[U-Boot] [PATCH 1/1] efi_selftest: unit test for EFI_SIMPLE_TEXT_INPUT_PROTOCOL
Provide a unit test for the EFI_SIMPLE_TEXT_INPUT_PROTOCOL.
The unicode character and the scan code are printed for text input.
To run the test:
setenv efi_selftest text input bootefi selftest
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- lib/efi_selftest/Makefile | 1 + lib/efi_selftest/efi_selftest_textinput.c | 182 ++++++++++++++++++++++++++++++ 2 files changed, 183 insertions(+) create mode 100644 lib/efi_selftest/efi_selftest_textinput.c
diff --git a/lib/efi_selftest/Makefile b/lib/efi_selftest/Makefile index 88c44840d52..95bd5416c09 100644 --- a/lib/efi_selftest/Makefile +++ b/lib/efi_selftest/Makefile @@ -23,6 +23,7 @@ efi_selftest_fdt.o \ efi_selftest_gop.o \ efi_selftest_manageprotocols.o \ efi_selftest_snp.o \ +efi_selftest_textinput.o \ efi_selftest_textoutput.o \ efi_selftest_tpl.o \ efi_selftest_util.o \ diff --git a/lib/efi_selftest/efi_selftest_textinput.c b/lib/efi_selftest/efi_selftest_textinput.c new file mode 100644 index 00000000000..c890ff88b7e --- /dev/null +++ b/lib/efi_selftest/efi_selftest_textinput.c @@ -0,0 +1,182 @@ +/* + * efi_selftest_textinput + * + * Copyright (c) 2018 Heinrich Schuchardt xypron.glpk@gmx.de + * + * SPDX-License-Identifier: GPL-2.0+ + * + * Provides a unit test for the EFI_SIMPLE_TEXT_INPUT_PROTOCOL. + * The unicode character and the scan code are printed for text + * input. To run the test: + * + * setenv efi_selftest text input + * bootefi selftest + */ + +#include <efi_selftest.h> + +struct translate { + u16 code; + u16 *text; +}; + +static struct efi_boot_services *boottime; + +static struct translate control_characters[] = { + {0, L"Null"}, + {8, L"BS"}, + {9, L"TAB"}, + {10, L"LF"}, + {13, L"CR"}, + {0, NULL}, +}; + +static u16 ch[] = L"' '"; +static u16 unknown[] = L"unknown"; + +static struct translate scan_codes[] = { + {0x00, L"Null"}, + {0x01, L"Up"}, + {0x02, L"Down"}, + {0x03, L"Right"}, + {0x04, L"Left"}, + {0x05, L"Home"}, + {0x06, L"End"}, + {0x07, L"Insert"}, + {0x08, L"Delete"}, + {0x09, L"Page Up"}, + {0x0a, L"Page Down"}, + {0x0b, L"FN 1"}, + {0x0c, L"FN 2"}, + {0x0d, L"FN 3"}, + {0x0e, L"FN 4"}, + {0x0f, L"FN 5"}, + {0x10, L"FN 6"}, + {0x11, L"FN 7"}, + {0x12, L"FN 8"}, + {0x13, L"FN 9"}, + {0x14, L"FN 10"}, + {0x15, L"FN 11"}, + {0x16, L"FN 12"}, + {0x17, L"Escape"}, + {0x68, L"FN 13"}, + {0x69, L"FN 14"}, + {0x6a, L"FN 15"}, + {0x6b, L"FN 16"}, + {0x6c, L"FN 17"}, + {0x6d, L"FN 18"}, + {0x6e, L"FN 19"}, + {0x6f, L"FN 20"}, + {0x70, L"FN 21"}, + {0x71, L"FN 22"}, + {0x72, L"FN 23"}, + {0x73, L"FN 24"}, + {0x7f, L"Mute"}, + {0x80, L"Volume Up"}, + {0x81, L"Volume Down"}, + {0x100, L"Brightness Up"}, + {0x101, L"Brightness Down"}, + {0x102, L"Suspend"}, + {0x103, L"Hibernate"}, + {0x104, L"Toggle Display"}, + {0x105, L"Recovery"}, + {0x106, L"Reject"}, + {0x0, NULL}, +}; + +/* + * Translate a unicode character to a string. + * + * @code unicode character + * @return string + */ +static u16 *translate_char(u16 code) +{ + struct translate *tr; + + if (code >= ' ') { + ch[1] = code; + return ch; + } + for (tr = control_characters; tr->text; ++tr) { + if (tr->code == code) + return tr->text; + } + return unknown; +} + +/* + * Translate a scan code to a human readable string. + * + * @code unicode character + * @return string + */ +static u16 *translate_code(u16 code) +{ + struct translate *tr; + + for (tr = scan_codes; tr->text; ++tr) { + if (tr->code == code) + return tr->text; + } + return unknown; +} + +/* + * Setup unit test. + * + * @handle: handle of the loaded image + * @systable: system table + * @return: EFI_ST_SUCCESS for success + */ +static int setup(const efi_handle_t handle, + const struct efi_system_table *systable) +{ + boottime = systable->boottime; + + return EFI_ST_SUCCESS; +} + +/* + * Execute unit test. + * + * @return: EFI_ST_SUCCESS for success + */ +static int execute(void) +{ + struct efi_input_key input_key = {0}; + efi_status_t ret; + + efi_st_printf("Waiting for your input\n"); + efi_st_printf("To terminate type 'x'\n"); + + for (;;) { + /* Wait for next key */ + do { + ret = con_in->read_key_stroke(con_in, &input_key); + } while (ret == EFI_NOT_READY); + + /* Allow 5 minutes until time out */ + boottime->set_watchdog_timer(300, 0, 0, NULL); + + efi_st_printf("Unicode char %u (%ps), scan code %u (%ps)\n", + (unsigned int)input_key.unicode_char, + translate_char(input_key.unicode_char), + (unsigned int)input_key.scan_code, + translate_code(input_key.scan_code)); + + switch (input_key.unicode_char) { + case 'x': + case 'X': + return EFI_ST_SUCCESS; + } + } +} + +EFI_UNIT_TEST(textinput) = { + .name = "text input", + .phase = EFI_EXECUTE_BEFORE_BOOTTIME_EXIT, + .setup = setup, + .execute = execute, + .on_request = true, +};
