[U-Boot-Users] DataTLBError with MPC8540
I'm working on porting u-boot 1.1.2 for a Metrowerks eval board. I have modified the MPC8540ADS.h to make it compatible with the board. I removed the RapidIO initialisation in init.S since I don't use it.
Whatever I try to do the CPU enter the DataTLBError exception: -> If I set a breakpoint (no matter where) -> If I step through the code
Here is a "typical" session:
BDI>info Target CPU : MPC8560/8540 Rev.2 Target state : halted Debug entry cause : COP halt Current PC : 0xfffffffc Current CR : 0x00000000 Current MSR : 0x02000200 Current LR : 0x00000000 Current CCSRBAR : 0xff700000
gdb>go BDI>info Target CPU : MPC8560/8540 Rev.2 Target state : running BDI>halt Target CPU : MPC8560/8540 Rev.2 Target state : halted Debug entry cause : COP halt Current PC : 0xfff81400 Current CR : 0x20000000 Current MSR : 0x00001000 Current LR : 0xfffff218 Current CCSRBAR : 0xe0000000
dear: 0x000211a8 135592 srr0: 0xfff81410 -519152 -> I know that this is not the primary source of the DataTLBError, but I didn't find a way to stop at the first exception. srr1: 0x00001000 4096 esr : 0x00800000 8388608 mas0: 0x00000001 1 mas1: 0x80000000 -2147483648 mas2: 0x00021000 135168 mas3: 0x00000000 0
TLB0 valid entries: IDX PID EPN SIZE V TS RPN U0-U3 WIMGE UUUSSS 0 : 00 ff700000 4KB V 0 -> ff700000 0000 -I-G- ---RWX 16 : 00 e4010000 4KB V 0 -> e4010000 0000 ----- ---RWX 17 : 00 e4011000 4KB V 0 -> e4011000 0000 ----- ---RWX 18 : 00 e4012000 4KB V 0 -> e4012000 0000 ----- ---RWX 19 : 00 e4013000 4KB V 0 -> e4013000 0000 ----- ---RWX
TLB1 valid entries: IDX PID EPN SIZE V TS RPN U0-U3 WIMGE UUUSSS 0 : 00 ff000000 16MB V 0 -> ff000000 0000 -I-G- ---RWX -> Flash 1 : 00 80000000 256MB V 0 -> 80000000 0000 -I-G- ---RWX -> PCI 1/2 2 : 00 90000000 256MB V 0 -> 90000000 0000 -I-G- ---RWX -> PCI 2/2 5 : 00 e0000000 64MB V 0 -> e0000000 0000 -I-G- ---RWX -> CCSRBAR 6 : 00 f0000000 64MB V 0 -> f0000000 0000 ----- ---RWX -> LBC_SDRAM 7 : 00 f8000000 16KB V 0 -> f8000000 0000 -I-G- ---RWX -> BCSR
Environment: - Board: Metrowerks board with a MPC8540 CPU. - U-boot version: 1.1.2 - Toolchain: ELDK3.1
/* * Copyright 2004 Freescale Semiconductor. * (C) Copyright 2002,2003 Motorola,Inc. * Xianghua Xiao X.Xiao@motorola.com * * See file CREDITS for list of people who contributed to this * project. * * This program is free software; you can redistribute it and/or * modify it under the terms of the GNU General Public License as * published by the Free Software Foundation; either version 2 of * the License, or (at your option) any later version. * * This program is distributed in the hope that it will be useful, * but WITHOUT ANY WARRANTY; without even the implied warranty of * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the * GNU General Public License for more details. * * You should have received a copy of the GNU General Public License * along with this program; if not, write to the Free Software * Foundation, Inc., 59 Temple Place, Suite 330, Boston, * MA 02111-1307 USA */
#ifndef __CONFIG_H #define __CONFIG_H
/* High Level Configuration Options */ #define CONFIG_BOOKE 1 /* BOOKE */ #define CONFIG_E500 1 /* BOOKE e500 family */ #define CONFIG_MPC85xx 1 /* MPC8540/MPC8560 */ #define CONFIG_MPC8540 1 /* MPC8540 specific */ #define CONFIG_MPC8540ADS 1 /* MPC8540ADS board specific */
#undef CONFIG_PCI #define CONFIG_TSEC_ENET /* tsec ethernet support */ #define CONFIG_ENV_OVERWRITE #define CONFIG_SPD_EEPROM /* Use SPD EEPROM for DDR setup*/ #undef CONFIG_DDR_ECC /* only for ECC DDR module */ #define CONFIG_DDR_DLL /* possible DLL fix needed */ #define CONFIG_DDR_2T_TIMING /* Sets the 2T timing bit */
/* Using Localbus SDRAM to emulate flash before we can program the flash, * normally you only need a flash-boot image(u-boot.bin),if unsure undef this. * Not availabe for EVAL board */ #undef CONFIG_RAM_AS_FLASH /* Added 30.05.2005, taken from EVAL8540.h */
/* * sysclk for MPC85xx * * Two valid values are: * 33000000 * 66000000 * * Most PCI cards are still 33Mhz, so in the presence of PCI, 33MHz * is likely the desired value here, so that is now the default. * The board, however, can run at 66MHz. In any event, this value * must match the settings of some switches. Details can be found * in the README.mpc85xxads. */
/* #ifndef CONFIG_SYS_CLK_FREQ #define CONFIG_SYS_CLK_FREQ 33000000 #endif */ #define CONFIG_SYS_CLK_FREQ 66000000 /* defined here or in the command line */
/* * These can be toggled for performance analysis, otherwise use default. */ #define CONFIG_L2_CACHE /* toggle L2 cache */ #undef CONFIG_BTB /* toggle branch predition */ #undef CONFIG_ADDR_STREAMING /* toggle addr streaming */
#define CONFIG_BOARD_EARLY_INIT_F 1 /* Call board_pre_init */
#undef CFG_DRAM_TEST /* memory test, takes time */ #define CFG_MEMTEST_START 0x00200000 /* memtest region */ #define CFG_MEMTEST_END 0x00400000
/* * Base addresses -- Note these are effective addresses where the * actual resources get mapped (not physical addresses) */ #define CFG_CCSRBAR_DEFAULT 0xff700000 /* CCSRBAR Default */ #define CFG_CCSRBAR 0xe0000000 /* relocated CCSRBAR */ #define CFG_IMMR CFG_CCSRBAR /* PQII uses CFG_IMMR */
/* * DDR Setup */ #define CFG_DDR_SDRAM_BASE 0x00000000 /* DDR is system memory*/ #define CFG_SDRAM_BASE CFG_DDR_SDRAM_BASE
#if defined(CONFIG_SPD_EEPROM) /* * Determine DDR configuration from I2C interface. */ #define SPD_EEPROM_ADDRESS 0x51 /* DDR DIMM */
#else /* * Manually set up DDR parameters */
#define CFG_SDRAM_SIZE 256 /* DDR is 256MB */ #define CFG_DDR_CS0_BNDS 0x00000007 /* 0-128MB */ #define CFG_DDR_CS0_CONFIG 0x80000101 /* New 24.05.2005 */ #define CFG_DDR_TIMING_1 0x36342321 /* from EVAL8540 */ #define CFG_DDR_TIMING_2 0x00000800 /* P9-45,may need tuning */ #define CFG_DDR_CONTROL 0xc2000000 /* unbuffered,no DYN_PWR */ #define CFG_DDR_MODE 0x00000062 /* DLL,normal,seq,4/2.5 */ #define CFG_DDR_INTERVAL 0x03d00100 /* autocharge,no open page */ #endif
/* * SDRAM on the Local Bus */ #define CFG_LBC_SDRAM_BASE 0xf0000000 /* Localbus SDRAM */ #define CFG_LBC_SDRAM_SIZE 0 /* LBC SDRAM is 64MB */
#define CFG_FLASH_BASE 0xff800000 /* start of FLASH 8M */ #define CFG_BR0_PRELIM 0xff801001 /* port size 16bit */
#define CFG_OR0_PRELIM 0xff806f67 /* 8MB Flash */ #define CFG_MAX_FLASH_BANKS 1 /* number of banks */ #define CFG_MAX_FLASH_SECT 64 /* sectors per device */ #undef CFG_FLASH_CHECKSUM #define CFG_FLASH_ERASE_TOUT 60000 /* Flash Erase Timeout (ms) */ #define CFG_FLASH_WRITE_TOUT 500 /* Flash Write Timeout (ms) */
#define CFG_MONITOR_BASE TEXT_BASE /* start of monitor, value defined in config.mk -> 0xfff80000 */
#if (CFG_MONITOR_BASE < CFG_FLASH_BASE) /* if 0xFFF8_0000 < 0xFF80_0000 */ #define CFG_RAMBOOT #else #undef CFG_RAMBOOT #endif
#define CFG_FLASH_CFI_DRIVER #define CFG_FLASH_CFI #define CFG_FLASH_EMPTY_INFO
#undef CONFIG_CLOCKS_IN_MHZ
/* * Local Bus Definitions */
/* * Base Register 2 and Option Register 2 configure SDRAM. * The SDRAM base address, CFG_LBC_SDRAM_BASE, is 0xf0000000. * * For BR2, need: * Base address of 0xf0000000 = BR[0:16] = 1111 0000 0000 0000 0 * port-size = 32-bits = BR2[19:20] = 11 * no parity checking = BR2[21:22] = 00 * SDRAM for MSEL = BR2[24:26] = 011 * Valid = BR[31] = 1 * * 0 4 8 12 16 20 24 28 * 1111 0000 0000 0000 0001 1000 0110 0001 = f0001861 * * FIXME: CFG_LBC_SDRAM_BASE should be masked and OR'ed into * FIXME: the top 17 bits of BR2. */
#define CFG_BR2_PRELIM 0xf0001861
/* * The SDRAM size in MB, CFG_LBC_SDRAM_SIZE, is 64. * * For OR2, need: * 64MB mask for AM, OR2[0:7] = 1111 1100 * XAM, OR2[17:18] = 11 * 9 columns OR2[19-21] = 010 * 13 rows OR2[23-25] = 100 * EAD set for extra time OR[31] = 1 * * 0 4 8 12 16 20 24 28 * 1111 1100 0000 0000 0110 1001 0000 0001 = fc006901 */
#define CFG_OR2_PRELIM 0xfc006901
#define CFG_LBC_LCRR 0x00030004 /* LB clock ratio reg */ #define CFG_LBC_LBCR 0x00000000 /* LB config reg */ #define CFG_LBC_LSRT 0x20000000 /* LB sdram refresh timer */ #define CFG_LBC_MRTPR 0x20000000 /* LB refresh timer prescal*/
/* * LSDMR masks */ #define CFG_LBC_LSDMR_RFEN (1 << (31 - 1)) #define CFG_LBC_LSDMR_BSMA1516 (3 << (31 - 10)) #define CFG_LBC_LSDMR_BSMA1617 (4 << (31 - 10)) #define CFG_LBC_LSDMR_RFCR5 (3 << (31 - 16)) #define CFG_LBC_LSDMR_RFCR16 (7 << (31 - 16)) #define CFG_LBC_LSDMR_PRETOACT3 (3 << (31 - 19)) #define CFG_LBC_LSDMR_PRETOACT7 (7 << (31 - 19)) #define CFG_LBC_LSDMR_ACTTORW3 (3 << (31 - 22)) #define CFG_LBC_LSDMR_ACTTORW7 (7 << (31 - 22)) #define CFG_LBC_LSDMR_ACTTORW6 (6 << (31 - 22)) #define CFG_LBC_LSDMR_BL8 (1 << (31 - 23)) #define CFG_LBC_LSDMR_WRC2 (2 << (31 - 27)) #define CFG_LBC_LSDMR_WRC4 (0 << (31 - 27)) #define CFG_LBC_LSDMR_BUFCMD (1 << (31 - 29)) #define CFG_LBC_LSDMR_CL3 (3 << (31 - 31))
#define CFG_LBC_LSDMR_OP_NORMAL (0 << (31 - 4)) #define CFG_LBC_LSDMR_OP_ARFRSH (1 << (31 - 4)) #define CFG_LBC_LSDMR_OP_SRFRSH (2 << (31 - 4)) #define CFG_LBC_LSDMR_OP_MRW (3 << (31 - 4)) #define CFG_LBC_LSDMR_OP_PRECH (4 << (31 - 4)) #define CFG_LBC_LSDMR_OP_PCHALL (5 << (31 - 4)) #define CFG_LBC_LSDMR_OP_ACTBNK (6 << (31 - 4)) #define CFG_LBC_LSDMR_OP_RWINV (7 << (31 - 4))
#define CFG_LBC_LSDMR_COMMON ( CFG_LBC_LSDMR_BSMA1516 \ | CFG_LBC_LSDMR_RFCR5 \ | CFG_LBC_LSDMR_PRETOACT3 \ | CFG_LBC_LSDMR_ACTTORW3 \ | CFG_LBC_LSDMR_BL8 \ | CFG_LBC_LSDMR_WRC2 \ | CFG_LBC_LSDMR_CL3 \ | CFG_LBC_LSDMR_RFEN \ )
/* * SDRAM Controller configuration sequence. */ #define CFG_LBC_LSDMR_1 ( CFG_LBC_LSDMR_COMMON \ | CFG_LBC_LSDMR_OP_PCHALL) #define CFG_LBC_LSDMR_2 ( CFG_LBC_LSDMR_COMMON \ | CFG_LBC_LSDMR_OP_ARFRSH) #define CFG_LBC_LSDMR_3 ( CFG_LBC_LSDMR_COMMON \ | CFG_LBC_LSDMR_OP_ARFRSH) #define CFG_LBC_LSDMR_4 ( CFG_LBC_LSDMR_COMMON \ | CFG_LBC_LSDMR_OP_MRW) #define CFG_LBC_LSDMR_5 ( CFG_LBC_LSDMR_COMMON \ | CFG_LBC_LSDMR_OP_NORMAL)
/* * 32KB, 8-bit wide for ADS config reg */ #define CFG_BR4_PRELIM 0xf8000801 #define CFG_OR4_PRELIM 0xffffe1f1 #define CFG_BCSR (CFG_BR4_PRELIM & 0xffff8000)
#define CONFIG_L1_INIT_RAM #define CFG_INIT_RAM_LOCK 1 #define CFG_INIT_RAM_ADDR 0xe4010000 /* Initial RAM address */ #define CFG_INIT_RAM_END 0x4000 /* End of used area in RAM */
#define CFG_GBL_DATA_SIZE 128 /* num bytes initial data */ #define CFG_GBL_DATA_OFFSET (CFG_INIT_RAM_END - CFG_GBL_DATA_SIZE) #define CFG_INIT_SP_OFFSET CFG_GBL_DATA_OFFSET
#define CFG_MONITOR_LEN (512 * 1024) /* Reserve 512 kB for Mon */ #define CFG_MALLOC_LEN (128 * 1024) /* Reserved for malloc */
/* Serial Port */ #define CONFIG_CONS_INDEX 1 #undef CONFIG_SERIAL_SOFTWARE_FIFO #define CFG_NS16550 #define CFG_NS16550_SERIAL #define CFG_NS16550_REG_SIZE 1 #define CFG_NS16550_CLK get_bus_freq(0)
#define CFG_BAUDRATE_TABLE \ {300, 600, 1200, 2400, 4800, 9600, 19200, 38400,115200}
#define CFG_NS16550_COM1 (CFG_CCSRBAR+0x4500) #define CFG_NS16550_COM2 (CFG_CCSRBAR+0x4600)
/* Use the HUSH parser */ #define CFG_HUSH_PARSER #ifdef CFG_HUSH_PARSER #define CFG_PROMPT_HUSH_PS2 "> " #endif
/* I2C */ #define CONFIG_HARD_I2C /* I2C with hardware support*/ #undef CONFIG_SOFT_I2C /* I2C bit-banged */ #define CFG_I2C_SPEED 400000 /* I2C speed and slave address */ #define CFG_I2C_SLAVE 0x7F #define CFG_I2C_NOPROBES {0x69} /* Don't probe these addrs */
/* RapidIO MMU */ /* #define CFG_RIO_MEM_BASE 0xc0000000 * base address * * #define CFG_RIO_MEM_PHYS CFG_RIO_MEM_BASE * #define CFG_RIO_MEM_SIZE 0x20000000 * 128M */
/* * General PCI * Addresses are mapped 1-1. */ #define CFG_PCI1_MEM_BASE 0x80000000 #define CFG_PCI1_MEM_PHYS CFG_PCI1_MEM_BASE #define CFG_PCI1_MEM_SIZE 0x20000000 /* 512M */ #define CFG_PCI1_IO_BASE 0xe2000000 #define CFG_PCI1_IO_PHYS CFG_PCI1_IO_BASE #define CFG_PCI1_IO_SIZE 0x1000000 /* 16M */
#if defined(CONFIG_PCI)
#define CONFIG_NET_MULTI #define CONFIG_PCI_PNP /* do pci plug-and-play */
#undef CONFIG_EEPRO100 #define CONFIG_TULIP
#if !defined(CONFIG_PCI_PNP) #define PCI_ENET0_IOADDR 0xe0000000 #define PCI_ENET0_MEMADDR 0xe0000000 #define PCI_IDSEL_NUMBER 0x0c /* slot0->3(IDSEL)=12->15 */ #endif
#undef CONFIG_PCI_SCAN_SHOW 1 /* show pci devices on startup */ #define CFG_PCI_SUBSYS_VENDORID 0x1057 /* Motorola */
#endif /* CONFIG_PCI */
#if defined(CONFIG_TSEC_ENET)
#ifndef CONFIG_NET_MULTI #define CONFIG_NET_MULTI 1 #endif
#define CONFIG_MII 1 /* MII PHY management */ #define CONFIG_MPC85XX_TSEC1 1 #define CONFIG_MPC85XX_TSEC2 1 #define TSEC1_PHY_ADDR 0 #define TSEC2_PHY_ADDR 1 #define TSEC1_PHYIDX 0 #define TSEC2_PHYIDX 0
#define CONFIG_MPC85XX_FEC 1 #define FEC_PHY_ADDR 3 #define FEC_PHYIDX 0
#define CONFIG_ETHPRIME "MOTO ENET0"
#endif /* CONFIG_TSEC_ENET */
/* * Environment */ #ifndef CFG_RAMBOOT #define CFG_ENV_IS_IN_FLASH 1 #define CFG_ENV_ADDR (CFG_MONITOR_BASE + 0x40000) #define CFG_ENV_SECT_SIZE 0x40000 /* 256K(one sector) for env */ #define CFG_ENV_SIZE 0x2000 #else #define CFG_NO_FLASH 1 /* Flash is not usable now */ #define CFG_ENV_IS_NOWHERE 1 /* Store ENV in memory only */ #define CFG_ENV_ADDR (CFG_MONITOR_BASE - 0x1000) #define CFG_ENV_SIZE 0x2000 #endif
#define CONFIG_LOADS_ECHO 1 /* echo on for serial download */ #define CFG_LOADS_BAUD_CHANGE 1 /* allow baudrate change */
#if defined(CFG_RAMBOOT) #if defined(CONFIG_PCI) #define CONFIG_COMMANDS ((CONFIG_CMD_DFL \ | CFG_CMD_PING \ | CFG_CMD_PCI \ | CFG_CMD_I2C) \ & \ ~(CFG_CMD_ENV \ | CFG_CMD_LOADS)) #else #define CONFIG_COMMANDS ((CONFIG_CMD_DFL \ | CFG_CMD_PING \ | CFG_CMD_I2C) \ & \ ~(CFG_CMD_ENV \ | CFG_CMD_LOADS)) #endif #else #if defined(CONFIG_PCI) #define CONFIG_COMMANDS (CONFIG_CMD_DFL \ | CFG_CMD_PCI \ | CFG_CMD_PING \ | CFG_CMD_I2C) #else #define CONFIG_COMMANDS (CONFIG_CMD_DFL \ | CFG_CMD_PING \ | CFG_CMD_I2C) #endif #endif
#include <cmd_confdefs.h>
#undef CONFIG_WATCHDOG /* watchdog disabled */
/* * Miscellaneous configurable options */ #define CFG_LONGHELP /* undef to save memory */ #define CFG_LOAD_ADDR 0x2000000 /* default load address */ #define CFG_PROMPT "Studer.SCore=> " /* Monitor Command Prompt */
#if (CONFIG_COMMANDS & CFG_CMD_KGDB) #define CFG_CBSIZE 1024 /* Console I/O Buffer Size */ #else #define CFG_CBSIZE 256 /* Console I/O Buffer Size */ #endif
#define CFG_PBSIZE (CFG_CBSIZE+sizeof(CFG_PROMPT)+16) /* Print Buffer Size */ #define CFG_MAXARGS 16 /* max number of command args */ #define CFG_BARGSIZE CFG_CBSIZE /* Boot Argument Buffer Size */ #define CFG_HZ 1000 /* decrementer freq: 1ms ticks */
/* * For booting Linux, the board info and command line data * have to be in the first 8 MB of memory, since this is * the maximum mapped by the Linux kernel during initialization. */ #define CFG_BOOTMAPSZ (8 << 20) /* Initial Memory map for Linux*/
/* Cache Configuration */ #define CFG_DCACHE_SIZE 32768 #define CFG_CACHELINE_SIZE 32 #if (CONFIG_COMMANDS & CFG_CMD_KGDB) #define CFG_CACHELINE_SHIFT 5 /*log base 2 of the above value*/ #endif
/* * Internal Definitions * * Boot Flags */ #define BOOTFLAG_COLD 0x01 /* Normal Power-On: Boot from FLASH */ #define BOOTFLAG_WARM 0x02 /* Software reboot */
#if (CONFIG_COMMANDS & CFG_CMD_KGDB) #define CONFIG_KGDB_BAUDRATE 230400 /* speed to run kgdb serial port */ #define CONFIG_KGDB_SER_INDEX 2 /* which serial port to use */ #endif
/* * Environment Configuration */
/* The mac addresses for all ethernet interface */ #if defined(CONFIG_TSEC_ENET) #define CONFIG_ETHADDR 00:E0:0C:00:00:FD #define CONFIG_HAS_ETH1 #define CONFIG_ETH1ADDR 00:E0:0C:00:01:FD #define CONFIG_HAS_ETH2 #define CONFIG_ETH2ADDR 00:E0:0C:00:02:FD #endif
#define CONFIG_IPADDR 192.168.1.253
#define CONFIG_HOSTNAME unknown #define CONFIG_ROOTPATH /nfsroot #define CONFIG_BOOTFILE your.uImage
#define CONFIG_SERVERIP 192.168.1.1 #define CONFIG_GATEWAYIP 192.168.1.1 #define CONFIG_NETMASK 255.255.255.0
#define CONFIG_LOADADDR 200000 /* default location for tftp and bootm */
#define CONFIG_BOOTDELAY 10 /* -1 disables auto-boot */ #undef CONFIG_BOOTARGS /* the boot command will set bootargs */
#define CONFIG_BAUDRATE 115200
#define CONFIG_EXTRA_ENV_SETTINGS \ "netdev=eth0\0" \ "consoledev=ttyS0\0" \ "ramdiskaddr=400000\0" \ "ramdiskfile=your.ramdisk.u-boot\0"
#define CONFIG_NFSBOOTCOMMAND \ "setenv bootargs root=/dev/nfs rw " \ "nfsroot=$serverip:$rootpath " \ "ip=$ipaddr:$serverip:$gatewayip:$netmask:$hostname:$netdev:off " \ "console=$consoledev,$baudrate $othbootargs;" \ "tftp $loadaddr $bootfile;" \ "bootm $loadaddr"
#define CONFIG_RAMBOOTCOMMAND \ "setenv bootargs root=/dev/ram rw " \ "console=$consoledev,$baudrate $othbootargs;" \ "tftp $ramdiskaddr $ramdiskfile;" \ "tftp $loadaddr $bootfile;" \ "bootm $loadaddr $ramdiskaddr"
#define CONFIG_BOOTCOMMAND CONFIG_NFSBOOTCOMMAND
#endif /* __CONFIG_H */
Armand Ciejak
