[U-Boot] [PATCH v4 0/2] rpi: passthrough of the firmware provided FDT blob
Raspberry firmware used to pass a FDT blob at a fixed address (0x100), but this is not true anymore. The address now depends on both the memory size and the blob size [1].
If one wants to passthrough this FDT blob to the kernel, the most reliable way is to save its address from the r2/x0 register in the U-Boot entry point and expose it in a environment variable for further processing.
This patch just does this: - save the provided address in the global variable fw_dtb_pointer - expose it in ${fdt_addr} if it points to a a valid FDT blob
There are many different ways to use it. One can, for example, use the following script which will extract from the tree the command line built by the firmware, then hand over the blob to a previously loaded kernel:
fdt addr ${fdt_addr} fdt get value bootargs /chosen bootargs bootz ${kernel_addr_r} - ${fdt_addr}
Alternatively, users relying on sysboot/pxe can simply omit any FDT statement in their extlinux.conf file, U-Boot will automagically pick ${fdt_addr} and pass it to the kernel.
[1] https://www.raspberrypi.org/forums//viewtopic.php?f=107&t=134018
Changes in v4: - add save_boot_params hook for ARM1176 to make the passthrough work on ARMv6-based original Pis
Changes in v3: - revert back to assembly for save_boot_params()
Changes in v2: - merge the series in a single patch - convert the save_boot_params() function to C code - add a board_get_usable_ram_top() function to protect the blob during relocation - remove the (obsolete) extern declaration from include/configs/rpi.h - rename the global variable to fw_dtb_pointer - rename the environment variable to ${fdt_addr} - fix 64-bits compatibility issues - document possible uses of ${fdt_addr}
Cédric Schieli (2): arm: add save_boot_params for ARM1176 rpi: passthrough of the firmware provided FDT blob
arch/arm/cpu/arm1176/start.S | 10 ++++++++++ board/raspberrypi/rpi/Makefile | 1 + board/raspberrypi/rpi/lowlevel_init.S | 36 +++++++++++++++++++++++++++++++++++ board/raspberrypi/rpi/rpi.c | 29 ++++++++++++++++++++++++++++ 4 files changed, 76 insertions(+) create mode 100644 board/raspberrypi/rpi/lowlevel_init.S
Implement a hook to allow boards to save boot-time CPU state for later use. When U-Boot is chain-loaded by another bootloader, CPU registers may contain useful information such as system configuration information. This feature mirrors the equivalent ARMv7 feature.
Signed-off-by: Cédric Schieli cschieli@gmail.com ---
arch/arm/cpu/arm1176/start.S | 10 ++++++++++ 1 file changed, 10 insertions(+)
diff --git a/arch/arm/cpu/arm1176/start.S b/arch/arm/cpu/arm1176/start.S index a602d4e..7c00201 100644 --- a/arch/arm/cpu/arm1176/start.S +++ b/arch/arm/cpu/arm1176/start.S @@ -16,6 +16,7 @@
#include <asm-offsets.h> #include <config.h> +#include <linux/linkage.h>
#ifndef CONFIG_SYS_PHY_UBOOT_BASE #define CONFIG_SYS_PHY_UBOOT_BASE CONFIG_SYS_UBOOT_BASE @@ -37,6 +38,11 @@ .globl reset
reset: + /* Allow the board to save important registers */ + b save_boot_params +.globl save_boot_params_ret +save_boot_params_ret: + /* * set the cpu to SVC32 mode */ @@ -110,3 +116,7 @@ mmu_disable_phys: c_runtime_cpu_setup:
mov pc, lr + +WEAK(save_boot_params) + b save_boot_params_ret /* back to my caller */ +ENDPROC(save_boot_params)
Acked-by: Stephen Warren swarren@nvidia.com
Signed-off-by: Cédric Schieli cschieli@gmail.com Acked-by: Stephen Warren swarren@nvidia.com
Changes in v4: None Changes in v3: - revert back to assembly for save_boot_params()
board/raspberrypi/rpi/Makefile | 1 + board/raspberrypi/rpi/lowlevel_init.S | 36 +++++++++++++++++++++++++++++++++++ board/raspberrypi/rpi/rpi.c | 29 ++++++++++++++++++++++++++++ 3 files changed, 66 insertions(+) create mode 100644 board/raspberrypi/rpi/lowlevel_init.S
diff --git a/board/raspberrypi/rpi/Makefile b/board/raspberrypi/rpi/Makefile index 4ce2c98..dcb25ac 100644 --- a/board/raspberrypi/rpi/Makefile +++ b/board/raspberrypi/rpi/Makefile @@ -5,3 +5,4 @@ #
obj-y := rpi.o +obj-y += lowlevel_init.o diff --git a/board/raspberrypi/rpi/lowlevel_init.S b/board/raspberrypi/rpi/lowlevel_init.S new file mode 100644 index 0000000..cdbd8e1 --- /dev/null +++ b/board/raspberrypi/rpi/lowlevel_init.S @@ -0,0 +1,36 @@ +/* + * (C) Copyright 2016 + * Cédric Schieli cschieli@gmail.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <config.h> + +.align 8 +.global fw_dtb_pointer +fw_dtb_pointer: +#ifdef CONFIG_ARM64 + .dword 0x0 +#else + .word 0x0 +#endif + +/* + * Routine: save_boot_params (called after reset from start.S) + * Description: save ATAG/FDT address provided by the firmware at boot time + */ + +.global save_boot_params +save_boot_params: + + /* The firmware provided ATAG/FDT address can be found in r2/x0 */ +#ifdef CONFIG_ARM64 + adr x8, fw_dtb_pointer + str x0, [x8] +#else + str r2, fw_dtb_pointer +#endif + + /* Returns */ + b save_boot_params_ret diff --git a/board/raspberrypi/rpi/rpi.c b/board/raspberrypi/rpi/rpi.c index 6245b36..ffd6d31 100644 --- a/board/raspberrypi/rpi/rpi.c +++ b/board/raspberrypi/rpi/rpi.c @@ -25,6 +25,9 @@
DECLARE_GLOBAL_DATA_PTR;
+/* From lowlevel_init.S */ +extern unsigned long fw_dtb_pointer; + static const struct bcm2835_gpio_platdata gpio_platdata = { .base = BCM2835_GPIO_BASE, }; @@ -285,6 +288,31 @@ static void set_fdtfile(void) setenv("fdtfile", fdtfile); }
+/* + * If the firmware provided a valid FDT at boot time, let's expose it in + * ${fdt_addr} so it may be passed unmodified to the kernel. + */ +static void set_fdt_addr(void) +{ + if (getenv("fdt_addr")) + return; + + if (fdt_magic(fw_dtb_pointer) != FDT_MAGIC) + return; + + setenv_hex("fdt_addr", fw_dtb_pointer); +} + +/* + * Prevent relocation from stomping on a firmware provided FDT blob. + */ +unsigned long board_get_usable_ram_top(unsigned long total_size) +{ + if ((gd->ram_top - fw_dtb_pointer) > SZ_64M) + return gd->ram_top; + return fw_dtb_pointer & ~0xffff; +} + static void set_usbethaddr(void) { ALLOC_CACHE_ALIGN_BUFFER(struct msg_get_mac_address, msg, 1); @@ -356,6 +384,7 @@ static void set_serial_number(void)
int misc_init_r(void) { + set_fdt_addr(); set_fdtfile(); set_usbethaddr(); #ifdef CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG
Cédric Schieli
Stephen Warren
