[U-Boot] [PATCH v7 12/17] sf: Code cleanups
- comment typo's - func args have a proper names
Signed-off-by: Jagannadha Sutradharudu Teki jaganna@xilinx.com --- drivers/mtd/spi/sf_internal.h | 11 +++-------- drivers/mtd/spi/sf_ops.c | 6 +++--- drivers/mtd/spi/sf_probe.c | 4 ++-- include/spi_flash.h | 5 ++++- 4 files changed, 12 insertions(+), 14 deletions(-)
diff --git a/drivers/mtd/spi/sf_internal.h b/drivers/mtd/spi/sf_internal.h index c77961f..6bcd522 100644 --- a/drivers/mtd/spi/sf_internal.h +++ b/drivers/mtd/spi/sf_internal.h @@ -20,11 +20,6 @@ #define SPI_FLASH_CFI_MFR_MACRONIX 0xc2 #define SPI_FLASH_CFI_MFR_WINBOND 0xef
-/* SECT flags */ -#define SECT_4K (1 << 1) -#define SECT_32K (1 << 2) -#define E_FSR (1 << 3) - /* Erase commands */ #define CMD_ERASE_4K 0x20 #define CMD_ERASE_32K 0x52 @@ -60,10 +55,10 @@ #endif
/* Common status */ -#define STATUS_WIP 0x01 +#define STATUS_WIP (1 << 0) #define STATUS_QEB_WINSPAN (1 << 1) #define STATUS_QEB_MXIC (1 << 6) -#define STATUS_PEC 0x80 +#define STATUS_PEC (1 << 7)
/* Flash timeout values */ #define SPI_FLASH_PROG_TIMEOUT (2 * CONFIG_SYS_HZ) @@ -105,7 +100,7 @@ int spi_flash_cmd_erase_ops(struct spi_flash *flash, u32 offset, size_t len); int spi_flash_cmd_read_status(struct spi_flash *flash, u8 *rs);
/* Program the status register */ -int spi_flash_cmd_write_status(struct spi_flash *flash, u8 sr); +int spi_flash_cmd_write_status(struct spi_flash *flash, u8 ws);
/* Read the config register */ int spi_flash_cmd_read_config(struct spi_flash *flash, u8 *rc); diff --git a/drivers/mtd/spi/sf_ops.c b/drivers/mtd/spi/sf_ops.c index 28527fa..bc4a822 100644 --- a/drivers/mtd/spi/sf_ops.c +++ b/drivers/mtd/spi/sf_ops.c @@ -39,13 +39,13 @@ int spi_flash_cmd_read_status(struct spi_flash *flash, u8 *rs) return 0; }
-int spi_flash_cmd_write_status(struct spi_flash *flash, u8 sr) +int spi_flash_cmd_write_status(struct spi_flash *flash, u8 ws) { u8 cmd; int ret;
cmd = CMD_WRITE_STATUS; - ret = spi_flash_write_common(flash, &cmd, 1, &sr, 1); + ret = spi_flash_write_common(flash, &cmd, 1, &ws, 1); if (ret < 0) { debug("SF: fail to write status register\n"); return ret; @@ -279,7 +279,7 @@ int spi_flash_cmd_write_ops(struct spi_flash *flash, u32 offset,
spi_flash_addr(offset, cmd);
- debug("PP: 0x%p => cmd = { 0x%02x 0x%02x%02x%02x } chunk_len = %zu\n", + debug("SF: 0x%p => cmd = { 0x%02x 0x%02x%02x%02x } chunk_len = %zu\n", buf + actual, cmd[0], cmd[1], cmd[2], cmd[3], chunk_len);
ret = spi_flash_write_common(flash, cmd, sizeof(cmd), diff --git a/drivers/mtd/spi/sf_probe.c b/drivers/mtd/spi/sf_probe.c index 6b59f2a..ac42b60 100644 --- a/drivers/mtd/spi/sf_probe.c +++ b/drivers/mtd/spi/sf_probe.c @@ -167,7 +167,7 @@ static struct spi_flash *spi_flash_validate_params(struct spi_slave *spi, cmd = spi_read_cmds_array[cmd - 1]; flash->read_cmd = cmd; } else { - /* Go for for default supported read cmd */ + /* Go for default supported read cmd */ flash->read_cmd = CMD_READ_ARRAY_FAST; }
@@ -207,7 +207,7 @@ static struct spi_flash *spi_flash_validate_params(struct spi_slave *spi, flash->dummy_byte = 1; }
- /* Poll cmd seclection */ + /* Poll cmd selection */ flash->poll_cmd = CMD_READ_STATUS; #ifdef CONFIG_SPI_FLASH_STMICRO if (params->flags & E_FSR) diff --git a/include/spi_flash.h b/include/spi_flash.h index 437937c..213d659 100644 --- a/include/spi_flash.h +++ b/include/spi_flash.h @@ -19,7 +19,10 @@ #include <linux/types.h> #include <linux/compiler.h>
-/* No enum list for write commands only QPP */ +/* sf param flags */ +#define SECT_4K 1 << 1 +#define SECT_32K 1 << 2 +#define E_FSR 1 << 3 #define WR_QPP 1 << 4
/* Enum list - Full read commands */
