[U-Boot] [PATCH v2 0/3] add support for VSC8584 and VSC8574 Microsemi PHYs
The VSC8584 and VSC8574 PHYs are 4-port PHYs that are 10/100/1000BASE-T, 100BASE-FX, 1000BASE-X and triple-speed copper SFP capable, can communicate with the MAC via SGMII, QSGMII or 1000BASE-X, supports WOL, downshifting and can set the blinking pattern of each of its 4 LEDs, supports SyncE as well as HP Auto-MDIX detection.
This adds support for 10/100/1000BASE-T and SGMII/QSGMII link with the MAC.
They have also an internal Intel 8051 microcontroller whose firmware needs to be patched when the PHY is reset. If the 8051's firmware has the expected CRC, its patching can be skipped. The microcontroller can be accessed from any port of the PHY, though the CRC function can only be done through the PHY that is the base PHY of the package (internal address 0) due to a limitation of the firmware.
The GPIO register bank is a set of registers that are common to all PHYs in the package. So any modification in any register of this bank affects all PHYs of the package.
Thanks, Quentin
v2: - used BIT and GENMASK instead of hex values, - defined a few magic values, - fixed comments formatting, - added comments on register writes for analog and electrical tweaks, - fixed a redondant use of (0x8000 | 0x8000 | addr) in vsc8584_csr_write for vsc8574,
Quentin Schulz (3): net: phy: mscc: add support for VSC8584 PHY net: phy: mscc: factorize part of config function for VSC8584 net: phy: mscc: add support for VSC8574 PHY
drivers/net/phy/mscc.c | 994 +++++++++++++++++++++++++++++++++++++++++ 1 file changed, 994 insertions(+)
The VSC8584 PHY is a 4-port PHY that is 10/100/1000BASE-T, 100BASE-FX, 1000BASE-X and triple-speed copper SFP capable, can communicate with the MAC via SGMII, QSGMII or 1000BASE-X, supports downshifting and can set the blinking pattern of each of its 4 LEDs, supports hardware offloading of MACsec and supports SyncE as well as HP Auto-MDIX detection.
The VSC8584 has also an internal Intel 8051 microcontroller whose firmware needs to be patched when the PHY is reset. If the 8051's firmware has the expected CRC, its patching can be skipped. The microcontroller can be accessed from any port of the PHY, though the CRC function can only be done through the PHY that is the base PHY of the package (internal address 0) due to a limitation of the firmware.
The revA of the VSC8584 PHY (which is not and will not be publicly released) should NOT patch the firmware of the microcontroller or it'll make things worse, the easiest way is just to not support it.
Signed-off-by: Quentin Schulz quentin.schulz@bootlin.com --- drivers/net/phy/mscc.c | 552 +++++++++++++++++++++++++++++++++++++++++ 1 file changed, 552 insertions(+)
diff --git a/drivers/net/phy/mscc.c b/drivers/net/phy/mscc.c index 6f102f134e..b1d32da95c 100644 --- a/drivers/net/phy/mscc.c +++ b/drivers/net/phy/mscc.c @@ -11,12 +11,15 @@
#include <miiphy.h> #include <bitfield.h> +#include <time.h> +#include <linux/delay.h>
/* Microsemi PHY ID's */ #define PHY_ID_VSC8530 0x00070560 #define PHY_ID_VSC8531 0x00070570 #define PHY_ID_VSC8540 0x00070760 #define PHY_ID_VSC8541 0x00070770 +#define PHY_ID_VSC8584 0x000707c0
/* Microsemi VSC85xx PHY Register Pages */ #define MSCC_EXT_PAGE_ACCESS 31 /* Page Access Register */ @@ -29,6 +32,14 @@ #define MSCC_PHY_PAGE_TEST 0x2A30 /* TEST Page registers */ #define MSCC_PHY_PAGE_TR 0x52B5 /* Token Ring Page registers */
+/* Std Page Register 18 */ +#define MSCC_PHY_BYPASS_CONTROL 18 +#define PARALLEL_DET_IGNORE_ADVERTISED BIT(3) + +/* Std Page Register 22 */ +#define MSCC_PHY_EXT_CNTL_STATUS 22 +#define SMI_BROADCAST_WR_EN BIT(0) + /* Std Page Register 28 - PHY AUX Control/Status */ #define MIIM_AUX_CNTRL_STAT_REG 28 #define MIIM_AUX_CNTRL_STAT_ACTIPHY_TO (0x0004) @@ -47,6 +58,37 @@ #define MAC_IF_SELECTION_RGMII (2) #define MAC_IF_SELECTION_POS (11) #define MAC_IF_SELECTION_WIDTH (2) +#define VSC8584_MAC_IF_SELECTION_MASK BIT(12) +#define VSC8584_MAC_IF_SELECTION_SGMII 0 +#define VSC8584_MAC_IF_SELECTION_1000BASEX 1 +#define VSC8584_MAC_IF_SELECTION_POS 12 +#define MEDIA_OP_MODE_MASK GENMASK(10, 8) +#define MEDIA_OP_MODE_COPPER 0 +#define MEDIA_OP_MODE_SERDES 1 +#define MEDIA_OP_MODE_1000BASEX 2 +#define MEDIA_OP_MODE_100BASEFX 3 +#define MEDIA_OP_MODE_AMS_COPPER_SERDES 5 +#define MEDIA_OP_MODE_AMS_COPPER_1000BASEX 6 +#define MEDIA_OP_MODE_AMS_COPPER_100BASEFX 7 +#define MEDIA_OP_MODE_POS 8 + +/* Extended Page 1 Register 20E1 */ +#define MSCC_PHY_ACTIPHY_CNTL 20 +#define PHY_ADDR_REVERSED BIT(9) + +/* Extended Page 1 Register 23E1 */ + +#define MSCC_PHY_EXT_PHY_CNTL_4 23 +#define PHY_CNTL_4_ADDR_POS 11 + +/* Extended Page 1 Register 25E1 */ +#define MSCC_PHY_VERIPHY_CNTL_2 25 + +/* Extended Page 1 Register 26E1 */ +#define MSCC_PHY_VERIPHY_CNTL_3 26 + +/* Extended Page 2 Register 16E2 */ +#define MSCC_PHY_CU_PMD_TX_CNTL 16
/* Extended Page 2 Register 20E2 */ #define MSCC_PHY_RGMII_CNTL_REG 20 @@ -72,6 +114,76 @@ #define RMII_CLK_OUT_ENABLE_WIDTH (1) #define RMII_CLK_OUT_ENABLE_MASK (0x10)
+/* Extended Page 3 Register 22E3 */ +#define MSCC_PHY_SERDES_TX_CRC_ERR_CNT 22 + +/* Extended page GPIO register 00G */ +#define MSCC_DW8051_CNTL_STATUS 0 +#define MICRO_NSOFT_RESET BIT(15) +#define RUN_FROM_INT_ROM BIT(14) +#define AUTOINC_ADDR BIT(13) +#define PATCH_RAM_CLK BIT(12) +#define MICRO_PATCH_EN BIT(7) +#define DW8051_CLK_EN BIT(4) +#define MICRO_CLK_EN BIT(3) +#define MICRO_CLK_DIVIDE(x) ((x) >> 1) + +/* Extended page GPIO register 09G */ +#define MSCC_TRAP_ROM_ADDR(x) ((x) * 2 + 1) + +/* Extended page GPIO register 10G */ +#define MSCC_PATCH_RAM_ADDR(x) (((x) + 1) * 2) + +/* Extended page GPIO register 11G */ +#define MSCC_INT_MEM_ADDR 11 + +/* Extended page GPIO register 12G */ +#define MSCC_INT_MEM_CNTL 12 +#define READ_SFR (BIT(14) | BIT(13)) +#define READ_PRAM BIT(14) +#define READ_ROM BIT(13) +#define READ_RAM (0x00 << 13) +#define INT_MEM_WRITE_EN BIT(12) +#define EN_PATCH_RAM_TRAP_ADDR(x) BIT((x) + 7) +#define INT_MEM_DATA_M GENMASK(7, 0) +#define INT_MEM_DATA(x) (INT_MEM_DATA_M & (x)) + +/* Extended page GPIO register 18G */ +#define MSCC_PHY_PROC_CMD 18 +#define PROC_CMD_NCOMPLETED BIT(15) +#define PROC_CMD_FAILED BIT(14) +#define PROC_CMD_SGMII_PORT(x) ((x) << 8) +#define PROC_CMD_FIBER_PORT(x) BIT(8 + (x) % 4) +#define PROC_CMD_QSGMII_PORT (BIT(11) | BIT(10)) +#define PROC_CMD_RST_CONF_PORT BIT(7) +#define PROC_CMD_RECONF_PORT (0 << 7) +#define PROC_CMD_READ_MOD_WRITE_PORT BIT(6) +#define PROC_CMD_WRITE BIT(6) +#define PROC_CMD_READ (0 << 6) +#define PROC_CMD_FIBER_DISABLE BIT(5) +#define PROC_CMD_FIBER_100BASE_FX BIT(4) +#define PROC_CMD_FIBER_1000BASE_X (0 << 4) +#define PROC_CMD_SGMII_MAC (BIT(5) | BIT(4)) +#define PROC_CMD_QSGMII_MAC BIT(5) +#define PROC_CMD_NO_MAC_CONF (0x00 << 4) +#define PROC_CMD_NOP GENMASK(3, 0) +#define PROC_CMD_CRC16 BIT(3) +#define PROC_CMD_FIBER_MEDIA_CONF BIT(0) +#define PROC_CMD_MCB_ACCESS_MAC_CONF (0x0000 << 0) +#define PROC_CMD_NCOMPLETED_TIMEOUT_MS 500 + +/* Extended page GPIO register 19G */ +#define MSCC_PHY_MAC_CFG_FASTLINK 19 +#define MAC_CFG_MASK GENMASK(15, 14) +#define MAC_CFG_SGMII (0x00 << 14) +#define MAC_CFG_QSGMII BIT(14) + +/* Test Registers */ +#define MSCC_PHY_TEST_PAGE_5 5 + +#define MSCC_PHY_TEST_PAGE_8 8 +#define TR_CLK_DISABLE BIT(15) + /* Token Ring Page 0x52B5 Registers */ #define MSCC_PHY_REG_TR_ADDR_16 16 #define MSCC_PHY_REG_TR_DATA_17 17 @@ -110,6 +222,12 @@ #define MSCC_PHY_RESET_TIMEOUT (100) #define MSCC_PHY_MICRO_TIMEOUT (500)
+#define VSC8584_REVB 0x0001 +#define MSCC_DEV_REV_MASK GENMASK(3, 0) + +#define MSCC_VSC8584_REVB_INT8051_FW_START_ADDR 0xe800 +#define MSCC_VSC8584_REVB_INT8051_FW_CRC 0xfb48 + /* RGMII/GMII Clock Delay (Skew) Options */ enum vsc_phy_rgmii_skew { VSC_PHY_RGMII_DELAY_200_PS, VSC_PHY_RGMII_DELAY_800_PS, @@ -133,6 +251,339 @@ vsc_phy_clk_slew { VSC_PHY_CLK_SLEW_RATE_7, };
+static void vsc8584_csr_write(struct mii_dev *bus, int phy0, u16 addr, u32 val) +{ + bus->write(bus, phy0, MDIO_DEVAD_NONE, MSCC_PHY_REG_TR_DATA_18, + val >> 16); + bus->write(bus, phy0, MDIO_DEVAD_NONE, MSCC_PHY_REG_TR_DATA_17, + val & GENMASK(15, 0)); + bus->write(bus, phy0, MDIO_DEVAD_NONE, MSCC_PHY_REG_TR_ADDR_16, + MSCC_PHY_TR_16_WRITE | addr); +} + +static int vsc8584_cmd(struct mii_dev *bus, int phy, u16 val) +{ + unsigned long deadline; + u16 reg_val; + + bus->write(bus, phy, MDIO_DEVAD_NONE, MSCC_EXT_PAGE_ACCESS, + MSCC_PHY_PAGE_GPIO); + + bus->write(bus, phy, MDIO_DEVAD_NONE, MSCC_PHY_PROC_CMD, + PROC_CMD_NCOMPLETED | val); + + deadline = timer_get_us() + PROC_CMD_NCOMPLETED_TIMEOUT_MS * 1000; + do { + reg_val = bus->read(bus, phy, MDIO_DEVAD_NONE, + MSCC_PHY_PROC_CMD); + } while (timer_get_us() <= deadline && + (reg_val & PROC_CMD_NCOMPLETED) && + !(reg_val & PROC_CMD_FAILED)); + + bus->write(bus, phy, MDIO_DEVAD_NONE, MSCC_EXT_PAGE_ACCESS, + MSCC_PHY_PAGE_STD); + + if (reg_val & PROC_CMD_FAILED) + return -EIO; + if (reg_val & PROC_CMD_NCOMPLETED) + return -ETIMEDOUT; + + return 0; +} + +static int vsc8584_micro_deassert_reset(struct mii_dev *bus, int phy, + bool patch_en) +{ + u32 enable, release; + + bus->write(bus, phy, MDIO_DEVAD_NONE, MSCC_EXT_PAGE_ACCESS, + MSCC_PHY_PAGE_GPIO); + + enable = RUN_FROM_INT_ROM | MICRO_CLK_EN | DW8051_CLK_EN; + release = MICRO_NSOFT_RESET | RUN_FROM_INT_ROM | DW8051_CLK_EN | + MICRO_CLK_EN; + + if (patch_en) { + enable |= MICRO_PATCH_EN; + release |= MICRO_PATCH_EN; + + /* Clear all patches */ + bus->write(bus, phy, MDIO_DEVAD_NONE, MSCC_INT_MEM_CNTL, + READ_RAM); + } + + /* + * Enable 8051 Micro clock; CLEAR/SET patch present; disable PRAM clock + * override and addr. auto-incr; operate at 125 MHz + */ + bus->write(bus, phy, MDIO_DEVAD_NONE, MSCC_DW8051_CNTL_STATUS, enable); + /* Release 8051 Micro SW reset */ + bus->write(bus, phy, MDIO_DEVAD_NONE, MSCC_DW8051_CNTL_STATUS, release); + + bus->write(bus, phy, MDIO_DEVAD_NONE, MSCC_EXT_PAGE_ACCESS, + MSCC_PHY_PAGE_STD); + + return 0; +} + +static int vsc8584_micro_assert_reset(struct mii_dev *bus, int phy) +{ + int ret; + u16 reg; + + ret = vsc8584_cmd(bus, phy, PROC_CMD_NOP); + if (ret) + return ret; + + bus->write(bus, phy, MDIO_DEVAD_NONE, MSCC_EXT_PAGE_ACCESS, + MSCC_PHY_PAGE_GPIO); + + reg = bus->read(bus, phy, MDIO_DEVAD_NONE, MSCC_INT_MEM_CNTL); + reg &= ~EN_PATCH_RAM_TRAP_ADDR(4); + bus->write(bus, phy, MDIO_DEVAD_NONE, MSCC_INT_MEM_CNTL, reg); + + bus->write(bus, phy, MDIO_DEVAD_NONE, MSCC_TRAP_ROM_ADDR(4), 0x005b); + bus->write(bus, phy, MDIO_DEVAD_NONE, MSCC_PATCH_RAM_ADDR(4), 0x005b); + + reg = bus->read(bus, phy, MDIO_DEVAD_NONE, MSCC_INT_MEM_CNTL); + reg |= EN_PATCH_RAM_TRAP_ADDR(4); + bus->write(bus, phy, MDIO_DEVAD_NONE, MSCC_INT_MEM_CNTL, reg); + + bus->write(bus, phy, MDIO_DEVAD_NONE, MSCC_PHY_PROC_CMD, PROC_CMD_NOP); + + reg = bus->read(bus, phy, MDIO_DEVAD_NONE, MSCC_DW8051_CNTL_STATUS); + reg &= ~MICRO_NSOFT_RESET; + bus->write(bus, phy, MDIO_DEVAD_NONE, MSCC_DW8051_CNTL_STATUS, reg); + + bus->write(bus, phy, MDIO_DEVAD_NONE, MSCC_PHY_PROC_CMD, + PROC_CMD_MCB_ACCESS_MAC_CONF | PROC_CMD_SGMII_PORT(0) | + PROC_CMD_NO_MAC_CONF | PROC_CMD_READ); + + reg = bus->read(bus, phy, MDIO_DEVAD_NONE, MSCC_INT_MEM_CNTL); + reg &= ~EN_PATCH_RAM_TRAP_ADDR(4); + bus->write(bus, phy, MDIO_DEVAD_NONE, MSCC_INT_MEM_CNTL, reg); + + bus->write(bus, phy, MDIO_DEVAD_NONE, MSCC_EXT_PAGE_ACCESS, + MSCC_PHY_PAGE_STD); + + return 0; +} + +static const u8 fw_patch_vsc8584[] = { + 0xe8, 0x59, 0x02, 0xe8, 0x12, 0x02, 0xe8, 0x42, 0x02, 0xe8, 0x5a, 0x02, + 0xe8, 0x5b, 0x02, 0xe8, 0x5c, 0xe5, 0x69, 0x54, 0x0f, 0x24, 0xf7, 0x60, + 0x27, 0x24, 0xfc, 0x60, 0x23, 0x24, 0x08, 0x70, 0x14, 0xe5, 0x69, 0xae, + 0x68, 0x78, 0x04, 0xce, 0xa2, 0xe7, 0x13, 0xce, 0x13, 0xd8, 0xf8, 0x7e, + 0x00, 0x54, 0x0f, 0x80, 0x00, 0x7b, 0x01, 0x7a, 0x00, 0x7d, 0xee, 0x7f, + 0x92, 0x12, 0x50, 0xee, 0x22, 0xe4, 0xf5, 0x10, 0x85, 0x10, 0xfb, 0x7d, + 0x1c, 0xe4, 0xff, 0x12, 0x59, 0xea, 0x05, 0x10, 0xe5, 0x10, 0xc3, 0x94, + 0x04, 0x40, 0xed, 0x22, 0x22, 0x22, 0x22, 0x22, +}; + +static int vsc8584_get_fw_crc(struct mii_dev *bus, int phy, u16 start, + u16 *crc, const u8 *fw_patch, int fw_size) +{ + int ret; + + bus->write(bus, phy, MDIO_DEVAD_NONE, MSCC_EXT_PAGE_ACCESS, + MSCC_PHY_PAGE_EXT1); + + bus->write(bus, phy, MDIO_DEVAD_NONE, MSCC_PHY_VERIPHY_CNTL_2, start); + /* Add one byte to size for the one added by the patch_fw function */ + bus->write(bus, phy, MDIO_DEVAD_NONE, MSCC_PHY_VERIPHY_CNTL_3, + fw_size + 1); + + ret = vsc8584_cmd(bus, phy, PROC_CMD_CRC16); + if (ret) + goto out; + + bus->write(bus, phy, MDIO_DEVAD_NONE, MSCC_EXT_PAGE_ACCESS, + MSCC_PHY_PAGE_EXT1); + + *crc = bus->read(bus, phy, MDIO_DEVAD_NONE, MSCC_PHY_VERIPHY_CNTL_2); + +out: + bus->write(bus, phy, MDIO_DEVAD_NONE, MSCC_EXT_PAGE_ACCESS, + MSCC_PHY_PAGE_STD); + + return ret; +} + +static int vsc8584_patch_fw(struct mii_dev *bus, int phy, const u8 *fw_patch, + int fw_size) +{ + int i, ret; + + ret = vsc8584_micro_assert_reset(bus, phy); + if (ret) { + pr_err("%s: failed to assert reset of micro\n", __func__); + return ret; + } + + bus->write(bus, phy, MDIO_DEVAD_NONE, MSCC_EXT_PAGE_ACCESS, + MSCC_PHY_PAGE_GPIO); + + /* + * Hold 8051 Micro in SW Reset, Enable auto incr address and patch clock + * Disable the 8051 Micro clock + */ + bus->write(bus, phy, MDIO_DEVAD_NONE, MSCC_DW8051_CNTL_STATUS, + RUN_FROM_INT_ROM | AUTOINC_ADDR | PATCH_RAM_CLK | + MICRO_CLK_EN | MICRO_CLK_DIVIDE(2)); + bus->write(bus, phy, MDIO_DEVAD_NONE, MSCC_INT_MEM_CNTL, READ_PRAM | + INT_MEM_WRITE_EN | INT_MEM_DATA(2)); + bus->write(bus, phy, MDIO_DEVAD_NONE, MSCC_INT_MEM_ADDR, 0x0000); + + for (i = 0; i < fw_size; i++) + bus->write(bus, phy, MDIO_DEVAD_NONE, MSCC_INT_MEM_CNTL, + READ_PRAM | INT_MEM_WRITE_EN | fw_patch[i]); + + /* Clear internal memory access */ + bus->write(bus, phy, MDIO_DEVAD_NONE, MSCC_INT_MEM_CNTL, READ_RAM); + + bus->write(bus, phy, MDIO_DEVAD_NONE, MSCC_EXT_PAGE_ACCESS, + MSCC_PHY_PAGE_STD); + + return 0; +} + +static int vsc8584_config_pre_init(struct mii_dev *bus, int phy0) +{ + u16 reg, crc; + int ret; + + bus->write(bus, phy0, MDIO_DEVAD_NONE, MSCC_EXT_PAGE_ACCESS, + MSCC_PHY_PAGE_STD); + + /* all writes below are broadcasted to all PHYs in the same package */ + reg = bus->read(bus, phy0, MDIO_DEVAD_NONE, MSCC_PHY_EXT_CNTL_STATUS); + reg |= SMI_BROADCAST_WR_EN; + bus->write(bus, phy0, MDIO_DEVAD_NONE, MSCC_PHY_EXT_CNTL_STATUS, reg); + + /* The below register writes are tweaking analog and electrical + * configuration that were determined through characterization by PHY + * engineers. These don't mean anything more than "these are the best + * values". + */ + reg = bus->read(bus, phy0, MDIO_DEVAD_NONE, MSCC_PHY_BYPASS_CONTROL); + reg |= PARALLEL_DET_IGNORE_ADVERTISED; + bus->write(bus, phy0, MDIO_DEVAD_NONE, MSCC_PHY_BYPASS_CONTROL, reg); + + bus->write(bus, phy0, MDIO_DEVAD_NONE, MSCC_EXT_PAGE_ACCESS, + MSCC_PHY_PAGE_EXT3); + + bus->write(bus, phy0, MDIO_DEVAD_NONE, MSCC_PHY_SERDES_TX_CRC_ERR_CNT, + 0x2000); + + bus->write(bus, phy0, MDIO_DEVAD_NONE, MSCC_EXT_PAGE_ACCESS, + MSCC_PHY_PAGE_TEST); + + bus->write(bus, phy0, MDIO_DEVAD_NONE, MSCC_PHY_TEST_PAGE_5, 0x1f20); + + reg = bus->read(bus, phy0, MDIO_DEVAD_NONE, MSCC_PHY_TEST_PAGE_8); + reg |= TR_CLK_DISABLE; + bus->write(bus, phy0, MDIO_DEVAD_NONE, MSCC_PHY_TEST_PAGE_8, reg); + + bus->write(bus, phy0, MDIO_DEVAD_NONE, MSCC_EXT_PAGE_ACCESS, + MSCC_PHY_PAGE_TR); + + bus->write(bus, phy0, MDIO_DEVAD_NONE, MSCC_PHY_REG_TR_ADDR_16, 0xafa4); + + reg = bus->read(bus, phy0, MDIO_DEVAD_NONE, MSCC_PHY_REG_TR_DATA_18); + reg &= ~0x007f; + reg |= 0x0019; + bus->write(bus, phy0, MDIO_DEVAD_NONE, MSCC_PHY_REG_TR_DATA_18, reg); + + bus->write(bus, phy0, MDIO_DEVAD_NONE, MSCC_PHY_REG_TR_ADDR_16, 0x8fa4); + + vsc8584_csr_write(bus, phy0, 0x07fa, 0x0050100f); + vsc8584_csr_write(bus, phy0, 0x1688, 0x00049f81); + vsc8584_csr_write(bus, phy0, 0x0f90, 0x00688980); + vsc8584_csr_write(bus, phy0, 0x03a4, 0x0000d8f0); + vsc8584_csr_write(bus, phy0, 0x0fc0, 0x00000400); + vsc8584_csr_write(bus, phy0, 0x0f82, 0x0012b002); + vsc8584_csr_write(bus, phy0, 0x1686, 0x00000004); + vsc8584_csr_write(bus, phy0, 0x168c, 0x00d2c46f); + vsc8584_csr_write(bus, phy0, 0x17a2, 0x00000620); + vsc8584_csr_write(bus, phy0, 0x16a0, 0x00eeffdd); + vsc8584_csr_write(bus, phy0, 0x16a6, 0x00071448); + vsc8584_csr_write(bus, phy0, 0x16a4, 0x0013132f); + vsc8584_csr_write(bus, phy0, 0x16a8, 0x00000000); + vsc8584_csr_write(bus, phy0, 0x0ffc, 0x00c0a028); + vsc8584_csr_write(bus, phy0, 0x0fe8, 0x0091b06c); + vsc8584_csr_write(bus, phy0, 0x0fea, 0x00041600); + vsc8584_csr_write(bus, phy0, 0x0f80, 0x00fffaff); + vsc8584_csr_write(bus, phy0, 0x0fec, 0x00901809); + vsc8584_csr_write(bus, phy0, 0x0ffe, 0x00b01007); + vsc8584_csr_write(bus, phy0, 0x16b0, 0x00eeff00); + vsc8584_csr_write(bus, phy0, 0x16b2, 0x00007000); + vsc8584_csr_write(bus, phy0, 0x16b4, 0x00000814); + + bus->write(bus, phy0, MDIO_DEVAD_NONE, MSCC_EXT_PAGE_ACCESS, + MSCC_PHY_PAGE_EXT2); + + bus->write(bus, phy0, MDIO_DEVAD_NONE, MSCC_PHY_CU_PMD_TX_CNTL, 0x028e); + + bus->write(bus, phy0, MDIO_DEVAD_NONE, MSCC_EXT_PAGE_ACCESS, + MSCC_PHY_PAGE_TR); + + vsc8584_csr_write(bus, phy0, 0x0486, 0x0008a518); + vsc8584_csr_write(bus, phy0, 0x0488, 0x006dc696); + vsc8584_csr_write(bus, phy0, 0x048a, 0x00000912); + + bus->write(bus, phy0, MDIO_DEVAD_NONE, MSCC_EXT_PAGE_ACCESS, + MSCC_PHY_PAGE_TEST); + + reg = bus->read(bus, phy0, MDIO_DEVAD_NONE, MSCC_PHY_TEST_PAGE_8); + reg &= ~TR_CLK_DISABLE; + bus->write(bus, phy0, MDIO_DEVAD_NONE, MSCC_PHY_TEST_PAGE_8, reg); + + bus->write(bus, phy0, MDIO_DEVAD_NONE, MSCC_EXT_PAGE_ACCESS, + MSCC_PHY_PAGE_STD); + + /* end of write broadcasting */ + reg = bus->read(bus, phy0, MDIO_DEVAD_NONE, MSCC_PHY_EXT_CNTL_STATUS); + reg &= ~SMI_BROADCAST_WR_EN; + bus->write(bus, phy0, MDIO_DEVAD_NONE, MSCC_PHY_EXT_CNTL_STATUS, reg); + + ret = vsc8584_get_fw_crc(bus, phy0, + MSCC_VSC8584_REVB_INT8051_FW_START_ADDR, &crc, + fw_patch_vsc8584, + ARRAY_SIZE(fw_patch_vsc8584)); + if (ret) + goto out; + + if (crc != MSCC_VSC8584_REVB_INT8051_FW_CRC) { + debug("FW CRC is not the expected one, patching FW...\n"); + if (vsc8584_patch_fw(bus, phy0, fw_patch_vsc8584, + ARRAY_SIZE(fw_patch_vsc8584))) + pr_warn("failed to patch FW, expect non-optimal device\n"); + } + + vsc8584_micro_deassert_reset(bus, phy0, false); + + ret = vsc8584_get_fw_crc(bus, phy0, + MSCC_VSC8584_REVB_INT8051_FW_START_ADDR, &crc, + fw_patch_vsc8584, + ARRAY_SIZE(fw_patch_vsc8584)); + if (ret) + goto out; + + if (crc != MSCC_VSC8584_REVB_INT8051_FW_CRC) + pr_warn("FW CRC after patching is not the expected one, expect non-optimal device\n"); + + ret = vsc8584_micro_assert_reset(bus, phy0); + if (ret) + goto out; + + vsc8584_micro_deassert_reset(bus, phy0, true); + +out: + bus->write(bus, phy0, MDIO_DEVAD_NONE, MSCC_EXT_PAGE_ACCESS, + MSCC_PHY_PAGE_STD); + + return ret; +}
static int mscc_vsc8531_vsc8541_init_scripts(struct phy_device *phydev) { @@ -457,6 +908,96 @@ static int vsc8541_config(struct phy_device *phydev) return genphy_config_aneg(phydev); }
+static int vsc8584_config(struct phy_device *phydev) +{ + int ret; + u16 addr; + u16 reg_val; + u16 val; + u16 base_addr; + + phy_write(phydev, MDIO_DEVAD_NONE, MSCC_EXT_PAGE_ACCESS, + MSCC_PHY_PAGE_EXT1); + addr = phy_read(phydev, MDIO_DEVAD_NONE, MSCC_PHY_EXT_PHY_CNTL_4); + addr >>= PHY_CNTL_4_ADDR_POS; + + val = phy_read(phydev, MDIO_DEVAD_NONE, MSCC_PHY_ACTIPHY_CNTL); + if (val & PHY_ADDR_REVERSED) + base_addr = phydev->addr + addr; + else + base_addr = phydev->addr - addr; + + if ((phydev->phy_id & MSCC_DEV_REV_MASK) != VSC8584_REVB) { + pr_warn("VSC8584 revA not officially supported, skipping firmware patching. Use at your own risk.\n"); + } else { + ret = vsc8584_config_pre_init(phydev->bus, base_addr); + if (ret) + return ret; + } + + phy_write(phydev, MDIO_DEVAD_NONE, MSCC_EXT_PAGE_ACCESS, + MSCC_PHY_PAGE_GPIO); + + if (phydev->interface == PHY_INTERFACE_MODE_QSGMII) + val = MAC_CFG_QSGMII; + else + val = MAC_CFG_SGMII; + + reg_val = phy_read(phydev, MDIO_DEVAD_NONE, MSCC_PHY_MAC_CFG_FASTLINK); + reg_val &= ~MAC_CFG_MASK; + reg_val |= val; + ret = phy_write(phydev, MDIO_DEVAD_NONE, MSCC_PHY_MAC_CFG_FASTLINK, + reg_val); + if (ret) + return ret; + + reg_val = PROC_CMD_MCB_ACCESS_MAC_CONF | PROC_CMD_RST_CONF_PORT | + PROC_CMD_READ_MOD_WRITE_PORT; + if (phydev->interface == PHY_INTERFACE_MODE_QSGMII) + reg_val |= PROC_CMD_QSGMII_MAC; + else + reg_val |= PROC_CMD_SGMII_MAC; + + ret = vsc8584_cmd(phydev->bus, phydev->addr, reg_val); + if (ret) + return ret; + + mdelay(10); + + /* Disable SerDes for 100Base-FX */ + ret = vsc8584_cmd(phydev->bus, phydev->addr, PROC_CMD_FIBER_MEDIA_CONF | + PROC_CMD_FIBER_PORT(addr) | PROC_CMD_FIBER_DISABLE | + PROC_CMD_READ_MOD_WRITE_PORT | + PROC_CMD_RST_CONF_PORT | PROC_CMD_FIBER_100BASE_FX); + if (ret) + return ret; + + /* Disable SerDes for 1000Base-X */ + ret = vsc8584_cmd(phydev->bus, phydev->addr, PROC_CMD_FIBER_MEDIA_CONF | + PROC_CMD_FIBER_PORT(addr) | PROC_CMD_FIBER_DISABLE | + PROC_CMD_READ_MOD_WRITE_PORT | + PROC_CMD_RST_CONF_PORT | PROC_CMD_FIBER_1000BASE_X); + if (ret) + return ret; + + phy_write(phydev, MDIO_DEVAD_NONE, MSCC_EXT_PAGE_ACCESS, + MSCC_PHY_PAGE_STD); + reg_val = phy_read(phydev, MDIO_DEVAD_NONE, + MSCC_PHY_EXT_PHY_CNTL_1_REG); + reg_val &= ~(MEDIA_OP_MODE_MASK | VSC8584_MAC_IF_SELECTION_MASK); + reg_val |= MEDIA_OP_MODE_COPPER | + (VSC8584_MAC_IF_SELECTION_SGMII << + VSC8584_MAC_IF_SELECTION_POS); + ret = phy_write(phydev, MDIO_DEVAD_NONE, MSCC_PHY_EXT_PHY_CNTL_1_REG, + reg_val); + + ret = mscc_phy_soft_reset(phydev); + if (ret != 0) + return ret; + + return genphy_config(phydev); +} + static struct phy_driver VSC8530_driver = { .name = "Microsemi VSC8530", .uid = PHY_ID_VSC8530, @@ -497,12 +1038,23 @@ static struct phy_driver VSC8541_driver = { .shutdown = &genphy_shutdown, };
+static struct phy_driver VSC8584_driver = { + .name = "Microsemi VSC8584", + .uid = PHY_ID_VSC8584, + .mask = 0x000ffff0, + .features = PHY_GBIT_FEATURES, + .config = &vsc8584_config, + .startup = &mscc_startup, + .shutdown = &genphy_shutdown, +}; + int phy_mscc_init(void) { phy_register(&VSC8530_driver); phy_register(&VSC8531_driver); phy_register(&VSC8540_driver); phy_register(&VSC8541_driver); + phy_register(&VSC8584_driver);
return 0; }
On Wed, Oct 31, 2018 at 5:23 AM Quentin Schulz quentin.schulz@bootlin.com wrote:
Hi Quentin,
https://patchwork.ozlabs.org/patch/991336/ was applied to http://git.denx.de/?p=u-boot/u-boot-net.git
Thanks! -Joe
Part of the config is common between the VSC8584 and the VSC8574, so to prepare for the upcoming support of VSC8574, use the phy_device.priv pointer that will keep the function that holds code that is PHY-specific and that should be called during config function.
Signed-off-by: Quentin Schulz quentin.schulz@bootlin.com Acked-by: Joe Hershberger joe.hershberger@ni.com --- drivers/net/phy/mscc.c | 56 +++++++++++++++++++++++++++++------------- 1 file changed, 39 insertions(+), 17 deletions(-)
diff --git a/drivers/net/phy/mscc.c b/drivers/net/phy/mscc.c index b1d32da95c..0861a82fc6 100644 --- a/drivers/net/phy/mscc.c +++ b/drivers/net/phy/mscc.c @@ -251,6 +251,10 @@ vsc_phy_clk_slew { VSC_PHY_CLK_SLEW_RATE_7, };
+struct vsc85xx_priv { + int (*config_pre)(struct phy_device *phydev); +}; + static void vsc8584_csr_write(struct mii_dev *bus, int phy0, u16 addr, u32 val) { bus->write(bus, phy0, MDIO_DEVAD_NONE, MSCC_PHY_REG_TR_DATA_18, @@ -447,11 +451,28 @@ static int vsc8584_patch_fw(struct mii_dev *bus, int phy, const u8 *fw_patch, return 0; }
-static int vsc8584_config_pre_init(struct mii_dev *bus, int phy0) +static int vsc8584_config_pre_init(struct phy_device *phydev) { - u16 reg, crc; + struct mii_dev *bus = phydev->bus; + u16 reg, crc, phy0, addr; int ret;
+ if ((phydev->phy_id & MSCC_DEV_REV_MASK) != VSC8584_REVB) { + pr_warn("VSC8584 revA not officially supported, skipping firmware patching. Use at your own risk.\n"); + return 0; + } + + phy_write(phydev, MDIO_DEVAD_NONE, MSCC_EXT_PAGE_ACCESS, + MSCC_PHY_PAGE_EXT1); + addr = phy_read(phydev, MDIO_DEVAD_NONE, MSCC_PHY_EXT_PHY_CNTL_4); + addr >>= PHY_CNTL_4_ADDR_POS; + + reg = phy_read(phydev, MDIO_DEVAD_NONE, MSCC_PHY_ACTIPHY_CNTL); + if (reg & PHY_ADDR_REVERSED) + phy0 = phydev->addr + addr; + else + phy0 = phydev->addr - addr; + bus->write(bus, phy0, MDIO_DEVAD_NONE, MSCC_EXT_PAGE_ACCESS, MSCC_PHY_PAGE_STD);
@@ -908,32 +929,22 @@ static int vsc8541_config(struct phy_device *phydev) return genphy_config_aneg(phydev); }
-static int vsc8584_config(struct phy_device *phydev) +static int vsc8584_config_init(struct phy_device *phydev) { + struct vsc85xx_priv *priv = phydev->priv; int ret; u16 addr; u16 reg_val; u16 val; - u16 base_addr;
phy_write(phydev, MDIO_DEVAD_NONE, MSCC_EXT_PAGE_ACCESS, MSCC_PHY_PAGE_EXT1); addr = phy_read(phydev, MDIO_DEVAD_NONE, MSCC_PHY_EXT_PHY_CNTL_4); addr >>= PHY_CNTL_4_ADDR_POS;
- val = phy_read(phydev, MDIO_DEVAD_NONE, MSCC_PHY_ACTIPHY_CNTL); - if (val & PHY_ADDR_REVERSED) - base_addr = phydev->addr + addr; - else - base_addr = phydev->addr - addr; - - if ((phydev->phy_id & MSCC_DEV_REV_MASK) != VSC8584_REVB) { - pr_warn("VSC8584 revA not officially supported, skipping firmware patching. Use at your own risk.\n"); - } else { - ret = vsc8584_config_pre_init(phydev->bus, base_addr); - if (ret) - return ret; - } + ret = priv->config_pre(phydev); + if (ret) + return ret;
phy_write(phydev, MDIO_DEVAD_NONE, MSCC_EXT_PAGE_ACCESS, MSCC_PHY_PAGE_GPIO); @@ -998,6 +1009,17 @@ static int vsc8584_config(struct phy_device *phydev) return genphy_config(phydev); }
+static struct vsc85xx_priv vsc8584_priv = { + .config_pre = vsc8584_config_pre_init, +}; + +static int vsc8584_config(struct phy_device *phydev) +{ + phydev->priv = &vsc8584_priv; + + return vsc8584_config_init(phydev); +} + static struct phy_driver VSC8530_driver = { .name = "Microsemi VSC8530", .uid = PHY_ID_VSC8530,
Hi Quentin,
https://patchwork.ozlabs.org/patch/991335/ was applied to http://git.denx.de/?p=u-boot/u-boot-net.git
Thanks! -Joe
The VSC8574 PHY is a 4-port PHY that is 10/100/1000BASE-T, 100BASE-FX, 1000BASE-X and triple-speed copper SFP capable, can communicate with the MAC via SGMII, QSGMII or 1000BASE-X, supports WOL, downshifting and can set the blinking pattern of each of its 4 LEDs, supports SyncE as well as HP Auto-MDIX detection.
The VSC8574 has also an internal Intel 8051 microcontroller whose firmware needs to be patched when the PHY is reset. If the 8051's firmware has the expected CRC, its patching can be skipped. The microcontroller can be accessed from any port of the PHY, though the CRC function can only be done through the PHY that is the base PHY of the package (internal address 0) due to a limitation of the firmware.
Signed-off-by: Quentin Schulz quentin.schulz@bootlin.com --- drivers/net/phy/mscc.c | 420 +++++++++++++++++++++++++++++++++++++++++ 1 file changed, 420 insertions(+)
diff --git a/drivers/net/phy/mscc.c b/drivers/net/phy/mscc.c index 0861a82fc6..53845710f0 100644 --- a/drivers/net/phy/mscc.c +++ b/drivers/net/phy/mscc.c @@ -19,6 +19,7 @@ #define PHY_ID_VSC8531 0x00070570 #define PHY_ID_VSC8540 0x00070760 #define PHY_ID_VSC8541 0x00070770 +#define PHY_ID_VSC8574 0x000704a0 #define PHY_ID_VSC8584 0x000707c0
/* Microsemi VSC85xx PHY Register Pages */ @@ -40,6 +41,9 @@ #define MSCC_PHY_EXT_CNTL_STATUS 22 #define SMI_BROADCAST_WR_EN BIT(0)
+/* Std Page Register 24 */ +#define MSCC_PHY_EXT_PHY_CNTL_2 24 + /* Std Page Register 28 - PHY AUX Control/Status */ #define MIIM_AUX_CNTRL_STAT_REG 28 #define MIIM_AUX_CNTRL_STAT_ACTIPHY_TO (0x0004) @@ -127,12 +131,15 @@ #define DW8051_CLK_EN BIT(4) #define MICRO_CLK_EN BIT(3) #define MICRO_CLK_DIVIDE(x) ((x) >> 1) +#define MSCC_DW8051_VLD_MASK 0xf1ff
/* Extended page GPIO register 09G */ #define MSCC_TRAP_ROM_ADDR(x) ((x) * 2 + 1) +#define MSCC_TRAP_ROM_ADDR_SERDES_INIT 0x3eb7
/* Extended page GPIO register 10G */ #define MSCC_PATCH_RAM_ADDR(x) (((x) + 1) * 2) +#define MSCC_PATCH_RAM_ADDR_SERDES_INIT 0x4012
/* Extended page GPIO register 11G */ #define MSCC_INT_MEM_ADDR 11 @@ -166,7 +173,9 @@ #define PROC_CMD_SGMII_MAC (BIT(5) | BIT(4)) #define PROC_CMD_QSGMII_MAC BIT(5) #define PROC_CMD_NO_MAC_CONF (0x00 << 4) +#define PROC_CMD_1588_DEFAULT_INIT BIT(4) #define PROC_CMD_NOP GENMASK(3, 0) +#define PROC_CMD_PHY_INIT (BIT(3) | BIT(1)) #define PROC_CMD_CRC16 BIT(3) #define PROC_CMD_FIBER_MEDIA_CONF BIT(0) #define PROC_CMD_MCB_ACCESS_MAC_CONF (0x0000 << 0) @@ -184,6 +193,10 @@ #define MSCC_PHY_TEST_PAGE_8 8 #define TR_CLK_DISABLE BIT(15)
+#define MSCC_PHY_TEST_PAGE_9 9 +#define MSCC_PHY_TEST_PAGE_20 20 +#define MSCC_PHY_TEST_PAGE_24 24 + /* Token Ring Page 0x52B5 Registers */ #define MSCC_PHY_REG_TR_ADDR_16 16 #define MSCC_PHY_REG_TR_DATA_17 17 @@ -225,6 +238,9 @@ #define VSC8584_REVB 0x0001 #define MSCC_DEV_REV_MASK GENMASK(3, 0)
+#define MSCC_VSC8574_REVB_INT8051_FW_START_ADDR 0x4000 +#define MSCC_VSC8574_REVB_INT8051_FW_CRC 0x29e8 + #define MSCC_VSC8584_REVB_INT8051_FW_START_ADDR 0xe800 #define MSCC_VSC8584_REVB_INT8051_FW_CRC 0xfb48
@@ -373,6 +389,147 @@ static int vsc8584_micro_assert_reset(struct mii_dev *bus, int phy) return 0; }
+static const u8 fw_patch_vsc8574[] = { + 0x46, 0x4a, 0x02, 0x43, 0x37, 0x02, 0x46, 0x26, 0x02, 0x46, 0x77, 0x02, + 0x45, 0x60, 0x02, 0x45, 0xaf, 0xed, 0xff, 0xe5, 0xfc, 0x54, 0x38, 0x64, + 0x20, 0x70, 0x08, 0x65, 0xff, 0x70, 0x04, 0xed, 0x44, 0x80, 0xff, 0x22, + 0x8f, 0x19, 0x7b, 0xbb, 0x7d, 0x0e, 0x7f, 0x04, 0x12, 0x3d, 0xd7, 0xef, + 0x4e, 0x60, 0x03, 0x02, 0x41, 0xf9, 0xe4, 0xf5, 0x1a, 0x74, 0x01, 0x7e, + 0x00, 0xa8, 0x1a, 0x08, 0x80, 0x05, 0xc3, 0x33, 0xce, 0x33, 0xce, 0xd8, + 0xf9, 0xff, 0xef, 0x55, 0x19, 0x70, 0x03, 0x02, 0x41, 0xed, 0x85, 0x1a, + 0xfb, 0x7b, 0xbb, 0xe4, 0xfd, 0xff, 0x12, 0x3d, 0xd7, 0xef, 0x4e, 0x60, + 0x03, 0x02, 0x41, 0xed, 0xe5, 0x1a, 0x54, 0x02, 0x75, 0x1d, 0x00, 0x25, + 0xe0, 0x25, 0xe0, 0xf5, 0x1c, 0xe4, 0x78, 0xc5, 0xf6, 0xd2, 0x0a, 0x12, + 0x41, 0xfa, 0x7b, 0xff, 0x7d, 0x12, 0x7f, 0x07, 0x12, 0x3d, 0xd7, 0xef, + 0x4e, 0x60, 0x03, 0x02, 0x41, 0xe7, 0xc2, 0x0a, 0x74, 0xc7, 0x25, 0x1a, + 0xf9, 0x74, 0xe7, 0x25, 0x1a, 0xf8, 0xe6, 0x27, 0xf5, 0x1b, 0xe5, 0x1d, + 0x24, 0x5b, 0x12, 0x45, 0xea, 0x12, 0x3e, 0xda, 0x7b, 0xfc, 0x7d, 0x11, + 0x7f, 0x07, 0x12, 0x3d, 0xd7, 0x78, 0xcc, 0xef, 0xf6, 0x78, 0xc1, 0xe6, + 0xfe, 0xef, 0xd3, 0x9e, 0x40, 0x06, 0x78, 0xcc, 0xe6, 0x78, 0xc1, 0xf6, + 0x12, 0x41, 0xfa, 0x7b, 0xec, 0x7d, 0x12, 0x7f, 0x07, 0x12, 0x3d, 0xd7, + 0x78, 0xcb, 0xef, 0xf6, 0xbf, 0x07, 0x06, 0x78, 0xc3, 0x76, 0x1a, 0x80, + 0x1f, 0x78, 0xc5, 0xe6, 0xff, 0x60, 0x0f, 0xc3, 0xe5, 0x1b, 0x9f, 0xff, + 0x78, 0xcb, 0xe6, 0x85, 0x1b, 0xf0, 0xa4, 0x2f, 0x80, 0x07, 0x78, 0xcb, + 0xe6, 0x85, 0x1b, 0xf0, 0xa4, 0x78, 0xc3, 0xf6, 0xe4, 0x78, 0xc2, 0xf6, + 0x78, 0xc2, 0xe6, 0xff, 0xc3, 0x08, 0x96, 0x40, 0x03, 0x02, 0x41, 0xd1, + 0xef, 0x54, 0x03, 0x60, 0x33, 0x14, 0x60, 0x46, 0x24, 0xfe, 0x60, 0x42, + 0x04, 0x70, 0x4b, 0xef, 0x24, 0x02, 0xff, 0xe4, 0x33, 0xfe, 0xef, 0x78, + 0x02, 0xce, 0xa2, 0xe7, 0x13, 0xce, 0x13, 0xd8, 0xf8, 0xff, 0xe5, 0x1d, + 0x24, 0x5c, 0xcd, 0xe5, 0x1c, 0x34, 0xf0, 0xcd, 0x2f, 0xff, 0xed, 0x3e, + 0xfe, 0x12, 0x46, 0x0d, 0x7d, 0x11, 0x80, 0x0b, 0x78, 0xc2, 0xe6, 0x70, + 0x04, 0x7d, 0x11, 0x80, 0x02, 0x7d, 0x12, 0x7f, 0x07, 0x12, 0x3e, 0x9a, + 0x8e, 0x1e, 0x8f, 0x1f, 0x80, 0x03, 0xe5, 0x1e, 0xff, 0x78, 0xc5, 0xe6, + 0x06, 0x24, 0xcd, 0xf8, 0xa6, 0x07, 0x78, 0xc2, 0x06, 0xe6, 0xb4, 0x1a, + 0x0a, 0xe5, 0x1d, 0x24, 0x5c, 0x12, 0x45, 0xea, 0x12, 0x3e, 0xda, 0x78, + 0xc5, 0xe6, 0x65, 0x1b, 0x70, 0x82, 0x75, 0xdb, 0x20, 0x75, 0xdb, 0x28, + 0x12, 0x46, 0x02, 0x12, 0x46, 0x02, 0xe5, 0x1a, 0x12, 0x45, 0xf5, 0xe5, + 0x1a, 0xc3, 0x13, 0x12, 0x45, 0xf5, 0x78, 0xc5, 0x16, 0xe6, 0x24, 0xcd, + 0xf8, 0xe6, 0xff, 0x7e, 0x08, 0x1e, 0xef, 0xa8, 0x06, 0x08, 0x80, 0x02, + 0xc3, 0x13, 0xd8, 0xfc, 0xfd, 0xc4, 0x33, 0x54, 0xe0, 0xf5, 0xdb, 0xef, + 0xa8, 0x06, 0x08, 0x80, 0x02, 0xc3, 0x13, 0xd8, 0xfc, 0xfd, 0xc4, 0x33, + 0x54, 0xe0, 0x44, 0x08, 0xf5, 0xdb, 0xee, 0x70, 0xd8, 0x78, 0xc5, 0xe6, + 0x70, 0xc8, 0x75, 0xdb, 0x10, 0x02, 0x40, 0xfd, 0x78, 0xc2, 0xe6, 0xc3, + 0x94, 0x17, 0x50, 0x0e, 0xe5, 0x1d, 0x24, 0x62, 0x12, 0x42, 0x08, 0xe5, + 0x1d, 0x24, 0x5c, 0x12, 0x42, 0x08, 0x20, 0x0a, 0x03, 0x02, 0x40, 0x76, + 0x05, 0x1a, 0xe5, 0x1a, 0xc3, 0x94, 0x04, 0x50, 0x03, 0x02, 0x40, 0x3a, + 0x22, 0xe5, 0x1d, 0x24, 0x5c, 0xff, 0xe5, 0x1c, 0x34, 0xf0, 0xfe, 0x12, + 0x46, 0x0d, 0x22, 0xff, 0xe5, 0x1c, 0x34, 0xf0, 0xfe, 0x12, 0x46, 0x0d, + 0x22, 0xe4, 0xf5, 0x19, 0x12, 0x46, 0x43, 0x20, 0xe7, 0x1e, 0x7b, 0xfe, + 0x12, 0x42, 0xf9, 0xef, 0xc4, 0x33, 0x33, 0x54, 0xc0, 0xff, 0xc0, 0x07, + 0x7b, 0x54, 0x12, 0x42, 0xf9, 0xd0, 0xe0, 0x4f, 0xff, 0x74, 0x2a, 0x25, + 0x19, 0xf8, 0xa6, 0x07, 0x12, 0x46, 0x43, 0x20, 0xe7, 0x03, 0x02, 0x42, + 0xdf, 0x54, 0x03, 0x64, 0x03, 0x70, 0x03, 0x02, 0x42, 0xcf, 0x7b, 0xcb, + 0x12, 0x43, 0x2c, 0x8f, 0xfb, 0x7b, 0x30, 0x7d, 0x03, 0xe4, 0xff, 0x12, + 0x3d, 0xd7, 0xc3, 0xef, 0x94, 0x02, 0xee, 0x94, 0x00, 0x50, 0x2a, 0x12, + 0x42, 0xec, 0xef, 0x4e, 0x70, 0x23, 0x12, 0x43, 0x04, 0x60, 0x0a, 0x12, + 0x43, 0x12, 0x70, 0x0c, 0x12, 0x43, 0x1f, 0x70, 0x07, 0x12, 0x46, 0x39, + 0x7b, 0x03, 0x80, 0x07, 0x12, 0x46, 0x39, 0x12, 0x46, 0x43, 0xfb, 0x7a, + 0x00, 0x7d, 0x54, 0x80, 0x3e, 0x12, 0x42, 0xec, 0xef, 0x4e, 0x70, 0x24, + 0x12, 0x43, 0x04, 0x60, 0x0a, 0x12, 0x43, 0x12, 0x70, 0x0f, 0x12, 0x43, + 0x1f, 0x70, 0x0a, 0x12, 0x46, 0x39, 0xe4, 0xfb, 0xfa, 0x7d, 0xee, 0x80, + 0x1e, 0x12, 0x46, 0x39, 0x7b, 0x01, 0x7a, 0x00, 0x7d, 0xee, 0x80, 0x13, + 0x12, 0x46, 0x39, 0x12, 0x46, 0x43, 0x54, 0x40, 0xfe, 0xc4, 0x13, 0x13, + 0x54, 0x03, 0xfb, 0x7a, 0x00, 0x7d, 0xee, 0x12, 0x38, 0xbd, 0x7b, 0xff, + 0x12, 0x43, 0x2c, 0xef, 0x4e, 0x70, 0x07, 0x74, 0x2a, 0x25, 0x19, 0xf8, + 0xe4, 0xf6, 0x05, 0x19, 0xe5, 0x19, 0xc3, 0x94, 0x02, 0x50, 0x03, 0x02, + 0x42, 0x15, 0x22, 0xe5, 0x19, 0x24, 0x17, 0xfd, 0x7b, 0x20, 0x7f, 0x04, + 0x12, 0x3d, 0xd7, 0x22, 0xe5, 0x19, 0x24, 0x17, 0xfd, 0x7f, 0x04, 0x12, + 0x3d, 0xd7, 0x22, 0x7b, 0x22, 0x7d, 0x18, 0x7f, 0x06, 0x12, 0x3d, 0xd7, + 0xef, 0x64, 0x01, 0x4e, 0x22, 0x7d, 0x1c, 0xe4, 0xff, 0x12, 0x3e, 0x9a, + 0xef, 0x54, 0x1b, 0x64, 0x0a, 0x22, 0x7b, 0xcc, 0x7d, 0x10, 0xff, 0x12, + 0x3d, 0xd7, 0xef, 0x64, 0x01, 0x4e, 0x22, 0xe5, 0x19, 0x24, 0x17, 0xfd, + 0x7f, 0x04, 0x12, 0x3d, 0xd7, 0x22, 0xd2, 0x08, 0x75, 0xfb, 0x03, 0xab, + 0x7e, 0xaa, 0x7d, 0x7d, 0x19, 0x7f, 0x03, 0x12, 0x3e, 0xda, 0xe5, 0x7e, + 0x54, 0x0f, 0x24, 0xf3, 0x60, 0x03, 0x02, 0x43, 0xe9, 0x12, 0x46, 0x5a, + 0x12, 0x46, 0x61, 0xd8, 0xfb, 0xff, 0x20, 0xe2, 0x35, 0x13, 0x92, 0x0c, + 0xef, 0xa2, 0xe1, 0x92, 0x0b, 0x30, 0x0c, 0x2a, 0xe4, 0xf5, 0x10, 0x7b, + 0xfe, 0x12, 0x43, 0xff, 0xef, 0xc4, 0x33, 0x33, 0x54, 0xc0, 0xff, 0xc0, + 0x07, 0x7b, 0x54, 0x12, 0x43, 0xff, 0xd0, 0xe0, 0x4f, 0xff, 0x74, 0x2a, + 0x25, 0x10, 0xf8, 0xa6, 0x07, 0x05, 0x10, 0xe5, 0x10, 0xc3, 0x94, 0x02, + 0x40, 0xd9, 0x12, 0x46, 0x5a, 0x12, 0x46, 0x61, 0xd8, 0xfb, 0x54, 0x05, + 0x64, 0x04, 0x70, 0x27, 0x78, 0xc4, 0xe6, 0x78, 0xc6, 0xf6, 0xe5, 0x7d, + 0xff, 0x33, 0x95, 0xe0, 0xef, 0x54, 0x0f, 0x78, 0xc4, 0xf6, 0x12, 0x44, + 0x0a, 0x20, 0x0c, 0x0c, 0x12, 0x46, 0x5a, 0x12, 0x46, 0x61, 0xd8, 0xfb, + 0x13, 0x92, 0x0d, 0x22, 0xc2, 0x0d, 0x22, 0x12, 0x46, 0x5a, 0x12, 0x46, + 0x61, 0xd8, 0xfb, 0x54, 0x05, 0x64, 0x05, 0x70, 0x1e, 0x78, 0xc4, 0x7d, + 0xb8, 0x12, 0x43, 0xf5, 0x78, 0xc1, 0x7d, 0x74, 0x12, 0x43, 0xf5, 0xe4, + 0x78, 0xc1, 0xf6, 0x22, 0x7b, 0x01, 0x7a, 0x00, 0x7d, 0xee, 0x7f, 0x92, + 0x12, 0x38, 0xbd, 0x22, 0xe6, 0xfb, 0x7a, 0x00, 0x7f, 0x92, 0x12, 0x38, + 0xbd, 0x22, 0xe5, 0x10, 0x24, 0x17, 0xfd, 0x7f, 0x04, 0x12, 0x3d, 0xd7, + 0x22, 0x78, 0xc1, 0xe6, 0xfb, 0x7a, 0x00, 0x7d, 0x74, 0x7f, 0x92, 0x12, + 0x38, 0xbd, 0xe4, 0x78, 0xc1, 0xf6, 0xf5, 0x11, 0x74, 0x01, 0x7e, 0x00, + 0xa8, 0x11, 0x08, 0x80, 0x05, 0xc3, 0x33, 0xce, 0x33, 0xce, 0xd8, 0xf9, + 0xff, 0x78, 0xc4, 0xe6, 0xfd, 0xef, 0x5d, 0x60, 0x44, 0x85, 0x11, 0xfb, + 0xe5, 0x11, 0x54, 0x02, 0x25, 0xe0, 0x25, 0xe0, 0xfe, 0xe4, 0x24, 0x5b, + 0xfb, 0xee, 0x12, 0x45, 0xed, 0x12, 0x3e, 0xda, 0x7b, 0x40, 0x7d, 0x11, + 0x7f, 0x07, 0x12, 0x3d, 0xd7, 0x74, 0xc7, 0x25, 0x11, 0xf8, 0xa6, 0x07, + 0x7b, 0x11, 0x7d, 0x12, 0x7f, 0x07, 0x12, 0x3d, 0xd7, 0xef, 0x4e, 0x60, + 0x09, 0x74, 0xe7, 0x25, 0x11, 0xf8, 0x76, 0x04, 0x80, 0x07, 0x74, 0xe7, + 0x25, 0x11, 0xf8, 0x76, 0x0a, 0x05, 0x11, 0xe5, 0x11, 0xc3, 0x94, 0x04, + 0x40, 0x9a, 0x78, 0xc6, 0xe6, 0x70, 0x15, 0x78, 0xc4, 0xe6, 0x60, 0x10, + 0x75, 0xd9, 0x38, 0x75, 0xdb, 0x10, 0x7d, 0xfe, 0x12, 0x44, 0xb8, 0x7d, + 0x76, 0x12, 0x44, 0xb8, 0x79, 0xc6, 0xe7, 0x78, 0xc4, 0x66, 0xff, 0x60, + 0x03, 0x12, 0x40, 0x25, 0x78, 0xc4, 0xe6, 0x70, 0x09, 0xfb, 0xfa, 0x7d, + 0xfe, 0x7f, 0x8e, 0x12, 0x38, 0xbd, 0x22, 0x7b, 0x01, 0x7a, 0x00, 0x7f, + 0x8e, 0x12, 0x38, 0xbd, 0x22, 0xe4, 0xf5, 0xfb, 0x7d, 0x1c, 0xe4, 0xff, + 0x12, 0x3e, 0x9a, 0xad, 0x07, 0xac, 0x06, 0xec, 0x54, 0xc0, 0xff, 0xed, + 0x54, 0x3f, 0x4f, 0xf5, 0x20, 0x30, 0x06, 0x2c, 0x30, 0x01, 0x08, 0xa2, + 0x04, 0x72, 0x03, 0x92, 0x07, 0x80, 0x21, 0x30, 0x04, 0x06, 0x7b, 0xcc, + 0x7d, 0x11, 0x80, 0x0d, 0x30, 0x03, 0x06, 0x7b, 0xcc, 0x7d, 0x10, 0x80, + 0x04, 0x7b, 0x66, 0x7d, 0x16, 0xe4, 0xff, 0x12, 0x3d, 0xd7, 0xee, 0x4f, + 0x24, 0xff, 0x92, 0x07, 0xaf, 0xfb, 0x74, 0x26, 0x2f, 0xf8, 0xe6, 0xff, + 0xa6, 0x20, 0x20, 0x07, 0x39, 0x8f, 0x20, 0x30, 0x07, 0x34, 0x30, 0x00, + 0x31, 0x20, 0x04, 0x2e, 0x20, 0x03, 0x2b, 0xe4, 0xf5, 0xff, 0x75, 0xfc, + 0xc2, 0xe5, 0xfc, 0x30, 0xe0, 0xfb, 0xaf, 0xfe, 0xef, 0x20, 0xe3, 0x1a, + 0xae, 0xfd, 0x44, 0x08, 0xf5, 0xfe, 0x75, 0xfc, 0x80, 0xe5, 0xfc, 0x30, + 0xe0, 0xfb, 0x8f, 0xfe, 0x8e, 0xfd, 0x75, 0xfc, 0x80, 0xe5, 0xfc, 0x30, + 0xe0, 0xfb, 0x05, 0xfb, 0xaf, 0xfb, 0xef, 0xc3, 0x94, 0x04, 0x50, 0x03, + 0x02, 0x44, 0xc5, 0xe4, 0xf5, 0xfb, 0x22, 0xe5, 0x7e, 0x54, 0x0f, 0x64, + 0x01, 0x70, 0x23, 0xe5, 0x7e, 0x30, 0xe4, 0x1e, 0x90, 0x47, 0xd0, 0xe0, + 0x44, 0x02, 0xf0, 0x54, 0xfb, 0xf0, 0x90, 0x47, 0xd4, 0xe0, 0x44, 0x04, + 0xf0, 0x7b, 0x03, 0x7d, 0x5b, 0x7f, 0x5d, 0x12, 0x36, 0x29, 0x7b, 0x0e, + 0x80, 0x1c, 0x90, 0x47, 0xd0, 0xe0, 0x54, 0xfd, 0xf0, 0x44, 0x04, 0xf0, + 0x90, 0x47, 0xd4, 0xe0, 0x54, 0xfb, 0xf0, 0x7b, 0x02, 0x7d, 0x5b, 0x7f, + 0x5d, 0x12, 0x36, 0x29, 0x7b, 0x06, 0x7d, 0x60, 0x7f, 0x63, 0x12, 0x36, + 0x29, 0x22, 0xe5, 0x7e, 0x30, 0xe5, 0x35, 0x30, 0xe4, 0x0b, 0x7b, 0x02, + 0x7d, 0x33, 0x7f, 0x35, 0x12, 0x36, 0x29, 0x80, 0x10, 0x7b, 0x01, 0x7d, + 0x33, 0x7f, 0x35, 0x12, 0x36, 0x29, 0x90, 0x47, 0xd2, 0xe0, 0x44, 0x04, + 0xf0, 0x90, 0x47, 0xd2, 0xe0, 0x54, 0xf7, 0xf0, 0x90, 0x47, 0xd1, 0xe0, + 0x44, 0x10, 0xf0, 0x7b, 0x05, 0x7d, 0x84, 0x7f, 0x86, 0x12, 0x36, 0x29, + 0x22, 0xfb, 0xe5, 0x1c, 0x34, 0xf0, 0xfa, 0x7d, 0x10, 0x7f, 0x07, 0x22, + 0x54, 0x01, 0xc4, 0x33, 0x54, 0xe0, 0xf5, 0xdb, 0x44, 0x08, 0xf5, 0xdb, + 0x22, 0xf5, 0xdb, 0x75, 0xdb, 0x08, 0xf5, 0xdb, 0x75, 0xdb, 0x08, 0x22, + 0xab, 0x07, 0xaa, 0x06, 0x7d, 0x10, 0x7f, 0x07, 0x12, 0x3e, 0xda, 0x7b, + 0xff, 0x7d, 0x10, 0x7f, 0x07, 0x12, 0x3d, 0xd7, 0xef, 0x4e, 0x60, 0xf3, + 0x22, 0x12, 0x44, 0xc2, 0x30, 0x0c, 0x03, 0x12, 0x42, 0x12, 0x78, 0xc4, + 0xe6, 0xff, 0x60, 0x03, 0x12, 0x40, 0x25, 0x22, 0xe5, 0x19, 0x24, 0x17, + 0x54, 0x1f, 0x44, 0x80, 0xff, 0x22, 0x74, 0x2a, 0x25, 0x19, 0xf8, 0xe6, + 0x22, 0x12, 0x46, 0x72, 0x12, 0x46, 0x68, 0x90, 0x47, 0xfa, 0xe0, 0x54, + 0xf8, 0x44, 0x02, 0xf0, 0x22, 0xe5, 0x7e, 0xae, 0x7d, 0x78, 0x04, 0x22, + 0xce, 0xa2, 0xe7, 0x13, 0xce, 0x13, 0x22, 0xe4, 0x78, 0xc4, 0xf6, 0xc2, + 0x0d, 0x78, 0xc1, 0xf6, 0x22, 0xc2, 0x0c, 0xc2, 0x0b, 0x22, 0x22, +}; + static const u8 fw_patch_vsc8584[] = { 0xe8, 0x59, 0x02, 0xe8, 0x12, 0x02, 0xe8, 0x42, 0x02, 0xe8, 0x5a, 0x02, 0xe8, 0x5b, 0x02, 0xe8, 0x5c, 0xe5, 0x69, 0x54, 0x0f, 0x24, 0xf7, 0x60, @@ -451,6 +608,247 @@ static int vsc8584_patch_fw(struct mii_dev *bus, int phy, const u8 *fw_patch, return 0; }
+static bool vsc8574_is_serdes_init(struct mii_dev *bus, int phy) +{ + u16 reg; + bool ret; + + bus->write(bus, phy, MDIO_DEVAD_NONE, MSCC_EXT_PAGE_ACCESS, + MSCC_PHY_PAGE_GPIO); + + reg = bus->read(bus, phy, MDIO_DEVAD_NONE, MSCC_TRAP_ROM_ADDR(1)); + if (reg != MSCC_TRAP_ROM_ADDR_SERDES_INIT) { + ret = false; + goto out; + } + + reg = bus->read(bus, phy, MDIO_DEVAD_NONE, MSCC_PATCH_RAM_ADDR(1)); + if (reg != MSCC_PATCH_RAM_ADDR_SERDES_INIT) { + ret = false; + goto out; + } + + reg = bus->read(bus, phy, MDIO_DEVAD_NONE, MSCC_INT_MEM_CNTL); + if (reg != EN_PATCH_RAM_TRAP_ADDR(1)) { + ret = false; + goto out; + } + + reg = bus->read(bus, phy, MDIO_DEVAD_NONE, MSCC_DW8051_CNTL_STATUS); + if ((MICRO_NSOFT_RESET | RUN_FROM_INT_ROM | DW8051_CLK_EN | + MICRO_CLK_EN) != (reg & MSCC_DW8051_VLD_MASK)) { + ret = false; + goto out; + } + + ret = true; + +out: + bus->write(bus, phy, MDIO_DEVAD_NONE, MSCC_EXT_PAGE_ACCESS, + MSCC_PHY_PAGE_GPIO); + + return ret; +} + +static int vsc8574_config_pre_init(struct phy_device *phydev) +{ + struct mii_dev *bus = phydev->bus; + u16 crc, reg, phy0, addr; + bool serdes_init; + int ret; + + phy_write(phydev, MDIO_DEVAD_NONE, MSCC_EXT_PAGE_ACCESS, + MSCC_PHY_PAGE_EXT1); + addr = phy_read(phydev, MDIO_DEVAD_NONE, MSCC_PHY_EXT_PHY_CNTL_4); + addr >>= PHY_CNTL_4_ADDR_POS; + + reg = phy_read(phydev, MDIO_DEVAD_NONE, MSCC_PHY_ACTIPHY_CNTL); + if (reg & PHY_ADDR_REVERSED) + phy0 = phydev->addr + addr; + else + phy0 = phydev->addr - addr; + + bus->write(bus, phy0, MDIO_DEVAD_NONE, MSCC_EXT_PAGE_ACCESS, + MSCC_PHY_PAGE_STD); + + /* all writes below are broadcasted to all PHYs in the same package */ + reg = bus->read(bus, phy0, MDIO_DEVAD_NONE, MSCC_PHY_EXT_CNTL_STATUS); + reg |= SMI_BROADCAST_WR_EN; + bus->write(bus, phy0, MDIO_DEVAD_NONE, MSCC_PHY_EXT_CNTL_STATUS, reg); + + /* + * The below register writes are tweaking analog and electrical + * configuration that were determined through characterization by PHY + * engineers. These don't mean anything more than "these are the best + * values". + */ + bus->write(bus, phy0, MDIO_DEVAD_NONE, MSCC_PHY_EXT_PHY_CNTL_2, 0x0040); + + bus->write(bus, phy0, MDIO_DEVAD_NONE, MSCC_EXT_PAGE_ACCESS, + MSCC_PHY_PAGE_TEST); + + bus->write(bus, phy0, MDIO_DEVAD_NONE, MSCC_PHY_TEST_PAGE_20, 0x4320); + bus->write(bus, phy0, MDIO_DEVAD_NONE, MSCC_PHY_TEST_PAGE_24, 0x0c00); + bus->write(bus, phy0, MDIO_DEVAD_NONE, MSCC_PHY_TEST_PAGE_9, 0x18ca); + bus->write(bus, phy0, MDIO_DEVAD_NONE, MSCC_PHY_TEST_PAGE_5, 0x1b20); + + reg = bus->read(bus, phy0, MDIO_DEVAD_NONE, MSCC_PHY_TEST_PAGE_8); + reg |= TR_CLK_DISABLE; + bus->write(bus, phy0, MDIO_DEVAD_NONE, MSCC_PHY_TEST_PAGE_8, reg); + + bus->write(bus, phy0, MDIO_DEVAD_NONE, MSCC_EXT_PAGE_ACCESS, + MSCC_PHY_PAGE_TR); + + vsc8584_csr_write(bus, phy0, 0x0fae, 0x000401bd); + vsc8584_csr_write(bus, phy0, 0x0fac, 0x000f000f); + vsc8584_csr_write(bus, phy0, 0x17a0, 0x00a0f147); + vsc8584_csr_write(bus, phy0, 0x0fe4, 0x00052f54); + vsc8584_csr_write(bus, phy0, 0x1792, 0x0027303d); + vsc8584_csr_write(bus, phy0, 0x07fe, 0x00000704); + vsc8584_csr_write(bus, phy0, 0x0fe0, 0x00060150); + vsc8584_csr_write(bus, phy0, 0x0f82, 0x0012b00a); + vsc8584_csr_write(bus, phy0, 0x0f80, 0x00000d74); + vsc8584_csr_write(bus, phy0, 0x02e0, 0x00000012); + vsc8584_csr_write(bus, phy0, 0x03a2, 0x00050208); + vsc8584_csr_write(bus, phy0, 0x03b2, 0x00009186); + vsc8584_csr_write(bus, phy0, 0x0fb0, 0x000e3700); + vsc8584_csr_write(bus, phy0, 0x1688, 0x00049f81); + vsc8584_csr_write(bus, phy0, 0x0fd2, 0x0000ffff); + vsc8584_csr_write(bus, phy0, 0x168a, 0x00039fa2); + vsc8584_csr_write(bus, phy0, 0x1690, 0x0020640b); + vsc8584_csr_write(bus, phy0, 0x0258, 0x00002220); + vsc8584_csr_write(bus, phy0, 0x025a, 0x00002a20); + vsc8584_csr_write(bus, phy0, 0x025c, 0x00003060); + vsc8584_csr_write(bus, phy0, 0x025e, 0x00003fa0); + vsc8584_csr_write(bus, phy0, 0x03a6, 0x0000e0f0); + vsc8584_csr_write(bus, phy0, 0x0f92, 0x00001489); + vsc8584_csr_write(bus, phy0, 0x16a2, 0x00007000); + vsc8584_csr_write(bus, phy0, 0x16a6, 0x00071448); + vsc8584_csr_write(bus, phy0, 0x16a0, 0x00eeffdd); + vsc8584_csr_write(bus, phy0, 0x0fe8, 0x0091b06c); + vsc8584_csr_write(bus, phy0, 0x0fea, 0x00041600); + vsc8584_csr_write(bus, phy0, 0x16b0, 0x00eeff00); + vsc8584_csr_write(bus, phy0, 0x16b2, 0x00007000); + vsc8584_csr_write(bus, phy0, 0x16b4, 0x00000814); + vsc8584_csr_write(bus, phy0, 0x0f90, 0x00688980); + vsc8584_csr_write(bus, phy0, 0x03a4, 0x0000d8f0); + vsc8584_csr_write(bus, phy0, 0x0fc0, 0x00000400); + vsc8584_csr_write(bus, phy0, 0x07fa, 0x0050100f); + vsc8584_csr_write(bus, phy0, 0x0796, 0x00000003); + vsc8584_csr_write(bus, phy0, 0x07f8, 0x00c3ff98); + vsc8584_csr_write(bus, phy0, 0x0fa4, 0x0018292a); + vsc8584_csr_write(bus, phy0, 0x168c, 0x00d2c46f); + vsc8584_csr_write(bus, phy0, 0x17a2, 0x00000620); + vsc8584_csr_write(bus, phy0, 0x16a4, 0x0013132f); + vsc8584_csr_write(bus, phy0, 0x16a8, 0x00000000); + vsc8584_csr_write(bus, phy0, 0x0ffc, 0x00c0a028); + vsc8584_csr_write(bus, phy0, 0x0fec, 0x00901c09); + vsc8584_csr_write(bus, phy0, 0x0fee, 0x0004a6a1); + vsc8584_csr_write(bus, phy0, 0x0ffe, 0x00b01807); + + bus->write(bus, phy0, MDIO_DEVAD_NONE, MSCC_EXT_PAGE_ACCESS, + MSCC_PHY_PAGE_EXT2); + + bus->write(bus, phy0, MDIO_DEVAD_NONE, MSCC_PHY_CU_PMD_TX_CNTL, 0x028e); + + bus->write(bus, phy0, MDIO_DEVAD_NONE, MSCC_EXT_PAGE_ACCESS, + MSCC_PHY_PAGE_TR); + + vsc8584_csr_write(bus, phy0, 0x0486, 0x0008a518); + vsc8584_csr_write(bus, phy0, 0x0488, 0x006dc696); + vsc8584_csr_write(bus, phy0, 0x048a, 0x00000912); + vsc8584_csr_write(bus, phy0, 0x048e, 0x00000db6); + vsc8584_csr_write(bus, phy0, 0x049c, 0x00596596); + vsc8584_csr_write(bus, phy0, 0x049e, 0x00000514); + vsc8584_csr_write(bus, phy0, 0x04a2, 0x00410280); + vsc8584_csr_write(bus, phy0, 0x04a4, 0x00000000); + vsc8584_csr_write(bus, phy0, 0x04a6, 0x00000000); + vsc8584_csr_write(bus, phy0, 0x04a8, 0x00000000); + vsc8584_csr_write(bus, phy0, 0x04aa, 0x00000000); + vsc8584_csr_write(bus, phy0, 0x04ae, 0x007df7dd); + vsc8584_csr_write(bus, phy0, 0x04b0, 0x006d95d4); + vsc8584_csr_write(bus, phy0, 0x04b2, 0x00492410); + + bus->write(bus, phy0, MDIO_DEVAD_NONE, MSCC_EXT_PAGE_ACCESS, + MSCC_PHY_PAGE_TEST); + + reg = bus->read(bus, phy0, MDIO_DEVAD_NONE, MSCC_PHY_TEST_PAGE_8); + reg &= ~TR_CLK_DISABLE; + bus->write(bus, phy0, MDIO_DEVAD_NONE, MSCC_PHY_TEST_PAGE_8, reg); + + bus->write(bus, phy0, MDIO_DEVAD_NONE, MSCC_EXT_PAGE_ACCESS, + MSCC_PHY_PAGE_STD); + + /* end of write broadcasting */ + reg = bus->read(bus, phy0, MDIO_DEVAD_NONE, MSCC_PHY_EXT_CNTL_STATUS); + reg &= ~SMI_BROADCAST_WR_EN; + bus->write(bus, phy0, MDIO_DEVAD_NONE, MSCC_PHY_EXT_CNTL_STATUS, reg); + + ret = vsc8584_get_fw_crc(bus, phy0, + MSCC_VSC8574_REVB_INT8051_FW_START_ADDR, &crc, + fw_patch_vsc8574, + ARRAY_SIZE(fw_patch_vsc8574)); + if (ret) + goto out; + + if (crc == MSCC_VSC8574_REVB_INT8051_FW_CRC) { + serdes_init = vsc8574_is_serdes_init(bus, phy0); + + if (!serdes_init) { + ret = vsc8584_micro_assert_reset(bus, phy0); + if (ret) { + pr_err("failed to assert reset of micro\n"); + return ret; + } + } + } else { + pr_debug("FW CRC is not the expected one, patching FW\n"); + + serdes_init = false; + + if (vsc8584_patch_fw(bus, phy0, fw_patch_vsc8574, + ARRAY_SIZE(fw_patch_vsc8574))) + pr_warn("failed to patch FW, expect non-optimal device\n"); + } + + if (!serdes_init) { + bus->write(bus, phy0, MDIO_DEVAD_NONE, MSCC_EXT_PAGE_ACCESS, + MSCC_PHY_PAGE_GPIO); + + bus->write(bus, phy0, MDIO_DEVAD_NONE, MSCC_TRAP_ROM_ADDR(1), + MSCC_TRAP_ROM_ADDR_SERDES_INIT); + bus->write(bus, phy0, MDIO_DEVAD_NONE, MSCC_PATCH_RAM_ADDR(1), + MSCC_PATCH_RAM_ADDR_SERDES_INIT); + + bus->write(bus, phy0, MDIO_DEVAD_NONE, MSCC_INT_MEM_CNTL, + EN_PATCH_RAM_TRAP_ADDR(1)); + + vsc8584_micro_deassert_reset(bus, phy0, false); + + ret = vsc8584_get_fw_crc(bus, phy0, + MSCC_VSC8574_REVB_INT8051_FW_START_ADDR, + &crc, fw_patch_vsc8574, + ARRAY_SIZE(fw_patch_vsc8574)); + if (ret) + goto out; + + if (crc != MSCC_VSC8574_REVB_INT8051_FW_CRC) + pr_warn("FW CRC after patching is not the expected one, expect non-optimal device\n"); + } + + bus->write(bus, phy0, MDIO_DEVAD_NONE, MSCC_EXT_PAGE_ACCESS, + MSCC_PHY_PAGE_GPIO); + + ret = vsc8584_cmd(bus, phy0, PROC_CMD_1588_DEFAULT_INIT | + PROC_CMD_PHY_INIT); + +out: + bus->write(bus, phy0, MDIO_DEVAD_NONE, MSCC_EXT_PAGE_ACCESS, + MSCC_PHY_PAGE_STD); + + return ret; +} + static int vsc8584_config_pre_init(struct phy_device *phydev) { struct mii_dev *bus = phydev->bus; @@ -1009,6 +1407,17 @@ static int vsc8584_config_init(struct phy_device *phydev) return genphy_config(phydev); }
+static struct vsc85xx_priv vsc8574_priv = { + .config_pre = vsc8574_config_pre_init, +}; + +static int vsc8574_config(struct phy_device *phydev) +{ + phydev->priv = &vsc8574_priv; + + return vsc8584_config_init(phydev); +} + static struct vsc85xx_priv vsc8584_priv = { .config_pre = vsc8584_config_pre_init, }; @@ -1060,6 +1469,16 @@ static struct phy_driver VSC8541_driver = { .shutdown = &genphy_shutdown, };
+static struct phy_driver VSC8574_driver = { + .name = "Microsemi VSC8574", + .uid = PHY_ID_VSC8574, + .mask = 0x000ffff0, + .features = PHY_GBIT_FEATURES, + .config = &vsc8574_config, + .startup = &mscc_startup, + .shutdown = &genphy_shutdown, +}; + static struct phy_driver VSC8584_driver = { .name = "Microsemi VSC8584", .uid = PHY_ID_VSC8584, @@ -1076,6 +1495,7 @@ int phy_mscc_init(void) phy_register(&VSC8531_driver); phy_register(&VSC8540_driver); phy_register(&VSC8541_driver); + phy_register(&VSC8574_driver); phy_register(&VSC8584_driver);
On Wed, Oct 31, 2018 at 5:22 AM Quentin Schulz quentin.schulz@bootlin.com wrote:
Hi Quentin,
https://patchwork.ozlabs.org/patch/991334/ was applied to http://git.denx.de/?p=u-boot/u-boot-net.git
Thanks! -Joe
Joe Hershberger
Quentin Schulz
