[PATCH v3 1/3] arm: mvebu: dts: sync DTS
Update the uDPU DTS to the version that is pending upstream [1][2][3][4].
[1] https://patchwork.kernel.org/project/linux-arm-kernel/patch/20220516124828.4... [2] https://patchwork.kernel.org/project/linux-arm-kernel/patch/20220516124828.4... [3] https://patchwork.kernel.org/project/linux-arm-kernel/patch/20220516124828.4... [4] https://patchwork.kernel.org/project/linux-arm-kernel/patch/20220516124828.4...
Signed-off-by: Robert Marko robert.marko@sartura.hr --- arch/arm/dts/armada-3720-uDPU.dts | 23 ++++++++++------------- 1 file changed, 10 insertions(+), 13 deletions(-)
diff --git a/arch/arm/dts/armada-3720-uDPU.dts b/arch/arm/dts/armada-3720-uDPU.dts index 1f534c0c65..f21a855fc6 100644 --- a/arch/arm/dts/armada-3720-uDPU.dts +++ b/arch/arm/dts/armada-3720-uDPU.dts @@ -16,7 +16,7 @@
/ { model = "Methode uDPU Board"; - compatible = "methode,udpu", "marvell,armada3720"; + compatible = "methode,udpu", "marvell,armada3720", "marvell,armada3710";
chosen { stdout-path = "serial0:115200n8"; @@ -28,35 +28,34 @@ };
leds { - pinctrl-names = "default"; compatible = "gpio-leds";
- power1 { + led-power1 { label = "udpu:green:power"; gpios = <&gpionb 11 GPIO_ACTIVE_LOW>; };
- power2 { + led-power2 { label = "udpu:red:power"; gpios = <&gpionb 12 GPIO_ACTIVE_LOW>; };
- network1 { + led-network1 { label = "udpu:green:network"; gpios = <&gpionb 13 GPIO_ACTIVE_LOW>; };
- network2 { + led-network2 { label = "udpu:red:network"; gpios = <&gpionb 14 GPIO_ACTIVE_LOW>; };
- alarm1 { + led-alarm1 { label = "udpu:green:alarm"; gpios = <&gpionb 15 GPIO_ACTIVE_LOW>; };
- alarm2 { + led-alarm2 { label = "udpu:red:alarm"; gpios = <&gpionb 16 GPIO_ACTIVE_LOW>; }; @@ -99,7 +98,7 @@ pinctrl-names = "default"; pinctrl-0 = <&spi_quad_pins>;
- spi-flash@0 { + flash@0 { compatible = "jedec,spi-nor"; reg = <0>; spi-max-frequency = <54000000>; @@ -153,14 +152,12 @@ scl-gpios = <&gpionb 2 (GPIO_ACTIVE_HIGH | GPIO_OPEN_DRAIN)>; sda-gpios = <&gpionb 3 (GPIO_ACTIVE_HIGH | GPIO_OPEN_DRAIN)>;
- nct375@48 { - status = "okay"; + temp-sensor@48 { compatible = "ti,tmp75c"; reg = <0x48>; };
- nct375@49 { - status = "okay"; + temp-sensor@49 { compatible = "ti,tmp75c"; reg = <0x49>; };
Methode eDPU is an Armada 3720 power board based on the Methode uDPU.
They feature the same CPU, RAM, and storage as well as the form factor.
However, eDPU only has one SFP slot plus a copper G.hn port which does not work under U-boot.
In order to reduce duplication, split the uDPU DTS into a common one.
Signed-off-by: Robert Marko robert.marko@sartura.hr --- Changes in v3: * Use DTS-es pending merge upstream * Re-enable SCSI as the Armada 37xx BOOT_TARGET_DEVICES defines SCSI device as one of the bootable ones. We dont have space constraints, so just re-enable SCSI rather than making one more config header
Changes in v2: * Correct the PHY mode to 2500Base-X * Add the DTB to Makefile * Remove SCSI/SATA, PCI and E1000 from defconfig as they are not present --- arch/arm/dts/Makefile | 1 + arch/arm/dts/armada-3720-eDPU-u-boot.dtsi | 45 ++++++ arch/arm/dts/armada-3720-eDPU.dts | 14 ++ arch/arm/dts/armada-3720-uDPU.dts | 150 +------------------- arch/arm/dts/armada-3720-uDPU.dtsi | 160 ++++++++++++++++++++++ configs/eDPU_defconfig | 96 +++++++++++++ 6 files changed, 317 insertions(+), 149 deletions(-) create mode 100644 arch/arm/dts/armada-3720-eDPU-u-boot.dtsi create mode 100644 arch/arm/dts/armada-3720-eDPU.dts create mode 100644 arch/arm/dts/armada-3720-uDPU.dtsi create mode 100644 configs/eDPU_defconfig
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 83630af4f6..c484875585 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -236,6 +236,7 @@ dtb-$(CONFIG_ARCH_MVEBU) += \ armada-3720-db.dtb \ armada-3720-espressobin.dtb \ armada-3720-turris-mox.dtb \ + armada-3720-eDPU.dtb \ armada-3720-uDPU.dtb \ armada-375-db.dtb \ armada-385-atl-x530.dtb \ diff --git a/arch/arm/dts/armada-3720-eDPU-u-boot.dtsi b/arch/arm/dts/armada-3720-eDPU-u-boot.dtsi new file mode 100644 index 0000000000..1b2648f64d --- /dev/null +++ b/arch/arm/dts/armada-3720-eDPU-u-boot.dtsi @@ -0,0 +1,45 @@ +// SPDX-License-Identifier: GPL-2.0+ + +/ { + smbios { + compatible = "u-boot,sysinfo-smbios"; + + smbios { + system { + product = "eDPU"; + }; + + baseboard { + product = "eDPU"; + }; + + chassis { + product = "eDPU"; + }; + }; + }; +}; + +&spi0 { + u-boot,dm-pre-reloc; + + spi-flash@0 { + u-boot,dm-pre-reloc; + }; +}; + +&sdhci0 { + u-boot,dm-pre-reloc; +}; + +ð0 { + /* G.hn does not work without additional configuration */ + status = "disabled"; +}; + +ð1 { + fixed-link { + speed = <1000>; + full-duplex; + }; +}; diff --git a/arch/arm/dts/armada-3720-eDPU.dts b/arch/arm/dts/armada-3720-eDPU.dts new file mode 100644 index 0000000000..57fc698e55 --- /dev/null +++ b/arch/arm/dts/armada-3720-eDPU.dts @@ -0,0 +1,14 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) + +/dts-v1/; + +#include "armada-3720-uDPU.dtsi" + +/ { + model = "Methode eDPU Board"; + compatible = "methode,edpu", "marvell,armada3720", "marvell,armada3710"; +}; + +ð0 { + phy-mode = "2500base-x"; +}; diff --git a/arch/arm/dts/armada-3720-uDPU.dts b/arch/arm/dts/armada-3720-uDPU.dts index f21a855fc6..a75734d88a 100644 --- a/arch/arm/dts/armada-3720-uDPU.dts +++ b/arch/arm/dts/armada-3720-uDPU.dts @@ -1,66 +1,13 @@ // SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/* - * Device tree for the uDPU board. - * Based on Marvell Armada 3720 development board (DB-88F3720-DDR3) - * Copyright (C) 2016 Marvell - * Copyright (C) 2019 Methode Electronics - * Copyright (C) 2019 Telus - * - * Vladimir Vid vladimir.vid@sartura.hr - */
/dts-v1/;
-#include <dt-bindings/gpio/gpio.h> -#include "armada-372x.dtsi" +#include "armada-3720-uDPU.dtsi"
/ { model = "Methode uDPU Board"; compatible = "methode,udpu", "marvell,armada3720", "marvell,armada3710";
- chosen { - stdout-path = "serial0:115200n8"; - }; - - memory@0 { - device_type = "memory"; - reg = <0x00000000 0x00000000 0x00000000 0x20000000>; - }; - - leds { - compatible = "gpio-leds"; - - led-power1 { - label = "udpu:green:power"; - gpios = <&gpionb 11 GPIO_ACTIVE_LOW>; - }; - - led-power2 { - label = "udpu:red:power"; - gpios = <&gpionb 12 GPIO_ACTIVE_LOW>; - }; - - led-network1 { - label = "udpu:green:network"; - gpios = <&gpionb 13 GPIO_ACTIVE_LOW>; - }; - - led-network2 { - label = "udpu:red:network"; - gpios = <&gpionb 14 GPIO_ACTIVE_LOW>; - }; - - led-alarm1 { - label = "udpu:green:alarm"; - gpios = <&gpionb 15 GPIO_ACTIVE_LOW>; - }; - - led-alarm2 { - label = "udpu:red:alarm"; - gpios = <&gpionb 16 GPIO_ACTIVE_LOW>; - }; - }; - sfp_eth0: sfp-eth0 { compatible = "sff,sfp"; i2c-bus = <&i2c0>; @@ -70,55 +17,6 @@ tx-fault-gpio = <&gpiosb 5 GPIO_ACTIVE_HIGH>; maximum-power-milliwatt = <3000>; }; - - sfp_eth1: sfp-eth1 { - compatible = "sff,sfp"; - i2c-bus = <&i2c1>; - los-gpio = <&gpiosb 7 GPIO_ACTIVE_HIGH>; - mod-def0-gpio = <&gpiosb 8 GPIO_ACTIVE_LOW>; - tx-disable-gpio = <&gpiosb 9 GPIO_ACTIVE_HIGH>; - tx-fault-gpio = <&gpiosb 10 GPIO_ACTIVE_HIGH>; - maximum-power-milliwatt = <3000>; - }; -}; - -&sdhci0 { - status = "okay"; - bus-width = <8>; - mmc-ddr-1_8v; - mmc-hs400-1_8v; - marvell,pad-type = "fixed-1-8v"; - non-removable; - no-sd; - no-sdio; -}; - -&spi0 { - status = "okay"; - pinctrl-names = "default"; - pinctrl-0 = <&spi_quad_pins>; - - flash@0 { - compatible = "jedec,spi-nor"; - reg = <0>; - spi-max-frequency = <54000000>; - - partitions { - compatible = "fixed-partitions"; - #address-cells = <1>; - #size-cells = <1>; - - partition@0 { - label = "firmware"; - reg = <0x0 0x180000>; - }; - - partition@180000 { - label = "u-boot-env"; - reg = <0x180000 0x10000>; - }; - }; - }; };
&pinctrl_nb { @@ -126,11 +24,6 @@ groups = "i2c1"; function = "gpio"; }; - - i2c2_recovery_pins: i2c2-recovery-pins { - groups = "i2c2"; - function = "gpio"; - }; };
&i2c0 { @@ -143,48 +36,7 @@ sda-gpios = <&gpionb 1 (GPIO_ACTIVE_HIGH | GPIO_OPEN_DRAIN)>; };
-&i2c1 { - status = "okay"; - pinctrl-names = "default", "recovery"; - pinctrl-0 = <&i2c2_pins>; - pinctrl-1 = <&i2c2_recovery_pins>; - /delete-property/mrvl,i2c-fast-mode; - scl-gpios = <&gpionb 2 (GPIO_ACTIVE_HIGH | GPIO_OPEN_DRAIN)>; - sda-gpios = <&gpionb 3 (GPIO_ACTIVE_HIGH | GPIO_OPEN_DRAIN)>; - - temp-sensor@48 { - compatible = "ti,tmp75c"; - reg = <0x48>; - }; - - temp-sensor@49 { - compatible = "ti,tmp75c"; - reg = <0x49>; - }; -}; - ð0 { phy-mode = "sgmii"; - status = "okay"; - managed = "in-band-status"; - phys = <&comphy1 0>; sfp = <&sfp_eth0>; }; - -ð1 { - phy-mode = "sgmii"; - status = "okay"; - managed = "in-band-status"; - phys = <&comphy0 1>; - sfp = <&sfp_eth1>; -}; - -&usb3 { - status = "okay"; - phys = <&usb2_utmi_otg_phy>; - phy-names = "usb2-utmi-otg-phy"; -}; - -&uart0 { - status = "okay"; -}; diff --git a/arch/arm/dts/armada-3720-uDPU.dtsi b/arch/arm/dts/armada-3720-uDPU.dtsi new file mode 100644 index 0000000000..3f79923376 --- /dev/null +++ b/arch/arm/dts/armada-3720-uDPU.dtsi @@ -0,0 +1,160 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Device tree for the uDPU board. + * Based on Marvell Armada 3720 development board (DB-88F3720-DDR3) + * Copyright (C) 2016 Marvell + * Copyright (C) 2019 Methode Electronics + * Copyright (C) 2019 Telus + * + * Vladimir Vid vladimir.vid@sartura.hr + */ + +/dts-v1/; + +#include <dt-bindings/gpio/gpio.h> +#include "armada-372x.dtsi" + +/ { + chosen { + stdout-path = "serial0:115200n8"; + }; + + memory@0 { + device_type = "memory"; + reg = <0x00000000 0x00000000 0x00000000 0x20000000>; + }; + + leds { + compatible = "gpio-leds"; + + led-power1 { + label = "udpu:green:power"; + gpios = <&gpionb 11 GPIO_ACTIVE_LOW>; + }; + + led-power2 { + label = "udpu:red:power"; + gpios = <&gpionb 12 GPIO_ACTIVE_LOW>; + }; + + led-network1 { + label = "udpu:green:network"; + gpios = <&gpionb 13 GPIO_ACTIVE_LOW>; + }; + + led-network2 { + label = "udpu:red:network"; + gpios = <&gpionb 14 GPIO_ACTIVE_LOW>; + }; + + led-alarm1 { + label = "udpu:green:alarm"; + gpios = <&gpionb 15 GPIO_ACTIVE_LOW>; + }; + + led-alarm2 { + label = "udpu:red:alarm"; + gpios = <&gpionb 16 GPIO_ACTIVE_LOW>; + }; + }; + + sfp_eth1: sfp-eth1 { + compatible = "sff,sfp"; + i2c-bus = <&i2c1>; + los-gpio = <&gpiosb 7 GPIO_ACTIVE_HIGH>; + mod-def0-gpio = <&gpiosb 8 GPIO_ACTIVE_LOW>; + tx-disable-gpio = <&gpiosb 9 GPIO_ACTIVE_HIGH>; + tx-fault-gpio = <&gpiosb 10 GPIO_ACTIVE_HIGH>; + maximum-power-milliwatt = <3000>; + }; +}; + +&sdhci0 { + status = "okay"; + bus-width = <8>; + mmc-ddr-1_8v; + mmc-hs400-1_8v; + marvell,pad-type = "fixed-1-8v"; + non-removable; + no-sd; + no-sdio; +}; + +&spi0 { + status = "okay"; + pinctrl-names = "default"; + pinctrl-0 = <&spi_quad_pins>; + + flash@0 { + compatible = "jedec,spi-nor"; + reg = <0>; + spi-max-frequency = <54000000>; + + partitions { + compatible = "fixed-partitions"; + #address-cells = <1>; + #size-cells = <1>; + + partition@0 { + label = "firmware"; + reg = <0x0 0x180000>; + }; + + partition@180000 { + label = "u-boot-env"; + reg = <0x180000 0x10000>; + }; + }; + }; +}; + +&pinctrl_nb { + i2c2_recovery_pins: i2c2-recovery-pins { + groups = "i2c2"; + function = "gpio"; + }; +}; + +&i2c1 { + status = "okay"; + pinctrl-names = "default", "recovery"; + pinctrl-0 = <&i2c2_pins>; + pinctrl-1 = <&i2c2_recovery_pins>; + /delete-property/mrvl,i2c-fast-mode; + scl-gpios = <&gpionb 2 (GPIO_ACTIVE_HIGH | GPIO_OPEN_DRAIN)>; + sda-gpios = <&gpionb 3 (GPIO_ACTIVE_HIGH | GPIO_OPEN_DRAIN)>; + + temp-sensor@48 { + compatible = "ti,tmp75c"; + reg = <0x48>; + }; + + temp-sensor@49 { + compatible = "ti,tmp75c"; + reg = <0x49>; + }; +}; + +ð0 { + status = "okay"; + managed = "in-band-status"; + phys = <&comphy1 0>; +}; + +ð1 { + phy-mode = "sgmii"; + status = "okay"; + managed = "in-band-status"; + phys = <&comphy0 1>; + sfp = <&sfp_eth1>; +}; + +&usb3 { + status = "okay"; + phys = <&usb2_utmi_otg_phy>; + phy-names = "usb2-utmi-otg-phy"; +}; + +&uart0 { + status = "okay"; +}; diff --git a/configs/eDPU_defconfig b/configs/eDPU_defconfig new file mode 100644 index 0000000000..5e5e5a6b4d --- /dev/null +++ b/configs/eDPU_defconfig @@ -0,0 +1,96 @@ +CONFIG_ARM=y +CONFIG_ARCH_CPU_INIT=y +CONFIG_ARCH_MVEBU=y +CONFIG_SYS_TEXT_BASE=0x00000000 +CONFIG_TARGET_MVEBU_ARMADA_37XX=y +CONFIG_MVEBU_EFUSE=y +CONFIG_ENV_SIZE=0x10000 +CONFIG_ENV_OFFSET=0x180000 +CONFIG_ENV_SECT_SIZE=0x10000 +CONFIG_DM_GPIO=y +CONFIG_DEFAULT_DEVICE_TREE="armada-3720-eDPU" +CONFIG_DEBUG_UART_BASE=0xd0012000 +CONFIG_SYS_LOAD_ADDR=0x6000000 +CONFIG_DEBUG_UART=y +CONFIG_DISTRO_DEFAULTS=y +# CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_FIT=y +CONFIG_FIT_VERBOSE=y +CONFIG_USE_PREBOOT=y +# CONFIG_DISPLAY_CPUINFO is not set +# CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_ARCH_EARLY_INIT_R=y +CONFIG_BOARD_EARLY_INIT_F=y +CONFIG_SYS_PROMPT="eDPU>> " +# CONFIG_CMD_ELF is not set +# CONFIG_CMD_IMI is not set +# CONFIG_CMD_XIMG is not set +# CONFIG_CMD_FLASH is not set +CONFIG_CMD_FUSE=y +CONFIG_CMD_GPIO=y +CONFIG_CMD_I2C=y +CONFIG_CMD_MMC=y +CONFIG_CMD_MTD=y +CONFIG_CMD_PCI=y +# CONFIG_CMD_SCSI is not set +CONFIG_CMD_SPI=y +CONFIG_CMD_USB=y +# CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_TFTPPUT=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_TIME=y +CONFIG_CMD_MVEBU_BUBT=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_MAC_PARTITION=y +CONFIG_ENV_OVERWRITE=y +CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_ARP_TIMEOUT=200 +CONFIG_NET_RETRY_COUNT=50 +CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_CLK=y +CONFIG_CLK_MVEBU=y +CONFIG_DM_I2C=y +CONFIG_DM_I2C_GPIO=y +CONFIG_SYS_I2C_MV=y +CONFIG_MISC=y +CONFIG_MMC_HS200_SUPPORT=y +CONFIG_MMC_SDHCI=y +CONFIG_MMC_SDHCI_SDMA=y +CONFIG_MMC_SDHCI_XENON=y +CONFIG_MTD=y +CONFIG_DM_MTD=y +CONFIG_SPI_FLASH_SFDP_SUPPORT=y +CONFIG_SPI_FLASH_MACRONIX=y +CONFIG_SPI_FLASH_SPANSION=y +CONFIG_SPI_FLASH_STMICRO=y +# CONFIG_SPI_FLASH_USE_4K_SECTORS is not set +CONFIG_SPI_FLASH_MTD=y +CONFIG_PHYLIB_10G=y +CONFIG_PHY_MARVELL=y +CONFIG_PHY_FIXED=y +CONFIG_PHY_GIGE=y +CONFIG_MVNETA=y +CONFIG_MVMDIO=y +CONFIG_PHY=y +CONFIG_MVEBU_COMPHY_SUPPORT=y +CONFIG_PINCTRL=y +CONFIG_PINCTRL_ARMADA_37XX=y +CONFIG_DM_REGULATOR_FIXED=y +CONFIG_DM_REGULATOR_GPIO=y +CONFIG_DM_SCSI=y +CONFIG_MVEBU_A3700_UART=y +CONFIG_MVEBU_A3700_SPI=y +CONFIG_SYSINFO=y +CONFIG_SYSINFO_SMBIOS=y +CONFIG_USB=y +CONFIG_USB_XHCI_HCD=y +CONFIG_USB_EHCI_HCD=y +CONFIG_USB_HOST_ETHER=y +CONFIG_USB_ETHER_ASIX=y +CONFIG_USB_ETHER_MCS7830=y +CONFIG_USB_ETHER_RTL8152=y +CONFIG_USB_ETHER_SMSC95XX=y +CONFIG_LZO=y +CONFIG_SPL_LZO=y
Changes in v3:
- Use DTS-es pending merge upstream
- Re-enable SCSI as the Armada 37xx BOOT_TARGET_DEVICES defines SCSI device
Changes in v2:
- Correct the PHY mode to 2500Base-X
- Add the DTB to Makefile
- Remove SCSI/SATA, PCI and E1000 from defconfig as they are not present
Hello! Seems that you forgot to remove some parts of PCI...
+CONFIG_SPL_LZO=y
2.36.1
Changes in v3:
Changes in v2:
Oh yeah, forgot the command(Which weirdly does not depend on PCI support at all) I will fixup it ASAP.
Regards, Robert
+CONFIG_SPL_LZO=y
2.36.1
I am currently maintaing the Methode uDPU and eDPU boards so add myself as the maintainer for them.
Signed-off-by: Robert Marko robert.marko@sartura.hr --- MAINTAINERS | 8 ++++++++ 1 file changed, 8 insertions(+)
diff --git a/MAINTAINERS b/MAINTAINERS index 56be0bfad0..3d72b0c11f 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -344,6 +344,14 @@ F: tools/mtk_image.c F: tools/mtk_image.h N: mediatek
+ARM METHODE SUPPORT +M: Robert Marko robert.marko@sartura.hr +S: Maintained +F: arch/arm/dts/armada-3720-eDPU* +F: arch/arm/dts/armada-3720-uDPU* +F: configs/eDPU_defconfig +F: configs/uDPU_defconfig + ARM MICROCHIP/ATMEL AT91 M: Eugen Hristev eugen.hristev@microchip.com S: Maintained
Pali Rohár
Robert Marko
