(dev);
- struct aspeed_sdhci_plat *plat = dev_get_platdata(dev);
- struct sdhci_host *host = dev_get_priv(dev);
- u32 max_clk;
- struct clk clk;
- int ret;
- ret = clk_get_by_index(dev, 0, &clk);
- if (ret)
return ret;
- ret = clk_enable(&clk);
- if (ret)
goto free;
- host->name = dev->name;
- host->ioaddr = (void *)devfdt_get_addr(dev);
- max_clk = clk_get_rate(&clk);
- if (IS_ERR_VALUE(max_clk)) {
ret = max_clk;
goto err;
- host->max_clk = max_clk;
- host->mmc = &plat->mmc;
- host->mmc->dev = dev;
- host->mmc->priv = host;
- upriv->mmc = host->mmc;
- ret = sdhci_setup_cfg(&plat->cfg, host, 0, 0);
- if (ret)
goto err;
- ret = sdhci_probe(dev);
- if (ret)
goto err;
+err:
- clk_disable(&clk);
+free:
- clk_free(&clk);
- return ret;
- return sdhci_bind(dev, &plat->mmc, &plat->cfg);
- { .compatible = "aspeed,ast2400-sdhci" },
- { .compatible = "aspeed,ast2500-sdhci" },
- { .compatible = "aspeed,ast2600-sdhci" },
- .name = "aspeed_sdhci",
- .id = UCLASS_MMC,
- .of_match = aspeed_sdhci_ids,
- .ops = &sdhci_ops,
- .bind = aspeed_sdhci_bind,
- .probe = aspeed_sdhci_probe,
- .priv_auto_alloc_size = sizeof(struct sdhci_host),
- .platdata_auto_alloc_size = sizeof(struct aspeed_sdhci_plat),
Hi Eddie,
Subject: [PATCH v3 2/4] mmc: Add Aspeed SD controller driver
This patch could not be applied to latest tree, could you please check?
Thanks, Peng.
- depends on DM_MMC
- help
Aspeed
- struct mmc mmc;
+static int aspeed_sdhci_probe(struct udevice *dev) {
- u32 max_clk;
- struct clk clk;
- int ret;
- if (ret)
return ret;
- if (ret)
goto free;
ret = max_clk;
goto err;
- if (ret)
goto err;
- if (ret)
goto err;
+err:
+free:
- clk_free(&clk);
- return ret;
+static int aspeed_sdhci_bind(struct udevice *dev) {
- return sdhci_bind(dev, &plat->mmc, &plat->cfg); }
- .id = UCLASS_MMC,
- .platdata_auto_alloc_size = sizeof(struct aspeed_sdhci_plat), };
-- 1.8.3.1
On 8/27/19 2:34 AM, Peng Fan wrote:
Hi Eddie,
Sorry I was a little behind master. I just sent this patch rebased.
Thanks,
Eddie
Thanks, Peng.
- !defined(CONFIG_ARCH_ASPEED) #include <asm/arch/gpio.h> #endif #include <asm-generic/gpio.h>
- depends on DM_MMC
- help
Aspeed
- config MMC_SDHCI_ATMEL bool "Atmel SDHCI controller support" depends on ARCH_AT91
- struct mmc mmc;
- u32 max_clk;
- struct clk clk;
- int ret;
- if (ret)
return ret;
- if (ret)
goto free;
ret = max_clk;
goto err;
- if (ret)
goto err;
- if (ret)
goto err;
+err:
+free:
- clk_free(&clk);
- return ret;
- .id = UCLASS_MMC,
-- 1.8.3.1
Enable the MMC subsystem and the Aspeed SD controller. Also enable the use of the device tree for probing the controller.
Signed-off-by: Eddie James eajames@linux.ibm.com --- configs/evb-ast2500_defconfig | 8 ++++++++ 1 file changed, 8 insertions(+)
diff --git a/configs/evb-ast2500_defconfig b/configs/evb-ast2500_defconfig index 59d41cb..b47ca5b 100644 --- a/configs/evb-ast2500_defconfig +++ b/configs/evb-ast2500_defconfig @@ -16,6 +16,7 @@ CONFIG_HUSH_PARSER=y CONFIG_CMD_I2C=y CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y +CONFIG_CMD_MMC=y CONFIG_CMD_PING=y CONFIG_DEFAULT_DEVICE_TREE="ast2500-evb" CONFIG_NET_RANDOM_ETHADDR=y @@ -36,3 +37,10 @@ CONFIG_SYS_NS16550=y CONFIG_SYSRESET=y CONFIG_TIMER=y CONFIG_WDT=y +CONFIG_MMC=y +CONFIG_DM_MMC=y +CONFIG_MMC_SDHCI=y +CONFIG_MMC_SDHCI_ASPEED=y +CONFIG_MMC_VERBOSE=y +CONFIG_OF_CONTROL=y +CONFIG_OF_EMBED=y
Thanks,
C.
Hi Eddie,
Subject: [PATCH v3 3/4] configs: AST2500 EVB: Enable SD controller
Would you add a MAINTAINERS file for this board?
Thanks, Peng.
+CONFIG_OF_EMBED=y
1.8.3.1
Add nodes for the Aspeed SD controllers with their necessary properties.
Reviewed-by: Cédric Le Goater clg@kaod.org Signed-off-by: Eddie James eajames@linux.ibm.com --- arch/arm/dts/ast2500-evb.dts | 14 ++++++++++++++ arch/arm/dts/ast2500-u-boot.dtsi | 16 ++++++++++++++++ 2 files changed, 30 insertions(+)
diff --git a/arch/arm/dts/ast2500-evb.dts b/arch/arm/dts/ast2500-evb.dts index ebf44fd..4796ed4 100644 --- a/arch/arm/dts/ast2500-evb.dts +++ b/arch/arm/dts/ast2500-evb.dts @@ -59,3 +59,17 @@ pinctrl-names = "default"; pinctrl-0 = <&pinctrl_mac2link_default &pinctrl_mdio2_default>; }; + +&sdhci0 { + status = "okay"; + + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_sd1_default>; +}; + +&sdhci1 { + status = "okay"; + + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_sd2_default>; +}; diff --git a/arch/arm/dts/ast2500-u-boot.dtsi b/arch/arm/dts/ast2500-u-boot.dtsi index 7f80bad..8ac4215 100644 --- a/arch/arm/dts/ast2500-u-boot.dtsi +++ b/arch/arm/dts/ast2500-u-boot.dtsi @@ -34,6 +34,22 @@
apb { u-boot,dm-pre-reloc; + + sdhci0: sdhci@1e740100 { + compatible = "aspeed,ast2500-sdhci"; + reg = <0x1e740100>; + #reset-cells = <1>; + clocks = <&scu BCLK_SDCLK>; + resets = <&rst AST_RESET_SDIO>; + }; + + sdhci1: sdhci@1e740200 { + compatible = "aspeed,ast2500-sdhci"; + reg = <0x1e740200>; + #reset-cells = <1>; + clocks = <&scu BCLK_SDCLK>; + resets = <&rst AST_RESET_SDIO>; + }; };
Cédric Le Goater
Eddie James
Peng Fan
