[PATCH 8/9] doc: add include/dm/of*.h to the HTML documentation
Correct Sphinx style comments in include/dm/ofnode.h and add the device tree node API to the HTML documentation; the ofnode functions are compatible with Live tree or with flat device tree.
Signed-off-by: Patrick Delaunay patrick.delaunay@foss.st.com ---
doc/api/dm.rst | 9 ++ include/dm/of.h | 13 +- include/dm/of_access.h | 141 ++++++++--------- include/dm/of_addr.h | 33 ++-- include/dm/of_extra.h | 48 +++--- include/dm/ofnode.h | 332 +++++++++++++++++++++-------------------- 6 files changed, 297 insertions(+), 279 deletions(-)
diff --git a/doc/api/dm.rst b/doc/api/dm.rst index 19a473f1f0..5bb66f2f50 100644 --- a/doc/api/dm.rst +++ b/doc/api/dm.rst @@ -17,3 +17,12 @@ Device .. kernel-doc:: include/dm/device.h .. kernel-doc:: include/dm/devres.h .. kernel-doc:: include/dm/read.h + +Device tree +----------- + +.. kernel-doc:: include/dm/of.h +.. kernel-doc:: include/dm/ofnode.h +.. kernel-doc:: include/dm/of_extra.h +.. kernel-doc:: include/dm/of_access.h +.. kernel-doc:: include/dm/of_addr.h diff --git a/include/dm/of.h b/include/dm/of.h index 5cb6f44a6c..963e1de44c 100644 --- a/include/dm/of.h +++ b/include/dm/of.h @@ -58,14 +58,13 @@ struct device_node { * struct of_phandle_args - structure to hold phandle and arguments * * This is used when decoding a phandle in a device tree property. Typically - * these look like this: + * these look like this: :: * - * wibble { - * phandle = <5>; - * }; - * - * ... - * some-prop = <&wibble 1 2 3> + * wibble { + * phandle = <5>; + * }; + * ... + * some-prop = <&wibble 1 2 3> * * Here &node is the phandle of the node 'wibble', i.e. 5. There are three * arguments: 1, 2, 3. diff --git a/include/dm/of_access.h b/include/dm/of_access.h index cc382b1671..2beb3797d7 100644 --- a/include/dm/of_access.h +++ b/include/dm/of_access.h @@ -44,7 +44,7 @@ static inline void of_node_put(const struct device_node *np) { } * which controls the given node. * * @np: Node pointer to check - * @return number of address cells this node uses + * Return: number of address cells this node uses */ int of_n_addr_cells(const struct device_node *np);
@@ -55,7 +55,7 @@ int of_n_addr_cells(const struct device_node *np); * which controls the given node. * * @np: Node pointer to check - * @return number of size cells this node uses + * Return: number of size cells this node uses */ int of_n_size_cells(const struct device_node *np);
@@ -65,7 +65,7 @@ int of_n_size_cells(const struct device_node *np); * This function matches fdt_address_cells(). * * @np: Node pointer to check - * @return value of #address-cells property in this node, or 2 if none + * Return: value of #address-cells property in this node, or 2 if none */ int of_simple_addr_cells(const struct device_node *np);
@@ -75,7 +75,7 @@ int of_simple_addr_cells(const struct device_node *np); * This function matches fdt_size_cells(). * * @np: Node pointer to check - * @return value of #size-cells property in this node, or 2 if none + * Return: value of #size-cells property in this node, or 2 if none */ int of_simple_size_cells(const struct device_node *np);
@@ -85,7 +85,7 @@ int of_simple_size_cells(const struct device_node *np); * @np: Pointer to device node holding property * @name: Name of property * @lenp: If non-NULL, returns length of property - * @return pointer to property, or NULL if not found + * Return: pointer to property, or NULL if not found */ struct property *of_find_property(const struct device_node *np, const char *name, int *lenp); @@ -98,7 +98,7 @@ struct property *of_find_property(const struct device_node *np, * @np: Pointer to device node holding property * @name: Name of property * @lenp: If non-NULL, returns length of property - * @return pointer to property value, or NULL if not found + * Return: pointer to property value, or NULL if not found */ const void *of_get_property(const struct device_node *np, const char *name, int *lenp); @@ -110,7 +110,7 @@ const void *of_get_property(const struct device_node *np, const char *name, * and read all the property with of_get_next_property_by_prop(). * * @np: Pointer to device node - * @return pointer to property or NULL if not found + * Return: pointer to property or NULL if not found */ const struct property *of_get_first_property(const struct device_node *np);
@@ -122,7 +122,7 @@ const struct property *of_get_first_property(const struct device_node *np); * * @np: Pointer to device node * @property: pointer of the current property - * @return pointer to next property or NULL if not found + * Return: pointer to next property or NULL if not found */ const struct property *of_get_next_property(const struct device_node *np, const struct property *property); @@ -132,11 +132,11 @@ const struct property *of_get_next_property(const struct device_node *np, * * Get value for the property identified by node and property pointer. * - * @node: node to read + * @np: Pointer to device node * @property: pointer of the property to read - * @propname: place to property name on success + * @name: place to property name on success * @lenp: place to put length on success - * @return pointer to property value or NULL if error + * Return: pointer to property value or NULL if error */ const void *of_get_property_by_prop(const struct device_node *np, const struct property *property, @@ -145,7 +145,7 @@ const void *of_get_property_by_prop(const struct device_node *np,
/** * of_device_is_compatible() - Check if the node matches given constraints - * @device: pointer to node + * @np: Pointer to device node * @compat: required compatible string, NULL or "" for any match * @type: required device_type value, NULL or "" for any match * @name: required node name, NULL or "" for any match @@ -154,7 +154,7 @@ const void *of_get_property_by_prop(const struct device_node *np, * properties of the given @device. A constraints can be skipped by * passing NULL or an empty string as the constraint. * - * @return 0 for no match, and a positive integer on match. The return + * Return: 0 for no match, and a positive integer on match. The return * value is a relative score with larger values indicating better * matches. The score is weighted for the most specific compatible value * to get the highest score. Matching type is next, followed by matching @@ -179,9 +179,9 @@ int of_device_is_compatible(const struct device_node *np, const char *compat, /** * of_device_is_available() - check if a device is available for use * - * @device: Node to check for availability + * @np: Pointer to device node to check for availability * - * @return true if the status property is absent or set to "okay", false + * Return: true if the status property is absent or set to "okay", false * otherwise */ bool of_device_is_available(const struct device_node *np); @@ -189,8 +189,8 @@ bool of_device_is_available(const struct device_node *np); /** * of_get_parent() - Get a node's parent, if any * - * @node: Node to check - * @eturns a node pointer, or NULL if none + * @np: Pointer to device node to check + * Return: a node pointer, or NULL if none */ struct device_node *of_get_parent(const struct device_node *np);
@@ -208,7 +208,7 @@ struct device_node *of_get_parent(const struct device_node *np); * foo Valid alias * foo/bar Valid alias + relative path * - * @return a node pointer or NULL if not found + * Return: a node pointer or NULL if not found */ struct device_node *of_find_node_opts_by_path(const char *path, const char **opts); @@ -228,7 +228,7 @@ static inline struct device_node *of_find_node_by_path(const char *path) * @type: The type string to match "device_type" or NULL to ignore * @compatible: The string to match to one of the tokens in the device * "compatible" list. - * @return node pointer or NULL if not found + * Return: node pointer or NULL if not found */ struct device_node *of_find_compatible_node(struct device_node *from, const char *type, const char *compatible); @@ -243,7 +243,7 @@ struct device_node *of_find_compatible_node(struct device_node *from, * @propname: property name to check * @propval: property value to search for * @proplen: length of the value in propval - * @return node pointer or NULL if not found + * Return: node pointer or NULL if not found */ struct device_node *of_find_node_by_prop_value(struct device_node *from, const char *propname, @@ -254,7 +254,7 @@ struct device_node *of_find_node_by_prop_value(struct device_node *from, * * @handle: phandle of the node to find * - * @return node pointer, or NULL if not found + * Return: node pointer, or NULL if not found */ struct device_node *of_find_node_by_phandle(phandle handle);
@@ -268,7 +268,7 @@ struct device_node *of_find_node_by_phandle(phandle handle); * @propname: name of the property to be searched. * @outp: pointer to return value, modified only if return value is 0. * - * @return 0 on success, -EINVAL if the property does not exist, + * Return: 0 on success, -EINVAL if the property does not exist, * -ENODATA if property does not have a value, and -EOVERFLOW if the * property data isn't large enough. */ @@ -286,9 +286,10 @@ int of_read_u32(const struct device_node *np, const char *propname, u32 *outp); * @index: index of the u32 in the list of values * @outp: pointer to return value, modified only if return value is 0. * - * @return 0 on success, -EINVAL if the property does not exist, - * -ENODATA if property does not have a value, and -EOVERFLOW if the - * property data isn't large enough. + * Return: + * 0 on success, -EINVAL if the property does not exist, + * -ENODATA if property does not have a value, and -EOVERFLOW if the + * property data isn't large enough. */ int of_read_u32_index(const struct device_node *np, const char *propname, int index, u32 *outp); @@ -303,9 +304,10 @@ int of_read_u32_index(const struct device_node *np, const char *propname, * @propname: name of the property to be searched. * @outp: pointer to return value, modified only if return value is 0. * - * @return 0 on success, -EINVAL if the property does not exist, - * -ENODATA if property does not have a value, and -EOVERFLOW if the - * property data isn't large enough. + * Return: + * 0 on success, -EINVAL if the property does not exist, + * -ENODATA if property does not have a value, and -EOVERFLOW if the + * property data isn't large enough. */ int of_read_u64(const struct device_node *np, const char *propname, u64 *outp);
@@ -319,8 +321,9 @@ int of_read_u64(const struct device_node *np, const char *propname, u64 *outp); * @propname: name of the property to be searched. * @out_values: pointer to return value, modified only if return value is 0. * @sz: number of array elements to read - * @return 0 on success, -EINVAL if the property does not exist, -ENODATA - * if property does not have a value, and -EOVERFLOW is longer than sz. + * Return: + * 0 on success, -EINVAL if the property does not exist, -ENODATA + * if property does not have a value, and -EOVERFLOW is longer than sz. */ int of_read_u32_array(const struct device_node *np, const char *propname, u32 *out_values, size_t sz); @@ -334,8 +337,9 @@ int of_read_u32_array(const struct device_node *np, const char *propname, * @np: pointer to node containing string list property * @propname: string list property name * @string: pointer to string to search for in string list - * @return 0 on success, -EINVAL if the property does not exist, -ENODATA - * if property does not have a value, and -EOVERFLOW is longer than sz. + * Return: + * 0 on success, -EINVAL if the property does not exist, -ENODATA + * if property does not have a value, and -EOVERFLOW is longer than sz. */ int of_property_match_string(const struct device_node *np, const char *propname, const char *string); @@ -350,15 +354,17 @@ int of_property_read_string_helper(const struct device_node *np, * @np: device node from which the property value is to be read. * @propname: name of the property to be searched. * @index: index of the string in the list of strings - * @out_string: pointer to null terminated return string, modified only if + * @output: pointer to null terminated return string, modified only if * return value is 0. * * Search for a property in a device tree node and retrieve a null * terminated string value (pointer to data, not a copy) in the list of strings * contained in that property. - * Returns 0 on success, -EINVAL if the property does not exist, -ENODATA if - * property does not have a value, and -EILSEQ if the string is not - * null-terminated within the length of the property data. + * + * Return: + * 0 on success, -EINVAL if the property does not exist, -ENODATA if + * property does not have a value, and -EILSEQ if the string is not + * null-terminated within the length of the property data. * * The out_string pointer is modified only if a valid string can be decoded. */ @@ -377,10 +383,12 @@ static inline int of_property_read_string_index(const struct device_node *np, * @propname: name of the property to be searched. * * Search for a property in a device tree node and retrieve the number of null - * terminated string contain in it. Returns the number of strings on - * success, -EINVAL if the property does not exist, -ENODATA if property - * does not have a value, and -EILSEQ if the string is not null-terminated - * within the length of the property data. + * terminated string contain in it. + * + * Return: + * the number of strings on success, -EINVAL if the property does not exist, + * -ENODATA if property does not have a value, and -EILSEQ if the string is + * not null-terminated within the length of the property data. */ static inline int of_property_count_strings(const struct device_node *np, const char *propname) @@ -395,8 +403,9 @@ static inline int of_property_count_strings(const struct device_node *np, * @index: For properties holding a table of phandles, this is the index into * the table * - * Returns the device_node pointer with refcount incremented. Use - * of_node_put() on it when done. + * Return: + * the device_node pointer with refcount incremented. Use + * of_node_put() on it when done. */ struct device_node *of_parse_phandle(const struct device_node *np, const char *phandle_name, int index); @@ -410,10 +419,11 @@ struct device_node *of_parse_phandle(const struct device_node *np, * @cells_count: Cell count to use if @cells_name is NULL * @index: index of a phandle to parse out * @out_args: optional pointer to output arguments structure (will be filled) - * @return 0 on success (with @out_args filled out if not NULL), -ENOENT if - * @list_name does not exist, -EINVAL if a phandle was not found, - * @cells_name could not be found, the arguments were truncated or there - * were too many arguments. + * Return: + * 0 on success (with @out_args filled out if not NULL), -ENOENT if + * @list_name does not exist, -EINVAL if a phandle was not found, + * @cells_name could not be found, the arguments were truncated or there + * were too many arguments. * * This function is useful to parse lists of phandles and their arguments. * Returns 0 on success and fills out_args, on error returns appropriate @@ -422,19 +432,17 @@ struct device_node *of_parse_phandle(const struct device_node *np, * Caller is responsible to call of_node_put() on the returned out_args->np * pointer. * - * Example: + * Example: :: * - * phandle1: node1 { - * #list-cells = <2>; - * } - * - * phandle2: node2 { - * #list-cells = <1>; - * } - * - * node3 { - * list = <&phandle1 1 2 &phandle2 3>; - * } + * phandle1: node1 { + * #list-cells = <2>; + * }; + * phandle2: node2 { + * #list-cells = <1>; + * }; + * node3 { + * list = <&phandle1 1 2 &phandle2 3>; + * }; * * To get a device_node of the `node2' node you may call this: * of_parse_phandle_with_args(node3, "list", "#list-cells", 1, &args); @@ -451,14 +459,13 @@ int of_parse_phandle_with_args(const struct device_node *np, * @list_name: property name that contains a list * @cells_name: property name that specifies phandles' arguments count * @cells_count: Cell count to use if @cells_name is NULL - * @return number of phandle found, -ENOENT if - * @list_name does not exist, -EINVAL if a phandle was not found, - * @cells_name could not be found, the arguments were truncated or there - * were too many arguments. + * Return: + * number of phandle found, -ENOENT if @list_name does not exist, + * -EINVAL if a phandle was not found, @cells_name could not be found, + * the arguments were truncated or there were too many arguments. * * Returns number of phandle found on success, on error returns appropriate * errno value. - * */ int of_count_phandle_with_args(const struct device_node *np, const char *list_name, const char *cells_name, @@ -471,7 +478,7 @@ int of_count_phandle_with_args(const struct device_node *np, * the lookup table with the properties. It returns the number of alias * properties found, or an error code in case of failure. * - * @return 9 if OK, -ENOMEM if not enough memory + * Return: 9 if OK, -ENOMEM if not enough memory */ int of_alias_scan(void);
@@ -483,7 +490,7 @@ int of_alias_scan(void); * * @np: Pointer to the given device_node * @stem: Alias stem of the given device_node - * @return alias ID, if found, else -ENODEV + * Return: alias ID, if found, else -ENODEV */ int of_alias_get_id(const struct device_node *np, const char *stem);
@@ -493,14 +500,14 @@ int of_alias_get_id(const struct device_node *np, const char *stem); * * The function travels the lookup table to get the highest alias id for the * given alias stem. - * @return alias ID, if found, else -1 + * Return: alias ID, if found, else -1 */ int of_alias_get_highest_id(const char *stem);
/** * of_get_stdout() - Get node to use for stdout * - * @return node referred to by stdout-path alias, or NULL if none + * Return: node referred to by stdout-path alias, or NULL if none */ struct device_node *of_get_stdout(void);
diff --git a/include/dm/of_addr.h b/include/dm/of_addr.h index ee21d5cf4f..e7f3a28081 100644 --- a/include/dm/of_addr.h +++ b/include/dm/of_addr.h @@ -20,11 +20,11 @@ * that can be mapped to a cpu physical address). This is not really specified * that way, but this is traditionally the way IBM at least do things * - * @np: node to check + * @np: pointer to node to check * @in_addr: pointer to input address - * @return translated address or OF_BAD_ADDR on error + * Return: translated address or OF_BAD_ADDR on error */ -u64 of_translate_address(const struct device_node *no, const __be32 *in_addr); +u64 of_translate_address(const struct device_node *np, const __be32 *in_addr);
/** * of_translate_dma_address() - translate a device-tree DMA address to a CPU @@ -38,11 +38,11 @@ u64 of_translate_address(const struct device_node *no, const __be32 *in_addr); * that can be mapped to a cpu physical address). This is not really specified * that way, but this is traditionally the way IBM at least do things * - * @np: node to check + * @np: ne * @in_addr: pointer to input DMA address - * @return translated DMA address or OF_BAD_ADDR on error + * Return: translated DMA address or OF_BAD_ADDR on error */ -u64 of_translate_dma_address(const struct device_node *no, const __be32 *in_addr); +u64 of_translate_dma_address(const struct device_node *np, const __be32 *in_addr);
/** @@ -51,14 +51,13 @@ u64 of_translate_dma_address(const struct device_node *no, const __be32 *in_addr * Get DMA ranges for a specifc node, this is useful to perform bus->cpu and * cpu->bus address translations * - * @param blob Pointer to device tree blob - * @param node_offset Node DT offset - * @param cpu Pointer to variable storing the range's cpu address - * @param bus Pointer to variable storing the range's bus address - * @param size Pointer to variable storing the range's size - * @return translated DMA address or OF_BAD_ADDR on error + * @np: Pointer to device tree blob + * @cpu: Pointer to variable storing the range's cpu address + * @bus: Pointer to variable storing the range's bus address + * @size: Pointer to variable storing the range's size + * Return: translated DMA address or OF_BAD_ADDR on error */ -int of_get_dma_range(const struct device_node *dev, phys_addr_t *cpu, +int of_get_dma_range(const struct device_node *np, phys_addr_t *cpu, dma_addr_t *bus, u64 *size);
/** @@ -72,9 +71,9 @@ int of_get_dma_range(const struct device_node *dev, phys_addr_t *cpu, * @index: Index of address to read (0 = first) * @size: place to put size on success * @flags: place to put flags on success - * @return pointer to address which can be read + * Return: pointer to address which can be read */ -const __be32 *of_get_address(const struct device_node *no, int index, +const __be32 *of_get_address(const struct device_node *np, int index, u64 *size, unsigned int *flags);
struct resource; @@ -90,9 +89,9 @@ struct resource; * @np: node to check * @index: index of address to read (0 = first) * @r: place to put resource information - * @return 0 if OK, -ve on error + * Return: 0 if OK, -ve on error */ -int of_address_to_resource(const struct device_node *no, int index, +int of_address_to_resource(const struct device_node *np, int index, struct resource *r);
#endif diff --git a/include/dm/of_extra.h b/include/dm/of_extra.h index c2498aa585..17e85a819b 100644 --- a/include/dm/of_extra.h +++ b/include/dm/of_extra.h @@ -41,11 +41,11 @@ struct fmap_entry { };
/** - * Read a flash entry from the fdt + * ofnode_read_fmap_entry() - Read a flash entry from the fdt * - * @param node Reference to node to read - * @param entry Place to put offset and size of this node - * @return 0 if ok, -ve on error + * @node: Reference to node to read + * @entry: Place to put offset and size of this node + * Return: 0 if ok, -ve on error */ int ofnode_read_fmap_entry(ofnode node, struct fmap_entry *entry);
@@ -58,11 +58,11 @@ int ofnode_read_fmap_entry(ofnode node, struct fmap_entry *entry); * The property must hold one address with a length. This is only tested on * 32-bit machines. * - * @param node ofnode to examine - * @param prop_name name of property to find - * @param basep Returns base address of region - * @param size Returns size of region - * @return 0 if ok, -1 on error (property not found) + * @node: ofnode to examine + * @prop_name: name of property to find + * @basep: Returns base address of region + * @sizep: Returns size of region + * Return: 0 if ok, -1 on error (property not found) */ int ofnode_decode_region(ofnode node, const char *prop_name, fdt_addr_t *basep, fdt_size_t *sizep); @@ -81,14 +81,14 @@ int ofnode_decode_region(ofnode node, const char *prop_name, fdt_addr_t *basep, * The property value must have an offset and a size. The function checks * that the region is entirely within the memory bank.5 * - * @param node ofnode containing the properties (-1 for /config) - * @param mem_type Type of memory to use, which is a name, such as - * "u-boot" or "kernel". - * @param suffix String to append to the memory/offset - * property names - * @param basep Returns base of region - * @param sizep Returns size of region - * @return 0 if OK, -ive on error + * @config_node: ofnode containing the properties (invalid for "/config") + * @mem_type: Type of memory to use, which is a name, such as + * "u-boot" or "kernel". + * @suffix: String to append to the memory/offset + * property names + * @basep: Returns base of region + * @sizep: Returns size of region + * Return: 0 if OK, -ive on error */ int ofnode_decode_memory_region(ofnode config_node, const char *mem_type, const char *suffix, fdt_addr_t *basep, @@ -102,15 +102,15 @@ int ofnode_decode_memory_region(ofnode config_node, const char *mem_type, * * This function supports the following two DT bindings: * - the new DT binding, where 'fixed-link' is a sub-node of the - * Ethernet device + * Ethernet device * - the old DT binding, where 'fixed-link' is a property with 5 - * cells encoding various information about the fixed PHY + * cells encoding various information about the fixed PHY * * If both new and old bindings exist, the new one is preferred. * - * @param eth_node ofnode containing the fixed-link subnode/property - * @param phy_node if fixed-link PHY detected, containing the PHY ofnode - * @return true if a fixed-link pseudo-PHY device exists, false otherwise + * @eth_node: ofnode containing the fixed-link subnode/property + * @phy_node: if fixed-link PHY detected, containing the PHY ofnode + * Return: true if a fixed-link pseudo-PHY device exists, false otherwise */ bool ofnode_phy_is_fixed_link(ofnode eth_node, ofnode *phy_node);
@@ -123,8 +123,8 @@ bool ofnode_phy_is_fixed_link(ofnode eth_node, ofnode *phy_node); * is connected to an on-board PHY or an SFP cage, and is not relevant when it * has a fixed link (in that case, in-band autoneg should not be used). * - * @param eth_node ofnode belonging to the Ethernet controller - * @return true if in-band autoneg should be used, false otherwise + * @eth_node: ofnode belonging to the Ethernet controller + * Return: true if in-band autoneg should be used, false otherwise */ bool ofnode_eth_uses_inband_aneg(ofnode eth_node);
diff --git a/include/dm/ofnode.h b/include/dm/ofnode.h index 6601bd8318..8b4f628856 100644 --- a/include/dm/ofnode.h +++ b/include/dm/ofnode.h @@ -19,7 +19,7 @@ struct resource;
/** - * ofnode - reference to a device tree node + * typedef union ofnode_union ofnode - reference to a device tree node * * This union can hold either a straightforward pointer to a struct device_node * in the live device tree, or an offset within the flat device tree. In the @@ -27,7 +27,7 @@ struct resource; * * Thus we can reference nodes in both the live tree (once available) and the * flat tree (until then). Functions are available to translate between an - * ofnode and either an offset or a struct device_node *. + * ofnode and either an offset or a `struct device_node *`. * * The reference can also hold a null offset, in which case the pointer value * here is NULL. This corresponds to a struct device_node * value of @@ -61,7 +61,7 @@ struct ofnode_phandle_args { };
/** - * ofprop - reference to a property of a device tree node + * struct ofprop - reference to a property of a device tree node * * This struct hold the reference on one property of one node, * using struct ofnode and an offset within the flat device tree or either @@ -91,7 +91,7 @@ struct ofprop { * This cannot be called if the reference contains an offset. * * @node: Reference containing struct device_node * (possibly invalid) - * @return pointer to device node (can be NULL) + * Return: pointer to device node (can be NULL) */ static inline const struct device_node *ofnode_to_np(ofnode node) { @@ -108,7 +108,7 @@ static inline const struct device_node *ofnode_to_np(ofnode node) * This cannot be called if the reference contains a node pointer. * * @node: Reference containing offset (possibly invalid) - * @return DT offset (can be -1) + * Return: DT offset (can be -1) */ static inline int ofnode_to_offset(ofnode node) { @@ -122,7 +122,8 @@ static inline int ofnode_to_offset(ofnode node) /** * ofnode_valid() - check if an ofnode is valid * - * @return true if the reference contains a valid ofnode, false if it is NULL + * @node: Reference containing offset (possibly invalid) + * Return: true if the reference contains a valid ofnode, false if it is NULL */ static inline bool ofnode_valid(ofnode node) { @@ -136,7 +137,7 @@ static inline bool ofnode_valid(ofnode node) * offset_to_ofnode() - convert a DT offset to an ofnode * * @of_offset: DT offset (either valid, or -1) - * @return reference to the associated DT offset + * Return: reference to the associated DT offset */ static inline ofnode offset_to_ofnode(int of_offset) { @@ -154,7 +155,7 @@ static inline ofnode offset_to_ofnode(int of_offset) * np_to_ofnode() - convert a node pointer to an ofnode * * @np: Live node pointer (can be NULL) - * @return reference to the associated node pointer + * Return: reference to the associated node pointer */ static inline ofnode np_to_ofnode(const struct device_node *np) { @@ -173,7 +174,7 @@ static inline ofnode np_to_ofnode(const struct device_node *np) * is valid is not permitted. * * @node: reference to check (possibly invalid) - * @return true if the reference is a live node pointer, false if it is a DT + * Return: true if the reference is a live node pointer, false if it is a DT * offset */ static inline bool ofnode_is_np(ofnode node) @@ -193,7 +194,9 @@ static inline bool ofnode_is_np(ofnode node) /** * ofnode_equal() - check if two references are equal * - * @return true if equal, else false + * @ref1: first reference to check (possibly invalid) + * @ref2: second reference to check (possibly invalid) + * Return: true if equal, else false */ static inline bool ofnode_equal(ofnode ref1, ofnode ref2) { @@ -237,28 +240,28 @@ static inline ofnode ofnode_root(void) * * @node: valid node reference that has to be compared * @name: name that has to be compared with the node name - * @return true if matches, false if it doesn't match + * Return: true if matches, false if it doesn't match */ bool ofnode_name_eq(ofnode node, const char *name);
/** * ofnode_read_u32() - Read a 32-bit integer from a property * - * @ref: valid node reference to read property from + * @node: valid node reference to read property from * @propname: name of the property to read from * @outp: place to put value (if found) - * @return 0 if OK, -ve on error + * Return: 0 if OK, -ve on error */ int ofnode_read_u32(ofnode node, const char *propname, u32 *outp);
/** * ofnode_read_u32_index() - Read a 32-bit integer from a multi-value property * - * @ref: valid node reference to read property from + * @node: valid node reference to read property from * @propname: name of the property to read from * @index: index of the integer to return * @outp: place to put value (if found) - * @return 0 if OK, -ve on error + * Return: 0 if OK, -ve on error */ int ofnode_read_u32_index(ofnode node, const char *propname, int index, u32 *outp); @@ -266,47 +269,47 @@ int ofnode_read_u32_index(ofnode node, const char *propname, int index, /** * ofnode_read_s32() - Read a 32-bit integer from a property * - * @ref: valid node reference to read property from + * @node: valid node reference to read property from * @propname: name of the property to read from * @outp: place to put value (if found) - * @return 0 if OK, -ve on error + * Return: 0 if OK, -ve on error */ static inline int ofnode_read_s32(ofnode node, const char *propname, - s32 *out_value) + s32 *outp) { - return ofnode_read_u32(node, propname, (u32 *)out_value); + return ofnode_read_u32(node, propname, (u32 *)outp); }
/** * ofnode_read_u32_default() - Read a 32-bit integer from a property * - * @ref: valid node reference to read property from + * @node: valid node reference to read property from * @propname: name of the property to read from * @def: default value to return if the property has no value - * @return property value, or @def if not found + * Return: property value, or @def if not found */ -u32 ofnode_read_u32_default(ofnode ref, const char *propname, u32 def); +u32 ofnode_read_u32_default(ofnode node, const char *propname, u32 def);
/** * ofnode_read_u32_index_default() - Read a 32-bit integer from a multi-value * property * - * @ref: valid node reference to read property from + * @node: valid node reference to read property from * @propname: name of the property to read from * @index: index of the integer to return * @def: default value to return if the property has no value - * @return property value, or @def if not found + * Return: property value, or @def if not found */ -u32 ofnode_read_u32_index_default(ofnode ref, const char *propname, int index, +u32 ofnode_read_u32_index_default(ofnode node, const char *propname, int index, u32 def);
/** * ofnode_read_s32_default() - Read a 32-bit integer from a property * - * @ref: valid node reference to read property from + * @node: valid node reference to read property from * @propname: name of the property to read from * @def: default value to return if the property has no value - * @return property value, or @def if not found + * Return: property value, or @def if not found */ int ofnode_read_s32_default(ofnode node, const char *propname, s32 def);
@@ -316,17 +319,17 @@ int ofnode_read_s32_default(ofnode node, const char *propname, s32 def); * @node: valid node reference to read property from * @propname: name of the property to read from * @outp: place to put value (if found) - * @return 0 if OK, -ve on error + * Return: 0 if OK, -ve on error */ int ofnode_read_u64(ofnode node, const char *propname, u64 *outp);
/** * ofnode_read_u64_default() - Read a 64-bit integer from a property * - * @ref: valid node reference to read property from + * @node: valid node reference to read property from * @propname: name of the property to read from * @def: default value to return if the property has no value - * @return property value, or @def if not found + * Return: property value, or @def if not found */ u64 ofnode_read_u64_default(ofnode node, const char *propname, u64 def);
@@ -336,8 +339,8 @@ u64 ofnode_read_u64_default(ofnode node, const char *propname, u64 def); * @node: valid node reference to read property from * @propname: name of the property to read * @sizep: if non-NULL, returns the size of the property, or an error code - if not found - * @return property value, or NULL if there is no such property + * if not found + * Return: property value, or NULL if there is no such property */ const void *ofnode_read_prop(ofnode node, const char *propname, int *sizep);
@@ -346,7 +349,7 @@ const void *ofnode_read_prop(ofnode node, const char *propname, int *sizep); * * @node: valid node reference to read property from * @propname: name of the property to read - * @return string from property value, or NULL if there is no such property + * Return: string from property value, or NULL if there is no such property */ const char *ofnode_read_string(ofnode node, const char *propname);
@@ -357,7 +360,7 @@ const char *ofnode_read_string(ofnode node, const char *propname); * @propname: name of the property to read * @out_values: pointer to return value, modified only if return value is 0 * @sz: number of array elements to read - * @return 0 if OK, -ve on error + * Return: 0 if OK, -ve on error * * Search for a property in a device node and read 32-bit value(s) from * it. Returns 0 on success, -EINVAL if the property does not exist, @@ -374,7 +377,7 @@ int ofnode_read_u32_array(ofnode node, const char *propname, * * @node: valid node reference to read property from * @propname: name of property to read - * @return true if property is present (meaning true), false if not present + * Return: true if property is present (meaning true), false if not present */ bool ofnode_read_bool(ofnode node, const char *propname);
@@ -383,7 +386,7 @@ bool ofnode_read_bool(ofnode node, const char *propname); * * @node: valid reference to parent node * @subnode_name: name of subnode to find - * @return reference to subnode (which can be invalid if there is no such + * Return: reference to subnode (which can be invalid if there is no such * subnode) */ ofnode ofnode_find_subnode(ofnode node, const char *subnode_name); @@ -429,7 +432,7 @@ static inline ofnode ofnode_next_subnode(ofnode node) * by default. * * @node: node to examine - * @return false (not enabled) or true (enabled) + * Return: false (not enabled) or true (enabled) */ bool ofnode_is_enabled(ofnode node);
@@ -437,7 +440,7 @@ bool ofnode_is_enabled(ofnode node); * ofnode_first_subnode() - find the first subnode of a parent node * * @node: valid reference to a valid parent node - * @return reference to the first subnode (which can be invalid if the parent + * Return: reference to the first subnode (which can be invalid if the parent * node has no subnodes) */ ofnode ofnode_first_subnode(ofnode node); @@ -446,7 +449,7 @@ ofnode ofnode_first_subnode(ofnode node); * ofnode_next_subnode() - find the next sibling of a subnode * * @node: valid reference to previous node (sibling) - * @return reference to the next subnode (which can be invalid if the node + * Return: reference to the next subnode (which can be invalid if the node * has no more siblings) */ ofnode ofnode_next_subnode(ofnode node); @@ -456,7 +459,7 @@ ofnode ofnode_next_subnode(ofnode node); * ofnode_get_parent() - get the ofnode's parent (enclosing ofnode) * * @node: valid node to look up - * @return ofnode reference of the parent node + * Return: ofnode reference of the parent node */ ofnode ofnode_get_parent(ofnode node);
@@ -464,7 +467,7 @@ ofnode ofnode_get_parent(ofnode node); * ofnode_get_name() - get the name of a node * * @node: valid node to look up - * @return name of node + * Return: name of node */ const char *ofnode_get_name(ofnode node);
@@ -474,7 +477,7 @@ const char *ofnode_get_name(ofnode node); * @node: valid node to look up * @buf: buffer to write the node path into * @buflen: buffer size - * @return 0 if OK, -ve on error + * Return: 0 if OK, -ve on error */ int ofnode_get_path(ofnode node, char *buf, int buflen);
@@ -482,7 +485,7 @@ int ofnode_get_path(ofnode node, char *buf, int buflen); * ofnode_get_by_phandle() - get ofnode from phandle * * @phandle: phandle to look up - * @return ofnode reference to the phandle + * Return: ofnode reference to the phandle */ ofnode ofnode_get_by_phandle(uint phandle);
@@ -491,7 +494,7 @@ ofnode ofnode_get_by_phandle(uint phandle); * * @node: node to check * @propname: property to check - * @return size of property if present, or -EINVAL if not + * Return: size of property if present, or -EINVAL if not */ int ofnode_read_size(ofnode node, const char *propname);
@@ -504,7 +507,7 @@ int ofnode_read_size(ofnode node, const char *propname); * @node: node to read from * @index: Index of address to read (0 for first) * @size: Pointer to size of the address - * @return address, or FDT_ADDR_T_NONE if not present or invalid + * Return: address, or FDT_ADDR_T_NONE if not present or invalid */ phys_addr_t ofnode_get_addr_size_index(ofnode node, int index, fdt_size_t *size); @@ -521,7 +524,7 @@ phys_addr_t ofnode_get_addr_size_index(ofnode node, int index, * @node: node to read from * @index: Index of address to read (0 for first) * @size: Pointer to size of the address - * @return address, or FDT_ADDR_T_NONE if not present or invalid + * Return: address, or FDT_ADDR_T_NONE if not present or invalid */ phys_addr_t ofnode_get_addr_size_index_notrans(ofnode node, int index, fdt_size_t *size); @@ -533,7 +536,7 @@ phys_addr_t ofnode_get_addr_size_index_notrans(ofnode node, int index, * * @node: node to read from * @index: Index of address to read (0 for first) - * @return address, or FDT_ADDR_T_NONE if not present or invalid + * Return: address, or FDT_ADDR_T_NONE if not present or invalid */ phys_addr_t ofnode_get_addr_index(ofnode node, int index);
@@ -543,7 +546,7 @@ phys_addr_t ofnode_get_addr_index(ofnode node, int index); * This reads the register address from a node * * @node: node to read from - * @return address, or FDT_ADDR_T_NONE if not present or invalid + * Return: address, or FDT_ADDR_T_NONE if not present or invalid */ phys_addr_t ofnode_get_addr(ofnode node);
@@ -553,7 +556,7 @@ phys_addr_t ofnode_get_addr(ofnode node); * This reads the register size from a node * * @node: node to read from - * @return size of the address, or FDT_SIZE_T_NONE if not present or invalid + * Return: size of the address, or FDT_SIZE_T_NONE if not present or invalid */ fdt_size_t ofnode_get_size(ofnode node);
@@ -570,7 +573,7 @@ fdt_size_t ofnode_get_size(ofnode node); * @propname: name of the property containing the string list * @string: string to look up in the string list * - * @return: + * Return: * the index of the string in the list of strings * -ENODATA if the property is not found * -EINVAL on some other error @@ -591,9 +594,9 @@ int ofnode_stringlist_search(ofnode node, const char *propname, * @node: node to check * @propname: name of the property containing the string list * @index: index of the string to return (cannot be negative) - * @lenp: return location for the string length or an error code on failure + * @outp: return location for the string * - * @return: + * Return: * 0 if found or -ve error value if not found */ int ofnode_read_string_index(ofnode node, const char *propname, int index, @@ -603,8 +606,8 @@ int ofnode_read_string_index(ofnode node, const char *propname, int index, * ofnode_read_string_count() - find the number of strings in a string list * * @node: node to check - * @propname: name of the property containing the string list - * @return: + * @property: name of the property containing the string list + * Return: * number of strings in the list, or -ve error value if not found */ int ofnode_read_string_count(ofnode node, const char *property); @@ -620,11 +623,12 @@ int ofnode_read_string_count(ofnode node, const char *property); * changed as they point directly into the devicetree property. * * @node: node to check + * @property: name of the property containing the string list * @listp: returns an allocated, NULL-terminated list of strings if the return * value is > 0, else is set to NULL - * @return number of strings in list, 0 if none, -ENOMEM if out of memory, - * -EINVAL if no such property, -EENODATA if property is empty - * @return: NULL-terminated list of strings (NULL if no property or empty) + * Return: + * number of strings in list, 0 if none, -ENOMEM if out of memory, + * -EINVAL if no such property, -EENODATA if property is empty */ int ofnode_read_string_list(ofnode node, const char *property, const char ***listp); @@ -639,19 +643,17 @@ int ofnode_read_string_list(ofnode node, const char *property, * Caller is responsible to call of_node_put() on the returned out_args->np * pointer. * - * Example: + * Example: :: * - * phandle1: node1 { - * #list-cells = <2>; - * } - * - * phandle2: node2 { - * #list-cells = <1>; - * } - * - * node3 { - * list = <&phandle1 1 2 &phandle2 3>; - * } + * phandle1: node1 { + * #list-cells = <2>; + * }; + * phandle2: node2 { + * #list-cells = <1>; + * }; + * node3 { + * list = <&phandle1 1 2 &phandle2 3>; + * }; * * To get a device_node of the `node2' node you may call this: * ofnode_parse_phandle_with_args(node3, "list", "#list-cells", 0, 1, &args); @@ -659,13 +661,14 @@ int ofnode_read_string_list(ofnode node, const char *property, * @node: device tree node containing a list * @list_name: property name that contains a list * @cells_name: property name that specifies phandles' arguments count - * @cells_count: Cell count to use if @cells_name is NULL + * @cell_count: Cell count to use if @cells_name is NULL * @index: index of a phandle to parse out * @out_args: optional pointer to output arguments structure (will be filled) - * @return 0 on success (with @out_args filled out if not NULL), -ENOENT if - * @list_name does not exist, -EINVAL if a phandle was not found, - * @cells_name could not be found, the arguments were truncated or there - * were too many arguments. + * Return: + * 0 on success (with @out_args filled out if not NULL), -ENOENT if + * @list_name does not exist, -EINVAL if a phandle was not found, + * @cells_name could not be found, the arguments were truncated or there + * were too many arguments. */ int ofnode_parse_phandle_with_args(ofnode node, const char *list_name, const char *cells_name, int cell_count, @@ -682,10 +685,10 @@ int ofnode_parse_phandle_with_args(ofnode node, const char *list_name, * @node: device tree node containing a list * @list_name: property name that contains a list * @cells_name: property name that specifies phandles' arguments count - * @cells_count: Cell count to use if @cells_name is NULL - * @return number of phandle on success, -ENOENT if @list_name does not - * exist, -EINVAL if a phandle was not found, @cells_name could not - * be found. + * @cell_count: Cell count to use if @cells_name is NULL + * Return: + * number of phandle on success, -ENOENT if @list_name does not exist, + * -EINVAL if a phandle was not found, @cells_name could not be found. */ int ofnode_count_phandle_with_args(ofnode node, const char *list_name, const char *cells_name, int cell_count); @@ -694,7 +697,7 @@ int ofnode_count_phandle_with_args(ofnode node, const char *list_name, * ofnode_path() - find a node by full path * * @path: Full path to node, e.g. "/bus/spi@1" - * @return reference to the node found. Use ofnode_valid() to check if it exists + * Return: reference to the node found. Use ofnode_valid() to check if it exists */ ofnode ofnode_path(const char *path);
@@ -704,9 +707,9 @@ ofnode ofnode_path(const char *path); * This looks for a property within the /chosen node and returns its value * * @propname: Property name to look for - * @sizep: Returns size of property, or FDT_ERR_... error code if function + * @sizep: Returns size of property, or `FDT_ERR_...` error code if function * returns NULL - * @return property value if found, else NULL + * Return: property value if found, else NULL */ const void *ofnode_read_chosen_prop(const char *propname, int *sizep);
@@ -717,7 +720,7 @@ const void *ofnode_read_chosen_prop(const char *propname, int *sizep); * checking that it is a valid nul-terminated string * * @propname: Property name to look for - * @return string value if found, else NULL + * Return: string value if found, else NULL */ const char *ofnode_read_chosen_string(const char *propname);
@@ -727,7 +730,8 @@ const char *ofnode_read_chosen_string(const char *propname); * This looks up a named property in the chosen node and uses that as a path to * look up a code. * - * @return the referenced node if present, else ofnode_null() + * @propname: Property name to look for + * Return: the referenced node if present, else ofnode_null() */ ofnode ofnode_get_chosen_node(const char *propname);
@@ -737,9 +741,9 @@ ofnode ofnode_get_chosen_node(const char *propname); * This looks for a property within the /aliases node and returns its value * * @propname: Property name to look for - * @sizep: Returns size of property, or FDT_ERR_... error code if function + * @sizep: Returns size of property, or `FDT_ERR_...` error code if function * returns NULL - * @return property value if found, else NULL + * Return: property value if found, else NULL */ const void *ofnode_read_aliases_prop(const char *propname, int *sizep);
@@ -749,7 +753,8 @@ const void *ofnode_read_aliases_prop(const char *propname, int *sizep); * This looks up a named property in the aliases node and uses that as a path to * look up a code. * - * @return the referenced node if present, else ofnode_null() + * @propname: Property name to look for + * Return: the referenced node if present, else ofnode_null() */ ofnode ofnode_get_aliases_node(const char *propname);
@@ -761,10 +766,10 @@ struct display_timing; * See doc/device-tree-bindings/video/display-timing.txt for binding * information. * - * @node 'display-timing' node containing the timing subnodes - * @index Index number to read (0=first timing subnode) - * @config Place to put timings - * @return 0 if OK, -FDT_ERR_NOTFOUND if not found + * @node: 'display-timing' node containing the timing subnodes + * @index: Index number to read (0=first timing subnode) + * @config: Place to put timings + * Return: 0 if OK, -FDT_ERR_NOTFOUND if not found */ int ofnode_decode_display_timing(ofnode node, int index, struct display_timing *config); @@ -775,7 +780,7 @@ int ofnode_decode_display_timing(ofnode node, int index, * @node: node to read * @propname: property to read * @lenp: place to put length on success - * @return pointer to property, or NULL if not found + * Return: pointer to property, or NULL if not found */ const void *ofnode_get_property(ofnode node, const char *propname, int *lenp);
@@ -787,7 +792,7 @@ const void *ofnode_get_property(ofnode node, const char *propname, int *lenp); * * @node: node to read * @prop: place to put argument reference - * @return 0 if OK, -ve on error. -FDT_ERR_NOTFOUND if not found + * Return: 0 if OK, -ve on error. -FDT_ERR_NOTFOUND if not found */ int ofnode_get_first_property(ofnode node, struct ofprop *prop);
@@ -798,7 +803,7 @@ int ofnode_get_first_property(ofnode node, struct ofprop *prop); * and read all the property with ofnode_get_property_by_prop(). * * @prop: reference of current argument and place to put reference of next one - * @return 0 if OK, -ve on error. -FDT_ERR_NOTFOUND if not found + * Return: 0 if OK, -ve on error. -FDT_ERR_NOTFOUND if not found */ int ofnode_get_next_property(struct ofprop *prop);
@@ -810,7 +815,7 @@ int ofnode_get_next_property(struct ofprop *prop); * @prop: reference on property * @propname: If non-NULL, place to property name on success, * @lenp: If non-NULL, place to put length on success - * @return 0 if OK, -ve on error. -FDT_ERR_NOTFOUND if not found + * Return: 0 if OK, -ve on error. -FDT_ERR_NOTFOUND if not found */ const void *ofnode_get_property_by_prop(const struct ofprop *prop, const char **propname, int *lenp); @@ -819,7 +824,7 @@ const void *ofnode_get_property_by_prop(const struct ofprop *prop, * ofnode_is_available() - check if a node is marked available * * @node: node to check - * @return true if node's 'status' property is "okay" (or is missing) + * Return: true if node's 'status' property is "okay" (or is missing) */ bool ofnode_is_available(ofnode node);
@@ -832,7 +837,7 @@ bool ofnode_is_available(ofnode node); * @node: node to read from * @propname: property to read * @sizep: place to put size value (on success) - * @return address value, or FDT_ADDR_T_NONE on error + * Return: address value, or FDT_ADDR_T_NONE on error */ phys_addr_t ofnode_get_addr_size(ofnode node, const char *propname, phys_size_t *sizep); @@ -845,11 +850,12 @@ phys_addr_t ofnode_get_addr_size(ofnode node, const char *propname, * for the array (count bytes). It may have more, but this will be ignored. * The data is not copied. * - * @node node to examine - * @propname name of property to find - * @sz number of array elements - * @return pointer to byte array if found, or NULL if the property is not - * found or there is not enough data + * @node: node to examine + * @propname: name of property to find + * @sz: number of array elements + * Return: + * pointer to byte array if found, or NULL if the property is not found or + * there is not enough data */ const uint8_t *ofnode_read_u8_array_ptr(ofnode node, const char *propname, size_t sz); @@ -861,13 +867,14 @@ const uint8_t *ofnode_read_u8_array_ptr(ofnode node, const char *propname, * corresponds to the given type in the form of fdt_pci_addr. * The property must hold one fdt_pci_addr with a lengh. * - * @node node to examine - * @type pci address type (FDT_PCI_SPACE_xxx) - * @propname name of property to find - * @addr returns pci address in the form of fdt_pci_addr - * @return 0 if ok, -ENOENT if the property did not exist, -EINVAL if the - * format of the property was invalid, -ENXIO if the requested - * address type was not found + * @node: node to examine + * @type: pci address type (FDT_PCI_SPACE_xxx) + * @propname: name of property to find + * @addr: returns pci address in the form of fdt_pci_addr + * Return: + * 0 if ok, -ENOENT if the property did not exist, -EINVAL if the + * format of the property was invalid, -ENXIO if the requested + * address type was not found */ int ofnode_read_pci_addr(ofnode node, enum fdt_pci_space type, const char *propname, struct fdt_pci_addr *addr); @@ -878,10 +885,10 @@ int ofnode_read_pci_addr(ofnode node, enum fdt_pci_space type, * Look at the compatible property of a device node that represents a PCI * device and extract pci vendor id and device id from it. * - * @param node node to examine - * @param vendor vendor id of the pci device - * @param device device id of the pci device - * @return 0 if ok, negative on error + * @node: node to examine + * @vendor: vendor id of the pci device + * @device: device id of the pci device + * Return: 0 if ok, negative on error */ int ofnode_read_pci_vendev(ofnode node, u16 *vendor, u16 *device);
@@ -892,7 +899,7 @@ int ofnode_read_pci_vendev(ofnode node, u16 *vendor, u16 *device); * which controls the given node. * * @node: Node to check - * @return number of address cells this node uses + * Return: number of address cells this node uses */ int ofnode_read_addr_cells(ofnode node);
@@ -903,7 +910,7 @@ int ofnode_read_addr_cells(ofnode node); * which controls the given node. * * @node: Node to check - * @return number of size cells this node uses + * Return: number of size cells this node uses */ int ofnode_read_size_cells(ofnode node);
@@ -912,8 +919,8 @@ int ofnode_read_size_cells(ofnode node); * * This function matches fdt_address_cells(). * - * @np: Node pointer to check - * @return value of #address-cells property in this node, or 2 if none + * @node: Node to check + * Return: value of #address-cells property in this node, or 2 if none */ int ofnode_read_simple_addr_cells(ofnode node);
@@ -922,8 +929,8 @@ int ofnode_read_simple_addr_cells(ofnode node); * * This function matches fdt_size_cells(). * - * @np: Node pointer to check - * @return value of #size-cells property in this node, or 2 if none + * @node: Node to check + * Return: value of #size-cells property in this node, or 2 if none */ int ofnode_read_simple_size_cells(ofnode node);
@@ -942,14 +949,13 @@ int ofnode_read_simple_size_cells(ofnode node); * There are 4 settings currently in use * - u-boot,dm-pre-proper: U-Boot proper pre-relocation only * - u-boot,dm-pre-reloc: legacy and indicates any of TPL or SPL - * Existing platforms only use it to indicate nodes needed in - * SPL. Should probably be replaced by u-boot,dm-spl for - * new platforms. + * Existing platforms only use it to indicate nodes needed in + * SPL. Should probably be replaced by u-boot,dm-spl for new platforms. * - u-boot,dm-spl: SPL and U-Boot pre-relocation * - u-boot,dm-tpl: TPL and U-Boot pre-relocation * * @node: node to check - * @return true if node is needed in SPL/TL, false otherwise + * Return: true if node is needed in SPL/TL, false otherwise */ bool ofnode_pre_reloc(ofnode node);
@@ -961,7 +967,7 @@ bool ofnode_pre_reloc(ofnode node); * @node: Node to read from * @index: Index of resource to read (0 = first) * @res: Returns resource that was read, on success - * @return 0 if OK, -ve on error + * Return: 0 if OK, -ve on error */ int ofnode_read_resource(ofnode node, uint index, struct resource *res);
@@ -975,7 +981,7 @@ int ofnode_read_resource(ofnode node, uint index, struct resource *res); * @node: Node to read from * @name: Name of resource to read * @res: Returns resource that was read, on success - * @return 0 if OK, -ve on error + * Return: 0 if OK, -ve on error */ int ofnode_read_resource_byname(ofnode node, const char *name, struct resource *res); @@ -987,7 +993,7 @@ int ofnode_read_resource_byname(ofnode node, const char *name, * * @from: ofnode to start from (use ofnode_null() to start at the beginning) * @compat: Compatible string to match - * @return ofnode found, or ofnode_null() if none + * Return: ofnode found, or ofnode_null() if none */ ofnode ofnode_by_compatible(ofnode from, const char *compat);
@@ -998,9 +1004,11 @@ ofnode ofnode_by_compatible(ofnode from, const char *compat); * @propval and a length @proplen. * * @from: ofnode to start from (use ofnode_null() to start at the - * beginning) @propname: property name to check @propval: property value to - * search for @proplen: length of the value in propval @return ofnode - * found, or ofnode_null() if none + * beginning) + * @propname: property name to check + * @propval: property value to search for + * @proplen: length of the value in propval + * Return: ofnode found, or ofnode_null() if none */ ofnode ofnode_by_prop_value(ofnode from, const char *propname, const void *propval, int proplen); @@ -1011,14 +1019,13 @@ ofnode ofnode_by_prop_value(ofnode from, const char *propname, * @node: child node (ofnode, lvalue) * @parent: parent node (ofnode) * - * This is a wrapper around a for loop and is used like so: + * This is a wrapper around a for loop and is used like so: :: * - * ofnode node; - * - * ofnode_for_each_subnode(node, parent) { - * Use node - * ... - * } + * ofnode node; + * ofnode_for_each_subnode(node, parent) { + * Use node + * ... + * } * * Note that this is implemented as a macro and @node is used as * iterator in the loop. The parent variable can be a constant or even a @@ -1036,14 +1043,13 @@ ofnode ofnode_by_prop_value(ofnode from, const char *propname, * @node: child node (ofnode, lvalue) * @compat: compatible string to match * - * This is a wrapper around a for loop and is used like so: - * - * ofnode node; + * This is a wrapper around a for loop and is used like so: :: * - * ofnode_for_each_compatible_node(node, parent, compatible) { - * Use node - * ... - * } + * ofnode node; + * ofnode_for_each_compatible_node(node, parent, compatible) { + * Use node + * ... + * } * * Note that this is implemented as a macro and @node is used as * iterator in the loop. @@ -1056,8 +1062,8 @@ ofnode ofnode_by_prop_value(ofnode from, const char *propname, /** * ofnode_get_child_count() - get the child count of a ofnode * - * @node: valid node to get its child count - * @return the number of subnodes + * @parent: valid node to get its child count + * Return: the number of subnodes */ int ofnode_get_child_count(ofnode parent);
@@ -1068,10 +1074,9 @@ int ofnode_get_child_count(ofnode parent); * function walks up the tree and applies the various bus mappings along the * way. * - * @ofnode: Device tree node giving the context in which to translate the - * address + * @node: Device tree node giving the context in which to translate the address * @in_addr: pointer to the address to translate - * @return the translated address; OF_BAD_ADDR on error + * Return: the translated address; OF_BAD_ADDR on error */ u64 ofnode_translate_address(ofnode node, const fdt32_t *in_addr);
@@ -1082,10 +1087,10 @@ u64 ofnode_translate_address(ofnode node, const fdt32_t *in_addr); * This function walks up the tree and applies the various bus mappings along * the way. * - * @ofnode: Device tree node giving the context in which to translate the - * DMA address + * @node: Device tree node giving the context in which to translate the + * DMA address * @in_addr: pointer to the DMA address to translate - * @return the translated DMA address; OF_BAD_ADDR on error + * Return: the translated DMA address; OF_BAD_ADDR on error */ u64 ofnode_translate_dma_address(ofnode node, const fdt32_t *in_addr);
@@ -1095,12 +1100,11 @@ u64 ofnode_translate_dma_address(ofnode node, const fdt32_t *in_addr); * Get DMA ranges for a specifc node, this is useful to perform bus->cpu and * cpu->bus address translations * - * @param blob Pointer to device tree blob - * @param node_offset Node DT offset - * @param cpu Pointer to variable storing the range's cpu address - * @param bus Pointer to variable storing the range's bus address - * @param size Pointer to variable storing the range's size - * @return translated DMA address or OF_BAD_ADDR on error + * @node: Device tree node + * @cpu: Pointer to variable storing the range's cpu address + * @bus: Pointer to variable storing the range's bus address + * @size: Pointer to variable storing the range's size + * Return: translated DMA address or OF_BAD_ADDR on error */ int ofnode_get_dma_range(ofnode node, phys_addr_t *cpu, dma_addr_t *bus, u64 *size); @@ -1112,7 +1116,7 @@ int ofnode_get_dma_range(ofnode node, phys_addr_t *cpu, dma_addr_t *bus, * * @node: Device tree node for which compatible needs to be verified. * @compat: Compatible string which needs to verified in the given node. - * @return true if OK, false if the compatible is not found + * Return: true if OK, false if the compatible is not found */ int ofnode_device_is_compatible(ofnode node, const char *compat);
@@ -1127,7 +1131,7 @@ int ofnode_device_is_compatible(ofnode node, const char *compat); * @len: The length of the new value of the property * @value: The new value of the property (must be valid prior to calling * the function) - * @return 0 if successful, -ve on error + * Return: 0 if successful, -ve on error */ int ofnode_write_prop(ofnode node, const char *propname, int len, const void *value); @@ -1142,7 +1146,7 @@ int ofnode_write_prop(ofnode node, const char *propname, int len, * @propname: The name of the string property to set * @value: The new value of the string property (must be valid prior to * calling the function) - * @return 0 if successful, -ve on error + * Return: 0 if successful, -ve on error */ int ofnode_write_string(ofnode node, const char *propname, const char *value);
@@ -1157,7 +1161,7 @@ int ofnode_write_string(ofnode node, const char *propname, const char *value); * @node: The node to enable * @value: Flag that tells the function to either disable or enable the * node - * @return 0 if successful, -ve on error + * Return: 0 if successful, -ve on error */ int ofnode_set_enabled(ofnode node, bool value);
@@ -1168,8 +1172,8 @@ int ofnode_set_enabled(ofnode node, bool value); * * See doc/config.txt for bindings * - * @prop_name property name to look up - * @return true, if it exists, false if not + * @prop_name: property name to look up + * Return: true, if it exists, false if not */ bool ofnode_conf_read_bool(const char *prop_name);
@@ -1182,7 +1186,7 @@ bool ofnode_conf_read_bool(const char *prop_name); * * @prop_name: property name to look up * @default_val: default value to return if the property is not found - * @return integer value, if found, or @default_val if not + * Return: integer value, if found, or @default_val if not */ int ofnode_conf_read_int(const char *prop_name, int default_val);
@@ -1194,7 +1198,7 @@ int ofnode_conf_read_int(const char *prop_name, int default_val); * See doc/config.txt for bindings * * @prop_name: property name to look up - * @return string value, if found, or NULL if not + * Return: string value, if found, or NULL if not */ const char *ofnode_conf_read_str(const char *prop_name);
Correct Sphinx style comments in include/dm/fdtaddr.h and add the devfdt API to the HTML documentation; these functions are NOT compatible with live tree.
Signed-off-by: Patrick Delaunay patrick.delaunay@foss.st.com ---
doc/api/dm.rst | 1 + include/dm/fdtaddr.h | 25 ++++++++++++------------- 2 files changed, 13 insertions(+), 13 deletions(-)
diff --git a/doc/api/dm.rst b/doc/api/dm.rst index 5bb66f2f50..df605dae9d 100644 --- a/doc/api/dm.rst +++ b/doc/api/dm.rst @@ -26,3 +26,4 @@ Device tree .. kernel-doc:: include/dm/of_extra.h .. kernel-doc:: include/dm/of_access.h .. kernel-doc:: include/dm/of_addr.h +.. kernel-doc:: include/dm/fdtaddr.h diff --git a/include/dm/fdtaddr.h b/include/dm/fdtaddr.h index d2c1994291..c9d2b27ba6 100644 --- a/include/dm/fdtaddr.h +++ b/include/dm/fdtaddr.h @@ -19,7 +19,7 @@ struct udevice; * * @dev: Pointer to a device * - * @return addr + * Return: addr */ fdt_addr_t devfdt_get_addr(const struct udevice *dev);
@@ -29,7 +29,7 @@ fdt_addr_t devfdt_get_addr(const struct udevice *dev); * * @dev: Pointer to a device * - * @return Pointer to addr, or NULL if there is no such property + * Return: Pointer to addr, or NULL if there is no such property */ void *devfdt_get_addr_ptr(const struct udevice *dev);
@@ -39,7 +39,7 @@ void *devfdt_get_addr_ptr(const struct udevice *dev); * * @dev: Pointer to a device * - * @return Pointer to addr, or NULL if there is no such property + * Return: Pointer to addr, or NULL if there is no such property */ void *devfdt_remap_addr(const struct udevice *dev);
@@ -51,7 +51,7 @@ void *devfdt_remap_addr(const struct udevice *dev); * * @dev: Pointer to a device * - * @return Pointer to addr, or NULL if there is no such property + * Return: Pointer to addr, or NULL if there is no such property */ void *devfdt_remap_addr_index(const struct udevice *dev, int index);
@@ -64,7 +64,7 @@ void *devfdt_remap_addr_index(const struct udevice *dev, int index); * * @dev: Pointer to a device * - * @return Pointer to addr, or NULL if there is no such property + * Return: Pointer to addr, or NULL if there is no such property */ void *devfdt_remap_addr_name(const struct udevice *dev, const char *name);
@@ -76,8 +76,7 @@ void *devfdt_remap_addr_name(const struct udevice *dev, const char *name); * @dev: Pointer to device * @size: size of the memory to map * - * @return mapped address, or NULL if the device does not have reg - * property. + * Return: mapped address, or NULL if the device does not have reg property. */ void *devfdt_map_physmem(const struct udevice *dev, unsigned long size);
@@ -88,7 +87,7 @@ void *devfdt_map_physmem(const struct udevice *dev, unsigned long size); * @index: the 'reg' property can hold a list of <addr, size> pairs * and @index is used to select which one is required * - * @return addr + * Return: addr */ fdt_addr_t devfdt_get_addr_index(const struct udevice *dev, int index);
@@ -100,7 +99,7 @@ fdt_addr_t devfdt_get_addr_index(const struct udevice *dev, int index); * @index: the 'reg' property can hold a list of <addr, size> pairs * and @index is used to select which one is required * - * @return Pointer to addr, or NULL if there is no such property + * Return: Pointer to addr, or NULL if there is no such property */ void *devfdt_get_addr_index_ptr(const struct udevice *dev, int index);
@@ -115,7 +114,7 @@ void *devfdt_get_addr_index_ptr(const struct udevice *dev, int index); * @size: Pointer to size varible - this function returns the size * specified in the 'reg' property here * - * @return addr + * Return: addr */ fdt_addr_t devfdt_get_addr_size_index(const struct udevice *dev, int index, fdt_size_t *size); @@ -128,7 +127,7 @@ fdt_addr_t devfdt_get_addr_size_index(const struct udevice *dev, int index, * 'reg-names' property providing named-based identification. @index * indicates the value to search for in 'reg-names'. * - * @return addr + * Return: addr */ fdt_addr_t devfdt_get_addr_name(const struct udevice *dev, const char *name);
@@ -145,7 +144,7 @@ fdt_addr_t devfdt_get_addr_name(const struct udevice *dev, const char *name); * @size: Pointer to size variable - this function returns the size * specified in the 'reg' property here * - * @return addr + * Return: addr */ fdt_addr_t devfdt_get_addr_size_name(const struct udevice *dev, const char *name, fdt_size_t *size); @@ -154,7 +153,7 @@ fdt_addr_t devfdt_get_addr_size_name(const struct udevice *dev, * devfdt_get_addr_pci() - Read an address and handle PCI address translation * * @dev: Device to read from - * @return address or FDT_ADDR_T_NONE if not found + * Return: address or FDT_ADDR_T_NONE if not found */ fdt_addr_t devfdt_get_addr_pci(const struct udevice *dev);
Signed-off-by: Patrick Delaunaypatrick.delaunay@foss.st.com
Reviewed-by: Heinrich Schuchardt xypron.glpk@gmx.de
Patrick Delaunay
