[U-Boot] [PATCH 4/9 V3] convert all at91 files to use at91_gpio driver syntax
* convert all files cpu/../at91 to use at91_gpio driver syntax * change AT91_PINP([A-F])(\d+) to AT91_PORTPIN(\1, \2), this makes all 160 AT91_PINPxxx defines obsolete * AT91_PINPxxx defines can be remove if all boards converted to new SoC access
Signed-off-by: Jens Scharsig js_at_ng@scharsoft.de --- cpu/arm926ejs/at91/at91cap9_devices.c | 100 +++++++++++++------------- cpu/arm926ejs/at91/at91sam9260_devices.c | 100 +++++++++++++------------- cpu/arm926ejs/at91/at91sam9261_devices.c | 60 ++++++++-------- cpu/arm926ejs/at91/at91sam9263_devices.c | 104 +++++++++++++------------- cpu/arm926ejs/at91/at91sam9m10g45_devices.c | 96 ++++++++++++------------ cpu/arm926ejs/at91/at91sam9rl_devices.c | 38 +++++----- 6 files changed, 249 insertions(+), 249 deletions(-)
diff --git a/cpu/arm926ejs/at91/at91cap9_devices.c b/cpu/arm926ejs/at91/at91cap9_devices.c index 39e405f..c41e139 100644 --- a/cpu/arm926ejs/at91/at91cap9_devices.c +++ b/cpu/arm926ejs/at91/at91cap9_devices.c @@ -34,29 +34,29 @@
void at91_serial0_hw_init(void) { - at91_set_A_periph(AT91_PIN_PA22, 1); /* TXD0 */ - at91_set_A_periph(AT91_PIN_PA23, 0); /* RXD0 */ + at91_set_a_periph(AT91_PORTPIN(A, 22), 1); /* TXD0 */ + at91_set_a_periph(AT91_PORTPIN(A, 23), 0); /* RXD0 */ at91_sys_write(AT91_PMC_PCER, 1 << AT91CAP9_ID_US0); }
void at91_serial1_hw_init(void) { - at91_set_A_periph(AT91_PIN_PD0, 1); /* TXD1 */ - at91_set_A_periph(AT91_PIN_PD1, 0); /* RXD1 */ + at91_set_a_periph(AT91_PORTPIN(D, 0), 1); /* TXD1 */ + at91_set_a_periph(AT91_PORTPIN(D, 1), 0); /* RXD1 */ at91_sys_write(AT91_PMC_PCER, 1 << AT91CAP9_ID_US1); }
void at91_serial2_hw_init(void) { - at91_set_A_periph(AT91_PIN_PD2, 1); /* TXD2 */ - at91_set_A_periph(AT91_PIN_PD3, 0); /* RXD2 */ + at91_set_a_periph(AT91_PORTPIN(D, 2), 1); /* TXD2 */ + at91_set_a_periph(AT91_PORTPIN(D, 3), 0); /* RXD2 */ at91_sys_write(AT91_PMC_PCER, 1 << AT91CAP9_ID_US2); }
void at91_serial3_hw_init(void) { - at91_set_A_periph(AT91_PIN_PC30, 0); /* DRXD */ - at91_set_A_periph(AT91_PIN_PC31, 1); /* DTXD */ + at91_set_a_periph(AT91_PORTPIN(C, 30), 0); /* DRXD */ + at91_set_a_periph(AT91_PORTPIN(C, 31), 1); /* DTXD */ at91_sys_write(AT91_PMC_PCER, 1 << AT91_ID_SYS); }
@@ -82,71 +82,71 @@ void at91_serial_hw_init(void) #ifdef CONFIG_HAS_DATAFLASH void at91_spi0_hw_init(unsigned long cs_mask) { - at91_set_B_periph(AT91_PIN_PA0, 0); /* SPI0_MISO */ - at91_set_B_periph(AT91_PIN_PA1, 0); /* SPI0_MOSI */ - at91_set_B_periph(AT91_PIN_PA2, 0); /* SPI0_SPCK */ + at91_set_b_periph(AT91_PORTPIN(A, 0), 0); /* SPI0_MISO */ + at91_set_b_periph(AT91_PORTPIN(A, 1), 0); /* SPI0_MOSI */ + at91_set_b_periph(AT91_PORTPIN(A, 2), 0); /* SPI0_SPCK */
/* Enable clock */ at91_sys_write(AT91_PMC_PCER, 1 << AT91CAP9_ID_SPI0);
if (cs_mask & (1 << 0)) { - at91_set_B_periph(AT91_PIN_PA5, 1); + at91_set_b_periph(AT91_PORTPIN(A, 5), 1); } if (cs_mask & (1 << 1)) { - at91_set_B_periph(AT91_PIN_PA3, 1); + at91_set_b_periph(AT91_PORTPIN(A, 3), 1); } if (cs_mask & (1 << 2)) { - at91_set_B_periph(AT91_PIN_PD0, 1); + at91_set_b_periph(AT91_PORTPIN(D, 0), 1); } if (cs_mask & (1 << 3)) { - at91_set_B_periph(AT91_PIN_PD1, 1); + at91_set_b_periph(AT91_PORTPIN(D, 1), 1); } if (cs_mask & (1 << 4)) { - at91_set_gpio_output(AT91_PIN_PA5, 1); + at91_set_gpio_output(AT91_PORTPIN(A, 5), 1); } if (cs_mask & (1 << 5)) { - at91_set_gpio_output(AT91_PIN_PA3, 1); + at91_set_gpio_output(AT91_PORTPIN(A, 3), 1); } if (cs_mask & (1 << 6)) { - at91_set_gpio_output(AT91_PIN_PD0, 1); + at91_set_gpio_output(AT91_PORTPIN(D, 0), 1); } if (cs_mask & (1 << 7)) { - at91_set_gpio_output(AT91_PIN_PD1, 1); + at91_set_gpio_output(AT91_PORTPIN(D, 1), 1); } }
void at91_spi1_hw_init(unsigned long cs_mask) { - at91_set_A_periph(AT91_PIN_PB12, 0); /* SPI1_MISO */ - at91_set_A_periph(AT91_PIN_PB13, 0); /* SPI1_MOSI */ - at91_set_A_periph(AT91_PIN_PB14, 0); /* SPI1_SPCK */ + at91_set_a_periph(AT91_PORTPIN(B, 12), 0); /* SPI1_MISO */ + at91_set_a_periph(AT91_PORTPIN(B, 13), 0); /* SPI1_MOSI */ + at91_set_a_periph(AT91_PORTPIN(B, 14), 0); /* SPI1_SPCK */
/* Enable clock */ at91_sys_write(AT91_PMC_PCER, 1 << AT91CAP9_ID_SPI1);
if (cs_mask & (1 << 0)) { - at91_set_A_periph(AT91_PIN_PB15, 1); + at91_set_a_periph(AT91_PORTPIN(B, 15), 1); } if (cs_mask & (1 << 1)) { - at91_set_A_periph(AT91_PIN_PB16, 1); + at91_set_a_periph(AT91_PORTPIN(B, 16), 1); } if (cs_mask & (1 << 2)) { - at91_set_A_periph(AT91_PIN_PB17, 1); + at91_set_a_periph(AT91_PORTPIN(B, 17), 1); } if (cs_mask & (1 << 3)) { - at91_set_A_periph(AT91_PIN_PB18, 1); + at91_set_a_periph(AT91_PORTPIN(B, 18), 1); } if (cs_mask & (1 << 4)) { - at91_set_gpio_output(AT91_PIN_PB15, 1); + at91_set_gpio_output(AT91_PORTPIN(B, 15), 1); } if (cs_mask & (1 << 5)) { - at91_set_gpio_output(AT91_PIN_PB16, 1); + at91_set_gpio_output(AT91_PORTPIN(B, 16), 1); } if (cs_mask & (1 << 6)) { - at91_set_gpio_output(AT91_PIN_PB17, 1); + at91_set_gpio_output(AT91_PORTPIN(B, 17), 1); } if (cs_mask & (1 << 7)) { - at91_set_gpio_output(AT91_PIN_PB18, 1); + at91_set_gpio_output(AT91_PORTPIN(B, 18), 1); }
} @@ -155,26 +155,26 @@ void at91_spi1_hw_init(unsigned long cs_mask) #ifdef CONFIG_MACB void at91_macb_hw_init(void) { - at91_set_A_periph(AT91_PIN_PB21, 0); /* ETXCK_EREFCK */ - at91_set_A_periph(AT91_PIN_PB22, 0); /* ERXDV */ - at91_set_A_periph(AT91_PIN_PB25, 0); /* ERX0 */ - at91_set_A_periph(AT91_PIN_PB26, 0); /* ERX1 */ - at91_set_A_periph(AT91_PIN_PB27, 0); /* ERXER */ - at91_set_A_periph(AT91_PIN_PB28, 0); /* ETXEN */ - at91_set_A_periph(AT91_PIN_PB23, 0); /* ETX0 */ - at91_set_A_periph(AT91_PIN_PB24, 0); /* ETX1 */ - at91_set_A_periph(AT91_PIN_PB30, 0); /* EMDIO */ - at91_set_A_periph(AT91_PIN_PB29, 0); /* EMDC */ + at91_set_a_periph(AT91_PORTPIN(B, 21), 0); /* ETXCK_EREFCK */ + at91_set_a_periph(AT91_PORTPIN(B, 22), 0); /* ERXDV */ + at91_set_a_periph(AT91_PORTPIN(B, 25), 0); /* ERX0 */ + at91_set_a_periph(AT91_PORTPIN(B, 26), 0); /* ERX1 */ + at91_set_a_periph(AT91_PORTPIN(B, 27), 0); /* ERXER */ + at91_set_a_periph(AT91_PORTPIN(B, 28), 0); /* ETXEN */ + at91_set_a_periph(AT91_PORTPIN(B, 23), 0); /* ETX0 */ + at91_set_a_periph(AT91_PORTPIN(B, 24), 0); /* ETX1 */ + at91_set_a_periph(AT91_PORTPIN(B, 30), 0); /* EMDIO */ + at91_set_a_periph(AT91_PORTPIN(B, 29), 0); /* EMDC */
#ifndef CONFIG_RMII - at91_set_B_periph(AT91_PIN_PC25, 0); /* ECRS */ - at91_set_B_periph(AT91_PIN_PC26, 0); /* ECOL */ - at91_set_B_periph(AT91_PIN_PC22, 0); /* ERX2 */ - at91_set_B_periph(AT91_PIN_PC23, 0); /* ERX3 */ - at91_set_B_periph(AT91_PIN_PC27, 0); /* ERXCK */ - at91_set_B_periph(AT91_PIN_PC20, 0); /* ETX2 */ - at91_set_B_periph(AT91_PIN_PC21, 0); /* ETX3 */ - at91_set_B_periph(AT91_PIN_PC24, 0); /* ETXER */ + at91_set_b_periph(AT91_PORTPIN(C, 25), 0); /* ECRS */ + at91_set_b_periph(AT91_PORTPIN(C, 26), 0); /* ECOL */ + at91_set_b_periph(AT91_PORTPIN(C, 22), 0); /* ERX2 */ + at91_set_b_periph(AT91_PORTPIN(C, 23), 0); /* ERX3 */ + at91_set_b_periph(AT91_PORTPIN(C, 27), 0); /* ERXCK */ + at91_set_b_periph(AT91_PORTPIN(C, 20), 0); /* ETX2 */ + at91_set_b_periph(AT91_PORTPIN(C, 21), 0); /* ETX3 */ + at91_set_b_periph(AT91_PORTPIN(C, 24), 0); /* ETXER */ #endif } #endif @@ -182,8 +182,8 @@ void at91_macb_hw_init(void) #ifdef CONFIG_AT91_CAN void at91_can_hw_init(void) { - at91_set_A_periph(AT91_PIN_PA12, 0); /* CAN_TX */ - at91_set_A_periph(AT91_PIN_PA13, 1); /* CAN_RX */ + at91_set_a_periph(AT91_PORTPIN(A, 12), 0); /* CAN_TX */ + at91_set_a_periph(AT91_PORTPIN(A, 13), 1); /* CAN_RX */
/* Enable clock */ at91_sys_write(AT91_PMC_PCER, 1 << AT91CAP9_ID_CAN); diff --git a/cpu/arm926ejs/at91/at91sam9260_devices.c b/cpu/arm926ejs/at91/at91sam9260_devices.c index f86cb99..d7d6f49 100644 --- a/cpu/arm926ejs/at91/at91sam9260_devices.c +++ b/cpu/arm926ejs/at91/at91sam9260_devices.c @@ -30,29 +30,29 @@
void at91_serial0_hw_init(void) { - at91_set_A_periph(AT91_PIN_PB4, 1); /* TXD0 */ - at91_set_A_periph(AT91_PIN_PB5, 0); /* RXD0 */ + at91_set_A_periph(AT91_PORTPIN(B, 4), 1); /* TXD0 */ + at91_set_A_periph(AT91_PORTPIN(B, 5), 0); /* RXD0 */ at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9260_ID_US0); }
void at91_serial1_hw_init(void) { - at91_set_A_periph(AT91_PIN_PB6, 1); /* TXD1 */ - at91_set_A_periph(AT91_PIN_PB7, 0); /* RXD1 */ + at91_set_A_periph(AT91_PORTPIN(B, 6), 1); /* TXD1 */ + at91_set_A_periph(AT91_PORTPIN(B, 7), 0); /* RXD1 */ at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9260_ID_US1); }
void at91_serial2_hw_init(void) { - at91_set_A_periph(AT91_PIN_PB8, 1); /* TXD2 */ - at91_set_A_periph(AT91_PIN_PB9, 0); /* RXD2 */ + at91_set_A_periph(AT91_PORTPIN(B, 8), 1); /* TXD2 */ + at91_set_A_periph(AT91_PORTPIN(B, 9), 0); /* RXD2 */ at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9260_ID_US2); }
void at91_serial3_hw_init(void) { - at91_set_A_periph(AT91_PIN_PB14, 0); /* DRXD */ - at91_set_A_periph(AT91_PIN_PB15, 1); /* DTXD */ + at91_set_A_periph(AT91_PORTPIN(B, 14), 0); /* DRXD */ + at91_set_A_periph(AT91_PORTPIN(B, 15), 1); /* DTXD */ at91_sys_write(AT91_PMC_PCER, 1 << AT91_ID_SYS); }
@@ -78,71 +78,71 @@ void at91_serial_hw_init(void) #if defined(CONFIG_HAS_DATAFLASH) || defined(CONFIG_ATMEL_SPI) void at91_spi0_hw_init(unsigned long cs_mask) { - at91_set_A_periph(AT91_PIN_PA0, 0); /* SPI0_MISO */ - at91_set_A_periph(AT91_PIN_PA1, 0); /* SPI0_MOSI */ - at91_set_A_periph(AT91_PIN_PA2, 0); /* SPI0_SPCK */ + at91_set_A_periph(AT91_PORTPIN(A, 0), 0); /* SPI0_MISO */ + at91_set_A_periph(AT91_PORTPIN(A, 1), 0); /* SPI0_MOSI */ + at91_set_A_periph(AT91_PORTPIN(A, 2), 0); /* SPI0_SPCK */
/* Enable clock */ at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9260_ID_SPI0);
if (cs_mask & (1 << 0)) { - at91_set_A_periph(AT91_PIN_PA3, 1); + at91_set_A_periph(AT91_PORTPIN(A, 3), 1); } if (cs_mask & (1 << 1)) { - at91_set_B_periph(AT91_PIN_PC11, 1); + at91_set_B_periph(AT91_PORTPIN(C, 11), 1); } if (cs_mask & (1 << 2)) { - at91_set_B_periph(AT91_PIN_PC16, 1); + at91_set_B_periph(AT91_PORTPIN(C, 16), 1); } if (cs_mask & (1 << 3)) { - at91_set_B_periph(AT91_PIN_PC17, 1); + at91_set_B_periph(AT91_PORTPIN(C, 17), 1); } if (cs_mask & (1 << 4)) { - at91_set_gpio_output(AT91_PIN_PA3, 1); + at91_set_gpio_output(AT91_PORTPIN(A, 3), 1); } if (cs_mask & (1 << 5)) { - at91_set_gpio_output(AT91_PIN_PC11, 1); + at91_set_gpio_output(AT91_PORTPIN(C, 11), 1); } if (cs_mask & (1 << 6)) { - at91_set_gpio_output(AT91_PIN_PC16, 1); + at91_set_gpio_output(AT91_PORTPIN(C, 16), 1); } if (cs_mask & (1 << 7)) { - at91_set_gpio_output(AT91_PIN_PC17, 1); + at91_set_gpio_output(AT91_PORTPIN(C, 17), 1); } }
void at91_spi1_hw_init(unsigned long cs_mask) { - at91_set_A_periph(AT91_PIN_PB0, 0); /* SPI1_MISO */ - at91_set_A_periph(AT91_PIN_PB1, 0); /* SPI1_MOSI */ - at91_set_A_periph(AT91_PIN_PB2, 0); /* SPI1_SPCK */ + at91_set_A_periph(AT91_PORTPIN(B, 0), 0); /* SPI1_MISO */ + at91_set_A_periph(AT91_PORTPIN(B, 1), 0); /* SPI1_MOSI */ + at91_set_A_periph(AT91_PORTPIN(B, 2), 0); /* SPI1_SPCK */
/* Enable clock */ at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9260_ID_SPI1);
if (cs_mask & (1 << 0)) { - at91_set_A_periph(AT91_PIN_PB3, 1); + at91_set_A_periph(AT91_PORTPIN(B, 3), 1); } if (cs_mask & (1 << 1)) { - at91_set_B_periph(AT91_PIN_PC5, 1); + at91_set_B_periph(AT91_PORTPIN(C, 5), 1); } if (cs_mask & (1 << 2)) { - at91_set_B_periph(AT91_PIN_PC4, 1); + at91_set_B_periph(AT91_PORTPIN(C, 4), 1); } if (cs_mask & (1 << 3)) { - at91_set_gpio_output(AT91_PIN_PC3, 1); + at91_set_gpio_output(AT91_PORTPIN(C, 3), 1); } if (cs_mask & (1 << 4)) { - at91_set_gpio_output(AT91_PIN_PB3, 1); + at91_set_gpio_output(AT91_PORTPIN(B, 3), 1); } if (cs_mask & (1 << 5)) { - at91_set_gpio_output(AT91_PIN_PC5, 1); + at91_set_gpio_output(AT91_PORTPIN(C, 5), 1); } if (cs_mask & (1 << 6)) { - at91_set_gpio_output(AT91_PIN_PC4, 1); + at91_set_gpio_output(AT91_PORTPIN(C, 4), 1); } if (cs_mask & (1 << 7)) { - at91_set_gpio_output(AT91_PIN_PC3, 1); + at91_set_gpio_output(AT91_PORTPIN(C, 3), 1); } } #endif @@ -150,35 +150,35 @@ void at91_spi1_hw_init(unsigned long cs_mask) #ifdef CONFIG_MACB void at91_macb_hw_init(void) { - at91_set_A_periph(AT91_PIN_PA19, 0); /* ETXCK_EREFCK */ - at91_set_A_periph(AT91_PIN_PA17, 0); /* ERXDV */ - at91_set_A_periph(AT91_PIN_PA14, 0); /* ERX0 */ - at91_set_A_periph(AT91_PIN_PA15, 0); /* ERX1 */ - at91_set_A_periph(AT91_PIN_PA18, 0); /* ERXER */ - at91_set_A_periph(AT91_PIN_PA16, 0); /* ETXEN */ - at91_set_A_periph(AT91_PIN_PA12, 0); /* ETX0 */ - at91_set_A_periph(AT91_PIN_PA13, 0); /* ETX1 */ - at91_set_A_periph(AT91_PIN_PA21, 0); /* EMDIO */ - at91_set_A_periph(AT91_PIN_PA20, 0); /* EMDC */ + at91_set_A_periph(AT91_PORTPIN(A, 19), 0); /* ETXCK_EREFCK */ + at91_set_A_periph(AT91_PORTPIN(A, 17), 0); /* ERXDV */ + at91_set_A_periph(AT91_PORTPIN(A, 14), 0); /* ERX0 */ + at91_set_A_periph(AT91_PORTPIN(A, 15), 0); /* ERX1 */ + at91_set_A_periph(AT91_PORTPIN(A, 18), 0); /* ERXER */ + at91_set_A_periph(AT91_PORTPIN(A, 16), 0); /* ETXEN */ + at91_set_A_periph(AT91_PORTPIN(A, 12), 0); /* ETX0 */ + at91_set_A_periph(AT91_PORTPIN(A, 13), 0); /* ETX1 */ + at91_set_A_periph(AT91_PORTPIN(A, 21), 0); /* EMDIO */ + at91_set_A_periph(AT91_PORTPIN(A, 20), 0); /* EMDC */
#ifndef CONFIG_RMII - at91_set_B_periph(AT91_PIN_PA28, 0); /* ECRS */ - at91_set_B_periph(AT91_PIN_PA29, 0); /* ECOL */ - at91_set_B_periph(AT91_PIN_PA25, 0); /* ERX2 */ - at91_set_B_periph(AT91_PIN_PA26, 0); /* ERX3 */ - at91_set_B_periph(AT91_PIN_PA27, 0); /* ERXCK */ + at91_set_B_periph(AT91_PORTPIN(A, 28), 0); /* ECRS */ + at91_set_B_periph(AT91_PORTPIN(A, 29), 0); /* ECOL */ + at91_set_B_periph(AT91_PORTPIN(A, 25), 0); /* ERX2 */ + at91_set_B_periph(AT91_PORTPIN(A, 26), 0); /* ERX3 */ + at91_set_B_periph(AT91_PORTPIN(A, 27), 0); /* ERXCK */ #if defined(CONFIG_AT91SAM9260EK) || defined(CONFIG_AFEB9260) /* * use PA10, PA11 for ETX2, ETX3. * PA23 and PA24 are for TWI EEPROM */ - at91_set_B_periph(AT91_PIN_PA10, 0); /* ETX2 */ - at91_set_B_periph(AT91_PIN_PA11, 0); /* ETX3 */ + at91_set_B_periph(AT91_PORTPIN(A, 10), 0); /* ETX2 */ + at91_set_B_periph(AT91_PORTPIN(A, 11), 0); /* ETX3 */ #else - at91_set_B_periph(AT91_PIN_PA23, 0); /* ETX2 */ - at91_set_B_periph(AT91_PIN_PA24, 0); /* ETX3 */ + at91_set_B_periph(AT91_PORTPIN(A, 23), 0); /* ETX2 */ + at91_set_B_periph(AT91_PORTPIN(A, 24), 0); /* ETX3 */ #endif - at91_set_B_periph(AT91_PIN_PA22, 0); /* ETXER */ + at91_set_B_periph(AT91_PORTPIN(A, 22), 0); /* ETXER */ #endif } #endif diff --git a/cpu/arm926ejs/at91/at91sam9261_devices.c b/cpu/arm926ejs/at91/at91sam9261_devices.c index 16d411f..9112ccb 100644 --- a/cpu/arm926ejs/at91/at91sam9261_devices.c +++ b/cpu/arm926ejs/at91/at91sam9261_devices.c @@ -30,29 +30,29 @@
void at91_serial0_hw_init(void) { - at91_set_A_periph(AT91_PIN_PC8, 1); /* TXD0 */ - at91_set_A_periph(AT91_PIN_PC9, 0); /* RXD0 */ + at91_set_a_periph(AT91_PORTPIN(C, 8), 1); /* TXD0 */ + at91_set_a_periph(AT91_PORTPIN(C, 9), 0); /* RXD0 */ at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9261_ID_US0); }
void at91_serial1_hw_init(void) { - at91_set_A_periph(AT91_PIN_PC12, 1); /* TXD1 */ - at91_set_A_periph(AT91_PIN_PC13, 0); /* RXD1 */ + at91_set_a_periph(AT91_PORTPIN(C, 12), 1); /* TXD1 */ + at91_set_a_periph(AT91_PORTPIN(C, 13), 0); /* RXD1 */ at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9261_ID_US1); }
void at91_serial2_hw_init(void) { - at91_set_A_periph(AT91_PIN_PC14, 1); /* TXD2 */ - at91_set_A_periph(AT91_PIN_PC15, 0); /* RXD2 */ + at91_set_a_periph(AT91_PORTPIN(C, 14), 1); /* TXD2 */ + at91_set_a_periph(AT91_PORTPIN(C, 15), 0); /* RXD2 */ at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9261_ID_US2); }
void at91_serial3_hw_init(void) { - at91_set_A_periph(AT91_PIN_PA9, 0); /* DRXD */ - at91_set_A_periph(AT91_PIN_PA10, 1); /* DTXD */ + at91_set_a_periph(AT91_PORTPIN(A, 9), 0); /* DRXD */ + at91_set_a_periph(AT91_PORTPIN(A, 10), 1); /* DTXD */ at91_sys_write(AT91_PMC_PCER, 1 << AT91_ID_SYS); }
@@ -78,71 +78,71 @@ void at91_serial_hw_init(void) #ifdef CONFIG_HAS_DATAFLASH void at91_spi0_hw_init(unsigned long cs_mask) { - at91_set_A_periph(AT91_PIN_PA0, 0); /* SPI0_MISO */ - at91_set_A_periph(AT91_PIN_PA1, 0); /* SPI0_MOSI */ - at91_set_A_periph(AT91_PIN_PA2, 0); /* SPI0_SPCK */ + at91_set_a_periph(AT91_PORTPIN(A, 0), 0); /* SPI0_MISO */ + at91_set_a_periph(AT91_PORTPIN(A, 1), 0); /* SPI0_MOSI */ + at91_set_a_periph(AT91_PORTPIN(A, 2), 0); /* SPI0_SPCK */
/* Enable clock */ at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9261_ID_SPI0);
if (cs_mask & (1 << 0)) { - at91_set_A_periph(AT91_PIN_PA3, 1); + at91_set_a_periph(AT91_PORTPIN(A, 3), 1); } if (cs_mask & (1 << 1)) { - at91_set_A_periph(AT91_PIN_PA4, 1); + at91_set_a_periph(AT91_PORTPIN(A, 4), 1); } if (cs_mask & (1 << 2)) { - at91_set_A_periph(AT91_PIN_PA5, 1); + at91_set_a_periph(AT91_PORTPIN(A, 5), 1); } if (cs_mask & (1 << 3)) { - at91_set_A_periph(AT91_PIN_PA6, 1); + at91_set_a_periph(AT91_PORTPIN(A, 6), 1); } if (cs_mask & (1 << 4)) { - at91_set_gpio_output(AT91_PIN_PA3, 1); + at91_set_gpio_output(AT91_PORTPIN(A, 3), 1); } if (cs_mask & (1 << 5)) { - at91_set_gpio_output(AT91_PIN_PA4, 1); + at91_set_gpio_output(AT91_PORTPIN(A, 4), 1); } if (cs_mask & (1 << 6)) { - at91_set_gpio_output(AT91_PIN_PA5, 1); + at91_set_gpio_output(AT91_PORTPIN(A, 5), 1); } if (cs_mask & (1 << 7)) { - at91_set_gpio_output(AT91_PIN_PA6, 1); + at91_set_gpio_output(AT91_PORTPIN(A, 6), 1); } }
void at91_spi1_hw_init(unsigned long cs_mask) { - at91_set_A_periph(AT91_PIN_PB30, 0); /* SPI1_MISO */ - at91_set_A_periph(AT91_PIN_PB31, 0); /* SPI1_MOSI */ - at91_set_A_periph(AT91_PIN_PB29, 0); /* SPI1_SPCK */ + at91_set_a_periph(AT91_PORTPIN(B, 30), 0); /* SPI1_MISO */ + at91_set_a_periph(AT91_PORTPIN(B, 31), 0); /* SPI1_MOSI */ + at91_set_a_periph(AT91_PORTPIN(B, 29), 0); /* SPI1_SPCK */
/* Enable clock */ at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9261_ID_SPI1);
if (cs_mask & (1 << 0)) { - at91_set_A_periph(AT91_PIN_PB28, 1); + at91_set_a_periph(AT91_PORTPIN(B, 28), 1); } if (cs_mask & (1 << 1)) { - at91_set_B_periph(AT91_PIN_PA24, 1); + at91_set_b_periph(AT91_PORTPIN(A, 24), 1); } if (cs_mask & (1 << 2)) { - at91_set_B_periph(AT91_PIN_PA25, 1); + at91_set_b_periph(AT91_PORTPIN(A, 25), 1); } if (cs_mask & (1 << 3)) { - at91_set_A_periph(AT91_PIN_PA26, 1); + at91_set_a_periph(AT91_PORTPIN(A, 26), 1); } if (cs_mask & (1 << 4)) { - at91_set_gpio_output(AT91_PIN_PB28, 1); + at91_set_gpio_output(AT91_PORTPIN(B, 28), 1); } if (cs_mask & (1 << 5)) { - at91_set_gpio_output(AT91_PIN_PA24, 1); + at91_set_gpio_output(AT91_PORTPIN(A, 24), 1); } if (cs_mask & (1 << 6)) { - at91_set_gpio_output(AT91_PIN_PA25, 1); + at91_set_gpio_output(AT91_PORTPIN(A, 25), 1); } if (cs_mask & (1 << 7)) { - at91_set_gpio_output(AT91_PIN_PA26, 1); + at91_set_gpio_output(AT91_PORTPIN(A, 26), 1); } } #endif diff --git a/cpu/arm926ejs/at91/at91sam9263_devices.c b/cpu/arm926ejs/at91/at91sam9263_devices.c index f72efdf..eb56ebf 100644 --- a/cpu/arm926ejs/at91/at91sam9263_devices.c +++ b/cpu/arm926ejs/at91/at91sam9263_devices.c @@ -34,29 +34,29 @@
void at91_serial0_hw_init(void) { - at91_set_A_periph(AT91_PIN_PA26, 1); /* TXD0 */ - at91_set_A_periph(AT91_PIN_PA27, 0); /* RXD0 */ + at91_set_a_periph(AT91_PORTPIN(A, 26), 1); /* TXD0 */ + at91_set_a_periph(AT91_PORTPIN(A, 27), 0); /* RXD0 */ at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9263_ID_US0); }
void at91_serial1_hw_init(void) { - at91_set_A_periph(AT91_PIN_PD0, 1); /* TXD1 */ - at91_set_A_periph(AT91_PIN_PD1, 0); /* RXD1 */ + at91_set_a_periph(AT91_PORTPIN(D, 0), 1); /* TXD1 */ + at91_set_a_periph(AT91_PORTPIN(D, 1), 0); /* RXD1 */ at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9263_ID_US1); }
void at91_serial2_hw_init(void) { - at91_set_A_periph(AT91_PIN_PD2, 1); /* TXD2 */ - at91_set_A_periph(AT91_PIN_PD3, 0); /* RXD2 */ + at91_set_a_periph(AT91_PORTPIN(D, 2), 1); /* TXD2 */ + at91_set_a_periph(AT91_PORTPIN(D, 3), 0); /* RXD2 */ at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9263_ID_US2); }
/* Enable clock */ at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9263_ID_SPI0);
if (cs_mask & (1 << 0)) { - at91_set_B_periph(AT91_PIN_PA5, 1); + at91_set_b_periph(AT91_PORTPIN(A, 5), 1); } if (cs_mask & (1 << 1)) { - at91_set_B_periph(AT91_PIN_PA3, 1); + at91_set_b_periph(AT91_PORTPIN(A, 3), 1); } if (cs_mask & (1 << 2)) { - at91_set_B_periph(AT91_PIN_PA4, 1); + at91_set_b_periph(AT91_PORTPIN(A, 4), 1); } if (cs_mask & (1 << 3)) { - at91_set_B_periph(AT91_PIN_PB11, 1); + at91_set_b_periph(AT91_PORTPIN(B, 11), 1); } if (cs_mask & (1 << 4)) { - at91_set_gpio_output(AT91_PIN_PA5, 1); + at91_set_gpio_output(AT91_PORTPIN(A, 5), 1); } if (cs_mask & (1 << 5)) { - at91_set_gpio_output(AT91_PIN_PA3, 1); + at91_set_gpio_output(AT91_PORTPIN(A, 3), 1); } if (cs_mask & (1 << 6)) { - at91_set_gpio_output(AT91_PIN_PA4, 1); + at91_set_gpio_output(AT91_PORTPIN(A, 4), 1); } if (cs_mask & (1 << 7)) { - at91_set_gpio_output(AT91_PIN_PB11, 1); + at91_set_gpio_output(AT91_PORTPIN(B, 11), 1); } }
/* Enable clock */ at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9263_ID_SPI1);
if (cs_mask & (1 << 0)) { - at91_set_A_periph(AT91_PIN_PB15, 1); + at91_set_a_periph(AT91_PORTPIN(B, 15), 1); } if (cs_mask & (1 << 1)) { - at91_set_A_periph(AT91_PIN_PB16, 1); + at91_set_a_periph(AT91_PORTPIN(B, 16), 1); } if (cs_mask & (1 << 2)) { - at91_set_A_periph(AT91_PIN_PB17, 1); + at91_set_a_periph(AT91_PORTPIN(B, 17), 1); } if (cs_mask & (1 << 3)) { - at91_set_A_periph(AT91_PIN_PB18, 1); + at91_set_a_periph(AT91_PORTPIN(B, 18), 1); } if (cs_mask & (1 << 4)) { - at91_set_gpio_output(AT91_PIN_PB15, 1); + at91_set_gpio_output(AT91_PORTPIN(B, 15), 1); } if (cs_mask & (1 << 5)) { - at91_set_gpio_output(AT91_PIN_PB16, 1); + at91_set_gpio_output(AT91_PORTPIN(B, 16), 1); } if (cs_mask & (1 << 6)) { - at91_set_gpio_output(AT91_PIN_PB17, 1); + at91_set_gpio_output(AT91_PORTPIN(B, 17), 1); } if (cs_mask & (1 << 7)) { - at91_set_gpio_output(AT91_PIN_PB18, 1); + at91_set_gpio_output(AT91_PORTPIN(B, 18), 1); } } #endif @@ -154,26 +154,26 @@ void at91_spi1_hw_init(unsigned long cs_mask) #ifdef CONFIG_MACB void at91_macb_hw_init(void) { - at91_set_A_periph(AT91_PIN_PE21, 0); /* ETXCK_EREFCK */ - at91_set_B_periph(AT91_PIN_PC25, 0); /* ERXDV */ - at91_set_A_periph(AT91_PIN_PE25, 0); /* ERX0 */ - at91_set_A_periph(AT91_PIN_PE26, 0); /* ERX1 */ - at91_set_A_periph(AT91_PIN_PE27, 0); /* ERXER */ - at91_set_A_periph(AT91_PIN_PE28, 0); /* ETXEN */ - at91_set_A_periph(AT91_PIN_PE23, 0); /* ETX0 */ - at91_set_A_periph(AT91_PIN_PE24, 0); /* ETX1 */ - at91_set_A_periph(AT91_PIN_PE30, 0); /* EMDIO */ - at91_set_A_periph(AT91_PIN_PE29, 0); /* EMDC */ + at91_set_a_periph(AT91_PORTPIN(E, 21), 0); /* ETXCK_EREFCK */ + at91_set_b_periph(AT91_PORTPIN(C, 25), 0); /* ERXDV */ + at91_set_a_periph(AT91_PORTPIN(E, 25), 0); /* ERX0 */ + at91_set_a_periph(AT91_PORTPIN(E, 26), 0); /* ERX1 */ + at91_set_a_periph(AT91_PORTPIN(E, 27), 0); /* ERXER */ + at91_set_a_periph(AT91_PORTPIN(E, 28), 0); /* ETXEN */ + at91_set_a_periph(AT91_PORTPIN(E, 23), 0); /* ETX0 */ + at91_set_a_periph(AT91_PORTPIN(E, 24), 0); /* ETX1 */ + at91_set_a_periph(AT91_PORTPIN(E, 30), 0); /* EMDIO */ + at91_set_a_periph(AT91_PORTPIN(E, 29), 0); /* EMDC */
#ifndef CONFIG_RMII - at91_set_A_periph(AT91_PIN_PE22, 0); /* ECRS */ - at91_set_B_periph(AT91_PIN_PC26, 0); /* ECOL */ - at91_set_B_periph(AT91_PIN_PC22, 0); /* ERX2 */ - at91_set_B_periph(AT91_PIN_PC23, 0); /* ERX3 */ - at91_set_B_periph(AT91_PIN_PC27, 0); /* ERXCK */ - at91_set_B_periph(AT91_PIN_PC20, 0); /* ETX2 */ - at91_set_B_periph(AT91_PIN_PC21, 0); /* ETX3 */ - at91_set_B_periph(AT91_PIN_PC24, 0); /* ETXER */ + at91_set_a_periph(AT91_PORTPIN(E, 22), 0); /* ECRS */ + at91_set_b_periph(AT91_PORTPIN(C, 26), 0); /* ECOL */ + at91_set_b_periph(AT91_PORTPIN(C, 22), 0); /* ERX2 */ + at91_set_b_periph(AT91_PORTPIN(C, 23), 0); /* ERX3 */ + at91_set_b_periph(AT91_PORTPIN(C, 27), 0); /* ERXCK */ + at91_set_b_periph(AT91_PORTPIN(C, 20), 0); /* ETX2 */ + at91_set_b_periph(AT91_PORTPIN(C, 21), 0); /* ETX3 */ + at91_set_b_periph(AT91_PORTPIN(C, 24), 0); /* ETXER */ #endif } #endif @@ -182,16 +182,16 @@ void at91_macb_hw_init(void) void at91_uhp_hw_init(void) { /* Enable VBus on UHP ports */ - at91_set_gpio_output(AT91_PIN_PA21, 0); - at91_set_gpio_output(AT91_PIN_PA24, 0); + at91_set_gpio_output(AT91_PORTPIN(A, 21), 0); + at91_set_gpio_output(AT91_PORTPIN(A, 24), 0); } #endif
#ifdef CONFIG_AT91_CAN void at91_can_hw_init(void) { - at91_set_A_periph(AT91_PIN_PA13, 0); /* CAN_TX */ - at91_set_A_periph(AT91_PIN_PA14, 1); /* CAN_RX */ + at91_set_a_periph(AT91_PORTPIN(A, 13), 0); /* CAN_TX */ + at91_set_a_periph(AT91_PORTPIN(A, 14), 1); /* CAN_RX */
/* Enable clock */ at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9263_ID_CAN); diff --git a/cpu/arm926ejs/at91/at91sam9m10g45_devices.c b/cpu/arm926ejs/at91/at91sam9m10g45_devices.c index 98d90f2..c3a2102 100644 --- a/cpu/arm926ejs/at91/at91sam9m10g45_devices.c +++ b/cpu/arm926ejs/at91/at91sam9m10g45_devices.c @@ -30,29 +30,29 @@
void at91_serial0_hw_init(void) { - at91_set_A_periph(AT91_PIN_PB19, 1); /* TXD0 */ - at91_set_A_periph(AT91_PIN_PB18, 0); /* RXD0 */ + at91_set_a_periph(AT91_PORTPIN(B, 19), 1); /* TXD0 */ + at91_set_a_periph(AT91_PORTPIN(B, 18), 0); /* RXD0 */ at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9G45_ID_US0); }
void at91_serial1_hw_init(void) { - at91_set_A_periph(AT91_PIN_PB4, 1); /* TXD1 */ - at91_set_A_periph(AT91_PIN_PB5, 0); /* RXD1 */ + at91_set_a_periph(AT91_PORTPIN(B, 4), 1); /* TXD1 */ + at91_set_a_periph(AT91_PORTPIN(B, 5), 0); /* RXD1 */ at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9G45_ID_US1); }
void at91_serial2_hw_init(void) { - at91_set_A_periph(AT91_PIN_PD6, 1); /* TXD2 */ - at91_set_A_periph(AT91_PIN_PD7, 0); /* RXD2 */ + at91_set_a_periph(AT91_PORTPIN(D, 6), 1); /* TXD2 */ + at91_set_a_periph(AT91_PORTPIN(D, 7), 0); /* RXD2 */ at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9G45_ID_US2); }
void at91_serial3_hw_init(void) { - at91_set_A_periph(AT91_PIN_PB12, 0); /* DRXD */ - at91_set_A_periph(AT91_PIN_PB13, 1); /* DTXD */ + at91_set_a_periph(AT91_PORTPIN(B, 12), 0); /* DRXD */ + at91_set_a_periph(AT91_PORTPIN(B, 13), 1); /* DTXD */ at91_sys_write(AT91_PMC_PCER, 1 << AT91_ID_SYS);; }
@@ -78,71 +78,71 @@ void at91_serial_hw_init(void) #ifdef CONFIG_ATMEL_SPI void at91_spi0_hw_init(unsigned long cs_mask) { - at91_set_A_periph(AT91_PIN_PB0, 0); /* SPI0_MISO */ - at91_set_A_periph(AT91_PIN_PB1, 0); /* SPI0_MOSI */ - at91_set_A_periph(AT91_PIN_PB2, 0); /* SPI0_SPCK */ + at91_set_a_periph(AT91_PORTPIN(B, 0), 0); /* SPI0_MISO */ + at91_set_a_periph(AT91_PORTPIN(B, 1), 0); /* SPI0_MOSI */ + at91_set_a_periph(AT91_PORTPIN(B, 2), 0); /* SPI0_SPCK */
/* Enable clock */ at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9G45_ID_SPI0);
if (cs_mask & (1 << 0)) { - at91_set_A_periph(AT91_PIN_PB3, 0); + at91_set_a_periph(AT91_PORTPIN(B, 3), 0); } if (cs_mask & (1 << 1)) { - at91_set_B_periph(AT91_PIN_PB18, 0); + at91_set_b_periph(AT91_PORTPIN(B, 18), 0); } if (cs_mask & (1 << 2)) { - at91_set_B_periph(AT91_PIN_PB19, 0); + at91_set_b_periph(AT91_PORTPIN(B, 19), 0); } if (cs_mask & (1 << 3)) { - at91_set_B_periph(AT91_PIN_PD27, 0); + at91_set_b_periph(AT91_PORTPIN(D, 27), 0); } if (cs_mask & (1 << 4)) { - at91_set_gpio_output(AT91_PIN_PB3, 0); + at91_set_gpio_output(AT91_PORTPIN(B, 3), 0); } if (cs_mask & (1 << 5)) { - at91_set_gpio_output(AT91_PIN_PB18, 0); + at91_set_gpio_output(AT91_PORTPIN(B, 18), 0); } if (cs_mask & (1 << 6)) { - at91_set_gpio_output(AT91_PIN_PB19, 0); + at91_set_gpio_output(AT91_PORTPIN(B, 19), 0); } if (cs_mask & (1 << 7)) { - at91_set_gpio_output(AT91_PIN_PD27, 0); + at91_set_gpio_output(AT91_PORTPIN(D, 27), 0); } }
void at91_spi1_hw_init(unsigned long cs_mask) { - at91_set_A_periph(AT91_PIN_PB14, 0); /* SPI1_MISO */ - at91_set_A_periph(AT91_PIN_PB15, 0); /* SPI1_MOSI */ - at91_set_A_periph(AT91_PIN_PB16, 0); /* SPI1_SPCK */ + at91_set_a_periph(AT91_PORTPIN(B, 14), 0); /* SPI1_MISO */ + at91_set_a_periph(AT91_PORTPIN(B, 15), 0); /* SPI1_MOSI */ + at91_set_a_periph(AT91_PORTPIN(B, 16), 0); /* SPI1_SPCK */
/* Enable clock */ at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9G45_ID_SPI1);
if (cs_mask & (1 << 0)) { - at91_set_A_periph(AT91_PIN_PB17, 0); + at91_set_a_periph(AT91_PORTPIN(B, 17), 0); } if (cs_mask & (1 << 1)) { - at91_set_B_periph(AT91_PIN_PD28, 0); + at91_set_b_periph(AT91_PORTPIN(D, 28), 0); } if (cs_mask & (1 << 2)) { - at91_set_A_periph(AT91_PIN_PD18, 0); + at91_set_a_periph(AT91_PORTPIN(D, 18), 0); } if (cs_mask & (1 << 3)) { - at91_set_A_periph(AT91_PIN_PD19, 0); + at91_set_a_periph(AT91_PORTPIN(D, 19), 0); } if (cs_mask & (1 << 4)) { - at91_set_gpio_output(AT91_PIN_PB17, 0); + at91_set_gpio_output(AT91_PORTPIN(B, 17), 0); } if (cs_mask & (1 << 5)) { - at91_set_gpio_output(AT91_PIN_PD28, 0); + at91_set_gpio_output(AT91_PORTPIN(D, 28), 0); } if (cs_mask & (1 << 6)) { - at91_set_gpio_output(AT91_PIN_PD18, 0); + at91_set_gpio_output(AT91_PORTPIN(D, 18), 0); } if (cs_mask & (1 << 7)) { - at91_set_gpio_output(AT91_PIN_PD19, 0); + at91_set_gpio_output(AT91_PORTPIN(D, 19), 0); }
} @@ -151,25 +151,25 @@ void at91_spi1_hw_init(unsigned long cs_mask) #ifdef CONFIG_MACB void at91_macb_hw_init(void) { - at91_set_A_periph(AT91_PIN_PA17, 0); /* ETXCK_EREFCK */ - at91_set_A_periph(AT91_PIN_PA15, 0); /* ERXDV */ - at91_set_A_periph(AT91_PIN_PA12, 0); /* ERX0 */ - at91_set_A_periph(AT91_PIN_PA13, 0); /* ERX1 */ - at91_set_A_periph(AT91_PIN_PA16, 0); /* ERXER */ - at91_set_A_periph(AT91_PIN_PA14, 0); /* ETXEN */ - at91_set_A_periph(AT91_PIN_PA10, 0); /* ETX0 */ - at91_set_A_periph(AT91_PIN_PA11, 0); /* ETX1 */ - at91_set_A_periph(AT91_PIN_PA19, 0); /* EMDIO */ - at91_set_A_periph(AT91_PIN_PA18, 0); /* EMDC */ + at91_set_a_periph(AT91_PORTPIN(A, 17), 0); /* ETXCK_EREFCK */ + at91_set_a_periph(AT91_PORTPIN(A, 15), 0); /* ERXDV */ + at91_set_a_periph(AT91_PORTPIN(A, 12), 0); /* ERX0 */ + at91_set_a_periph(AT91_PORTPIN(A, 13), 0); /* ERX1 */ + at91_set_a_periph(AT91_PORTPIN(A, 16), 0); /* ERXER */ + at91_set_a_periph(AT91_PORTPIN(A, 14), 0); /* ETXEN */ + at91_set_a_periph(AT91_PORTPIN(A, 10), 0); /* ETX0 */ + at91_set_a_periph(AT91_PORTPIN(A, 11), 0); /* ETX1 */ + at91_set_a_periph(AT91_PORTPIN(A, 19), 0); /* EMDIO */ + at91_set_a_periph(AT91_PORTPIN(A, 18), 0); /* EMDC */ #ifndef CONFIG_RMII - at91_set_B_periph(AT91_PIN_PA29, 0); /* ECRS */ - at91_set_B_periph(AT91_PIN_PA30, 0); /* ECOL */ - at91_set_B_periph(AT91_PIN_PA8, 0); /* ERX2 */ - at91_set_B_periph(AT91_PIN_PA9, 0); /* ERX3 */ - at91_set_B_periph(AT91_PIN_PA28, 0); /* ERXCK */ - at91_set_B_periph(AT91_PIN_PA6, 0); /* ETX2 */ - at91_set_B_periph(AT91_PIN_PA7, 0); /* ETX3 */ - at91_set_B_periph(AT91_PIN_PA27, 0); /* ETXER */ + at91_set_b_periph(AT91_PORTPIN(A, 29), 0); /* ECRS */ + at91_set_b_periph(AT91_PORTPIN(A, 30), 0); /* ECOL */ + at91_set_b_periph(AT91_PORTPIN(A, 8), 0); /* ERX2 */ + at91_set_b_periph(AT91_PORTPIN(A, 9), 0); /* ERX3 */ + at91_set_b_periph(AT91_PORTPIN(A, 28), 0); /* ERXCK */ + at91_set_b_periph(AT91_PORTPIN(A, 6), 0); /* ETX2 */ + at91_set_b_periph(AT91_PORTPIN(A, 7), 0); /* ETX3 */ + at91_set_b_periph(AT91_PORTPIN(A, 27), 0); /* ETXER */ #endif } #endif diff --git a/cpu/arm926ejs/at91/at91sam9rl_devices.c b/cpu/arm926ejs/at91/at91sam9rl_devices.c index ebed193..9c5624a 100644 --- a/cpu/arm926ejs/at91/at91sam9rl_devices.c +++ b/cpu/arm926ejs/at91/at91sam9rl_devices.c @@ -30,29 +30,29 @@
void at91_serial0_hw_init(void) { - at91_set_A_periph(AT91_PIN_PA6, 1); /* TXD0 */ - at91_set_A_periph(AT91_PIN_PA7, 0); /* RXD0 */ + at91_set_a_periph(AT91_PORTPIN(A, 6), 1); /* TXD0 */ + at91_set_a_periph(AT91_PORTPIN(A, 7), 0); /* RXD0 */ at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9RL_ID_US0); }
void at91_serial1_hw_init(void) { - at91_set_A_periph(AT91_PIN_PA11, 1); /* TXD1 */ - at91_set_A_periph(AT91_PIN_PA12, 0); /* RXD1 */ + at91_set_a_periph(AT91_PORTPIN(A, 11), 1); /* TXD1 */ + at91_set_a_periph(AT91_PORTPIN(A, 12), 0); /* RXD1 */ at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9RL_ID_US1); }
void at91_serial2_hw_init(void) { - at91_set_A_periph(AT91_PIN_PA13, 1); /* TXD2 */ - at91_set_A_periph(AT91_PIN_PA14, 0); /* RXD2 */ + at91_set_a_periph(AT91_PORTPIN(A, 13), 1); /* TXD2 */ + at91_set_a_periph(AT91_PORTPIN(A, 14), 0); /* RXD2 */ at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9RL_ID_US2); }
void at91_serial3_hw_init(void) { - at91_set_A_periph(AT91_PIN_PA21, 0); /* DRXD */ - at91_set_A_periph(AT91_PIN_PA22, 1); /* DTXD */ + at91_set_a_periph(AT91_PORTPIN(A, 21), 0); /* DRXD */ + at91_set_a_periph(AT91_PORTPIN(A, 22), 1); /* DTXD */ at91_sys_write(AT91_PMC_PCER, 1 << AT91_ID_SYS); }
@@ -78,36 +78,36 @@ void at91_serial_hw_init(void) #ifdef CONFIG_HAS_DATAFLASH void at91_spi0_hw_init(unsigned long cs_mask) { - at91_set_A_periph(AT91_PIN_PA25, 0); /* SPI0_MISO */ - at91_set_A_periph(AT91_PIN_PA26, 0); /* SPI0_MOSI */ - at91_set_A_periph(AT91_PIN_PA27, 0); /* SPI0_SPCK */ + at91_set_a_periph(AT91_PORTPIN(A, 25), 0); /* SPI0_MISO */ + at91_set_a_periph(AT91_PORTPIN(A, 26), 0); /* SPI0_MOSI */ + at91_set_a_periph(AT91_PORTPIN(A, 27), 0); /* SPI0_SPCK */
/* Enable clock */ at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9RL_ID_SPI);
if (cs_mask & (1 << 0)) { - at91_set_A_periph(AT91_PIN_PA28, 1); + at91_set_a_periph(AT91_PORTPIN(A, 28), 1); } if (cs_mask & (1 << 1)) { - at91_set_B_periph(AT91_PIN_PB7, 1); + at91_set_b_periph(AT91_PORTPIN(B, 7), 1); } if (cs_mask & (1 << 2)) { - at91_set_A_periph(AT91_PIN_PD8, 1); + at91_set_a_periph(AT91_PORTPIN(D, 8), 1); } if (cs_mask & (1 << 3)) { - at91_set_B_periph(AT91_PIN_PD9, 1); + at91_set_b_periph(AT91_PORTPIN(D, 9), 1); } if (cs_mask & (1 << 4)) { - at91_set_gpio_output(AT91_PIN_PA28, 1); + at91_set_gpio_output(AT91_PORTPIN(A, 28), 1); } if (cs_mask & (1 << 5)) { - at91_set_gpio_output(AT91_PIN_PB7, 1); + at91_set_gpio_output(AT91_PORTPIN(B, 7), 1); } if (cs_mask & (1 << 6)) { - at91_set_gpio_output(AT91_PIN_PD8, 1); + at91_set_gpio_output(AT91_PORTPIN(D, 8), 1); } if (cs_mask & (1 << 7)) { - at91_set_gpio_output(AT91_PIN_PD9, 1); + at91_set_gpio_output(AT91_PORTPIN(D, 9), 1); } } #endif
Jens Scharsig wrote:
- convert all files cpu/../at91 to use at91_gpio driver syntax
- change AT91_PINP([A-F])(\d+) to AT91_PORTPIN(\1, \2), this makes all 160 AT91_PINPxxx defines obsolete
- AT91_PINPxxx defines can be remove if all boards converted to new SoC access
- at91_set_a_periph(AT91_PORTPIN(A, 22), 1); /* TXD0 */
- at91_set_a_periph(AT91_PORTPIN(A, 23), 0); /* RXD0 */
See comments about AT91_PORTPIN and converting the gpio functions to pass in the port and the pin as parameters
The other changes are straight forward. Tom
* convert all files cpu/../at91 to use at91_gpio driver syntax * change AT91_PINP([A-F])(\d+) to AT91_PIO_PORT\1, \2 this makes all 160 AT91_PINPxxx defines obsolete * AT91_PINPxxx defines and gpio.h can be remove, if all boards converted to new SoC access
diff --git a/cpu/arm926ejs/at91/at91cap9_devices.c b/cpu/arm926ejs/at91/at91cap9_devices.c index 39e405f..518a8d7 100644 --- a/cpu/arm926ejs/at91/at91cap9_devices.c +++ b/cpu/arm926ejs/at91/at91cap9_devices.c @@ -34,29 +34,29 @@
void at91_serial0_hw_init(void) { - at91_set_A_periph(AT91_PIN_PA22, 1); /* TXD0 */ - at91_set_A_periph(AT91_PIN_PA23, 0); /* RXD0 */ + at91_set_a_periph(AT91_PIO_PORTA, 22, 1); /* TXD0 */ + at91_set_a_periph(AT91_PIO_PORTA, 23, 0); /* RXD0 */ at91_sys_write(AT91_PMC_PCER, 1 << AT91CAP9_ID_US0); }
void at91_serial1_hw_init(void) { - at91_set_A_periph(AT91_PIN_PD0, 1); /* TXD1 */ - at91_set_A_periph(AT91_PIN_PD1, 0); /* RXD1 */ + at91_set_a_periph(AT91_PIO_PORTD, 0, 1); /* TXD1 */ + at91_set_a_periph(AT91_PIO_PORTD, 1, 0); /* RXD1 */ at91_sys_write(AT91_PMC_PCER, 1 << AT91CAP9_ID_US1); }
void at91_serial2_hw_init(void) { - at91_set_A_periph(AT91_PIN_PD2, 1); /* TXD2 */ - at91_set_A_periph(AT91_PIN_PD3, 0); /* RXD2 */ + at91_set_a_periph(AT91_PIO_PORTD, 2, 1); /* TXD2 */ + at91_set_a_periph(AT91_PIO_PORTD, 3, 0); /* RXD2 */ at91_sys_write(AT91_PMC_PCER, 1 << AT91CAP9_ID_US2); }
void at91_serial3_hw_init(void) { - at91_set_A_periph(AT91_PIN_PC30, 0); /* DRXD */ - at91_set_A_periph(AT91_PIN_PC31, 1); /* DTXD */ + at91_set_a_periph(AT91_PIO_PORTC, 30, 0); /* DRXD */ + at91_set_a_periph(AT91_PIO_PORTC, 31, 1); /* DTXD */ at91_sys_write(AT91_PMC_PCER, 1 << AT91_ID_SYS); }
@@ -82,71 +82,71 @@ void at91_serial_hw_init(void) #ifdef CONFIG_HAS_DATAFLASH void at91_spi0_hw_init(unsigned long cs_mask) { - at91_set_B_periph(AT91_PIN_PA0, 0); /* SPI0_MISO */ - at91_set_B_periph(AT91_PIN_PA1, 0); /* SPI0_MOSI */ - at91_set_B_periph(AT91_PIN_PA2, 0); /* SPI0_SPCK */ + at91_set_b_periph(AT91_PIO_PORTA, 0, 0); /* SPI0_MISO */ + at91_set_b_periph(AT91_PIO_PORTA, 1, 0); /* SPI0_MOSI */ + at91_set_b_periph(AT91_PIO_PORTA, 2, 0); /* SPI0_SPCK */
if (cs_mask & (1 << 0)) { - at91_set_B_periph(AT91_PIN_PA5, 1); + at91_set_b_periph(AT91_PIO_PORTA, 5, 1); } if (cs_mask & (1 << 1)) { - at91_set_B_periph(AT91_PIN_PA3, 1); + at91_set_b_periph(AT91_PIO_PORTA, 3, 1); } if (cs_mask & (1 << 2)) { - at91_set_B_periph(AT91_PIN_PD0, 1); + at91_set_b_periph(AT91_PIO_PORTD, 0, 1); } if (cs_mask & (1 << 3)) { - at91_set_B_periph(AT91_PIN_PD1, 1); + at91_set_b_periph(AT91_PIO_PORTD, 1, 1); } if (cs_mask & (1 << 4)) { - at91_set_gpio_output(AT91_PIN_PA5, 1); + at91_set_pio_output(AT91_PIO_PORTA, 5, 1); } if (cs_mask & (1 << 5)) { - at91_set_gpio_output(AT91_PIN_PA3, 1); + at91_set_pio_output(AT91_PIO_PORTA, 3, 1); } if (cs_mask & (1 << 6)) { - at91_set_gpio_output(AT91_PIN_PD0, 1); + at91_set_pio_output(AT91_PIO_PORTD, 0, 1); } if (cs_mask & (1 << 7)) { - at91_set_gpio_output(AT91_PIN_PD1, 1); + at91_set_pio_output(AT91_PIO_PORTD, 1, 1); } }
void at91_spi1_hw_init(unsigned long cs_mask) { - at91_set_A_periph(AT91_PIN_PB12, 0); /* SPI1_MISO */ - at91_set_A_periph(AT91_PIN_PB13, 0); /* SPI1_MOSI */ - at91_set_A_periph(AT91_PIN_PB14, 0); /* SPI1_SPCK */ + at91_set_a_periph(AT91_PIO_PORTB, 12, 0); /* SPI1_MISO */ + at91_set_a_periph(AT91_PIO_PORTB, 13, 0); /* SPI1_MOSI */ + at91_set_a_periph(AT91_PIO_PORTB, 14, 0); /* SPI1_SPCK */
if (cs_mask & (1 << 0)) { - at91_set_A_periph(AT91_PIN_PB15, 1); + at91_set_a_periph(AT91_PIO_PORTB, 15, 1); } if (cs_mask & (1 << 1)) { - at91_set_A_periph(AT91_PIN_PB16, 1); + at91_set_a_periph(AT91_PIO_PORTB, 16, 1); } if (cs_mask & (1 << 2)) { - at91_set_A_periph(AT91_PIN_PB17, 1); + at91_set_a_periph(AT91_PIO_PORTB, 17, 1); } if (cs_mask & (1 << 3)) { - at91_set_A_periph(AT91_PIN_PB18, 1); + at91_set_a_periph(AT91_PIO_PORTB, 18, 1); } if (cs_mask & (1 << 4)) { - at91_set_gpio_output(AT91_PIN_PB15, 1); + at91_set_pio_output(AT91_PIO_PORTB, 15, 1); } if (cs_mask & (1 << 5)) { - at91_set_gpio_output(AT91_PIN_PB16, 1); + at91_set_pio_output(AT91_PIO_PORTB, 16, 1); } if (cs_mask & (1 << 6)) { - at91_set_gpio_output(AT91_PIN_PB17, 1); + at91_set_pio_output(AT91_PIO_PORTB, 17, 1); } if (cs_mask & (1 << 7)) { - at91_set_gpio_output(AT91_PIN_PB18, 1); + at91_set_pio_output(AT91_PIO_PORTB, 18, 1); }
} @@ -155,26 +155,26 @@ void at91_spi1_hw_init(unsigned long cs_mask) #ifdef CONFIG_MACB void at91_macb_hw_init(void) { - at91_set_A_periph(AT91_PIN_PB21, 0); /* ETXCK_EREFCK */ - at91_set_A_periph(AT91_PIN_PB22, 0); /* ERXDV */ - at91_set_A_periph(AT91_PIN_PB25, 0); /* ERX0 */ - at91_set_A_periph(AT91_PIN_PB26, 0); /* ERX1 */ - at91_set_A_periph(AT91_PIN_PB27, 0); /* ERXER */ - at91_set_A_periph(AT91_PIN_PB28, 0); /* ETXEN */ - at91_set_A_periph(AT91_PIN_PB23, 0); /* ETX0 */ - at91_set_A_periph(AT91_PIN_PB24, 0); /* ETX1 */ - at91_set_A_periph(AT91_PIN_PB30, 0); /* EMDIO */ - at91_set_A_periph(AT91_PIN_PB29, 0); /* EMDC */ + at91_set_a_periph(AT91_PIO_PORTB, 21, 0); /* ETXCK_EREFCK */ + at91_set_a_periph(AT91_PIO_PORTB, 22, 0); /* ERXDV */ + at91_set_a_periph(AT91_PIO_PORTB, 25, 0); /* ERX0 */ + at91_set_a_periph(AT91_PIO_PORTB, 26, 0); /* ERX1 */ + at91_set_a_periph(AT91_PIO_PORTB, 27, 0); /* ERXER */ + at91_set_a_periph(AT91_PIO_PORTB, 28, 0); /* ETXEN */ + at91_set_a_periph(AT91_PIO_PORTB, 23, 0); /* ETX0 */ + at91_set_a_periph(AT91_PIO_PORTB, 24, 0); /* ETX1 */ + at91_set_a_periph(AT91_PIO_PORTB, 30, 0); /* EMDIO */ + at91_set_a_periph(AT91_PIO_PORTB, 29, 0); /* EMDC */
#ifndef CONFIG_RMII - at91_set_B_periph(AT91_PIN_PC25, 0); /* ECRS */ - at91_set_B_periph(AT91_PIN_PC26, 0); /* ECOL */ - at91_set_B_periph(AT91_PIN_PC22, 0); /* ERX2 */ - at91_set_B_periph(AT91_PIN_PC23, 0); /* ERX3 */ - at91_set_B_periph(AT91_PIN_PC27, 0); /* ERXCK */ - at91_set_B_periph(AT91_PIN_PC20, 0); /* ETX2 */ - at91_set_B_periph(AT91_PIN_PC21, 0); /* ETX3 */ - at91_set_B_periph(AT91_PIN_PC24, 0); /* ETXER */ + at91_set_b_periph(AT91_PIO_PORTC, 25, 0); /* ECRS */ + at91_set_b_periph(AT91_PIO_PORTC, 26, 0); /* ECOL */ + at91_set_b_periph(AT91_PIO_PORTC, 22, 0); /* ERX2 */ + at91_set_b_periph(AT91_PIO_PORTC, 23, 0); /* ERX3 */ + at91_set_b_periph(AT91_PIO_PORTC, 27, 0); /* ERXCK */ + at91_set_b_periph(AT91_PIO_PORTC, 20, 0); /* ETX2 */ + at91_set_b_periph(AT91_PIO_PORTC, 21, 0); /* ETX3 */ + at91_set_b_periph(AT91_PIO_PORTC, 24, 0); /* ETXER */ #endif } #endif @@ -182,8 +182,8 @@ void at91_macb_hw_init(void) #ifdef CONFIG_AT91_CAN void at91_can_hw_init(void) { - at91_set_A_periph(AT91_PIN_PA12, 0); /* CAN_TX */ - at91_set_A_periph(AT91_PIN_PA13, 1); /* CAN_RX */ + at91_set_a_periph(AT91_PIO_PORTA, 12, 0); /* CAN_TX */ + at91_set_a_periph(AT91_PIO_PORTA, 13, 1); /* CAN_RX */
/* Enable clock */ at91_sys_write(AT91_PMC_PCER, 1 << AT91CAP9_ID_CAN); diff --git a/cpu/arm926ejs/at91/at91sam9260_devices.c b/cpu/arm926ejs/at91/at91sam9260_devices.c index f86cb99..68c1974 100644 --- a/cpu/arm926ejs/at91/at91sam9260_devices.c +++ b/cpu/arm926ejs/at91/at91sam9260_devices.c @@ -30,29 +30,29 @@
void at91_serial0_hw_init(void) { - at91_set_A_periph(AT91_PIN_PB4, 1); /* TXD0 */ - at91_set_A_periph(AT91_PIN_PB5, 0); /* RXD0 */ + at91_set_a_periph(AT91_PIO_PORTB, 4, 1); /* TXD0 */ + at91_set_a_periph(AT91_PIO_PORTB, 5, 0); /* RXD0 */ at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9260_ID_US0); }
void at91_serial1_hw_init(void) { - at91_set_A_periph(AT91_PIN_PB6, 1); /* TXD1 */ - at91_set_A_periph(AT91_PIN_PB7, 0); /* RXD1 */ + at91_set_a_periph(AT91_PIO_PORTB, 6, 1); /* TXD1 */ + at91_set_a_periph(AT91_PIO_PORTB, 7, 0); /* RXD1 */ at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9260_ID_US1); }
void at91_serial2_hw_init(void) { - at91_set_A_periph(AT91_PIN_PB8, 1); /* TXD2 */ - at91_set_A_periph(AT91_PIN_PB9, 0); /* RXD2 */ + at91_set_a_periph(AT91_PIO_PORTB, 8, 1); /* TXD2 */ + at91_set_a_periph(AT91_PIO_PORTB, 9, 0); /* RXD2 */ at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9260_ID_US2); }
void at91_serial3_hw_init(void) { - at91_set_A_periph(AT91_PIN_PB14, 0); /* DRXD */ - at91_set_A_periph(AT91_PIN_PB15, 1); /* DTXD */ + at91_set_a_periph(AT91_PIO_PORTB, 14, 0); /* DRXD */ + at91_set_a_periph(AT91_PIO_PORTB, 15, 1); /* DTXD */ at91_sys_write(AT91_PMC_PCER, 1 << AT91_ID_SYS); }
@@ -78,71 +78,71 @@ void at91_serial_hw_init(void) #if defined(CONFIG_HAS_DATAFLASH) || defined(CONFIG_ATMEL_SPI) void at91_spi0_hw_init(unsigned long cs_mask) { - at91_set_A_periph(AT91_PIN_PA0, 0); /* SPI0_MISO */ - at91_set_A_periph(AT91_PIN_PA1, 0); /* SPI0_MOSI */ - at91_set_A_periph(AT91_PIN_PA2, 0); /* SPI0_SPCK */ + at91_set_a_periph(AT91_PIO_PORTA, 0, 0); /* SPI0_MISO */ + at91_set_a_periph(AT91_PIO_PORTA, 1, 0); /* SPI0_MOSI */ + at91_set_a_periph(AT91_PIO_PORTA, 2, 0); /* SPI0_SPCK */
if (cs_mask & (1 << 0)) { - at91_set_A_periph(AT91_PIN_PA3, 1); + at91_set_a_periph(AT91_PIO_PORTA, 3, 1); } if (cs_mask & (1 << 1)) { - at91_set_B_periph(AT91_PIN_PC11, 1); + at91_set_b_periph(AT91_PIO_PORTC, 11, 1); } if (cs_mask & (1 << 2)) { - at91_set_B_periph(AT91_PIN_PC16, 1); + at91_set_b_periph(AT91_PIO_PORTC, 16, 1); } if (cs_mask & (1 << 3)) { - at91_set_B_periph(AT91_PIN_PC17, 1); + at91_set_b_periph(AT91_PIO_PORTC, 17, 1); } if (cs_mask & (1 << 4)) { - at91_set_gpio_output(AT91_PIN_PA3, 1); + at91_set_pio_output(AT91_PIO_PORTA, 3, 1); } if (cs_mask & (1 << 5)) { - at91_set_gpio_output(AT91_PIN_PC11, 1); + at91_set_pio_output(AT91_PIO_PORTC, 11, 1); } if (cs_mask & (1 << 6)) { - at91_set_gpio_output(AT91_PIN_PC16, 1); + at91_set_pio_output(AT91_PIO_PORTC, 16, 1); } if (cs_mask & (1 << 7)) { - at91_set_gpio_output(AT91_PIN_PC17, 1); + at91_set_pio_output(AT91_PIO_PORTC, 17, 1); } }
void at91_spi1_hw_init(unsigned long cs_mask) { - at91_set_A_periph(AT91_PIN_PB0, 0); /* SPI1_MISO */ - at91_set_A_periph(AT91_PIN_PB1, 0); /* SPI1_MOSI */ - at91_set_A_periph(AT91_PIN_PB2, 0); /* SPI1_SPCK */ + at91_set_a_periph(AT91_PIO_PORTB, 0, 0); /* SPI1_MISO */ + at91_set_a_periph(AT91_PIO_PORTB, 1, 0); /* SPI1_MOSI */ + at91_set_a_periph(AT91_PIO_PORTB, 2, 0); /* SPI1_SPCK */
if (cs_mask & (1 << 0)) { - at91_set_A_periph(AT91_PIN_PB3, 1); + at91_set_a_periph(AT91_PIO_PORTB, 3, 1); } if (cs_mask & (1 << 1)) { - at91_set_B_periph(AT91_PIN_PC5, 1); + at91_set_b_periph(AT91_PIO_PORTC, 5, 1); } if (cs_mask & (1 << 2)) { - at91_set_B_periph(AT91_PIN_PC4, 1); + at91_set_b_periph(AT91_PIO_PORTC, 4, 1); } if (cs_mask & (1 << 3)) { - at91_set_gpio_output(AT91_PIN_PC3, 1); + at91_set_pio_output(AT91_PIO_PORTC, 3, 1); } if (cs_mask & (1 << 4)) { - at91_set_gpio_output(AT91_PIN_PB3, 1); + at91_set_pio_output(AT91_PIO_PORTB, 3, 1); } if (cs_mask & (1 << 5)) { - at91_set_gpio_output(AT91_PIN_PC5, 1); + at91_set_pio_output(AT91_PIO_PORTC, 5, 1); } if (cs_mask & (1 << 6)) { - at91_set_gpio_output(AT91_PIN_PC4, 1); + at91_set_pio_output(AT91_PIO_PORTC, 4, 1); } if (cs_mask & (1 << 7)) { - at91_set_gpio_output(AT91_PIN_PC3, 1); + at91_set_pio_output(AT91_PIO_PORTC, 3, 1); } } #endif @@ -150,35 +150,35 @@ void at91_spi1_hw_init(unsigned long cs_mask) #ifdef CONFIG_MACB void at91_macb_hw_init(void) { - at91_set_A_periph(AT91_PIN_PA19, 0); /* ETXCK_EREFCK */ - at91_set_A_periph(AT91_PIN_PA17, 0); /* ERXDV */ - at91_set_A_periph(AT91_PIN_PA14, 0); /* ERX0 */ - at91_set_A_periph(AT91_PIN_PA15, 0); /* ERX1 */ - at91_set_A_periph(AT91_PIN_PA18, 0); /* ERXER */ - at91_set_A_periph(AT91_PIN_PA16, 0); /* ETXEN */ - at91_set_A_periph(AT91_PIN_PA12, 0); /* ETX0 */ - at91_set_A_periph(AT91_PIN_PA13, 0); /* ETX1 */ - at91_set_A_periph(AT91_PIN_PA21, 0); /* EMDIO */ - at91_set_A_periph(AT91_PIN_PA20, 0); /* EMDC */ + at91_set_a_periph(AT91_PIO_PORTA, 19, 0); /* ETXCK_EREFCK */ + at91_set_a_periph(AT91_PIO_PORTA, 17, 0); /* ERXDV */ + at91_set_a_periph(AT91_PIO_PORTA, 14, 0); /* ERX0 */ + at91_set_a_periph(AT91_PIO_PORTA, 15, 0); /* ERX1 */ + at91_set_a_periph(AT91_PIO_PORTA, 18, 0); /* ERXER */ + at91_set_a_periph(AT91_PIO_PORTA, 16, 0); /* ETXEN */ + at91_set_a_periph(AT91_PIO_PORTA, 12, 0); /* ETX0 */ + at91_set_a_periph(AT91_PIO_PORTA, 13, 0); /* ETX1 */ + at91_set_a_periph(AT91_PIO_PORTA, 21, 0); /* EMDIO */ + at91_set_a_periph(AT91_PIO_PORTA, 20, 0); /* EMDC */
#ifndef CONFIG_RMII - at91_set_B_periph(AT91_PIN_PA28, 0); /* ECRS */ - at91_set_B_periph(AT91_PIN_PA29, 0); /* ECOL */ - at91_set_B_periph(AT91_PIN_PA25, 0); /* ERX2 */ - at91_set_B_periph(AT91_PIN_PA26, 0); /* ERX3 */ - at91_set_B_periph(AT91_PIN_PA27, 0); /* ERXCK */ + at91_set_b_periph(AT91_PIO_PORTA, 28, 0); /* ECRS */ + at91_set_b_periph(AT91_PIO_PORTA, 29, 0); /* ECOL */ + at91_set_b_periph(AT91_PIO_PORTA, 25, 0); /* ERX2 */ + at91_set_b_periph(AT91_PIO_PORTA, 26, 0); /* ERX3 */ + at91_set_b_periph(AT91_PIO_PORTA, 27, 0); /* ERXCK */ #if defined(CONFIG_AT91SAM9260EK) || defined(CONFIG_AFEB9260) /* * use PA10, PA11 for ETX2, ETX3. * PA23 and PA24 are for TWI EEPROM */ - at91_set_B_periph(AT91_PIN_PA10, 0); /* ETX2 */ - at91_set_B_periph(AT91_PIN_PA11, 0); /* ETX3 */ + at91_set_b_periph(AT91_PIO_PORTA, 10, 0); /* ETX2 */ + at91_set_b_periph(AT91_PIO_PORTA, 11, 0); /* ETX3 */ #else - at91_set_B_periph(AT91_PIN_PA23, 0); /* ETX2 */ - at91_set_B_periph(AT91_PIN_PA24, 0); /* ETX3 */ + at91_set_b_periph(AT91_PIO_PORTA, 23, 0); /* ETX2 */ + at91_set_b_periph(AT91_PIO_PORTA, 24, 0); /* ETX3 */ #endif - at91_set_B_periph(AT91_PIN_PA22, 0); /* ETXER */ + at91_set_b_periph(AT91_PIO_PORTA, 22, 0); /* ETXER */ #endif } #endif diff --git a/cpu/arm926ejs/at91/at91sam9261_devices.c b/cpu/arm926ejs/at91/at91sam9261_devices.c index 16d411f..286e72a 100644 --- a/cpu/arm926ejs/at91/at91sam9261_devices.c +++ b/cpu/arm926ejs/at91/at91sam9261_devices.c @@ -30,29 +30,29 @@
void at91_serial0_hw_init(void) { - at91_set_A_periph(AT91_PIN_PC8, 1); /* TXD0 */ - at91_set_A_periph(AT91_PIN_PC9, 0); /* RXD0 */ + at91_set_a_periph(AT91_PIO_PORTC, 8, 1); /* TXD0 */ + at91_set_a_periph(AT91_PIO_PORTC, 9, 0); /* RXD0 */ at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9261_ID_US0); }
void at91_serial1_hw_init(void) { - at91_set_A_periph(AT91_PIN_PC12, 1); /* TXD1 */ - at91_set_A_periph(AT91_PIN_PC13, 0); /* RXD1 */ + at91_set_a_periph(AT91_PIO_PORTC, 12, 1); /* TXD1 */ + at91_set_a_periph(AT91_PIO_PORTC, 13, 0); /* RXD1 */ at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9261_ID_US1); }
void at91_serial2_hw_init(void) { - at91_set_A_periph(AT91_PIN_PC14, 1); /* TXD2 */ - at91_set_A_periph(AT91_PIN_PC15, 0); /* RXD2 */ + at91_set_a_periph(AT91_PIO_PORTC, 14, 1); /* TXD2 */ + at91_set_a_periph(AT91_PIO_PORTC, 15, 0); /* RXD2 */ at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9261_ID_US2); }
void at91_serial3_hw_init(void) { - at91_set_A_periph(AT91_PIN_PA9, 0); /* DRXD */ - at91_set_A_periph(AT91_PIN_PA10, 1); /* DTXD */ + at91_set_a_periph(AT91_PIO_PORTA, 9, 0); /* DRXD */ + at91_set_a_periph(AT91_PIO_PORTA, 10, 1); /* DTXD */ at91_sys_write(AT91_PMC_PCER, 1 << AT91_ID_SYS); }
@@ -78,71 +78,71 @@ void at91_serial_hw_init(void) #ifdef CONFIG_HAS_DATAFLASH void at91_spi0_hw_init(unsigned long cs_mask) { - at91_set_A_periph(AT91_PIN_PA0, 0); /* SPI0_MISO */ - at91_set_A_periph(AT91_PIN_PA1, 0); /* SPI0_MOSI */ - at91_set_A_periph(AT91_PIN_PA2, 0); /* SPI0_SPCK */ + at91_set_a_periph(AT91_PIO_PORTA, 0, 0); /* SPI0_MISO */ + at91_set_a_periph(AT91_PIO_PORTA, 1, 0); /* SPI0_MOSI */ + at91_set_a_periph(AT91_PIO_PORTA, 2, 0); /* SPI0_SPCK */
if (cs_mask & (1 << 0)) { - at91_set_A_periph(AT91_PIN_PA3, 1); + at91_set_a_periph(AT91_PIO_PORTA, 3, 1); } if (cs_mask & (1 << 1)) { - at91_set_A_periph(AT91_PIN_PA4, 1); + at91_set_a_periph(AT91_PIO_PORTA, 4, 1); } if (cs_mask & (1 << 2)) { - at91_set_A_periph(AT91_PIN_PA5, 1); + at91_set_a_periph(AT91_PIO_PORTA, 5, 1); } if (cs_mask & (1 << 3)) { - at91_set_A_periph(AT91_PIN_PA6, 1); + at91_set_a_periph(AT91_PIO_PORTA, 6, 1); } if (cs_mask & (1 << 4)) { - at91_set_gpio_output(AT91_PIN_PA3, 1); + at91_set_pio_output(AT91_PIO_PORTA, 3, 1); } if (cs_mask & (1 << 5)) { - at91_set_gpio_output(AT91_PIN_PA4, 1); + at91_set_pio_output(AT91_PIO_PORTA, 4, 1); } if (cs_mask & (1 << 6)) { - at91_set_gpio_output(AT91_PIN_PA5, 1); + at91_set_pio_output(AT91_PIO_PORTA, 5, 1); } if (cs_mask & (1 << 7)) { - at91_set_gpio_output(AT91_PIN_PA6, 1); + at91_set_pio_output(AT91_PIO_PORTA, 6, 1); } }
void at91_spi1_hw_init(unsigned long cs_mask) { - at91_set_A_periph(AT91_PIN_PB30, 0); /* SPI1_MISO */ - at91_set_A_periph(AT91_PIN_PB31, 0); /* SPI1_MOSI */ - at91_set_A_periph(AT91_PIN_PB29, 0); /* SPI1_SPCK */ + at91_set_a_periph(AT91_PIO_PORTB, 30, 0); /* SPI1_MISO */ + at91_set_a_periph(AT91_PIO_PORTB, 31, 0); /* SPI1_MOSI */ + at91_set_a_periph(AT91_PIO_PORTB, 29, 0); /* SPI1_SPCK */
if (cs_mask & (1 << 0)) { - at91_set_A_periph(AT91_PIN_PB28, 1); + at91_set_a_periph(AT91_PIO_PORTB, 28, 1); } if (cs_mask & (1 << 1)) { - at91_set_B_periph(AT91_PIN_PA24, 1); + at91_set_b_periph(AT91_PIO_PORTA, 24, 1); } if (cs_mask & (1 << 2)) { - at91_set_B_periph(AT91_PIN_PA25, 1); + at91_set_b_periph(AT91_PIO_PORTA, 25, 1); } if (cs_mask & (1 << 3)) { - at91_set_A_periph(AT91_PIN_PA26, 1); + at91_set_a_periph(AT91_PIO_PORTA, 26, 1); } if (cs_mask & (1 << 4)) { - at91_set_gpio_output(AT91_PIN_PB28, 1); + at91_set_pio_output(AT91_PIO_PORTB, 28, 1); } if (cs_mask & (1 << 5)) { - at91_set_gpio_output(AT91_PIN_PA24, 1); + at91_set_pio_output(AT91_PIO_PORTA, 24, 1); } if (cs_mask & (1 << 6)) { - at91_set_gpio_output(AT91_PIN_PA25, 1); + at91_set_pio_output(AT91_PIO_PORTA, 25, 1); } if (cs_mask & (1 << 7)) { - at91_set_gpio_output(AT91_PIN_PA26, 1); + at91_set_pio_output(AT91_PIO_PORTA, 26, 1); } } #endif diff --git a/cpu/arm926ejs/at91/at91sam9263_devices.c b/cpu/arm926ejs/at91/at91sam9263_devices.c index f72efdf..90bdcc2 100644 --- a/cpu/arm926ejs/at91/at91sam9263_devices.c +++ b/cpu/arm926ejs/at91/at91sam9263_devices.c @@ -34,29 +34,29 @@
void at91_serial0_hw_init(void) { - at91_set_A_periph(AT91_PIN_PA26, 1); /* TXD0 */ - at91_set_A_periph(AT91_PIN_PA27, 0); /* RXD0 */ + at91_set_a_periph(AT91_PIO_PORTA, 26, 1); /* TXD0 */ + at91_set_a_periph(AT91_PIO_PORTA, 27, 0); /* RXD0 */ at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9263_ID_US0); }
void at91_serial1_hw_init(void) { - at91_set_A_periph(AT91_PIN_PD0, 1); /* TXD1 */ - at91_set_A_periph(AT91_PIN_PD1, 0); /* RXD1 */ + at91_set_a_periph(AT91_PIO_PORTD, 0, 1); /* TXD1 */ + at91_set_a_periph(AT91_PIO_PORTD, 1, 0); /* RXD1 */ at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9263_ID_US1); }
void at91_serial2_hw_init(void) { - at91_set_A_periph(AT91_PIN_PD2, 1); /* TXD2 */ - at91_set_A_periph(AT91_PIN_PD3, 0); /* RXD2 */ + at91_set_a_periph(AT91_PIO_PORTD, 2, 1); /* TXD2 */ + at91_set_a_periph(AT91_PIO_PORTD, 3, 0); /* RXD2 */ at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9263_ID_US2); }
if (cs_mask & (1 << 0)) { - at91_set_B_periph(AT91_PIN_PA5, 1); + at91_set_b_periph(AT91_PIO_PORTA, 5, 1); } if (cs_mask & (1 << 1)) { - at91_set_B_periph(AT91_PIN_PA3, 1); + at91_set_b_periph(AT91_PIO_PORTA, 3, 1); } if (cs_mask & (1 << 2)) { - at91_set_B_periph(AT91_PIN_PA4, 1); + at91_set_b_periph(AT91_PIO_PORTA, 4, 1); } if (cs_mask & (1 << 3)) { - at91_set_B_periph(AT91_PIN_PB11, 1); + at91_set_b_periph(AT91_PIO_PORTB, 11, 1); } if (cs_mask & (1 << 4)) { - at91_set_gpio_output(AT91_PIN_PA5, 1); + at91_set_pio_output(AT91_PIO_PORTA, 5, 1); } if (cs_mask & (1 << 5)) { - at91_set_gpio_output(AT91_PIN_PA3, 1); + at91_set_pio_output(AT91_PIO_PORTA, 3, 1); } if (cs_mask & (1 << 6)) { - at91_set_gpio_output(AT91_PIN_PA4, 1); + at91_set_pio_output(AT91_PIO_PORTA, 4, 1); } if (cs_mask & (1 << 7)) { - at91_set_gpio_output(AT91_PIN_PB11, 1); + at91_set_pio_output(AT91_PIO_PORTB, 11, 1); } }
if (cs_mask & (1 << 0)) { - at91_set_A_periph(AT91_PIN_PB15, 1); + at91_set_a_periph(AT91_PIO_PORTB, 15, 1); } if (cs_mask & (1 << 1)) { - at91_set_A_periph(AT91_PIN_PB16, 1); + at91_set_a_periph(AT91_PIO_PORTB, 16, 1); } if (cs_mask & (1 << 2)) { - at91_set_A_periph(AT91_PIN_PB17, 1); + at91_set_a_periph(AT91_PIO_PORTB, 17, 1); } if (cs_mask & (1 << 3)) { - at91_set_A_periph(AT91_PIN_PB18, 1); + at91_set_a_periph(AT91_PIO_PORTB, 18, 1); } if (cs_mask & (1 << 4)) { - at91_set_gpio_output(AT91_PIN_PB15, 1); + at91_set_pio_output(AT91_PIO_PORTB, 15, 1); } if (cs_mask & (1 << 5)) { - at91_set_gpio_output(AT91_PIN_PB16, 1); + at91_set_pio_output(AT91_PIO_PORTB, 16, 1); } if (cs_mask & (1 << 6)) { - at91_set_gpio_output(AT91_PIN_PB17, 1); + at91_set_pio_output(AT91_PIO_PORTB, 17, 1); } if (cs_mask & (1 << 7)) { - at91_set_gpio_output(AT91_PIN_PB18, 1); + at91_set_pio_output(AT91_PIO_PORTB, 18, 1); } } #endif @@ -154,26 +154,26 @@ void at91_spi1_hw_init(unsigned long cs_mask) #ifdef CONFIG_MACB void at91_macb_hw_init(void) { - at91_set_A_periph(AT91_PIN_PE21, 0); /* ETXCK_EREFCK */ - at91_set_B_periph(AT91_PIN_PC25, 0); /* ERXDV */ - at91_set_A_periph(AT91_PIN_PE25, 0); /* ERX0 */ - at91_set_A_periph(AT91_PIN_PE26, 0); /* ERX1 */ - at91_set_A_periph(AT91_PIN_PE27, 0); /* ERXER */ - at91_set_A_periph(AT91_PIN_PE28, 0); /* ETXEN */ - at91_set_A_periph(AT91_PIN_PE23, 0); /* ETX0 */ - at91_set_A_periph(AT91_PIN_PE24, 0); /* ETX1 */ - at91_set_A_periph(AT91_PIN_PE30, 0); /* EMDIO */ - at91_set_A_periph(AT91_PIN_PE29, 0); /* EMDC */ + at91_set_a_periph(AT91_PIO_PORTE, 21, 0); /* ETXCK_EREFCK */ + at91_set_b_periph(AT91_PIO_PORTC, 25, 0); /* ERXDV */ + at91_set_a_periph(AT91_PIO_PORTE, 25, 0); /* ERX0 */ + at91_set_a_periph(AT91_PIO_PORTE, 26, 0); /* ERX1 */ + at91_set_a_periph(AT91_PIO_PORTE, 27, 0); /* ERXER */ + at91_set_a_periph(AT91_PIO_PORTE, 28, 0); /* ETXEN */ + at91_set_a_periph(AT91_PIO_PORTE, 23, 0); /* ETX0 */ + at91_set_a_periph(AT91_PIO_PORTE, 24, 0); /* ETX1 */ + at91_set_a_periph(AT91_PIO_PORTE, 30, 0); /* EMDIO */ + at91_set_a_periph(AT91_PIO_PORTE, 29, 0); /* EMDC */
#ifndef CONFIG_RMII - at91_set_A_periph(AT91_PIN_PE22, 0); /* ECRS */ - at91_set_B_periph(AT91_PIN_PC26, 0); /* ECOL */ - at91_set_B_periph(AT91_PIN_PC22, 0); /* ERX2 */ - at91_set_B_periph(AT91_PIN_PC23, 0); /* ERX3 */ - at91_set_B_periph(AT91_PIN_PC27, 0); /* ERXCK */ - at91_set_B_periph(AT91_PIN_PC20, 0); /* ETX2 */ - at91_set_B_periph(AT91_PIN_PC21, 0); /* ETX3 */ - at91_set_B_periph(AT91_PIN_PC24, 0); /* ETXER */ + at91_set_a_periph(AT91_PIO_PORTE, 22, 0); /* ECRS */ + at91_set_b_periph(AT91_PIO_PORTC, 26, 0); /* ECOL */ + at91_set_b_periph(AT91_PIO_PORTC, 22, 0); /* ERX2 */ + at91_set_b_periph(AT91_PIO_PORTC, 23, 0); /* ERX3 */ + at91_set_b_periph(AT91_PIO_PORTC, 27, 0); /* ERXCK */ + at91_set_b_periph(AT91_PIO_PORTC, 20, 0); /* ETX2 */ + at91_set_b_periph(AT91_PIO_PORTC, 21, 0); /* ETX3 */ + at91_set_b_periph(AT91_PIO_PORTC, 24, 0); /* ETXER */ #endif } #endif @@ -182,16 +182,16 @@ void at91_macb_hw_init(void) void at91_uhp_hw_init(void) { /* Enable VBus on UHP ports */ - at91_set_gpio_output(AT91_PIN_PA21, 0); - at91_set_gpio_output(AT91_PIN_PA24, 0); + at91_set_pio_output(AT91_PIO_PORTA, 21, 0); + at91_set_pio_output(AT91_PIO_PORTA, 24, 0); } #endif
#ifdef CONFIG_AT91_CAN void at91_can_hw_init(void) { - at91_set_A_periph(AT91_PIN_PA13, 0); /* CAN_TX */ - at91_set_A_periph(AT91_PIN_PA14, 1); /* CAN_RX */ + at91_set_a_periph(AT91_PIO_PORTA, 13, 0); /* CAN_TX */ + at91_set_a_periph(AT91_PIO_PORTA, 14, 1); /* CAN_RX */
/* Enable clock */ at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9263_ID_CAN); diff --git a/cpu/arm926ejs/at91/at91sam9m10g45_devices.c b/cpu/arm926ejs/at91/at91sam9m10g45_devices.c index 98d90f2..6881e46 100644 --- a/cpu/arm926ejs/at91/at91sam9m10g45_devices.c +++ b/cpu/arm926ejs/at91/at91sam9m10g45_devices.c @@ -30,29 +30,29 @@
void at91_serial0_hw_init(void) { - at91_set_A_periph(AT91_PIN_PB19, 1); /* TXD0 */ - at91_set_A_periph(AT91_PIN_PB18, 0); /* RXD0 */ + at91_set_a_periph(AT91_PIO_PORTB, 19, 1); /* TXD0 */ + at91_set_a_periph(AT91_PIO_PORTB, 18, 0); /* RXD0 */ at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9G45_ID_US0); }
void at91_serial1_hw_init(void) { - at91_set_A_periph(AT91_PIN_PB4, 1); /* TXD1 */ - at91_set_A_periph(AT91_PIN_PB5, 0); /* RXD1 */ + at91_set_a_periph(AT91_PIO_PORTB, 4, 1); /* TXD1 */ + at91_set_a_periph(AT91_PIO_PORTB, 5, 0); /* RXD1 */ at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9G45_ID_US1); }
void at91_serial2_hw_init(void) { - at91_set_A_periph(AT91_PIN_PD6, 1); /* TXD2 */ - at91_set_A_periph(AT91_PIN_PD7, 0); /* RXD2 */ + at91_set_a_periph(AT91_PIO_PORTD, 6, 1); /* TXD2 */ + at91_set_a_periph(AT91_PIO_PORTD, 7, 0); /* RXD2 */ at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9G45_ID_US2); }
void at91_serial3_hw_init(void) { - at91_set_A_periph(AT91_PIN_PB12, 0); /* DRXD */ - at91_set_A_periph(AT91_PIN_PB13, 1); /* DTXD */ + at91_set_a_periph(AT91_PIO_PORTB, 12, 0); /* DRXD */ + at91_set_a_periph(AT91_PIO_PORTB, 13, 1); /* DTXD */ at91_sys_write(AT91_PMC_PCER, 1 << AT91_ID_SYS);; }
@@ -78,71 +78,71 @@ void at91_serial_hw_init(void) #ifdef CONFIG_ATMEL_SPI void at91_spi0_hw_init(unsigned long cs_mask) { - at91_set_A_periph(AT91_PIN_PB0, 0); /* SPI0_MISO */ - at91_set_A_periph(AT91_PIN_PB1, 0); /* SPI0_MOSI */ - at91_set_A_periph(AT91_PIN_PB2, 0); /* SPI0_SPCK */ + at91_set_a_periph(AT91_PIO_PORTB, 0, 0); /* SPI0_MISO */ + at91_set_a_periph(AT91_PIO_PORTB, 1, 0); /* SPI0_MOSI */ + at91_set_a_periph(AT91_PIO_PORTB, 2, 0); /* SPI0_SPCK */
if (cs_mask & (1 << 0)) { - at91_set_A_periph(AT91_PIN_PB3, 0); + at91_set_a_periph(AT91_PIO_PORTB, 3, 0); } if (cs_mask & (1 << 1)) { - at91_set_B_periph(AT91_PIN_PB18, 0); + at91_set_b_periph(AT91_PIO_PORTB, 18, 0); } if (cs_mask & (1 << 2)) { - at91_set_B_periph(AT91_PIN_PB19, 0); + at91_set_b_periph(AT91_PIO_PORTB, 19, 0); } if (cs_mask & (1 << 3)) { - at91_set_B_periph(AT91_PIN_PD27, 0); + at91_set_b_periph(AT91_PIO_PORTD, 27, 0); } if (cs_mask & (1 << 4)) { - at91_set_gpio_output(AT91_PIN_PB3, 0); + at91_set_pio_output(AT91_PIO_PORTB, 3, 0); } if (cs_mask & (1 << 5)) { - at91_set_gpio_output(AT91_PIN_PB18, 0); + at91_set_pio_output(AT91_PIO_PORTB, 18, 0); } if (cs_mask & (1 << 6)) { - at91_set_gpio_output(AT91_PIN_PB19, 0); + at91_set_pio_output(AT91_PIO_PORTB, 19, 0); } if (cs_mask & (1 << 7)) { - at91_set_gpio_output(AT91_PIN_PD27, 0); + at91_set_pio_output(AT91_PIO_PORTD, 27, 0); } }
void at91_spi1_hw_init(unsigned long cs_mask) { - at91_set_A_periph(AT91_PIN_PB14, 0); /* SPI1_MISO */ - at91_set_A_periph(AT91_PIN_PB15, 0); /* SPI1_MOSI */ - at91_set_A_periph(AT91_PIN_PB16, 0); /* SPI1_SPCK */ + at91_set_a_periph(AT91_PIO_PORTB, 14, 0); /* SPI1_MISO */ + at91_set_a_periph(AT91_PIO_PORTB, 15, 0); /* SPI1_MOSI */ + at91_set_a_periph(AT91_PIO_PORTB, 16, 0); /* SPI1_SPCK */
if (cs_mask & (1 << 0)) { - at91_set_A_periph(AT91_PIN_PB17, 0); + at91_set_a_periph(AT91_PIO_PORTB, 17, 0); } if (cs_mask & (1 << 1)) { - at91_set_B_periph(AT91_PIN_PD28, 0); + at91_set_b_periph(AT91_PIO_PORTD, 28, 0); } if (cs_mask & (1 << 2)) { - at91_set_A_periph(AT91_PIN_PD18, 0); + at91_set_a_periph(AT91_PIO_PORTD, 18, 0); } if (cs_mask & (1 << 3)) { - at91_set_A_periph(AT91_PIN_PD19, 0); + at91_set_a_periph(AT91_PIO_PORTD, 19, 0); } if (cs_mask & (1 << 4)) { - at91_set_gpio_output(AT91_PIN_PB17, 0); + at91_set_pio_output(AT91_PIO_PORTB, 17, 0); } if (cs_mask & (1 << 5)) { - at91_set_gpio_output(AT91_PIN_PD28, 0); + at91_set_pio_output(AT91_PIO_PORTD, 28, 0); } if (cs_mask & (1 << 6)) { - at91_set_gpio_output(AT91_PIN_PD18, 0); + at91_set_pio_output(AT91_PIO_PORTD, 18, 0); } if (cs_mask & (1 << 7)) { - at91_set_gpio_output(AT91_PIN_PD19, 0); + at91_set_pio_output(AT91_PIO_PORTD, 19, 0); }
} @@ -151,25 +151,25 @@ void at91_spi1_hw_init(unsigned long cs_mask) #ifdef CONFIG_MACB void at91_macb_hw_init(void) { - at91_set_A_periph(AT91_PIN_PA17, 0); /* ETXCK_EREFCK */ - at91_set_A_periph(AT91_PIN_PA15, 0); /* ERXDV */ - at91_set_A_periph(AT91_PIN_PA12, 0); /* ERX0 */ - at91_set_A_periph(AT91_PIN_PA13, 0); /* ERX1 */ - at91_set_A_periph(AT91_PIN_PA16, 0); /* ERXER */ - at91_set_A_periph(AT91_PIN_PA14, 0); /* ETXEN */ - at91_set_A_periph(AT91_PIN_PA10, 0); /* ETX0 */ - at91_set_A_periph(AT91_PIN_PA11, 0); /* ETX1 */ - at91_set_A_periph(AT91_PIN_PA19, 0); /* EMDIO */ - at91_set_A_periph(AT91_PIN_PA18, 0); /* EMDC */ + at91_set_a_periph(AT91_PIO_PORTA, 17, 0); /* ETXCK_EREFCK */ + at91_set_a_periph(AT91_PIO_PORTA, 15, 0); /* ERXDV */ + at91_set_a_periph(AT91_PIO_PORTA, 12, 0); /* ERX0 */ + at91_set_a_periph(AT91_PIO_PORTA, 13, 0); /* ERX1 */ + at91_set_a_periph(AT91_PIO_PORTA, 16, 0); /* ERXER */ + at91_set_a_periph(AT91_PIO_PORTA, 14, 0); /* ETXEN */ + at91_set_a_periph(AT91_PIO_PORTA, 10, 0); /* ETX0 */ + at91_set_a_periph(AT91_PIO_PORTA, 11, 0); /* ETX1 */ + at91_set_a_periph(AT91_PIO_PORTA, 19, 0); /* EMDIO */ + at91_set_a_periph(AT91_PIO_PORTA, 18, 0); /* EMDC */ #ifndef CONFIG_RMII - at91_set_B_periph(AT91_PIN_PA29, 0); /* ECRS */ - at91_set_B_periph(AT91_PIN_PA30, 0); /* ECOL */ - at91_set_B_periph(AT91_PIN_PA8, 0); /* ERX2 */ - at91_set_B_periph(AT91_PIN_PA9, 0); /* ERX3 */ - at91_set_B_periph(AT91_PIN_PA28, 0); /* ERXCK */ - at91_set_B_periph(AT91_PIN_PA6, 0); /* ETX2 */ - at91_set_B_periph(AT91_PIN_PA7, 0); /* ETX3 */ - at91_set_B_periph(AT91_PIN_PA27, 0); /* ETXER */ + at91_set_b_periph(AT91_PIO_PORTA, 29, 0); /* ECRS */ + at91_set_b_periph(AT91_PIO_PORTA, 30, 0); /* ECOL */ + at91_set_b_periph(AT91_PIO_PORTA, 8, 0); /* ERX2 */ + at91_set_b_periph(AT91_PIO_PORTA, 9, 0); /* ERX3 */ + at91_set_b_periph(AT91_PIO_PORTA, 28, 0); /* ERXCK */ + at91_set_b_periph(AT91_PIO_PORTA, 6, 0); /* ETX2 */ + at91_set_b_periph(AT91_PIO_PORTA, 7, 0); /* ETX3 */ + at91_set_b_periph(AT91_PIO_PORTA, 27, 0); /* ETXER */ #endif } #endif diff --git a/cpu/arm926ejs/at91/at91sam9rl_devices.c b/cpu/arm926ejs/at91/at91sam9rl_devices.c index ebed193..d74e144 100644 --- a/cpu/arm926ejs/at91/at91sam9rl_devices.c +++ b/cpu/arm926ejs/at91/at91sam9rl_devices.c @@ -30,29 +30,29 @@
void at91_serial0_hw_init(void) { - at91_set_A_periph(AT91_PIN_PA6, 1); /* TXD0 */ - at91_set_A_periph(AT91_PIN_PA7, 0); /* RXD0 */ + at91_set_a_periph(AT91_PIO_PORTA, 6, 1); /* TXD0 */ + at91_set_a_periph(AT91_PIO_PORTA, 7, 0); /* RXD0 */ at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9RL_ID_US0); }
void at91_serial1_hw_init(void) { - at91_set_A_periph(AT91_PIN_PA11, 1); /* TXD1 */ - at91_set_A_periph(AT91_PIN_PA12, 0); /* RXD1 */ + at91_set_a_periph(AT91_PIO_PORTA, 11, 1); /* TXD1 */ + at91_set_a_periph(AT91_PIO_PORTA, 12, 0); /* RXD1 */ at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9RL_ID_US1); }
void at91_serial2_hw_init(void) { - at91_set_A_periph(AT91_PIN_PA13, 1); /* TXD2 */ - at91_set_A_periph(AT91_PIN_PA14, 0); /* RXD2 */ + at91_set_a_periph(AT91_PIO_PORTA, 13, 1); /* TXD2 */ + at91_set_a_periph(AT91_PIO_PORTA, 14, 0); /* RXD2 */ at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9RL_ID_US2); }
void at91_serial3_hw_init(void) { - at91_set_A_periph(AT91_PIN_PA21, 0); /* DRXD */ - at91_set_A_periph(AT91_PIN_PA22, 1); /* DTXD */ + at91_set_a_periph(AT91_PIO_PORTA, 21, 0); /* DRXD */ + at91_set_a_periph(AT91_PIO_PORTA, 22, 1); /* DTXD */ at91_sys_write(AT91_PMC_PCER, 1 << AT91_ID_SYS); }
@@ -78,36 +78,36 @@ void at91_serial_hw_init(void) #ifdef CONFIG_HAS_DATAFLASH void at91_spi0_hw_init(unsigned long cs_mask) { - at91_set_A_periph(AT91_PIN_PA25, 0); /* SPI0_MISO */ - at91_set_A_periph(AT91_PIN_PA26, 0); /* SPI0_MOSI */ - at91_set_A_periph(AT91_PIN_PA27, 0); /* SPI0_SPCK */ + at91_set_a_periph(AT91_PIO_PORTA, 25, 0); /* SPI0_MISO */ + at91_set_a_periph(AT91_PIO_PORTA, 26, 0); /* SPI0_MOSI */ + at91_set_a_periph(AT91_PIO_PORTA, 27, 0); /* SPI0_SPCK */
if (cs_mask & (1 << 0)) { - at91_set_A_periph(AT91_PIN_PA28, 1); + at91_set_a_periph(AT91_PIO_PORTA, 28, 1); } if (cs_mask & (1 << 1)) { - at91_set_B_periph(AT91_PIN_PB7, 1); + at91_set_b_periph(AT91_PIO_PORTB, 7, 1); } if (cs_mask & (1 << 2)) { - at91_set_A_periph(AT91_PIN_PD8, 1); + at91_set_a_periph(AT91_PIO_PORTD, 8, 1); } if (cs_mask & (1 << 3)) { - at91_set_B_periph(AT91_PIN_PD9, 1); + at91_set_b_periph(AT91_PIO_PORTD, 9, 1); } if (cs_mask & (1 << 4)) { - at91_set_gpio_output(AT91_PIN_PA28, 1); + at91_set_pio_output(AT91_PIO_PORTA, 28, 1); } if (cs_mask & (1 << 5)) { - at91_set_gpio_output(AT91_PIN_PB7, 1); + at91_set_pio_output(AT91_PIO_PORTB, 7, 1); } if (cs_mask & (1 << 6)) { - at91_set_gpio_output(AT91_PIN_PD8, 1); + at91_set_pio_output(AT91_PIO_PORTD, 8, 1); } if (cs_mask & (1 << 7)) { - at91_set_gpio_output(AT91_PIN_PD9, 1); + at91_set_pio_output(AT91_PIO_PORTD, 9, 1); } } #endif
Jens Scharsig
Tom
