[U-Boot] [PATCH v2] fsl_pci_init_port end-point initialization is broken
commit 70ed869e broke fsl pcie end-point initialization. Returning 0 is not correct. The function must return the first free bus number for the next controller.
fsl_pci_init() must still be called and a bus allocated even if the controller is an end-point.
Signed-off-by: Ed Swarthout Ed.Swarthout@freescale.com Acked-by: Vivek Mahajan vivek.mahajan@freescale.com Signed-off-by: Kumar Gala galak@kernel.crashing.org --- Guys, I want to revert commit 70ed869e and replace it with this. There is no reason to pass in pci_ep we can determine that internally. I will also change the board code to use fsl_is_pci_agent and kill off is_fsl_pci_agent (post november u-boot release).
Can one of you test this out.
- k
drivers/pci/fsl_pci_init.c | 18 +++++++++++++++++- include/asm-ppc/fsl_pci.h | 1 + 2 files changed, 18 insertions(+), 1 deletions(-)
diff --git a/drivers/pci/fsl_pci_init.c b/drivers/pci/fsl_pci_init.c index 87944bf..170cc25 100644 --- a/drivers/pci/fsl_pci_init.c +++ b/drivers/pci/fsl_pci_init.c @@ -1,5 +1,5 @@ /* - * Copyright 2007 Freescale Semiconductor, Inc. + * Copyright 2007-2009 Freescale Semiconductor, Inc. * * This program is free software; you can redistribute it and/or * modify it under the terms of the GNU General Public License @@ -42,6 +42,7 @@ DECLARE_GLOBAL_DATA_PTR; #define FSL_PCI_PBFR 0x44 #define FSL_PCIE_CAP_ID 0x4c #define FSL_PCIE_CFG_RDY 0x4b0 +#define FSL_PROG_IF_AGENT 0x1
void pciauto_prescan_setup_bridge(struct pci_controller *hose, pci_dev_t dev, int sub_bus); @@ -412,6 +413,16 @@ void fsl_pci_init(struct pci_controller *hose, u32 cfg_addr, u32 cfg_data) } }
+int fsl_is_pci_agent(struct pci_controller *hose) +{ + u8 prog_if; + pci_dev_t dev = PCI_BDF(hose->first_busno, 0, 0); + + pci_hose_read_config_byte(hose, dev, PCI_CLASS_PROG, &prog_if); + + return (prog_if == FSL_PROG_IF_AGENT); +} + int fsl_pci_init_port(struct fsl_pci_info *pci_info, struct pci_controller *hose, int busno) { @@ -450,6 +461,11 @@ int fsl_pci_init_port(struct fsl_pci_info *pci_info,
fsl_pci_init(hose, (u32)&pci->cfg_addr, (u32)&pci->cfg_data);
+ if (fsl_is_pci_agent(hose)) { + fsl_pci_config_unlock(hose); + hose->last_busno = hose->first_busno; + } + printf(" PCIE%x on bus %02x - %02x\n", pci_info->pci_num, hose->first_busno, hose->last_busno);
diff --git a/include/asm-ppc/fsl_pci.h b/include/asm-ppc/fsl_pci.h index 2790da7..a5f72f5 100644 --- a/include/asm-ppc/fsl_pci.h +++ b/include/asm-ppc/fsl_pci.h @@ -25,6 +25,7 @@ int is_fsl_pci_agent(enum law_trgt_if trgt, u32 host_agent); int is_fsl_pci_cfg(enum law_trgt_if trgt, u32 io_sel);
+int fsl_is_pci_agent(struct pci_controller *hose); void fsl_pci_init(struct pci_controller *hose, u32 cfg_addr, u32 cfg_data); void fsl_pci_config_unlock(struct pci_controller *hose); void ft_fsl_pci_setup(void *blob, const char *pci_alias,
From: Kumar Gala [mailto:galak@kernel.crashing.org] Sent: Wednesday, November 04, 2009 1:14 PM To: Swarthout Edward L-SWARTHOU; Mahajan Vivek-B08308 Cc: u-boot@lists.denx.de Subject: [PATCH v2] fsl_pci_init_port end-point initialization is broken
Works fine on P2020RDB host/agent virtual network scenario pending that hold off linux bringup on the PCIe host.
- k
Thanks, Vivek
Kumar Gala
