[PATCH v2 0/5] powerpc, mpc83xx: add DM_ETH support
This patch series adds DM ethernet support for mpc83xx based keymile boards.
Travis build: https://travis-ci.org/github/hsdenx/u-boot-test/builds/691607214
Changes in v2: - new in v2 - remove RFC - fixed Codingstyle errors, therefore new patch powerpc, mpc83xx: fix codingstyle issues for qe_io.c - moved DM part to drivers/pinctrl - add comments from Qiang Zhao: - add device node documentation - I did not drop the dm_qe_uec_phy.c and use drivers/net/fsl_mdio.c because using drivers/net/fsl_mdio.c leads in none existent udevice mdio@3320 instead boards with DM ETH support should use now this driver. - remove RFC tag - add patch which fixes Codingstyle errors in drivers/qe - add patch which converts the mpc83xx based boards from keymile to DM_ETH
Heiko Schocher (5): mpc83xx: remove unneeded extern declaration in cpu_init powerpc, qe: fix codingstyle issues for drivers/qe powerpc, qe: add DTS support for parallel I/O ports net, qe: add DM support for QE UEC ethernet mpc83xx, keymile boards: enable DM_ETH and add DTS
arch/powerpc/cpu/mpc83xx/Kconfig | 8 + arch/powerpc/cpu/mpc83xx/Makefile | 2 + arch/powerpc/cpu/mpc83xx/cpu_init.c | 11 +- arch/powerpc/cpu/mpc83xx/qe_io.c | 98 +- arch/powerpc/dts/Makefile | 8 + arch/powerpc/dts/km8309-uboot.dtsi | 33 + arch/powerpc/dts/km8321-uboot.dtsi | 67 + arch/powerpc/dts/km8321.dtsi | 220 ++++ arch/powerpc/dts/km836x-uboot.dtsi | 61 + arch/powerpc/dts/km836x.dtsi | 182 +++ arch/powerpc/dts/kmcoge5ne-uboot.dtsi | 22 + arch/powerpc/dts/kmcoge5ne.dts | 320 +++++ arch/powerpc/dts/kmeter1-uboot.dtsi | 42 + arch/powerpc/dts/kmeter1.dts | 480 +++++++ arch/powerpc/dts/kmopti2.dts | 161 +++ arch/powerpc/dts/kmsupc5.dts | 139 ++ arch/powerpc/dts/kmsupm5.dts | 129 ++ arch/powerpc/dts/kmtegr1.dts | 392 ++++++ arch/powerpc/dts/kmtepr2.dts | 142 ++ arch/powerpc/dts/kmtuge1.dts | 100 ++ arch/powerpc/dts/kmtuxa1.dts | 100 ++ board/keymile/km83xx/Kconfig | 17 + board/keymile/km83xx/MAINTAINERS | 23 +- board/keymile/km83xx/km83xx.c | 64 - configs/kmcoge5ne_defconfig | 11 +- configs/kmeter1_defconfig | 10 +- configs/kmopti2_defconfig | 11 +- configs/kmsupx5_defconfig | 10 +- configs/kmtegr1_defconfig | 12 +- configs/kmtepr2_defconfig | 10 +- configs/tuge1_defconfig | 10 +- configs/tuxx1_defconfig | 11 +- .../soc/fsl/cpm_qe/qe/ucc.txt | 53 + drivers/net/Kconfig | 2 + drivers/net/Makefile | 1 + drivers/net/qe/Kconfig | 9 + drivers/net/qe/Makefile | 5 + drivers/net/qe/dm_qe_uec.c | 1167 +++++++++++++++++ drivers/net/qe/dm_qe_uec.h | 22 + drivers/net/qe/dm_qe_uec_phy.c | 163 +++ drivers/net/qe/uccf.c | 507 +++++++ drivers/net/qe/uccf.h | 119 ++ drivers/net/qe/uec.h | 693 ++++++++++ drivers/pinctrl/Kconfig | 7 + drivers/pinctrl/Makefile | 1 + drivers/pinctrl/pinctrl-qe-io.c | 255 ++++ drivers/qe/qe.c | 96 +- drivers/qe/uccf.c | 449 ++++--- drivers/qe/uccf.h | 90 +- drivers/qe/uec.c | 598 ++++----- drivers/qe/uec.h | 381 +++--- drivers/qe/uec_phy.c | 334 ++--- drivers/qe/uec_phy.h | 71 +- include/configs/km/km-mpc832x.h | 14 - include/configs/km/km-mpc8360.h | 14 - include/configs/km/km-mpc83xx.h | 10 - include/fsl_qe.h | 3 + 57 files changed, 6826 insertions(+), 1144 deletions(-) create mode 100644 arch/powerpc/dts/km8309-uboot.dtsi create mode 100644 arch/powerpc/dts/km8321-uboot.dtsi create mode 100644 arch/powerpc/dts/km8321.dtsi create mode 100644 arch/powerpc/dts/km836x-uboot.dtsi create mode 100644 arch/powerpc/dts/km836x.dtsi create mode 100644 arch/powerpc/dts/kmcoge5ne-uboot.dtsi create mode 100644 arch/powerpc/dts/kmcoge5ne.dts create mode 100644 arch/powerpc/dts/kmeter1-uboot.dtsi create mode 100644 arch/powerpc/dts/kmeter1.dts create mode 100644 arch/powerpc/dts/kmopti2.dts create mode 100644 arch/powerpc/dts/kmsupc5.dts create mode 100644 arch/powerpc/dts/kmsupm5.dts create mode 100644 arch/powerpc/dts/kmtegr1.dts create mode 100644 arch/powerpc/dts/kmtepr2.dts create mode 100644 arch/powerpc/dts/kmtuge1.dts create mode 100644 arch/powerpc/dts/kmtuxa1.dts create mode 100644 doc/device-tree-bindings/soc/fsl/cpm_qe/qe/ucc.txt create mode 100644 drivers/net/qe/Kconfig create mode 100644 drivers/net/qe/Makefile create mode 100644 drivers/net/qe/dm_qe_uec.c create mode 100644 drivers/net/qe/dm_qe_uec.h create mode 100644 drivers/net/qe/dm_qe_uec_phy.c create mode 100644 drivers/net/qe/uccf.c create mode 100644 drivers/net/qe/uccf.h create mode 100644 drivers/net/qe/uec.h create mode 100644 drivers/pinctrl/pinctrl-qe-io.c
remove extern void qe_init(uint qe_base); extern void qe_reset(void);
and include fsl_qe.h instead.
Signed-off-by: Heiko Schocher hs@denx.de
arch/powerpc/cpu/mpc83xx/cpu_init.c | 3 +-- 1 file changed, 1 insertion(+), 2 deletions(-)
diff --git a/arch/powerpc/cpu/mpc83xx/cpu_init.c b/arch/powerpc/cpu/mpc83xx/cpu_init.c index 438b14b162..b21b0b0324 100644 --- a/arch/powerpc/cpu/mpc83xx/cpu_init.c +++ b/arch/powerpc/cpu/mpc83xx/cpu_init.c @@ -9,6 +9,7 @@ #include <ioports.h> #include <asm/io.h> #include <asm/processor.h> +#include <fsl_qe.h> #ifdef CONFIG_USB_EHCI_FSL #include <usb/ehci-ci.h> #endif @@ -26,8 +27,6 @@ DECLARE_GLOBAL_DATA_PTR; extern qe_iop_conf_t qe_iop_conf_tab[]; extern void qe_config_iopin(u8 port, u8 pin, int dir, int open_drain, int assign); -extern void qe_init(uint qe_base); -extern void qe_reset(void);
static void config_qe_ioports(void) {
fix Codingstyle for files in drivers/qe, remaining following check warnings:
$ ./scripts/checkpatch.pl -f drivers/qe/uec.h CHECK: Macro argument reuse '_bd' - possible side-effects? +#define BD_ADVANCE(_bd, _status, _base) \ + (((_status) & BD_WRAP) ? (_bd) = \ + ((struct buffer_descriptor *)(_base)) : ++(_bd))
total: 0 errors, 0 warnings, 1 checks, 692 lines checked
$ ./scripts/checkpatch.pl -f drivers/qe/uec_phy.h total: 0 errors, 0 warnings, 0 checks, 214 lines checked $ ./scripts/checkpatch.pl -f drivers/qe/uccf.c total: 0 errors, 0 warnings, 0 checks, 507 lines checked $ ./scripts/checkpatch.pl -f drivers/qe/uec.c total: 0 errors, 0 warnings, 0 checks, 1434 lines checked $ ./scripts/checkpatch.pl -f drivers/qe/uec_phy.c total: 0 errors, 0 warnings, 0 checks, 927 lines checked
$ ./scripts/checkpatch.pl -f drivers/qe/qe.c CHECK: Lines should not end with a '(' +U_BOOT_CMD(
total: 0 errors, 0 warnings, 1 checks, 830 lines checked
Signed-off-by: Heiko Schocher hs@denx.de ---
Changes in v2: None
arch/powerpc/cpu/mpc83xx/qe_io.c | 63 ++-- drivers/qe/qe.c | 96 ++--- drivers/qe/uccf.c | 447 ++++++++++++++--------- drivers/qe/uccf.h | 90 ++--- drivers/qe/uec.c | 596 ++++++++++++++++--------------- drivers/qe/uec.h | 381 +++++++++----------- drivers/qe/uec_phy.c | 331 +++++++++-------- drivers/qe/uec_phy.h | 71 ++-- 8 files changed, 1073 insertions(+), 1002 deletions(-)
diff --git a/arch/powerpc/cpu/mpc83xx/qe_io.c b/arch/powerpc/cpu/mpc83xx/qe_io.c index 88aa689551..1079ae128a 100644 --- a/arch/powerpc/cpu/mpc83xx/qe_io.c +++ b/arch/powerpc/cpu/mpc83xx/qe_io.c @@ -14,55 +14,58 @@ #define NUM_OF_PINS 32 void qe_config_iopin(u8 port, u8 pin, int dir, int open_drain, int assign) { - u32 pin_2bit_mask; - u32 pin_2bit_dir; - u32 pin_2bit_assign; - u32 pin_1bit_mask; - u32 tmp_val; - volatile immap_t *im = (volatile immap_t *)CONFIG_SYS_IMMR; - volatile qepio83xx_t *par_io = (volatile qepio83xx_t *)&im->qepio; + u32 2bit_mask; + u32 2bit_dir; + u32 2bit_assign; + u32 1bit_mask; + u32 tmp_val; + immap_t *im; + qepio83xx_t *par_io; + int offset; + + im = (immap_t *)CONFIG_SYS_IMMR; + par_io = (qepio83xx_t *)&im->qepio; + offset = (NUM_OF_PINS - (pin % (NUM_OF_PINS / 2) + 1) * 2);
/* Calculate pin location and 2bit mask and dir */ - pin_2bit_mask = (u32)(0x3 << (NUM_OF_PINS-(pin%(NUM_OF_PINS/2)+1)*2)); - pin_2bit_dir = (u32)(dir << (NUM_OF_PINS-(pin%(NUM_OF_PINS/2)+1)*2)); + 2bit_mask = (u32)(0x3 << offset); + 2bit_dir = (u32)(dir << offset);
/* Setup the direction */ - tmp_val = (pin > (NUM_OF_PINS/2) - 1) ? \ + tmp_val = (pin > (NUM_OF_PINS / 2) - 1) ? in_be32(&par_io->ioport[port].dir2) : in_be32(&par_io->ioport[port].dir1);
- if (pin > (NUM_OF_PINS/2) -1) { - out_be32(&par_io->ioport[port].dir2, ~pin_2bit_mask & tmp_val); - out_be32(&par_io->ioport[port].dir2, pin_2bit_dir | tmp_val); + if (pin > (NUM_OF_PINS / 2) - 1) { + out_be32(&par_io->ioport[port].dir2, ~2bit_mask & tmp_val); + out_be32(&par_io->ioport[port].dir2, 2bit_dir | tmp_val); } else { - out_be32(&par_io->ioport[port].dir1, ~pin_2bit_mask & tmp_val); - out_be32(&par_io->ioport[port].dir1, pin_2bit_dir | tmp_val); + out_be32(&par_io->ioport[port].dir1, ~2bit_mask & tmp_val); + out_be32(&par_io->ioport[port].dir1, 2bit_dir | tmp_val); }
/* Calculate pin location for 1bit mask */ - pin_1bit_mask = (u32)(1 << (NUM_OF_PINS - (pin+1))); + 1bit_mask = (u32)(1 << (NUM_OF_PINS - (pin + 1)));
/* Setup the open drain */ tmp_val = in_be32(&par_io->ioport[port].podr); - if (open_drain) { - out_be32(&par_io->ioport[port].podr, pin_1bit_mask | tmp_val); - } else { - out_be32(&par_io->ioport[port].podr, ~pin_1bit_mask & tmp_val); - } + if (open_drain) + out_be32(&par_io->ioport[port].podr, 1bit_mask | tmp_val); + else + out_be32(&par_io->ioport[port].podr, ~1bit_mask & tmp_val);
/* Setup the assignment */ - tmp_val = (pin > (NUM_OF_PINS/2) - 1) ? - in_be32(&par_io->ioport[port].ppar2): + tmp_val = (pin > (NUM_OF_PINS / 2) - 1) ? + in_be32(&par_io->ioport[port].ppar2) : in_be32(&par_io->ioport[port].ppar1); - pin_2bit_assign = (u32)(assign - << (NUM_OF_PINS - (pin%(NUM_OF_PINS/2)+1)*2)); + 2bit_assign = (u32)(assign << offset);
/* Clear and set 2 bits mask */ - if (pin > (NUM_OF_PINS/2) - 1) { - out_be32(&par_io->ioport[port].ppar2, ~pin_2bit_mask & tmp_val); - out_be32(&par_io->ioport[port].ppar2, pin_2bit_assign | tmp_val); + if (pin > (NUM_OF_PINS / 2) - 1) { + out_be32(&par_io->ioport[port].ppar2, ~2bit_mask & tmp_val); + out_be32(&par_io->ioport[port].ppar2, 2bit_assign | tmp_val); } else { - out_be32(&par_io->ioport[port].ppar1, ~pin_2bit_mask & tmp_val); - out_be32(&par_io->ioport[port].ppar1, pin_2bit_assign | tmp_val); + out_be32(&par_io->ioport[port].ppar1, ~2bit_mask & tmp_val); + out_be32(&par_io->ioport[port].ppar1, 2bit_assign | tmp_val); } } diff --git a/drivers/qe/qe.c b/drivers/qe/qe.c index 61ca4760c8..1a829b5a4c 100644 --- a/drivers/qe/qe.c +++ b/drivers/qe/qe.c @@ -26,7 +26,7 @@
#define MPC85xx_DEVDISR_QE_DISABLE 0x1
-qe_map_t *qe_immr = NULL; +qe_map_t *qe_immr; #ifdef CONFIG_QE static qe_snum_t snums[QE_NUM_OF_SNUM]; #endif @@ -38,18 +38,16 @@ void qe_issue_cmd(uint cmd, uint sbc, u8 mcn, u32 cmd_data) u32 cecr;
if (cmd == QE_RESET) { - out_be32(&qe_immr->cp.cecr,(u32) (cmd | QE_CR_FLG)); + out_be32(&qe_immr->cp.cecr, (u32)(cmd | QE_CR_FLG)); } else { out_be32(&qe_immr->cp.cecdr, cmd_data); out_be32(&qe_immr->cp.cecr, (sbc | QE_CR_FLG | - ((u32) mcn<<QE_CR_PROTOCOL_SHIFT) | cmd)); + ((u32)mcn << QE_CR_PROTOCOL_SHIFT) | cmd)); } /* Wait for the QE_CR_FLG to clear */ do { cecr = in_be32(&qe_immr->cp.cecr); } while (cecr & QE_CR_FLG); - - return; }
#ifdef CONFIG_QE @@ -66,12 +64,13 @@ uint qe_muram_alloc(uint size, uint align) if (off != 0) gd->arch.mp_alloc_base += (align - off);
- if ((off = size & align_mask) != 0) + off = size & align_mask; + if (off != 0) size += (align - off);
if ((gd->arch.mp_alloc_base + size) >= gd->arch.mp_alloc_top) { gd->arch.mp_alloc_base = savebase; - printf("%s: ran out of ram.\n", __FUNCTION__); + printf("%s: ran out of ram.\n", __func__); }
retloc = gd->arch.mp_alloc_base; @@ -93,10 +92,10 @@ void *qe_muram_addr(uint offset) #ifdef CONFIG_QE static void qe_sdma_init(void) { - volatile sdma_t *p; - uint sdma_buffer_base; + sdma_t *p; + uint sdma_buffer_base;
- p = (volatile sdma_t *)&qe_immr->sdma; + p = (sdma_t *)&qe_immr->sdma;
/* All of DMA transaction in bus 1 */ out_be32(&p->sdaqr, 0); @@ -212,7 +211,7 @@ void qe_init(uint qe_base) qe_upload_firmware((const void *)CONFIG_SYS_QE_FW_ADDR);
/* enable the microcode in IRAM */ - out_be32(&qe_immr->iram.iready,QE_IRAM_READY); + out_be32(&qe_immr->iram.iready, QE_IRAM_READY); #endif
gd->arch.mp_alloc_base = QE_DATAONLY_BASE; @@ -235,10 +234,12 @@ void u_qe_init(void) void *addr = (void *)CONFIG_SYS_QE_FW_ADDR;
if (src == BOOT_SOURCE_IFC_NOR) - addr = (void *)(CONFIG_SYS_QE_FW_ADDR + CONFIG_SYS_FSL_IFC_BASE); + addr = (void *)(CONFIG_SYS_QE_FW_ADDR + + CONFIG_SYS_FSL_IFC_BASE);
if (src == BOOT_SOURCE_QSPI_NOR) - addr = (void *)(CONFIG_SYS_QE_FW_ADDR + CONFIG_SYS_FSL_QSPI_BASE); + addr = (void *)(CONFIG_SYS_QE_FW_ADDR + + CONFIG_SYS_FSL_QSPI_BASE);
if (src == BOOT_SOURCE_SD_MMC) { int dev = CONFIG_SYS_MMC_ENV_DEV; @@ -320,7 +321,7 @@ void u_qe_resume(void) void qe_reset(void) { qe_issue_cmd(QE_RESET, QE_CR_SUBBLOCK_INVALID, - (u8) QE_CR_PROTOCOL_UNSPECIFIED, 0); + (u8)QE_CR_PROTOCOL_UNSPECIFIED, 0); }
#ifdef CONFIG_QE @@ -329,24 +330,22 @@ void qe_assign_page(uint snum, uint para_ram_base) u32 cecr;
out_be32(&qe_immr->cp.cecdr, para_ram_base); - out_be32(&qe_immr->cp.cecr, ((u32) snum<<QE_CR_ASSIGN_PAGE_SNUM_SHIFT) + out_be32(&qe_immr->cp.cecr, ((u32)snum << QE_CR_ASSIGN_PAGE_SNUM_SHIFT) | QE_CR_FLG | QE_ASSIGN_PAGE);
/* Wait for the QE_CR_FLG to clear */ do { cecr = in_be32(&qe_immr->cp.cecr); - } while (cecr & QE_CR_FLG ); - - return; + } while (cecr & QE_CR_FLG); } #endif
/* * brg: 0~15 as BRG1~BRG16 - rate: baud rate + * rate: baud rate * BRG input clock comes from the BRGCLK (internal clock generated from - the QE clock, it is one-half of the QE clock), If need the clock source - from CLKn pin, we have te change the function. + * the QE clock, it is one-half of the QE clock), If need the clock source + * from CLKn pin, we have te change the function. */
#define BRG_CLK (gd->arch.brg_clk) @@ -354,12 +353,14 @@ void qe_assign_page(uint snum, uint para_ram_base) #ifdef CONFIG_QE int qe_set_brg(uint brg, uint rate) { - volatile uint *bp; - u32 divisor; - int div16 = 0; + uint *bp; + u32 divisor; + u32 val; + int div16 = 0;
if (brg >= QE_NUM_OF_BRGS) return -EINVAL; + bp = (uint *)&qe_immr->brg.brgc1; bp += brg;
@@ -369,33 +370,37 @@ int qe_set_brg(uint brg, uint rate) divisor /= 16; }
- *bp = ((divisor - 1) << QE_BRGC_DIVISOR_SHIFT) | QE_BRGC_ENABLE; - __asm__ __volatile__("sync"); + /* CHECK TODO */ + /* + * was + * *bp = ((divisor - 1) << QE_BRGC_DIVISOR_SHIFT) | QE_BRGC_ENABLE; + * __asm__ __volatile__("sync"); + */
- if (div16) { - *bp |= QE_BRGC_DIV16; - __asm__ __volatile__("sync"); - } + val = ((divisor - 1) << QE_BRGC_DIVISOR_SHIFT) | QE_BRGC_ENABLE; + if (div16) + val |= QE_BRGC_DIV16; + + out_be32(bp, val);
return 0; } #endif
-/* Set ethernet MII clock master -*/ +/* Set ethernet MII clock master */ int qe_set_mii_clk_src(int ucc_num) { u32 cmxgcr;
/* check if the UCC number is in range. */ - if ((ucc_num > UCC_MAX_NUM - 1) || (ucc_num < 0)) { - printf("%s: ucc num not in ranges\n", __FUNCTION__); + if ((ucc_num > UCC_MAX_NUM - 1) || ucc_num < 0) { + printf("%s: ucc num not in ranges\n", __func__); return -EINVAL; }
cmxgcr = in_be32(&qe_immr->qmx.cmxgcr); cmxgcr &= ~QE_CMXGCR_MII_ENET_MNG_MASK; - cmxgcr |= (ucc_num <<QE_CMXGCR_MII_ENET_MNG_SHIFT); + cmxgcr |= (ucc_num << QE_CMXGCR_MII_ENET_MNG_SHIFT); out_be32(&qe_immr->qmx.cmxgcr, cmxgcr);
return 0; @@ -417,7 +422,7 @@ static int qe_firmware_uploaded; * the actual uploading of the microcode. */ static void qe_upload_microcode(const void *base, - const struct qe_microcode *ucode) + const struct qe_microcode *ucode) { const u32 *code = base + be32_to_cpu(ucode->code_offset); unsigned int i; @@ -494,7 +499,7 @@ int qe_upload_firmware(const struct qe_firmware *firmware) }
/* Validate some of the fields */ - if ((firmware->count < 1) || (firmware->count > MAX_QE_RISC)) { + if (firmware->count < 1 || firmware->count > MAX_QE_RISC) { printf("Invalid data\n"); return -EINVAL; } @@ -522,7 +527,7 @@ int qe_upload_firmware(const struct qe_firmware *firmware) * function isn't available unless you turn on JFFS support. */ crc = be32_to_cpu(*(u32 *)((void *)firmware + calc_size)); - if (crc != (crc32(-1, (const void *) firmware, calc_size) ^ -1)) { + if (crc != (crc32(-1, (const void *)firmware, calc_size) ^ -1)) { printf("Firmware CRC is invalid\n"); return -EIO; } @@ -532,12 +537,12 @@ int qe_upload_firmware(const struct qe_firmware *firmware) */ if (!firmware->split) { out_be16(&qe_immr->cp.cercr, - in_be16(&qe_immr->cp.cercr) | QE_CP_CERCR_CIR); + in_be16(&qe_immr->cp.cercr) | QE_CP_CERCR_CIR); }
if (firmware->soc.model) printf("Firmware '%s' for %u V%u.%u\n", - firmware->id, be16_to_cpu(firmware->soc.model), + firmware->id, be16_to_cpu(firmware->soc.model), firmware->soc.major, firmware->soc.minor); else printf("Firmware '%s'\n", firmware->id); @@ -550,7 +555,7 @@ int qe_upload_firmware(const struct qe_firmware *firmware) strncpy(qe_firmware_info.id, (char *)firmware->id, 62); qe_firmware_info.extended_modes = firmware->extended_modes; memcpy(qe_firmware_info.vtraps, firmware->vtraps, - sizeof(firmware->vtraps)); + sizeof(firmware->vtraps)); qe_firmware_uploaded = 1;
/* Loop through each microcode. */ @@ -634,7 +639,7 @@ int u_qe_upload_firmware(const struct qe_firmware *firmware) }
/* Validate some of the fields */ - if ((firmware->count < 1) || (firmware->count > MAX_QE_RISC)) { + if (firmware->count < 1 || firmware->count > MAX_QE_RISC) { printf("Invalid data\n"); return -EINVAL; } @@ -803,7 +808,7 @@ static int qe_cmd(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[])
if (argc > 3) { ulong length = simple_strtoul(argv[3], NULL, 16); - struct qe_firmware *firmware = (void *) addr; + struct qe_firmware *firmware = (void *)addr;
if (length != be32_to_cpu(firmware->header.length)) { printf("Length mismatch\n"); @@ -811,7 +816,7 @@ static int qe_cmd(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) } }
- return qe_upload_firmware((const struct qe_firmware *) addr); + return qe_upload_firmware((const struct qe_firmware *)addr); }
return cmd_usage(cmdtp); @@ -820,7 +825,6 @@ static int qe_cmd(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) U_BOOT_CMD( qe, 4, 0, qe_cmd, "QUICC Engine commands", - "fw <addr> [<length>] - Upload firmware binary at address <addr> to " - "the QE,\n" + "fw <addr> [<length>] - Upload firmware binary at address <addr> to the QE,\n" "\twith optional length <length> verification." ); diff --git a/drivers/qe/uccf.c b/drivers/qe/uccf.c index 9beb5d90ac..306f1ea1db 100644 --- a/drivers/qe/uccf.c +++ b/drivers/qe/uccf.c @@ -14,7 +14,7 @@ #include "uccf.h" #include <fsl_qe.h>
-void ucc_fast_transmit_on_demand(ucc_fast_private_t *uccf) +void ucc_fast_transmit_on_demand(struct ucc_fast_priv *uccf) { out_be16(&uccf->uf_regs->utodr, UCC_FAST_TOD); } @@ -22,170 +22,271 @@ void ucc_fast_transmit_on_demand(ucc_fast_private_t *uccf) u32 ucc_fast_get_qe_cr_subblock(int ucc_num) { switch (ucc_num) { - case 0: return QE_CR_SUBBLOCK_UCCFAST1; - case 1: return QE_CR_SUBBLOCK_UCCFAST2; - case 2: return QE_CR_SUBBLOCK_UCCFAST3; - case 3: return QE_CR_SUBBLOCK_UCCFAST4; - case 4: return QE_CR_SUBBLOCK_UCCFAST5; - case 5: return QE_CR_SUBBLOCK_UCCFAST6; - case 6: return QE_CR_SUBBLOCK_UCCFAST7; - case 7: return QE_CR_SUBBLOCK_UCCFAST8; - default: return QE_CR_SUBBLOCK_INVALID; + case 0: + return QE_CR_SUBBLOCK_UCCFAST1; + case 1: + return QE_CR_SUBBLOCK_UCCFAST2; + case 2: + return QE_CR_SUBBLOCK_UCCFAST3; + case 3: + return QE_CR_SUBBLOCK_UCCFAST4; + case 4: + return QE_CR_SUBBLOCK_UCCFAST5; + case 5: + return QE_CR_SUBBLOCK_UCCFAST6; + case 6: + return QE_CR_SUBBLOCK_UCCFAST7; + case 7: + return QE_CR_SUBBLOCK_UCCFAST8; + default: + return QE_CR_SUBBLOCK_INVALID; } }
-static void ucc_get_cmxucr_reg(int ucc_num, volatile u32 **p_cmxucr, - u8 *reg_num, u8 *shift) +static void ucc_get_cmxucr_reg(int ucc_num, u32 **p_cmxucr, + u8 *reg_num, u8 *shift) { switch (ucc_num) { - case 0: /* UCC1 */ - *p_cmxucr = &(qe_immr->qmx.cmxucr1); - *reg_num = 1; - *shift = 16; - break; - case 2: /* UCC3 */ - *p_cmxucr = &(qe_immr->qmx.cmxucr1); - *reg_num = 1; - *shift = 0; - break; - case 4: /* UCC5 */ - *p_cmxucr = &(qe_immr->qmx.cmxucr2); - *reg_num = 2; - *shift = 16; - break; - case 6: /* UCC7 */ - *p_cmxucr = &(qe_immr->qmx.cmxucr2); - *reg_num = 2; - *shift = 0; - break; - case 1: /* UCC2 */ - *p_cmxucr = &(qe_immr->qmx.cmxucr3); - *reg_num = 3; - *shift = 16; - break; - case 3: /* UCC4 */ - *p_cmxucr = &(qe_immr->qmx.cmxucr3); - *reg_num = 3; - *shift = 0; - break; - case 5: /* UCC6 */ - *p_cmxucr = &(qe_immr->qmx.cmxucr4); - *reg_num = 4; - *shift = 16; - break; - case 7: /* UCC8 */ - *p_cmxucr = &(qe_immr->qmx.cmxucr4); - *reg_num = 4; - *shift = 0; - break; - default: - break; + case 0: /* UCC1 */ + *p_cmxucr = &qe_immr->qmx.cmxucr1; + *reg_num = 1; + *shift = 16; + break; + case 2: /* UCC3 */ + *p_cmxucr = &qe_immr->qmx.cmxucr1; + *reg_num = 1; + *shift = 0; + break; + case 4: /* UCC5 */ + *p_cmxucr = &qe_immr->qmx.cmxucr2; + *reg_num = 2; + *shift = 16; + break; + case 6: /* UCC7 */ + *p_cmxucr = &qe_immr->qmx.cmxucr2; + *reg_num = 2; + *shift = 0; + break; + case 1: /* UCC2 */ + *p_cmxucr = &qe_immr->qmx.cmxucr3; + *reg_num = 3; + *shift = 16; + break; + case 3: /* UCC4 */ + *p_cmxucr = &qe_immr->qmx.cmxucr3; + *reg_num = 3; + *shift = 0; + break; + case 5: /* UCC6 */ + *p_cmxucr = &qe_immr->qmx.cmxucr4; + *reg_num = 4; + *shift = 16; + break; + case 7: /* UCC8 */ + *p_cmxucr = &qe_immr->qmx.cmxucr4; + *reg_num = 4; + *shift = 0; + break; + default: + break; } }
static int ucc_set_clk_src(int ucc_num, qe_clock_e clock, comm_dir_e mode) { - volatile u32 *p_cmxucr = NULL; - u8 reg_num = 0; - u8 shift = 0; - u32 clockBits; - u32 clockMask; - int source = -1; + u32 *p_cmxucr = NULL; + u8 reg_num = 0; + u8 shift = 0; + u32 clk_bits; + u32 clk_mask; + int source = -1;
/* check if the UCC number is in range. */ - if ((ucc_num > UCC_MAX_NUM - 1) || (ucc_num < 0)) + if ((ucc_num > UCC_MAX_NUM - 1) || ucc_num < 0) return -EINVAL;
- if (! ((mode == COMM_DIR_RX) || (mode == COMM_DIR_TX))) { - printf("%s: bad comm mode type passed\n", __FUNCTION__); + if (!(mode == COMM_DIR_RX || mode == COMM_DIR_TX)) { + printf("%s: bad comm mode type passed\n", __func__); return -EINVAL; }
ucc_get_cmxucr_reg(ucc_num, &p_cmxucr, ®_num, &shift);
switch (reg_num) { - case 1: - switch (clock) { - case QE_BRG1: source = 1; break; - case QE_BRG2: source = 2; break; - case QE_BRG7: source = 3; break; - case QE_BRG8: source = 4; break; - case QE_CLK9: source = 5; break; - case QE_CLK10: source = 6; break; - case QE_CLK11: source = 7; break; - case QE_CLK12: source = 8; break; - case QE_CLK15: source = 9; break; - case QE_CLK16: source = 10; break; - default: source = -1; break; - } - break; - case 2: - switch (clock) { - case QE_BRG5: source = 1; break; - case QE_BRG6: source = 2; break; - case QE_BRG7: source = 3; break; - case QE_BRG8: source = 4; break; - case QE_CLK13: source = 5; break; - case QE_CLK14: source = 6; break; - case QE_CLK19: source = 7; break; - case QE_CLK20: source = 8; break; - case QE_CLK15: source = 9; break; - case QE_CLK16: source = 10; break; - default: source = -1; break; - } - break; - case 3: - switch (clock) { - case QE_BRG9: source = 1; break; - case QE_BRG10: source = 2; break; - case QE_BRG15: source = 3; break; - case QE_BRG16: source = 4; break; - case QE_CLK3: source = 5; break; - case QE_CLK4: source = 6; break; - case QE_CLK17: source = 7; break; - case QE_CLK18: source = 8; break; - case QE_CLK7: source = 9; break; - case QE_CLK8: source = 10; break; - case QE_CLK16: source = 11; break; - default: source = -1; break; - } - break; - case 4: - switch (clock) { - case QE_BRG13: source = 1; break; - case QE_BRG14: source = 2; break; - case QE_BRG15: source = 3; break; - case QE_BRG16: source = 4; break; - case QE_CLK5: source = 5; break; - case QE_CLK6: source = 6; break; - case QE_CLK21: source = 7; break; - case QE_CLK22: source = 8; break; - case QE_CLK7: source = 9; break; - case QE_CLK8: source = 10; break; - case QE_CLK16: source = 11; break; - default: source = -1; break; - } + case 1: + switch (clock) { + case QE_BRG1: + source = 1; + break; + case QE_BRG2: + source = 2; + break; + case QE_BRG7: + source = 3; + break; + case QE_BRG8: + source = 4; + break; + case QE_CLK9: + source = 5; + break; + case QE_CLK10: + source = 6; + break; + case QE_CLK11: + source = 7; + break; + case QE_CLK12: + source = 8; + break; + case QE_CLK15: + source = 9; + break; + case QE_CLK16: + source = 10; + break; + default: + source = -1; + break; + } + break; + case 2: + switch (clock) { + case QE_BRG5: + source = 1; + break; + case QE_BRG6: + source = 2; + break; + case QE_BRG7: + source = 3; + break; + case QE_BRG8: + source = 4; + break; + case QE_CLK13: + source = 5; + break; + case QE_CLK14: + source = 6; + break; + case QE_CLK19: + source = 7; + break; + case QE_CLK20: + source = 8; + break; + case QE_CLK15: + source = 9; + break; + case QE_CLK16: + source = 10; break; default: source = -1; break; + } + break; + case 3: + switch (clock) { + case QE_BRG9: + source = 1; + break; + case QE_BRG10: + source = 2; + break; + case QE_BRG15: + source = 3; + break; + case QE_BRG16: + source = 4; + break; + case QE_CLK3: + source = 5; + break; + case QE_CLK4: + source = 6; + break; + case QE_CLK17: + source = 7; + break; + case QE_CLK18: + source = 8; + break; + case QE_CLK7: + source = 9; + break; + case QE_CLK8: + source = 10; + break; + case QE_CLK16: + source = 11; + break; + default: + source = -1; + break; + } + break; + case 4: + switch (clock) { + case QE_BRG13: + source = 1; + break; + case QE_BRG14: + source = 2; + break; + case QE_BRG15: + source = 3; + break; + case QE_BRG16: + source = 4; + break; + case QE_CLK5: + source = 5; + break; + case QE_CLK6: + source = 6; + break; + case QE_CLK21: + source = 7; + break; + case QE_CLK22: + source = 8; + break; + case QE_CLK7: + source = 9; + break; + case QE_CLK8: + source = 10; + break; + case QE_CLK16: + source = 11; + break; + default: + source = -1; + break; + } + break; + default: + source = -1; + break; }
if (source == -1) { - printf("%s: Bad combination of clock and UCC\n", __FUNCTION__); + printf("%s: Bad combination of clock and UCC\n", __func__); return -ENOENT; }
- clockBits = (u32) source; - clockMask = QE_CMXUCR_TX_CLK_SRC_MASK; + clk_bits = (u32)source; + clk_mask = QE_CMXUCR_TX_CLK_SRC_MASK; if (mode == COMM_DIR_RX) { - clockBits <<= 4; /* Rx field is 4 bits to left of Tx field */ - clockMask <<= 4; /* Rx field is 4 bits to left of Tx field */ + clk_bits <<= 4; /* Rx field is 4 bits to left of Tx field */ + clk_mask <<= 4; /* Rx field is 4 bits to left of Tx field */ } - clockBits <<= shift; - clockMask <<= shift; + clk_bits <<= shift; + clk_mask <<= shift;
- out_be32(p_cmxucr, (in_be32(p_cmxucr) & ~clockMask) | clockBits); + out_be32(p_cmxucr, (in_be32(p_cmxucr) & ~clk_mask) | clk_bits);
return 0; } @@ -195,28 +296,45 @@ static uint ucc_get_reg_baseaddr(int ucc_num) uint base = 0;
/* check if the UCC number is in range */ - if ((ucc_num > UCC_MAX_NUM - 1) || (ucc_num < 0)) { - printf("%s: the UCC num not in ranges\n", __FUNCTION__); + if ((ucc_num > UCC_MAX_NUM - 1) || ucc_num < 0) { + printf("%s: the UCC num not in ranges\n", __func__); return 0; }
switch (ucc_num) { - case 0: base = 0x00002000; break; - case 1: base = 0x00003000; break; - case 2: base = 0x00002200; break; - case 3: base = 0x00003200; break; - case 4: base = 0x00002400; break; - case 5: base = 0x00003400; break; - case 6: base = 0x00002600; break; - case 7: base = 0x00003600; break; - default: break; + case 0: + base = 0x00002000; + break; + case 1: + base = 0x00003000; + break; + case 2: + base = 0x00002200; + break; + case 3: + base = 0x00003200; + break; + case 4: + base = 0x00002400; + break; + case 5: + base = 0x00003400; + break; + case 6: + base = 0x00002600; + break; + case 7: + base = 0x00003600; + break; + default: + break; }
base = (uint)qe_immr + base; return base; }
-void ucc_fast_enable(ucc_fast_private_t *uccf, comm_dir_e mode) +void ucc_fast_enable(struct ucc_fast_priv *uccf, comm_dir_e mode) { ucc_fast_t *uf_regs; u32 gumr; @@ -236,7 +354,7 @@ void ucc_fast_enable(ucc_fast_private_t *uccf, comm_dir_e mode) out_be32(&uf_regs->gumr, gumr); }
-void ucc_fast_disable(ucc_fast_private_t *uccf, comm_dir_e mode) +void ucc_fast_disable(struct ucc_fast_priv *uccf, comm_dir_e mode) { ucc_fast_t *uf_regs; u32 gumr; @@ -256,34 +374,35 @@ void ucc_fast_disable(ucc_fast_private_t *uccf, comm_dir_e mode) out_be32(&uf_regs->gumr, gumr); }
-int ucc_fast_init(ucc_fast_info_t *uf_info, ucc_fast_private_t **uccf_ret) +int ucc_fast_init(struct ucc_fast_inf *uf_info, + struct ucc_fast_priv **uccf_ret) { - ucc_fast_private_t *uccf; + struct ucc_fast_priv *uccf; ucc_fast_t *uf_regs;
if (!uf_info) return -EINVAL;
- if ((uf_info->ucc_num < 0) || (uf_info->ucc_num > UCC_MAX_NUM - 1)) { - printf("%s: Illagal UCC number!\n", __FUNCTION__); + if (uf_info->ucc_num < 0 || (uf_info->ucc_num > UCC_MAX_NUM - 1)) { + printf("%s: Illagal UCC number!\n", __func__); return -EINVAL; }
- uccf = (ucc_fast_private_t *)malloc(sizeof(ucc_fast_private_t)); + uccf = (struct ucc_fast_priv *)malloc(sizeof(struct ucc_fast_priv)); if (!uccf) { printf("%s: No memory for UCC fast data structure!\n", - __FUNCTION__); + __func__); return -ENOMEM; } - memset(uccf, 0, sizeof(ucc_fast_private_t)); + memset(uccf, 0, sizeof(struct ucc_fast_priv));
/* Save fast UCC structure */ uccf->uf_info = uf_info; uccf->uf_regs = (ucc_fast_t *)ucc_get_reg_baseaddr(uf_info->ucc_num);
- if (uccf->uf_regs == NULL) { + if (!uccf->uf_regs) { printf("%s: No memory map for UCC fast controller!\n", - __FUNCTION__); + __func__); return -ENOMEM; }
@@ -291,8 +410,8 @@ int ucc_fast_init(ucc_fast_info_t *uf_info, ucc_fast_private_t **uccf_ret) uccf->enabled_rx = 0;
uf_regs = uccf->uf_regs; - uccf->p_ucce = (u32 *) &(uf_regs->ucce); - uccf->p_uccm = (u32 *) &(uf_regs->uccm); + uccf->p_ucce = (u32 *)&uf_regs->ucce; + uccf->p_uccm = (u32 *)&uf_regs->uccm;
/* Init GUEMR register, UCC both Rx and Tx is Fast protocol */ out_8(&uf_regs->guemr, UCC_GUEMR_SET_RESERVED3 | UCC_GUEMR_MODE_FAST_RX @@ -306,13 +425,13 @@ int ucc_fast_init(ucc_fast_info_t *uf_info, ucc_fast_private_t **uccf_ret) /* Allocate memory for Tx Virtual Fifo */ uccf->ucc_fast_tx_virtual_fifo_base_offset = qe_muram_alloc(UCC_GETH_UTFS_GIGA_INIT, - UCC_FAST_VIRT_FIFO_REGS_ALIGNMENT); + UCC_FAST_VIRT_FIFO_REGS_ALIGNMENT);
/* Allocate memory for Rx Virtual Fifo */ uccf->ucc_fast_rx_virtual_fifo_base_offset = qe_muram_alloc(UCC_GETH_URFS_GIGA_INIT + - UCC_FAST_RX_VIRTUAL_FIFO_SIZE_PAD, - UCC_FAST_VIRT_FIFO_REGS_ALIGNMENT); + UCC_FAST_RX_VIRTUAL_FIFO_SIZE_PAD, + UCC_FAST_VIRT_FIFO_REGS_ALIGNMENT);
/* utfb, urfb are offsets from MURAM base */ out_be32(&uf_regs->utfb, @@ -334,7 +453,7 @@ int ucc_fast_init(ucc_fast_info_t *uf_info, ucc_fast_private_t **uccf_ret) /* Allocate memory for Tx Virtual Fifo */ uccf->ucc_fast_tx_virtual_fifo_base_offset = qe_muram_alloc(UCC_GETH_UTFS_INIT, - UCC_FAST_VIRT_FIFO_REGS_ALIGNMENT); + UCC_FAST_VIRT_FIFO_REGS_ALIGNMENT);
/* Allocate memory for Rx Virtual Fifo */ uccf->ucc_fast_rx_virtual_fifo_base_offset = @@ -360,9 +479,9 @@ int ucc_fast_init(ucc_fast_info_t *uf_info, ucc_fast_private_t **uccf_ret) /* Rx clock routing */ if (uf_info->rx_clock != QE_CLK_NONE) { if (ucc_set_clk_src(uf_info->ucc_num, - uf_info->rx_clock, COMM_DIR_RX)) { + uf_info->rx_clock, COMM_DIR_RX)) { printf("%s: Illegal value for parameter 'RxClock'.\n", - __FUNCTION__); + __func__); return -EINVAL; } } @@ -370,9 +489,9 @@ int ucc_fast_init(ucc_fast_info_t *uf_info, ucc_fast_private_t **uccf_ret) /* Tx clock routing */ if (uf_info->tx_clock != QE_CLK_NONE) { if (ucc_set_clk_src(uf_info->ucc_num, - uf_info->tx_clock, COMM_DIR_TX)) { + uf_info->tx_clock, COMM_DIR_TX)) { printf("%s: Illegal value for parameter 'TxClock'.\n", - __FUNCTION__); + __func__); return -EINVAL; } } diff --git a/drivers/qe/uccf.h b/drivers/qe/uccf.h index 4098c66317..99f8458edf 100644 --- a/drivers/qe/uccf.h +++ b/drivers/qe/uccf.h @@ -13,25 +13,23 @@ #include "linux/immap_qe.h" #include <fsl_qe.h>
-/* Fast or Giga ethernet -*/ -typedef enum enet_type { +/* Fast or Giga ethernet */ +enum enet_type { FAST_ETH, GIGA_ETH, -} enet_type_e; +};
-/* General UCC Extended Mode Register -*/ +/* General UCC Extended Mode Register */ #define UCC_GUEMR_MODE_MASK_RX 0x02 #define UCC_GUEMR_MODE_MASK_TX 0x01 #define UCC_GUEMR_MODE_FAST_RX 0x02 #define UCC_GUEMR_MODE_FAST_TX 0x01 #define UCC_GUEMR_MODE_SLOW_RX 0x00 #define UCC_GUEMR_MODE_SLOW_TX 0x00 -#define UCC_GUEMR_SET_RESERVED3 0x10 /* Bit 3 must be set 1 */ +/* Bit 3 must be set 1 */ +#define UCC_GUEMR_SET_RESERVED3 0x10
-/* General UCC FAST Mode Register -*/ +/* General UCC FAST Mode Register */ #define UCC_FAST_GUMR_TCI 0x20000000 #define UCC_FAST_GUMR_TRX 0x10000000 #define UCC_FAST_GUMR_TTX 0x08000000 @@ -46,8 +44,7 @@ typedef enum enet_type { #define UCC_FAST_GUMR_ENR 0x00000020 #define UCC_FAST_GUMR_ENT 0x00000010
-/* GUMR [MODE] bit maps -*/ +/* GUMR [MODE] bit maps */ #define UCC_FAST_GUMR_HDLC 0x00000000 #define UCC_FAST_GUMR_QMC 0x00000002 #define UCC_FAST_GUMR_UART 0x00000004 @@ -55,50 +52,54 @@ typedef enum enet_type { #define UCC_FAST_GUMR_ATM 0x0000000a #define UCC_FAST_GUMR_ETH 0x0000000c
-/* Transmit On Demand (UTORD) -*/ +/* Transmit On Demand (UTORD) */ #define UCC_SLOW_TOD 0x8000 #define UCC_FAST_TOD 0x8000
-/* Fast Ethernet (10/100 Mbps) -*/ -#define UCC_GETH_URFS_INIT 512 /* Rx virtual FIFO size */ -#define UCC_GETH_URFET_INIT 256 /* 1/2 urfs */ -#define UCC_GETH_URFSET_INIT 384 /* 3/4 urfs */ -#define UCC_GETH_UTFS_INIT 512 /* Tx virtual FIFO size */ -#define UCC_GETH_UTFET_INIT 256 /* 1/2 utfs */ +/* Fast Ethernet (10/100 Mbps) */ +/* Rx virtual FIFO size */ +#define UCC_GETH_URFS_INIT 512 +/* 1/2 urfs */ +#define UCC_GETH_URFET_INIT 256 +/* 3/4 urfs */ +#define UCC_GETH_URFSET_INIT 384 +/* Tx virtual FIFO size */ +#define UCC_GETH_UTFS_INIT 512 +/* 1/2 utfs */ +#define UCC_GETH_UTFET_INIT 256 #define UCC_GETH_UTFTT_INIT 128
-/* Gigabit Ethernet (1000 Mbps) -*/ -#define UCC_GETH_URFS_GIGA_INIT 4096/*2048*/ /* Rx virtual FIFO size */ -#define UCC_GETH_URFET_GIGA_INIT 2048/*1024*/ /* 1/2 urfs */ -#define UCC_GETH_URFSET_GIGA_INIT 3072/*1536*/ /* 3/4 urfs */ -#define UCC_GETH_UTFS_GIGA_INIT 8192/*2048*/ /* Tx virtual FIFO size */ -#define UCC_GETH_UTFET_GIGA_INIT 4096/*1024*/ /* 1/2 utfs */ -#define UCC_GETH_UTFTT_GIGA_INIT 0x400/*0x40*/ /* */ +/* Gigabit Ethernet (1000 Mbps) */ +/* Rx virtual FIFO size */ +#define UCC_GETH_URFS_GIGA_INIT 4096/*2048*/ +/* 1/2 urfs */ +#define UCC_GETH_URFET_GIGA_INIT 2048/*1024*/ +/* 3/4 urfs */ +#define UCC_GETH_URFSET_GIGA_INIT 3072/*1536*/ +/* Tx virtual FIFO size */ +#define UCC_GETH_UTFS_GIGA_INIT 8192/*2048*/ +/* 1/2 utfs */ +#define UCC_GETH_UTFET_GIGA_INIT 4096/*1024*/ +#define UCC_GETH_UTFTT_GIGA_INIT 0x400/*0x40*/
-/* UCC fast alignment -*/ +/* UCC fast alignment */ #define UCC_FAST_RX_ALIGN 4 #define UCC_FAST_MRBLR_ALIGNMENT 4 #define UCC_FAST_VIRT_FIFO_REGS_ALIGNMENT 8
-/* Sizes -*/ +/* Sizes */ #define UCC_FAST_RX_VIRTUAL_FIFO_SIZE_PAD 8
-/* UCC fast structure. -*/ -typedef struct ucc_fast_info { +/* UCC fast structure. */ +struct ucc_fast_inf { int ucc_num; qe_clock_e rx_clock; qe_clock_e tx_clock; - enet_type_e eth_type; -} ucc_fast_info_t; + enum enet_type eth_type; +};
-typedef struct ucc_fast_private { - ucc_fast_info_t *uf_info; +struct ucc_fast_priv { + struct ucc_fast_inf *uf_info; ucc_fast_t *uf_regs; /* a pointer to memory map of UCC regs */ u32 *p_ucce; /* a pointer to the event register */ u32 *p_uccm; /* a pointer to the mask register */ @@ -106,12 +107,13 @@ typedef struct ucc_fast_private { int enabled_rx; /* whether UCC is enabled for Rx (ENR) */ u32 ucc_fast_tx_virtual_fifo_base_offset; u32 ucc_fast_rx_virtual_fifo_base_offset; -} ucc_fast_private_t; +};
-void ucc_fast_transmit_on_demand(ucc_fast_private_t *uccf); +void ucc_fast_transmit_on_demand(struct ucc_fast_priv *uccf); u32 ucc_fast_get_qe_cr_subblock(int ucc_num); -void ucc_fast_enable(ucc_fast_private_t *uccf, comm_dir_e mode); -void ucc_fast_disable(ucc_fast_private_t *uccf, comm_dir_e mode); -int ucc_fast_init(ucc_fast_info_t *uf_info, ucc_fast_private_t **uccf_ret); +void ucc_fast_enable(struct ucc_fast_priv *uccf, comm_dir_e mode); +void ucc_fast_disable(struct ucc_fast_priv *uccf, comm_dir_e mode); +int ucc_fast_init(struct ucc_fast_inf *uf_info, + struct ucc_fast_priv **uccf_ret);
#endif /* __UCCF_H__ */ diff --git a/drivers/qe/uec.c b/drivers/qe/uec.c index 849f191d6d..1ead28f1dd 100644 --- a/drivers/qe/uec.c +++ b/drivers/qe/uec.c @@ -25,7 +25,7 @@ #define CONFIG_UTBIPAR_INIT_TBIPA 0x1F #endif
-static uec_info_t uec_info[] = { +static struct uec_inf uec_info[] = { #ifdef CONFIG_UEC_ETH1 STD_UEC_INFO(1), /* UEC1 */ #endif @@ -56,13 +56,13 @@ static uec_info_t uec_info[] = {
static struct eth_device *devlist[MAXCONTROLLERS];
-static int uec_mac_enable(uec_private_t *uec, comm_dir_e mode) +static int uec_mac_enable(struct uec_priv *uec, comm_dir_e mode) { uec_t *uec_regs; u32 maccfg1;
if (!uec) { - printf("%s: uec not initial\n", __FUNCTION__); + printf("%s: uec not initial\n", __func__); return -EINVAL; } uec_regs = uec->uec_regs; @@ -84,13 +84,13 @@ static int uec_mac_enable(uec_private_t *uec, comm_dir_e mode) return 0; }
-static int uec_mac_disable(uec_private_t *uec, comm_dir_e mode) +static int uec_mac_disable(struct uec_priv *uec, comm_dir_e mode) { uec_t *uec_regs; u32 maccfg1;
if (!uec) { - printf("%s: uec not initial\n", __FUNCTION__); + printf("%s: uec not initial\n", __func__); return -EINVAL; } uec_regs = uec->uec_regs; @@ -112,14 +112,14 @@ static int uec_mac_disable(uec_private_t *uec, comm_dir_e mode) return 0; }
-static int uec_graceful_stop_tx(uec_private_t *uec) +static int uec_graceful_stop_tx(struct uec_priv *uec) { ucc_fast_t *uf_regs; u32 cecr_subblock; u32 ucce;
if (!uec || !uec->uccf) { - printf("%s: No handle passed.\n", __FUNCTION__); + printf("%s: No handle passed.\n", __func__); return -EINVAL; }
@@ -132,30 +132,30 @@ static int uec_graceful_stop_tx(uec_private_t *uec) cecr_subblock = ucc_fast_get_qe_cr_subblock(uec->uec_info->uf_info.ucc_num); qe_issue_cmd(QE_GRACEFUL_STOP_TX, cecr_subblock, - (u8)QE_CR_PROTOCOL_ETHERNET, 0); + (u8)QE_CR_PROTOCOL_ETHERNET, 0);
/* Wait for command to complete */ do { ucce = in_be32(&uf_regs->ucce); - } while (! (ucce & UCCE_GRA)); + } while (!(ucce & UCCE_GRA));
uec->grace_stopped_tx = 1;
return 0; }
-static int uec_graceful_stop_rx(uec_private_t *uec) +static int uec_graceful_stop_rx(struct uec_priv *uec) { u32 cecr_subblock; u8 ack;
if (!uec) { - printf("%s: No handle passed.\n", __FUNCTION__); + printf("%s: No handle passed.\n", __func__); return -EINVAL; }
if (!uec->p_rx_glbl_pram) { - printf("%s: No init rx global parameter\n", __FUNCTION__); + printf("%s: No init rx global parameter\n", __func__); return -EINVAL; }
@@ -170,66 +170,66 @@ static int uec_graceful_stop_rx(uec_private_t *uec) cecr_subblock = ucc_fast_get_qe_cr_subblock(uec->uec_info->uf_info.ucc_num); qe_issue_cmd(QE_GRACEFUL_STOP_RX, cecr_subblock, - (u8)QE_CR_PROTOCOL_ETHERNET, 0); + (u8)QE_CR_PROTOCOL_ETHERNET, 0); ack = uec->p_rx_glbl_pram->rxgstpack; - } while (! (ack & GRACEFUL_STOP_ACKNOWLEDGE_RX )); + } while (!(ack & GRACEFUL_STOP_ACKNOWLEDGE_RX));
uec->grace_stopped_rx = 1;
return 0; }
-static int uec_restart_tx(uec_private_t *uec) +static int uec_restart_tx(struct uec_priv *uec) { u32 cecr_subblock;
if (!uec || !uec->uec_info) { - printf("%s: No handle passed.\n", __FUNCTION__); + printf("%s: No handle passed.\n", __func__); return -EINVAL; }
cecr_subblock = ucc_fast_get_qe_cr_subblock(uec->uec_info->uf_info.ucc_num); qe_issue_cmd(QE_RESTART_TX, cecr_subblock, - (u8)QE_CR_PROTOCOL_ETHERNET, 0); + (u8)QE_CR_PROTOCOL_ETHERNET, 0);
uec->grace_stopped_tx = 0;
return 0; }
-static int uec_restart_rx(uec_private_t *uec) +static int uec_restart_rx(struct uec_priv *uec) { u32 cecr_subblock;
cecr_subblock = ucc_fast_get_qe_cr_subblock(uec->uec_info->uf_info.ucc_num); qe_issue_cmd(QE_RESTART_RX, cecr_subblock, - (u8)QE_CR_PROTOCOL_ETHERNET, 0); + (u8)QE_CR_PROTOCOL_ETHERNET, 0);
uec->grace_stopped_rx = 0;
return 0; }
-static int uec_open(uec_private_t *uec, comm_dir_e mode) +static int uec_open(struct uec_priv *uec, comm_dir_e mode) { - ucc_fast_private_t *uccf; + struct ucc_fast_priv *uccf;
if (!uec || !uec->uccf) { - printf("%s: No handle passed.\n", __FUNCTION__); + printf("%s: No handle passed.\n", __func__); return -EINVAL; } uccf = uec->uccf;
/* check if the UCC number is in range. */ if (uec->uec_info->uf_info.ucc_num >= UCC_MAX_NUM) { - printf("%s: ucc_num out of range.\n", __FUNCTION__); + printf("%s: ucc_num out of range.\n", __func__); return -EINVAL; }
@@ -240,36 +240,33 @@ static int uec_open(uec_private_t *uec, comm_dir_e mode) ucc_fast_enable(uccf, mode);
/* RISC microcode start */ - if ((mode & COMM_DIR_TX) && uec->grace_stopped_tx) { + if ((mode & COMM_DIR_TX) && uec->grace_stopped_tx) uec_restart_tx(uec); - } - if ((mode & COMM_DIR_RX) && uec->grace_stopped_rx) { + if ((mode & COMM_DIR_RX) && uec->grace_stopped_rx) uec_restart_rx(uec); - }
return 0; }
-static int uec_stop(uec_private_t *uec, comm_dir_e mode) +static int uec_stop(struct uec_priv *uec, comm_dir_e mode) { if (!uec || !uec->uccf) { - printf("%s: No handle passed.\n", __FUNCTION__); + printf("%s: No handle passed.\n", __func__); return -EINVAL; }
/* check if the UCC number is in range. */ if (uec->uec_info->uf_info.ucc_num >= UCC_MAX_NUM) { - printf("%s: ucc_num out of range.\n", __FUNCTION__); + printf("%s: ucc_num out of range.\n", __func__); return -EINVAL; } /* Stop any transmissions */ - if ((mode & COMM_DIR_TX) && !uec->grace_stopped_tx) { + if ((mode & COMM_DIR_TX) && !uec->grace_stopped_tx) uec_graceful_stop_tx(uec); - } + /* Stop any receptions */ - if ((mode & COMM_DIR_RX) && !uec->grace_stopped_rx) { + if ((mode & COMM_DIR_RX) && !uec->grace_stopped_rx) uec_graceful_stop_rx(uec); - }
/* Disable the UCC fast */ ucc_fast_disable(uec->uccf, mode); @@ -280,13 +277,13 @@ static int uec_stop(uec_private_t *uec, comm_dir_e mode) return 0; }
-static int uec_set_mac_duplex(uec_private_t *uec, int duplex) +static int uec_set_mac_duplex(struct uec_priv *uec, int duplex) { uec_t *uec_regs; u32 maccfg2;
if (!uec) { - printf("%s: uec not initial\n", __FUNCTION__); + printf("%s: uec not initial\n", __func__); return -EINVAL; } uec_regs = uec->uec_regs; @@ -306,8 +303,8 @@ static int uec_set_mac_duplex(uec_private_t *uec, int duplex) return 0; }
-static int uec_set_mac_if_mode(uec_private_t *uec, - phy_interface_t if_mode, int speed) +static int uec_set_mac_if_mode(struct uec_priv *uec, + phy_interface_t if_mode, int speed) { phy_interface_t enet_if_mode; uec_t *uec_regs; @@ -315,7 +312,7 @@ static int uec_set_mac_if_mode(uec_private_t *uec, u32 maccfg2;
@@ -329,66 +326,62 @@ static int uec_set_mac_if_mode(uec_private_t *uec, upsmr &= ~(UPSMR_RPM | UPSMR_TBIM | UPSMR_R10M | UPSMR_RMM);
switch (speed) { - case SPEED_10: - maccfg2 |= MACCFG2_INTERFACE_MODE_NIBBLE; - switch (enet_if_mode) { - case PHY_INTERFACE_MODE_MII: - break; - case PHY_INTERFACE_MODE_RGMII: - upsmr |= (UPSMR_RPM | UPSMR_R10M); - break; - case PHY_INTERFACE_MODE_RMII: - upsmr |= (UPSMR_R10M | UPSMR_RMM); - break; - default: - return -EINVAL; - break; - } + case SPEED_10: + maccfg2 |= MACCFG2_INTERFACE_MODE_NIBBLE; + switch (enet_if_mode) { + case PHY_INTERFACE_MODE_MII: break; - case SPEED_100: - maccfg2 |= MACCFG2_INTERFACE_MODE_NIBBLE; - switch (enet_if_mode) { - case PHY_INTERFACE_MODE_MII: - break; - case PHY_INTERFACE_MODE_RGMII: - upsmr |= UPSMR_RPM; - break; - case PHY_INTERFACE_MODE_RMII: - upsmr |= UPSMR_RMM; - break; - default: - return -EINVAL; - break; - } + case PHY_INTERFACE_MODE_RGMII: + upsmr |= (UPSMR_RPM | UPSMR_R10M); break; - case SPEED_1000: - maccfg2 |= MACCFG2_INTERFACE_MODE_BYTE; - switch (enet_if_mode) { - case PHY_INTERFACE_MODE_GMII: - break; - case PHY_INTERFACE_MODE_TBI: - upsmr |= UPSMR_TBIM; - break; - case PHY_INTERFACE_MODE_RTBI: - upsmr |= (UPSMR_RPM | UPSMR_TBIM); - break; - case PHY_INTERFACE_MODE_RGMII_RXID: - case PHY_INTERFACE_MODE_RGMII_TXID: - case PHY_INTERFACE_MODE_RGMII_ID: - case PHY_INTERFACE_MODE_RGMII: - upsmr |= UPSMR_RPM; - break; - case PHY_INTERFACE_MODE_SGMII: - upsmr |= UPSMR_SGMM; - break; - default: - return -EINVAL; - break; - } + case PHY_INTERFACE_MODE_RMII: + upsmr |= (UPSMR_R10M | UPSMR_RMM); break; default: return -EINVAL; + } + break; + case SPEED_100: + maccfg2 |= MACCFG2_INTERFACE_MODE_NIBBLE; + switch (enet_if_mode) { + case PHY_INTERFACE_MODE_MII: + break; + case PHY_INTERFACE_MODE_RGMII: + upsmr |= UPSMR_RPM; + break; + case PHY_INTERFACE_MODE_RMII: + upsmr |= UPSMR_RMM; + break; + default: + return -EINVAL; + } + break; + case SPEED_1000: + maccfg2 |= MACCFG2_INTERFACE_MODE_BYTE; + switch (enet_if_mode) { + case PHY_INTERFACE_MODE_GMII: + break; + case PHY_INTERFACE_MODE_TBI: + upsmr |= UPSMR_TBIM; + break; + case PHY_INTERFACE_MODE_RTBI: + upsmr |= (UPSMR_RPM | UPSMR_TBIM); + break; + case PHY_INTERFACE_MODE_RGMII_RXID: + case PHY_INTERFACE_MODE_RGMII_TXID: + case PHY_INTERFACE_MODE_RGMII_ID: + case PHY_INTERFACE_MODE_RGMII: + upsmr |= UPSMR_RPM; break; + case PHY_INTERFACE_MODE_SGMII: + upsmr |= UPSMR_SGMM; + break; + default: + return -EINVAL; + } + break; + default: + return -EINVAL; }
out_be32(&uec_regs->maccfg2, maccfg2); @@ -407,9 +400,10 @@ static int init_mii_management_configuration(uec_mii_t *uec_mii_regs) out_be32(&uec_mii_regs->miimcfg, miimcfg);
/* Wait until the bus is free */ - while ((in_be32(&uec_mii_regs->miimcfg) & MIIMIND_BUSY) && timeout--); + while ((in_be32(&uec_mii_regs->miimcfg) & MIIMIND_BUSY) && timeout--) + ; if (timeout <= 0) { - printf("%s: The MII Bus is stuck!", __FUNCTION__); + printf("%s: The MII Bus is stuck!", __func__); return -ETIMEDOUT; }
@@ -418,13 +412,13 @@ static int init_mii_management_configuration(uec_mii_t *uec_mii_regs)
static int init_phy(struct eth_device *dev) { - uec_private_t *uec; + struct uec_priv *uec; uec_mii_t *umii_regs; struct uec_mii_info *mii_info; struct phy_info *curphy; int err;
- uec = (uec_private_t *)dev->priv; + uec = (struct uec_priv *)dev->priv; umii_regs = uec->uec_mii_regs;
uec->oldlink = 0; @@ -438,11 +432,10 @@ static int init_phy(struct eth_device *dev) } memset(mii_info, 0, sizeof(*mii_info));
- if (uec->uec_info->uf_info.eth_type == GIGA_ETH) { + if (uec->uec_info->uf_info.eth_type == GIGA_ETH) mii_info->speed = SPEED_1000; - } else { + else mii_info->speed = SPEED_100; - }
mii_info->duplex = DUPLEX_FULL; mii_info->pause = 0; @@ -498,15 +491,14 @@ bus_fail:
static void adjust_link(struct eth_device *dev) { - uec_private_t *uec = (uec_private_t *)dev->priv; + struct uec_priv *uec = (struct uec_priv *)dev->priv; struct uec_mii_info *mii_info = uec->mii_info;
- extern void change_phy_interface_mode(struct eth_device *dev, - phy_interface_t mode, int speed); - if (mii_info->link) { - /* Now we make sure that we can be in full duplex mode. - * If not, we operate in half-duplex mode. */ + /* + * Now we make sure that we can be in full duplex mode. + * If not, we operate in half-duplex mode. + */ if (mii_info->duplex != uec->oldduplex) { if (!(mii_info->duplex)) { uec_set_mac_duplex(uec, DUPLEX_HALF); @@ -526,16 +518,16 @@ static void adjust_link(struct eth_device *dev) case SPEED_1000: break; case SPEED_100: - printf ("switching to rgmii 100\n"); + printf("switching to rgmii 100\n"); mode = PHY_INTERFACE_MODE_RGMII; break; case SPEED_10: - printf ("switching to rgmii 10\n"); + printf("switching to rgmii 10\n"); mode = PHY_INTERFACE_MODE_RGMII; break; default: printf("%s: Ack,Speed(%d)is illegal\n", - dev->name, mii_info->speed); + dev->name, mii_info->speed); break; } } @@ -566,12 +558,12 @@ static void adjust_link(struct eth_device *dev)
static void phy_change(struct eth_device *dev) { - uec_private_t *uec = (uec_private_t *)dev->priv; + struct uec_priv *uec = (struct uec_priv *)dev->priv;
#if defined(CONFIG_ARCH_P1021) || defined(CONFIG_ARCH_P1025) ccsr_gur_t *gur = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR);
- /* QE9 and QE12 need to be set for enabling QE MII managment signals */ + /* QE9 and QE12 need to be set for enabling QE MII management signals */ setbits_be32(&gur->pmuxcr, MPC85xx_PMUXCR_QE9); setbits_be32(&gur->pmuxcr, MPC85xx_PMUXCR_QE12); #endif @@ -604,14 +596,14 @@ static int uec_miiphy_find_dev_by_name(const char *devname) int i;
for (i = 0; i < MAXCONTROLLERS; i++) { - if (strncmp(devname, devlist[i]->name, strlen(devname)) == 0) { + if (strncmp(devname, devlist[i]->name, strlen(devname)) == 0) break; - } }
/* If device cannot be found, returns -1 */ if (i == MAXCONTROLLERS) { - debug ("%s: device %s not found in devlist\n", __FUNCTION__, devname); + debug("%s: device %s not found in devlist\n", __func__, + devname); i = -1; }
@@ -629,13 +621,12 @@ static int uec_miiphy_read(struct mii_dev *bus, int addr, int devad, int reg) unsigned short value = 0; int devindex = 0;
- if (bus->name == NULL) { - debug("%s: NULL pointer given\n", __FUNCTION__); + if (!bus->name) { + debug("%s: NULL pointer given\n", __func__); } else { devindex = uec_miiphy_find_dev_by_name(bus->name); - if (devindex >= 0) { + if (devindex >= 0) value = uec_read_phy_reg(devlist[devindex], addr, reg); - } } return value; } @@ -651,36 +642,37 @@ static int uec_miiphy_write(struct mii_dev *bus, int addr, int devad, int reg, { int devindex = 0;
- if (bus->name == NULL) { - debug("%s: NULL pointer given\n", __FUNCTION__); + if (!bus->name) { + debug("%s: NULL pointer given\n", __func__); } else { devindex = uec_miiphy_find_dev_by_name(bus->name); - if (devindex >= 0) { + if (devindex >= 0) uec_write_phy_reg(devlist[devindex], addr, reg, value); - } } return 0; } #endif
-static int uec_set_mac_address(uec_private_t *uec, u8 *mac_addr) +static int uec_set_mac_address(struct uec_priv *uec, u8 *mac_addr) { uec_t *uec_regs; u32 mac_addr1; u32 mac_addr2;
- /* if a station address of 0x12345678ABCD, perform a write to - MACSTNADDR1 of 0xCDAB7856, - MACSTNADDR2 of 0x34120000 */ + /* + * if a station address of 0x12345678ABCD, perform a write to + * MACSTNADDR1 of 0xCDAB7856, + * MACSTNADDR2 of 0x34120000 + */
- mac_addr1 = (mac_addr[5] << 24) | (mac_addr[4] << 16) | \ + mac_addr1 = (mac_addr[5] << 24) | (mac_addr[4] << 16) | (mac_addr[3] << 8) | (mac_addr[2]); out_be32(&uec_regs->macstnaddr1, mac_addr1);
@@ -690,31 +682,31 @@ static int uec_set_mac_address(uec_private_t *uec, u8 *mac_addr) return 0; }
-static int uec_convert_threads_num(uec_num_of_threads_e threads_num, - int *threads_num_ret) +static int uec_convert_threads_num(enum uec_num_of_threads threads_num, + int *threads_num_ret) { int num_threads_numerica;
switch (threads_num) { - case UEC_NUM_OF_THREADS_1: - num_threads_numerica = 1; - break; - case UEC_NUM_OF_THREADS_2: - num_threads_numerica = 2; - break; - case UEC_NUM_OF_THREADS_4: - num_threads_numerica = 4; - break; - case UEC_NUM_OF_THREADS_6: - num_threads_numerica = 6; - break; - case UEC_NUM_OF_THREADS_8: - num_threads_numerica = 8; - break; - default: - printf("%s: Bad number of threads value.", - __FUNCTION__); - return -EINVAL; + case UEC_NUM_OF_THREADS_1: + num_threads_numerica = 1; + break; + case UEC_NUM_OF_THREADS_2: + num_threads_numerica = 2; + break; + case UEC_NUM_OF_THREADS_4: + num_threads_numerica = 4; + break; + case UEC_NUM_OF_THREADS_6: + num_threads_numerica = 6; + break; + case UEC_NUM_OF_THREADS_8: + num_threads_numerica = 8; + break; + default: + printf("%s: Bad number of threads value.", + __func__); + return -EINVAL; }
*threads_num_ret = num_threads_numerica; @@ -722,9 +714,9 @@ static int uec_convert_threads_num(uec_num_of_threads_e threads_num, return 0; }
-static void uec_init_tx_parameter(uec_private_t *uec, int num_threads_tx) +static void uec_init_tx_parameter(struct uec_priv *uec, int num_threads_tx) { - uec_info_t *uec_info; + struct uec_inf *uec_info; u32 end_bd; u8 bmrx = 0; int i; @@ -732,14 +724,14 @@ static void uec_init_tx_parameter(uec_private_t *uec, int num_threads_tx) uec_info = uec->uec_info;
/* Alloc global Tx parameter RAM page */ - uec->tx_glbl_pram_offset = qe_muram_alloc( - sizeof(uec_tx_global_pram_t), - UEC_TX_GLOBAL_PRAM_ALIGNMENT); - uec->p_tx_glbl_pram = (uec_tx_global_pram_t *) + uec->tx_glbl_pram_offset = + qe_muram_alloc(sizeof(struct uec_tx_global_pram), + UEC_TX_GLOBAL_PRAM_ALIGNMENT); + uec->p_tx_glbl_pram = (struct uec_tx_global_pram *) qe_muram_addr(uec->tx_glbl_pram_offset);
/* Zero the global Tx prameter RAM */ - memset(uec->p_tx_glbl_pram, 0, sizeof(uec_tx_global_pram_t)); + memset(uec->p_tx_glbl_pram, 0, sizeof(struct uec_tx_global_pram));
/* Init global Tx parameter RAM */
@@ -747,10 +739,10 @@ static void uec_init_tx_parameter(uec_private_t *uec, int num_threads_tx) out_be16(&uec->p_tx_glbl_pram->temoder, TEMODER_INIT_VALUE);
/* SQPTR */ - uec->send_q_mem_reg_offset = qe_muram_alloc( - sizeof(uec_send_queue_qd_t), - UEC_SEND_QUEUE_QUEUE_DESCRIPTOR_ALIGNMENT); - uec->p_send_q_mem_reg = (uec_send_queue_mem_region_t *) + uec->send_q_mem_reg_offset = + qe_muram_alloc(sizeof(struct uec_send_queue_qd), + UEC_SEND_QUEUE_QUEUE_DESCRIPTOR_ALIGNMENT); + uec->p_send_q_mem_reg = (struct uec_send_queue_mem_region *) qe_muram_addr(uec->send_q_mem_reg_offset); out_be32(&uec->p_tx_glbl_pram->sqptr, uec->send_q_mem_reg_offset);
@@ -758,9 +750,9 @@ static void uec_init_tx_parameter(uec_private_t *uec, int num_threads_tx) end_bd = (u32)uec->p_tx_bd_ring + (uec_info->tx_bd_ring_len - 1) * SIZEOFBD; out_be32(&uec->p_send_q_mem_reg->sqqd[0].bd_ring_base, - (u32)(uec->p_tx_bd_ring)); + (u32)(uec->p_tx_bd_ring)); out_be32(&uec->p_send_q_mem_reg->sqqd[0].last_bd_completed_address, - end_bd); + end_bd);
/* Scheduler Base Pointer, we have only one Tx queue, no need it */ out_be32(&uec->p_tx_glbl_pram->schedulerbasepointer, 0); @@ -773,54 +765,57 @@ static void uec_init_tx_parameter(uec_private_t *uec, int num_threads_tx) out_be32(&uec->p_tx_glbl_pram->tstate, ((u32)(bmrx) << BMR_SHIFT));
/* IPH_Offset */ - for (i = 0; i < MAX_IPH_OFFSET_ENTRY; i++) { + for (i = 0; i < MAX_IPH_OFFSET_ENTRY; i++) out_8(&uec->p_tx_glbl_pram->iphoffset[i], 0); - }
/* VTAG table */ - for (i = 0; i < UEC_TX_VTAG_TABLE_ENTRY_MAX; i++) { + for (i = 0; i < UEC_TX_VTAG_TABLE_ENTRY_MAX; i++) out_be32(&uec->p_tx_glbl_pram->vtagtable[i], 0); - }
/* TQPTR */ - uec->thread_dat_tx_offset = qe_muram_alloc( - num_threads_tx * sizeof(uec_thread_data_tx_t) + - 32 *(num_threads_tx == 1), UEC_THREAD_DATA_ALIGNMENT); + uec->thread_dat_tx_offset = + qe_muram_alloc(num_threads_tx * + sizeof(struct uec_thread_data_tx) + + 32 * (num_threads_tx == 1), + UEC_THREAD_DATA_ALIGNMENT);
- uec->p_thread_data_tx = (uec_thread_data_tx_t *) + uec->p_thread_data_tx = (struct uec_thread_data_tx *) qe_muram_addr(uec->thread_dat_tx_offset); out_be32(&uec->p_tx_glbl_pram->tqptr, uec->thread_dat_tx_offset); }
-static void uec_init_rx_parameter(uec_private_t *uec, int num_threads_rx) +static void uec_init_rx_parameter(struct uec_priv *uec, int num_threads_rx) { u8 bmrx = 0; int i; - uec_82xx_address_filtering_pram_t *p_af_pram; + struct uec_82xx_add_filtering_pram *p_af_pram;
/* Allocate global Rx parameter RAM page */ - uec->rx_glbl_pram_offset = qe_muram_alloc( - sizeof(uec_rx_global_pram_t), UEC_RX_GLOBAL_PRAM_ALIGNMENT); - uec->p_rx_glbl_pram = (uec_rx_global_pram_t *) + uec->rx_glbl_pram_offset = + qe_muram_alloc(sizeof(struct uec_rx_global_pram), + UEC_RX_GLOBAL_PRAM_ALIGNMENT); + uec->p_rx_glbl_pram = (struct uec_rx_global_pram *) qe_muram_addr(uec->rx_glbl_pram_offset);
/* Zero Global Rx parameter RAM */ - memset(uec->p_rx_glbl_pram, 0, sizeof(uec_rx_global_pram_t)); + memset(uec->p_rx_glbl_pram, 0, sizeof(struct uec_rx_global_pram));
/* Init global Rx parameter RAM */ - /* REMODER, Extended feature mode disable, VLAN disable, - LossLess flow control disable, Receive firmware statisic disable, - Extended address parsing mode disable, One Rx queues, - Dynamic maximum/minimum frame length disable, IP checksum check - disable, IP address alignment disable - */ + /* + * REMODER, Extended feature mode disable, VLAN disable, + * LossLess flow control disable, Receive firmware statisic disable, + * Extended address parsing mode disable, One Rx queues, + * Dynamic maximum/minimum frame length disable, IP checksum check + * disable, IP address alignment disable + */ out_be32(&uec->p_rx_glbl_pram->remoder, REMODER_INIT_VALUE);
/* RQPTR */ - uec->thread_dat_rx_offset = qe_muram_alloc( - num_threads_rx * sizeof(uec_thread_data_rx_t), - UEC_THREAD_DATA_ALIGNMENT); - uec->p_thread_data_rx = (uec_thread_data_rx_t *) + uec->thread_dat_rx_offset = + qe_muram_alloc(num_threads_rx * + sizeof(struct uec_thread_data_rx), + UEC_THREAD_DATA_ALIGNMENT); + uec->p_thread_data_rx = (struct uec_thread_data_rx *) qe_muram_addr(uec->thread_dat_rx_offset); out_be32(&uec->p_rx_glbl_pram->rqptr, uec->thread_dat_rx_offset);
@@ -841,16 +836,16 @@ static void uec_init_rx_parameter(uec_private_t *uec, int num_threads_rx) out_be16(&uec->p_rx_glbl_pram->mrblr, MAX_RXBUF_LEN);
/* RBDQPTR */ - uec->rx_bd_qs_tbl_offset = qe_muram_alloc( - sizeof(uec_rx_bd_queues_entry_t) + \ - sizeof(uec_rx_prefetched_bds_t), - UEC_RX_BD_QUEUES_ALIGNMENT); - uec->p_rx_bd_qs_tbl = (uec_rx_bd_queues_entry_t *) + uec->rx_bd_qs_tbl_offset = + qe_muram_alloc(sizeof(struct uec_rx_bd_queues_entry) + + sizeof(struct uec_rx_pref_bds), + UEC_RX_BD_QUEUES_ALIGNMENT); + uec->p_rx_bd_qs_tbl = (struct uec_rx_bd_queues_entry *) qe_muram_addr(uec->rx_bd_qs_tbl_offset);
/* Zero it */ - memset(uec->p_rx_bd_qs_tbl, 0, sizeof(uec_rx_bd_queues_entry_t) + \ - sizeof(uec_rx_prefetched_bds_t)); + memset(uec->p_rx_bd_qs_tbl, 0, sizeof(struct uec_rx_bd_queues_entry) + + sizeof(struct uec_rx_pref_bds)); out_be32(&uec->p_rx_glbl_pram->rbdqptr, uec->rx_bd_qs_tbl_offset); out_be32(&uec->p_rx_bd_qs_tbl->externalbdbaseptr, (u32)uec->p_rx_bd_ring); @@ -868,9 +863,8 @@ static void uec_init_rx_parameter(uec_private_t *uec, int num_threads_rx) /* L2QT */ out_be32(&uec->p_rx_glbl_pram->l2qt, 0); /* L3QT */ - for (i = 0; i < 8; i++) { + for (i = 0; i < 8; i++) out_be32(&uec->p_rx_glbl_pram->l3qt[i], 0); - }
/* VLAN_TYPE */ out_be16(&uec->p_rx_glbl_pram->vlantype, 0x8100); @@ -878,7 +872,7 @@ static void uec_init_rx_parameter(uec_private_t *uec, int num_threads_rx) out_be16(&uec->p_rx_glbl_pram->vlantci, 0);
/* Clear PQ2 style address filtering hash table */ - p_af_pram = (uec_82xx_address_filtering_pram_t *) \ + p_af_pram = (struct uec_82xx_add_filtering_pram *) uec->p_rx_glbl_pram->addressfiltering;
p_af_pram->iaddr_h = 0; @@ -887,30 +881,33 @@ static void uec_init_rx_parameter(uec_private_t *uec, int num_threads_rx) p_af_pram->gaddr_l = 0; }
-static int uec_issue_init_enet_rxtx_cmd(uec_private_t *uec, - int thread_tx, int thread_rx) +static int uec_issue_init_enet_rxtx_cmd(struct uec_priv *uec, + int thread_tx, int thread_rx) { - uec_init_cmd_pram_t *p_init_enet_param; + struct uec_init_cmd_pram *p_init_enet_param; u32 init_enet_param_offset; - uec_info_t *uec_info; + struct uec_inf *uec_info; + struct ucc_fast_inf *uf_info; int i; int snum; - u32 init_enet_offset; + u32 off; u32 entry_val; u32 command; u32 cecr_subblock;
uec_info = uec->uec_info; + uf_info = &uec_info->uf_info;
/* Allocate init enet command parameter */ - uec->init_enet_param_offset = qe_muram_alloc( - sizeof(uec_init_cmd_pram_t), 4); + uec->init_enet_param_offset = + qe_muram_alloc(sizeof(struct uec_init_cmd_pram), 4); init_enet_param_offset = uec->init_enet_param_offset; - uec->p_init_enet_param = (uec_init_cmd_pram_t *) + uec->p_init_enet_param = (struct uec_init_cmd_pram *) qe_muram_addr(uec->init_enet_param_offset);
/* Zero init enet command struct */ - memset((void *)uec->p_init_enet_param, 0, sizeof(uec_init_cmd_pram_t)); + memset((void *)uec->p_init_enet_param, 0, + sizeof(struct uec_init_cmd_pram));
/* Init the command struct */ p_init_enet_param = uec->p_init_enet_param; @@ -932,21 +929,21 @@ static int uec_issue_init_enet_rxtx_cmd(uec_private_t *uec,
/* Init Rx threads */ for (i = 0; i < (thread_rx + 1); i++) { - if ((snum = qe_get_snum()) < 0) { - printf("%s can not get snum\n", __FUNCTION__); + snum = qe_get_snum(); + if (snum < 0) { + printf("%s can not get snum\n", __func__); return -ENOMEM; }
- if (i==0) { - init_enet_offset = 0; + if (i == 0) { + off = 0; } else { - init_enet_offset = qe_muram_alloc( - sizeof(uec_thread_rx_pram_t), - UEC_THREAD_RX_PRAM_ALIGNMENT); + off = qe_muram_alloc(sizeof(struct uec_thread_rx_pram), + UEC_THREAD_RX_PRAM_ALIGNMENT); }
entry_val = ((u32)snum << ENET_INIT_PARAM_SNUM_SHIFT) | - init_enet_offset | (u32)uec_info->risc_rx; + off | (u32)uec_info->risc_rx; p_init_enet_param->rxthread[i] = entry_val; }
@@ -956,16 +953,17 @@ static int uec_issue_init_enet_rxtx_cmd(uec_private_t *uec,
/* Init Tx threads */ for (i = 0; i < thread_tx; i++) { - if ((snum = qe_get_snum()) < 0) { - printf("%s can not get snum\n", __FUNCTION__); + snum = qe_get_snum(); + if (snum < 0) { + printf("%s can not get snum\n", __func__); return -ENOMEM; }
- init_enet_offset = qe_muram_alloc(sizeof(uec_thread_tx_pram_t), - UEC_THREAD_TX_PRAM_ALIGNMENT); + off = qe_muram_alloc(sizeof(struct uec_thread_tx_pram), + UEC_THREAD_TX_PRAM_ALIGNMENT);
entry_val = ((u32)snum << ENET_INIT_PARAM_SNUM_SHIFT) | - init_enet_offset | (u32)uec_info->risc_tx; + off | (u32)uec_info->risc_tx; p_init_enet_param->txthread[i] = entry_val; }
@@ -973,19 +971,18 @@ static int uec_issue_init_enet_rxtx_cmd(uec_private_t *uec,
/* Issue QE command */ command = QE_INIT_TX_RX; - cecr_subblock = ucc_fast_get_qe_cr_subblock( - uec->uec_info->uf_info.ucc_num); - qe_issue_cmd(command, cecr_subblock, (u8) QE_CR_PROTOCOL_ETHERNET, - init_enet_param_offset); + cecr_subblock = ucc_fast_get_qe_cr_subblock(uf_info->ucc_num); + qe_issue_cmd(command, cecr_subblock, (u8)QE_CR_PROTOCOL_ETHERNET, + init_enet_param_offset);
return 0; }
-static int uec_startup(uec_private_t *uec) +static int uec_startup(struct uec_priv *uec) { - uec_info_t *uec_info; - ucc_fast_info_t *uf_info; - ucc_fast_private_t *uccf; + struct uec_inf *uec_info; + struct ucc_fast_inf *uf_info; + struct ucc_fast_priv *uccf; ucc_fast_t *uf_regs; uec_t *uec_regs; int num_threads_tx; @@ -993,37 +990,37 @@ static int uec_startup(uec_private_t *uec) u32 utbipar; u32 length; u32 align; - qe_bd_t *bd; + struct buffer_descriptor *bd; u8 *buf; int i;
if (!uec || !uec->uec_info) { - printf("%s: uec or uec_info not initial\n", __FUNCTION__); + printf("%s: uec or uec_info not initial\n", __func__); return -EINVAL; }
uec_info = uec->uec_info; - uf_info = &(uec_info->uf_info); + uf_info = &uec_info->uf_info;
/* Check if Rx BD ring len is illegal */ - if ((uec_info->rx_bd_ring_len < UEC_RX_BD_RING_SIZE_MIN) || \ - (uec_info->rx_bd_ring_len % UEC_RX_BD_RING_SIZE_ALIGNMENT)) { + if (uec_info->rx_bd_ring_len < UEC_RX_BD_RING_SIZE_MIN || + (uec_info->rx_bd_ring_len % UEC_RX_BD_RING_SIZE_ALIGNMENT)) { printf("%s: Rx BD ring len must be multiple of 4, and > 8.\n", - __FUNCTION__); + __func__); return -EINVAL; }
/* Check if Tx BD ring len is illegal */ if (uec_info->tx_bd_ring_len < UEC_TX_BD_RING_SIZE_MIN) { printf("%s: Tx BD ring length must not be smaller than 2.\n", - __FUNCTION__); + __func__); return -EINVAL; }
/* Check if MRBLR is illegal */ - if ((MAX_RXBUF_LEN == 0) || (MAX_RXBUF_LEN % UEC_MRBLR_ALIGNMENT)) { + if (MAX_RXBUF_LEN == 0 || MAX_RXBUF_LEN % UEC_MRBLR_ALIGNMENT) { printf("%s: max rx buffer length must be mutliple of 128.\n", - __FUNCTION__); + __func__); return -EINVAL; }
@@ -1033,7 +1030,7 @@ static int uec_startup(uec_private_t *uec)
/* Init UCC fast */ if (ucc_fast_init(uf_info, &uccf)) { - printf("%s: failed to init ucc fast\n", __FUNCTION__); + printf("%s: failed to init ucc fast\n", __func__); return -ENOMEM; }
@@ -1042,13 +1039,13 @@ static int uec_startup(uec_private_t *uec)
/* Convert the Tx threads number */ if (uec_convert_threads_num(uec_info->num_threads_tx, - &num_threads_tx)) { + &num_threads_tx)) { return -EINVAL; }
/* Convert the Rx threads number */ if (uec_convert_threads_num(uec_info->num_threads_rx, - &num_threads_rx)) { + &num_threads_rx)) { return -EINVAL; }
@@ -1070,13 +1067,14 @@ static int uec_startup(uec_private_t *uec) out_be32(&uec_regs->maccfg2, MACCFG2_INIT_VALUE);
/* Setup MAC interface mode */ - uec_set_mac_if_mode(uec, uec_info->enet_interface_type, uec_info->speed); + uec_set_mac_if_mode(uec, uec_info->enet_interface_type, + uec_info->speed);
/* Setup MII management base */ #ifndef CONFIG_eTSEC_MDIO_BUS uec->uec_mii_regs = (uec_mii_t *)(&uec_regs->miimcfg); #else - uec->uec_mii_regs = (uec_mii_t *) CONFIG_MIIM_ADDRESS; + uec->uec_mii_regs = (uec_mii_t *)CONFIG_MIIM_ADDRESS; #endif
/* Setup MII master clock source */ @@ -1093,16 +1091,16 @@ static int uec_startup(uec_private_t *uec) out_be32(&uec_regs->utbipar, utbipar);
/* Configure the TBI for SGMII operation */ - if ((uec->uec_info->enet_interface_type == PHY_INTERFACE_MODE_SGMII) && - (uec->uec_info->speed == SPEED_1000)) { + if (uec->uec_info->enet_interface_type == PHY_INTERFACE_MODE_SGMII && + uec->uec_info->speed == SPEED_1000) { uec_write_phy_reg(uec->dev, uec_regs->utbipar, - ENET_TBI_MII_ANA, TBIANA_SETTINGS); + ENET_TBI_MII_ANA, TBIANA_SETTINGS);
uec_write_phy_reg(uec->dev, uec_regs->utbipar, - ENET_TBI_MII_TBICON, TBICON_CLK_SELECT); + ENET_TBI_MII_TBICON, TBICON_CLK_SELECT);
uec_write_phy_reg(uec->dev, uec_regs->utbipar, - ENET_TBI_MII_CR, TBICR_SETTINGS); + ENET_TBI_MII_CR, TBICR_SETTINGS); }
/* Allocate Tx BDs */ @@ -1149,29 +1147,29 @@ static int uec_startup(uec_private_t *uec) memset((void *)(uec->rx_buf_offset), 0, length + align);
/* Init TxBD ring */ - bd = (qe_bd_t *)uec->p_tx_bd_ring; - uec->txBd = bd; + bd = (struct buffer_descriptor *)uec->p_tx_bd_ring; + uec->tx_bd = bd;
for (i = 0; i < uec_info->tx_bd_ring_len; i++) { BD_DATA_CLEAR(bd); BD_STATUS_SET(bd, 0); BD_LENGTH_SET(bd, 0); - bd ++; + bd++; } - BD_STATUS_SET((--bd), TxBD_WRAP); + BD_STATUS_SET((--bd), TX_BD_WRAP);
/* Init RxBD ring */ - bd = (qe_bd_t *)uec->p_rx_bd_ring; - uec->rxBd = bd; + bd = (struct buffer_descriptor *)uec->p_rx_bd_ring; + uec->rx_bd = bd; buf = uec->p_rx_buf; for (i = 0; i < uec_info->rx_bd_ring_len; i++) { BD_DATA_SET(bd, buf); BD_LENGTH_SET(bd, 0); - BD_STATUS_SET(bd, RxBD_EMPTY); + BD_STATUS_SET(bd, RX_BD_EMPTY); buf += MAX_RXBUF_LEN; - bd ++; + bd++; } - BD_STATUS_SET((--bd), RxBD_WRAP | RxBD_EMPTY); + BD_STATUS_SET((--bd), RX_BD_WRAP | RX_BD_EMPTY);
/* Init global Tx parameter RAM */ uec_init_tx_parameter(uec, num_threads_tx); @@ -1182,29 +1180,32 @@ static int uec_startup(uec_private_t *uec) /* Init ethernet Tx and Rx parameter command */ if (uec_issue_init_enet_rxtx_cmd(uec, num_threads_tx, num_threads_rx)) { - printf("%s issue init enet cmd failed\n", __FUNCTION__); + printf("%s issue init enet cmd failed\n", __func__); return -ENOMEM; }
return 0; }
-static int uec_init(struct eth_device* dev, bd_t *bd) +static int uec_init(struct eth_device *dev, bd_t *bd) { - uec_private_t *uec; + struct uec_priv *uec; int err, i; struct phy_info *curphy; #if defined(CONFIG_ARCH_P1021) || defined(CONFIG_ARCH_P1025) ccsr_gur_t *gur = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); #endif
- if (uec->the_first_run == 0) { + if (!uec->the_first_run) { #if defined(CONFIG_ARCH_P1021) || defined(CONFIG_ARCH_P1025) - /* QE9 and QE12 need to be set for enabling QE MII managment signals */ - setbits_be32(&gur->pmuxcr, MPC85xx_PMUXCR_QE9); - setbits_be32(&gur->pmuxcr, MPC85xx_PMUXCR_QE12); + /* + * QE9 and QE12 need to be set for enabling QE MII + * management signals + */ + setbits_be32(&gur->pmuxcr, MPC85xx_PMUXCR_QE9); + setbits_be32(&gur->pmuxcr, MPC85xx_PMUXCR_QE12); #endif
err = init_phy(dev); @@ -1230,7 +1231,7 @@ static int uec_init(struct eth_device* dev, bd_t *bd) err = curphy->read_status(uec->mii_info); if (!(((i-- > 0) && !uec->mii_info->link) || err)) break; - udelay(100000); + mdelay(100); } while (1);
#if defined(CONFIG_ARCH_P1021) || defined(CONFIG_ARCH_P1025) @@ -1248,12 +1249,11 @@ static int uec_init(struct eth_device* dev, bd_t *bd) /* Set up the MAC address */ if (dev->enetaddr[0] & 0x01) { printf("%s: MacAddress is multcast address\n", - __FUNCTION__); + __func__); return -1; } uec_set_mac_address(uec, dev->enetaddr);
- err = uec_open(uec, COMM_DIR_RX_AND_TX); if (err) { printf("%s: cannot enable UEC device\n", dev->name); @@ -1262,30 +1262,31 @@ static int uec_init(struct eth_device* dev, bd_t *bd)
phy_change(dev);
- return (uec->mii_info->link ? 0 : -1); + return uec->mii_info->link ? 0 : -1; }
-static void uec_halt(struct eth_device* dev) +static void uec_halt(struct eth_device *dev) { - uec_private_t *uec = (uec_private_t *)dev->priv; + struct uec_priv *uec = (struct uec_priv *)dev->priv; + uec_stop(uec, COMM_DIR_RX_AND_TX); }
static int uec_send(struct eth_device *dev, void *buf, int len) { - uec_private_t *uec; - ucc_fast_private_t *uccf; - volatile qe_bd_t *bd; + struct uec_priv *uec; + struct ucc_fast_priv *uccf; + struct buffer_descriptor *bd; u16 status; int i; int result = 0;
- uec = (uec_private_t *)dev->priv; + uec = (struct uec_priv *)dev->priv; uccf = uec->uccf; - bd = uec->txBd; + bd = uec->tx_bd;
/* Find an empty TxBD */ - for (i = 0; bd->status & TxBD_READY; i++) { + for (i = 0; BD_STATUS(bd) & TX_BD_READY; i++) { if (i > 0x100000) { printf("%s: tx buffer not ready\n", dev->name); return result; @@ -1295,16 +1296,16 @@ static int uec_send(struct eth_device *dev, void *buf, int len) /* Init TxBD */ BD_DATA_SET(bd, buf); BD_LENGTH_SET(bd, len); - status = bd->status; + status = BD_STATUS(bd); status &= BD_WRAP; - status |= (TxBD_READY | TxBD_LAST); + status |= (TX_BD_READY | TX_BD_LAST); BD_STATUS_SET(bd, status);
/* Tell UCC to transmit the buffer */ ucc_fast_transmit_on_demand(uccf);
/* Wait for buffer to be transmitted */ - for (i = 0; bd->status & TxBD_READY; i++) { + for (i = 0; BD_STATUS(bd) & TX_BD_READY; i++) { if (i > 0x100000) { printf("%s: tx error\n", dev->name); return result; @@ -1313,25 +1314,25 @@ static int uec_send(struct eth_device *dev, void *buf, int len)
/* Ok, the buffer be transimitted */ BD_ADVANCE(bd, status, uec->p_tx_bd_ring); - uec->txBd = bd; + uec->tx_bd = bd; result = 1;
return result; }
-static int uec_recv(struct eth_device* dev) +static int uec_recv(struct eth_device *dev) { - uec_private_t *uec = dev->priv; - volatile qe_bd_t *bd; + struct uec_priv *uec = dev->priv; + struct buffer_descriptor *bd; u16 status; u16 len; u8 *data;
- bd = uec->rxBd; - status = bd->status; + bd = uec->rx_bd; + status = BD_STATUS(bd);
- while (!(status & RxBD_EMPTY)) { - if (!(status & RxBD_ERROR)) { + while (!(status & RX_BD_EMPTY)) { + if (!(status & RX_BD_ERROR)) { data = BD_DATA(bd); len = BD_LENGTH(bd); net_process_received_packet(data, len); @@ -1340,20 +1341,20 @@ static int uec_recv(struct eth_device* dev) } status &= BD_CLEAN; BD_LENGTH_SET(bd, 0); - BD_STATUS_SET(bd, status | RxBD_EMPTY); + BD_STATUS_SET(bd, status | RX_BD_EMPTY); BD_ADVANCE(bd, status, uec->p_rx_bd_ring); - status = bd->status; + status = BD_STATUS(bd); } - uec->rxBd = bd; + uec->rx_bd = bd;
return 1; }
-int uec_initialize(bd_t *bis, uec_info_t *uec_info) +int uec_initialize(bd_t *bis, struct uec_inf *uec_info) { struct eth_device *dev; int i; - uec_private_t *uec; + struct uec_priv *uec; int err;
dev = (struct eth_device *)malloc(sizeof(struct eth_device)); @@ -1362,11 +1363,11 @@ int uec_initialize(bd_t *bis, uec_info_t *uec_info) memset(dev, 0, sizeof(struct eth_device));
/* Allocate the UEC private struct */ - uec = (uec_private_t *)malloc(sizeof(uec_private_t)); - if (!uec) { + uec = (struct uec_priv *)malloc(sizeof(struct uec_priv)); + if (!uec) return -ENOMEM; - } - memset(uec, 0, sizeof(uec_private_t)); + + memset(uec, 0, sizeof(struct uec_priv));
/* Adjust uec_info */ #if (MAX_QE_RISC == 4) @@ -1395,13 +1396,14 @@ int uec_initialize(bd_t *bis, uec_info_t *uec_info)
err = uec_startup(uec); if (err) { - printf("%s: Cannot configure net device, aborting.",dev->name); + printf("%s: Cannot configure net device, aborting.", dev->name); return err; }
#if defined(CONFIG_MII) || defined(CONFIG_CMD_MII) int retval; struct mii_dev *mdiodev = mdio_alloc(); + if (!mdiodev) return -ENOMEM; strncpy(mdiodev->name, dev->name, MDIO_NAME_LEN); @@ -1416,7 +1418,7 @@ int uec_initialize(bd_t *bis, uec_info_t *uec_info) return 1; }
-int uec_eth_init(bd_t *bis, uec_info_t *uecs, int num) +int uec_eth_init(bd_t *bis, struct uec_inf *uecs, int num) { int i;
diff --git a/drivers/qe/uec.h b/drivers/qe/uec.h index 5f8baefb10..fc3b25f193 100644 --- a/drivers/qe/uec.h +++ b/drivers/qe/uec.h @@ -76,8 +76,7 @@ #define MACCFG2_INIT_VALUE (MACCFG2_PREL | MACCFG2_RESERVED_1 | \ MACCFG2_LC | MACCFG2_PAD_CRC | MACCFG2_FDX)
-/* UEC Event Register -*/ +/* UEC Event Register */ #define UCCE_MPD 0x80000000 #define UCCE_SCAR 0x40000000 #define UCCE_GRA 0x20000000 @@ -120,26 +119,24 @@ #define UCCE_OTHER (UCCE_SCAR | UCCE_GRA | UCCE_CBPR | UCCE_BSY | \ UCCE_RXC | UCCE_TXC | UCCE_TXE)
-/* UEC TEMODR Register -*/ +/* UEC TEMODR Register */ #define TEMODER_SCHEDULER_ENABLE 0x2000 #define TEMODER_IP_CHECKSUM_GENERATE 0x0400 #define TEMODER_PERFORMANCE_OPTIMIZATION_MODE1 0x0200 #define TEMODER_RMON_STATISTICS 0x0100 -#define TEMODER_NUM_OF_QUEUES_SHIFT (15-15) +#define TEMODER_NUM_OF_QUEUES_SHIFT (15 - 15)
#define TEMODER_INIT_VALUE 0xc000
-/* UEC REMODR Register -*/ +/* UEC REMODR Register */ #define REMODER_RX_RMON_STATISTICS_ENABLE 0x00001000 #define REMODER_RX_EXTENDED_FEATURES 0x80000000 -#define REMODER_VLAN_OPERATION_TAGGED_SHIFT (31-9 ) -#define REMODER_VLAN_OPERATION_NON_TAGGED_SHIFT (31-10) -#define REMODER_RX_QOS_MODE_SHIFT (31-15) +#define REMODER_VLAN_OPERATION_TAGGED_SHIFT (31 - 9) +#define REMODER_VLAN_OPERATION_NON_TAGGED_SHIFT (31 - 10) +#define REMODER_RX_QOS_MODE_SHIFT (31 - 15) #define REMODER_RMON_STATISTICS 0x00001000 #define REMODER_RX_EXTENDED_FILTERING 0x00000800 -#define REMODER_NUM_OF_QUEUES_SHIFT (31-23) +#define REMODER_NUM_OF_QUEUES_SHIFT (31 - 23) #define REMODER_DYNAMIC_MAX_FRAME_LENGTH 0x00000008 #define REMODER_DYNAMIC_MIN_FRAME_LENGTH 0x00000004 #define REMODER_IP_CHECKSUM_CHECK 0x00000002 @@ -213,35 +210,31 @@ #define UESCR_SCOV_SHIFT (15 - 15)
/****** Tx data struct collection ******/ -/* Tx thread data, each Tx thread has one this struct. -*/ -typedef struct uec_thread_data_tx { +/* Tx thread data, each Tx thread has one this struct. */ +struct uec_thread_data_tx { u8 res0[136]; -} __attribute__ ((packed)) uec_thread_data_tx_t; +} __packed;
-/* Tx thread parameter, each Tx thread has one this struct. -*/ -typedef struct uec_thread_tx_pram { +/* Tx thread parameter, each Tx thread has one this struct. */ +struct uec_thread_tx_pram { u8 res0[64]; -} __attribute__ ((packed)) uec_thread_tx_pram_t; +} __packed;
-/* Send queue queue-descriptor, each Tx queue has one this QD -*/ -typedef struct uec_send_queue_qd { +/* Send queue queue-descriptor, each Tx queue has one this QD */ +struct uec_send_queue_qd { u32 bd_ring_base; /* pointer to BD ring base address */ u8 res0[0x8]; u32 last_bd_completed_address; /* last entry in BD ring */ u8 res1[0x30]; -} __attribute__ ((packed)) uec_send_queue_qd_t; +} __packed;
/* Send queue memory region */ -typedef struct uec_send_queue_mem_region { - uec_send_queue_qd_t sqqd[MAX_TX_QUEUES]; -} __attribute__ ((packed)) uec_send_queue_mem_region_t; +struct uec_send_queue_mem_region { + struct uec_send_queue_qd sqqd[MAX_TX_QUEUES]; +} __packed;
-/* Scheduler struct -*/ -typedef struct uec_scheduler { +/* Scheduler struct */ +struct uec_scheduler { u16 cpucount0; /* CPU packet counter */ u16 cpucount1; /* CPU packet counter */ u16 cecount0; /* QE packet counter */ @@ -272,12 +265,11 @@ typedef struct uec_scheduler { u8 oldwfqmask; /* temporary variable handled by QE */ u8 weightfactor[MAX_TX_QUEUES]; /**< weight factor for queues */ u32 minw; /* temporary variable handled by QE */ - u8 res1[0x70-0x64]; -} __attribute__ ((packed)) uec_scheduler_t; + u8 res1[0x70 - 0x64]; +} __packed;
-/* Tx firmware counters -*/ -typedef struct uec_tx_firmware_statistics_pram { +/* Tx firmware counters */ +struct uec_tx_firmware_statistics_pram { u32 sicoltx; /* single collision */ u32 mulcoltx; /* multiple collision */ u32 latecoltxfr; /* late collision */ @@ -290,13 +282,12 @@ typedef struct uec_tx_firmware_statistics_pram { u32 txpkts512; /* total packets(including bad) 512~1023B */ u32 txpkts1024; /* total packets(including bad) 1024~1518B */ u32 txpktsjumbo; /* total packets(including bad) >1024 */ -} __attribute__ ((packed)) uec_tx_firmware_statistics_pram_t; +} __packed;
-/* Tx global parameter table -*/ -typedef struct uec_tx_global_pram { +/* Tx global parameter table */ +struct uec_tx_global_pram { u16 temoder; - u8 res0[0x38-0x02]; + u8 res0[0x38 - 0x02]; u32 sqptr; u32 schedulerbasepointer; u32 txrmonbaseptr; @@ -304,26 +295,22 @@ typedef struct uec_tx_global_pram { u8 iphoffset[MAX_IPH_OFFSET_ENTRY]; u32 vtagtable[0x8]; u32 tqptr; - u8 res2[0x80-0x74]; -} __attribute__ ((packed)) uec_tx_global_pram_t; - + u8 res2[0x80 - 0x74]; +} __packed;
/****** Rx data struct collection ******/ -/* Rx thread data, each Rx thread has one this struct. -*/ -typedef struct uec_thread_data_rx { +/* Rx thread data, each Rx thread has one this struct. */ +struct uec_thread_data_rx { u8 res0[40]; -} __attribute__ ((packed)) uec_thread_data_rx_t; +} __packed;
-/* Rx thread parameter, each Rx thread has one this struct. -*/ -typedef struct uec_thread_rx_pram { +/* Rx thread parameter, each Rx thread has one this struct. */ +struct uec_thread_rx_pram { u8 res0[128]; -} __attribute__ ((packed)) uec_thread_rx_pram_t; +} __packed;
-/* Rx firmware counters -*/ -typedef struct uec_rx_firmware_statistics_pram { +/* Rx firmware counters */ +struct uec_rx_firmware_statistics_pram { u32 frrxfcser; /* frames with crc error */ u32 fraligner; /* frames with alignment error */ u32 inrangelenrxer; /* in range length error */ @@ -346,44 +333,41 @@ typedef struct uec_rx_firmware_statistics_pram { u32 removevlan; u32 replacevlan; u32 insertvlan; -} __attribute__ ((packed)) uec_rx_firmware_statistics_pram_t; +} __packed;
-/* Rx interrupt coalescing entry, each Rx queue has one this entry. -*/ -typedef struct uec_rx_interrupt_coalescing_entry { +/* Rx interrupt coalescing entry, each Rx queue has one this entry. */ +struct uec_rx_interrupt_coalescing_entry { u32 maxvalue; u32 counter; -} __attribute__ ((packed)) uec_rx_interrupt_coalescing_entry_t; +} __packed;
-typedef struct uec_rx_interrupt_coalescing_table { - uec_rx_interrupt_coalescing_entry_t entry[MAX_RX_QUEUES]; -} __attribute__ ((packed)) uec_rx_interrupt_coalescing_table_t; +struct uec_rx_interrupt_coalescing_table { + struct uec_rx_interrupt_coalescing_entry entry[MAX_RX_QUEUES]; +} __packed;
-/* RxBD queue entry, each Rx queue has one this entry. -*/ -typedef struct uec_rx_bd_queues_entry { +/* RxBD queue entry, each Rx queue has one this entry. */ +struct uec_rx_bd_queues_entry { u32 bdbaseptr; /* BD base pointer */ u32 bdptr; /* BD pointer */ u32 externalbdbaseptr; /* external BD base pointer */ u32 externalbdptr; /* external BD pointer */ -} __attribute__ ((packed)) uec_rx_bd_queues_entry_t; +} __packed;
-/* Rx global paramter table -*/ -typedef struct uec_rx_global_pram { +/* Rx global parameter table */ +struct uec_rx_global_pram { u32 remoder; /* ethernet mode reg. */ u32 rqptr; /* base pointer to the Rx Queues */ u32 res0[0x1]; - u8 res1[0x20-0xC]; + u8 res1[0x20 - 0xc]; u16 typeorlen; u8 res2[0x1]; u8 rxgstpack; /* ack on GRACEFUL STOP RX command */ u32 rxrmonbaseptr; /* Rx RMON statistics base */ - u8 res3[0x30-0x28]; + u8 res3[0x30 - 0x28]; u32 intcoalescingptr; /* Interrupt coalescing table pointer */ - u8 res4[0x36-0x34]; + u8 res4[0x36 - 0x34]; u8 rstate; - u8 res5[0x46-0x37]; + u8 res5[0x46 - 0x37]; u16 mrblr; /* max receive buffer length reg. */ u32 rbdqptr; /* RxBD parameter table description */ u16 mflr; /* max frame length reg. */ @@ -396,17 +380,15 @@ typedef struct uec_rx_global_pram { u16 vlantype; /* vlan type */ u16 vlantci; /* default vlan tci */ u8 addressfiltering[64];/* address filtering data structure */ - u32 exfGlobalParam; /* extended filtering global parameters */ - u8 res6[0x100-0xC4]; /* Initialize to zero */ -} __attribute__ ((packed)) uec_rx_global_pram_t; + u32 exf_global_param; /* extended filtering global parameters */ + u8 res6[0x100 - 0xc4]; /* Initialize to zero */ +} __packed;
#define GRACEFUL_STOP_ACKNOWLEDGE_RX 0x01
- /****** UEC common ******/ -/* UCC statistics - hardware counters -*/ -typedef struct uec_hardware_statistics { +/* UCC statistics - hardware counters */ +struct uec_hardware_statistics { u32 tx64; u32 tx127; u32 tx255; @@ -422,11 +404,10 @@ typedef struct uec_hardware_statistics { u32 rbyt; u32 rmca; u32 rbca; -} __attribute__ ((packed)) uec_hardware_statistics_t; +} __packed;
-/* InitEnet command parameter -*/ -typedef struct uec_init_cmd_pram { +/* InitEnet command parameter */ +struct uec_init_cmd_pram { u8 resinit0; u8 resinit1; u8 resinit2; @@ -440,7 +421,7 @@ typedef struct uec_init_cmd_pram { u32 txglobal; /* tx global */ u32 txthread[MAX_ENET_INIT_PARAM_ENTRIES_TX]; /* tx threads */ u8 res3[0x1]; -} __attribute__ ((packed)) uec_init_cmd_pram_t; +} __packed;
#define ENET_INIT_PARAM_RGF_SHIFT (32 - 4) #define ENET_INIT_PARAM_TGF_SHIFT (32 - 8) @@ -456,105 +437,96 @@ typedef struct uec_init_cmd_pram { #define ENET_INIT_PARAM_MAGIC_RES_INIT3 0x00 #define ENET_INIT_PARAM_MAGIC_RES_INIT4 0x0400
-/* structure representing 82xx Address Filtering Enet Address in PRAM -*/ -typedef struct uec_82xx_enet_address { +/* structure representing 82xx Address Filtering Enet Address in PRAM */ +struct uec_82xx_enet_addr { u8 res1[0x2]; u16 h; /* address (MSB) */ u16 m; /* address */ u16 l; /* address (LSB) */ -} __attribute__ ((packed)) uec_82xx_enet_address_t; +} __packed;
-/* structure representing 82xx Address Filtering PRAM -*/ -typedef struct uec_82xx_address_filtering_pram { +/* structure representing 82xx Address Filtering PRAM */ +struct uec_82xx_add_filtering_pram { u32 iaddr_h; /* individual address filter, high */ u32 iaddr_l; /* individual address filter, low */ u32 gaddr_h; /* group address filter, high */ u32 gaddr_l; /* group address filter, low */ - uec_82xx_enet_address_t taddr; - uec_82xx_enet_address_t paddr[4]; - u8 res0[0x40-0x38]; -} __attribute__ ((packed)) uec_82xx_address_filtering_pram_t; - -/* Buffer Descriptor -*/ -typedef struct buffer_descriptor { + struct uec_82xx_enet_addr taddr; + struct uec_82xx_enet_addr paddr[4]; + u8 res0[0x40 - 0x38]; +} __packed; + +/* Buffer Descriptor */ +struct buffer_descriptor { u16 status; u16 len; u32 data; -} __attribute__ ((packed)) qe_bd_t, *p_bd_t; +} __packed;
-#define SIZEOFBD sizeof(qe_bd_t) +#define SIZEOFBD sizeof(struct buffer_descriptor)
-/* Common BD flags -*/ +/* Common BD flags */ #define BD_WRAP 0x2000 #define BD_INT 0x1000 #define BD_LAST 0x0800 #define BD_CLEAN 0x3000
-/* TxBD status flags -*/ -#define TxBD_READY 0x8000 -#define TxBD_PADCRC 0x4000 -#define TxBD_WRAP BD_WRAP -#define TxBD_INT BD_INT -#define TxBD_LAST BD_LAST -#define TxBD_TXCRC 0x0400 -#define TxBD_DEF 0x0200 -#define TxBD_PP 0x0100 -#define TxBD_LC 0x0080 -#define TxBD_RL 0x0040 -#define TxBD_RC 0x003C -#define TxBD_UNDERRUN 0x0002 -#define TxBD_TRUNC 0x0001 - -#define TxBD_ERROR (TxBD_UNDERRUN | TxBD_TRUNC) - -/* RxBD status flags -*/ -#define RxBD_EMPTY 0x8000 -#define RxBD_OWNER 0x4000 -#define RxBD_WRAP BD_WRAP -#define RxBD_INT BD_INT -#define RxBD_LAST BD_LAST -#define RxBD_FIRST 0x0400 -#define RxBD_CMR 0x0200 -#define RxBD_MISS 0x0100 -#define RxBD_BCAST 0x0080 -#define RxBD_MCAST 0x0040 -#define RxBD_LG 0x0020 -#define RxBD_NO 0x0010 -#define RxBD_SHORT 0x0008 -#define RxBD_CRCERR 0x0004 -#define RxBD_OVERRUN 0x0002 -#define RxBD_IPCH 0x0001 - -#define RxBD_ERROR (RxBD_LG | RxBD_NO | RxBD_SHORT | \ - RxBD_CRCERR | RxBD_OVERRUN) - -/* BD access macros -*/ -#define BD_STATUS(_bd) (((p_bd_t)(_bd))->status) -#define BD_STATUS_SET(_bd, _val) (((p_bd_t)(_bd))->status = _val) -#define BD_LENGTH(_bd) (((p_bd_t)(_bd))->len) -#define BD_LENGTH_SET(_bd, _val) (((p_bd_t)(_bd))->len = _val) -#define BD_DATA_CLEAR(_bd) (((p_bd_t)(_bd))->data = 0) -#define BD_IS_DATA(_bd) (((p_bd_t)(_bd))->data) -#define BD_DATA(_bd) ((u8 *)(((p_bd_t)(_bd))->data)) -#define BD_DATA_SET(_bd, _data) (((p_bd_t)(_bd))->data = (u32)(_data)) -#define BD_ADVANCE(_bd,_status,_base) \ - (((_status) & BD_WRAP) ? (_bd) = ((p_bd_t)(_base)) : ++(_bd)) - -/* Rx Prefetched BDs -*/ -typedef struct uec_rx_prefetched_bds { - qe_bd_t bd[MAX_PREFETCHED_BDS]; /* prefetched bd */ -} __attribute__ ((packed)) uec_rx_prefetched_bds_t; - -/* Alignments - */ +/* TxBD status flags */ +#define TX_BD_READY 0x8000 +#define TX_BD_PADCRC 0x4000 +#define TX_BD_WRAP BD_WRAP +#define TX_BD_INT BD_INT +#define TX_BD_LAST BD_LAST +#define TX_BD_TXCRC 0x0400 +#define TX_BD_DEF 0x0200 +#define TX_BD_PP 0x0100 +#define TX_BD_LC 0x0080 +#define TX_BD_RL 0x0040 +#define TX_BD_RC 0x003C +#define TX_BD_UNDERRUN 0x0002 +#define TX_BD_TRUNC 0x0001 + +#define TX_BD_ERROR (TX_BD_UNDERRUN | TX_BD_TRUNC) + +/* RxBD status flags */ +#define RX_BD_EMPTY 0x8000 +#define RX_BD_OWNER 0x4000 +#define RX_BD_WRAP BD_WRAP +#define RX_BD_INT BD_INT +#define RX_BD_LAST BD_LAST +#define RX_BD_FIRST 0x0400 +#define RX_BD_CMR 0x0200 +#define RX_BD_MISS 0x0100 +#define RX_BD_BCAST 0x0080 +#define RX_BD_MCAST 0x0040 +#define RX_BD_LG 0x0020 +#define RX_BD_NO 0x0010 +#define RX_BD_SHORT 0x0008 +#define RX_BD_CRCERR 0x0004 +#define RX_BD_OVERRUN 0x0002 +#define RX_BD_IPCH 0x0001 + +#define RX_BD_ERROR (RX_BD_LG | RX_BD_NO | RX_BD_SHORT | \ + RX_BD_CRCERR | RX_BD_OVERRUN) + +/* BD access macros */ +#define BD_STATUS(_bd) (in_be16(&((_bd)->status))) +#define BD_STATUS_SET(_bd, _v) (out_be16(&((_bd)->status), _v)) +#define BD_LENGTH(_bd) (in_be16(&((_bd)->len))) +#define BD_LENGTH_SET(_bd, _v) (out_be16(&((_bd)->len), _v)) +#define BD_DATA_CLEAR(_bd) (out_be32(&((_bd)->data), 0)) +#define BD_DATA(_bd) ((u8 *)(((_bd)->data))) +#define BD_DATA_SET(_bd, _data) (out_be32(&((_bd)->data), (u32)_data)) +#define BD_ADVANCE(_bd, _status, _base) \ + (((_status) & BD_WRAP) ? (_bd) = \ + ((struct buffer_descriptor *)(_base)) : ++(_bd)) + +/* Rx Prefetched BDs */ +struct uec_rx_pref_bds { + struct buffer_descriptor bd[MAX_PREFETCHED_BDS]; /* prefetched bd */ +} __packed; + +/* Alignments */ #define UEC_RX_GLOBAL_PRAM_ALIGNMENT 64 #define UEC_TX_GLOBAL_PRAM_ALIGNMENT 64 #define UEC_THREAD_RX_PRAM_ALIGNMENT 128 @@ -581,25 +553,8 @@ typedef struct uec_rx_prefetched_bds { #define UEC_RX_BD_RING_SIZE_MIN 8 #define UEC_TX_BD_RING_SIZE_MIN 2
-/* Ethernet speed -*/ -typedef enum enet_speed { - ENET_SPEED_10BT, /* 10 Base T */ - ENET_SPEED_100BT, /* 100 Base T */ - ENET_SPEED_1000BT /* 1000 Base T */ -} enet_speed_e; - -/* Ethernet Address Type. -*/ -typedef enum enet_addr_type { - ENET_ADDR_TYPE_INDIVIDUAL, - ENET_ADDR_TYPE_GROUP, - ENET_ADDR_TYPE_BROADCAST -} enet_addr_type_e; - -/* TBI / MII Set Register -*/ -typedef enum enet_tbi_mii_reg { +/* TBI / MII Set Register */ +enum enet_tbi_mii_reg { ENET_TBI_MII_CR = 0x00, ENET_TBI_MII_SR = 0x01, ENET_TBI_MII_ANA = 0x04, @@ -610,7 +565,7 @@ typedef enum enet_tbi_mii_reg { ENET_TBI_MII_EXST = 0x0F, ENET_TBI_MII_JD = 0x10, ENET_TBI_MII_TBICON = 0x11 -} enet_tbi_mii_reg_e; +};
/* TBI MDIO register bit fields*/ #define TBICON_CLK_SELECT 0x0020 @@ -637,18 +592,16 @@ typedef enum enet_tbi_mii_reg { | TBICR_SPEED1_SET \ )
-/* UEC number of threads -*/ -typedef enum uec_num_of_threads { +/* UEC number of threads */ +enum uec_num_of_threads { UEC_NUM_OF_THREADS_1 = 0x1, /* 1 */ UEC_NUM_OF_THREADS_2 = 0x2, /* 2 */ UEC_NUM_OF_THREADS_4 = 0x0, /* 4 */ UEC_NUM_OF_THREADS_6 = 0x3, /* 6 */ UEC_NUM_OF_THREADS_8 = 0x4 /* 8 */ -} uec_num_of_threads_e; +};
-/* UEC initialization info struct -*/ +/* UEC initialization info struct */ #define STD_UEC_INFO(num) \ { \ .uf_info = { \ @@ -668,10 +621,10 @@ typedef enum uec_num_of_threads { .speed = CONFIG_SYS_UEC##num##_INTERFACE_SPEED, \ }
-typedef struct uec_info { - ucc_fast_info_t uf_info; - uec_num_of_threads_e num_threads_tx; - uec_num_of_threads_e num_threads_rx; +struct uec_inf { + struct ucc_fast_inf uf_info; + enum uec_num_of_threads num_threads_tx; + enum uec_num_of_threads num_threads_rx; unsigned int risc_tx; unsigned int risc_rx; u16 rx_bd_ring_len; @@ -679,39 +632,37 @@ typedef struct uec_info { u8 phy_address; phy_interface_t enet_interface_type; int speed; -} uec_info_t; +};
-/* UEC driver initialized info -*/ +/* UEC driver initialized info */ #define MAX_RXBUF_LEN 1536 #define MAX_FRAME_LEN 1518 #define MIN_FRAME_LEN 64 #define MAX_DMA1_LEN 1520 #define MAX_DMA2_LEN 1520
-/* UEC driver private struct -*/ -typedef struct uec_private { - uec_info_t *uec_info; - ucc_fast_private_t *uccf; +/* UEC driver private struct */ +struct uec_priv { + struct uec_inf *uec_info; + struct ucc_fast_priv *uccf; struct eth_device *dev; uec_t *uec_regs; uec_mii_t *uec_mii_regs; /* enet init command parameter */ - uec_init_cmd_pram_t *p_init_enet_param; + struct uec_init_cmd_pram *p_init_enet_param; u32 init_enet_param_offset; - /* Rx and Tx paramter */ - uec_rx_global_pram_t *p_rx_glbl_pram; + /* Rx and Tx parameter */ + struct uec_rx_global_pram *p_rx_glbl_pram; u32 rx_glbl_pram_offset; - uec_tx_global_pram_t *p_tx_glbl_pram; + struct uec_tx_global_pram *p_tx_glbl_pram; u32 tx_glbl_pram_offset; - uec_send_queue_mem_region_t *p_send_q_mem_reg; + struct uec_send_queue_mem_region *p_send_q_mem_reg; u32 send_q_mem_reg_offset; - uec_thread_data_tx_t *p_thread_data_tx; + struct uec_thread_data_tx *p_thread_data_tx; u32 thread_dat_tx_offset; - uec_thread_data_rx_t *p_thread_data_rx; + struct uec_thread_data_rx *p_thread_data_rx; u32 thread_dat_rx_offset; - uec_rx_bd_queues_entry_t *p_rx_bd_qs_tbl; + struct uec_rx_bd_queues_entry *p_rx_bd_qs_tbl; u32 rx_bd_qs_tbl_offset; /* BDs specific */ u8 *p_tx_bd_ring; @@ -720,8 +671,8 @@ typedef struct uec_private { u32 rx_bd_ring_offset; u8 *p_rx_buf; u32 rx_buf_offset; - volatile qe_bd_t *txBd; - volatile qe_bd_t *rxBd; + struct buffer_descriptor *tx_bd; + struct buffer_descriptor *rx_bd; /* Status */ int mac_tx_enabled; int mac_rx_enabled; @@ -733,9 +684,9 @@ typedef struct uec_private { int oldspeed; int oldduplex; int oldlink; -} uec_private_t; +};
-int uec_initialize(bd_t *bis, uec_info_t *uec_info); -int uec_eth_init(bd_t *bis, uec_info_t *uecs, int num); +int uec_initialize(bd_t *bis, struct uec_inf *uec_info); +int uec_eth_init(bd_t *bis, struct uec_inf *uecs, int num); int uec_standard_init(bd_t *bis); #endif /* __UEC_H__ */ diff --git a/drivers/qe/uec_phy.c b/drivers/qe/uec_phy.c index 69c22dd5e2..b5ca5f76f9 100644 --- a/drivers/qe/uec_phy.c +++ b/drivers/qe/uec_phy.c @@ -27,13 +27,13 @@ printf(format "\n", ## arg)
#define ugphy_dbg(format, arg...) \ - ugphy_printk(format , ## arg) + ugphy_printk(format, ## arg) #define ugphy_err(format, arg...) \ - ugphy_printk(format , ## arg) + ugphy_printk(format, ## arg) #define ugphy_info(format, arg...) \ - ugphy_printk(format , ## arg) + ugphy_printk(format, ## arg) #define ugphy_warn(format, arg...) \ - ugphy_printk(format , ## arg) + ugphy_printk(format, ## arg)
#ifdef UEC_VERBOSE_DEBUG #define ugphy_vdbg ugphy_dbg @@ -41,13 +41,13 @@ #define ugphy_vdbg(ugeth, fmt, args...) do { } while (0) #endif /* UEC_VERBOSE_DEBUG */
-/*--------------------------------------------------------------------+ +/* + * -------------------------------------------------------------------- * Fixed PHY (PHY-less) support for Ethernet Ports. * * Copied from arch/powerpc/cpu/ppc4xx/4xx_enet.c - *--------------------------------------------------------------------*/ - -/* + *-------------------------------------------------------------------- + * * Some boards do not have a PHY for each ethernet port. These ports are known * as Fixed PHY (or PHY-less) ports. For such ports, set the appropriate * CONFIG_SYS_UECx_PHY_ADDR equal to CONFIG_FIXED_PHY_ADDR (an unused address) @@ -90,54 +90,58 @@ static const struct fixed_phy_port fixed_phy_port[] = { CONFIG_SYS_FIXED_PHY_PORTS /* defined in board configuration file */ };
-/*--------------------------------------------------------------------+ +/* + * ------------------------------------------------------------------- * BitBang MII support for ethernet ports * * Based from MPC8560ADS implementation - *--------------------------------------------------------------------*/ -/* + *-------------------------------------------------------------------- + * * Example board header file to define bitbang ethernet ports: * * #define CONFIG_SYS_BITBANG_PHY_PORT(name) name, * #define CONFIG_SYS_BITBANG_PHY_PORTS CONFIG_SYS_BITBANG_PHY_PORT("UEC0") -*/ + */ #ifndef CONFIG_SYS_BITBANG_PHY_PORTS #define CONFIG_SYS_BITBANG_PHY_PORTS /* default is an empty array */ #endif
#if defined(CONFIG_BITBANGMII) -static const char *bitbang_phy_port[] = { +static const char * const bitbang_phy_port[] = { CONFIG_SYS_BITBANG_PHY_PORTS /* defined in board configuration file */ }; #endif /* CONFIG_BITBANGMII */
-static void config_genmii_advert (struct uec_mii_info *mii_info); -static void genmii_setup_forced (struct uec_mii_info *mii_info); -static void genmii_restart_aneg (struct uec_mii_info *mii_info); -static int gbit_config_aneg (struct uec_mii_info *mii_info); -static int genmii_config_aneg (struct uec_mii_info *mii_info); -static int genmii_update_link (struct uec_mii_info *mii_info); -static int genmii_read_status (struct uec_mii_info *mii_info); -u16 uec_phy_read(struct uec_mii_info *mii_info, u16 regnum); -void uec_phy_write(struct uec_mii_info *mii_info, u16 regnum, u16 val); - -/* Write value to the PHY for this device to the register at regnum, */ -/* waiting until the write is done before it returns. All PHY */ -/* configuration has to be done through the TSEC1 MIIM regs */ -void uec_write_phy_reg (struct eth_device *dev, int mii_id, int regnum, int value) -{ - uec_private_t *ugeth = (uec_private_t *) dev->priv; +static void config_genmii_advert(struct uec_mii_info *mii_info); +static void genmii_setup_forced(struct uec_mii_info *mii_info); +static void genmii_restart_aneg(struct uec_mii_info *mii_info); +static int gbit_config_aneg(struct uec_mii_info *mii_info); +static int genmii_config_aneg(struct uec_mii_info *mii_info); +static int genmii_update_link(struct uec_mii_info *mii_info); +static int genmii_read_status(struct uec_mii_info *mii_info); +static u16 uec_phy_read(struct uec_mii_info *mii_info, u16 regnum); +static void uec_phy_write(struct uec_mii_info *mii_info, u16 regnum, + u16 val); + +/* + * Write value to the PHY for this device to the register at regnum, + * waiting until the write is done before it returns. All PHY + * configuration has to be done through the TSEC1 MIIM regs + */ +void uec_write_phy_reg(struct eth_device *dev, int mii_id, int regnum, + int value) +{ + struct uec_priv *ugeth = (struct uec_priv *)dev->priv; uec_mii_t *ug_regs; - enet_tbi_mii_reg_e mii_reg = (enet_tbi_mii_reg_e) regnum; + enum enet_tbi_mii_reg mii_reg = (enum enet_tbi_mii_reg)regnum; u32 tmp_reg;
- #if defined(CONFIG_BITBANGMII) u32 i = 0;
for (i = 0; i < ARRAY_SIZE(bitbang_phy_port); i++) { if (strncmp(dev->name, bitbang_phy_port[i], - sizeof(dev->name)) == 0) { + sizeof(dev->name)) == 0) { (void)bb_miiphy_write(NULL, mii_id, regnum, value); return; } @@ -148,46 +152,48 @@ void uec_write_phy_reg (struct eth_device *dev, int mii_id, int regnum, int valu
/* Stop the MII management read cycle */ out_be32 (&ug_regs->miimcom, 0); - /* Setting up the MII Mangement Address Register */ - tmp_reg = ((u32) mii_id << MIIMADD_PHY_ADDRESS_SHIFT) | mii_reg; + /* Setting up the MII Management Address Register */ + tmp_reg = ((u32)mii_id << MIIMADD_PHY_ADDRESS_SHIFT) | mii_reg; out_be32 (&ug_regs->miimadd, tmp_reg);
- /* Setting up the MII Mangement Control Register with the value */ - out_be32 (&ug_regs->miimcon, (u32) value); + /* Setting up the MII Management Control Register with the value */ + out_be32 (&ug_regs->miimcon, (u32)value); sync();
/* Wait till MII management write is complete */ - while ((in_be32 (&ug_regs->miimind)) & MIIMIND_BUSY); + while ((in_be32 (&ug_regs->miimind)) & MIIMIND_BUSY) + ; }
-/* Reads from register regnum in the PHY for device dev, */ -/* returning the value. Clears miimcom first. All PHY */ -/* configuration has to be done through the TSEC1 MIIM regs */ -int uec_read_phy_reg (struct eth_device *dev, int mii_id, int regnum) +/* + * Reads from register regnum in the PHY for device dev, + * returning the value. Clears miimcom first. All PHY + * configuration has to be done through the TSEC1 MIIM regs + */ +int uec_read_phy_reg(struct eth_device *dev, int mii_id, int regnum) { - uec_private_t *ugeth = (uec_private_t *) dev->priv; + struct uec_priv *ugeth = (struct uec_priv *)dev->priv; uec_mii_t *ug_regs; - enet_tbi_mii_reg_e mii_reg = (enet_tbi_mii_reg_e) regnum; + enum enet_tbi_mii_reg mii_reg = (enum enet_tbi_mii_reg)regnum; u32 tmp_reg; u16 value;
for (i = 0; i < ARRAY_SIZE(bitbang_phy_port); i++) { if (strncmp(dev->name, bitbang_phy_port[i], - sizeof(dev->name)) == 0) { + sizeof(dev->name)) == 0) { (void)bb_miiphy_read(NULL, mii_id, regnum, &value); - return (value); + return value; } } #endif /* CONFIG_BITBANGMII */
ug_regs = ugeth->uec_mii_regs;
/* clear MII management command cycle */ @@ -199,37 +205,38 @@ int uec_read_phy_reg (struct eth_device *dev, int mii_id, int regnum)
/* Wait till MII management write is complete */ while ((in_be32 (&ug_regs->miimind)) & - (MIIMIND_NOT_VALID | MIIMIND_BUSY)); + (MIIMIND_NOT_VALID | MIIMIND_BUSY)) + ;
/* Read MII management status */ - value = (u16) in_be32 (&ug_regs->miimstat); + value = (u16)in_be32 (&ug_regs->miimstat); if (value == 0xffff) ugphy_vdbg ("read wrong value : mii_id %d,mii_reg %d, base %08x", - mii_id, mii_reg, (u32) & (ug_regs->miimcfg)); + mii_id, mii_reg, (u32)&ug_regs->miimcfg);
-void mii_clear_phy_interrupt (struct uec_mii_info *mii_info) +void mii_clear_phy_interrupt(struct uec_mii_info *mii_info) { if (mii_info->phyinfo->ack_interrupt) - mii_info->phyinfo->ack_interrupt (mii_info); + mii_info->phyinfo->ack_interrupt(mii_info); }
-void mii_configure_phy_interrupt (struct uec_mii_info *mii_info, - u32 interrupts) +void mii_configure_phy_interrupt(struct uec_mii_info *mii_info, + u32 interrupts) { mii_info->interrupts = interrupts; if (mii_info->phyinfo->config_intr) - mii_info->phyinfo->config_intr (mii_info); + mii_info->phyinfo->config_intr(mii_info); }
/* Writes MII_ADVERTISE with the appropriate values, after * sanitizing advertise to make sure only supported features * are advertised */ -static void config_genmii_advert (struct uec_mii_info *mii_info) +static void config_genmii_advert(struct uec_mii_info *mii_info) { u32 advertise; u16 adv; @@ -252,7 +259,7 @@ static void config_genmii_advert (struct uec_mii_info *mii_info) uec_phy_write(mii_info, MII_ADVERTISE, adv); }
-static void genmii_setup_forced (struct uec_mii_info *mii_info) +static void genmii_setup_forced(struct uec_mii_info *mii_info) { u16 ctrl; u32 features = mii_info->phyinfo->features; @@ -283,7 +290,7 @@ static void genmii_setup_forced (struct uec_mii_info *mii_info) | SUPPORTED_10baseT_Full)) break; default: /* Unsupported speed! */ - ugphy_err ("%s: Bad speed!", mii_info->dev->name); + ugphy_err("%s: Bad speed!", mii_info->dev->name); break; }
@@ -291,7 +298,7 @@ static void genmii_setup_forced (struct uec_mii_info *mii_info) }
/* Enable and Restart Autonegotiation */ -static void genmii_restart_aneg (struct uec_mii_info *mii_info) +static void genmii_restart_aneg(struct uec_mii_info *mii_info) { u16 ctl;
@@ -300,14 +307,14 @@ static void genmii_restart_aneg (struct uec_mii_info *mii_info) uec_phy_write(mii_info, MII_BMCR, ctl); }
-static int gbit_config_aneg (struct uec_mii_info *mii_info) +static int gbit_config_aneg(struct uec_mii_info *mii_info) { u16 adv; u32 advertise;
if (mii_info->autoneg) { /* Configure the ADVERTISE register */ - config_genmii_advert (mii_info); + config_genmii_advert(mii_info); advertise = mii_info->advertising;
adv = uec_phy_read(mii_info, MII_CTRL1000); @@ -320,18 +327,21 @@ static int gbit_config_aneg (struct uec_mii_info *mii_info) uec_phy_write(mii_info, MII_CTRL1000, adv);
/* Start/Restart aneg */ - genmii_restart_aneg (mii_info); - } else - genmii_setup_forced (mii_info); + genmii_restart_aneg(mii_info); + } else { + genmii_setup_forced(mii_info); + }
return 0; }
-static int marvell_config_aneg (struct uec_mii_info *mii_info) +static int marvell_config_aneg(struct uec_mii_info *mii_info) { - /* The Marvell PHY has an errata which requires + /* + * The Marvell PHY has an errata which requires * that certain registers get written in order - * to restart autonegotiation */ + * to restart autonegotiation + */ uec_phy_write(mii_info, MII_BMCR, BMCR_RESET);
uec_phy_write(mii_info, 0x1d, 0x1f); @@ -340,16 +350,18 @@ static int marvell_config_aneg (struct uec_mii_info *mii_info) uec_phy_write(mii_info, 0x1e, 0); uec_phy_write(mii_info, 0x1e, 0x100);
- gbit_config_aneg (mii_info); + gbit_config_aneg(mii_info);
return 0; }
-static int genmii_config_aneg (struct uec_mii_info *mii_info) +static int genmii_config_aneg(struct uec_mii_info *mii_info) { if (mii_info->autoneg) { - /* Speed up the common case, if link is already up, speed and - duplex match, skip auto neg as it already matches */ + /* + * Speed up the common case, if link is already up, speed and + * duplex match, skip auto neg as it already matches + */ if (!genmii_read_status(mii_info) && mii_info->link) if (mii_info->duplex == DUPLEX_FULL && mii_info->speed == SPEED_100) @@ -357,15 +369,16 @@ static int genmii_config_aneg (struct uec_mii_info *mii_info) ADVERTISED_100baseT_Full) return 0;
- config_genmii_advert (mii_info); - genmii_restart_aneg (mii_info); - } else - genmii_setup_forced (mii_info); + config_genmii_advert(mii_info); + genmii_restart_aneg(mii_info); + } else { + genmii_setup_forced(mii_info); + }
return 0; }
-static int genmii_update_link (struct uec_mii_info *mii_info) +static int genmii_update_link(struct uec_mii_info *mii_info) { u16 status;
@@ -377,8 +390,8 @@ static int genmii_update_link (struct uec_mii_info *mii_info) * (ie - we're capable and it's not done) */ status = uec_phy_read(mii_info, MII_BMSR); - if ((status & BMSR_LSTATUS) && (status & BMSR_ANEGCAPABLE) - && !(status & BMSR_ANEGCOMPLETE)) { + if ((status & BMSR_LSTATUS) && (status & BMSR_ANEGCAPABLE) && + !(status & BMSR_ANEGCOMPLETE)) { int i = 0;
while (!(status & BMSR_ANEGCOMPLETE)) { @@ -405,14 +418,13 @@ static int genmii_update_link (struct uec_mii_info *mii_info) return 0; }
-static int genmii_read_status (struct uec_mii_info *mii_info) +static int genmii_read_status(struct uec_mii_info *mii_info) { u16 status; int err;
- /* Update the link, but return if there - * was an error */ - err = genmii_update_link (mii_info); + /* Update the link, but return if there was an error */ + err = genmii_update_link(mii_info); if (err) return err;
@@ -449,13 +461,13 @@ static int genmii_read_status (struct uec_mii_info *mii_info) static int bcm_init(struct uec_mii_info *mii_info) { struct eth_device *edev = mii_info->dev; - uec_private_t *uec = edev->priv; + struct uec_priv *uec = edev->priv;
- if ((uec->uec_info->enet_interface_type == - PHY_INTERFACE_MODE_RGMII_RXID) && - (uec->uec_info->speed == SPEED_1000)) { + if (uec->uec_info->enet_interface_type == + PHY_INTERFACE_MODE_RGMII_RXID && + uec->uec_info->speed == SPEED_1000) { u16 val; int cnt = 50;
@@ -476,18 +488,18 @@ static int bcm_init(struct uec_mii_info *mii_info) uec_phy_write(mii_info, 0x18, val); }
- return 0; + return 0; }
static int uec_marvell_init(struct uec_mii_info *mii_info) { struct eth_device *edev = mii_info->dev; - uec_private_t *uec = edev->priv; + struct uec_priv *uec = edev->priv; phy_interface_t iface = uec->uec_info->enet_interface_type; int speed = uec->uec_info->speed;
- if ((speed == SPEED_1000) && - (iface == PHY_INTERFACE_MODE_RGMII_ID || + if (speed == SPEED_1000 && + (iface == PHY_INTERFACE_MODE_RGMII_ID || iface == PHY_INTERFACE_MODE_RGMII_RXID || iface == PHY_INTERFACE_MODE_RGMII_TXID)) { int temp; @@ -515,20 +527,21 @@ static int uec_marvell_init(struct uec_mii_info *mii_info) return 0; }
-static int marvell_read_status (struct uec_mii_info *mii_info) +static int marvell_read_status(struct uec_mii_info *mii_info) { u16 status; int err;
- /* If the link is up, read the speed and duplex */ - /* If we aren't autonegotiating, assume speeds - * are as set */ + /* + * If the link is up, read the speed and duplex + * If we aren't autonegotiating, assume speeds + * are as set + */ if (mii_info->autoneg && mii_info->link) { int speed;
@@ -559,7 +572,7 @@ static int marvell_read_status (struct uec_mii_info *mii_info) return 0; }
-static int marvell_ack_interrupt (struct uec_mii_info *mii_info) +static int marvell_ack_interrupt(struct uec_mii_info *mii_info) { /* Clear the interrupts by reading the reg */ uec_phy_read(mii_info, MII_M1011_IEVENT); @@ -567,18 +580,18 @@ static int marvell_ack_interrupt (struct uec_mii_info *mii_info) return 0; }
-static int marvell_config_intr (struct uec_mii_info *mii_info) +static int marvell_config_intr(struct uec_mii_info *mii_info) { if (mii_info->interrupts == MII_INTERRUPT_ENABLED) uec_phy_write(mii_info, MII_M1011_IMASK, MII_M1011_IMASK_INIT); else uec_phy_write(mii_info, MII_M1011_IMASK, - MII_M1011_IMASK_CLEAR); + MII_M1011_IMASK_CLEAR);
return 0; }
-static int dm9161_init (struct uec_mii_info *mii_info) +static int dm9161_init(struct uec_mii_info *mii_info) { /* Reset the PHY */ uec_phy_write(mii_info, MII_BMCR, uec_phy_read(mii_info, MII_BMCR) | @@ -589,29 +602,31 @@ static int dm9161_init (struct uec_mii_info *mii_info)
uec_phy_write(mii_info, MII_DM9161_SCR, MII_DM9161_SCR_INIT);
- config_genmii_advert (mii_info); + config_genmii_advert(mii_info); /* Start/restart aneg */ - genmii_config_aneg (mii_info); + genmii_config_aneg(mii_info);
return 0; }
-static int dm9161_config_aneg (struct uec_mii_info *mii_info) +static int dm9161_config_aneg(struct uec_mii_info *mii_info) { return 0; }
-static int dm9161_read_status (struct uec_mii_info *mii_info) +static int dm9161_read_status(struct uec_mii_info *mii_info) { u16 status; int err;
/* Update the link, but return if there was an error */ - err = genmii_update_link (mii_info); + err = genmii_update_link(mii_info); if (err) return err; - /* If the link is up, read the speed and duplex - If we aren't autonegotiating assume speeds are as set */ + /* + * If the link is up, read the speed and duplex + * If we aren't autonegotiating assume speeds are as set + */ if (mii_info->autoneg && mii_info->link) { status = uec_phy_read(mii_info, MII_DM9161_SCSR); if (status & (MII_DM9161_SCSR_100F | MII_DM9161_SCSR_100H)) @@ -628,7 +643,7 @@ static int dm9161_read_status (struct uec_mii_info *mii_info) return 0; }
-static int dm9161_ack_interrupt (struct uec_mii_info *mii_info) +static int dm9161_ack_interrupt(struct uec_mii_info *mii_info) { /* Clear the interrupt by reading the reg */ uec_phy_read(mii_info, MII_DM9161_INTR); @@ -636,7 +651,7 @@ static int dm9161_ack_interrupt (struct uec_mii_info *mii_info) return 0; }
-static int dm9161_config_intr (struct uec_mii_info *mii_info) +static int dm9161_config_intr(struct uec_mii_info *mii_info) { if (mii_info->interrupts == MII_INTERRUPT_ENABLED) uec_phy_write(mii_info, MII_DM9161_INTR, MII_DM9161_INTR_INIT); @@ -646,23 +661,23 @@ static int dm9161_config_intr (struct uec_mii_info *mii_info) return 0; }
-static void dm9161_close (struct uec_mii_info *mii_info) +static void dm9161_close(struct uec_mii_info *mii_info) { }
-static int fixed_phy_aneg (struct uec_mii_info *mii_info) +static int fixed_phy_aneg(struct uec_mii_info *mii_info) { mii_info->autoneg = 0; /* Turn off auto negotiation for fixed phy */ return 0; }
-static int fixed_phy_read_status (struct uec_mii_info *mii_info) +static int fixed_phy_read_status(struct uec_mii_info *mii_info) { int i = 0;
for (i = 0; i < ARRAY_SIZE(fixed_phy_port); i++) { if (strncmp(mii_info->dev->name, fixed_phy_port[i].name, - strlen(mii_info->dev->name)) == 0) { + strlen(mii_info->dev->name)) == 0) { mii_info->speed = fixed_phy_port[i].speed; mii_info->duplex = fixed_phy_port[i].duplex; mii_info->link = 1; /* Link is always UP */ @@ -673,25 +688,26 @@ static int fixed_phy_read_status (struct uec_mii_info *mii_info) return 0; }
-static int smsc_config_aneg (struct uec_mii_info *mii_info) +static int smsc_config_aneg(struct uec_mii_info *mii_info) { return 0; }
-static int smsc_read_status (struct uec_mii_info *mii_info) +static int smsc_read_status(struct uec_mii_info *mii_info) { u16 status; int err;
- /* If the link is up, read the speed and duplex */ - /* If we aren't autonegotiating, assume speeds - * are as set */ + /* + * If the link is up, read the speed and duplex + * If we aren't autonegotiating, assume speeds + * are as set + */ if (mii_info->autoneg && mii_info->link) { int val;
@@ -699,22 +715,22 @@ static int smsc_read_status (struct uec_mii_info *mii_info) val = (status & 0x1c) >> 2;
switch (val) { - case 1: - mii_info->duplex = DUPLEX_HALF; - mii_info->speed = SPEED_10; - break; - case 5: - mii_info->duplex = DUPLEX_FULL; - mii_info->speed = SPEED_10; - break; - case 2: - mii_info->duplex = DUPLEX_HALF; - mii_info->speed = SPEED_100; - break; - case 6: - mii_info->duplex = DUPLEX_FULL; - mii_info->speed = SPEED_100; - break; + case 1: + mii_info->duplex = DUPLEX_HALF; + mii_info->speed = SPEED_10; + break; + case 5: + mii_info->duplex = DUPLEX_FULL; + mii_info->speed = SPEED_10; + break; + case 2: + mii_info->duplex = DUPLEX_HALF; + mii_info->speed = SPEED_100; + break; + case 6: + mii_info->duplex = DUPLEX_FULL; + mii_info->speed = SPEED_100; + break; } mii_info->pause = 0; } @@ -803,25 +819,25 @@ static struct phy_info *phy_info[] = { NULL };
-u16 uec_phy_read(struct uec_mii_info *mii_info, u16 regnum) +static u16 uec_phy_read(struct uec_mii_info *mii_info, u16 regnum) { - return mii_info->mdio_read (mii_info->dev, mii_info->mii_id, regnum); + return mii_info->mdio_read(mii_info->dev, mii_info->mii_id, regnum); }
-void uec_phy_write(struct uec_mii_info *mii_info, u16 regnum, u16 val) +static void uec_phy_write(struct uec_mii_info *mii_info, u16 regnum, u16 val) { - mii_info->mdio_write (mii_info->dev, mii_info->mii_id, regnum, val); + mii_info->mdio_write(mii_info->dev, mii_info->mii_id, regnum, val); }
/* Use the PHY ID registers to determine what type of PHY is attached * to device dev. return a struct phy_info structure describing that PHY */ -struct phy_info *uec_get_phy_info (struct uec_mii_info *mii_info) +struct phy_info *uec_get_phy_info(struct uec_mii_info *mii_info) { u16 phy_reg; u32 phy_ID; int i; - struct phy_info *theInfo = NULL; + struct phy_info *info = NULL;
/* Grab the bits from PHYIR1, and put them in the upper half */ phy_reg = uec_phy_read(mii_info, MII_PHYSID1); @@ -836,30 +852,29 @@ struct phy_info *uec_get_phy_info (struct uec_mii_info *mii_info) for (i = 0; phy_info[i]; i++) if (phy_info[i]->phy_id == (phy_ID & phy_info[i]->phy_id_mask)) { - theInfo = phy_info[i]; + info = phy_info[i]; break; }
/* This shouldn't happen, as we have generic PHY support */ - if (theInfo == NULL) { - ugphy_info ("UEC: PHY id %x is not supported!", phy_ID); + if (!info) { + ugphy_info("UEC: PHY id %x is not supported!", phy_ID); return NULL; - } else { - ugphy_info ("UEC: PHY is %s (%x)", theInfo->name, phy_ID); } + ugphy_info("UEC: PHY is %s (%x)", info->name, phy_ID);
- return theInfo; + return info; }
void marvell_phy_interface_mode(struct eth_device *dev, phy_interface_t type, - int speed) + int speed) { - uec_private_t *uec = (uec_private_t *) dev->priv; + struct uec_priv *uec = (struct uec_priv *)dev->priv; struct uec_mii_info *mii_info; u16 status;
if (!uec->mii_info) { - printf ("%s: the PHY not initialized\n", __FUNCTION__); + printf("%s: the PHY not initialized\n", __func__); return; } mii_info = uec->mii_info; @@ -903,10 +918,10 @@ void marvell_phy_interface_mode(struct eth_device *dev, phy_interface_t type, /* now the B2 will correctly report autoneg completion status */ }
-void change_phy_interface_mode (struct eth_device *dev, - phy_interface_t type, int speed) +void change_phy_interface_mode(struct eth_device *dev, + phy_interface_t type, int speed) { #ifdef CONFIG_PHY_MODE_NEED_CHANGE - marvell_phy_interface_mode (dev, type, speed); + marvell_phy_interface_mode(dev, type, speed); #endif } diff --git a/drivers/qe/uec_phy.h b/drivers/qe/uec_phy.h index 83a7ccd981..7fd0e2c544 100644 --- a/drivers/qe/uec_phy.h +++ b/drivers/qe/uec_phy.h @@ -11,6 +11,8 @@ #ifndef __UEC_PHY_H__ #define __UEC_PHY_H__
+#include <linux/bitops.h> + #define MII_end ((u32)-2) #define MII_read ((u32)-1)
@@ -93,8 +95,8 @@ #define MII_DM9161_INTR_LINK_CHANGE 0x0004 #define MII_DM9161_INTR_INIT 0x0000 #define MII_DM9161_INTR_STOP \ -(MII_DM9161_INTR_DPLX_MASK | MII_DM9161_INTR_SPD_MASK \ - | MII_DM9161_INTR_LINK_MASK | MII_DM9161_INTR_MASK) + (MII_DM9161_INTR_DPLX_MASK | MII_DM9161_INTR_SPD_MASK | \ + MII_DM9161_INTR_LINK_MASK | MII_DM9161_INTR_MASK)
/* DM9161 10BT Configuration/Status */ #define MII_DM9161_10BTCSR 0x12 @@ -125,35 +127,6 @@ #define DUPLEX_HALF 0x00 #define DUPLEX_FULL 0x01
-/* Indicates what features are supported by the interface. */ -#define SUPPORTED_10baseT_Half (1 << 0) -#define SUPPORTED_10baseT_Full (1 << 1) -#define SUPPORTED_100baseT_Half (1 << 2) -#define SUPPORTED_100baseT_Full (1 << 3) -#define SUPPORTED_1000baseT_Half (1 << 4) -#define SUPPORTED_1000baseT_Full (1 << 5) -#define SUPPORTED_Autoneg (1 << 6) -#define SUPPORTED_TP (1 << 7) -#define SUPPORTED_AUI (1 << 8) -#define SUPPORTED_MII (1 << 9) -#define SUPPORTED_FIBRE (1 << 10) -#define SUPPORTED_BNC (1 << 11) -#define SUPPORTED_10000baseT_Full (1 << 12) - -#define ADVERTISED_10baseT_Half (1 << 0) -#define ADVERTISED_10baseT_Full (1 << 1) -#define ADVERTISED_100baseT_Half (1 << 2) -#define ADVERTISED_100baseT_Full (1 << 3) -#define ADVERTISED_1000baseT_Half (1 << 4) -#define ADVERTISED_1000baseT_Full (1 << 5) -#define ADVERTISED_Autoneg (1 << 6) -#define ADVERTISED_TP (1 << 7) -#define ADVERTISED_AUI (1 << 8) -#define ADVERTISED_MII (1 << 9) -#define ADVERTISED_FIBRE (1 << 10) -#define ADVERTISED_BNC (1 << 11) -#define ADVERTISED_10000baseT_Full (1 << 12) - /* Taken from mii_if_info and sungem_phy.h */ struct uec_mii_info { /* Information about the PHY type */ @@ -184,9 +157,9 @@ struct uec_mii_info { void *priv;
/* Provided by ethernet driver */ - int (*mdio_read) (struct eth_device * dev, int mii_id, int reg); - void (*mdio_write) (struct eth_device * dev, int mii_id, int reg, - int val); + int (*mdio_read)(struct eth_device *dev, int mii_id, int reg); + void (*mdio_write)(struct eth_device *dev, int mii_id, int reg, + int val); };
/* struct phy_info: a structure which defines attributes for a PHY @@ -208,32 +181,34 @@ struct phy_info { u32 features;
/* Called to initialize the PHY */ - int (*init) (struct uec_mii_info * mii_info); + int (*init)(struct uec_mii_info *mii_info);
/* Called to suspend the PHY for power */ - int (*suspend) (struct uec_mii_info * mii_info); + int (*suspend)(struct uec_mii_info *mii_info);
/* Reconfigures autonegotiation (or disables it) */ - int (*config_aneg) (struct uec_mii_info * mii_info); + int (*config_aneg)(struct uec_mii_info *mii_info);
/* Determines the negotiated speed and duplex */ - int (*read_status) (struct uec_mii_info * mii_info); + int (*read_status)(struct uec_mii_info *mii_info);
/* Clears any pending interrupts */ - int (*ack_interrupt) (struct uec_mii_info * mii_info); + int (*ack_interrupt)(struct uec_mii_info *mii_info);
/* Enables or disables interrupts */ - int (*config_intr) (struct uec_mii_info * mii_info); + int (*config_intr)(struct uec_mii_info *mii_info);
/* Clears up any memory if needed */ - void (*close) (struct uec_mii_info * mii_info); + void (*close)(struct uec_mii_info *mii_info); };
-struct phy_info *uec_get_phy_info (struct uec_mii_info *mii_info); -void uec_write_phy_reg (struct eth_device *dev, int mii_id, int regnum, - int value); -int uec_read_phy_reg (struct eth_device *dev, int mii_id, int regnum); -void mii_clear_phy_interrupt (struct uec_mii_info *mii_info); -void mii_configure_phy_interrupt (struct uec_mii_info *mii_info, - u32 interrupts); +struct phy_info *uec_get_phy_info(struct uec_mii_info *mii_info); +void uec_write_phy_reg(struct eth_device *dev, int mii_id, int regnum, + int value); +int uec_read_phy_reg(struct eth_device *dev, int mii_id, int regnum); +void mii_clear_phy_interrupt(struct uec_mii_info *mii_info); +void mii_configure_phy_interrupt(struct uec_mii_info *mii_info, + u32 interrupts); +void change_phy_interface_mode(struct eth_device *dev, + phy_interface_t type, int speed); #endif /* __UEC_PHY_H__ */
add DM support for parallel I/O ports on QUICC Engine Block
Signed-off-by: Heiko Schocher hs@denx.de
--- Open questions / discussion:
- I let the old none DM based implementation in code so boards should work with old implementation.
This should be removed if all boards are converted to DM/DTS.
- Unfortunately linux DTS does not use "pinctrl-" properties, instead "pio-handle" properties.
Even worser old U-Boot code initializes all pins defined in "const qe_iop_conf_t qe_iop_conf_tab[]" table in board code. As linux does the same I decided to also scan through all subnodes containing "pio-map" property and initialize them too.
The proper solution would be to check for "pio-handle" when a device is probed.
Changes in v2: - remove RFC - fixed Codingstyle errors, therefore new patch powerpc, mpc83xx: fix codingstyle issues for qe_io.c - moved DM part to drivers/pinctrl
arch/powerpc/cpu/mpc83xx/Makefile | 2 + arch/powerpc/cpu/mpc83xx/cpu_init.c | 8 + arch/powerpc/cpu/mpc83xx/qe_io.c | 83 ++++++--- drivers/pinctrl/Kconfig | 7 + drivers/pinctrl/Makefile | 1 + drivers/pinctrl/pinctrl-qe-io.c | 255 ++++++++++++++++++++++++++++ include/fsl_qe.h | 3 + 7 files changed, 334 insertions(+), 25 deletions(-) create mode 100644 drivers/pinctrl/pinctrl-qe-io.c
diff --git a/arch/powerpc/cpu/mpc83xx/Makefile b/arch/powerpc/cpu/mpc83xx/Makefile index 304029977e..aeb42b109d 100644 --- a/arch/powerpc/cpu/mpc83xx/Makefile +++ b/arch/powerpc/cpu/mpc83xx/Makefile @@ -27,7 +27,9 @@ obj-y += cpu_init.o obj-y += speed.o obj-y += interrupts.o obj-y += ecc.o +ifndef CONFIG_PINCTRL obj-$(CONFIG_QE) += qe_io.o +endif obj-$(CONFIG_FSL_SERDES) += serdes.o ifndef CONFIG_ARCH_MPC8308 obj-$(CONFIG_PCI) += pci.o diff --git a/arch/powerpc/cpu/mpc83xx/cpu_init.c b/arch/powerpc/cpu/mpc83xx/cpu_init.c index b21b0b0324..840f907acb 100644 --- a/arch/powerpc/cpu/mpc83xx/cpu_init.c +++ b/arch/powerpc/cpu/mpc83xx/cpu_init.c @@ -14,6 +14,9 @@ #include <usb/ehci-ci.h> #endif #include <linux/delay.h> +#ifdef CONFIG_QE +#include <fsl_qe.h> +#endif
#include "lblaw/lblaw.h" #include "elbc/elbc.h" @@ -28,6 +31,7 @@ extern qe_iop_conf_t qe_iop_conf_tab[]; extern void qe_config_iopin(u8 port, u8 pin, int dir, int open_drain, int assign);
+#if !defined(CONFIG_PINCTRL) static void config_qe_ioports(void) { u8 port, pin; @@ -44,6 +48,7 @@ static void config_qe_ioports(void) } } #endif +#endif
/* * Breathe some life into the CPU... @@ -190,10 +195,13 @@ void cpu_init_f (volatile immap_t * im) __raw_writel(CONFIG_SYS_OBIR, &im->sysconf.obir); #endif
+#if !defined(CONFIG_PINCTRL) #ifdef CONFIG_QE /* Config QE ioports */ config_qe_ioports(); #endif +#endif + /* Set up preliminary BR/OR regs */ init_early_memctl_regs();
diff --git a/arch/powerpc/cpu/mpc83xx/qe_io.c b/arch/powerpc/cpu/mpc83xx/qe_io.c index 1079ae128a..52360703a7 100644 --- a/arch/powerpc/cpu/mpc83xx/qe_io.c +++ b/arch/powerpc/cpu/mpc83xx/qe_io.c @@ -12,24 +12,35 @@ #include <asm/immap_83xx.h>
#define NUM_OF_PINS 32 -void qe_config_iopin(u8 port, u8 pin, int dir, int open_drain, int assign) + +/** qe_cfg_iopin configure one io pin setting + * + * @par_io: pointer to parallel I/O base + * @port: io pin port + * @pin: io pin number which get configured + * @dir: direction of io pin 2 bits valid + * 00 = pin disabled + * 01 = output + * 10 = input + * 11 = pin is I/O + * @open_drain: is pin open drain + * @assign: pin assignment registers select the function of the pin + */ +static void qe_cfg_iopin(qepio83xx_t *par_io, u8 port, u8 pin, int dir, + int open_drain, int assign) { - u32 2bit_mask; - u32 2bit_dir; - u32 2bit_assign; - u32 1bit_mask; - u32 tmp_val; - immap_t *im; - qepio83xx_t *par_io; - int offset; + u32 dbit_mask; + u32 dbit_dir; + u32 dbit_asgn; + u32 bit_mask; + u32 tmp_val; + int offset;
- im = (immap_t *)CONFIG_SYS_IMMR; - par_io = (qepio83xx_t *)&im->qepio; offset = (NUM_OF_PINS - (pin % (NUM_OF_PINS / 2) + 1) * 2);
/* Calculate pin location and 2bit mask and dir */ - 2bit_mask = (u32)(0x3 << offset); - 2bit_dir = (u32)(dir << offset); + dbit_mask = (u32)(0x3 << offset); + dbit_dir = (u32)(dir << offset);
/* Setup the direction */ tmp_val = (pin > (NUM_OF_PINS / 2) - 1) ? @@ -37,35 +48,57 @@ void qe_config_iopin(u8 port, u8 pin, int dir, int open_drain, int assign) in_be32(&par_io->ioport[port].dir1);
if (pin > (NUM_OF_PINS / 2) - 1) { - out_be32(&par_io->ioport[port].dir2, ~2bit_mask & tmp_val); - out_be32(&par_io->ioport[port].dir2, 2bit_dir | tmp_val); + out_be32(&par_io->ioport[port].dir2, ~dbit_mask & tmp_val); + out_be32(&par_io->ioport[port].dir2, dbit_dir | tmp_val); } else { - out_be32(&par_io->ioport[port].dir1, ~2bit_mask & tmp_val); - out_be32(&par_io->ioport[port].dir1, 2bit_dir | tmp_val); + out_be32(&par_io->ioport[port].dir1, ~dbit_mask & tmp_val); + out_be32(&par_io->ioport[port].dir1, dbit_dir | tmp_val); }
/* Calculate pin location for 1bit mask */ - 1bit_mask = (u32)(1 << (NUM_OF_PINS - (pin + 1))); + bit_mask = (u32)(1 << (NUM_OF_PINS - (pin + 1)));
/* Setup the open drain */ tmp_val = in_be32(&par_io->ioport[port].podr); if (open_drain) - out_be32(&par_io->ioport[port].podr, 1bit_mask | tmp_val); + out_be32(&par_io->ioport[port].podr, bit_mask | tmp_val); else - out_be32(&par_io->ioport[port].podr, ~1bit_mask & tmp_val); + out_be32(&par_io->ioport[port].podr, ~bit_mask & tmp_val);
/* Setup the assignment */ tmp_val = (pin > (NUM_OF_PINS / 2) - 1) ? in_be32(&par_io->ioport[port].ppar2) : in_be32(&par_io->ioport[port].ppar1); - 2bit_assign = (u32)(assign << offset); + dbit_asgn = (u32)(assign << offset);
/* Clear and set 2 bits mask */ if (pin > (NUM_OF_PINS / 2) - 1) { - out_be32(&par_io->ioport[port].ppar2, ~2bit_mask & tmp_val); - out_be32(&par_io->ioport[port].ppar2, 2bit_assign | tmp_val); + out_be32(&par_io->ioport[port].ppar2, ~dbit_mask & tmp_val); + out_be32(&par_io->ioport[port].ppar2, dbit_asgn | tmp_val); } else { - out_be32(&par_io->ioport[port].ppar1, ~2bit_mask & tmp_val); - out_be32(&par_io->ioport[port].ppar1, 2bit_assign | tmp_val); + out_be32(&par_io->ioport[port].ppar1, ~dbit_mask & tmp_val); + out_be32(&par_io->ioport[port].ppar1, dbit_asgn | tmp_val); } } + +#if !defined(CONFIG_PINCTRL) +/** qe_config_iopin configure one io pin setting + * + * @port: io pin port + * @pin: io pin number which get configured + * @dir: direction of io pin 2 bits valid + * 00 = pin disabled + * 01 = output + * 10 = input + * 11 = pin is I/O + * @open_drain: is pin open drain + * @assign: pin assignment registers select the function of the pin + */ +void qe_config_iopin(u8 port, u8 pin, int dir, int open_drain, int assign) +{ + immap_t *im = (immap_t *)CONFIG_SYS_IMMR; + qepio83xx_t *par_io = (qepio83xx_t *)&im->qepio; + + qe_cfg_iopin(par_io, port, pin, dir, open_drain, assign); +} +#endif diff --git a/drivers/pinctrl/Kconfig b/drivers/pinctrl/Kconfig index 83e39b9de3..06df148b06 100644 --- a/drivers/pinctrl/Kconfig +++ b/drivers/pinctrl/Kconfig @@ -205,6 +205,13 @@ config PINCTRL_QCA953X the GPIO definitions and pin control functions for each available multiplex function.
+config PINCTRL_QE + bool "QE based pinctrl driver, like on mpc83xx" + depends on DM + help + This option is to enable the QE pinctrl driver for QE based io + controller. + config PINCTRL_ROCKCHIP_RV1108 bool "Rockchip rv1108 pin control driver" depends on DM diff --git a/drivers/pinctrl/Makefile b/drivers/pinctrl/Makefile index 4f662c4f6d..7b9a672198 100644 --- a/drivers/pinctrl/Makefile +++ b/drivers/pinctrl/Makefile @@ -21,6 +21,7 @@ obj-$(CONFIG_PINCTRL_MESON) += meson/ obj-$(CONFIG_PINCTRL_MTK) += mediatek/ obj-$(CONFIG_PINCTRL_MSCC) += mscc/ obj-$(CONFIG_ARCH_MVEBU) += mvebu/ +obj-$(CONFIG_PINCTRL_QE) += pinctrl-qe-io.o obj-$(CONFIG_PINCTRL_SINGLE) += pinctrl-single.o obj-$(CONFIG_PINCTRL_STI) += pinctrl-sti.o obj-$(CONFIG_PINCTRL_STM32) += pinctrl_stm32.o diff --git a/drivers/pinctrl/pinctrl-qe-io.c b/drivers/pinctrl/pinctrl-qe-io.c new file mode 100644 index 0000000000..85521eabd4 --- /dev/null +++ b/drivers/pinctrl/pinctrl-qe-io.c @@ -0,0 +1,255 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2006 Freescale Semiconductor, Inc. + * + * Dave Liu daveliu@freescale.com + * based on source code of Shlomi Gridish + */ + +#include <common.h> +#include <linux/errno.h> +#include <asm/io.h> +#include <asm/immap_83xx.h> + +#if defined(CONFIG_PINCTRL) +#include <dm.h> +#include <dm/device_compat.h> +#include <dm/pinctrl.h> +#include <linux/ioport.h> + +/** + * struct qe_io_platdata + * + * @base: Base register address + * @num_par_io_ports number of io ports + */ +struct qe_io_platdata { + qepio83xx_t *base; + u32 num_io_ports; +}; +#endif + +#define NUM_OF_PINS 32 + +/** qe_cfg_iopin configure one io pin setting + * + * @par_io: pointer to parallel I/O base + * @port: io pin port + * @pin: io pin number which get configured + * @dir: direction of io pin 2 bits valid + * 00 = pin disabled + * 01 = output + * 10 = input + * 11 = pin is I/O + * @open_drain: is pin open drain + * @assign: pin assignment registers select the function of the pin + */ +static void qe_cfg_iopin(qepio83xx_t *par_io, u8 port, u8 pin, int dir, + int open_drain, int assign) +{ + u32 dbit_mask; + u32 dbit_dir; + u32 dbit_asgn; + u32 bit_mask; + u32 tmp_val; + int offset; + + offset = (NUM_OF_PINS - (pin % (NUM_OF_PINS / 2) + 1) * 2); + + /* Calculate pin location and 2bit mask and dir */ + dbit_mask = (u32)(0x3 << offset); + dbit_dir = (u32)(dir << offset); + + /* Setup the direction */ + tmp_val = (pin > (NUM_OF_PINS / 2) - 1) ? + in_be32(&par_io->ioport[port].dir2) : + in_be32(&par_io->ioport[port].dir1); + + if (pin > (NUM_OF_PINS / 2) - 1) { + out_be32(&par_io->ioport[port].dir2, ~dbit_mask & tmp_val); + out_be32(&par_io->ioport[port].dir2, dbit_dir | tmp_val); + } else { + out_be32(&par_io->ioport[port].dir1, ~dbit_mask & tmp_val); + out_be32(&par_io->ioport[port].dir1, dbit_dir | tmp_val); + } + + /* Calculate pin location for 1bit mask */ + bit_mask = (u32)(1 << (NUM_OF_PINS - (pin + 1))); + + /* Setup the open drain */ + tmp_val = in_be32(&par_io->ioport[port].podr); + if (open_drain) + out_be32(&par_io->ioport[port].podr, bit_mask | tmp_val); + else + out_be32(&par_io->ioport[port].podr, ~bit_mask & tmp_val); + + /* Setup the assignment */ + tmp_val = (pin > (NUM_OF_PINS / 2) - 1) ? + in_be32(&par_io->ioport[port].ppar2) : + in_be32(&par_io->ioport[port].ppar1); + dbit_asgn = (u32)(assign << offset); + + /* Clear and set 2 bits mask */ + if (pin > (NUM_OF_PINS / 2) - 1) { + out_be32(&par_io->ioport[port].ppar2, ~dbit_mask & tmp_val); + out_be32(&par_io->ioport[port].ppar2, dbit_asgn | tmp_val); + } else { + out_be32(&par_io->ioport[port].ppar1, ~dbit_mask & tmp_val); + out_be32(&par_io->ioport[port].ppar1, dbit_asgn | tmp_val); + } +} + +#if !defined(CONFIG_PINCTRL) +/** qe_config_iopin configure one io pin setting + * + * @port: io pin port + * @pin: io pin number which get configured + * @dir: direction of io pin 2 bits valid + * 00 = pin disabled + * 01 = output + * 10 = input + * 11 = pin is I/O + * @open_drain: is pin open drain + * @assign: pin assignment registers select the function of the pin + */ +void qe_config_iopin(u8 port, u8 pin, int dir, int open_drain, int assign) +{ + immap_t *im = (immap_t *)CONFIG_SYS_IMMR; + qepio83xx_t *par_io = (qepio83xx_t *)&im->qepio; + + qe_cfg_iopin(par_io, port, pin, dir, open_drain, assign); +} +#else +static int qe_io_ofdata_to_platdata(struct udevice *dev) +{ + struct qe_io_platdata *plat = dev->platdata; + fdt_addr_t addr; + + addr = dev_read_addr(dev); + if (addr == FDT_ADDR_T_NONE) + return -EINVAL; + + plat->base = (qepio83xx_t *)addr; + if (dev_read_u32(dev, "num-ports", &plat->num_io_ports)) + return -EINVAL; + + return 0; +} + +/** + * par_io_of_config_node config + * @dev: pointer to pinctrl device + * @pio: ofnode of pinconfig property + */ +static int par_io_of_config_node(struct udevice *dev, ofnode pio) +{ + struct qe_io_platdata *plat = dev->platdata; + qepio83xx_t *par_io = plat->base; + const unsigned int *pio_map; + int pio_map_len; + + pio_map = ofnode_get_property(pio, "pio-map", &pio_map_len); + if (!pio_map) + return -ENOENT; + + pio_map_len /= sizeof(unsigned int); + if ((pio_map_len % 6) != 0) { + dev_err(dev, "%s: pio-map format wrong!\n", __func__); + return -EINVAL; + } + + while (pio_map_len > 0) { + /* + * column pio_map[5] from linux (has_irq) not + * supported in u-boot yet. + */ + qe_cfg_iopin(par_io, (u8)pio_map[0], (u8)pio_map[1], + (int)pio_map[2], (int)pio_map[3], + (int)pio_map[4]); + pio_map += 6; + pio_map_len -= 6; + } + return 0; +} + +int par_io_of_config(struct udevice *dev) +{ + u32 phandle; + ofnode pio; + int err; + + err = ofnode_read_u32(dev_ofnode(dev), "pio-handle", &phandle); + if (err) { + dev_err(dev, "%s: pio-handle not available\n", __func__); + return err; + } + + pio = ofnode_get_by_phandle(phandle); + if (!ofnode_valid(pio)) { + dev_err(dev, "%s: unable to find node\n", __func__); + return -EINVAL; + } + + /* To Do: find pinctrl device and pass it */ + return par_io_of_config_node(NULL, pio); +} + +/* + * This is not nice! + * pinsettings should work with "pinctrl-" properties. + * Unfortunately on mpc83xx powerpc linux device trees + * devices handle this with "pio-handle" properties ... + * + * Even worser, old board code inits all par_io + * pins in one step, if U-Boot uses the device + * or not. So init all par_io definitions here too + * as linux does this also. + */ +static void config_qe_ioports(struct udevice *dev) +{ + ofnode ofn; + + for (ofn = dev_read_first_subnode(dev); ofnode_valid(ofn); + ofn = dev_read_next_subnode(ofn)) { + /* + * ignore errors here, as may the subnode + * has no pio-handle + */ + par_io_of_config_node(dev, ofn); + } +} + +static int par_io_pinctrl_probe(struct udevice *dev) +{ + config_qe_ioports(dev); + + return 0; +} + +static int par_io_pinctrl_set_state(struct udevice *dev, struct udevice *config) +{ + return 0; +} + +const struct pinctrl_ops par_io_pinctrl_ops = { + .set_state = par_io_pinctrl_set_state, +}; + +static const struct udevice_id par_io_pinctrl_match[] = { + { .compatible = "fsl,mpc8360-par_io"}, + { /* sentinel */ } +}; + +U_BOOT_DRIVER(par_io_pinctrl) = { + .name = "par-io-pinctrl", + .id = UCLASS_PINCTRL, + .of_match = of_match_ptr(par_io_pinctrl_match), + .probe = par_io_pinctrl_probe, + .ofdata_to_platdata = qe_io_ofdata_to_platdata, + .platdata_auto_alloc_size = sizeof(struct qe_io_platdata), + .ops = &par_io_pinctrl_ops, +#if CONFIG_IS_ENABLED(OF_CONTROL) && !CONFIG_IS_ENABLED(OF_PLATDATA) + .flags = DM_FLAG_PRE_RELOC, +#endif +}; +#endif diff --git a/include/fsl_qe.h b/include/fsl_qe.h index 6e44cbdb56..1c6941347f 100644 --- a/include/fsl_qe.h +++ b/include/fsl_qe.h @@ -296,4 +296,7 @@ int u_qe_firmware_resume(const struct qe_firmware *firmware, qe_map_t *qe_immrr); #endif
+#if defined(CONFIG_PINCTRL) +int par_io_of_config(struct udevice *dev); +#endif #endif /* __QE_H__ */
add DM/DTS support for the UEC ethernet on QUICC Engine Block.
- I let the old none DM based implementation in code so boards should work with old implementation. This Code should be removed if all boards are converted to DM/DTS.
- add the DM based qe uec driver under drivers/net/qe
- Therefore copied the files uccf.c uccf.h uec.h from drivers/qe. So there are a lot of Codingstyle problems currently. I fix them in next version if this RFC patch is OK or it needs some changes.
- The dm based driver code is now under drivers/net/qe/dm_qe_uec.c Used a lot of functions from drivers/qe/uec.c
- seperated the PHY specific code into seperate file drivers/net/qe/dm_qe_uec_phy.c
Changes in v2: - add comments from Qiang Zhao: - add device node documentation - I did not drop the dm_qe_uec_phy.c and use drivers/net/fsl_mdio.c because using drivers/net/fsl_mdio.c leads in none existent udevice mdio@3320 instead boards with DM ETH support should use now this driver. - remove RFC tag
.../soc/fsl/cpm_qe/qe/ucc.txt | 53 + drivers/net/Kconfig | 2 + drivers/net/Makefile | 1 + drivers/net/qe/Kconfig | 9 + drivers/net/qe/Makefile | 5 + drivers/net/qe/dm_qe_uec.c | 1167 +++++++++++++++++ drivers/net/qe/dm_qe_uec.h | 22 + drivers/net/qe/dm_qe_uec_phy.c | 163 +++ drivers/net/qe/uccf.c | 507 +++++++ drivers/net/qe/uccf.h | 119 ++ drivers/net/qe/uec.h | 693 ++++++++++ drivers/qe/uccf.c | 2 + drivers/qe/uec.c | 2 + drivers/qe/uec_phy.c | 3 + 14 files changed, 2748 insertions(+) create mode 100644 doc/device-tree-bindings/soc/fsl/cpm_qe/qe/ucc.txt create mode 100644 drivers/net/qe/Kconfig create mode 100644 drivers/net/qe/Makefile create mode 100644 drivers/net/qe/dm_qe_uec.c create mode 100644 drivers/net/qe/dm_qe_uec.h create mode 100644 drivers/net/qe/dm_qe_uec_phy.c create mode 100644 drivers/net/qe/uccf.c create mode 100644 drivers/net/qe/uccf.h create mode 100644 drivers/net/qe/uec.h
diff --git a/doc/device-tree-bindings/soc/fsl/cpm_qe/qe/ucc.txt b/doc/device-tree-bindings/soc/fsl/cpm_qe/qe/ucc.txt new file mode 100644 index 0000000000..2758f86437 --- /dev/null +++ b/doc/device-tree-bindings/soc/fsl/cpm_qe/qe/ucc.txt @@ -0,0 +1,53 @@ +* UCC (Unified Communications Controllers) + +Required properties: +- compatible : ucc_geth +- cell-index : the ucc number(1-8), corresponding to UCCx in UM. +- reg : Offset and length of the register set for the device +- rx-clock-name: the UCC receive clock source + "none": clock source is disabled + "brg1" through "brg16": clock source is BRG1-BRG16, respectively + "clk1" through "clk24": clock source is CLK1-CLK24, respectively +- tx-clock-name: the UCC transmit clock source + "none": clock source is disabled + "brg1" through "brg16": clock source is BRG1-BRG16, respectively + "clk1" through "clk24": clock source is CLK1-CLK24, respectively +The following two properties are deprecated. rx-clock has been replaced +with rx-clock-name, and tx-clock has been replaced with tx-clock-name. +Drivers that currently use the deprecated properties should continue to +do so, in order to support older device trees, but they should be updated +to check for the new properties first. +- rx-clock : represents the UCC receive clock source. + 0x00 : clock source is disabled; + 0x1~0x10 : clock source is BRG1~BRG16 respectively; + 0x11~0x28: clock source is QE_CLK1~QE_CLK24 respectively. +- tx-clock: represents the UCC transmit clock source; + 0x00 : clock source is disabled; + 0x1~0x10 : clock source is BRG1~BRG16 respectively; + 0x11~0x28: clock source is QE_CLK1~QE_CLK24 respectively. +- phy-handle : The phandle for the PHY connected to this controller. +- phy-connection-type : a string naming the controller/PHY interface type, + i.e., "mii" (default), "rmii", "gmii", "rgmii", "rgmii-id" (Internal + Delay), "rgmii-txid" (delay on TX only), "rgmii-rxid" (delay on RX only), + "tbi", or "rtbi". +- pio-handle : The phandle for the Parallel I/O port configuration. + +Deprecated properties: +- device-id : the ucc number(1-8), corresponding to UCCx in UM. + you should use cell-index + +Example: + ucc@2000 { + device_type = "network"; + compatible = "ucc_geth"; + cell-index = <1>; + reg = <2000 200>; + interrupts = <a0 0>; + interrupt-parent = <700>; + mac-address = [ 00 04 9f 00 23 23 ]; + rx-clock = "none"; + tx-clock = "clk9"; + phy-handle = <212000>; + phy-connection-type = "gmii"; + pio-handle = <140001>; + }; diff --git a/drivers/net/Kconfig b/drivers/net/Kconfig index 0b08de0ef4..f984f09450 100644 --- a/drivers/net/Kconfig +++ b/drivers/net/Kconfig @@ -391,6 +391,8 @@ config MII help Enable support of the Media-Independent Interface (MII)
+source "drivers/net/qe/Kconfig" + config RTL8139 bool "Realtek 8139 series Ethernet controller driver" help diff --git a/drivers/net/Makefile b/drivers/net/Makefile index 383ed1c64f..6f8957f521 100644 --- a/drivers/net/Makefile +++ b/drivers/net/Makefile @@ -77,6 +77,7 @@ obj-$(CONFIG_VSC9953) += vsc9953.o obj-$(CONFIG_PIC32_ETH) += pic32_mdio.o pic32_eth.o obj-$(CONFIG_DWC_ETH_QOS) += dwc_eth_qos.o obj-$(CONFIG_FSL_PFE) += pfe_eth/ +obj-y += qe/ obj-$(CONFIG_SNI_AVE) += sni_ave.o obj-y += ti/ obj-$(CONFIG_MEDIATEK_ETH) += mtk_eth.o diff --git a/drivers/net/qe/Kconfig b/drivers/net/qe/Kconfig new file mode 100644 index 0000000000..dec88dea2a --- /dev/null +++ b/drivers/net/qe/Kconfig @@ -0,0 +1,9 @@ +# SPDX-License-Identifier: GPL-2.0+ +# +# Copyright (C) 2020 Heiko Schocher hs@denx.de + +config QE_UEC + bool "NXP QE UEC Ethernet controller" + depends on DM_ETH + help + This driver supports the NXP QE UEC ethernet controller diff --git a/drivers/net/qe/Makefile b/drivers/net/qe/Makefile new file mode 100644 index 0000000000..7d84757c17 --- /dev/null +++ b/drivers/net/qe/Makefile @@ -0,0 +1,5 @@ +# SPDX-License-Identifier: GPL-2.0+ +# +# Copyright (C) 2020 Heiko Schocher hs@denx.de + +obj-$(CONFIG_QE_UEC) += dm_qe_uec.o dm_qe_uec_phy.o uccf.o diff --git a/drivers/net/qe/dm_qe_uec.c b/drivers/net/qe/dm_qe_uec.c new file mode 100644 index 0000000000..3482b3ff17 --- /dev/null +++ b/drivers/net/qe/dm_qe_uec.c @@ -0,0 +1,1167 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * QE UEC ethernet controller driver + * + * based on drivers/qe/uec.c from NXP + * + * Copyright (C) 2020 Heiko Schocher hs@denx.de + */ + +#include <common.h> +#include <dm.h> +#include <errno.h> +#include <memalign.h> +#include <miiphy.h> +#include <asm/io.h> + +#include "dm_qe_uec.h" + +#define QE_UEC_DRIVER_NAME "ucc_geth" + +/* Default UTBIPAR SMI address */ +#ifndef CONFIG_UTBIPAR_INIT_TBIPA +#define CONFIG_UTBIPAR_INIT_TBIPA 0x1F +#endif + +static int uec_mac_enable(struct uec_priv *uec, comm_dir_e mode) +{ + uec_t *uec_regs; + u32 maccfg1; + + uec_regs = uec->uec_regs; + maccfg1 = in_be32(&uec_regs->maccfg1); + + if (mode & COMM_DIR_TX) { + maccfg1 |= MACCFG1_ENABLE_TX; + out_be32(&uec_regs->maccfg1, maccfg1); + uec->mac_tx_enabled = 1; + } + + if (mode & COMM_DIR_RX) { + maccfg1 |= MACCFG1_ENABLE_RX; + out_be32(&uec_regs->maccfg1, maccfg1); + uec->mac_rx_enabled = 1; + } + + return 0; +} + +static int uec_mac_disable(struct uec_priv *uec, comm_dir_e mode) +{ + uec_t *uec_regs; + u32 maccfg1; + + uec_regs = uec->uec_regs; + maccfg1 = in_be32(&uec_regs->maccfg1); + + if (mode & COMM_DIR_TX) { + maccfg1 &= ~MACCFG1_ENABLE_TX; + out_be32(&uec_regs->maccfg1, maccfg1); + uec->mac_tx_enabled = 0; + } + + if (mode & COMM_DIR_RX) { + maccfg1 &= ~MACCFG1_ENABLE_RX; + out_be32(&uec_regs->maccfg1, maccfg1); + uec->mac_rx_enabled = 0; + } + + return 0; +} + +static int uec_restart_tx(struct uec_priv *uec) +{ + struct uec_inf *ui = uec->uec_info; + u32 cecr_subblock; + + cecr_subblock = ucc_fast_get_qe_cr_subblock(ui->uf_info.ucc_num); + qe_issue_cmd(QE_RESTART_TX, cecr_subblock, + (u8)QE_CR_PROTOCOL_ETHERNET, 0); + + uec->grace_stopped_tx = 0; + + return 0; +} + +static int uec_restart_rx(struct uec_priv *uec) +{ + struct uec_inf *ui = uec->uec_info; + u32 cecr_subblock; + + cecr_subblock = ucc_fast_get_qe_cr_subblock(ui->uf_info.ucc_num); + qe_issue_cmd(QE_RESTART_RX, cecr_subblock, + (u8)QE_CR_PROTOCOL_ETHERNET, 0); + + uec->grace_stopped_rx = 0; + + return 0; +} + +static int uec_open(struct uec_priv *uec, comm_dir_e mode) +{ + struct ucc_fast_priv *uccf; + + uccf = uec->uccf; + + /* check if the UCC number is in range. */ + if (uec->uec_info->uf_info.ucc_num >= UCC_MAX_NUM) { + printf("%s: ucc_num out of range.\n", __func__); + return -EINVAL; + } + + /* Enable MAC */ + uec_mac_enable(uec, mode); + + /* Enable UCC fast */ + ucc_fast_enable(uccf, mode); + + /* RISC microcode start */ + if ((mode & COMM_DIR_TX) && uec->grace_stopped_tx) + uec_restart_tx(uec); + + if ((mode & COMM_DIR_RX) && uec->grace_stopped_rx) + uec_restart_rx(uec); + + return 0; +} + +static int uec_set_mac_if_mode(struct uec_priv *uec) +{ + struct uec_inf *uec_info = uec->uec_info; + phy_interface_t enet_if_mode; + uec_t *uec_regs; + u32 upsmr; + u32 maccfg2; + + uec_regs = uec->uec_regs; + enet_if_mode = uec_info->enet_interface_type; + + maccfg2 = in_be32(&uec_regs->maccfg2); + maccfg2 &= ~MACCFG2_INTERFACE_MODE_MASK; + + upsmr = in_be32(&uec->uccf->uf_regs->upsmr); + upsmr &= ~(UPSMR_RPM | UPSMR_TBIM | UPSMR_R10M | UPSMR_RMM); + + switch (uec_info->speed) { + case SPEED_10: + maccfg2 |= MACCFG2_INTERFACE_MODE_NIBBLE; + switch (enet_if_mode) { + case PHY_INTERFACE_MODE_MII: + break; + case PHY_INTERFACE_MODE_RGMII: + upsmr |= (UPSMR_RPM | UPSMR_R10M); + break; + case PHY_INTERFACE_MODE_RMII: + upsmr |= (UPSMR_R10M | UPSMR_RMM); + break; + default: + return -EINVAL; + } + break; + case SPEED_100: + maccfg2 |= MACCFG2_INTERFACE_MODE_NIBBLE; + switch (enet_if_mode) { + case PHY_INTERFACE_MODE_MII: + break; + case PHY_INTERFACE_MODE_RGMII: + upsmr |= UPSMR_RPM; + break; + case PHY_INTERFACE_MODE_RMII: + upsmr |= UPSMR_RMM; + break; + default: + return -EINVAL; + } + break; + case SPEED_1000: + maccfg2 |= MACCFG2_INTERFACE_MODE_BYTE; + switch (enet_if_mode) { + case PHY_INTERFACE_MODE_GMII: + break; + case PHY_INTERFACE_MODE_TBI: + upsmr |= UPSMR_TBIM; + break; + case PHY_INTERFACE_MODE_RTBI: + upsmr |= (UPSMR_RPM | UPSMR_TBIM); + break; + case PHY_INTERFACE_MODE_RGMII_RXID: + case PHY_INTERFACE_MODE_RGMII_TXID: + case PHY_INTERFACE_MODE_RGMII_ID: + case PHY_INTERFACE_MODE_RGMII: + upsmr |= UPSMR_RPM; + break; + case PHY_INTERFACE_MODE_SGMII: + upsmr |= UPSMR_SGMM; + break; + default: + return -EINVAL; + } + break; + default: + return -EINVAL; + } + + out_be32(&uec_regs->maccfg2, maccfg2); + out_be32(&uec->uccf->uf_regs->upsmr, upsmr); + + return 0; +} + +static int qe_uec_start(struct udevice *dev) +{ + struct qe_uec_priv *priv = dev_get_priv(dev); + struct uec_priv *uec = priv->uec; + struct phy_device *phydev = priv->phydev; + struct uec_inf *uec_info = uec->uec_info; + int err; + + if (!phydev) + return -ENODEV; + + /* Setup MAC interface mode */ + genphy_update_link(phydev); + genphy_parse_link(phydev); + uec_info->speed = phydev->speed; + uec_set_mac_if_mode(uec); + + err = uec_open(uec, COMM_DIR_RX_AND_TX); + if (err) { + printf("%s: cannot enable UEC device\n", dev->name); + return -EINVAL; + } + + return (phydev->link ? 0 : -EINVAL); +} + +static int qe_uec_send(struct udevice *dev, void *packet, int length) +{ + struct qe_uec_priv *priv = dev_get_priv(dev); + struct uec_priv *uec = priv->uec; + struct ucc_fast_priv *uccf = uec->uccf; + struct buffer_descriptor *bd; + u16 status; + int i; + int result = 0; + + uccf = uec->uccf; + bd = uec->tx_bd; + + /* Find an empty TxBD */ + for (i = 0; BD_STATUS(bd) & TX_BD_READY; i++) { + if (i > 0x100000) { + printf("%s: tx buffer not ready\n", dev->name); + return result; + } + } + + /* Init TxBD */ + BD_DATA_SET(bd, packet); + BD_LENGTH_SET(bd, length); + status = BD_STATUS(bd); + status &= BD_WRAP; + status |= (TX_BD_READY | TX_BD_LAST); + BD_STATUS_SET(bd, status); + + /* Tell UCC to transmit the buffer */ + ucc_fast_transmit_on_demand(uccf); + + /* Wait for buffer to be transmitted */ + for (i = 0; BD_STATUS(bd) & TX_BD_READY; i++) { + if (i > 0x100000) { + printf("%s: tx error\n", dev->name); + return result; + } + } + + /* Ok, the buffer be transimitted */ + BD_ADVANCE(bd, status, uec->p_tx_bd_ring); + uec->tx_bd = bd; + result = 1; + + return result; +} + +/* + * Receive frame: + * - wait for the next BD to get ready bit set + * - clean up the descriptor + * - move on and indicate to HW that the cleaned BD is available for Rx + */ +static int qe_uec_recv(struct udevice *dev, int flags, uchar **packetp) +{ + struct qe_uec_priv *priv = dev_get_priv(dev); + struct uec_priv *uec = priv->uec; + struct buffer_descriptor *bd; + u16 status; + u16 len = 0; + u8 *data; + + *packetp = memalign(ARCH_DMA_MINALIGN, MAX_RXBUF_LEN); + if (*packetp == 0) { + printf("%s: error allocating packetp\n", __func__); + return -ENOMEM; + } + + bd = uec->rx_bd; + status = BD_STATUS(bd); + + while (!(status & RX_BD_EMPTY)) { + if (!(status & RX_BD_ERROR)) { + data = BD_DATA(bd); + len = BD_LENGTH(bd); + memcpy(*packetp, (char *)data, len); + } else { + printf("%s: Rx error\n", dev->name); + } + status &= BD_CLEAN; + BD_LENGTH_SET(bd, 0); + BD_STATUS_SET(bd, status | RX_BD_EMPTY); + BD_ADVANCE(bd, status, uec->p_rx_bd_ring); + status = BD_STATUS(bd); + } + uec->rx_bd = bd; + + return len; +} + +static int uec_graceful_stop_tx(struct uec_priv *uec) +{ + ucc_fast_t *uf_regs; + u32 cecr_subblock; + u32 ucce; + + uf_regs = uec->uccf->uf_regs; + + /* Clear the grace stop event */ + out_be32(&uf_regs->ucce, UCCE_GRA); + + /* Issue host command */ + cecr_subblock = + ucc_fast_get_qe_cr_subblock(uec->uec_info->uf_info.ucc_num); + qe_issue_cmd(QE_GRACEFUL_STOP_TX, cecr_subblock, + (u8)QE_CR_PROTOCOL_ETHERNET, 0); + + /* Wait for command to complete */ + do { + ucce = in_be32(&uf_regs->ucce); + } while (!(ucce & UCCE_GRA)); + + uec->grace_stopped_tx = 1; + + return 0; +} + +static int uec_graceful_stop_rx(struct uec_priv *uec) +{ + u32 cecr_subblock; + u8 ack; + + if (!uec->p_rx_glbl_pram) { + printf("%s: No init rx global parameter\n", __func__); + return -EINVAL; + } + + /* Clear acknowledge bit */ + ack = uec->p_rx_glbl_pram->rxgstpack; + ack &= ~GRACEFUL_STOP_ACKNOWLEDGE_RX; + uec->p_rx_glbl_pram->rxgstpack = ack; + + /* Keep issuing cmd and checking ack bit until it is asserted */ + do { + /* Issue host command */ + cecr_subblock = + ucc_fast_get_qe_cr_subblock(uec->uec_info->uf_info.ucc_num); + qe_issue_cmd(QE_GRACEFUL_STOP_RX, cecr_subblock, + (u8)QE_CR_PROTOCOL_ETHERNET, 0); + ack = uec->p_rx_glbl_pram->rxgstpack; + } while (!(ack & GRACEFUL_STOP_ACKNOWLEDGE_RX)); + + uec->grace_stopped_rx = 1; + + return 0; +} + +static int uec_stop(struct uec_priv *uec, comm_dir_e mode) +{ + /* check if the UCC number is in range. */ + if (uec->uec_info->uf_info.ucc_num >= UCC_MAX_NUM) { + printf("%s: ucc_num out of range.\n", __func__); + return -EINVAL; + } + /* Stop any transmissions */ + if ((mode & COMM_DIR_TX) && !uec->grace_stopped_tx) + uec_graceful_stop_tx(uec); + + /* Stop any receptions */ + if ((mode & COMM_DIR_RX) && !uec->grace_stopped_rx) + uec_graceful_stop_rx(uec); + + /* Disable the UCC fast */ + ucc_fast_disable(uec->uccf, mode); + + /* Disable the MAC */ + uec_mac_disable(uec, mode); + + return 0; +} + +static void qe_uec_stop(struct udevice *dev) +{ + struct qe_uec_priv *priv = dev_get_priv(dev); + struct uec_priv *uec = priv->uec; + + uec_stop(uec, COMM_DIR_RX_AND_TX); +} + +static int qe_uec_set_hwaddr(struct udevice *dev) +{ + struct qe_uec_priv *priv = dev_get_priv(dev); + struct eth_pdata *pdata = dev_get_platdata(dev); + struct uec_priv *uec = priv->uec; + uec_t *uec_regs = uec->uec_regs; + uchar *mac = pdata->enetaddr; + u32 mac_addr1; + u32 mac_addr2; + + /* + * if a station address of 0x12345678ABCD, perform a write to + * MACSTNADDR1 of 0xCDAB7856, + * MACSTNADDR2 of 0x34120000 + */ + + mac_addr1 = (mac[5] << 24) | (mac[4] << 16) | + (mac[3] << 8) | (mac[2]); + out_be32(&uec_regs->macstnaddr1, mac_addr1); + + mac_addr2 = ((mac[1] << 24) | (mac[0] << 16)) & 0xffff0000; + out_be32(&uec_regs->macstnaddr2, mac_addr2); + + return 0; +} + +static int qe_uec_free_pkt(struct udevice *dev, uchar *packet, int length) +{ + if (packet) + free(packet); + + return 0; +} + +static const struct eth_ops qe_uec_eth_ops = { + .start = qe_uec_start, + .send = qe_uec_send, + .recv = qe_uec_recv, + .free_pkt = qe_uec_free_pkt, + .stop = qe_uec_stop, + .write_hwaddr = qe_uec_set_hwaddr, +}; + +static int uec_convert_threads_num(enum uec_num_of_threads threads_num, + int *threads_num_ret) +{ + int num_threads_numerica; + + switch (threads_num) { + case UEC_NUM_OF_THREADS_1: + num_threads_numerica = 1; + break; + case UEC_NUM_OF_THREADS_2: + num_threads_numerica = 2; + break; + case UEC_NUM_OF_THREADS_4: + num_threads_numerica = 4; + break; + case UEC_NUM_OF_THREADS_6: + num_threads_numerica = 6; + break; + case UEC_NUM_OF_THREADS_8: + num_threads_numerica = 8; + break; + default: + printf("%s: Bad number of threads value.", + __func__); + return -EINVAL; + } + + *threads_num_ret = num_threads_numerica; + + return 0; +} + +static void uec_init_tx_parameter(struct uec_priv *uec, int num_threads_tx) +{ + struct uec_inf *uec_info; + u32 end_bd; + u8 bmrx = 0; + int i; + + uec_info = uec->uec_info; + + /* Alloc global Tx parameter RAM page */ + uec->tx_glbl_pram_offset = + qe_muram_alloc(sizeof(struct uec_tx_global_pram), + UEC_TX_GLOBAL_PRAM_ALIGNMENT); + uec->p_tx_glbl_pram = (struct uec_tx_global_pram *) + qe_muram_addr(uec->tx_glbl_pram_offset); + + /* Zero the global Tx prameter RAM */ + memset(uec->p_tx_glbl_pram, 0, sizeof(struct uec_tx_global_pram)); + + /* Init global Tx parameter RAM */ + + /* TEMODER, RMON statistics disable, one Tx queue */ + out_be16(&uec->p_tx_glbl_pram->temoder, TEMODER_INIT_VALUE); + + /* SQPTR */ + uec->send_q_mem_reg_offset = + qe_muram_alloc(sizeof(struct uec_send_queue_qd), + UEC_SEND_QUEUE_QUEUE_DESCRIPTOR_ALIGNMENT); + uec->p_send_q_mem_reg = (struct uec_send_queue_mem_region *) + qe_muram_addr(uec->send_q_mem_reg_offset); + out_be32(&uec->p_tx_glbl_pram->sqptr, uec->send_q_mem_reg_offset); + + /* Setup the table with TxBDs ring */ + end_bd = (u32)uec->p_tx_bd_ring + (uec_info->tx_bd_ring_len - 1) + * SIZEOFBD; + out_be32(&uec->p_send_q_mem_reg->sqqd[0].bd_ring_base, + (u32)(uec->p_tx_bd_ring)); + out_be32(&uec->p_send_q_mem_reg->sqqd[0].last_bd_completed_address, + end_bd); + + /* Scheduler Base Pointer, we have only one Tx queue, no need it */ + out_be32(&uec->p_tx_glbl_pram->schedulerbasepointer, 0); + + /* TxRMON Base Pointer, TxRMON disable, we don't need it */ + out_be32(&uec->p_tx_glbl_pram->txrmonbaseptr, 0); + + /* TSTATE, global snooping, big endian, the CSB bus selected */ + bmrx = BMR_INIT_VALUE; + out_be32(&uec->p_tx_glbl_pram->tstate, ((u32)(bmrx) << BMR_SHIFT)); + + /* IPH_Offset */ + for (i = 0; i < MAX_IPH_OFFSET_ENTRY; i++) + out_8(&uec->p_tx_glbl_pram->iphoffset[i], 0); + + /* VTAG table */ + for (i = 0; i < UEC_TX_VTAG_TABLE_ENTRY_MAX; i++) + out_be32(&uec->p_tx_glbl_pram->vtagtable[i], 0); + + /* TQPTR */ + uec->thread_dat_tx_offset = + qe_muram_alloc(num_threads_tx * + sizeof(struct uec_thread_data_tx) + + 32 * (num_threads_tx == 1), + UEC_THREAD_DATA_ALIGNMENT); + + uec->p_thread_data_tx = (struct uec_thread_data_tx *) + qe_muram_addr(uec->thread_dat_tx_offset); + out_be32(&uec->p_tx_glbl_pram->tqptr, uec->thread_dat_tx_offset); +} + +static void uec_init_rx_parameter(struct uec_priv *uec, int num_threads_rx) +{ + u8 bmrx = 0; + int i; + struct uec_82xx_add_filtering_pram *p_af_pram; + + /* Allocate global Rx parameter RAM page */ + uec->rx_glbl_pram_offset = + qe_muram_alloc(sizeof(struct uec_rx_global_pram), + UEC_RX_GLOBAL_PRAM_ALIGNMENT); + uec->p_rx_glbl_pram = (struct uec_rx_global_pram *) + qe_muram_addr(uec->rx_glbl_pram_offset); + + /* Zero Global Rx parameter RAM */ + memset(uec->p_rx_glbl_pram, 0, sizeof(struct uec_rx_global_pram)); + + /* Init global Rx parameter RAM */ + /* + * REMODER, Extended feature mode disable, VLAN disable, + * LossLess flow control disable, Receive firmware statisic disable, + * Extended address parsing mode disable, One Rx queues, + * Dynamic maximum/minimum frame length disable, IP checksum check + * disable, IP address alignment disable + */ + out_be32(&uec->p_rx_glbl_pram->remoder, REMODER_INIT_VALUE); + + /* RQPTR */ + uec->thread_dat_rx_offset = + qe_muram_alloc(num_threads_rx * + sizeof(struct uec_thread_data_rx), + UEC_THREAD_DATA_ALIGNMENT); + uec->p_thread_data_rx = (struct uec_thread_data_rx *) + qe_muram_addr(uec->thread_dat_rx_offset); + out_be32(&uec->p_rx_glbl_pram->rqptr, uec->thread_dat_rx_offset); + + /* Type_or_Len */ + out_be16(&uec->p_rx_glbl_pram->typeorlen, 3072); + + /* RxRMON base pointer, we don't need it */ + out_be32(&uec->p_rx_glbl_pram->rxrmonbaseptr, 0); + + /* IntCoalescingPTR, we don't need it, no interrupt */ + out_be32(&uec->p_rx_glbl_pram->intcoalescingptr, 0); + + /* RSTATE, global snooping, big endian, the CSB bus selected */ + bmrx = BMR_INIT_VALUE; + out_8(&uec->p_rx_glbl_pram->rstate, bmrx); + + /* MRBLR */ + out_be16(&uec->p_rx_glbl_pram->mrblr, MAX_RXBUF_LEN); + + /* RBDQPTR */ + uec->rx_bd_qs_tbl_offset = + qe_muram_alloc(sizeof(struct uec_rx_bd_queues_entry) + + sizeof(struct uec_rx_pref_bds), + UEC_RX_BD_QUEUES_ALIGNMENT); + uec->p_rx_bd_qs_tbl = (struct uec_rx_bd_queues_entry *) + qe_muram_addr(uec->rx_bd_qs_tbl_offset); + + /* Zero it */ + memset(uec->p_rx_bd_qs_tbl, 0, sizeof(struct uec_rx_bd_queues_entry) + + sizeof(struct uec_rx_pref_bds)); + out_be32(&uec->p_rx_glbl_pram->rbdqptr, uec->rx_bd_qs_tbl_offset); + out_be32(&uec->p_rx_bd_qs_tbl->externalbdbaseptr, + (u32)uec->p_rx_bd_ring); + + /* MFLR */ + out_be16(&uec->p_rx_glbl_pram->mflr, MAX_FRAME_LEN); + /* MINFLR */ + out_be16(&uec->p_rx_glbl_pram->minflr, MIN_FRAME_LEN); + /* MAXD1 */ + out_be16(&uec->p_rx_glbl_pram->maxd1, MAX_DMA1_LEN); + /* MAXD2 */ + out_be16(&uec->p_rx_glbl_pram->maxd2, MAX_DMA2_LEN); + /* ECAM_PTR */ + out_be32(&uec->p_rx_glbl_pram->ecamptr, 0); + /* L2QT */ + out_be32(&uec->p_rx_glbl_pram->l2qt, 0); + /* L3QT */ + for (i = 0; i < 8; i++) + out_be32(&uec->p_rx_glbl_pram->l3qt[i], 0); + + /* VLAN_TYPE */ + out_be16(&uec->p_rx_glbl_pram->vlantype, 0x8100); + /* TCI */ + out_be16(&uec->p_rx_glbl_pram->vlantci, 0); + + /* Clear PQ2 style address filtering hash table */ + p_af_pram = (struct uec_82xx_add_filtering_pram *) + uec->p_rx_glbl_pram->addressfiltering; + + p_af_pram->iaddr_h = 0; + p_af_pram->iaddr_l = 0; + p_af_pram->gaddr_h = 0; + p_af_pram->gaddr_l = 0; +} + +static int uec_issue_init_enet_rxtx_cmd(struct uec_priv *uec, + int thread_tx, int thread_rx) +{ + struct uec_init_cmd_pram *p_init_enet_param; + u32 init_enet_param_offset; + struct uec_inf *uec_info; + struct ucc_fast_inf *uf_info; + int i; + int snum; + u32 off; + u32 entry_val; + u32 command; + u32 cecr_subblock; + + uec_info = uec->uec_info; + uf_info = &uec_info->uf_info; + + /* Allocate init enet command parameter */ + uec->init_enet_param_offset = + qe_muram_alloc(sizeof(struct uec_init_cmd_pram), 4); + init_enet_param_offset = uec->init_enet_param_offset; + uec->p_init_enet_param = (struct uec_init_cmd_pram *) + qe_muram_addr(uec->init_enet_param_offset); + + /* Zero init enet command struct */ + memset((void *)uec->p_init_enet_param, 0, + sizeof(struct uec_init_cmd_pram)); + + /* Init the command struct */ + p_init_enet_param = uec->p_init_enet_param; + p_init_enet_param->resinit0 = ENET_INIT_PARAM_MAGIC_RES_INIT0; + p_init_enet_param->resinit1 = ENET_INIT_PARAM_MAGIC_RES_INIT1; + p_init_enet_param->resinit2 = ENET_INIT_PARAM_MAGIC_RES_INIT2; + p_init_enet_param->resinit3 = ENET_INIT_PARAM_MAGIC_RES_INIT3; + p_init_enet_param->resinit4 = ENET_INIT_PARAM_MAGIC_RES_INIT4; + p_init_enet_param->largestexternallookupkeysize = 0; + + p_init_enet_param->rgftgfrxglobal |= ((u32)uec_info->num_threads_rx) + << ENET_INIT_PARAM_RGF_SHIFT; + p_init_enet_param->rgftgfrxglobal |= ((u32)uec_info->num_threads_tx) + << ENET_INIT_PARAM_TGF_SHIFT; + + /* Init Rx global parameter pointer */ + p_init_enet_param->rgftgfrxglobal |= uec->rx_glbl_pram_offset | + (u32)uec_info->risc_rx; + + /* Init Rx threads */ + for (i = 0; i < (thread_rx + 1); i++) { + snum = qe_get_snum(); + if (snum < 0) { + printf("%s can not get snum\n", __func__); + return -ENOMEM; + } + + if (i == 0) { + off = 0; + } else { + off = qe_muram_alloc(sizeof(struct uec_thread_rx_pram), + UEC_THREAD_RX_PRAM_ALIGNMENT); + } + + entry_val = ((u32)snum << ENET_INIT_PARAM_SNUM_SHIFT) | + off | (u32)uec_info->risc_rx; + p_init_enet_param->rxthread[i] = entry_val; + } + + /* Init Tx global parameter pointer */ + p_init_enet_param->txglobal = uec->tx_glbl_pram_offset | + (u32)uec_info->risc_tx; + + /* Init Tx threads */ + for (i = 0; i < thread_tx; i++) { + snum = qe_get_snum(); + if (snum < 0) { + printf("%s can not get snum\n", __func__); + return -ENOMEM; + } + + off = qe_muram_alloc(sizeof(struct uec_thread_tx_pram), + UEC_THREAD_TX_PRAM_ALIGNMENT); + + entry_val = ((u32)snum << ENET_INIT_PARAM_SNUM_SHIFT) | + off | (u32)uec_info->risc_tx; + p_init_enet_param->txthread[i] = entry_val; + } + + __asm__ __volatile__("sync"); + + /* Issue QE command */ + command = QE_INIT_TX_RX; + cecr_subblock = ucc_fast_get_qe_cr_subblock(uf_info->ucc_num); + qe_issue_cmd(command, cecr_subblock, (u8)QE_CR_PROTOCOL_ETHERNET, + init_enet_param_offset); + + return 0; +} + +static int uec_startup(struct udevice *dev) +{ + struct qe_uec_priv *priv = dev_get_priv(dev); + struct uec_priv *uec = priv->uec; + struct uec_inf *uec_info; + struct ucc_fast_inf *uf_info; + struct ucc_fast_priv *uccf; + ucc_fast_t *uf_regs; + uec_t *uec_regs; + int num_threads_tx; + int num_threads_rx; + u32 utbipar; + u32 length; + u32 align; + struct buffer_descriptor *bd; + u8 *buf; + int i; + + uec_info = uec->uec_info; + uf_info = &uec_info->uf_info; + + /* Check if Rx BD ring len is illegal */ + if (uec_info->rx_bd_ring_len < UEC_RX_BD_RING_SIZE_MIN || + uec_info->rx_bd_ring_len % UEC_RX_BD_RING_SIZE_ALIGNMENT) { + printf("%s: Rx BD ring len must be multiple of 4, and > 8.\n", + __func__); + return -EINVAL; + } + + /* Check if Tx BD ring len is illegal */ + if (uec_info->tx_bd_ring_len < UEC_TX_BD_RING_SIZE_MIN) { + printf("%s: Tx BD ring length must not be smaller than 2.\n", + __func__); + return -EINVAL; + } + + /* Check if MRBLR is illegal */ + if (MAX_RXBUF_LEN == 0 || (MAX_RXBUF_LEN % UEC_MRBLR_ALIGNMENT)) { + printf("%s: max rx buffer length must be mutliple of 128.\n", + __func__); + return -EINVAL; + } + + /* Both Rx and Tx are stopped */ + uec->grace_stopped_rx = 1; + uec->grace_stopped_tx = 1; + + /* Init UCC fast */ + if (ucc_fast_init(uf_info, &uccf)) { + printf("%s: failed to init ucc fast\n", __func__); + return -ENOMEM; + } + + /* Save uccf */ + uec->uccf = uccf; + + /* Convert the Tx threads number */ + if (uec_convert_threads_num(uec_info->num_threads_tx, + &num_threads_tx)) + return -EINVAL; + + /* Convert the Rx threads number */ + if (uec_convert_threads_num(uec_info->num_threads_rx, + &num_threads_rx)) + return -EINVAL; + + uf_regs = uccf->uf_regs; + + /* UEC register is following UCC fast registers */ + uec_regs = (uec_t *)(&uf_regs->ucc_eth); + + /* Save the UEC register pointer to UEC private struct */ + uec->uec_regs = uec_regs; + + /* Init UPSMR, enable hardware statistics (UCC) */ + out_be32(&uec->uccf->uf_regs->upsmr, UPSMR_INIT_VALUE); + + /* Init MACCFG1, flow control disable, disable Tx and Rx */ + out_be32(&uec_regs->maccfg1, MACCFG1_INIT_VALUE); + + /* Init MACCFG2, length check, MAC PAD and CRC enable */ + out_be32(&uec_regs->maccfg2, MACCFG2_INIT_VALUE); + + /* Setup UTBIPAR */ + utbipar = in_be32(&uec_regs->utbipar); + utbipar &= ~UTBIPAR_PHY_ADDRESS_MASK; + + /* Initialize UTBIPAR address to CONFIG_UTBIPAR_INIT_TBIPA for ALL UEC. + * This frees up the remaining SMI addresses for use. + */ + utbipar |= CONFIG_UTBIPAR_INIT_TBIPA << UTBIPAR_PHY_ADDRESS_SHIFT; + out_be32(&uec_regs->utbipar, utbipar); + + /* Allocate Tx BDs */ + length = ((uec_info->tx_bd_ring_len * SIZEOFBD) / + UEC_TX_BD_RING_SIZE_MEMORY_ALIGNMENT) * + UEC_TX_BD_RING_SIZE_MEMORY_ALIGNMENT; + if ((uec_info->tx_bd_ring_len * SIZEOFBD) % + UEC_TX_BD_RING_SIZE_MEMORY_ALIGNMENT) + length += UEC_TX_BD_RING_SIZE_MEMORY_ALIGNMENT; + + align = UEC_TX_BD_RING_ALIGNMENT; + uec->tx_bd_ring_offset = (u32)malloc((u32)(length + align)); + if (uec->tx_bd_ring_offset != 0) + uec->p_tx_bd_ring = (u8 *)((uec->tx_bd_ring_offset + align) + & ~(align - 1)); + + /* Zero all of Tx BDs */ + memset((void *)(uec->tx_bd_ring_offset), 0, length + align); + + /* Allocate Rx BDs */ + length = uec_info->rx_bd_ring_len * SIZEOFBD; + align = UEC_RX_BD_RING_ALIGNMENT; + uec->rx_bd_ring_offset = (u32)(malloc((u32)(length + align))); + if (uec->rx_bd_ring_offset != 0) + uec->p_rx_bd_ring = (u8 *)((uec->rx_bd_ring_offset + align) + & ~(align - 1)); + + /* Zero all of Rx BDs */ + memset((void *)(uec->rx_bd_ring_offset), 0, length + align); + + /* Allocate Rx buffer */ + length = uec_info->rx_bd_ring_len * MAX_RXBUF_LEN; + align = UEC_RX_DATA_BUF_ALIGNMENT; + uec->rx_buf_offset = (u32)malloc(length + align); + if (uec->rx_buf_offset != 0) + uec->p_rx_buf = (u8 *)((uec->rx_buf_offset + align) + & ~(align - 1)); + + /* Zero all of the Rx buffer */ + memset((void *)(uec->rx_buf_offset), 0, length + align); + + /* Init TxBD ring */ + bd = (struct buffer_descriptor *)uec->p_tx_bd_ring; + uec->tx_bd = bd; + + for (i = 0; i < uec_info->tx_bd_ring_len; i++) { + BD_DATA_CLEAR(bd); + BD_STATUS_SET(bd, 0); + BD_LENGTH_SET(bd, 0); + bd++; + } + BD_STATUS_SET((--bd), TX_BD_WRAP); + + /* Init RxBD ring */ + bd = (struct buffer_descriptor *)uec->p_rx_bd_ring; + uec->rx_bd = bd; + buf = uec->p_rx_buf; + for (i = 0; i < uec_info->rx_bd_ring_len; i++) { + BD_DATA_SET(bd, buf); + BD_LENGTH_SET(bd, 0); + BD_STATUS_SET(bd, RX_BD_EMPTY); + buf += MAX_RXBUF_LEN; + bd++; + } + BD_STATUS_SET((--bd), RX_BD_WRAP | RX_BD_EMPTY); + + /* Init global Tx parameter RAM */ + uec_init_tx_parameter(uec, num_threads_tx); + + /* Init global Rx parameter RAM */ + uec_init_rx_parameter(uec, num_threads_rx); + + /* Init ethernet Tx and Rx parameter command */ + if (uec_issue_init_enet_rxtx_cmd(uec, num_threads_tx, + num_threads_rx)) { + printf("%s issue init enet cmd failed\n", __func__); + return -ENOMEM; + } + return 0; +} + +/* Convert a string to a QE clock source enum + * + * This function takes a string, typically from a property in the device + * tree, and returns the corresponding "enum qe_clock" value. + */ +enum qe_clock qe_clock_source(const char *source) +{ + unsigned int i; + + if (strcasecmp(source, "none") == 0) + return QE_CLK_NONE; + + if (strncasecmp(source, "brg", 3) == 0) { + i = simple_strtoul(source + 3, NULL, 10); + if (i >= 1 && i <= 16) + return (QE_BRG1 - 1) + i; + else + return QE_CLK_DUMMY; + } + + if (strncasecmp(source, "clk", 3) == 0) { + i = simple_strtoul(source + 3, NULL, 10); + if (i >= 1 && i <= 24) + return (QE_CLK1 - 1) + i; + else + return QE_CLK_DUMMY; + } + + return QE_CLK_DUMMY; +} + +static void qe_uec_set_eth_type(struct udevice *dev) +{ + struct qe_uec_priv *priv = dev_get_priv(dev); + struct uec_priv *uec = priv->uec; + struct uec_inf *uec_info = uec->uec_info; + struct ucc_fast_inf *uf_info = &uec_info->uf_info; + + switch (uec_info->enet_interface_type) { + case PHY_INTERFACE_MODE_GMII: + case PHY_INTERFACE_MODE_RGMII: + case PHY_INTERFACE_MODE_RGMII_ID: + case PHY_INTERFACE_MODE_RGMII_RXID: + case PHY_INTERFACE_MODE_RGMII_TXID: + case PHY_INTERFACE_MODE_TBI: + case PHY_INTERFACE_MODE_RTBI: + case PHY_INTERFACE_MODE_SGMII: + uf_info->eth_type = GIGA_ETH; + break; + default: + uf_info->eth_type = FAST_ETH; + break; + } +} + +static int qe_uec_set_uec_info(struct udevice *dev) +{ + struct qe_uec_priv *priv = dev_get_priv(dev); + struct eth_pdata *pdata = dev_get_platdata(dev); + struct uec_priv *uec = priv->uec; + struct uec_inf *uec_info; + struct ucc_fast_inf *uf_info; + const char *s; + int ret; + u32 val; + + uec_info = (struct uec_inf *)malloc(sizeof(struct uec_inf)); + if (!uec_info) + return -ENOMEM; + + uf_info = &uec_info->uf_info; + + ret = dev_read_u32(dev, "cell-index", &val); + if (ret) { + ret = dev_read_u32(dev, "device-id", &val); + if (ret) { + pr_err("no cell-index nor device-id found!"); + goto out; + } + } + + uf_info->ucc_num = val - 1; + if (uf_info->ucc_num < 0 || uf_info->ucc_num > 7) { + ret = -ENODEV; + goto out; + } + + ret = dev_read_string_index(dev, "rx-clock-name", 0, &s); + if (!ret) { + uf_info->rx_clock = qe_clock_source(s); + if (uf_info->rx_clock < QE_CLK_NONE || + uf_info->rx_clock > QE_CLK24) { + pr_err("invalid rx-clock-name property\n"); + ret = -EINVAL; + goto out; + } + } else { + ret = dev_read_u32(dev, "rx-clock", &val); + if (ret) { + /* + * If both rx-clock-name and rx-clock are missing, + * we want to tell people to use rx-clock-name. + */ + pr_err("missing rx-clock-name property\n"); + goto out; + } + if (val < QE_CLK_NONE || val > QE_CLK24) { + pr_err("invalid rx-clock property\n"); + ret = -EINVAL; + goto out; + } + uf_info->rx_clock = val; + } + + ret = dev_read_string_index(dev, "tx-clock-name", 0, &s); + if (!ret) { + uf_info->tx_clock = qe_clock_source(s); + if (uf_info->tx_clock < QE_CLK_NONE || + uf_info->tx_clock > QE_CLK24) { + pr_err("invalid tx-clock-name property\n"); + ret = -EINVAL; + goto out; + } + } else { + ret = dev_read_u32(dev, "tx-clock", &val); + if (ret) { + pr_err("missing tx-clock-name property\n"); + goto out; + } + if (val < QE_CLK_NONE || val > QE_CLK24) { + pr_err("invalid tx-clock property\n"); + ret = -EINVAL; + goto out; + } + uf_info->tx_clock = val; + } + + uec_info->num_threads_tx = UEC_NUM_OF_THREADS_1; + uec_info->num_threads_rx = UEC_NUM_OF_THREADS_1; + uec_info->risc_tx = QE_RISC_ALLOCATION_RISC1_AND_RISC2; + uec_info->risc_rx = QE_RISC_ALLOCATION_RISC1_AND_RISC2; + uec_info->tx_bd_ring_len = 16; + uec_info->rx_bd_ring_len = 16; +#if (MAX_QE_RISC == 4) + uec_info->risc_tx = QE_RISC_ALLOCATION_FOUR_RISCS; + uec_info->risc_rx = QE_RISC_ALLOCATION_FOUR_RISCS; +#endif + + uec_info->enet_interface_type = pdata->phy_interface; + + uec->uec_info = uec_info; + qe_uec_set_eth_type(dev); + + return 0; +out: + free(uec_info); + return ret; +} + +static int qe_uec_probe(struct udevice *dev) +{ + struct qe_uec_priv *priv = dev_get_priv(dev); + struct eth_pdata *pdata = dev_get_platdata(dev); + struct uec_priv *uec; + int ret; + + /* Allocate the UEC private struct */ + uec = (struct uec_priv *)malloc(sizeof(struct uec_priv)); + if (!uec) + return -ENOMEM; + + memset(uec, 0, sizeof(struct uec_priv)); + priv->uec = uec; + uec->uec_regs = (uec_t *)pdata->iobase; + + /* setup uec info struct */ + ret = qe_uec_set_uec_info(dev); + if (ret) { + free(uec); + return ret; + } + + ret = uec_startup(dev); + if (ret) { + free(uec->uec_info); + free(uec); + return ret; + } + + priv->phydev = dm_eth_phy_connect(dev); + return 0; +} + +/* + * Remove the driver from an interface: + * - free up allocated memory + */ +static int qe_uec_remove(struct udevice *dev) +{ + struct qe_uec_priv *priv = dev_get_priv(dev); + + free(priv->uec); + return 0; +} + +static int qe_uec_ofdata_to_platdata(struct udevice *dev) +{ + struct eth_pdata *pdata = dev_get_platdata(dev); + const char *phy_mode; + + pdata->iobase = (phys_addr_t)devfdt_get_addr(dev); + + pdata->phy_interface = -1; + phy_mode = fdt_getprop(gd->fdt_blob, dev_of_offset(dev), + "phy-connection-type", NULL); + if (phy_mode) + pdata->phy_interface = phy_get_interface_by_name(phy_mode); + if (pdata->phy_interface == -1) { + debug("%s: Invalid PHY interface '%s'\n", __func__, phy_mode); + return -EINVAL; + } + + return 0; +} + +static const struct udevice_id qe_uec_ids[] = { + { .compatible = QE_UEC_DRIVER_NAME }, + { } +}; + +U_BOOT_DRIVER(eth_qe_uec) = { + .name = QE_UEC_DRIVER_NAME, + .id = UCLASS_ETH, + .of_match = qe_uec_ids, + .ofdata_to_platdata = qe_uec_ofdata_to_platdata, + .probe = qe_uec_probe, + .remove = qe_uec_remove, + .ops = &qe_uec_eth_ops, + .priv_auto_alloc_size = sizeof(struct qe_uec_priv), + .platdata_auto_alloc_size = sizeof(struct eth_pdata), +}; diff --git a/drivers/net/qe/dm_qe_uec.h b/drivers/net/qe/dm_qe_uec.h new file mode 100644 index 0000000000..690093caa2 --- /dev/null +++ b/drivers/net/qe/dm_qe_uec.h @@ -0,0 +1,22 @@ +/* SPDX-License-Identifier: GPL-2.0+ + * + * QE UEC ethernet controller driver + * + * based on drivers/qe/uec.c from NXP + * + * Copyright (C) 2020 Heiko Schocher hs@denx.de + */ + +#ifndef _DM_QE_UEC_H +#define _DM_QE_UEC_H + +#define qe_uec_dbg(dev, fmt, args...) debug("%s:" fmt, dev->name, ##args) + +#include "uec.h" + +/* QE UEC private structure */ +struct qe_uec_priv { + struct uec_priv *uec; + struct phy_device *phydev; +}; +#endif diff --git a/drivers/net/qe/dm_qe_uec_phy.c b/drivers/net/qe/dm_qe_uec_phy.c new file mode 100644 index 0000000000..02ce08edad --- /dev/null +++ b/drivers/net/qe/dm_qe_uec_phy.c @@ -0,0 +1,163 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * QE UEC ethernet phy controller driver + * + * based on phy parts of drivers/qe/uec.c and drivers/qe/uec_phy.c + * from NXP + * + * Copyright (C) 2020 Heiko Schocher hs@denx.de + */ + +#include <common.h> +#include <dm.h> +#include <errno.h> +#include <miiphy.h> +#include <phy.h> +#include <asm/io.h> +#include <linux/ioport.h> + +#include "dm_qe_uec.h" + +struct qe_uec_mdio_priv { + struct ucc_mii_mng *base; +}; + +static int +qe_uec_mdio_read(struct udevice *dev, int addr, int devad, int reg) +{ + struct qe_uec_mdio_priv *priv = dev_get_priv(dev); + struct ucc_mii_mng *regs = priv->base; + u32 tmp_reg; + u16 value; + + debug("%s: regs: %p addr: %x devad: %x reg: %x\n", __func__, regs, + addr, devad, reg); + /* Setting up the MII management Address Register */ + tmp_reg = ((u32)addr << MIIMADD_PHY_ADDRESS_SHIFT) | reg; + out_be32(®s->miimadd, tmp_reg); + + /* clear MII management command cycle */ + out_be32(®s->miimcom, 0); + sync(); + + /* Perform an MII management read cycle */ + out_be32(®s->miimcom, MIIMCOM_READ_CYCLE); + + /* Wait till MII management write is complete */ + while ((in_be32(®s->miimind)) & + (MIIMIND_NOT_VALID | MIIMIND_BUSY)) + ; + + /* Read MII management status */ + value = (u16)in_be32(®s->miimstat); + if (value == 0xffff) + return -EINVAL; + + return value; +}; + +static int +qe_uec_mdio_write(struct udevice *dev, int addr, int devad, int reg, + u16 value) +{ + struct qe_uec_mdio_priv *priv = dev_get_priv(dev); + struct ucc_mii_mng *regs = priv->base; + u32 tmp_reg; + + debug("%s: regs: %p addr: %x devad: %x reg: %x val: %x\n", __func__, + regs, addr, devad, reg, value); + + /* Stop the MII management read cycle */ + out_be32(®s->miimcom, 0); + /* Setting up the MII management Address Register */ + tmp_reg = ((u32)addr << MIIMADD_PHY_ADDRESS_SHIFT) | reg; + out_be32(®s->miimadd, tmp_reg); + + /* Setting up the MII management Control Register with the value */ + out_be32(®s->miimcon, (u32)value); + sync(); + + /* Wait till MII management write is complete */ + while ((in_be32(®s->miimind)) & MIIMIND_BUSY) + ; + + return 0; +}; + +static const struct mdio_ops qe_uec_mdio_ops = { + .read = qe_uec_mdio_read, + .write = qe_uec_mdio_write, +}; + +static int qe_uec_mdio_probe(struct udevice *dev) +{ + struct qe_uec_mdio_priv *priv = dev_get_priv(dev); + fdt_size_t base; + ofnode node; + u32 num = 0; + int ret = -ENODEV; + + priv->base = (struct ucc_mii_mng *)dev_read_addr(dev); + base = (fdt_size_t)priv->base; + + /* + * idea from linux: + * drivers/net/ethernet/freescale/fsl_pq_mdio.c + * + * Find the UCC node that controls the given MDIO node + * + * For some reason, the QE MDIO nodes are not children of the UCC + * devices that control them. Therefore, we need to scan all UCC + * nodes looking for the one that encompases the given MDIO node. + * We do this by comparing physical addresses. The 'start' and + * 'end' addresses of the MDIO node are passed, and the correct + * UCC node will cover the entire address range. + */ + node = ofnode_by_compatible(ofnode_null(), "ucc_geth"); + while (ofnode_valid(node)) { + fdt_size_t size; + fdt_addr_t addr; + + addr = ofnode_get_addr_index(node, 0); + ret = ofnode_get_addr_size_index(node, 0, &size); + + if (addr == FDT_ADDR_T_NONE) { + node = ofnode_by_compatible(node, "ucc_geth"); + continue; + } + + /* check if priv->base in start end */ + if (base > addr && base < (addr + size)) { + ret = ofnode_read_u32(node, "cell-index", &num); + if (ret) + ret = ofnode_read_u32(node, "device-id", + &num); + break; + } + node = ofnode_by_compatible(node, "ucc_geth"); + } + + if (ret) { + printf("%s: no cell-index nor device-id found!", __func__); + return ret; + } + + /* Setup MII master clock source */ + qe_set_mii_clk_src(num - 1); + + return 0; +} + +static const struct udevice_id qe_uec_mdio_ids[] = { + { .compatible = "fsl,ucc-mdio" }, + { } +}; + +U_BOOT_DRIVER(mvmdio) = { + .name = "qe_uec_mdio", + .id = UCLASS_MDIO, + .of_match = qe_uec_mdio_ids, + .probe = qe_uec_mdio_probe, + .ops = &qe_uec_mdio_ops, + .priv_auto_alloc_size = sizeof(struct qe_uec_mdio_priv), +}; diff --git a/drivers/net/qe/uccf.c b/drivers/net/qe/uccf.c new file mode 100644 index 0000000000..306f1ea1db --- /dev/null +++ b/drivers/net/qe/uccf.c @@ -0,0 +1,507 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2006 Freescale Semiconductor, Inc. + * + * Dave Liu daveliu@freescale.com + * based on source code of Shlomi Gridish + */ + +#include <common.h> +#include <malloc.h> +#include <linux/errno.h> +#include <asm/io.h> +#include <linux/immap_qe.h> +#include "uccf.h" +#include <fsl_qe.h> + +void ucc_fast_transmit_on_demand(struct ucc_fast_priv *uccf) +{ + out_be16(&uccf->uf_regs->utodr, UCC_FAST_TOD); +} + +u32 ucc_fast_get_qe_cr_subblock(int ucc_num) +{ + switch (ucc_num) { + case 0: + return QE_CR_SUBBLOCK_UCCFAST1; + case 1: + return QE_CR_SUBBLOCK_UCCFAST2; + case 2: + return QE_CR_SUBBLOCK_UCCFAST3; + case 3: + return QE_CR_SUBBLOCK_UCCFAST4; + case 4: + return QE_CR_SUBBLOCK_UCCFAST5; + case 5: + return QE_CR_SUBBLOCK_UCCFAST6; + case 6: + return QE_CR_SUBBLOCK_UCCFAST7; + case 7: + return QE_CR_SUBBLOCK_UCCFAST8; + default: + return QE_CR_SUBBLOCK_INVALID; + } +} + +static void ucc_get_cmxucr_reg(int ucc_num, u32 **p_cmxucr, + u8 *reg_num, u8 *shift) +{ + switch (ucc_num) { + case 0: /* UCC1 */ + *p_cmxucr = &qe_immr->qmx.cmxucr1; + *reg_num = 1; + *shift = 16; + break; + case 2: /* UCC3 */ + *p_cmxucr = &qe_immr->qmx.cmxucr1; + *reg_num = 1; + *shift = 0; + break; + case 4: /* UCC5 */ + *p_cmxucr = &qe_immr->qmx.cmxucr2; + *reg_num = 2; + *shift = 16; + break; + case 6: /* UCC7 */ + *p_cmxucr = &qe_immr->qmx.cmxucr2; + *reg_num = 2; + *shift = 0; + break; + case 1: /* UCC2 */ + *p_cmxucr = &qe_immr->qmx.cmxucr3; + *reg_num = 3; + *shift = 16; + break; + case 3: /* UCC4 */ + *p_cmxucr = &qe_immr->qmx.cmxucr3; + *reg_num = 3; + *shift = 0; + break; + case 5: /* UCC6 */ + *p_cmxucr = &qe_immr->qmx.cmxucr4; + *reg_num = 4; + *shift = 16; + break; + case 7: /* UCC8 */ + *p_cmxucr = &qe_immr->qmx.cmxucr4; + *reg_num = 4; + *shift = 0; + break; + default: + break; + } +} + +static int ucc_set_clk_src(int ucc_num, qe_clock_e clock, comm_dir_e mode) +{ + u32 *p_cmxucr = NULL; + u8 reg_num = 0; + u8 shift = 0; + u32 clk_bits; + u32 clk_mask; + int source = -1; + + /* check if the UCC number is in range. */ + if ((ucc_num > UCC_MAX_NUM - 1) || ucc_num < 0) + return -EINVAL; + + if (!(mode == COMM_DIR_RX || mode == COMM_DIR_TX)) { + printf("%s: bad comm mode type passed\n", __func__); + return -EINVAL; + } + + ucc_get_cmxucr_reg(ucc_num, &p_cmxucr, ®_num, &shift); + + switch (reg_num) { + case 1: + switch (clock) { + case QE_BRG1: + source = 1; + break; + case QE_BRG2: + source = 2; + break; + case QE_BRG7: + source = 3; + break; + case QE_BRG8: + source = 4; + break; + case QE_CLK9: + source = 5; + break; + case QE_CLK10: + source = 6; + break; + case QE_CLK11: + source = 7; + break; + case QE_CLK12: + source = 8; + break; + case QE_CLK15: + source = 9; + break; + case QE_CLK16: + source = 10; + break; + default: + source = -1; + break; + } + break; + case 2: + switch (clock) { + case QE_BRG5: + source = 1; + break; + case QE_BRG6: + source = 2; + break; + case QE_BRG7: + source = 3; + break; + case QE_BRG8: + source = 4; + break; + case QE_CLK13: + source = 5; + break; + case QE_CLK14: + source = 6; + break; + case QE_CLK19: + source = 7; + break; + case QE_CLK20: + source = 8; + break; + case QE_CLK15: + source = 9; + break; + case QE_CLK16: + source = 10; + break; + default: + source = -1; + break; + } + break; + case 3: + switch (clock) { + case QE_BRG9: + source = 1; + break; + case QE_BRG10: + source = 2; + break; + case QE_BRG15: + source = 3; + break; + case QE_BRG16: + source = 4; + break; + case QE_CLK3: + source = 5; + break; + case QE_CLK4: + source = 6; + break; + case QE_CLK17: + source = 7; + break; + case QE_CLK18: + source = 8; + break; + case QE_CLK7: + source = 9; + break; + case QE_CLK8: + source = 10; + break; + case QE_CLK16: + source = 11; + break; + default: + source = -1; + break; + } + break; + case 4: + switch (clock) { + case QE_BRG13: + source = 1; + break; + case QE_BRG14: + source = 2; + break; + case QE_BRG15: + source = 3; + break; + case QE_BRG16: + source = 4; + break; + case QE_CLK5: + source = 5; + break; + case QE_CLK6: + source = 6; + break; + case QE_CLK21: + source = 7; + break; + case QE_CLK22: + source = 8; + break; + case QE_CLK7: + source = 9; + break; + case QE_CLK8: + source = 10; + break; + case QE_CLK16: + source = 11; + break; + default: + source = -1; + break; + } + break; + default: + source = -1; + break; + } + + if (source == -1) { + printf("%s: Bad combination of clock and UCC\n", __func__); + return -ENOENT; + } + + clk_bits = (u32)source; + clk_mask = QE_CMXUCR_TX_CLK_SRC_MASK; + if (mode == COMM_DIR_RX) { + clk_bits <<= 4; /* Rx field is 4 bits to left of Tx field */ + clk_mask <<= 4; /* Rx field is 4 bits to left of Tx field */ + } + clk_bits <<= shift; + clk_mask <<= shift; + + out_be32(p_cmxucr, (in_be32(p_cmxucr) & ~clk_mask) | clk_bits); + + return 0; +} + +static uint ucc_get_reg_baseaddr(int ucc_num) +{ + uint base = 0; + + /* check if the UCC number is in range */ + if ((ucc_num > UCC_MAX_NUM - 1) || ucc_num < 0) { + printf("%s: the UCC num not in ranges\n", __func__); + return 0; + } + + switch (ucc_num) { + case 0: + base = 0x00002000; + break; + case 1: + base = 0x00003000; + break; + case 2: + base = 0x00002200; + break; + case 3: + base = 0x00003200; + break; + case 4: + base = 0x00002400; + break; + case 5: + base = 0x00003400; + break; + case 6: + base = 0x00002600; + break; + case 7: + base = 0x00003600; + break; + default: + break; + } + + base = (uint)qe_immr + base; + return base; +} + +void ucc_fast_enable(struct ucc_fast_priv *uccf, comm_dir_e mode) +{ + ucc_fast_t *uf_regs; + u32 gumr; + + uf_regs = uccf->uf_regs; + + /* Enable reception and/or transmission on this UCC. */ + gumr = in_be32(&uf_regs->gumr); + if (mode & COMM_DIR_TX) { + gumr |= UCC_FAST_GUMR_ENT; + uccf->enabled_tx = 1; + } + if (mode & COMM_DIR_RX) { + gumr |= UCC_FAST_GUMR_ENR; + uccf->enabled_rx = 1; + } + out_be32(&uf_regs->gumr, gumr); +} + +void ucc_fast_disable(struct ucc_fast_priv *uccf, comm_dir_e mode) +{ + ucc_fast_t *uf_regs; + u32 gumr; + + uf_regs = uccf->uf_regs; + + /* Disable reception and/or transmission on this UCC. */ + gumr = in_be32(&uf_regs->gumr); + if (mode & COMM_DIR_TX) { + gumr &= ~UCC_FAST_GUMR_ENT; + uccf->enabled_tx = 0; + } + if (mode & COMM_DIR_RX) { + gumr &= ~UCC_FAST_GUMR_ENR; + uccf->enabled_rx = 0; + } + out_be32(&uf_regs->gumr, gumr); +} + +int ucc_fast_init(struct ucc_fast_inf *uf_info, + struct ucc_fast_priv **uccf_ret) +{ + struct ucc_fast_priv *uccf; + ucc_fast_t *uf_regs; + + if (!uf_info) + return -EINVAL; + + if (uf_info->ucc_num < 0 || (uf_info->ucc_num > UCC_MAX_NUM - 1)) { + printf("%s: Illagal UCC number!\n", __func__); + return -EINVAL; + } + + uccf = (struct ucc_fast_priv *)malloc(sizeof(struct ucc_fast_priv)); + if (!uccf) { + printf("%s: No memory for UCC fast data structure!\n", + __func__); + return -ENOMEM; + } + memset(uccf, 0, sizeof(struct ucc_fast_priv)); + + /* Save fast UCC structure */ + uccf->uf_info = uf_info; + uccf->uf_regs = (ucc_fast_t *)ucc_get_reg_baseaddr(uf_info->ucc_num); + + if (!uccf->uf_regs) { + printf("%s: No memory map for UCC fast controller!\n", + __func__); + return -ENOMEM; + } + + uccf->enabled_tx = 0; + uccf->enabled_rx = 0; + + uf_regs = uccf->uf_regs; + uccf->p_ucce = (u32 *)&uf_regs->ucce; + uccf->p_uccm = (u32 *)&uf_regs->uccm; + + /* Init GUEMR register, UCC both Rx and Tx is Fast protocol */ + out_8(&uf_regs->guemr, UCC_GUEMR_SET_RESERVED3 | UCC_GUEMR_MODE_FAST_RX + | UCC_GUEMR_MODE_FAST_TX); + + /* Set GUMR, disable UCC both Rx and Tx, Ethernet protocol */ + out_be32(&uf_regs->gumr, UCC_FAST_GUMR_ETH); + + /* Set the Giga ethernet VFIFO stuff */ + if (uf_info->eth_type == GIGA_ETH) { + /* Allocate memory for Tx Virtual Fifo */ + uccf->ucc_fast_tx_virtual_fifo_base_offset = + qe_muram_alloc(UCC_GETH_UTFS_GIGA_INIT, + UCC_FAST_VIRT_FIFO_REGS_ALIGNMENT); + + /* Allocate memory for Rx Virtual Fifo */ + uccf->ucc_fast_rx_virtual_fifo_base_offset = + qe_muram_alloc(UCC_GETH_URFS_GIGA_INIT + + UCC_FAST_RX_VIRTUAL_FIFO_SIZE_PAD, + UCC_FAST_VIRT_FIFO_REGS_ALIGNMENT); + + /* utfb, urfb are offsets from MURAM base */ + out_be32(&uf_regs->utfb, + uccf->ucc_fast_tx_virtual_fifo_base_offset); + out_be32(&uf_regs->urfb, + uccf->ucc_fast_rx_virtual_fifo_base_offset); + + /* Set Virtual Fifo registers */ + out_be16(&uf_regs->urfs, UCC_GETH_URFS_GIGA_INIT); + out_be16(&uf_regs->urfet, UCC_GETH_URFET_GIGA_INIT); + out_be16(&uf_regs->urfset, UCC_GETH_URFSET_GIGA_INIT); + out_be16(&uf_regs->utfs, UCC_GETH_UTFS_GIGA_INIT); + out_be16(&uf_regs->utfet, UCC_GETH_UTFET_GIGA_INIT); + out_be16(&uf_regs->utftt, UCC_GETH_UTFTT_GIGA_INIT); + } + + /* Set the Fast ethernet VFIFO stuff */ + if (uf_info->eth_type == FAST_ETH) { + /* Allocate memory for Tx Virtual Fifo */ + uccf->ucc_fast_tx_virtual_fifo_base_offset = + qe_muram_alloc(UCC_GETH_UTFS_INIT, + UCC_FAST_VIRT_FIFO_REGS_ALIGNMENT); + + /* Allocate memory for Rx Virtual Fifo */ + uccf->ucc_fast_rx_virtual_fifo_base_offset = + qe_muram_alloc(UCC_GETH_URFS_INIT + + UCC_FAST_RX_VIRTUAL_FIFO_SIZE_PAD, + UCC_FAST_VIRT_FIFO_REGS_ALIGNMENT); + + /* utfb, urfb are offsets from MURAM base */ + out_be32(&uf_regs->utfb, + uccf->ucc_fast_tx_virtual_fifo_base_offset); + out_be32(&uf_regs->urfb, + uccf->ucc_fast_rx_virtual_fifo_base_offset); + + /* Set Virtual Fifo registers */ + out_be16(&uf_regs->urfs, UCC_GETH_URFS_INIT); + out_be16(&uf_regs->urfet, UCC_GETH_URFET_INIT); + out_be16(&uf_regs->urfset, UCC_GETH_URFSET_INIT); + out_be16(&uf_regs->utfs, UCC_GETH_UTFS_INIT); + out_be16(&uf_regs->utfet, UCC_GETH_UTFET_INIT); + out_be16(&uf_regs->utftt, UCC_GETH_UTFTT_INIT); + } + + /* Rx clock routing */ + if (uf_info->rx_clock != QE_CLK_NONE) { + if (ucc_set_clk_src(uf_info->ucc_num, + uf_info->rx_clock, COMM_DIR_RX)) { + printf("%s: Illegal value for parameter 'RxClock'.\n", + __func__); + return -EINVAL; + } + } + + /* Tx clock routing */ + if (uf_info->tx_clock != QE_CLK_NONE) { + if (ucc_set_clk_src(uf_info->ucc_num, + uf_info->tx_clock, COMM_DIR_TX)) { + printf("%s: Illegal value for parameter 'TxClock'.\n", + __func__); + return -EINVAL; + } + } + + /* Clear interrupt mask register to disable all of interrupts */ + out_be32(&uf_regs->uccm, 0x0); + + /* Writing '1' to clear all of envents */ + out_be32(&uf_regs->ucce, 0xffffffff); + + *uccf_ret = uccf; + return 0; +} diff --git a/drivers/net/qe/uccf.h b/drivers/net/qe/uccf.h new file mode 100644 index 0000000000..99f8458edf --- /dev/null +++ b/drivers/net/qe/uccf.h @@ -0,0 +1,119 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright (C) 2006 Freescale Semiconductor, Inc. + * + * Dave Liu daveliu@freescale.com + * based on source code of Shlomi Gridish + */ + +#ifndef __UCCF_H__ +#define __UCCF_H__ + +#include "common.h" +#include "linux/immap_qe.h" +#include <fsl_qe.h> + +/* Fast or Giga ethernet */ +enum enet_type { + FAST_ETH, + GIGA_ETH, +}; + +/* General UCC Extended Mode Register */ +#define UCC_GUEMR_MODE_MASK_RX 0x02 +#define UCC_GUEMR_MODE_MASK_TX 0x01 +#define UCC_GUEMR_MODE_FAST_RX 0x02 +#define UCC_GUEMR_MODE_FAST_TX 0x01 +#define UCC_GUEMR_MODE_SLOW_RX 0x00 +#define UCC_GUEMR_MODE_SLOW_TX 0x00 +/* Bit 3 must be set 1 */ +#define UCC_GUEMR_SET_RESERVED3 0x10 + +/* General UCC FAST Mode Register */ +#define UCC_FAST_GUMR_TCI 0x20000000 +#define UCC_FAST_GUMR_TRX 0x10000000 +#define UCC_FAST_GUMR_TTX 0x08000000 +#define UCC_FAST_GUMR_CDP 0x04000000 +#define UCC_FAST_GUMR_CTSP 0x02000000 +#define UCC_FAST_GUMR_CDS 0x01000000 +#define UCC_FAST_GUMR_CTSS 0x00800000 +#define UCC_FAST_GUMR_TXSY 0x00020000 +#define UCC_FAST_GUMR_RSYN 0x00010000 +#define UCC_FAST_GUMR_RTSM 0x00002000 +#define UCC_FAST_GUMR_REVD 0x00000400 +#define UCC_FAST_GUMR_ENR 0x00000020 +#define UCC_FAST_GUMR_ENT 0x00000010 + +/* GUMR [MODE] bit maps */ +#define UCC_FAST_GUMR_HDLC 0x00000000 +#define UCC_FAST_GUMR_QMC 0x00000002 +#define UCC_FAST_GUMR_UART 0x00000004 +#define UCC_FAST_GUMR_BISYNC 0x00000008 +#define UCC_FAST_GUMR_ATM 0x0000000a +#define UCC_FAST_GUMR_ETH 0x0000000c + +/* Transmit On Demand (UTORD) */ +#define UCC_SLOW_TOD 0x8000 +#define UCC_FAST_TOD 0x8000 + +/* Fast Ethernet (10/100 Mbps) */ +/* Rx virtual FIFO size */ +#define UCC_GETH_URFS_INIT 512 +/* 1/2 urfs */ +#define UCC_GETH_URFET_INIT 256 +/* 3/4 urfs */ +#define UCC_GETH_URFSET_INIT 384 +/* Tx virtual FIFO size */ +#define UCC_GETH_UTFS_INIT 512 +/* 1/2 utfs */ +#define UCC_GETH_UTFET_INIT 256 +#define UCC_GETH_UTFTT_INIT 128 + +/* Gigabit Ethernet (1000 Mbps) */ +/* Rx virtual FIFO size */ +#define UCC_GETH_URFS_GIGA_INIT 4096/*2048*/ +/* 1/2 urfs */ +#define UCC_GETH_URFET_GIGA_INIT 2048/*1024*/ +/* 3/4 urfs */ +#define UCC_GETH_URFSET_GIGA_INIT 3072/*1536*/ +/* Tx virtual FIFO size */ +#define UCC_GETH_UTFS_GIGA_INIT 8192/*2048*/ +/* 1/2 utfs */ +#define UCC_GETH_UTFET_GIGA_INIT 4096/*1024*/ +#define UCC_GETH_UTFTT_GIGA_INIT 0x400/*0x40*/ + +/* UCC fast alignment */ +#define UCC_FAST_RX_ALIGN 4 +#define UCC_FAST_MRBLR_ALIGNMENT 4 +#define UCC_FAST_VIRT_FIFO_REGS_ALIGNMENT 8 + +/* Sizes */ +#define UCC_FAST_RX_VIRTUAL_FIFO_SIZE_PAD 8 + +/* UCC fast structure. */ +struct ucc_fast_inf { + int ucc_num; + qe_clock_e rx_clock; + qe_clock_e tx_clock; + enum enet_type eth_type; +}; + +struct ucc_fast_priv { + struct ucc_fast_inf *uf_info; + ucc_fast_t *uf_regs; /* a pointer to memory map of UCC regs */ + u32 *p_ucce; /* a pointer to the event register */ + u32 *p_uccm; /* a pointer to the mask register */ + int enabled_tx; /* whether UCC is enabled for Tx (ENT) */ + int enabled_rx; /* whether UCC is enabled for Rx (ENR) */ + u32 ucc_fast_tx_virtual_fifo_base_offset; + u32 ucc_fast_rx_virtual_fifo_base_offset; +}; + +void ucc_fast_transmit_on_demand(struct ucc_fast_priv *uccf); +u32 ucc_fast_get_qe_cr_subblock(int ucc_num); +void ucc_fast_enable(struct ucc_fast_priv *uccf, comm_dir_e mode); +void ucc_fast_disable(struct ucc_fast_priv *uccf, comm_dir_e mode); +int ucc_fast_init(struct ucc_fast_inf *uf_info, + struct ucc_fast_priv **uccf_ret); + +#endif /* __UCCF_H__ */ diff --git a/drivers/net/qe/uec.h b/drivers/net/qe/uec.h new file mode 100644 index 0000000000..2c89b36847 --- /dev/null +++ b/drivers/net/qe/uec.h @@ -0,0 +1,693 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright (C) 2006-2010 Freescale Semiconductor, Inc. + * + * Dave Liu daveliu@freescale.com + * based on source code of Shlomi Gridish + */ + +#ifndef __UEC_H__ +#define __UEC_H__ + +#include "uccf.h" +#include <fsl_qe.h> +#include <phy.h> + +#define MAX_TX_THREADS 8 +#define MAX_RX_THREADS 8 +#define MAX_TX_QUEUES 8 +#define MAX_RX_QUEUES 8 +#define MAX_PREFETCHED_BDS 4 +#define MAX_IPH_OFFSET_ENTRY 8 +#define MAX_ENET_INIT_PARAM_ENTRIES_RX 9 +#define MAX_ENET_INIT_PARAM_ENTRIES_TX 8 + +/* UEC UPSMR (Protocol Specific Mode Register) + */ +#define UPSMR_ECM 0x04000000 /* Enable CAM Miss */ +#define UPSMR_HSE 0x02000000 /* Hardware Statistics Enable */ +#define UPSMR_PRO 0x00400000 /* Promiscuous */ +#define UPSMR_CAP 0x00200000 /* CAM polarity */ +#define UPSMR_RSH 0x00100000 /* Receive Short Frames */ +#define UPSMR_RPM 0x00080000 /* Reduced Pin Mode interfaces */ +#define UPSMR_R10M 0x00040000 /* RGMII/RMII 10 Mode */ +#define UPSMR_RLPB 0x00020000 /* RMII Loopback Mode */ +#define UPSMR_TBIM 0x00010000 /* Ten-bit Interface Mode */ +#define UPSMR_RMM 0x00001000 /* RMII/RGMII Mode */ +#define UPSMR_CAM 0x00000400 /* CAM Address Matching */ +#define UPSMR_BRO 0x00000200 /* Broadcast Address */ +#define UPSMR_RES1 0x00002000 /* Reserved feild - must be 1 */ +#define UPSMR_SGMM 0x00000020 /* SGMII mode */ + +#define UPSMR_INIT_VALUE (UPSMR_HSE | UPSMR_RES1) + +/* UEC MACCFG1 (MAC Configuration 1 Register) + */ +#define MACCFG1_FLOW_RX 0x00000020 /* Flow Control Rx */ +#define MACCFG1_FLOW_TX 0x00000010 /* Flow Control Tx */ +#define MACCFG1_ENABLE_SYNCHED_RX 0x00000008 /* Enable Rx Sync */ +#define MACCFG1_ENABLE_RX 0x00000004 /* Enable Rx */ +#define MACCFG1_ENABLE_SYNCHED_TX 0x00000002 /* Enable Tx Sync */ +#define MACCFG1_ENABLE_TX 0x00000001 /* Enable Tx */ + +#define MACCFG1_INIT_VALUE (0) + +/* UEC MACCFG2 (MAC Configuration 2 Register) + */ +#define MACCFG2_PREL 0x00007000 +#define MACCFG2_PREL_SHIFT (31 - 19) +#define MACCFG2_PREL_MASK 0x0000f000 +#define MACCFG2_SRP 0x00000080 +#define MACCFG2_STP 0x00000040 +#define MACCFG2_RESERVED_1 0x00000020 /* must be set */ +#define MACCFG2_LC 0x00000010 /* Length Check */ +#define MACCFG2_MPE 0x00000008 +#define MACCFG2_FDX 0x00000001 /* Full Duplex */ +#define MACCFG2_FDX_MASK 0x00000001 +#define MACCFG2_PAD_CRC 0x00000004 +#define MACCFG2_CRC_EN 0x00000002 +#define MACCFG2_PAD_AND_CRC_MODE_NONE 0x00000000 +#define MACCFG2_PAD_AND_CRC_MODE_CRC_ONLY 0x00000002 +#define MACCFG2_PAD_AND_CRC_MODE_PAD_AND_CRC 0x00000004 +#define MACCFG2_INTERFACE_MODE_NIBBLE 0x00000100 +#define MACCFG2_INTERFACE_MODE_BYTE 0x00000200 +#define MACCFG2_INTERFACE_MODE_MASK 0x00000300 + +#define MACCFG2_INIT_VALUE (MACCFG2_PREL | MACCFG2_RESERVED_1 | \ + MACCFG2_LC | MACCFG2_PAD_CRC | MACCFG2_FDX) + +/* UEC Event Register */ +#define UCCE_MPD 0x80000000 +#define UCCE_SCAR 0x40000000 +#define UCCE_GRA 0x20000000 +#define UCCE_CBPR 0x10000000 +#define UCCE_BSY 0x08000000 +#define UCCE_RXC 0x04000000 +#define UCCE_TXC 0x02000000 +#define UCCE_TXE 0x01000000 +#define UCCE_TXB7 0x00800000 +#define UCCE_TXB6 0x00400000 +#define UCCE_TXB5 0x00200000 +#define UCCE_TXB4 0x00100000 +#define UCCE_TXB3 0x00080000 +#define UCCE_TXB2 0x00040000 +#define UCCE_TXB1 0x00020000 +#define UCCE_TXB0 0x00010000 +#define UCCE_RXB7 0x00008000 +#define UCCE_RXB6 0x00004000 +#define UCCE_RXB5 0x00002000 +#define UCCE_RXB4 0x00001000 +#define UCCE_RXB3 0x00000800 +#define UCCE_RXB2 0x00000400 +#define UCCE_RXB1 0x00000200 +#define UCCE_RXB0 0x00000100 +#define UCCE_RXF7 0x00000080 +#define UCCE_RXF6 0x00000040 +#define UCCE_RXF5 0x00000020 +#define UCCE_RXF4 0x00000010 +#define UCCE_RXF3 0x00000008 +#define UCCE_RXF2 0x00000004 +#define UCCE_RXF1 0x00000002 +#define UCCE_RXF0 0x00000001 + +#define UCCE_TXB (UCCE_TXB7 | UCCE_TXB6 | UCCE_TXB5 | UCCE_TXB4 | \ + UCCE_TXB3 | UCCE_TXB2 | UCCE_TXB1 | UCCE_TXB0) +#define UCCE_RXB (UCCE_RXB7 | UCCE_RXB6 | UCCE_RXB5 | UCCE_RXB4 | \ + UCCE_RXB3 | UCCE_RXB2 | UCCE_RXB1 | UCCE_RXB0) +#define UCCE_RXF (UCCE_RXF7 | UCCE_RXF6 | UCCE_RXF5 | UCCE_RXF4 | \ + UCCE_RXF3 | UCCE_RXF2 | UCCE_RXF1 | UCCE_RXF0) +#define UCCE_OTHER (UCCE_SCAR | UCCE_GRA | UCCE_CBPR | UCCE_BSY | \ + UCCE_RXC | UCCE_TXC | UCCE_TXE) + +/* UEC TEMODR Register */ +#define TEMODER_SCHEDULER_ENABLE 0x2000 +#define TEMODER_IP_CHECKSUM_GENERATE 0x0400 +#define TEMODER_PERFORMANCE_OPTIMIZATION_MODE1 0x0200 +#define TEMODER_RMON_STATISTICS 0x0100 +#define TEMODER_NUM_OF_QUEUES_SHIFT (15 - 15) + +#define TEMODER_INIT_VALUE 0xc000 + +/* UEC REMODR Register */ +#define REMODER_RX_RMON_STATISTICS_ENABLE 0x00001000 +#define REMODER_RX_EXTENDED_FEATURES 0x80000000 +#define REMODER_VLAN_OPERATION_TAGGED_SHIFT (31 - 9) +#define REMODER_VLAN_OPERATION_NON_TAGGED_SHIFT (31 - 10) +#define REMODER_RX_QOS_MODE_SHIFT (31 - 15) +#define REMODER_RMON_STATISTICS 0x00001000 +#define REMODER_RX_EXTENDED_FILTERING 0x00000800 +#define REMODER_NUM_OF_QUEUES_SHIFT (31 - 23) +#define REMODER_DYNAMIC_MAX_FRAME_LENGTH 0x00000008 +#define REMODER_DYNAMIC_MIN_FRAME_LENGTH 0x00000004 +#define REMODER_IP_CHECKSUM_CHECK 0x00000002 +#define REMODER_IP_ADDRESS_ALIGNMENT 0x00000001 + +#define REMODER_INIT_VALUE 0 + +/* BMRx - Bus Mode Register */ +#define BMR_GLB 0x20 +#define BMR_BO_BE 0x10 +#define BMR_DTB_SECONDARY_BUS 0x02 +#define BMR_BDB_SECONDARY_BUS 0x01 + +#define BMR_SHIFT 24 +#define BMR_INIT_VALUE (BMR_GLB | BMR_BO_BE) + +/* UEC UCCS (Ethernet Status Register) + */ +#define UCCS_BPR 0x02 +#define UCCS_PAU 0x02 +#define UCCS_MPD 0x01 + +/* UEC MIIMCFG (MII Management Configuration Register) + */ +#define MIIMCFG_RESET_MANAGEMENT 0x80000000 +#define MIIMCFG_NO_PREAMBLE 0x00000010 +#define MIIMCFG_CLOCK_DIVIDE_SHIFT (31 - 31) +#define MIIMCFG_CLOCK_DIVIDE_MASK 0x0000000f +#define MIIMCFG_MANAGEMENT_CLOCK_DIVIDE_BY_4 0x00000001 +#define MIIMCFG_MANAGEMENT_CLOCK_DIVIDE_BY_6 0x00000002 +#define MIIMCFG_MANAGEMENT_CLOCK_DIVIDE_BY_8 0x00000003 +#define MIIMCFG_MANAGEMENT_CLOCK_DIVIDE_BY_10 0x00000004 +#define MIIMCFG_MANAGEMENT_CLOCK_DIVIDE_BY_14 0x00000005 +#define MIIMCFG_MANAGEMENT_CLOCK_DIVIDE_BY_20 0x00000006 +#define MIIMCFG_MANAGEMENT_CLOCK_DIVIDE_BY_28 0x00000007 + +#define MIIMCFG_MNGMNT_CLC_DIV_INIT_VALUE \ + MIIMCFG_MANAGEMENT_CLOCK_DIVIDE_BY_10 + +/* UEC MIIMCOM (MII Management Command Register) + */ +#define MIIMCOM_SCAN_CYCLE 0x00000002 /* Scan cycle */ +#define MIIMCOM_READ_CYCLE 0x00000001 /* Read cycle */ + +/* UEC MIIMADD (MII Management Address Register) + */ +#define MIIMADD_PHY_ADDRESS_SHIFT (31 - 23) +#define MIIMADD_PHY_REGISTER_SHIFT (31 - 31) + +/* UEC MIIMCON (MII Management Control Register) + */ +#define MIIMCON_PHY_CONTROL_SHIFT (31 - 31) +#define MIIMCON_PHY_STATUS_SHIFT (31 - 31) + +/* UEC MIIMIND (MII Management Indicator Register) + */ +#define MIIMIND_NOT_VALID 0x00000004 +#define MIIMIND_SCAN 0x00000002 +#define MIIMIND_BUSY 0x00000001 + +/* UEC UTBIPAR (Ten Bit Interface Physical Address Register) + */ +#define UTBIPAR_PHY_ADDRESS_SHIFT (31 - 31) +#define UTBIPAR_PHY_ADDRESS_MASK 0x0000001f + +/* UEC UESCR (Ethernet Statistics Control Register) + */ +#define UESCR_AUTOZ 0x8000 +#define UESCR_CLRCNT 0x4000 +#define UESCR_MAXCOV_SHIFT (15 - 7) +#define UESCR_SCOV_SHIFT (15 - 15) + +/****** Tx data struct collection ******/ +/* Tx thread data, each Tx thread has one this struct. */ +struct uec_thread_data_tx { + u8 res0[136]; +} __packed; + +/* Tx thread parameter, each Tx thread has one this struct. */ +struct uec_thread_tx_pram { + u8 res0[64]; +} __packed; + +/* Send queue queue-descriptor, each Tx queue has one this QD */ +struct uec_send_queue_qd { + u32 bd_ring_base; /* pointer to BD ring base address */ + u8 res0[0x8]; + u32 last_bd_completed_address; /* last entry in BD ring */ + u8 res1[0x30]; +} __packed; + +/* Send queue memory region */ +struct uec_send_queue_mem_region { + struct uec_send_queue_qd sqqd[MAX_TX_QUEUES]; +} __packed; + +/* Scheduler struct */ +struct uec_scheduler { + u16 cpucount0; /* CPU packet counter */ + u16 cpucount1; /* CPU packet counter */ + u16 cecount0; /* QE packet counter */ + u16 cecount1; /* QE packet counter */ + u16 cpucount2; /* CPU packet counter */ + u16 cpucount3; /* CPU packet counter */ + u16 cecount2; /* QE packet counter */ + u16 cecount3; /* QE packet counter */ + u16 cpucount4; /* CPU packet counter */ + u16 cpucount5; /* CPU packet counter */ + u16 cecount4; /* QE packet counter */ + u16 cecount5; /* QE packet counter */ + u16 cpucount6; /* CPU packet counter */ + u16 cpucount7; /* CPU packet counter */ + u16 cecount6; /* QE packet counter */ + u16 cecount7; /* QE packet counter */ + u32 weightstatus[MAX_TX_QUEUES]; /* accumulated weight factor */ + u32 rtsrshadow; /* temporary variable handled by QE */ + u32 time; /* temporary variable handled by QE */ + u32 ttl; /* temporary variable handled by QE */ + u32 mblinterval; /* max burst length interval */ + u16 nortsrbytetime; /* normalized value of byte time in tsr units */ + u8 fracsiz; + u8 res0[1]; + u8 strictpriorityq; /* Strict Priority Mask register */ + u8 txasap; /* Transmit ASAP register */ + u8 extrabw; /* Extra BandWidth register */ + u8 oldwfqmask; /* temporary variable handled by QE */ + u8 weightfactor[MAX_TX_QUEUES]; /**< weight factor for queues */ + u32 minw; /* temporary variable handled by QE */ + u8 res1[0x70 - 0x64]; +} __packed; + +/* Tx firmware counters */ +struct uec_tx_firmware_statistics_pram { + u32 sicoltx; /* single collision */ + u32 mulcoltx; /* multiple collision */ + u32 latecoltxfr; /* late collision */ + u32 frabortduecol; /* frames aborted due to tx collision */ + u32 frlostinmactxer; /* frames lost due to internal MAC error tx */ + u32 carriersenseertx; /* carrier sense error */ + u32 frtxok; /* frames transmitted OK */ + u32 txfrexcessivedefer; + u32 txpkts256; /* total packets(including bad) 256~511 B */ + u32 txpkts512; /* total packets(including bad) 512~1023B */ + u32 txpkts1024; /* total packets(including bad) 1024~1518B */ + u32 txpktsjumbo; /* total packets(including bad) >1024 */ +} __packed; + +/* Tx global parameter table */ +struct uec_tx_global_pram { + u16 temoder; + u8 res0[0x38 - 0x02]; + u32 sqptr; + u32 schedulerbasepointer; + u32 txrmonbaseptr; + u32 tstate; + u8 iphoffset[MAX_IPH_OFFSET_ENTRY]; + u32 vtagtable[0x8]; + u32 tqptr; + u8 res2[0x80 - 0x74]; +} __packed; + +/****** Rx data struct collection ******/ +/* Rx thread data, each Rx thread has one this struct. */ +struct uec_thread_data_rx { + u8 res0[40]; +} __packed; + +/* Rx thread parameter, each Rx thread has one this struct. */ +struct uec_thread_rx_pram { + u8 res0[128]; +} __packed; + +/* Rx firmware counters */ +struct uec_rx_firmware_statistics_pram { + u32 frrxfcser; /* frames with crc error */ + u32 fraligner; /* frames with alignment error */ + u32 inrangelenrxer; /* in range length error */ + u32 outrangelenrxer; /* out of range length error */ + u32 frtoolong; /* frame too long */ + u32 runt; /* runt */ + u32 verylongevent; /* very long event */ + u32 symbolerror; /* symbol error */ + u32 dropbsy; /* drop because of BD not ready */ + u8 res0[0x8]; + u32 mismatchdrop; /* drop because of MAC filtering */ + u32 underpkts; /* total frames less than 64 octets */ + u32 pkts256; /* total frames(including bad)256~511 B */ + u32 pkts512; /* total frames(including bad)512~1023 B */ + u32 pkts1024; /* total frames(including bad)1024~1518 B */ + u32 pktsjumbo; /* total frames(including bad) >1024 B */ + u32 frlossinmacer; + u32 pausefr; /* pause frames */ + u8 res1[0x4]; + u32 removevlan; + u32 replacevlan; + u32 insertvlan; +} __packed; + +/* Rx interrupt coalescing entry, each Rx queue has one this entry. */ +struct uec_rx_interrupt_coalescing_entry { + u32 maxvalue; + u32 counter; +} __packed; + +struct uec_rx_interrupt_coalescing_table { + struct uec_rx_interrupt_coalescing_entry entry[MAX_RX_QUEUES]; +} __packed; + +/* RxBD queue entry, each Rx queue has one this entry. */ +struct uec_rx_bd_queues_entry { + u32 bdbaseptr; /* BD base pointer */ + u32 bdptr; /* BD pointer */ + u32 externalbdbaseptr; /* external BD base pointer */ + u32 externalbdptr; /* external BD pointer */ +} __packed; + +/* Rx global parameter table */ +struct uec_rx_global_pram { + u32 remoder; /* ethernet mode reg. */ + u32 rqptr; /* base pointer to the Rx Queues */ + u32 res0[0x1]; + u8 res1[0x20 - 0xc]; + u16 typeorlen; + u8 res2[0x1]; + u8 rxgstpack; /* ack on GRACEFUL STOP RX command */ + u32 rxrmonbaseptr; /* Rx RMON statistics base */ + u8 res3[0x30 - 0x28]; + u32 intcoalescingptr; /* Interrupt coalescing table pointer */ + u8 res4[0x36 - 0x34]; + u8 rstate; + u8 res5[0x46 - 0x37]; + u16 mrblr; /* max receive buffer length reg. */ + u32 rbdqptr; /* RxBD parameter table description */ + u16 mflr; /* max frame length reg. */ + u16 minflr; /* min frame length reg. */ + u16 maxd1; /* max dma1 length reg. */ + u16 maxd2; /* max dma2 length reg. */ + u32 ecamptr; /* external CAM address */ + u32 l2qt; /* VLAN priority mapping table. */ + u32 l3qt[0x8]; /* IP priority mapping table. */ + u16 vlantype; /* vlan type */ + u16 vlantci; /* default vlan tci */ + u8 addressfiltering[64];/* address filtering data structure */ + u32 exf_global_param; /* extended filtering global parameters */ + u8 res6[0x100 - 0xc4]; /* Initialize to zero */ +} __packed; + +#define GRACEFUL_STOP_ACKNOWLEDGE_RX 0x01 + +/****** UEC common ******/ +/* UCC statistics - hardware counters */ +struct uec_hardware_statistics { + u32 tx64; + u32 tx127; + u32 tx255; + u32 rx64; + u32 rx127; + u32 rx255; + u32 txok; + u16 txcf; + u32 tmca; + u32 tbca; + u32 rxfok; + u32 rxbok; + u32 rbyt; + u32 rmca; + u32 rbca; +} __packed; + +/* InitEnet command parameter */ +struct uec_init_cmd_pram { + u8 resinit0; + u8 resinit1; + u8 resinit2; + u8 resinit3; + u16 resinit4; + u8 res1[0x1]; + u8 largestexternallookupkeysize; + u32 rgftgfrxglobal; + u32 rxthread[MAX_ENET_INIT_PARAM_ENTRIES_RX]; /* rx threads */ + u8 res2[0x38 - 0x30]; + u32 txglobal; /* tx global */ + u32 txthread[MAX_ENET_INIT_PARAM_ENTRIES_TX]; /* tx threads */ + u8 res3[0x1]; +} __packed; + +#define ENET_INIT_PARAM_RGF_SHIFT (32 - 4) +#define ENET_INIT_PARAM_TGF_SHIFT (32 - 8) + +#define ENET_INIT_PARAM_RISC_MASK 0x0000003f +#define ENET_INIT_PARAM_PTR_MASK 0x00ffffc0 +#define ENET_INIT_PARAM_SNUM_MASK 0xff000000 +#define ENET_INIT_PARAM_SNUM_SHIFT 24 + +#define ENET_INIT_PARAM_MAGIC_RES_INIT0 0x06 +#define ENET_INIT_PARAM_MAGIC_RES_INIT1 0x30 +#define ENET_INIT_PARAM_MAGIC_RES_INIT2 0xff +#define ENET_INIT_PARAM_MAGIC_RES_INIT3 0x00 +#define ENET_INIT_PARAM_MAGIC_RES_INIT4 0x0400 + +/* structure representing 82xx Address Filtering Enet Address in PRAM */ +struct uec_82xx_enet_addr { + u8 res1[0x2]; + u16 h; /* address (MSB) */ + u16 m; /* address */ + u16 l; /* address (LSB) */ +} __packed; + +/* structure representing 82xx Address Filtering PRAM */ +struct uec_82xx_add_filtering_pram { + u32 iaddr_h; /* individual address filter, high */ + u32 iaddr_l; /* individual address filter, low */ + u32 gaddr_h; /* group address filter, high */ + u32 gaddr_l; /* group address filter, low */ + struct uec_82xx_enet_addr taddr; + struct uec_82xx_enet_addr paddr[4]; + u8 res0[0x40 - 0x38]; +} __packed; + +/* Buffer Descriptor */ +struct buffer_descriptor { + u16 status; + u16 len; + u32 data; +} __packed; + +#define SIZEOFBD sizeof(struct buffer_descriptor) + +/* Common BD flags */ +#define BD_WRAP 0x2000 +#define BD_INT 0x1000 +#define BD_LAST 0x0800 +#define BD_CLEAN 0x3000 + +/* TxBD status flags */ +#define TX_BD_READY 0x8000 +#define TX_BD_PADCRC 0x4000 +#define TX_BD_WRAP BD_WRAP +#define TX_BD_INT BD_INT +#define TX_BD_LAST BD_LAST +#define TX_BD_TXCRC 0x0400 +#define TX_BD_DEF 0x0200 +#define TX_BD_PP 0x0100 +#define TX_BD_LC 0x0080 +#define TX_BD_RL 0x0040 +#define TX_BD_RC 0x003C +#define TX_BD_UNDERRUN 0x0002 +#define TX_BD_TRUNC 0x0001 + +#define TX_BD_ERROR (TX_BD_UNDERRUN | TX_BD_TRUNC) + +/* RxBD status flags */ +#define RX_BD_EMPTY 0x8000 +#define RX_BD_OWNER 0x4000 +#define RX_BD_WRAP BD_WRAP +#define RX_BD_INT BD_INT +#define RX_BD_LAST BD_LAST +#define RX_BD_FIRST 0x0400 +#define RX_BD_CMR 0x0200 +#define RX_BD_MISS 0x0100 +#define RX_BD_BCAST 0x0080 +#define RX_BD_MCAST 0x0040 +#define RX_BD_LG 0x0020 +#define RX_BD_NO 0x0010 +#define RX_BD_SHORT 0x0008 +#define RX_BD_CRCERR 0x0004 +#define RX_BD_OVERRUN 0x0002 +#define RX_BD_IPCH 0x0001 + +#define RX_BD_ERROR (RX_BD_LG | RX_BD_NO | RX_BD_SHORT | \ + RX_BD_CRCERR | RX_BD_OVERRUN) + +/* BD access macros */ +#define BD_STATUS(_bd) (in_be16(&((_bd)->status))) +#define BD_STATUS_SET(_bd, _v) (out_be16(&((_bd)->status), _v)) +#define BD_LENGTH(_bd) (in_be16(&((_bd)->len))) +#define BD_LENGTH_SET(_bd, _v) (out_be16(&((_bd)->len), _v)) +#define BD_DATA_CLEAR(_bd) (out_be32(&((_bd)->data), 0)) +#define BD_DATA(_bd) ((u8 *)(((_bd)->data))) +#define BD_DATA_SET(_bd, _data) (out_be32(&((_bd)->data), (u32)_data)) +#define BD_ADVANCE(_bd, _status, _base) \ + (((_status) & BD_WRAP) ? (_bd) = \ + ((struct buffer_descriptor *)(_base)) : ++(_bd)) + +/* Rx Prefetched BDs */ +struct uec_rx_pref_bds { + struct buffer_descriptor bd[MAX_PREFETCHED_BDS]; /* prefetched bd */ +} __packed; + +/* Alignments */ +#define UEC_RX_GLOBAL_PRAM_ALIGNMENT 64 +#define UEC_TX_GLOBAL_PRAM_ALIGNMENT 64 +#define UEC_THREAD_RX_PRAM_ALIGNMENT 128 +#define UEC_THREAD_TX_PRAM_ALIGNMENT 64 +#define UEC_THREAD_DATA_ALIGNMENT 256 +#define UEC_SEND_QUEUE_QUEUE_DESCRIPTOR_ALIGNMENT 32 +#define UEC_SCHEDULER_ALIGNMENT 4 +#define UEC_TX_STATISTICS_ALIGNMENT 4 +#define UEC_RX_STATISTICS_ALIGNMENT 4 +#define UEC_RX_INTERRUPT_COALESCING_ALIGNMENT 4 +#define UEC_RX_BD_QUEUES_ALIGNMENT 8 +#define UEC_RX_PREFETCHED_BDS_ALIGNMENT 128 +#define UEC_RX_EXTENDED_FILTERING_GLOBAL_PARAMETERS_ALIGNMENT 4 +#define UEC_RX_BD_RING_ALIGNMENT 32 +#define UEC_TX_BD_RING_ALIGNMENT 32 +#define UEC_MRBLR_ALIGNMENT 128 +#define UEC_RX_BD_RING_SIZE_ALIGNMENT 4 +#define UEC_TX_BD_RING_SIZE_MEMORY_ALIGNMENT 32 +#define UEC_RX_DATA_BUF_ALIGNMENT 64 + +#define UEC_VLAN_PRIORITY_MAX 8 +#define UEC_IP_PRIORITY_MAX 64 +#define UEC_TX_VTAG_TABLE_ENTRY_MAX 8 +#define UEC_RX_BD_RING_SIZE_MIN 8 +#define UEC_TX_BD_RING_SIZE_MIN 2 + +/* TBI / MII Set Register */ +enum enet_tbi_mii_reg { + ENET_TBI_MII_CR = 0x00, + ENET_TBI_MII_SR = 0x01, + ENET_TBI_MII_ANA = 0x04, + ENET_TBI_MII_ANLPBPA = 0x05, + ENET_TBI_MII_ANEX = 0x06, + ENET_TBI_MII_ANNPT = 0x07, + ENET_TBI_MII_ANLPANP = 0x08, + ENET_TBI_MII_EXST = 0x0F, + ENET_TBI_MII_JD = 0x10, + ENET_TBI_MII_TBICON = 0x11 +}; + +/* TBI MDIO register bit fields*/ +#define TBICON_CLK_SELECT 0x0020 +#define TBIANA_ASYMMETRIC_PAUSE 0x0100 +#define TBIANA_SYMMETRIC_PAUSE 0x0080 +#define TBIANA_HALF_DUPLEX 0x0040 +#define TBIANA_FULL_DUPLEX 0x0020 +#define TBICR_PHY_RESET 0x8000 +#define TBICR_ANEG_ENABLE 0x1000 +#define TBICR_RESTART_ANEG 0x0200 +#define TBICR_FULL_DUPLEX 0x0100 +#define TBICR_SPEED1_SET 0x0040 + +#define TBIANA_SETTINGS ( \ + TBIANA_ASYMMETRIC_PAUSE \ + | TBIANA_SYMMETRIC_PAUSE \ + | TBIANA_FULL_DUPLEX \ + ) + +#define TBICR_SETTINGS ( \ + TBICR_PHY_RESET \ + | TBICR_ANEG_ENABLE \ + | TBICR_FULL_DUPLEX \ + | TBICR_SPEED1_SET \ + ) + +/* UEC number of threads */ +enum uec_num_of_threads { + UEC_NUM_OF_THREADS_1 = 0x1, /* 1 */ + UEC_NUM_OF_THREADS_2 = 0x2, /* 2 */ + UEC_NUM_OF_THREADS_4 = 0x0, /* 4 */ + UEC_NUM_OF_THREADS_6 = 0x3, /* 6 */ + UEC_NUM_OF_THREADS_8 = 0x4 /* 8 */ +}; + +/* UEC initialization info struct */ +#define STD_UEC_INFO(num) \ +{ \ + .uf_info = { \ + .ucc_num = CONFIG_SYS_UEC##num##_UCC_NUM,\ + .rx_clock = CONFIG_SYS_UEC##num##_RX_CLK, \ + .tx_clock = CONFIG_SYS_UEC##num##_TX_CLK, \ + .eth_type = CONFIG_SYS_UEC##num##_ETH_TYPE,\ + }, \ + .num_threads_tx = UEC_NUM_OF_THREADS_1, \ + .num_threads_rx = UEC_NUM_OF_THREADS_1, \ + .risc_tx = QE_RISC_ALLOCATION_RISC1_AND_RISC2, \ + .risc_rx = QE_RISC_ALLOCATION_RISC1_AND_RISC2, \ + .tx_bd_ring_len = 16, \ + .rx_bd_ring_len = 16, \ + .phy_address = CONFIG_SYS_UEC##num##_PHY_ADDR, \ + .enet_interface_type = CONFIG_SYS_UEC##num##_INTERFACE_TYPE, \ + .speed = CONFIG_SYS_UEC##num##_INTERFACE_SPEED, \ +} + +struct uec_inf { + struct ucc_fast_inf uf_info; + enum uec_num_of_threads num_threads_tx; + enum uec_num_of_threads num_threads_rx; + unsigned int risc_tx; + unsigned int risc_rx; + u16 rx_bd_ring_len; + u16 tx_bd_ring_len; + u8 phy_address; + phy_interface_t enet_interface_type; + int speed; +}; + +/* UEC driver initialized info */ +#define MAX_RXBUF_LEN 1536 +#define MAX_FRAME_LEN 1518 +#define MIN_FRAME_LEN 64 +#define MAX_DMA1_LEN 1520 +#define MAX_DMA2_LEN 1520 + +/* UEC driver private struct */ +struct uec_priv { + struct uec_inf *uec_info; + struct ucc_fast_priv *uccf; + struct eth_device *dev; + uec_t *uec_regs; + /* enet init command parameter */ + struct uec_init_cmd_pram *p_init_enet_param; + u32 init_enet_param_offset; + /* Rx and Tx parameter */ + struct uec_rx_global_pram *p_rx_glbl_pram; + u32 rx_glbl_pram_offset; + struct uec_tx_global_pram *p_tx_glbl_pram; + u32 tx_glbl_pram_offset; + struct uec_send_queue_mem_region *p_send_q_mem_reg; + u32 send_q_mem_reg_offset; + struct uec_thread_data_tx *p_thread_data_tx; + u32 thread_dat_tx_offset; + struct uec_thread_data_rx *p_thread_data_rx; + u32 thread_dat_rx_offset; + struct uec_rx_bd_queues_entry *p_rx_bd_qs_tbl; + u32 rx_bd_qs_tbl_offset; + /* BDs specific */ + u8 *p_tx_bd_ring; + u32 tx_bd_ring_offset; + u8 *p_rx_bd_ring; + u32 rx_bd_ring_offset; + u8 *p_rx_buf; + u32 rx_buf_offset; + struct buffer_descriptor *tx_bd; + struct buffer_descriptor *rx_bd; + /* Status */ + int mac_tx_enabled; + int mac_rx_enabled; + int grace_stopped_tx; + int grace_stopped_rx; + int the_first_run; +#if !defined(COFIG_DM) + /* PHY specific */ + struct uec_mii_info *mii_info; + int oldspeed; + int oldduplex; + int oldlink; +#endif +}; + +int uec_initialize(bd_t *bis, struct uec_inf *uec_info); +int uec_eth_init(bd_t *bis, struct uec_inf *uecs, int num); +int uec_standard_init(bd_t *bis); +#endif /* __UEC_H__ */ diff --git a/drivers/qe/uccf.c b/drivers/qe/uccf.c index 306f1ea1db..d5d734439c 100644 --- a/drivers/qe/uccf.c +++ b/drivers/qe/uccf.c @@ -14,6 +14,7 @@ #include "uccf.h" #include <fsl_qe.h>
+#if !defined(CONFIG_DM_ETH) void ucc_fast_transmit_on_demand(struct ucc_fast_priv *uccf) { out_be16(&uccf->uf_regs->utodr, UCC_FAST_TOD); @@ -505,3 +506,4 @@ int ucc_fast_init(struct ucc_fast_inf *uf_info, *uccf_ret = uccf; return 0; } +#endif diff --git a/drivers/qe/uec.c b/drivers/qe/uec.c index 1ead28f1dd..5f6f159af2 100644 --- a/drivers/qe/uec.c +++ b/drivers/qe/uec.c @@ -20,6 +20,7 @@ #include <fsl_qe.h> #include <phy.h>
+#if !defined(CONFIG_DM_ETH) /* Default UTBIPAR SMI address */ #ifndef CONFIG_UTBIPAR_INIT_TBIPA #define CONFIG_UTBIPAR_INIT_TBIPA 0x1F @@ -1432,3 +1433,4 @@ int uec_standard_init(bd_t *bis) { return uec_eth_init(bis, uec_info, ARRAY_SIZE(uec_info)); } +#endif diff --git a/drivers/qe/uec_phy.c b/drivers/qe/uec_phy.c index b5ca5f76f9..9d429c832f 100644 --- a/drivers/qe/uec_phy.c +++ b/drivers/qe/uec_phy.c @@ -23,6 +23,8 @@ #include <fsl_qe.h> #include <phy.h>
+#if !defined(CONFIG_DM_ETH) + #define ugphy_printk(format, arg...) \ printf(format "\n", ## arg)
@@ -925,3 +927,4 @@ void change_phy_interface_mode(struct eth_device *dev, marvell_phy_interface_mode(dev, type, speed); #endif } +#endif
enable DTS support for keymile mpc83xx based boards.
get rid of compile warning: ===================== WARNING ====================== This board does not use CONFIG_DM_ETH (Driver Model for Ethernet drivers). Please update the board to use CONFIG_DM_ETH before the v2020.07 release. Failure to update by the deadline may result in board removal. See doc/driver-model/migration.rst for more info. ====================================================
Therefore done: - add DTS for all mpc83xx based boards from keymile mainly they are not mainlined to linux. - add u-boot specific dtsi - add stdout-path - add missing ucc4 par_io definitions, which were in board code, but not in linux DTS - remove not used ethernet nodes
Signed-off-by: Heiko Schocher hs@denx.de
Changes in v2: - add patch which fixes Codingstyle errors in drivers/qe - add patch which converts the mpc83xx based boards from keymile to DM_ETH
arch/powerpc/cpu/mpc83xx/Kconfig | 8 + arch/powerpc/dts/Makefile | 8 + arch/powerpc/dts/km8309-uboot.dtsi | 33 ++ arch/powerpc/dts/km8321-uboot.dtsi | 67 ++++ arch/powerpc/dts/km8321.dtsi | 220 ++++++++++++ arch/powerpc/dts/km836x-uboot.dtsi | 61 ++++ arch/powerpc/dts/km836x.dtsi | 182 ++++++++++ arch/powerpc/dts/kmcoge5ne-uboot.dtsi | 22 ++ arch/powerpc/dts/kmcoge5ne.dts | 320 +++++++++++++++++ arch/powerpc/dts/kmeter1-uboot.dtsi | 42 +++ arch/powerpc/dts/kmeter1.dts | 480 ++++++++++++++++++++++++++ arch/powerpc/dts/kmopti2.dts | 161 +++++++++ arch/powerpc/dts/kmsupc5.dts | 139 ++++++++ arch/powerpc/dts/kmsupm5.dts | 129 +++++++ arch/powerpc/dts/kmtegr1.dts | 392 +++++++++++++++++++++ arch/powerpc/dts/kmtepr2.dts | 142 ++++++++ arch/powerpc/dts/kmtuge1.dts | 100 ++++++ arch/powerpc/dts/kmtuxa1.dts | 100 ++++++ board/keymile/km83xx/Kconfig | 17 + board/keymile/km83xx/MAINTAINERS | 23 +- board/keymile/km83xx/km83xx.c | 64 ---- configs/kmcoge5ne_defconfig | 11 +- configs/kmeter1_defconfig | 10 +- configs/kmopti2_defconfig | 11 +- configs/kmsupx5_defconfig | 10 +- configs/kmtegr1_defconfig | 12 +- configs/kmtepr2_defconfig | 10 +- configs/tuge1_defconfig | 10 +- configs/tuxx1_defconfig | 11 +- include/configs/km/km-mpc832x.h | 14 - include/configs/km/km-mpc8360.h | 14 - include/configs/km/km-mpc83xx.h | 10 - 32 files changed, 2694 insertions(+), 139 deletions(-) create mode 100644 arch/powerpc/dts/km8309-uboot.dtsi create mode 100644 arch/powerpc/dts/km8321-uboot.dtsi create mode 100644 arch/powerpc/dts/km8321.dtsi create mode 100644 arch/powerpc/dts/km836x-uboot.dtsi create mode 100644 arch/powerpc/dts/km836x.dtsi create mode 100644 arch/powerpc/dts/kmcoge5ne-uboot.dtsi create mode 100644 arch/powerpc/dts/kmcoge5ne.dts create mode 100644 arch/powerpc/dts/kmeter1-uboot.dtsi create mode 100644 arch/powerpc/dts/kmeter1.dts create mode 100644 arch/powerpc/dts/kmopti2.dts create mode 100644 arch/powerpc/dts/kmsupc5.dts create mode 100644 arch/powerpc/dts/kmsupm5.dts create mode 100644 arch/powerpc/dts/kmtegr1.dts create mode 100644 arch/powerpc/dts/kmtepr2.dts create mode 100644 arch/powerpc/dts/kmtuge1.dts create mode 100644 arch/powerpc/dts/kmtuxa1.dts
diff --git a/arch/powerpc/cpu/mpc83xx/Kconfig b/arch/powerpc/cpu/mpc83xx/Kconfig index 18808da37d..2bae08e278 100644 --- a/arch/powerpc/cpu/mpc83xx/Kconfig +++ b/arch/powerpc/cpu/mpc83xx/Kconfig @@ -101,34 +101,42 @@ config TARGET_IDS8313 config TARGET_KMETER1 bool "Support kmeter1" select VENDOR_KM + select KM_ENABLE_FULL_DM_DTS_SUPPORT
config TARGET_KMCOGE5NE bool "Support kmcoge5ne" select VENDOR_KM + select KM_ENABLE_FULL_DM_DTS_SUPPORT
config TARGET_KMTEGR1 bool "Support kmtegr1" select VENDOR_KM + select KM_ENABLE_FULL_DM_DTS_SUPPORT
config TARGET_TUXX1 bool "Support tuxx1" select VENDOR_KM + select KM_ENABLE_FULL_DM_DTS_SUPPORT
config TARGET_KMSUPX5 bool "Support kmsupx5" select VENDOR_KM + select KM_ENABLE_FULL_DM_DTS_SUPPORT
config TARGET_TUGE1 bool "Support tuge1" select VENDOR_KM + select KM_ENABLE_FULL_DM_DTS_SUPPORT
config TARGET_KMOPTI2 bool "Support kmopti2" select VENDOR_KM + select KM_ENABLE_FULL_DM_DTS_SUPPORT
config TARGET_KMTEPR2 bool "Support kmtepr2" select VENDOR_KM + select KM_ENABLE_FULL_DM_DTS_SUPPORT
config TARGET_TQM834X bool "Support TQM834x" diff --git a/arch/powerpc/dts/Makefile b/arch/powerpc/dts/Makefile index 7eb005f450..266d345f72 100644 --- a/arch/powerpc/dts/Makefile +++ b/arch/powerpc/dts/Makefile @@ -1,5 +1,11 @@ # SPDX-License-Identifier: GPL-2.0+
+dtb-$(CONFIG_TARGET_KMCOGE5NE) += kmcoge5ne.dtb +dtb-$(CONFIG_TARGET_KMETER1) += kmeter1.dtb +dtb-$(CONFIG_TARGET_KMOPTI2) += kmopti2.dtb +dtb-$(CONFIG_TARGET_KMSUPX5) += kmsupc5.dtb kmsupm5.dtb +dtb-$(CONFIG_TARGET_KMTEGR1) += kmtegr1.dtb +dtb-$(CONFIG_TARGET_KMTEPR2) += kmtepr2.dtb dtb-$(CONFIG_TARGET_MPC8548CDS) += mpc8548cds.dtb mpc8548cds_36b.dtb dtb-$(CONFIG_TARGET_P1010RDB_PA) += p1010rdb-pa.dtb p1010rdb-pa_36b.dtb dtb-$(CONFIG_TARGET_P1010RDB_PB) += p1010rdb-pb.dtb p1010rdb-pb_36b.dtb @@ -16,6 +22,8 @@ dtb-$(CONFIG_TARGET_T1042D4RDB) += t1042d4rdb.dtb dtb-$(CONFIG_TARGET_T2080QDS) += t2080qds.dtb dtb-$(CONFIG_TARGET_T2080RDB) += t2080rdb.dtb dtb-$(CONFIG_TARGET_T4240RDB) += t4240rdb.dtb +dtb-$(CONFIG_TARGET_TUGE1) += kmtuge1.dtb +dtb-$(CONFIG_TARGET_TUXX1) += kmtuxa1.dtb dtb-$(CONFIG_TARGET_MCR3000) += mcr3000.dtb dtb-$(CONFIG_TARGET_GAZERBEAM) += gazerbeam.dtb
diff --git a/arch/powerpc/dts/km8309-uboot.dtsi b/arch/powerpc/dts/km8309-uboot.dtsi new file mode 100644 index 0000000000..c44ce7d8dc --- /dev/null +++ b/arch/powerpc/dts/km8309-uboot.dtsi @@ -0,0 +1,33 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * ABB PGGA 8309 U-Boot specific Device Tree Source parts + * + * Copyright (C) 2020 Heiko Schocher hs@denx.de + * + */ + +/ { + cpus { + u-boot,dm-pre-reloc; + PowerPC,8309@0 { + u-boot,dm-pre-reloc; + }; + }; + + chosen { + stdout-path = &serial0; + }; +}; + +&qe { + compatible = "fsl,qe", "simple-bus"; +}; + +&soc { + u-boot,dm-pre-reloc; +}; + +&serial0 { + clock-frequency = <132000000>; + u-boot,dm-pre-reloc; +}; diff --git a/arch/powerpc/dts/km8321-uboot.dtsi b/arch/powerpc/dts/km8321-uboot.dtsi new file mode 100644 index 0000000000..348826057a --- /dev/null +++ b/arch/powerpc/dts/km8321-uboot.dtsi @@ -0,0 +1,67 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * ABB PGGA 8321 U-Boot specific Device Tree Source parts + * + * Copyright (C) 2020 Heiko Schocher hs@denx.de + * + */ + +/ { + cpus { + u-boot,dm-pre-reloc; + PowerPC,8321@0 { + u-boot,dm-pre-reloc; + }; + }; + + chosen { + stdout-path = &serial0; + }; +}; + +&enet_piggy2 { + status = "okay"; +}; + +&qe { + compatible = "fsl,qe", "simple-bus"; +}; + +&serial0 { + clock-frequency = <132000000>; + u-boot,dm-pre-reloc; +}; + +&soc { + u-boot,dm-pre-reloc; + + par_io@1400 { + compatible = "fsl,mpc8360-par_io"; + u-boot,dm-pre-reloc; + + serial_pin@0 { + u-boot,dm-pre-reloc; + }; + ucc_pin@0 { + u-boot,dm-pre-reloc; + }; + ucc_pin@1 { + u-boot,dm-pre-reloc; + }; + ucc_pin@3 { + u-boot,dm-pre-reloc; + }; + ucc_pin@4 { + u-boot,dm-pre-reloc; + }; + ucc_pin@5 { + u-boot,dm-pre-reloc; + }; + ucc_pin@6 { + u-boot,dm-pre-reloc; + }; + ucc_pin@7 { + u-boot,dm-pre-reloc; + }; + }; +}; diff --git a/arch/powerpc/dts/km8321.dtsi b/arch/powerpc/dts/km8321.dtsi new file mode 100644 index 0000000000..e49361359d --- /dev/null +++ b/arch/powerpc/dts/km8321.dtsi @@ -0,0 +1,220 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * ABB PGGA km8321 common ports Device Tree Source + * + * Copyright (C) 2020 Heiko Schocher hs@denx.de + * + */ + +/dts-v1/; + +/ { + cpus { + #address-cells = <1>; + #size-cells = <0>; + + PowerPC,8321@0 { + device_type = "cpu"; + reg = <0x0>; + d-cache-line-size = <32>; // 32 bytes + i-cache-line-size = <32>; // 32 bytes + d-cache-size = <16384>; // L1, 16K + i-cache-size = <16384>; // L1, 16K + timebase-frequency = <66000000>; + bus-frequency = <264000000>; + clock-frequency = <528000000>; + }; + }; + + memory { + device_type = "memory"; + reg = <0x00000000 0x10000000>; + }; + + soc: soc8321@e0000000 { + #address-cells = <1>; + #size-cells = <1>; + device_type = "soc"; + compatible = "simple-bus"; + ranges = <0x0 0xe0000000 0x00100000>; + reg = <0xe0000000 0x00000200>; + bus-frequency = <264000000>; + + i2c0: i2c@3000 { + #address-cells = <1>; + #size-cells = <0>; + cell-index = <0>; + compatible = "fsl,mpc8313-i2c","fsl-i2c"; + reg = <0x3000 0x100>; + interrupts = <14 0x8>; + interrupt-parent = <&ipic>; + clock-frequency = <100000>; + }; + + serial0: serial@4500 { + cell-index = <0>; + device_type = "serial"; + compatible = "fsl,ns16550", "ns16550"; + reg = <0x4500 0x100>; + clock-frequency = <264000000>; + interrupts = <9 0x8>; + interrupt-parent = <&ipic>; + }; + + dma@82a8 { + #address-cells = <1>; + #size-cells = <1>; + compatible = "fsl,mpc8321-dma", "fsl,elo-dma"; + reg = <0x82a8 4>; + ranges = <0 0x8100 0x1a8>; + interrupt-parent = <&ipic>; + interrupts = <71 8>; + cell-index = <0>; + dma-channel@0 { + compatible = "fsl,mpc8321-dma-channel", + "fsl,elo-dma-channel"; + reg = <0 0x80>; + interrupt-parent = <&ipic>; + interrupts = <71 8>; + }; + dma-channel@80 { + compatible = "fsl,mpc8321-dma-channel", + "fsl,elo-dma-channel"; + reg = <0x80 0x80>; + interrupt-parent = <&ipic>; + interrupts = <71 8>; + }; + dma-channel@100 { + compatible = "fsl,mpc8321-dma-channel", + "fsl,elo-dma-channel"; + reg = <0x100 0x80>; + interrupt-parent = <&ipic>; + interrupts = <71 8>; + }; + dma-channel@180 { + compatible = "fsl,mpc8321-dma-channel", + "fsl,elo-dma-channel"; + reg = <0x180 0x28>; + interrupt-parent = <&ipic>; + interrupts = <71 8>; + }; + }; + + ipic: pic@700 { + #address-cells = <0>; + #interrupt-cells = <2>; + compatible = "fsl,pq2pro-pic", "fsl,ipic"; + interrupt-controller; + reg = <0x700 0x100>; + device_type = "ipic"; + }; + + par_io: par_io@1400 { + #address-cells = <1>; + #size-cells = <1>; + reg = <0x1400 0x100>; + ranges; + device_type = "par_io"; + num-ports = <7>; + + qe_pio_d: gpio-controller@48 { + #gpio-cells = <2>; + compatible = "fsl,mpc8360-qe-pario-bank", + "fsl,mpc8323-qe-pario-bank"; + reg = <0x1448 0x18>; + gpio-controller; + }; + }; + }; + + qe: qe@e0100000 { + #address-cells = <1>; + #size-cells = <1>; + device_type = "qe"; + compatible = "fsl,qe"; + ranges = <0x0 0xe0100000 0x00100000>; + reg = <0xe0100000 0x480>; + brg-frequency = <0>; + bus-frequency = <396000000>; + + muram@10000 { + #address-cells = <1>; + #size-cells = <1>; + compatible = "fsl,qe-muram", "fsl,cpm-muram"; + ranges = <0x0 0x00010000 0x00004000>; + + data-only@0 { + compatible = "fsl,qe-muram-data", + "fsl,cpm-muram-data"; + reg = <0x0 0x4000>; + }; + }; + + /* Piggy2 (UCC4, MDIO 0x00, RMII) */ + enet_piggy2: ucc@3200 { + device_type = "network"; + compatible = "ucc_geth"; + cell-index = <4>; + reg = <0x3200 0x200>; + interrupts = <35>; + interrupt-parent = <&qeic>; + local-mac-address = [ 00 00 00 00 00 00 ]; + rx-clock-name = "none"; + tx-clock-name = "clk17"; + phy-handle = <&phy_piggy2>; + phy-connection-type = "rmii"; + pio-handle = <&pio_ucc4>; + }; + + mdio: mdio@3320 { + #address-cells = <1>; + #size-cells = <0>; + reg = <0x3320 0x18>; + compatible = "fsl,ucc-mdio"; + + /* Piggy2 (UCC4, MDIO 0x00, RMII) */ + phy_piggy2: ethernet-phy@00 { + reg = <0x0>; + device_type = "ethernet-phy"; + }; + }; + + qeic: interrupt-controller@80 { + interrupt-controller; + compatible = "fsl,qe-ic"; + #address-cells = <0>; + #interrupt-cells = <1>; + reg = <0x80 0x80>; + big-endian; + interrupts = <32 8 33 8>; + interrupt-parent = <&ipic>; + }; + bootcount@0x13ff8 { + device_type = "bootcount"; + compatible = "u-boot,bootcount"; + reg = <0x13ff8 0x08>; + }; + + spi0: spi@4c0 { + cell-index = <0>; + compatible = "fsl,spi"; + reg = <0x4c0 0x40>; + interrupts = <2>; + interrupt-parent = <&qeic>; + mode = "qe"; + #address-cells = <1>; + #size-cells = <0>; + pio-handle = <&pio_spi>; + }; + }; + + localbus: localbus@e0005000 { + #address-cells = <2>; + #size-cells = <1>; + compatible = "fsl,mpc8321-localbus", "fsl,pq2pro-localbus", + "simple-bus"; + reg = <0xe0005000 0xd8>; + }; +}; + +#include "km8321-uboot.dtsi" diff --git a/arch/powerpc/dts/km836x-uboot.dtsi b/arch/powerpc/dts/km836x-uboot.dtsi new file mode 100644 index 0000000000..ac5339eff6 --- /dev/null +++ b/arch/powerpc/dts/km836x-uboot.dtsi @@ -0,0 +1,61 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * ABB PGGA km836x U-Boot specific Device Tree Source parts + * + * Copyright (C) 2020 Heiko Schocher hs@denx.de + * + */ + +/ { + cpus { + u-boot,dm-pre-reloc; + PowerPC,8360@0 { + u-boot,dm-pre-reloc; + }; + }; + + chosen { + stdout-path = &serial0; + }; +}; + +&qe { + compatible = "fsl,qe", "simple-bus"; +}; + +&soc { + u-boot,dm-pre-reloc; + + par_io@1400 { + u-boot,dm-pre-reloc; + + serial_pin@0 { + u-boot,dm-pre-reloc; + }; + ucc_pin@0 { + u-boot,dm-pre-reloc; + }; + ucc_pin@1 { + u-boot,dm-pre-reloc; + }; + ucc_pin@3 { + u-boot,dm-pre-reloc; + }; + ucc_pin@4 { + u-boot,dm-pre-reloc; + }; + ucc_pin@5 { + u-boot,dm-pre-reloc; + }; + ucc_pin@6 { + u-boot,dm-pre-reloc; + }; + ucc_pin@7 { + u-boot,dm-pre-reloc; + }; + }; +}; + +&serial0 { + u-boot,dm-pre-reloc; +}; diff --git a/arch/powerpc/dts/km836x.dtsi b/arch/powerpc/dts/km836x.dtsi new file mode 100644 index 0000000000..a8c83fc7e3 --- /dev/null +++ b/arch/powerpc/dts/km836x.dtsi @@ -0,0 +1,182 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * ABB PGGA km836x common ports Device Tree Source + * + * Copyright (C) 2020 Heiko Schocher hs@denx.de + * + */ + +/dts-v1/; + +/ { + #address-cells = <1>; + #size-cells = <1>; + + cpus { + #address-cells = <1>; + #size-cells = <0>; + + PowerPC,8360@0 { + device_type = "cpu"; + reg = <0x0>; + d-cache-line-size = <32>; /* 32 bytes */ + i-cache-line-size = <32>; /* 32 bytes */ + d-cache-size = <32768>; /* L1, 32K */ + i-cache-size = <32768>; /* L1, 32K */ + timebase-frequency = <0>; /* Filled in by U-Boot */ + bus-frequency = <0>; /* Filled in by U-Boot */ + clock-frequency = <0>; /* Filled in by U-Boot */ + }; + }; + + memory { + device_type = "memory"; + reg = <0 0>; /* Filled in by U-Boot */ + }; + + soc: soc8360@e0000000 { + #address-cells = <1>; + #size-cells = <1>; + device_type = "soc"; + compatible = "fsl,mpc8360-immr", "simple-bus"; + ranges = <0x0 0xe0000000 0x00200000>; + reg = <0xe0000000 0x00000200>; + bus-frequency = <0>;/* Filled in by U-Boot */ + + /* power management control module*/ + pmc: power@b00 { + compatible = "fsl,mpc8360-pmc", "fsl,mpc8349-pmc"; + reg = <0xb00 0x100 0xa00 0x100>; + interrupts = <80 0x8>; + interrupt-parent = <&ipic>; + }; + + i2c0: i2c@3000 { + #address-cells = <1>; + #size-cells = <0>; + cell-index = <0>; + compatible = "fsl,mpc8313-i2c","fsl-i2c"; + reg = <0x3000 0x100>; + interrupts = <14 0x8>; + interrupt-parent = <&ipic>; + clock-frequency = <100000>; + }; + + serial0: serial@4500 { + cell-index = <0>; + device_type = "serial"; + compatible = "fsl,ns16550", "ns16550"; + reg = <0x4500 0x100>; + clock-frequency = <264000000>; + interrupts = <9 0x8>; + interrupt-parent = <&ipic>; + status = "disabled"; + }; + + serial1: serial@4600 { + cell-index = <1>; + device_type = "serial"; + compatible = "fsl,ns16550", "ns16550"; + reg = <0x4600 0x100>; + clock-frequency = <133333333>; + interrupts = <10 0x8>; + interrupt-parent = <&ipic>; + status = "disabled"; + }; + + ipic: pic@700 { + #address-cells = <0>; + #interrupt-cells = <2>; + compatible = "fsl,pq2pro-pic", "fsl,ipic"; + interrupt-controller; + reg = <0x700 0x100>; + }; + + par_io: par_io@1400 { + #address-cells = <1>; + #size-cells = <1>; + reg = <0x1400 0x100>; + ranges; + compatible = "fsl,mpc8360-par_io"; + device_type = "par_io"; + num-ports = <7>; + + qe_pio_c: gpio-controller@30 { + #gpio-cells = <2>; + compatible = "fsl,mpc8360-qe-pario-bank", + "fsl,mpc8323-qe-pario-bank"; + reg = <0x1430 0x18>; + gpio-controller; + }; + }; + + qe: qe@100000 { + #address-cells = <1>; + #size-cells = <1>; + compatible = "fsl,qe"; + ranges = <0x0 0x100000 0x100000>; + reg = <0x100000 0x480>; + clock-frequency = <0>; /* Filled in by U-Boot */ + brg-frequency = <0>; /* Filled in by U-Boot */ + bus-frequency = <0>; /* Filled in by U-Boot */ + + muram@10000 { + #address-cells = <1>; + #size-cells = <1>; + compatible = "fsl,qe-muram", "fsl,cpm-muram"; + ranges = <0x0 0x00010000 0x0000c000>; + + data-only@0 { + compatible = "fsl,qe-muram-data", + "fsl,cpm-muram-data"; + reg = <0x0 0xc000>; + }; + }; + + qeic: interrupt-controller@80 { + interrupt-controller; + compatible = "fsl,qe-ic"; + #address-cells = <0>; + #interrupt-cells = <1>; + reg = <0x80 0x80>; + big-endian; + interrupts = < + 32 0x8 /* ucc1 */ + 33 0x8 /* ucc2 */ + 34 0x8 /* ucc3 */ + 35 0x8 /* ucc4 */ + 40 0x8 /* ucc1 */ + >; + interrupt-parent = <&ipic>; + }; + + spi0: spi@4c0 { + cell-index = <0>; + compatible = "fsl,spi"; + reg = <0x4c0 0x40>; + interrupts = <2>; + interrupt-parent = <&qeic>; + mode = "qe"; + #address-cells = <1>; + #size-cells = <0>; + pio-handle = <&pio_spi>; + }; + + bootcount@0x1bff8 { + device_type = "bootcount"; + compatible = "u-boot,bootcount"; + reg = <0x1bff8 0x08>; + }; + }; + }; + + localbus: localbus@e0005000 { + #address-cells = <2>; + #size-cells = <1>; + compatible = "fsl,mpc8360-localbus", "fsl,pq2pro-localbus", + "simple-bus"; + reg = <0xe0005000 0xd8>; + }; +}; + +#include "km836x-uboot.dtsi" diff --git a/arch/powerpc/dts/kmcoge5ne-uboot.dtsi b/arch/powerpc/dts/kmcoge5ne-uboot.dtsi new file mode 100644 index 0000000000..6a5e74f434 --- /dev/null +++ b/arch/powerpc/dts/kmcoge5ne-uboot.dtsi @@ -0,0 +1,22 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * ABB PGGA kmcoge5ne U-Boot specific Device Tree Source parts + * + * Copyright (C) 2020 Heiko Schocher hs@denx.de + * + */ + +/ { + aliases { + /delete-property/ ethernet1; + /delete-property/ ethernet2; + }; +}; + +&enet_switch { + status = "disabled"; +}; + +&enet_mate { + status = "disabled"; +}; diff --git a/arch/powerpc/dts/kmcoge5ne.dts b/arch/powerpc/dts/kmcoge5ne.dts new file mode 100644 index 0000000000..467e5bd9d2 --- /dev/null +++ b/arch/powerpc/dts/kmcoge5ne.dts @@ -0,0 +1,320 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * ABB PGGA KMCOGE5ne Device Tree Source + * + * Copyright (C) 2020 Heiko Schocher hs@denx.de + * + */ + +/dts-v1/; + +#include "km836x.dtsi" + +/ { + model = "kmcoge5ne"; + compatible = "ABB,kmcoge5ne"; + + aliases { + ethernet0 = &enet_admin; + ethernet1 = &enet_mate; + ethernet2 = &enet_switch; + serial0 = &serial0; + }; +}; + +&soc { + /* brg for hdlc clk */ + brg@0 { + compatible = "fsl,mpc-brg"; + brg-name = "brg16"; + brg-frequency = <20000000>; /* 20 MHz */ + pio-handle = <&pio_brg>; + }; +}; + +&i2c0 { + mux@70 { + compatible = "nxp,pca9547"; + reg = <0x70>; + #address-cells = <1>; + #size-cells = <0>; + + i2c@1 { + reg = <1>; + #address-cells = <1>; + #size-cells = <0>; + + /* Inventory EEPROM of the unit itself */ + ivm@50 { + label = "MAIN_CTRL"; + compatible = "dummy"; + reg = <0x50>; + }; + }; + + i2c@2 { + reg = <2>; + #address-cells = <1>; + #size-cells = <0>; + + /* Inventory EEPROM of the fan unit */ + fanu-ivm@50 { + label = "FANUV"; + compatible = "dummy"; + reg = <0x50>; + }; + + /* fan unit (GPIOs and so on) */ + fanu@20 { + label = "FANUV_CTRL"; + compatible = "dummy"; + reg = <0x20>; + }; + }; + + i2c@3 { + reg = <3>; + #address-cells = <1>; + #size-cells = <0>; + + backplane@50 { + label = "BP_CTRL"; + compatible = "dummy"; + reg = <0x50>; + }; + }; + }; +}; + +&serial0 { + status = "okay"; +}; + +&par_io { + pio_ucc1: ucc_pin@0 { /* RGMII mng-switch */ + pio-map = < + /* port pin dir open_drain assignment has_irq */ + 0 1 3 0 2 0 /* MDIO (PA1, bi, f2) */ + 0 2 1 0 1 0 /* MDC (PA2, in, f1) */ + + 0 3 1 0 1 0 /* TxD0 (PA3, in, f1) */ + 0 4 1 0 1 0 /* TxD1 (PA4, in, f1) */ + 0 5 1 0 1 0 /* TxD2 (PA5, in, f1) */ + 0 6 1 0 1 0 /* TxD3 (PA6, in, f1) */ + 0 9 2 0 1 0 /* RxD0 (PA9, out, f1) */ + 0 10 2 0 1 0 /* RxD1 (PA10, out, f1) */ + 0 11 2 0 1 0 /* RxD2 (PA11, out, f1) */ + 0 12 2 0 1 0 /* RxD3 (PA12, out, f1) */ + 0 7 1 0 1 0 /* TX_EN (PA7, in, f1) */ + 0 15 2 0 1 0 /* RX_DV (PA15, out, f1) */ + 0 0 2 0 1 0 /* RX_CLK (PA0, out, f1) */ + 2 9 1 0 3 0 /* GTX_CLK (CLK10) */ + 2 8 2 0 1 0 /* GTX125 (CLK9) */ + >; + }; + + pio_ucc4: ucc_pin@3 { /* RMII, admin front port */ + pio-map = < + /* port pin dir open_drain assignment has_irq */ + 0 1 3 0 2 0 /* MDIO (PA1, bi, f2) */ + 0 2 1 0 1 0 /* MDC (PA2, in, f1) */ + + 1 14 1 0 1 0 /* TxD0 (PB14, out, f1) */ + 1 15 1 0 1 0 /* TxD1 (PB15, out, f1) */ + 1 20 2 0 1 0 /* RxD0 (PB20, in, f1) */ + 1 21 2 0 1 0 /* RxD1 (PB21, in, f1) */ + 1 18 1 0 1 0 /* TX_EN (PB18, out, f1) */ + 1 26 2 0 1 0 /* RX_DV (PB26, in, f1) */ + 1 27 2 0 1 0 /* RX_ER (PB27, in, f1) */ + + 2 16 2 0 1 0 /* UCC4_RMII_CLK (CLK17) */ + >; + }; + + pio_ucc5: ucc_pin@4 { /* RMII, mate backplane port */ + pio-map = < + /* port pin dir open_drain assignment has_irq */ + 0 1 3 0 2 0 /* MDIO (PA1, bi, f2) */ + 0 2 1 0 1 0 /* MDC (PA2, in, f1) */ + + 3 0 1 0 1 0 /* TxD0 (PD0, out, f1) */ + 3 1 1 0 1 0 /* TxD1 (PD1, out, f1) */ + 3 6 2 0 1 0 /* RxD0 (PD6, in, f1) */ + 3 7 2 0 1 0 /* RxD1 (PD7, in, f1) */ + 3 4 1 0 1 0 /* TX_EN (PD4, out, f1) */ + 3 12 2 0 1 0 /* RX_DV (PD12, in, f1) */ + 3 13 2 0 1 0 /* RX_ER (PD13, in, f1) */ + + 2 15 2 0 1 0 /* UCCx_RMII_CLK (CLK16) */ + >; + }; + + pio_spi: spi_pin@01 { + pio-map = < + /* port pin dir open_drain assignment has_irq */ + 4 28 3 0 3 0 /* SPI_MOSI (PE28, out, f3) */ + 4 29 3 0 3 0 /* SPI_MISO (PE29, out, f3) */ + 4 30 3 0 3 0 /* SPI_CLK (PE30, out, f3) */ + >; + }; + + pio_brg: brg_pin@0 { + pio-map = < + /* port pin dir open_drain assignment has_irq */ + 2 25 1 0 1 0 /* BRG (PC25, out, f1) */ + >; + }; + + pio_tdm: tdm_pin@00 { + pio-map = < + /* port pin dir open_drain assignment has_irq */ + /* TDMa */ + 0 8 3 0 2 0 /* RxD0 (PA8, bi, f2) */ + 0 13 3 0 2 0 /* TxD0 (PA13, bi, f2) */ + 0 14 2 0 2 0 /* RSync0 (PA14, in, f2) */ + 2 7 2 0 1 0 /* RxClk8 (PC7, in, f1) */ + /* TDMb */ + 0 27 3 0 2 0 /* RxD1 (PA27, bi, f2) */ + 0 22 3 0 2 0 /* TxD1 (PA22, bi, f2) */ + 0 28 2 0 2 0 /* RSync1 (PA28, in, f2) */ + 2 1 2 0 1 0 /* RxClk2 (PC1, in, f1) */ + /* TDMc */ + 1 5 3 0 2 0 /* RxD2 (PB5, bi, f2) */ + 1 8 3 0 2 0 /* TxD2 (PB8, bi, f2) */ + 1 2 2 0 3 0 /* RSync2 (PB2, in, f3) */ + 2 6 2 0 1 0 /* RxClk7 (PC6, in, f1) */ + /* TDMd */ + 1 22 3 0 2 0 /* RxD3 (PB22, bi, f2) */ + 1 19 3 0 1 0 /* TxD3 (PB19, bi, f1) */ + 1 16 2 0 2 0 /* RSync3 (PB16, in, f2) */ + 2 13 2 0 1 0 /* RxClk14 (PC13, in, f1) */ + /* TDMe */ + 3 8 3 0 2 0 /* RxD4 (PD8, bi, f2) */ + 3 5 3 0 2 0 /* TxD4 (PD5, bi, f2) */ + 3 2 2 0 2 0 /* RSync4 (PD2 , in, f2) */ + 2 22 2 0 1 0 /* RxClk23 (PC22, in, f1) */ + /* TDMf */ + 3 19 3 0 2 0 /* RxD5 (PD19, bi, f2) */ + 3 22 3 0 2 0 /* TxD5 (PD22, bi, f2) */ + 3 16 2 0 1 0 /* RSync5 (PD16, in, f1) */ + 2 17 2 0 1 0 /* RxClk18 (PC17, in, f1) */ + /* TDMg */ + 4 8 3 0 2 0 /* RxD6 (PE8, bi, f2) */ + 4 5 3 0 2 0 /* TxD6 (PE5, bi, f2) */ + 4 2 2 0 1 0 /* RSync6 (PE2, in, f1) */ + 2 19 2 0 1 0 /* RxClk20 (PC19, in, f1) */ + /* TDMh */ + 4 19 3 0 2 0 /* RxD7 (PE19, bi, f2) */ + 4 22 3 0 3 0 /* TxD7 (PE22, bi, f3) */ + 4 16 2 0 2 0 /* RSync7 (PE16, in, f2) */ + 2 21 2 0 1 0 /* RxClk22 (PC21, in, f1) */ + /* RxTxClk0/1 */ + 2 0 2 0 1 0 /* Clk1 (PC0, in, f1) */ + 2 23 2 0 1 0 /* Clk24 (PC23, in, f1) */ + /* RxTxSync0/1 */ + 2 10 2 0 1 0 /* Clk11 (PC10, in, f1) */ + 2 20 2 0 1 0>; /* Clk21 (PC20, in, f1) */ + }; +}; + +&qe { + /* mng-switch port (UCC1, MDIO 0x10, RGMII) */ + enet_switch: ethernet@2000 { + device_type = "network"; + compatible = "ucc_geth"; + cell-index = <1>; + reg = <0x2000 0x200>; + interrupts = <32>; + interrupt-parent = <&qeic>; + local-mac-address = [ 00 00 00 00 00 00 ]; + rx-clock-name = "none"; + tx-clock-name = "clk9"; + /*id=0, full-dup, 1G, no-pause, no-asym_p*/ + fixed-link = <0 1 1000 0 0>; + phy-connection-type = "rgmii-id"; + pio-handle = <&pio_ucc1>; + }; + + /* admin and debug port (UCC4, MDIO 0x00, RMII) */ + enet_admin: ucc@3200 { + device_type = "network"; + compatible = "ucc_geth"; + cell-index = <4>; + reg = <0x3200 0x200>; + interrupts = <35>; + interrupt-parent = <&qeic>; + local-mac-address = [ 00 00 00 00 00 00 ]; + rx-clock-name = "none"; + tx-clock-name = "clk17"; + phy-handle = <&phy_admin>; + phy-connection-type = "rmii"; + pio-handle = <&pio_ucc4>; + }; + + /* mate backplane port (UCC5, MDIO 0x08, RMII) */ + enet_mate: ucc@2400 { + device_type = "network"; + compatible = "ucc_geth"; + cell-index = <5>; + reg = <0x2400 0x200>; + interrupts = <40>; + interrupt-parent = <&qeic>; + local-mac-address = [ 00 00 00 00 00 00 ]; + rx-clock-name = "none"; + tx-clock-name = "clk16"; + phy-handle = <&phy_mate>; + phy-connection-type = "rmii"; + pio-handle = <&pio_ucc5>; + }; + + mdio@3320 { + #address-cells = <1>; + #size-cells = <0>; + reg = <0x3320 0x18>; + compatible = "fsl,ucc-mdio"; + + /* admin front port (UCC4, MDIO 0x00, RMII) */ + phy_admin: ethernet-phy@00 { + reg = <0x0>; + }; + + /* mate bp port (UCC5, MDIO 0x08, RMII) */ + phy_mate: ethernet-phy@08 { + reg = <0x08>; + }; + }; +}; + +&localbus { + ranges = <0 0 0xf0000000 0x04000000 + 1 0 0xe8000000 0x01000000 + 3 0 0xa0000000 0x10000000 + 4 0 0xb0000000 0x10000000>; + + flash@0,0 { + compatible = "cfi-flash"; + reg = <0 0 0x04000000>; + nornand = "nor"; + #address-cells = <1>; + #size-cells = <1>; + bank-width = <2>; + partition@0 { /* 768KB */ + label = "u-boot"; + reg = <0 0xC0000>; + }; + partition@c0000 { /* 128KB */ + label = "env"; + reg = <0xC0000 0x20000>; + }; + partition@e0000 { /* 128KB */ + label = "envred"; + reg = <0xE0000 0x20000>; + }; + partition@100000 { /* 64512KB */ + label = "ubi0"; + reg = <0x100000 0x3F00000>; + }; + }; +}; + +#include "kmcoge5ne-uboot.dtsi" diff --git a/arch/powerpc/dts/kmeter1-uboot.dtsi b/arch/powerpc/dts/kmeter1-uboot.dtsi new file mode 100644 index 0000000000..898fa7dc7a --- /dev/null +++ b/arch/powerpc/dts/kmeter1-uboot.dtsi @@ -0,0 +1,42 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * ABB PGGA kmeter1 U-Boot specific Device Tree Source parts + * + * Copyright (C) 2020 Heiko Schocher hs@denx.de + * + */ + +/ { + aliases { + /delete-property/ ethernet1; + /delete-property/ ethernet2; + /delete-property/ ethernet3; + /delete-property/ ethernet4; + /delete-property/ ethernet5; + /delete-property/ ethernet6; + }; +}; + +&enet_estar1 { + status = "disabled"; +}; + +&enet_estar2 { + status = "disabled"; +}; + +&enet_eth1 { + status = "disabled"; +}; + +&enet_eth2 { + status = "disabled"; +}; + +&enet_eth3 { + status = "disabled"; +}; + +&enet_eth4 { + status = "disabled"; +}; diff --git a/arch/powerpc/dts/kmeter1.dts b/arch/powerpc/dts/kmeter1.dts new file mode 100644 index 0000000000..f1f79952ab --- /dev/null +++ b/arch/powerpc/dts/kmeter1.dts @@ -0,0 +1,480 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * ABB PGGA KMETER1 Device Tree Source + * + * 2008-2011 DENX Software Engineering GmbH + * Copyright (C) 2020 Heiko Schocher hs@denx.de + */ + +/dts-v1/; + +#include "km836x.dtsi" + +/ { + model = "KMETER1"; + compatible = "ABB,KMETER1"; + + aliases { + ethernet0 = &enet_piggy2; + ethernet1 = &enet_estar1; + ethernet2 = &enet_estar2; + ethernet3 = &enet_eth1; + ethernet4 = &enet_eth2; + ethernet5 = &enet_eth3; + ethernet6 = &enet_eth4; + serial0 = &serial0; + }; +}; + +&i2c0 { + mux@70 { + compatible = "nxp,pca9547"; + reg = <0x70>; + #address-cells = <1>; + #size-cells = <0>; + + i2c@1 { + reg = <1>; + #address-cells = <1>; + #size-cells = <0>; + + /* Inventory EEPROM of the unit itself */ + ivm@50 { + label = "MAIN_CTRL"; + compatible = "dummy"; + reg = <0x50>; + }; + }; + + i2c@2 { + reg = <2>; + #address-cells = <1>; + #size-cells = <0>; + + /* Temperature sensors */ + temp@48 { + label = "Top"; + compatible = "national,lm75"; + reg = <0x48>; + }; + + temp@49 { + label = "Control"; + compatible = "national,lm75"; + reg = <0x49>; + }; + + temp@4a { + label = "Power"; + compatible = "national,lm75"; + reg = <0x4a>; + }; + + temp@4b { + label = "Front"; + compatible = "national,lm75"; + reg = <0x4b>; + }; + }; + }; +}; + +&serial0 { + status = "okay"; +}; + +&par_io { + pio_ucc1: ucc_pin@0 { + pio-map = < + /* port pin dir open_drain assignment has_irq */ + 0 1 3 0 2 0 /* MDIO */ + 0 2 1 0 1 0 /* MDC */ + + 0 3 1 0 1 0 /* TxD0 */ + 0 4 1 0 1 0 /* TxD1 */ + 0 5 1 0 1 0 /* TxD2 */ + 0 6 1 0 1 0 /* TxD3 */ + 0 9 2 0 1 0 /* RxD0 */ + 0 10 2 0 1 0 /* RxD1 */ + 0 11 2 0 1 0 /* RxD2 */ + 0 12 2 0 1 0 /* RxD3 */ + 0 7 1 0 1 0 /* TX_EN */ + 0 8 1 0 1 0 /* TX_ER */ + 0 15 2 0 1 0 /* RX_DV */ + 0 16 2 0 1 0 /* RX_ER */ + 0 0 2 0 1 0 /* RX_CLK */ + 2 9 1 0 3 0 /* GTX_CLK - CLK10 */ + 2 8 2 0 1 0 /* GTX125 - CLK9 */ + >; + }; + + pio_ucc2: ucc_pin@1 { + pio-map = < + /* port pin dir open_drain assignment has_irq */ + 0 1 3 0 2 0 /* MDIO */ + 0 2 1 0 1 0 /* MDC */ + + 0 17 1 0 1 0 /* TxD0 */ + 0 18 1 0 1 0 /* TxD1 */ + 0 19 1 0 1 0 /* TxD2 */ + 0 20 1 0 1 0 /* TxD3 */ + 0 23 2 0 1 0 /* RxD0 */ + 0 24 2 0 1 0 /* RxD1 */ + 0 25 2 0 1 0 /* RxD2 */ + 0 26 2 0 1 0 /* RxD3 */ + 0 21 1 0 1 0 /* TX_EN */ + 0 22 1 0 1 0 /* TX_ER */ + 0 29 2 0 1 0 /* RX_DV */ + 0 30 2 0 1 0 /* RX_ER */ + 0 31 2 0 1 0 /* RX_CLK */ + 2 2 1 0 2 0 /* GTX_CLK - CLK3 */ + 2 3 2 0 1 0 /* GTX125 - CLK4 */ + >; + }; + + pio_ucc4: ucc_pin@3 { + pio-map = < + /* port pin dir open_drain assignment has_irq */ + 0 1 3 0 2 0 /* MDIO */ + 0 2 1 0 1 0 /* MDC */ + + 1 14 1 0 1 0 /* TxD0 (PB14, out, f1) */ + 1 15 1 0 1 0 /* TxD1 (PB15, out, f1) */ + 1 20 2 0 1 0 /* RxD0 (PB20, in, f1) */ + 1 21 2 0 1 0 /* RxD1 (PB21, in, f1) */ + 1 18 1 0 1 0 /* TX_EN (PB18, out, f1) */ + 1 26 2 0 1 0 /* RX_DV (PB26, in, f1) */ + 1 27 2 0 1 0 /* RX_ER (PB27, in, f1) */ + + 2 16 2 0 1 0 /* UCC4_RMII_CLK (CLK17) */ + >; + }; + + pio_ucc5: ucc_pin@4 { + pio-map = < + /* port pin dir open_drain assignment has_irq */ + 0 1 3 0 2 0 /* MDIO */ + 0 2 1 0 1 0 /* MDC */ + + 3 0 1 0 1 0 /* TxD0 (PD0, out, f1) */ + 3 1 1 0 1 0 /* TxD1 (PD1, out, f1) */ + 3 6 2 0 1 0 /* RxD0 (PD6, in, f1) */ + 3 7 2 0 1 0 /* RxD1 (PD7, in, f1) */ + 3 4 1 0 1 0 /* TX_EN (PD4, out, f1) */ + 3 12 2 0 1 0 /* RX_DV (PD12, in, f1) */ + 3 13 2 0 1 0 /* RX_ER (PD13, in, f1) */ + >; + }; + + pio_ucc6: ucc_pin@5 { + pio-map = < + /* port pin dir open_drain assignment has_irq */ + 0 1 3 0 2 0 /* MDIO */ + 0 2 1 0 1 0 /* MDC */ + + 3 14 1 0 1 0 /* TxD0 (PD14, out, f1) */ + 3 15 1 0 1 0 /* TxD1 (PD15, out, f1) */ + 3 20 2 0 1 0 /* RxD0 (PD20, in, f1) */ + 3 21 2 0 1 0 /* RxD1 (PD21, in, f1) */ + 3 18 1 0 1 0 /* TX_EN (PD18, out, f1) */ + 3 26 2 0 1 0 /* RX_DV (PD26, in, f1) */ + 3 27 2 0 1 0 /* RX_ER (PD27, in, f1) */ + >; + }; + + pio_ucc7: ucc_pin@6 { + pio-map = < + /* port pin dir open_drain assignment has_irq */ + 0 1 3 0 2 0 /* MDIO */ + 0 2 1 0 1 0 /* MDC */ + + 4 0 1 0 1 0 /* TxD0 (PE0, out, f1) */ + 4 1 1 0 1 0 /* TxD1 (PE1, out, f1) */ + 4 6 2 0 1 0 /* RxD0 (PE6, in, f1) */ + 4 7 2 0 1 0 /* RxD1 (PE7, in, f1) */ + 4 4 1 0 1 0 /* TX_EN (PE4, out, f1) */ + 4 12 2 0 1 0 /* RX_DV (PE12, in, f1) */ + 4 13 2 0 1 0 /* RX_ER (PE13, in, f1) */ + >; + }; + + pio_ucc8: ucc_pin@7 { + pio-map = < + /* port pin dir open_drain assignment has_irq */ + 0 1 3 0 2 0 /* MDIO */ + 0 2 1 0 1 0 /* MDC */ + + 4 14 1 0 2 0 /* TxD0 (PE14, out, f2) */ + 4 15 1 0 1 0 /* TxD1 (PE15, out, f1) */ + 4 20 2 0 1 0 /* RxD0 (PE20, in, f1) */ + 4 21 2 0 1 0 /* RxD1 (PE21, in, f1) */ + 4 18 1 0 1 0 /* TX_EN (PE18, out, f1) */ + 4 26 2 0 1 0 /* RX_DV (PE26, in, f1) */ + 4 27 2 0 1 0 /* RX_ER (PE27, in, f1) */ + + 2 15 2 0 1 0 /* UCCx_RMII_CLK (CLK16) */ + >; + }; + + pio_spi: spi_pin@01 { + pio-map = < + /* port pin dir open_drain assignment has_irq */ + 4 28 3 0 3 0 /* SPI_MOSI (PE28, out, f3 */ + 4 30 3 0 3 0 /* SPI_CLK (PE30, out, f3 */ + >; + }; + + /* UCC3 as HDLC controller for ICN */ + pio5: ucc_pin@02 { + pio-map = < + /* port pin dir open_drain assignment has_irq */ + 1 0 1 0 1 0 /* TxD0 */ + 1 6 2 0 1 0 /* RxD0 */ + 1 12 2 0 1 0 /* CTS */ + 2 11 2 0 1 0 /* TX-CLK12 */ + >; + }; + + pio_tdm: tdm_pin@00 { + pio-map = < + /* port pin dir open_drain assignment has_irq */ + /* TDMa */ + 0 8 3 0 2 0 /* RxD0 (PA8, bi, f2) */ + 0 13 3 0 2 0 /* TxD0 (PA13, bi, f2) */ + 0 14 2 0 2 0 /* RSync0 (PA14, in, f2) */ + 2 7 2 0 1 0 /* RxClk8 (PC7, in, f1) */ + /* TDMb */ + 0 27 3 0 2 0 /* RxD1 (PA27, bi, f2) */ + 0 22 3 0 2 0 /* TxD1 (PA22, bi, f2) */ + 0 28 2 0 2 0 /* RSync1 (PA28, in, f2) */ + 2 1 2 0 1 0 /* RxClk2 (PC1, in, f1) */ + /* TDMc */ + 1 5 3 0 2 0 /* RxD2 (PB5, bi, f2) */ + 1 8 3 0 2 0 /* TxD2 (PB8, bi, f2) */ + 1 2 2 0 3 0 /* RSync2 (PB2, in, f3) */ + 2 6 2 0 1 0 /* RxClk7 (PC6, in, f1) */ + /* TDMd */ + 1 22 3 0 2 0 /* RxD3 (PB22, bi, f2) */ + 1 19 3 0 1 0 /* TxD3 (PB19, bi, f1) */ + 1 16 2 0 2 0 /* RSync3 (PB16, in, f2) */ + 2 13 2 0 1 0 /* RxClk14 (PC13, in, f1) */ + /* TDMe */ + 3 8 3 0 2 0 /* RxD4 (PD8, bi, f2) */ + 3 5 3 0 2 0 /* TxD4 (PD5, bi, f2) */ + 3 2 2 0 2 0 /* RSync4 (PD2 , in, f2) */ + 2 22 2 0 1 0 /* RxClk23 (PC22, in, f1) */ + /* TDMf */ + 3 19 3 0 2 0 /* RxD5 (PD19, bi, f2) */ + 3 22 3 0 2 0 /* TxD5 (PD22, bi, f2) */ + 3 16 2 0 1 0 /* RSync5 (PD16, in, f1) */ + 2 17 2 0 1 0 /* RxClk18 (PC17, in, f1) */ + /* TDMg */ + 4 8 3 0 2 0 /* RxD6 (PE8, bi, f2) */ + 4 5 3 0 2 0 /* TxD6 (PE5, bi, f2) */ + 4 2 2 0 1 0 /* RSync6 (PE2, in, f1) */ + 2 19 2 0 1 0 /* RxClk20 (PC19, in, f1) */ + /* TDMh */ + 4 19 3 0 2 0 /* RxD7 (PE19, bi, f2) */ + 4 22 3 0 3 0 /* TxD7 (PE22, bi, f3) */ + 4 16 2 0 2 0 /* RSync7 (PE16, in, f2) */ + 2 21 2 0 1 0 /* RxClk22 (PC21, in, f1) */ + /* RxTxClk0/1 */ + 2 0 2 0 1 0 /* Clk1 (PC0, in, f1) */ + 2 23 2 0 1 0 /* Clk24 (PC23, in, f1) */ + /* RxTxSync0/1 */ + 2 10 2 0 1 0 /* Clk11 (PC10, in, f1) */ + 2 20 2 0 1 0>; /* Clk21 (PC20, in, f1) */ + }; +}; + +&qe { + /* ESTAR-1 (UCC1, MDIO 0x10, RGMII) */ + enet_estar1: ucc@2000 { + device_type = "network"; + compatible = "ucc_geth"; + cell-index = <1>; + reg = <0x2000 0x200>; + interrupts = <32>; + interrupt-parent = <&qeic>; + local-mac-address = [ 00 00 00 00 00 00 ]; + rx-clock-name = "none"; + tx-clock-name = "clk9"; + phy-handle = <&phy_estar1>; + phy-connection-type = "rgmii-id"; + pio-handle = <&pio_ucc1>; + }; + + /* ESTAR-2 (UCC2, MDIO 0x11, RGMII) */ + enet_estar2: ucc@3000 { + device_type = "network"; + compatible = "ucc_geth"; + cell-index = <2>; + reg = <0x3000 0x200>; + interrupts = <33>; + interrupt-parent = <&qeic>; + local-mac-address = [ 00 00 00 00 00 00 ]; + rx-clock-name = "none"; + tx-clock-name = "clk4"; + phy-handle = <&phy_estar2>; + phy-connection-type = "rgmii-id"; + pio-handle = <&pio_ucc2>; + }; + + /* Piggy2 (UCC4, MDIO 0x00, RMII) */ + enet_piggy2: ucc@3200 { + device_type = "network"; + compatible = "ucc_geth"; + cell-index = <4>; + reg = <0x3200 0x200>; + interrupts = <35>; + interrupt-parent = <&qeic>; + local-mac-address = [ 00 00 00 00 00 00 ]; + rx-clock-name = "none"; + tx-clock-name = "clk17"; + phy-handle = <&phy_piggy2>; + phy-connection-type = "rmii"; + pio-handle = <&pio_ucc4>; + }; + + /* Eth-1 (UCC5, MDIO 0x08, RMII) */ + enet_eth1: ucc@2400 { + device_type = "network"; + compatible = "ucc_geth"; + cell-index = <5>; + reg = <0x2400 0x200>; + interrupts = <40>; + interrupt-parent = <&qeic>; + local-mac-address = [ 00 00 00 00 00 00 ]; + rx-clock-name = "none"; + tx-clock-name = "clk16"; + phy-handle = <&phy_eth1>; + phy-connection-type = "rmii"; + pio-handle = <&pio_ucc5>; + }; + + /* Eth-2 (UCC6, MDIO 0x09, RMII) */ + enet_eth2: ucc@3400 { + device_type = "network"; + compatible = "ucc_geth"; + cell-index = <6>; + reg = <0x3400 0x200>; + interrupts = <41>; + interrupt-parent = <&qeic>; + local-mac-address = [ 00 00 00 00 00 00 ]; + rx-clock-name = "none"; + tx-clock-name = "clk16"; + phy-handle = <&phy_eth2>; + phy-connection-type = "rmii"; + pio-handle = <&pio_ucc6>; + }; + + /* Eth-3 (UCC7, MDIO 0x0a, RMII) */ + enet_eth3: ucc@2600 { + device_type = "network"; + compatible = "ucc_geth"; + cell-index = <7>; + reg = <0x2600 0x200>; + interrupts = <42>; + interrupt-parent = <&qeic>; + local-mac-address = [ 00 00 00 00 00 00 ]; + rx-clock-name = "none"; + tx-clock-name = "clk16"; + phy-handle = <&phy_eth3>; + phy-connection-type = "rmii"; + pio-handle = <&pio_ucc7>; + }; + + /* Eth-4 (UCC8, MDIO 0x0b, RMII) */ + enet_eth4: ucc@3600 { + device_type = "network"; + compatible = "ucc_geth"; + cell-index = <8>; + reg = <0x3600 0x200>; + interrupts = <43>; + interrupt-parent = <&qeic>; + local-mac-address = [ 00 00 00 00 00 00 ]; + rx-clock-name = "none"; + tx-clock-name = "clk16"; + phy-handle = <&phy_eth4>; + phy-connection-type = "rmii"; + pio-handle = <&pio_ucc8>; + }; + + mdio@3320 { + #address-cells = <1>; + #size-cells = <0>; + reg = <0x3320 0x18>; + compatible = "fsl,ucc-mdio"; + + /* Piggy2 (UCC4, MDIO 0x00, RMII) */ + phy_piggy2: ethernet-phy@0 { + reg = <0x0>; + }; + + /* Eth-1 (UCC5, MDIO 0x08, RMII) */ + phy_eth1: ethernet-phy@8 { + reg = <0x08>; + }; + + /* Eth-2 (UCC6, MDIO 0x09, RMII) */ + phy_eth2: ethernet-phy@9 { + reg = <0x09>; + }; + + /* Eth-3 (UCC7, MDIO 0x0a, RMII) */ + phy_eth3: ethernet-phy@a { + reg = <0x0a>; + }; + + /* Eth-4 (UCC8, MDIO 0x0b, RMII) */ + phy_eth4: ethernet-phy@b { + reg = <0x0b>; + }; + + /* ESTAR-1 (UCC1, MDIO 0x10, RGMII) */ + phy_estar1: ethernet-phy@10 { + interrupt-parent = <&ipic>; + interrupts = <17 0x8>; + reg = <0x10>; + }; + + /* ESTAR-2 (UCC2, MDIO 0x11, RGMII) */ + phy_estar2: ethernet-phy@11 { + interrupt-parent = <&ipic>; + interrupts = <18 0x8>; + reg = <0x11>; + }; + }; +}; + +&localbus { + ranges = <0 0 0xf0000000 0x04000000 /* LB 0 */ + 1 0 0xe8000000 0x01000000 /* LB 1 */ + 3 0 0xa0000000 0x10000000>; /* LB 3 */ + + flash@0,0 { + compatible = "cfi-flash"; + reg = <0 0 0x04000000>; + #address-cells = <1>; + #size-cells = <1>; + bank-width = <2>; + partition@0 { /* 768KB */ + label = "u-boot"; + reg = <0 0xC0000>; + }; + partition@c0000 { /* 128KB */ + label = "env"; + reg = <0xC0000 0x20000>; + }; + partition@e0000 { /* 128KB */ + label = "envred"; + reg = <0xE0000 0x20000>; + }; + partition@100000 { /* 64512KB */ + label = "ubi0"; + reg = <0x100000 0x3F00000>; + }; + }; +}; + +#include "kmeter1-uboot.dtsi" diff --git a/arch/powerpc/dts/kmopti2.dts b/arch/powerpc/dts/kmopti2.dts new file mode 100644 index 0000000000..23e31872dd --- /dev/null +++ b/arch/powerpc/dts/kmopti2.dts @@ -0,0 +1,161 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * ABB PGGA OPTI2 Device Tree Source + * + * Copyright (C) 2020 Heiko Schocher hs@denx.de + * + */ + +/dts-v1/; + +#include "km8321.dtsi" + +/ { + model = "KMOPTI2"; + compatible = "ABB,kmpbec8321"; + #address-cells = <1>; + #size-cells = <1>; + + aliases { + ethernet0 = &enet_piggy2; + serial0 = &serial0; + }; +}; + +&i2c0 { + mux@70 { + compatible = "nxp,pca9547"; + reg = <0x70>; + #address-cells = <1>; + #size-cells = <0>; + + i2c@1 { + reg = <1>; + #address-cells = <1>; + #size-cells = <0>; + + /* Inventory EEPROM of the unit itself */ + ivm@50 { + label = "MAIN_CTRL"; + compatible = "dummy"; + reg = <0x50>; + }; + }; + + i2c@2 { + reg = <2>; + #address-cells = <1>; + #size-cells = <0>; + + /* Temperature sensors */ + temp@49 { + label = "board"; + compatible = "national,lm75"; + reg = <0x49>; + }; + + temp@4a { + label = "power"; + compatible = "national,lm75"; + reg = <0x4a>; + }; + }; + + i2c@6 { + reg = <6>; + #address-cells = <1>; + #size-cells = <0>; + }; + + i2c@5 { + reg = <5>; + #address-cells = <1>; + #size-cells = <0>; + }; + + i2c@4 { + reg = <4>; + #address-cells = <1>; + #size-cells = <0>; + }; + + i2c@3 { + reg = <3>; + #address-cells = <1>; + #size-cells = <0>; + }; + }; +}; + +&par_io { + /* UCC5 as HDLC controller for ICN */ + pio_ucc5: ucc_pin@04 { + pio-map = < + /* port pin dir open_drain assignment has_irq */ + 2 0 1 0 2 0 /* TxD0 */ + 2 8 2 0 2 0 /* RxD0 */ + 2 29 2 0 2 0 /* CTS */ + 3 30 2 0 1 0 /* ICN CLK */ + >; + }; + + /* UCC4 Piggy Ethernet */ + pio_ucc4: ucc_pin@03 { + pio-map = < + /* port pin dir open_drain assignment has_irq */ + 3 4 3 0 2 0 /* MDIO */ + 3 5 1 0 2 0 /* MDC */ + + 1 18 1 0 1 0 /* TxD0 */ + 1 19 1 0 1 0 /* TxD1 */ + 1 22 2 0 1 0 /* RxD0 */ + 1 23 2 0 1 0 /* RxD1 */ + 1 26 2 0 1 0 /* RX_ER */ + 1 28 2 0 1 0 /* RX_DV */ + 1 30 1 0 1 0 /* TX_EN */ + 1 31 2 0 1 0 /* CRS */ + 3 10 2 0 3 0 /* UCC4_RMII_CLK (CLK17) */ + >; + }; + + pio_spi: spi_pin@01 { + pio-map = < + /* port pin dir open_drain assignment has_irq */ + 3 0 3 0 1 0 /* SPI_MOSI (PD0, bi, f3) */ + 3 1 3 0 1 0 /* SPI_MISO (PD1, bi, f3) */ + 3 2 3 0 1 0 /* SPI_CLK (PD2, bi, f3) */ + >; + }; +}; + +&localbus { + ranges = <0 0 0xf0000000 0x04000000 /* LB 0 Flash (boot) */ + 1 0 0xe8000000 0x01000000 /* LB 1 PRIO1 and Piggy */ + 2 0 0xa0000000 0x10000000 /* LB 2 PAXE */ + 3 0 0xb0000000 0x10000000>; /* LB 3 OPI2 */ + + flash@0,0 { + compatible = "cfi-flash"; + reg = <0 0x00000000 0x04000000>; + bank-width = <2>; + #address-cells = <1>; + #size-cells = <1>; + use-advanced-sector-protection; + partition@0 { /* 768KB */ + label = "u-boot"; + reg = <0 0xC0000>; + }; + partition@c0000 { /* 128KB */ + label = "env"; + reg = <0xc0000 0x20000>; + }; + partition@e0000 { /* 128KB */ + label = "envred"; + reg = <0xe0000 0x20000>; + }; + partition@100000 { /* 64512KB */ + label = "ubi0"; + reg = <0x100000 0x3F00000>; + }; + }; +}; diff --git a/arch/powerpc/dts/kmsupc5.dts b/arch/powerpc/dts/kmsupc5.dts new file mode 100644 index 0000000000..60ca0d3324 --- /dev/null +++ b/arch/powerpc/dts/kmsupc5.dts @@ -0,0 +1,139 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * ABB PGGA SUPC5 Device Tree Source + * + * Copyright (C) 2020 Heiko Schocher hs@denx.de + * + */ + +/dts-v1/; + +#include "km8321.dtsi" + +/ { + model = "SUPC5"; + compatible = "ABB,kmpbec8321"; + #address-cells = <1>; + #size-cells = <1>; + + aliases { + ethernet0 = &enet_piggy2; + serial0 = &serial0; + }; +}; + +&i2c0 { + mux@70 { + compatible = "nxp,pca9547"; + reg = <0x70>; + #address-cells = <1>; + #size-cells = <0>; + + i2c@1 { + reg = <1>; + #address-cells = <1>; + #size-cells = <0>; + + /* Inventory EEPROM of the unit itself */ + ivm@50 { + label = "MAIN_CTRL"; + compatible = "dummy"; + reg = <0x50>; + }; + }; + + i2c@2 { + reg = <2>; + #address-cells = <1>; + #size-cells = <0>; + + /* Temperature sensors */ + temp@49 { + label = "board"; + compatible = "national,lm75"; + reg = <0x49>; + }; + }; + }; +}; + +&par_io { + /* UCC5 as HDLC controller for ICN */ + pio_ucc5: ucc_pin@04 { + pio-map = < + /* port pin dir open_drain assignment has_irq */ + 2 0 1 0 2 0 /* TxD0 */ + 2 8 2 0 2 0 /* RxD0 */ + 2 29 2 0 2 0 /* CTS */ + 3 30 2 0 1 0 /* ICN CLK */ + >; + }; + + /* UCC4 Piggy Ethernet */ + pio_ucc4: ucc_pin@03 { + pio-map = < + /* port pin dir open_drain assignment has_irq */ + 3 4 3 0 2 0 /* MDIO */ + 3 5 1 0 2 0 /* MDC */ + + 1 18 1 0 1 0 /* TxD0 */ + 1 19 1 0 1 0 /* TxD1 */ + 1 22 2 0 1 0 /* RxD0 */ + 1 23 2 0 1 0 /* RxD1 */ + 1 26 2 0 1 0 /* RX_ER */ + 1 28 2 0 1 0 /* RX_DV */ + 1 30 1 0 1 0 /* TX_EN */ + 1 31 2 0 1 0 /* CRS */ + /* UCC4_RMII_CLK (CLK17) */ + 3 10 2 0 3 0 + >; + }; + + pio_spi: spi_pin@01 { + pio-map = < + /* + * port pin dir open_drain assignment has_irq + * SPI_MOSI (PD0, bi, f3) + */ + 3 0 3 0 1 0 + /* SPI_MISO (PD1, bi, f3) */ + 3 1 3 0 1 0 + /* SPI_CLK (PD2, bi, f3) */ + 3 2 3 0 1 0 + >; + }; +}; + +&spi0 { + pio-handle = <&pio_spi>; +}; + +&localbus { + ranges = <0 0 0xf0000000 0x04000000 /* LB 0 Flash (boot) */ + 1 0 0xe8000000 0x01000000 /* LB 1 PRIO1 and Piggy */ + 2 0 0xa0000000 0x10000000>; /* LB 2 LPXF */ + + flash@0,0 { + compatible = "cfi-flash"; + reg = <0 0x00000000 0x04000000>; + bank-width = <2>; + #address-cells = <1>; + #size-cells = <1>; + partition@0 { /* 768KB */ + label = "u-boot"; + reg = <0 0xC0000>; + }; + partition@c0000 { /* 128KB */ + label = "env"; + reg = <0xc0000 0x20000>; + }; + partition@e0000 { /* 128KB */ + label = "envred"; + reg = <0xe0000 0x20000>; + }; + partition@100000 { /* 64512KB */ + label = "ubi0"; + reg = <0x100000 0x3F00000>; + }; + }; +}; diff --git a/arch/powerpc/dts/kmsupm5.dts b/arch/powerpc/dts/kmsupm5.dts new file mode 100644 index 0000000000..1cd11c3344 --- /dev/null +++ b/arch/powerpc/dts/kmsupm5.dts @@ -0,0 +1,129 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * ABB PGGA SUPM5 Device Tree Source + * + * Copyright (C) 2020 Heiko Schocher hs@denx.de + * + */ + +/dts-v1/; + +#include "km8321.dtsi" + +/ { + model = "SUPM5"; + compatible = "ABB,kmpbec8321"; + #address-cells = <1>; + #size-cells = <1>; + + aliases { + ethernet0 = &enet_piggy2; + serial0 = &serial0; + }; +}; + +&i2c0 { + mux@70 { + compatible = "nxp,pca9547"; + reg = <0x70>; + #address-cells = <1>; + #size-cells = <0>; + + i2c@1 { + reg = <1>; + #address-cells = <1>; + #size-cells = <0>; + + /* Inventory EEPROM of the unit itself */ + ivm@50 { + label = "MAIN_CTRL"; + compatible = "dummy"; + reg = <0x50>; + }; + }; + + i2c@2 { + reg = <2>; + #address-cells = <1>; + #size-cells = <0>; + + /* Temperature sensors */ + temp@49 { + label = "board"; + compatible = "national,lm75"; + reg = <0x49>; + }; + }; + }; +}; + +&par_io { + /* UCC5 as HDLC controller for ICN */ + pio_ucc5: ucc_pin@04 { + pio-map = < + /* port pin dir open_drain assignment has_irq */ + 2 0 1 0 2 0 /* TxD0 */ + 2 8 2 0 2 0 /* RxD0 */ + 2 29 2 0 2 0 /* CTS */ + 3 30 2 0 1 0 /* ICN CLK */ + >; + }; + + /* UCC4 Piggy Ethernet */ + pio_ucc4: ucc_pin@03 { + pio-map = < + /* port pin dir open_drain assignment has_irq */ + 3 4 3 0 2 0 /* MDIO */ + 3 5 1 0 2 0 /* MDC */ + + 1 18 1 0 1 0 /* TxD0 */ + 1 19 1 0 1 0 /* TxD1 */ + 1 22 2 0 1 0 /* RxD0 */ + 1 23 2 0 1 0 /* RxD1 */ + 1 26 2 0 1 0 /* RX_ER */ + 1 28 2 0 1 0 /* RX_DV */ + 1 30 1 0 1 0 /* TX_EN */ + 1 31 2 0 1 0 /* CRS */ + 3 10 2 0 3 0 /* UCC4_RMII_CLK (CLK17) */ + >; + }; + + pio_spi: spi_pin@01 { + pio-map = < + /* port pin dir open_drain assignment has_irq */ + 3 0 3 0 1 0 /* SPI_MOSI (PD0, bi, f3) */ + 3 1 3 0 1 0 /* SPI_MISO (PD1, bi, f3) */ + 3 2 3 0 1 0 /* SPI_CLK (PD2, bi, f3) */ + >; + }; +}; + +&localbus { + ranges = <0 0 0xf0000000 0x04000000 /* LB 0 Flash (boot) */ + 1 0 0xe8000000 0x01000000 /* LB 1 PRIO1 and Piggy */ + 2 0 0xa0000000 0x10000000>; /* LB 2 LPXF */ + + flash@0,0 { + compatible = "cfi-flash"; + reg = <0 0x00000000 0x04000000>; + bank-width = <2>; + #address-cells = <1>; + #size-cells = <1>; + partition@0 { /* 768KB */ + label = "u-boot"; + reg = <0 0xC0000>; + }; + partition@c0000 { /* 128KB */ + label = "env"; + reg = <0xc0000 0x20000>; + }; + partition@e0000 { /* 128KB */ + label = "envred"; + reg = <0xe0000 0x20000>; + }; + partition@100000 { /* 64512KB */ + label = "ubi0"; + reg = <0x100000 0x3F00000>; + }; + }; +}; diff --git a/arch/powerpc/dts/kmtegr1.dts b/arch/powerpc/dts/kmtegr1.dts new file mode 100644 index 0000000000..c9b21cf500 --- /dev/null +++ b/arch/powerpc/dts/kmtegr1.dts @@ -0,0 +1,392 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * ABB PGGA TEGR1 Device Tree Source + * + * Copyright (C) 2020 Heiko Schocher hs@denx.de + * + */ + +/dts-v1/; + +/ { + model = "KMTEGR1"; + compatible = "ABB,kmpbec8309"; + #address-cells = <1>; + #size-cells = <1>; + + aliases { + ethernet0 = &enet_zynq; + ethernet1 = &enet_piggy2; + serial0 = &serial0; + }; + + cpus { + #address-cells = <1>; + #size-cells = <0>; + + PowerPC,8309@0 { + device_type = "cpu"; + reg = <0x0>; + d-cache-line-size = <32>; // 32 bytes + i-cache-line-size = <32>; // 32 bytes + d-cache-size = <16384>; // L1, 16K + i-cache-size = <16384>; // L1, 16K + timebase-frequency = <66000000>; + bus-frequency = <264000000>; + clock-frequency = <264000000>; + }; + }; + + memory { + device_type = "memory"; + reg = <0x00000000 0x10000000>; + }; + + soc: soc8309@e0000000 { + #address-cells = <1>; + #size-cells = <1>; + device_type = "soc"; + compatible = "simple-bus"; + ranges = <0x0 0xe0000000 0x00100000>; + reg = <0xe0000000 0x00000200>; + bus-frequency = <264000000>; + + i2c@3000 { + #address-cells = <1>; + #size-cells = <0>; + cell-index = <0>; + compatible = "fsl,mpc8313-i2c","fsl-i2c"; + reg = <0x3000 0x100>; + interrupts = <14 0x8>; + interrupt-parent = <&ipic>; + clock-frequency = <400000>; + + mux@70 { + compatible = "nxp,pca9547"; + reg = <0x70>; + #address-cells = <1>; + #size-cells = <0>; + + i2c@1 { + reg = <1>; + #address-cells = <1>; + #size-cells = <0>; + + /* + * Inventory EEPROM of the + * unit itself + */ + ivm@50 { + label = "MAIN_CTRL"; + compatible = "dummy"; + reg = <0x50>; + }; + }; + + i2c@2 { + reg = <2>; + #address-cells = <1>; + #size-cells = <0>; + + /* Temperature sensors */ + temp@48 { + label = "front"; + compatible = "national,lm75"; + reg = <0x48>; + }; + + temp@49 { + label = "board"; + compatible = "national,lm75"; + reg = <0x49>; + }; + + temp@4a { + label = "power"; + compatible = "national,lm75"; + reg = <0x4a>; + }; + + temp@4b { + label = "bottom"; + compatible = "national,lm75"; + reg = <0x4b>; + }; + }; + + i2c@6 { + reg = <6>; + #address-cells = <1>; + #size-cells = <0>; + + }; + + i2c@5 { + reg = <5>; + #address-cells = <1>; + #size-cells = <0>; + + }; + + i2c@7 { + reg = <7>; + #address-cells = <1>; + #size-cells = <0>; + + }; + + i2c@3 { + reg = <3>; + #address-cells = <1>; + #size-cells = <0>; + + }; + }; + }; + + serial0: serial@4500 { + cell-index = <0>; + device_type = "serial"; + compatible = "fsl,ns16550", "ns16550"; + reg = <0x4500 0x100>; + clock-frequency = <264000000>; + interrupts = <9 0x8>; + interrupt-parent = <&ipic>; + }; + + dma@82a8 { + #address-cells = <1>; + #size-cells = <1>; + compatible = "fsl,mpc8309-dma", "fsl,elo-dma"; + reg = <0x82a8 4>; + ranges = <0 0x8100 0x1a8>; + interrupt-parent = <&ipic>; + interrupts = <71 8>; + cell-index = <0>; + dma-channel@0 { + compatible = "fsl,mpc8309-dma-channel", + "fsl,elo-dma-channel"; + reg = <0 0x80>; + interrupt-parent = <&ipic>; + interrupts = <71 8>; + }; + dma-channel@80 { + compatible = "fsl,mpc8309-dma-channel", + "fsl,elo-dma-channel"; + reg = <0x80 0x80>; + interrupt-parent = <&ipic>; + interrupts = <71 8>; + }; + dma-channel@100 { + compatible = "fsl,mpc8309-dma-channel", + "fsl,elo-dma-channel"; + reg = <0x100 0x80>; + interrupt-parent = <&ipic>; + interrupts = <71 8>; + }; + dma-channel@180 { + compatible = "fsl,mpc8309-dma-channel", + "fsl,elo-dma-channel"; + reg = <0x180 0x28>; + interrupt-parent = <&ipic>; + interrupts = <71 8>; + }; + }; + + ipic: pic@700 { + #address-cells = <0>; + #interrupt-cells = <2>; + compatible = "fsl,pq2pro-pic", "fsl,ipic"; + interrupt-controller; + reg = <0x700 0x100>; + device_type = "ipic"; + }; + + gpio1: gpio-controller@c00 { + #gpio-cells = <2>; + compatible = "fsl,mpc8309-gpio", "fsl,mpc8349-gpio"; + reg = <0xc00 0x100>; + interrupts = <75 0x8>; + interrupt-parent = <&ipic>; + gpio-controller; + interrupt-controller; + #interrupt-cells = <2>; + }; + + gpio2: gpio-controller@d00 { + #gpio-cells = <2>; + compatible = "fsl,mpc8309-gpio", "fsl,mpc8349-gpio"; + reg = <0xd00 0x100>; + interrupts = <75 0x8>; + interrupt-parent = <&ipic>; + gpio-controller; + interrupt-controller; + #interrupt-cells = <2>; + }; + + spi@7000 { + cell-index = <0>; + compatible = "fsl,spi"; + reg = <0x7000 0x1000>; + interrupts = <16 0x8>; + interrupt-parent = <&ipic>; + mode = "cpu"; + #address-cells = <1>; + #size-cells = <0>; + + /* GPIO_15 chipselect for ZYNQ flash */ + gpios = <&gpio1 15 0>; + + zynq_flash@0 { + #address-cells = <1>; + #size-cells = <1>; + compatible = "spansion,m25p80"; + reg = <0>; + spi-max-frequency = <4000000>; + m25p,fast-read; + partition@0 { + label = "bootloader"; + reg = <0x0 0x01000000>; + }; + }; + }; + }; + + qe: qe@e0100000 { + #address-cells = <1>; + #size-cells = <1>; + device_type = "qe"; + compatible = "fsl,qe"; + ranges = <0x0 0xe0100000 0x00100000>; + reg = <0xe0100000 0x480>; + brg-frequency = <0>; + bus-frequency = <396000000>; + fsl,qe-num-snums = <32>; + + muram@10000 { + #address-cells = <1>; + #size-cells = <1>; + compatible = "fsl,qe-muram", "fsl,cpm-muram"; + ranges = <0x0 0x00010000 0x00004000>; + + data-only@0 { + compatible = "fsl,qe-muram-data", + "fsl,cpm-muram-data"; + reg = <0x0 0x4000>; + }; + }; + + /* ZYNQ (UCC1, MDIO 0x10, MII) */ + enet_zynq: ethernet@2000 { + device_type = "network"; + compatible = "ucc_geth"; + cell-index = <1>; + reg = <0x2000 0x200>; + interrupts = <32>; + interrupt-parent = <&qeic>; + local-mac-address = [ 00 00 00 00 00 00 ]; + /*id=0, full-dup, 100M, no-pause, no-asym_p*/ + fixed-link = <0 1 100 0 0>; + rx-clock-name = "clk9"; + tx-clock-name = "clk10"; + phy-connection-type = "mii"; + }; + + /* Piggy2 (UCC3, MDIO 0x00, RMII) */ + enet_piggy2: ucc@2200 { + device_type = "network"; + compatible = "ucc_geth"; + cell-index = <3>; + reg = <0x2200 0x200>; + interrupts = <34>; + interrupt-parent = <&qeic>; + local-mac-address = [ 00 00 00 00 00 00 ]; + rx-clock-name = "none"; + tx-clock-name = "clk12"; + phy-handle = <&phy_piggy2>; + phy-connection-type = "rmii"; + }; + + mdio@2320 { + #address-cells = <1>; + #size-cells = <0>; + reg = <0x2320 0x38>; + compatible = "fsl,ucc-mdio"; + + /* Piggy2 (UCC3, MDIO 0x00, RMII) */ + phy_piggy2: ethernet-phy@0 { + reg = <0x0>; + device_type = "ethernet-phy"; + }; + + /* Explicitly set the tbi-phy to a non-zero address + * so that it does not conflict with phy_piggy2 that + * is unfortunately at address 0 + */ + tbi1: tbi-phy@1 { + reg = <0x1>; + device_type = "tbi-phy"; + }; + }; + + qeic: interrupt-controller@80 { + interrupt-controller; + compatible = "fsl,qe-ic"; + #address-cells = <0>; + #interrupt-cells = <1>; + reg = <0x80 0x80>; + big-endian; + interrupts = <32 8 33 8>; + interrupt-parent = <&ipic>; + }; + bootcount@0x13ff8 { + device_type = "bootcount"; + compatible = "u-boot,bootcount"; + reg = <0x13ff8 0x08>; + }; + + }; + localbus@e0005000 { + #address-cells = <2>; + #size-cells = <1>; + compatible = "fsl,mpc8309-localbus", "fsl,pq2pro-localbus", + "simple-bus"; + reg = <0xe0005000 0xd8>; + ranges = <0 0 0xf0000000 0x04000000 + 1 0 0xe8000000 0x01000000 + 2 0 0xe0000000 0x10000000 + 3 0 0xb0000000 0x10000000>; + + flash@0,0 { + compatible = "cfi-flash"; + reg = <0 0x00000000 0x04000000>; + bank-width = <2>; + nornand = "nor"; + #address-cells = <1>; + #size-cells = <1>; + use-advanced-sector-protection; + partition@0 { /* 768KB */ + label = "u-boot"; + reg = <0 0xc0000>; + }; + partition@c0000 { /* 256KB */ + label = "qe-fw"; + reg = <0xc0000 0x40000>; + }; + partition@100000 { /* 128KB */ + label = "env"; + reg = <0x100000 0x20000>; + }; + partition@120000 { /* 128KB */ + label = "envred"; + reg = <0x120000 0x20000>; + }; + partition@140000 { /* 64256KB */ + label = "ubi0"; + reg = <0x140000 0x3EC0000>; + }; + }; + }; +}; + +#include "km8309-uboot.dtsi" diff --git a/arch/powerpc/dts/kmtepr2.dts b/arch/powerpc/dts/kmtepr2.dts new file mode 100644 index 0000000000..5a272ec6cb --- /dev/null +++ b/arch/powerpc/dts/kmtepr2.dts @@ -0,0 +1,142 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * ABB PGGA TEPR2 Device Tree Source + * + * Copyright (C) 2020 Heiko Schocher hs@denx.de + * + */ + +/dts-v1/; + +#include "km8321.dtsi" + +/ { + model = "KMTEPR2"; + compatible = "ABB,kmpbec8321"; + #address-cells = <1>; + #size-cells = <1>; + + aliases { + ethernet0 = &enet_piggy2; + serial0 = &serial0; + }; +}; + +&i2c0 { + mux@70 { + compatible = "nxp,pca9547"; + reg = <0x70>; + #address-cells = <1>; + #size-cells = <0>; + + i2c@1 { + reg = <1>; + #address-cells = <1>; + #size-cells = <0>; + + /* Inventory EEPROM of the unit itself */ + ivm@50 { + label = "MAIN_CTRL"; + compatible = "dummy"; + reg = <0x50>; + }; + }; + + i2c@2 { + reg = <2>; + #address-cells = <1>; + #size-cells = <0>; + + /* Temperature sensors */ + temp@49 { + label = "board"; + compatible = "national,lm75"; + reg = <0x49>; + }; + + temp@4a { + label = "power"; + compatible = "national,lm75"; + reg = <0x4a>; + }; + }; + }; +}; + +&par_io { + /* UCC5 as HDLC controller for ICN */ + pio_ucc5: ucc_pin@04 { + pio-map = < + /* port pin dir open_drain assignment has_irq */ + 2 0 1 0 2 0 /* TxD0 */ + 2 8 2 0 2 0 /* RxD0 */ + 2 29 2 0 2 0 /* CTS */ + 3 30 2 0 1 0 /* ICN CLK */ + >; + }; + + /* UCC4 Piggy Ethernet */ + pio_ucc4: ucc_pin@03 { + pio-map = < + /* port pin dir open_drain assignment has_irq */ + 3 4 3 0 2 0 /* MDIO */ + 3 5 1 0 2 0 /* MDC */ + + 1 18 1 0 1 0 /* TxD0 */ + 1 19 1 0 1 0 /* TxD1 */ + 1 22 2 0 1 0 /* RxD0 */ + 1 23 2 0 1 0 /* RxD1 */ + 1 26 2 0 1 0 /* RX_ER */ + 1 28 2 0 1 0 /* RX_DV */ + 1 30 1 0 1 0 /* TX_EN */ + 1 31 2 0 1 0 /* CRS */ + 3 10 2 0 3 0 /* UCC4_RMII_CLK (CLK17) */ + >; + }; + + pio_spi: spi_pin@01 { + pio-map = < + /* + *port pin dir open_drain assignment has_irq + * SPI_MOSI (PD0, bi, f3) + */ + 3 0 3 0 1 0 + /* SPI_MISO (PD1, bi, f3) */ + 3 1 3 0 1 0 + /* SPI_CLK (PD2, bi, f3) */ + 3 2 3 0 1 0 + >; + }; +}; + +&localbus { + ranges = <0 0 0xf0000000 0x04000000 /* LB 0 Flash (boot) */ + 1 0 0xe8000000 0x01000000 /* LB 1 PRIO1 and Piggy */ + 2 0 0xa0000000 0x10000000 /* LB 2 NVSRAM */ + 3 0 0xb0000000 0x10000000>; /* LB 3 TEP2 */ + + flash@0,0 { + compatible = "cfi-flash"; + reg = <0 0x00000000 0x04000000>; + bank-width = <2>; + #address-cells = <1>; + #size-cells = <1>; + use-advanced-sector-protection; + partition@0 { /* 768KB */ + label = "u-boot"; + reg = <0 0xC0000>; + }; + partition@c0000 { /* 128KB */ + label = "env"; + reg = <0xc0000 0x20000>; + }; + partition@e0000 { /* 128KB */ + label = "envred"; + reg = <0xe0000 0x20000>; + }; + partition@100000 { /* 64512KB */ + label = "ubi0"; + reg = <0x100000 0x3F00000>; + }; + }; +}; diff --git a/arch/powerpc/dts/kmtuge1.dts b/arch/powerpc/dts/kmtuge1.dts new file mode 100644 index 0000000000..8a7b5a42cb --- /dev/null +++ b/arch/powerpc/dts/kmtuge1.dts @@ -0,0 +1,100 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * ABB PGGA TUGE1 Device Tree Source + * + * Copyright (C) 2020 Heiko Schocher hs@denx.de + * + */ + +/dts-v1/; + +#include "km8321.dtsi" + +/ { + model = "TUGE1"; + compatible = "ABB,kmpbec8321"; + #address-cells = <1>; + #size-cells = <1>; + + aliases { + ethernet0 = &enet_piggy2; + serial0 = &serial0; + }; +}; + +&par_io { + /* UCC5 as HDLC controller for ICN */ + pio_ucc5: ucc_pin@04 { + pio-map = < + /* port pin dir open_drain assignment has_irq */ + 2 0 1 0 2 0 /* TxD0 */ + 2 8 2 0 2 0 /* RxD0 */ + 2 29 2 0 2 0 /* CTS */ + 3 30 2 0 1 0 /* ICN CLK */ + >; + }; + + /* UCC4 Piggy Ethernet */ + pio_ucc4: ucc_pin@03 { + pio-map = < + /* port pin dir open_drain assignment has_irq */ + 3 4 3 0 2 0 /* MDIO */ + 3 5 1 0 2 0 /* MDC */ + + 1 18 1 0 1 0 /* TxD0 */ + 1 19 1 0 1 0 /* TxD1 */ + 1 22 2 0 1 0 /* RxD0 */ + 1 23 2 0 1 0 /* RxD1 */ + 1 26 2 0 1 0 /* RX_ER */ + 1 28 2 0 1 0 /* RX_DV */ + 1 30 1 0 1 0 /* TX_EN */ + 1 31 2 0 1 0 /* CRS */ + 3 10 2 0 3 0 /* UCC4_RMII_CLK (CLK17) */ + >; + }; + + pio_spi: spi_pin@01 { + pio-map = < + /* + *port pin dir open_drain assignment has_irq + * SPI_MOSI (PD0, bi, f3) + */ + 3 0 3 0 1 0 + /* SPI_MISO (PD1, bi, f3) */ + 3 1 3 0 1 0 + /* SPI_CLK (PD2, bi, f3) */ + 3 2 3 0 1 0 + >; + }; +}; + +&localbus { + ranges = <0 0 0xf0000000 0x04000000 /* LB 0 Flash (boot) */ + 1 0 0xe8000000 0x01000000 /* LB 1 PRIO1 and Piggy */ + 2 0 0xa0000000 0x10000000>; /* LB 2 PAXI */ + + flash@0,0 { + compatible = "cfi-flash"; + reg = <0 0x00000000 0x04000000>; + bank-width = <2>; + #address-cells = <1>; + #size-cells = <1>; + + partition@0 { /* 768KB */ + label = "u-boot"; + reg = <0 0xC0000>; + }; + partition@c0000 { /* 128KB */ + label = "env"; + reg = <0xc0000 0x20000>; + }; + partition@e0000 { /* 128KB */ + label = "envred"; + reg = <0xe0000 0x20000>; + }; + partition@100000 { /* 64512KB */ + label = "ubi0"; + reg = <0x100000 0x3F00000>; + }; + }; +}; diff --git a/arch/powerpc/dts/kmtuxa1.dts b/arch/powerpc/dts/kmtuxa1.dts new file mode 100644 index 0000000000..c2681c5efb --- /dev/null +++ b/arch/powerpc/dts/kmtuxa1.dts @@ -0,0 +1,100 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * ABB PGGA TUXA1 Device Tree Source + * + * Copyright (C) 2020 Heiko Schocher hs@denx.de + * + */ + +/dts-v1/; + +#include "km8321.dtsi" + +/ { + model = "TUXA1"; + compatible = "ABB,kmpbec8321"; + #address-cells = <1>; + #size-cells = <1>; + + aliases { + ethernet0 = &enet_piggy2; + serial0 = &serial0; + }; +}; + +&par_io { + /* UCC5 as HDLC controller for ICN */ + pio_ucc5: ucc_pin@04 { + pio-map = < + /* port pin dir open_drain assignment has_irq */ + 2 0 1 0 2 0 /* TxD0 */ + 2 8 2 0 2 0 /* RxD0 */ + 2 29 2 0 2 0 /* CTS */ + 3 30 2 0 1 0 /* ICN CLK */ + >; + }; + + /* UCC4 Piggy Ethernet */ + pio_ucc4: ucc_pin@03 { + pio-map = < + /* port pin dir open_drain assignment has_irq */ + 3 4 3 0 2 0 /* MDIO */ + 3 5 1 0 2 0 /* MDC */ + + 1 18 1 0 1 0 /* TxD0 */ + 1 19 1 0 1 0 /* TxD1 */ + 1 22 2 0 1 0 /* RxD0 */ + 1 23 2 0 1 0 /* RxD1 */ + 1 26 2 0 1 0 /* RX_ER */ + 1 28 2 0 1 0 /* RX_DV */ + 1 30 1 0 1 0 /* TX_EN */ + 1 31 2 0 1 0 /* CRS */ + 3 10 2 0 3 0 /* UCC4_RMII_CLK (CLK17) */ + >; + }; + + pio_spi: spi_pin@01 { + pio-map = < + /* + *port pin dir open_drain assignment has_irq + * SPI_MOSI (PD0, bi, f3) + */ + 3 0 3 0 1 0 + /* SPI_MISO (PD1, bi, f3) */ + 3 1 3 0 1 0 + /* SPI_CLK (PD2, bi, f3) */ + 3 2 3 0 1 0 + >; + }; +}; + +&localbus { + ranges = <0 0 0xf0000000 0x04000000 /* LB 0 Flash (boot) */ + 1 0 0xe8000000 0x01000000 /* LB 1 PRIO1 and Piggy */ + 2 0 0xa0000000 0x10000000 /* LB 2 LPXF */ + 3 0 0xb0000000 0x10000000>; /* LB 3 PINC2 */ + + flash@0,0 { + compatible = "cfi-flash"; + reg = <0 0x00000000 0x04000000>; + bank-width = <2>; + #address-cells = <1>; + #size-cells = <1>; + partition@0 { /* 768KB */ + label = "u-boot"; + reg = <0 0xC0000>; + }; + partition@c0000 { /* 128KB */ + label = "env"; + reg = <0xc0000 0x20000>; + }; + partition@e0000 { /* 128KB */ + label = "envred"; + reg = <0xe0000 0x20000>; + }; + partition@100000 { /* 64512KB */ + label = "ubi0"; + reg = <0x100000 0x3F00000>; + }; + }; +}; diff --git a/board/keymile/km83xx/Kconfig b/board/keymile/km83xx/Kconfig index 94075ce70f..bbafabdcb2 100644 --- a/board/keymile/km83xx/Kconfig +++ b/board/keymile/km83xx/Kconfig @@ -1,3 +1,20 @@ +menu "KM 83xx Options" + depends on MPC83xx + +config KM_ENABLE_FULL_DM_DTS_SUPPORT + bool "enable full DM/DTS support for KM 83xx boards" + default y + select CMD_DM + select DM + select DM_ETH + select DM_MDIO + select DM_SERIAL + select OF_CONTROL + select PINCTRL + select PINCTRL_QE + select PHYLIB +endmenu + if TARGET_KMETER1
config SYS_BOARD diff --git a/board/keymile/km83xx/MAINTAINERS b/board/keymile/km83xx/MAINTAINERS index 177c2c4970..0ce6317625 100644 --- a/board/keymile/km83xx/MAINTAINERS +++ b/board/keymile/km83xx/MAINTAINERS @@ -1,5 +1,6 @@ KM83XX BOARD M: Holger Brunck holger.brunck@ch.abb.com +M: Heiko Schocher hs@denx.de S: Maintained F: board/keymile/km83xx/ F: include/configs/km8360.h @@ -7,12 +8,24 @@ F: configs/kmcoge5ne_defconfig F: configs/kmeter1_defconfig F: include/configs/tuxx1.h F: configs/kmopti2_defconfig +F: configs/kmsupx5_defconfig F: configs/kmtepr2_defconfig F: configs/kmtegr1_defconfig F: configs/tuge1_defconfig F: configs/tuxx1_defconfig - -KMSUPX5 BOARD -M: Heiko Schocher hs@denx.de -S: Maintained -F: configs/kmsupx5_defconfig +F: arch/powerpc/dts/km8309-uboot.dtsi +F: arch/powerpc/dts/km8321-uboot.dtsi +F: arch/powerpc/dts/km8321.dtsi +F: arch/powerpc/dts/km836x-uboot.dtsi +F: arch/powerpc/dts/km836x.dtsi +F: arch/powerpc/dts/kmcoge5ne-uboot.dtsi +F: arch/powerpc/dts/kmcoge5ne.dts +F: arch/powerpc/dts/kmeter1-uboot.dtsi +F: arch/powerpc/dts/kmeter1.dts +F: arch/powerpc/dts/kmopti2.dts +F: arch/powerpc/dts/kmsupc5.dts +F: arch/powerpc/dts/kmsupm5.dts +F: arch/powerpc/dts/kmtegr1.dts +F: arch/powerpc/dts/kmtepr2.dts +F: arch/powerpc/dts/kmtuge1.dts +F: arch/powerpc/dts/kmtuxa1.dts diff --git a/board/keymile/km83xx/km83xx.c b/board/keymile/km83xx/km83xx.c index 75c558ad3c..a7923090db 100644 --- a/board/keymile/km83xx/km83xx.c +++ b/board/keymile/km83xx/km83xx.c @@ -36,70 +36,6 @@ DECLARE_GLOBAL_DATA_PTR;
static uchar ivm_content[CONFIG_SYS_IVM_EEPROM_MAX_LEN];
-const qe_iop_conf_t qe_iop_conf_tab[] = { - /* port pin dir open_drain assign */ -#if defined(CONFIG_ARCH_MPC8360) - /* MDIO */ - {0, 1, 3, 0, 2}, /* MDIO */ - {0, 2, 1, 0, 1}, /* MDC */ - - /* UCC4 - UEC */ - {1, 14, 1, 0, 1}, /* TxD0 */ - {1, 15, 1, 0, 1}, /* TxD1 */ - {1, 20, 2, 0, 1}, /* RxD0 */ - {1, 21, 2, 0, 1}, /* RxD1 */ - {1, 18, 1, 0, 1}, /* TX_EN */ - {1, 26, 2, 0, 1}, /* RX_DV */ - {1, 27, 2, 0, 1}, /* RX_ER */ - {1, 24, 2, 0, 1}, /* COL */ - {1, 25, 2, 0, 1}, /* CRS */ - {2, 15, 2, 0, 1}, /* TX_CLK - CLK16 */ - {2, 16, 2, 0, 1}, /* RX_CLK - CLK17 */ - - /* DUART - UART2 */ - {5, 0, 1, 0, 2}, /* UART2_SOUT */ - {5, 2, 1, 0, 1}, /* UART2_RTS */ - {5, 3, 2, 0, 2}, /* UART2_SIN */ - {5, 1, 2, 0, 3}, /* UART2_CTS */ -#elif !defined(CONFIG_ARCH_MPC8309) - /* Local Bus */ - {0, 16, 1, 0, 3}, /* LA00 */ - {0, 17, 1, 0, 3}, /* LA01 */ - {0, 18, 1, 0, 3}, /* LA02 */ - {0, 19, 1, 0, 3}, /* LA03 */ - {0, 20, 1, 0, 3}, /* LA04 */ - {0, 21, 1, 0, 3}, /* LA05 */ - {0, 22, 1, 0, 3}, /* LA06 */ - {0, 23, 1, 0, 3}, /* LA07 */ - {0, 24, 1, 0, 3}, /* LA08 */ - {0, 25, 1, 0, 3}, /* LA09 */ - {0, 26, 1, 0, 3}, /* LA10 */ - {0, 27, 1, 0, 3}, /* LA11 */ - {0, 28, 1, 0, 3}, /* LA12 */ - {0, 29, 1, 0, 3}, /* LA13 */ - {0, 30, 1, 0, 3}, /* LA14 */ - {0, 31, 1, 0, 3}, /* LA15 */ - - /* MDIO */ - {3, 4, 3, 0, 2}, /* MDIO */ - {3, 5, 1, 0, 2}, /* MDC */ - - /* UCC4 - UEC */ - {1, 18, 1, 0, 1}, /* TxD0 */ - {1, 19, 1, 0, 1}, /* TxD1 */ - {1, 22, 2, 0, 1}, /* RxD0 */ - {1, 23, 2, 0, 1}, /* RxD1 */ - {1, 26, 2, 0, 1}, /* RxER */ - {1, 28, 2, 0, 1}, /* Rx_DV */ - {1, 30, 1, 0, 1}, /* TxEN */ - {1, 31, 2, 0, 1}, /* CRS */ - {3, 10, 2, 0, 3}, /* TxCLK->CLK17 */ -#endif - - /* END of table */ - {0, 0, 0, 0, QE_IOP_TAB_END}, -}; - static int piggy_present(void) { struct km_bec_fpga __iomem *base = diff --git a/configs/kmcoge5ne_defconfig b/configs/kmcoge5ne_defconfig index 363099212e..2d7b7ba879 100644 --- a/configs/kmcoge5ne_defconfig +++ b/configs/kmcoge5ne_defconfig @@ -4,7 +4,6 @@ CONFIG_KM_DEF_NETDEV="eth1" CONFIG_ENV_SIZE=0x4000 CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_BOOTCOUNT_BOOTLIMIT=3 -CONFIG_SYS_BOOTCOUNT_ADDR=0xE011BFF8 CONFIG_SYS_CLK_FREQ=66000000 CONFIG_MPC83xx=y CONFIG_HIGH_BATS=y @@ -156,7 +155,6 @@ CONFIG_ACR_PARKM_USB_I2C1_BOOT=y CONFIG_LCRR_DBYP_PLL_BYPASSED=y CONFIG_LCRR_EADC_2=y CONFIG_LCRR_CLKDIV_4=y -# CONFIG_SYS_MALLOC_F is not set CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_MISC_INIT_R=y @@ -173,6 +171,7 @@ CONFIG_CMD_GREPENV=y CONFIG_CMD_EEPROM=y CONFIG_CMD_I2C=y CONFIG_CMD_NAND=y +# CONFIG_CMD_PINMUX is not set CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y @@ -182,11 +181,13 @@ CONFIG_MTDIDS_DEFAULT="nor0=boot,nand0=app" CONFIG_MTDPARTS_DEFAULT="mtdparts=boot:768k(u-boot),128k(env),128k(envred),-(ubi0);app:-(ubi1);" CONFIG_CMD_UBI=y # CONFIG_CMD_UBIFS is not set +CONFIG_DEFAULT_DEVICE_TREE="kmcoge5ne" CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_ENV_ADDR=0xF00C0000 CONFIG_ENV_ADDR_REDUND=0xF00E0000 -CONFIG_DM=y CONFIG_BOOTCOUNT_LIMIT=y +CONFIG_DM_BOOTCOUNT=y +CONFIG_BOOTCOUNT_MEM=y # CONFIG_MMC is not set CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y @@ -196,8 +197,10 @@ CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_PROTECTION=y CONFIG_SYS_FLASH_CFI=y CONFIG_MTD_RAW_NAND=y +CONFIG_DM_ETH_PHY=y +CONFIG_QE_UEC=y # CONFIG_PCI is not set +# CONFIG_PINCTRL_FULL is not set CONFIG_QE=y CONFIG_SYS_NS16550=y CONFIG_BCH=y -CONFIG_OF_LIBFDT=y diff --git a/configs/kmeter1_defconfig b/configs/kmeter1_defconfig index 97c75dc68c..8967ace2e1 100644 --- a/configs/kmeter1_defconfig +++ b/configs/kmeter1_defconfig @@ -4,7 +4,6 @@ CONFIG_KM_DEF_NETDEV="eth2" CONFIG_ENV_SIZE=0x4000 CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_BOOTCOUNT_BOOTLIMIT=3 -CONFIG_SYS_BOOTCOUNT_ADDR=0xE011BFF8 CONFIG_SYS_CLK_FREQ=66000000 CONFIG_MPC83xx=y CONFIG_HIGH_BATS=y @@ -120,7 +119,6 @@ CONFIG_ACR_PARKM_USB_I2C1_BOOT=y CONFIG_LCRR_DBYP_PLL_BYPASSED=y CONFIG_LCRR_EADC_2=y CONFIG_LCRR_CLKDIV_4=y -# CONFIG_SYS_MALLOC_F is not set CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_MISC_INIT_R=y @@ -136,6 +134,7 @@ CONFIG_CMD_ASKENV=y CONFIG_CMD_GREPENV=y CONFIG_CMD_EEPROM=y CONFIG_CMD_I2C=y +# CONFIG_CMD_PINMUX is not set CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y @@ -145,11 +144,13 @@ CONFIG_MTDIDS_DEFAULT="nor0=boot" CONFIG_MTDPARTS_DEFAULT="mtdparts=boot:768k(u-boot),128k(env),128k(envred),-(ubi0);" CONFIG_CMD_UBI=y # CONFIG_CMD_UBIFS is not set +CONFIG_DEFAULT_DEVICE_TREE="kmeter1" CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_ENV_ADDR=0xF00C0000 CONFIG_ENV_ADDR_REDUND=0xF00E0000 -CONFIG_DM=y CONFIG_BOOTCOUNT_LIMIT=y +CONFIG_DM_BOOTCOUNT=y +CONFIG_BOOTCOUNT_MEM=y # CONFIG_MMC is not set CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y @@ -158,7 +159,8 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_PROTECTION=y CONFIG_SYS_FLASH_CFI=y +CONFIG_DM_ETH_PHY=y +CONFIG_QE_UEC=y # CONFIG_PCI is not set CONFIG_QE=y CONFIG_SYS_NS16550=y -CONFIG_OF_LIBFDT=y diff --git a/configs/kmopti2_defconfig b/configs/kmopti2_defconfig index 4b0f0e7521..7059facf0e 100644 --- a/configs/kmopti2_defconfig +++ b/configs/kmopti2_defconfig @@ -3,7 +3,6 @@ CONFIG_SYS_TEXT_BASE=0xF0000000 CONFIG_ENV_SIZE=0x4000 CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_BOOTCOUNT_BOOTLIMIT=3 -CONFIG_SYS_BOOTCOUNT_ADDR=0xE0113FF8 CONFIG_SYS_CLK_FREQ=66000000 CONFIG_MPC83xx=y CONFIG_HIGH_BATS=y @@ -139,7 +138,6 @@ CONFIG_ACR_APARK_MASTER=y CONFIG_ACR_PARKM_USB_I2C1_BOOT=y CONFIG_LCRR_EADC_1=y CONFIG_LCRR_CLKDIV_2=y -# CONFIG_SYS_MALLOC_F is not set CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_MISC_INIT_R=y @@ -155,6 +153,7 @@ CONFIG_CMD_ASKENV=y CONFIG_CMD_GREPENV=y CONFIG_CMD_EEPROM=y CONFIG_CMD_I2C=y +# CONFIG_CMD_PINMUX is not set CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y @@ -164,11 +163,13 @@ CONFIG_MTDIDS_DEFAULT="nor0=boot" CONFIG_MTDPARTS_DEFAULT="mtdparts=boot:768k(u-boot),128k(env),128k(envred),-(ubi0);" CONFIG_CMD_UBI=y # CONFIG_CMD_UBIFS is not set +CONFIG_DEFAULT_DEVICE_TREE="kmopti2" CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_ENV_ADDR=0xF00C0000 CONFIG_ENV_ADDR_REDUND=0xF00E0000 -CONFIG_DM=y CONFIG_BOOTCOUNT_LIMIT=y +CONFIG_DM_BOOTCOUNT=y +CONFIG_BOOTCOUNT_MEM=y # CONFIG_MMC is not set CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y @@ -177,7 +178,9 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_PROTECTION=y CONFIG_SYS_FLASH_CFI=y +CONFIG_DM_ETH_PHY=y +CONFIG_QE_UEC=y # CONFIG_PCI is not set +# CONFIG_PINCTRL_FULL is not set CONFIG_QE=y CONFIG_SYS_NS16550=y -CONFIG_OF_LIBFDT=y diff --git a/configs/kmsupx5_defconfig b/configs/kmsupx5_defconfig index 2e8c2d32f2..d62fc84cf6 100644 --- a/configs/kmsupx5_defconfig +++ b/configs/kmsupx5_defconfig @@ -3,7 +3,6 @@ CONFIG_SYS_TEXT_BASE=0xF0000000 CONFIG_ENV_SIZE=0x4000 CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_BOOTCOUNT_BOOTLIMIT=3 -CONFIG_SYS_BOOTCOUNT_ADDR=0xE0113FF8 CONFIG_SYS_CLK_FREQ=66000000 CONFIG_MPC83xx=y CONFIG_HIGH_BATS=y @@ -119,7 +118,6 @@ CONFIG_ACR_APARK_MASTER=y CONFIG_ACR_PARKM_USB_I2C1_BOOT=y CONFIG_LCRR_EADC_1=y CONFIG_LCRR_CLKDIV_2=y -# CONFIG_SYS_MALLOC_F is not set CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_MISC_INIT_R=y @@ -144,11 +142,13 @@ CONFIG_MTDIDS_DEFAULT="nor0=boot" CONFIG_MTDPARTS_DEFAULT="mtdparts=boot:768k(u-boot),128k(env),128k(envred),-(ubi0);" CONFIG_CMD_UBI=y # CONFIG_CMD_UBIFS is not set +CONFIG_DEFAULT_DEVICE_TREE="kmsupm5" CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_ENV_ADDR=0xF00C0000 CONFIG_ENV_ADDR_REDUND=0xF00E0000 -CONFIG_DM=y CONFIG_BOOTCOUNT_LIMIT=y +CONFIG_DM_BOOTCOUNT=y +CONFIG_BOOTCOUNT_MEM=y # CONFIG_MMC is not set CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y @@ -157,7 +157,9 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_PROTECTION=y CONFIG_SYS_FLASH_CFI=y +CONFIG_DM_ETH_PHY=y +CONFIG_QE_UEC=y # CONFIG_PCI is not set +# CONFIG_PINCTRL_FULL is not set CONFIG_QE=y CONFIG_SYS_NS16550=y -CONFIG_OF_LIBFDT=y diff --git a/configs/kmtegr1_defconfig b/configs/kmtegr1_defconfig index dc09d238ec..5bb2b05e25 100644 --- a/configs/kmtegr1_defconfig +++ b/configs/kmtegr1_defconfig @@ -4,7 +4,6 @@ CONFIG_KM_DEF_NETDEV="eth1" CONFIG_ENV_SIZE=0x4000 CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_BOOTCOUNT_BOOTLIMIT=3 -CONFIG_SYS_BOOTCOUNT_ADDR=0xE0113FF8 CONFIG_SYS_CLK_FREQ=66000000 CONFIG_MPC83xx=y CONFIG_HIGH_BATS=y @@ -118,7 +117,6 @@ CONFIG_ACR_APARK_MASTER=y CONFIG_ACR_PARKM_USB_I2C1_BOOT=y CONFIG_LCRR_EADC_1=y CONFIG_LCRR_CLKDIV_2=y -# CONFIG_SYS_MALLOC_F is not set CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="KMTEGR1" @@ -146,11 +144,13 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=boot:768k(u-boot),256k(qe-fw),128k(env),128k(e CONFIG_CMD_DIAG=y CONFIG_CMD_UBI=y # CONFIG_CMD_UBIFS is not set +CONFIG_DEFAULT_DEVICE_TREE="kmtegr1" CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_ENV_ADDR=0xF0100000 CONFIG_ENV_ADDR_REDUND=0xF0120000 -CONFIG_DM=y CONFIG_BOOTCOUNT_LIMIT=y +CONFIG_DM_BOOTCOUNT=y +CONFIG_BOOTCOUNT_MEM=y # CONFIG_MMC is not set CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y @@ -160,9 +160,13 @@ CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_PROTECTION=y CONFIG_SYS_FLASH_CFI=y CONFIG_MTD_RAW_NAND=y +CONFIG_PHY_SMSC=y +CONFIG_PHY_FIXED=y +CONFIG_DM_ETH_PHY=y +CONFIG_QE_UEC=y # CONFIG_PCI is not set +# CONFIG_PINCTRL_FULL is not set CONFIG_QE=y CONFIG_SYS_QE_FMAN_FW_IN_NOR=y CONFIG_SYS_NS16550=y CONFIG_BCH=y -CONFIG_OF_LIBFDT=y diff --git a/configs/kmtepr2_defconfig b/configs/kmtepr2_defconfig index 6159425bba..02888dd1d3 100644 --- a/configs/kmtepr2_defconfig +++ b/configs/kmtepr2_defconfig @@ -3,7 +3,6 @@ CONFIG_SYS_TEXT_BASE=0xF0000000 CONFIG_ENV_SIZE=0x4000 CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_BOOTCOUNT_BOOTLIMIT=3 -CONFIG_SYS_BOOTCOUNT_ADDR=0xE0113FF8 CONFIG_SYS_CLK_FREQ=66000000 CONFIG_MPC83xx=y CONFIG_HIGH_BATS=y @@ -139,7 +138,6 @@ CONFIG_ACR_APARK_MASTER=y CONFIG_ACR_PARKM_USB_I2C1_BOOT=y CONFIG_LCRR_EADC_1=y CONFIG_LCRR_CLKDIV_2=y -# CONFIG_SYS_MALLOC_F is not set CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_MISC_INIT_R=y @@ -164,11 +162,13 @@ CONFIG_MTDIDS_DEFAULT="nor0=boot" CONFIG_MTDPARTS_DEFAULT="mtdparts=boot:768k(u-boot),128k(env),128k(envred),-(ubi0);" CONFIG_CMD_UBI=y # CONFIG_CMD_UBIFS is not set +CONFIG_DEFAULT_DEVICE_TREE="kmtepr2" CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_ENV_ADDR=0xF00C0000 CONFIG_ENV_ADDR_REDUND=0xF00E0000 -CONFIG_DM=y CONFIG_BOOTCOUNT_LIMIT=y +CONFIG_DM_BOOTCOUNT=y +CONFIG_BOOTCOUNT_MEM=y # CONFIG_MMC is not set CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y @@ -177,7 +177,9 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_PROTECTION=y CONFIG_SYS_FLASH_CFI=y +CONFIG_DM_ETH_PHY=y +CONFIG_QE_UEC=y # CONFIG_PCI is not set +# CONFIG_PINCTRL_FULL is not set CONFIG_QE=y CONFIG_SYS_NS16550=y -CONFIG_OF_LIBFDT=y diff --git a/configs/tuge1_defconfig b/configs/tuge1_defconfig index 93ff5f0361..7ac97742c5 100644 --- a/configs/tuge1_defconfig +++ b/configs/tuge1_defconfig @@ -3,7 +3,6 @@ CONFIG_SYS_TEXT_BASE=0xF0000000 CONFIG_ENV_SIZE=0x4000 CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_BOOTCOUNT_BOOTLIMIT=3 -CONFIG_SYS_BOOTCOUNT_ADDR=0xE0113FF8 CONFIG_SYS_CLK_FREQ=66000000 CONFIG_MPC83xx=y CONFIG_HIGH_BATS=y @@ -119,7 +118,6 @@ CONFIG_ACR_APARK_MASTER=y CONFIG_ACR_PARKM_USB_I2C1_BOOT=y CONFIG_LCRR_EADC_1=y CONFIG_LCRR_CLKDIV_2=y -# CONFIG_SYS_MALLOC_F is not set CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_MISC_INIT_R=y @@ -144,11 +142,13 @@ CONFIG_MTDIDS_DEFAULT="nor0=boot" CONFIG_MTDPARTS_DEFAULT="mtdparts=boot:768k(u-boot),128k(env),128k(envred),-(ubi0);" CONFIG_CMD_UBI=y # CONFIG_CMD_UBIFS is not set +CONFIG_DEFAULT_DEVICE_TREE="kmtuge1" CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_ENV_ADDR=0xF00C0000 CONFIG_ENV_ADDR_REDUND=0xF00E0000 -CONFIG_DM=y CONFIG_BOOTCOUNT_LIMIT=y +CONFIG_DM_BOOTCOUNT=y +CONFIG_BOOTCOUNT_MEM=y # CONFIG_MMC is not set CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y @@ -157,7 +157,9 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_PROTECTION=y CONFIG_SYS_FLASH_CFI=y +CONFIG_DM_ETH_PHY=y +CONFIG_QE_UEC=y # CONFIG_PCI is not set +# CONFIG_PINCTRL_FULL is not set CONFIG_QE=y CONFIG_SYS_NS16550=y -CONFIG_OF_LIBFDT=y diff --git a/configs/tuxx1_defconfig b/configs/tuxx1_defconfig index 2e27dc6b3f..77ca2db57a 100644 --- a/configs/tuxx1_defconfig +++ b/configs/tuxx1_defconfig @@ -3,7 +3,6 @@ CONFIG_SYS_TEXT_BASE=0xF0000000 CONFIG_ENV_SIZE=0x4000 CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_BOOTCOUNT_BOOTLIMIT=3 -CONFIG_SYS_BOOTCOUNT_ADDR=0xE0113FF8 CONFIG_SYS_CLK_FREQ=66000000 CONFIG_MPC83xx=y CONFIG_HIGH_BATS=y @@ -141,7 +140,6 @@ CONFIG_ACR_APARK_MASTER=y CONFIG_ACR_PARKM_USB_I2C1_BOOT=y CONFIG_LCRR_EADC_1=y CONFIG_LCRR_CLKDIV_2=y -# CONFIG_SYS_MALLOC_F is not set CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_MISC_INIT_R=y @@ -166,11 +164,13 @@ CONFIG_MTDIDS_DEFAULT="nor0=boot" CONFIG_MTDPARTS_DEFAULT="mtdparts=boot:768k(u-boot),128k(env),128k(envred),-(ubi0);" CONFIG_CMD_UBI=y # CONFIG_CMD_UBIFS is not set +CONFIG_DEFAULT_DEVICE_TREE="kmtuxa1" CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_ENV_ADDR=0xF00C0000 CONFIG_ENV_ADDR_REDUND=0xF00E0000 -CONFIG_DM=y CONFIG_BOOTCOUNT_LIMIT=y +CONFIG_DM_BOOTCOUNT=y +CONFIG_BOOTCOUNT_MEM=y # CONFIG_MMC is not set CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y @@ -179,7 +179,10 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_PROTECTION=y CONFIG_SYS_FLASH_CFI=y +CONFIG_PHY_SMSC=y +CONFIG_DM_ETH_PHY=y +CONFIG_QE_UEC=y # CONFIG_PCI is not set +# CONFIG_PINCTRL_FULL is not set CONFIG_QE=y CONFIG_SYS_NS16550=y -CONFIG_OF_LIBFDT=y diff --git a/include/configs/km/km-mpc832x.h b/include/configs/km/km-mpc832x.h index d7186ab919..22dfb5da67 100644 --- a/include/configs/km/km-mpc832x.h +++ b/include/configs/km/km-mpc832x.h @@ -10,20 +10,6 @@ #define CONFIG_SYS_CLK_FREQ 66000000 #define CONFIG_83XX_PCICLK 66000000
-/* - * QE UEC ethernet configuration - */ -#define CONFIG_UEC_ETH1 /* GETH1 */ -#define UEC_VERBOSE_DEBUG 1 - -#define CONFIG_SYS_UEC1_UCC_NUM 3 /* UCC4 */ -#define CONFIG_SYS_UEC1_RX_CLK QE_CLK_NONE /* not used in RMII Mode */ -#define CONFIG_SYS_UEC1_TX_CLK QE_CLK17 -#define CONFIG_SYS_UEC1_ETH_TYPE FAST_ETH -#define CONFIG_SYS_UEC1_PHY_ADDR 0 -#define CONFIG_SYS_UEC1_INTERFACE_TYPE PHY_INTERFACE_MODE_RMII -#define CONFIG_SYS_UEC1_INTERFACE_SPEED 100 - /* * System IO Config */ diff --git a/include/configs/km/km-mpc8360.h b/include/configs/km/km-mpc8360.h index bdbb8bf6b5..798b126960 100644 --- a/include/configs/km/km-mpc8360.h +++ b/include/configs/km/km-mpc8360.h @@ -6,20 +6,6 @@ * High Level Configuration Options */
-/* - * QE UEC ethernet configuration - */ -#define CONFIG_UEC_ETH1 /* GETH1 */ -#define UEC_VERBOSE_DEBUG 1 - -#define CONFIG_SYS_UEC1_UCC_NUM 3 /* UCC4 */ -#define CONFIG_SYS_UEC1_RX_CLK QE_CLK_NONE /* not used in RMII Mode */ -#define CONFIG_SYS_UEC1_TX_CLK QE_CLK17 -#define CONFIG_SYS_UEC1_ETH_TYPE FAST_ETH -#define CONFIG_SYS_UEC1_PHY_ADDR 0 -#define CONFIG_SYS_UEC1_INTERFACE_TYPE PHY_INTERFACE_MODE_RMII -#define CONFIG_SYS_UEC1_INTERFACE_SPEED 100 - /* * System IO Setup */ diff --git a/include/configs/km/km-mpc83xx.h b/include/configs/km/km-mpc83xx.h index 451baf8b80..7d9012c715 100644 --- a/include/configs/km/km-mpc83xx.h +++ b/include/configs/km/km-mpc83xx.h @@ -61,16 +61,6 @@ #define CONFIG_SYS_MAX_FLASH_SECT 512 /* max num of sects on one chip */ #define CONFIG_SYS_FLASH_BANKS_LIST { CONFIG_SYS_FLASH_BASE }
-/* - * Serial Port - */ -#define CONFIG_SYS_NS16550_SERIAL -#define CONFIG_SYS_NS16550_REG_SIZE 1 -#define CONFIG_SYS_NS16550_CLK get_bus_freq(0) - -#define CONFIG_SYS_NS16550_COM1 (CONFIG_SYS_IMMR + 0x4500) -#define CONFIG_SYS_NS16550_COM2 (CONFIG_SYS_IMMR + 0x4600) - /* I2C */ #define CONFIG_SYS_I2C #define CONFIG_SYS_NUM_I2C_BUSES 4
Hello Mario,
Am 27.05.2020 um 14:43 schrieb Heiko Schocher:
This patch series adds DM ethernet support for mpc83xx based keymile boards.
Travis build: https://travis-ci.org/github/hsdenx/u-boot-test/builds/691607214
Changes in v2:
- new in v2
- remove RFC
- fixed Codingstyle errors, therefore new patch powerpc, mpc83xx: fix codingstyle issues for qe_io.c
- moved DM part to drivers/pinctrl
- add comments from Qiang Zhao:
- add device node documentation
- I did not drop the dm_qe_uec_phy.c and use drivers/net/fsl_mdio.c because using drivers/net/fsl_mdio.c leads in none existent udevice mdio@3320 instead boards with DM ETH support should use now this driver.
- remove RFC tag
- add patch which fixes Codingstyle errors in drivers/qe
- add patch which converts the mpc83xx based boards from keymile to DM_ETH
Heiko Schocher (5): mpc83xx: remove unneeded extern declaration in cpu_init powerpc, qe: fix codingstyle issues for drivers/qe powerpc, qe: add DTS support for parallel I/O ports net, qe: add DM support for QE UEC ethernet mpc83xx, keymile boards: enable DM_ETH and add DTS
arch/powerpc/cpu/mpc83xx/Kconfig | 8 + arch/powerpc/cpu/mpc83xx/Makefile | 2 + arch/powerpc/cpu/mpc83xx/cpu_init.c | 11 +- arch/powerpc/cpu/mpc83xx/qe_io.c | 98 +- arch/powerpc/dts/Makefile | 8 + arch/powerpc/dts/km8309-uboot.dtsi | 33 + arch/powerpc/dts/km8321-uboot.dtsi | 67 + arch/powerpc/dts/km8321.dtsi | 220 ++++ arch/powerpc/dts/km836x-uboot.dtsi | 61 + arch/powerpc/dts/km836x.dtsi | 182 +++ arch/powerpc/dts/kmcoge5ne-uboot.dtsi | 22 + arch/powerpc/dts/kmcoge5ne.dts | 320 +++++ arch/powerpc/dts/kmeter1-uboot.dtsi | 42 + arch/powerpc/dts/kmeter1.dts | 480 +++++++ arch/powerpc/dts/kmopti2.dts | 161 +++ arch/powerpc/dts/kmsupc5.dts | 139 ++ arch/powerpc/dts/kmsupm5.dts | 129 ++ arch/powerpc/dts/kmtegr1.dts | 392 ++++++ arch/powerpc/dts/kmtepr2.dts | 142 ++ arch/powerpc/dts/kmtuge1.dts | 100 ++ arch/powerpc/dts/kmtuxa1.dts | 100 ++ board/keymile/km83xx/Kconfig | 17 + board/keymile/km83xx/MAINTAINERS | 23 +- board/keymile/km83xx/km83xx.c | 64 - configs/kmcoge5ne_defconfig | 11 +- configs/kmeter1_defconfig | 10 +- configs/kmopti2_defconfig | 11 +- configs/kmsupx5_defconfig | 10 +- configs/kmtegr1_defconfig | 12 +- configs/kmtepr2_defconfig | 10 +- configs/tuge1_defconfig | 10 +- configs/tuxx1_defconfig | 11 +- .../soc/fsl/cpm_qe/qe/ucc.txt | 53 + drivers/net/Kconfig | 2 + drivers/net/Makefile | 1 + drivers/net/qe/Kconfig | 9 + drivers/net/qe/Makefile | 5 + drivers/net/qe/dm_qe_uec.c | 1167 +++++++++++++++++ drivers/net/qe/dm_qe_uec.h | 22 + drivers/net/qe/dm_qe_uec_phy.c | 163 +++ drivers/net/qe/uccf.c | 507 +++++++ drivers/net/qe/uccf.h | 119 ++ drivers/net/qe/uec.h | 693 ++++++++++ drivers/pinctrl/Kconfig | 7 + drivers/pinctrl/Makefile | 1 + drivers/pinctrl/pinctrl-qe-io.c | 255 ++++ drivers/qe/qe.c | 96 +- drivers/qe/uccf.c | 449 ++++--- drivers/qe/uccf.h | 90 +- drivers/qe/uec.c | 598 ++++----- drivers/qe/uec.h | 381 +++--- drivers/qe/uec_phy.c | 334 ++--- drivers/qe/uec_phy.h | 71 +- include/configs/km/km-mpc832x.h | 14 - include/configs/km/km-mpc8360.h | 14 - include/configs/km/km-mpc83xx.h | 10 - include/fsl_qe.h | 3 + 57 files changed, 6826 insertions(+), 1144 deletions(-) create mode 100644 arch/powerpc/dts/km8309-uboot.dtsi create mode 100644 arch/powerpc/dts/km8321-uboot.dtsi create mode 100644 arch/powerpc/dts/km8321.dtsi create mode 100644 arch/powerpc/dts/km836x-uboot.dtsi create mode 100644 arch/powerpc/dts/km836x.dtsi create mode 100644 arch/powerpc/dts/kmcoge5ne-uboot.dtsi create mode 100644 arch/powerpc/dts/kmcoge5ne.dts create mode 100644 arch/powerpc/dts/kmeter1-uboot.dtsi create mode 100644 arch/powerpc/dts/kmeter1.dts create mode 100644 arch/powerpc/dts/kmopti2.dts create mode 100644 arch/powerpc/dts/kmsupc5.dts create mode 100644 arch/powerpc/dts/kmsupm5.dts create mode 100644 arch/powerpc/dts/kmtegr1.dts create mode 100644 arch/powerpc/dts/kmtepr2.dts create mode 100644 arch/powerpc/dts/kmtuge1.dts create mode 100644 arch/powerpc/dts/kmtuxa1.dts create mode 100644 doc/device-tree-bindings/soc/fsl/cpm_qe/qe/ucc.txt create mode 100644 drivers/net/qe/Kconfig create mode 100644 drivers/net/qe/Makefile create mode 100644 drivers/net/qe/dm_qe_uec.c create mode 100644 drivers/net/qe/dm_qe_uec.h create mode 100644 drivers/net/qe/dm_qe_uec_phy.c create mode 100644 drivers/net/qe/uccf.c create mode 100644 drivers/net/qe/uccf.h create mode 100644 drivers/net/qe/uec.h create mode 100644 drivers/pinctrl/pinctrl-qe-io.c
gentle ping!
I got no reviews, comments for this patchseries ...
any comments?
bye, Heiko
Hi Mario,
Am 17.08.2020 um 07:23 schrieb Heiko Schocher:
Hello Mario,
Changes in v2:
- new in v2
- remove RFC
- add device node documentation - I did not drop the dm_qe_uec_phy.c and use drivers/net/fsl_mdio.c because using drivers/net/fsl_mdio.c leads in none existent udevice mdio@3320 instead boards with DM ETH support should use now this driver.
- remove RFC tag
keymile to DM_ETH
gentle ping!
any comments?
ping?
I have a rebased version in the meantime, but I would wait for any comments...
bye, Heiko
Hello Mario, Tom,
added Tom to cc ...
Am 08.09.2020 um 07:59 schrieb Heiko Schocher:
Hi Mario,
Hello Mario,
Changes in v2:
- new in v2
- remove RFC
- remove RFC tag
keymile to DM_ETH
gentle ping!
any comments?
ping?
gentle ping...
@Tom: Mario seems to busy .. how to proceed here with this patches?
bye, Heiko
On Wed, Sep 16, 2020 at 07:04:57AM +0200, Heiko Schocher wrote:
Hello Mario, Tom,
added Tom to cc ...
Hi Mario,
Hello Mario,
Changes in v2:
- new in v2
- remove RFC
- remove RFC tag
keymile to DM_ETH
gentle ping!
any comments?
ping?
gentle ping...
Can you put together something for me to pull in to -next please? Thanks!
Hello Tom,
Am 16.09.2020 um 21:01 schrieb Tom Rini:
Hello Mario, Tom,
added Tom to cc ...
Hi Mario,
Hello Mario,
Changes in v2:
- new in v2
- remove RFC
- remove RFC tag
keymile to DM_ETH
gentle ping!
any comments?
ping?
gentle ping...
Ok, pushed them to a repo on github:
https://github.com/hsdenx/u-boot-test/tree/kmcoge5ne-dm-ethernet-devel
started travis build for this branch: https://travis-ci.org/github/hsdenx/u-boot-test/builds/727904421
If all builds fine, I can send a pull request ... is it ok for you if I push this branch to u-boot-i2c kmcoge5ne-dm-ethernet-devel?
Thanks!
bye, Heiko
On Thu, Sep 17, 2020 at 06:27:03AM +0200, Heiko Schocher wrote:
Hello Tom,
Hello Mario, Tom,
added Tom to cc ...
Hi Mario,
Hello Mario,
Changes in v2:
- new in v2
- remove RFC
- remove RFC tag
keymile to DM_ETH
gentle ping!
any comments?
ping?
gentle ping...
Works for me, thanks!
Hello Tom,
Am 17.09.2020 um 14:51 schrieb Tom Rini:
Hello Tom,
Hello Mario, Tom,
added Tom to cc ...
Hi Mario,
Hello Mario,
Am 27.05.2020 um 14:43 schrieb Heiko Schocher: > > This patch series adds DM ethernet support for mpc83xx based > keymile boards. > > Travis build: > https://travis-ci.org/github/hsdenx/u-boot-test/builds/691607214 > > > Changes in v2: > - new in v2 > - remove RFC > - fixed Codingstyle errors, therefore new patch > powerpc, mpc83xx: fix codingstyle issues for qe_io.c > - moved DM part to drivers/pinctrl > - add comments from Qiang Zhao: > - add device node documentation > - I did not drop the dm_qe_uec_phy.c and use drivers/net/fsl_mdio.c > because using drivers/net/fsl_mdio.c leads in none existent > udevice mdio@3320 > instead boards with DM ETH support should use now this > driver. > - remove RFC tag > - add patch which fixes Codingstyle errors in drivers/qe > - add patch which converts the mpc83xx based boards from > keymile to DM_ETH > > Heiko Schocher (5): > mpc83xx: remove unneeded extern declaration in cpu_init > powerpc, qe: fix codingstyle issues for drivers/qe > powerpc, qe: add DTS support for parallel I/O ports > net, qe: add DM support for QE UEC ethernet > mpc83xx, keymile boards: enable DM_ETH and add DTS > > arch/powerpc/cpu/mpc83xx/Kconfig | 8 + > arch/powerpc/cpu/mpc83xx/Makefile | 2 + > arch/powerpc/cpu/mpc83xx/cpu_init.c | 11 +- > arch/powerpc/cpu/mpc83xx/qe_io.c | 98 +- > arch/powerpc/dts/Makefile | 8 + > arch/powerpc/dts/km8309-uboot.dtsi | 33 + > arch/powerpc/dts/km8321-uboot.dtsi | 67 + > arch/powerpc/dts/km8321.dtsi | 220 ++++ > arch/powerpc/dts/km836x-uboot.dtsi | 61 + > arch/powerpc/dts/km836x.dtsi | 182 +++ > arch/powerpc/dts/kmcoge5ne-uboot.dtsi | 22 + > arch/powerpc/dts/kmcoge5ne.dts | 320 +++++ > arch/powerpc/dts/kmeter1-uboot.dtsi | 42 + > arch/powerpc/dts/kmeter1.dts | 480 +++++++ > arch/powerpc/dts/kmopti2.dts | 161 +++ > arch/powerpc/dts/kmsupc5.dts | 139 ++ > arch/powerpc/dts/kmsupm5.dts | 129 ++ > arch/powerpc/dts/kmtegr1.dts | 392 ++++++ > arch/powerpc/dts/kmtepr2.dts | 142 ++ > arch/powerpc/dts/kmtuge1.dts | 100 ++ > arch/powerpc/dts/kmtuxa1.dts | 100 ++ > board/keymile/km83xx/Kconfig | 17 + > board/keymile/km83xx/MAINTAINERS | 23 +- > board/keymile/km83xx/km83xx.c | 64 - > configs/kmcoge5ne_defconfig | 11 +- > configs/kmeter1_defconfig | 10 +- > configs/kmopti2_defconfig | 11 +- > configs/kmsupx5_defconfig | 10 +- > configs/kmtegr1_defconfig | 12 +- > configs/kmtepr2_defconfig | 10 +- > configs/tuge1_defconfig | 10 +- > configs/tuxx1_defconfig | 11 +- > .../soc/fsl/cpm_qe/qe/ucc.txt | 53 + > drivers/net/Kconfig | 2 + > drivers/net/Makefile | 1 + > drivers/net/qe/Kconfig | 9 + > drivers/net/qe/Makefile | 5 + > drivers/net/qe/dm_qe_uec.c | 1167 +++++++++++++++++ > drivers/net/qe/dm_qe_uec.h | 22 + > drivers/net/qe/dm_qe_uec_phy.c | 163 +++ > drivers/net/qe/uccf.c | 507 +++++++ > drivers/net/qe/uccf.h | 119 ++ > drivers/net/qe/uec.h | 693 ++++++++++ > drivers/pinctrl/Kconfig | 7 + > drivers/pinctrl/Makefile | 1 + > drivers/pinctrl/pinctrl-qe-io.c | 255 ++++ > drivers/qe/qe.c | 96 +- > drivers/qe/uccf.c | 449 ++++--- > drivers/qe/uccf.h | 90 +- > drivers/qe/uec.c | 598 ++++----- > drivers/qe/uec.h | 381 +++--- > drivers/qe/uec_phy.c | 334 ++--- > drivers/qe/uec_phy.h | 71 +- > include/configs/km/km-mpc832x.h | 14 - > include/configs/km/km-mpc8360.h | 14 - > include/configs/km/km-mpc83xx.h | 10 - > include/fsl_qe.h | 3 + > 57 files changed, 6826 insertions(+), 1144 deletions(-) > create mode 100644 arch/powerpc/dts/km8309-uboot.dtsi > create mode 100644 arch/powerpc/dts/km8321-uboot.dtsi > create mode 100644 arch/powerpc/dts/km8321.dtsi > create mode 100644 arch/powerpc/dts/km836x-uboot.dtsi > create mode 100644 arch/powerpc/dts/km836x.dtsi > create mode 100644 arch/powerpc/dts/kmcoge5ne-uboot.dtsi > create mode 100644 arch/powerpc/dts/kmcoge5ne.dts > create mode 100644 arch/powerpc/dts/kmeter1-uboot.dtsi > create mode 100644 arch/powerpc/dts/kmeter1.dts > create mode 100644 arch/powerpc/dts/kmopti2.dts > create mode 100644 arch/powerpc/dts/kmsupc5.dts > create mode 100644 arch/powerpc/dts/kmsupm5.dts > create mode 100644 arch/powerpc/dts/kmtegr1.dts > create mode 100644 arch/powerpc/dts/kmtepr2.dts > create mode 100644 arch/powerpc/dts/kmtuge1.dts > create mode 100644 arch/powerpc/dts/kmtuxa1.dts > create mode 100644 doc/device-tree-bindings/soc/fsl/cpm_qe/qe/ucc.txt > create mode 100644 drivers/net/qe/Kconfig > create mode 100644 drivers/net/qe/Makefile > create mode 100644 drivers/net/qe/dm_qe_uec.c > create mode 100644 drivers/net/qe/dm_qe_uec.h > create mode 100644 drivers/net/qe/dm_qe_uec_phy.c > create mode 100644 drivers/net/qe/uccf.c > create mode 100644 drivers/net/qe/uccf.h > create mode 100644 drivers/net/qe/uec.h > create mode 100644 drivers/pinctrl/pinctrl-qe-io.c
gentle ping!
any comments?
ping?
gentle ping...
Ok, travis build is fine, so here the pull request:
The following changes since commit bd4e8944cf7e36f8ad39466c40f8fc197c9df1c5:
Merge tag 'ti-v2021.01-next' of https://gitlab.denx.de/u-boot/custodians/u-boot-ti into next (2020-09-15 15:22:00 -0400)
https://gitlab.denx.de/u-boot/custodians/u-boot-i2c.git tags/for-v2021.01-next
for you to fetch changes up to 7bdfe8592956439743cad3c2d3ff5f24c4dd5aa9:
mpc83xx, keymile boards: enable DM_ETH and add DTS (2020-09-17 06:09:54 +0200)
---------------------------------------------------------------- mpc83xx, keymile boards: enable DM_ETH and add DTS - mpc83xx: remove unneeded extern declaration in cpu_init - powerpc, qe: fix codingstyle issues for drivers/qe - powerpc, qe: add DTS support for parallel I/O ports - net, qe: add DM support for QE UEC ethernet - add DTS for all mpc83xx based boards from keymile mainly they are not mainlined to linux. - add u-boot specific dtsi
- add stdout-path
- add missing ucc4 par_io definitions, which were in board code, but not in linux DTS - remove not used ethernet nodes
---------------------------------------------------------------- Heiko Schocher (5): mpc83xx: remove unneeded extern declaration in cpu_init powerpc, qe: fix codingstyle issues for drivers/qe powerpc, qe: add DTS support for parallel I/O ports net, qe: add DM support for QE UEC ethernet mpc83xx, keymile boards: enable DM_ETH and add DTS
arch/powerpc/cpu/mpc83xx/Kconfig | 8 + arch/powerpc/cpu/mpc83xx/Makefile | 2 + arch/powerpc/cpu/mpc83xx/cpu_init.c | 11 +- arch/powerpc/cpu/mpc83xx/qe_io.c | 98 +++++++--- arch/powerpc/dts/Makefile | 8 + arch/powerpc/dts/km8309-uboot.dtsi | 33 ++++ arch/powerpc/dts/km8321-uboot.dtsi | 67 +++++++ arch/powerpc/dts/km8321.dtsi | 220 +++++++++++++++++++++ arch/powerpc/dts/km836x-uboot.dtsi | 61 ++++++ arch/powerpc/dts/km836x.dtsi | 182 ++++++++++++++++++ arch/powerpc/dts/kmcoge5ne-uboot.dtsi | 22 +++ arch/powerpc/dts/kmcoge5ne.dts | 320 +++++++++++++++++++++++++++++++ arch/powerpc/dts/kmeter1-uboot.dtsi | 42 ++++ arch/powerpc/dts/kmeter1.dts | 480 ++++++++++++++++++++++++++++++++++++++++++++++ arch/powerpc/dts/kmopti2.dts | 161 ++++++++++++++++ arch/powerpc/dts/kmsupc5.dts | 139 ++++++++++++++ arch/powerpc/dts/kmsupm5.dts | 129 +++++++++++++ arch/powerpc/dts/kmtegr1.dts | 392 ++++++++++++++++++++++++++++++++++++++ arch/powerpc/dts/kmtepr2.dts | 142 ++++++++++++++ arch/powerpc/dts/kmtuge1.dts | 100 ++++++++++ arch/powerpc/dts/kmtuxa1.dts | 100 ++++++++++ board/keymile/km83xx/Kconfig | 17 ++ board/keymile/km83xx/MAINTAINERS | 23 ++- board/keymile/km83xx/km83xx.c | 64 ------- configs/kmcoge5ne_defconfig | 11 +- configs/kmeter1_defconfig | 10 +- configs/kmopti2_defconfig | 11 +- configs/kmsupx5_defconfig | 10 +- configs/kmtegr1_defconfig | 12 +- configs/kmtepr2_defconfig | 10 +- configs/tuge1_defconfig | 10 +- configs/tuxx1_defconfig | 11 +- doc/device-tree-bindings/soc/fsl/cpm_qe/qe/ucc.txt | 53 ++++++ drivers/net/Kconfig | 2 + drivers/net/Makefile | 1 + drivers/net/qe/Kconfig | 9 + drivers/net/qe/Makefile | 5 + drivers/net/qe/dm_qe_uec.c | 1167 ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ drivers/net/qe/dm_qe_uec.h | 22 +++ drivers/net/qe/dm_qe_uec_phy.c | 163 ++++++++++++++++ drivers/net/qe/uccf.c | 507 +++++++++++++++++++++++++++++++++++++++++++++++++ drivers/net/qe/uccf.h | 119 ++++++++++++ drivers/net/qe/uec.h | 693 ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ drivers/pinctrl/Kconfig | 7 + drivers/pinctrl/Makefile | 1 + drivers/pinctrl/pinctrl-qe-io.c | 255 +++++++++++++++++++++++++ drivers/qe/Kconfig | 2 +- drivers/qe/qe.c | 96 +++++----- drivers/qe/uccf.c | 449 +++++++++++++++++++++++++++---------------- drivers/qe/uccf.h | 90 ++++----- drivers/qe/uec.c | 598 ++++++++++++++++++++++++++++----------------------------- drivers/qe/uec.h | 381 ++++++++++++++++--------------------- drivers/qe/uec_phy.c | 334 ++++++++++++++++---------------- drivers/qe/uec_phy.h | 71 +++---- include/configs/km/km-mpc832x.h | 14 -- include/configs/km/km-mpc8360.h | 14 -- include/configs/km/km-mpc83xx.h | 10 - include/fsl_qe.h | 3 + 58 files changed, 6827 insertions(+), 1145 deletions(-) create mode 100644 arch/powerpc/dts/km8309-uboot.dtsi create mode 100644 arch/powerpc/dts/km8321-uboot.dtsi create mode 100644 arch/powerpc/dts/km8321.dtsi create mode 100644 arch/powerpc/dts/km836x-uboot.dtsi create mode 100644 arch/powerpc/dts/km836x.dtsi create mode 100644 arch/powerpc/dts/kmcoge5ne-uboot.dtsi create mode 100644 arch/powerpc/dts/kmcoge5ne.dts create mode 100644 arch/powerpc/dts/kmeter1-uboot.dtsi create mode 100644 arch/powerpc/dts/kmeter1.dts create mode 100644 arch/powerpc/dts/kmopti2.dts create mode 100644 arch/powerpc/dts/kmsupc5.dts create mode 100644 arch/powerpc/dts/kmsupm5.dts create mode 100644 arch/powerpc/dts/kmtegr1.dts create mode 100644 arch/powerpc/dts/kmtepr2.dts create mode 100644 arch/powerpc/dts/kmtuge1.dts create mode 100644 arch/powerpc/dts/kmtuxa1.dts create mode 100644 doc/device-tree-bindings/soc/fsl/cpm_qe/qe/ucc.txt create mode 100644 drivers/net/qe/Kconfig create mode 100644 drivers/net/qe/Makefile create mode 100644 drivers/net/qe/dm_qe_uec.c create mode 100644 drivers/net/qe/dm_qe_uec.h create mode 100644 drivers/net/qe/dm_qe_uec_phy.c create mode 100644 drivers/net/qe/uccf.c create mode 100644 drivers/net/qe/uccf.h create mode 100644 drivers/net/qe/uec.h create mode 100644 drivers/pinctrl/pinctrl-qe-io.c
Thanks!
bye, Heiko
On Thu, Sep 17, 2020 at 03:03:28PM +0200, Heiko Schocher wrote:
Hello Tom,
Hello Tom,
Hello Mario, Tom,
added Tom to cc ...
Hi Mario,
Am 17.08.2020 um 07:23 schrieb Heiko Schocher: > Hello Mario, > > Am 27.05.2020 um 14:43 schrieb Heiko Schocher: > > > > This patch series adds DM ethernet support for mpc83xx based > > keymile boards. > > > > Travis build: > > https://travis-ci.org/github/hsdenx/u-boot-test/builds/691607214 > > > > > > Changes in v2: > > - new in v2 > > - remove RFC > > - fixed Codingstyle errors, therefore new patch > > powerpc, mpc83xx: fix codingstyle issues for qe_io.c > > - moved DM part to drivers/pinctrl > > - add comments from Qiang Zhao: > > - add device node documentation > > - I did not drop the dm_qe_uec_phy.c and use drivers/net/fsl_mdio.c > > because using drivers/net/fsl_mdio.c leads in none existent > > udevice mdio@3320 > > instead boards with DM ETH support should use now this > > driver. > > - remove RFC tag > > - add patch which fixes Codingstyle errors in drivers/qe > > - add patch which converts the mpc83xx based boards from > > keymile to DM_ETH > > > > Heiko Schocher (5): > > mpc83xx: remove unneeded extern declaration in cpu_init > > powerpc, qe: fix codingstyle issues for drivers/qe > > powerpc, qe: add DTS support for parallel I/O ports > > net, qe: add DM support for QE UEC ethernet > > mpc83xx, keymile boards: enable DM_ETH and add DTS > > > > arch/powerpc/cpu/mpc83xx/Kconfig | 8 + > > arch/powerpc/cpu/mpc83xx/Makefile | 2 + > > arch/powerpc/cpu/mpc83xx/cpu_init.c | 11 +- > > arch/powerpc/cpu/mpc83xx/qe_io.c | 98 +- > > arch/powerpc/dts/Makefile | 8 + > > arch/powerpc/dts/km8309-uboot.dtsi | 33 + > > arch/powerpc/dts/km8321-uboot.dtsi | 67 + > > arch/powerpc/dts/km8321.dtsi | 220 ++++ > > arch/powerpc/dts/km836x-uboot.dtsi | 61 + > > arch/powerpc/dts/km836x.dtsi | 182 +++ > > arch/powerpc/dts/kmcoge5ne-uboot.dtsi | 22 + > > arch/powerpc/dts/kmcoge5ne.dts | 320 +++++ > > arch/powerpc/dts/kmeter1-uboot.dtsi | 42 + > > arch/powerpc/dts/kmeter1.dts | 480 +++++++ > > arch/powerpc/dts/kmopti2.dts | 161 +++ > > arch/powerpc/dts/kmsupc5.dts | 139 ++ > > arch/powerpc/dts/kmsupm5.dts | 129 ++ > > arch/powerpc/dts/kmtegr1.dts | 392 ++++++ > > arch/powerpc/dts/kmtepr2.dts | 142 ++ > > arch/powerpc/dts/kmtuge1.dts | 100 ++ > > arch/powerpc/dts/kmtuxa1.dts | 100 ++ > > board/keymile/km83xx/Kconfig | 17 + > > board/keymile/km83xx/MAINTAINERS | 23 +- > > board/keymile/km83xx/km83xx.c | 64 - > > configs/kmcoge5ne_defconfig | 11 +- > > configs/kmeter1_defconfig | 10 +- > > configs/kmopti2_defconfig | 11 +- > > configs/kmsupx5_defconfig | 10 +- > > configs/kmtegr1_defconfig | 12 +- > > configs/kmtepr2_defconfig | 10 +- > > configs/tuge1_defconfig | 10 +- > > configs/tuxx1_defconfig | 11 +- > > .../soc/fsl/cpm_qe/qe/ucc.txt | 53 + > > drivers/net/Kconfig | 2 + > > drivers/net/Makefile | 1 + > > drivers/net/qe/Kconfig | 9 + > > drivers/net/qe/Makefile | 5 + > > drivers/net/qe/dm_qe_uec.c | 1167 +++++++++++++++++ > > drivers/net/qe/dm_qe_uec.h | 22 + > > drivers/net/qe/dm_qe_uec_phy.c | 163 +++ > > drivers/net/qe/uccf.c | 507 +++++++ > > drivers/net/qe/uccf.h | 119 ++ > > drivers/net/qe/uec.h | 693 ++++++++++ > > drivers/pinctrl/Kconfig | 7 + > > drivers/pinctrl/Makefile | 1 + > > drivers/pinctrl/pinctrl-qe-io.c | 255 ++++ > > drivers/qe/qe.c | 96 +- > > drivers/qe/uccf.c | 449 ++++--- > > drivers/qe/uccf.h | 90 +- > > drivers/qe/uec.c | 598 ++++----- > > drivers/qe/uec.h | 381 +++--- > > drivers/qe/uec_phy.c | 334 ++--- > > drivers/qe/uec_phy.h | 71 +- > > include/configs/km/km-mpc832x.h | 14 - > > include/configs/km/km-mpc8360.h | 14 - > > include/configs/km/km-mpc83xx.h | 10 - > > include/fsl_qe.h | 3 + > > 57 files changed, 6826 insertions(+), 1144 deletions(-) > > create mode 100644 arch/powerpc/dts/km8309-uboot.dtsi > > create mode 100644 arch/powerpc/dts/km8321-uboot.dtsi > > create mode 100644 arch/powerpc/dts/km8321.dtsi > > create mode 100644 arch/powerpc/dts/km836x-uboot.dtsi > > create mode 100644 arch/powerpc/dts/km836x.dtsi > > create mode 100644 arch/powerpc/dts/kmcoge5ne-uboot.dtsi > > create mode 100644 arch/powerpc/dts/kmcoge5ne.dts > > create mode 100644 arch/powerpc/dts/kmeter1-uboot.dtsi > > create mode 100644 arch/powerpc/dts/kmeter1.dts > > create mode 100644 arch/powerpc/dts/kmopti2.dts > > create mode 100644 arch/powerpc/dts/kmsupc5.dts > > create mode 100644 arch/powerpc/dts/kmsupm5.dts > > create mode 100644 arch/powerpc/dts/kmtegr1.dts > > create mode 100644 arch/powerpc/dts/kmtepr2.dts > > create mode 100644 arch/powerpc/dts/kmtuge1.dts > > create mode 100644 arch/powerpc/dts/kmtuxa1.dts > > create mode 100644 doc/device-tree-bindings/soc/fsl/cpm_qe/qe/ucc.txt > > create mode 100644 drivers/net/qe/Kconfig > > create mode 100644 drivers/net/qe/Makefile > > create mode 100644 drivers/net/qe/dm_qe_uec.c > > create mode 100644 drivers/net/qe/dm_qe_uec.h > > create mode 100644 drivers/net/qe/dm_qe_uec_phy.c > > create mode 100644 drivers/net/qe/uccf.c > > create mode 100644 drivers/net/qe/uccf.h > > create mode 100644 drivers/net/qe/uec.h > > create mode 100644 drivers/pinctrl/pinctrl-qe-io.c > > gentle ping! > > I got no reviews, comments for this patchseries ... > > any comments?
ping?
gentle ping...
On 16/09/2020 07.04, Heiko Schocher wrote:
Hello Mario, Tom,
added Tom to cc ...
Hi Mario,
Hello Mario,
ping?
gentle ping...
We have a mpc8309-based board, currently using a U-Boot based on v2020.04. If you have a git tree I can pull these patches from I'll try to test them on our hardware.
Rasmus
Hello Rasmus,
Am 16.09.2020 um 21:35 schrieb Rasmus Villemoes:
Hello Mario, Tom,
added Tom to cc ...
Hi Mario,
Hello Mario,
ping?
gentle ping...
Pushed them (rebased to next) to:
Thanks!
bye, Heiko
On 17/09/2020 06.24, Heiko Schocher wrote:
Hello Rasmus,
Thanks, it took me a bit longer rebasing our private patches to -next than I thought, but I'm starting to look at those now. The first thing I notice is this:
- u32 pin_2bit_mask; - u32 pin_2bit_dir; - u32 pin_2bit_assign; - u32 pin_1bit_mask; + u32 2bit_mask; + u32 2bit_dir; + u32 2bit_assign; + u32 1bit_mask;
That doesn't compile (can't start identifier with digit), but you fix it up later. Any chance you can make these patches bisectable? Especially a patch that claims to be about fixing coding style shouldn't introduce build errors.
Thanks, Rasmus
Hi Rasmus,
Am 21.09.2020 um 10:40 schrieb Rasmus Villemoes:
Hello Rasmus,
u32 pin_2bit_mask;
u32 pin_2bit_dir;
u32 pin_1bit_mask;
u32 2bit_mask;
u32 2bit_dir;
u32 2bit_assign;
u32 1bit_mask;
Autsch ...
I am sorry about that, but Tom already pulled the patches into next...
bye, Heiko
Hi Heiko
I'm struggling somewhat with getting our mpc8309-derived board converted to DM_ETH. I just get
Net: No ethernet found.
where I used to get
Net: UEC0, UEC1, UEC2
and there's no errors or other diagnostics printed (I've also tried adding #define DEBUG 1 to the .c files under drivers/net/qe/, still nothing).
The board already used OF_CONTROL, so I've tried extending the device-tree based partly on you changes for the km boards, partly from our linux device tree - the two mostly agree:
@@ -25,6 +25,8 @@ i2c0 = &i2c0; i2c1 = &i2c1; spi0 = &spi0; + ethernet0 = &enet0; + ethernet2 = &enet2; };
chosen { @@ -315,6 +317,95 @@ clocks = <&clocks MPC83XX_CLK_SDHC>; clock-names = "per"; }; + + ipic: pic@700 { + compatible = "fsl,ipic"; + interrupt-controller; + #address-cells = <0>; + #interrupt-cells = <2>; + reg = <0x700 0x100>; + device_type = "ipic"; + }; }; -};
+ qe: qe@e0100000 { + #address-cells = <1>; + #size-cells = <1>; + device_type = "qe"; + compatible = "fsl,qe"; + ranges = <0x0 0xe0100000 0x00100000>; + reg = <0xe0100000 0x480>; + brg-frequency = <0>; + bus-frequency = <396000000>; + + muram@10000 { + #address-cells = <1>; + #size-cells = <1>; + compatible = "fsl,qe-muram", "fsl,cpm-muram"; + ranges = <0x0 0x00010000 0x00004000>; + + data-only@0 { + compatible = "fsl,qe-muram-data", + "fsl,cpm-muram-data"; + reg = <0x0 0x4000>; + }; + }; + + qeic: interrupt-controller@80 { + interrupt-controller; + compatible = "fsl,qe-ic"; + #address-cells = <0>; + #interrupt-cells = <1>; + reg = <0x80 0x80>; + big-endian; + interrupts = <32 8 33 8>; + interrupt-parent = <&ipic>; + }; + + enet0: ethernet@2000 { + device_type = "network"; + compatible = "ucc_geth"; + cell-index = <1>; + reg = <0x2000 0x200>; + interrupts = <32>; + interrupt-parent = <&qeic>; + local-mac-address = [ 00 00 00 00 00 00 ]; + rx-clock-name = "clk9"; + tx-clock-name = "clk10"; + fixed-link = <1 1 100 0 0>; + }; + + enet2: ethernet@2200 { + device_type = "network"; + compatible = "ucc_geth"; + cell-index = <3>; + reg = <0x2200 0x200>; + interrupts = <34>; + interrupt-parent = <&qeic>; + local-mac-address = [ 00 00 00 00 00 00 ]; + rx-clock-name = "clk11"; + tx-clock-name = "clk12"; + phy-handle = <&phy1>; + phy-connection-type = "mii"; + }; + + mdio0: mdio@2120 { + #address-cells = <1>; + #size-cells = <0>; + reg = <0x2120 0x18>; + compatible = "fsl,ucc-mdio"; + + phy0: ethernet-phy@00 { + reg = <0x01>; + device_type = "ethernet-phy"; + }; + phy1: ethernet-phy@01 { + reg = <0x02>; + device_type = "ethernet-phy"; + }; + }; + + + }; + +};
The defconfig is updated with
CONFIG_MTD_UBI_FASTMAP_AUTOCONVERT=1 CONFIG_PHYLIB=y CONFIG_PHY_MARVELL=y +CONFIG_DM_ETH=y +CONFIG_DM_MDIO=y +CONFIG_DM_ETH_PHY=y CONFIG_MII=y +CONFIG_QE_UEC=y
and finally I've removed the UEC_ETH definitions from the board config header:
-/* - * Ethernet setup - */ - -/* enable uec ethernet */ -#define CONFIG_UEC_ETH - -/* eth1 */ -#define CONFIG_UEC_ETH1 -#define CONFIG_SYS_UEC1_UCC_NUM 0 -#define CONFIG_SYS_UEC1_RX_CLK QE_CLK9 -#define CONFIG_SYS_UEC1_TX_CLK QE_CLK10 -#define CONFIG_SYS_UEC1_ETH_TYPE FAST_ETH -#define CONFIG_SYS_UEC1_PHY_ADDR 0x11 -#define CONFIG_SYS_UEC1_INTERFACE_TYPE PHY_INTERFACE_MODE_MII -#define CONFIG_SYS_UEC1_INTERFACE_SPEED 100 - -/* eth2 */ -#define CONFIG_UEC_ETH2 -#define CONFIG_SYS_UEC2_UCC_NUM 1 -#define CONFIG_SYS_UEC2_RX_CLK QE_CLK7 -#define CONFIG_SYS_UEC2_TX_CLK QE_CLK8 -#define CONFIG_SYS_UEC2_ETH_TYPE FAST_ETH -#define CONFIG_SYS_UEC2_PHY_ADDR 0x13 -#define CONFIG_SYS_UEC2_INTERFACE_TYPE PHY_INTERFACE_MODE_MII -#define CONFIG_SYS_UEC2_INTERFACE_SPEED 100 - -/* eth3 */ -#define CONFIG_UEC_ETH3 -#define CONFIG_SYS_UEC3_UCC_NUM 2 -#define CONFIG_SYS_UEC3_RX_CLK QE_CLK11 -#define CONFIG_SYS_UEC3_TX_CLK QE_CLK12 -#define CONFIG_SYS_UEC3_ETH_TYPE FAST_ETH -#define CONFIG_SYS_UEC3_PHY_ADDR 0x12 -#define CONFIG_SYS_UEC3_INTERFACE_TYPE PHY_INTERFACE_MODE_MII -#define CONFIG_SYS_UEC3_INTERFACE_SPEED 100 -
I only define two ethernet devices in DT above - the third (middle one) is used for ethercat and irrelevant in U-Boot.
I have not set CONFIG_PINCTRL{,_QE} since our qe_iop_conf_tab is just
const qe_iop_conf_t qe_iop_conf_tab[] = { {0, 0, 0, 0, QE_IOP_TAB_END}, /* END of table */ };
so config_qe_ioports() should be a no-op.
Can you see something obviously wrong with the above, and/or do you have some hints as for what I can do to figure out why the drivers apparently do not pick up the devices from DT? 'dm drivers' does list
ucc_geth 033 eth <none> qe_uec_mdio 051 mdio <none>
Thanks, Rasmus
Hi Rasmus,
Am 22.09.2020 um 16:34 schrieb Rasmus Villemoes:
Hi Heiko
where I used to get
Ok, I currently have no access to the hardware, I wait for the customer to give me access, will take until next week ... so I can only review currently code changes...
BTW: I hope to get daily access, so I can add at least one board to my daily U-Boot tbot tests, see:
http://xeidos.ddns.net/ubtestresults/home
ethernet0 = &enet0;
ethernet2 = &enet2;
chosen {
ipic: pic@700 {
- qe: qe@e0100000 {
#size-cells = <1>;
device_type = "qe";
muram@10000 {
#size-cells = <1>;
data-only@0 {
reg = <0x0 0x4000>;
reg = <0x80 0x80>;
big-endian;
cell-index = <1>;
interrupts = <32>;
cell-index = <3>;
interrupts = <34>;
mdio0: mdio@2120 {
#size-cells = <0>;
reg = <0x01>;
reg = <0x02>;
Does this work with linux? If so, it should be OK....
I miss something like:
https://gitlab.denx.de/u-boot/u-boot/-/commit/7bdfe8592956439743cad3c2d3ff5f...
Important here:
&qe { compatible = "fsl,qe", "simple-bus"; };
Looks good...
- Ethernet setup
Okay...
Here from an old log (mpc8360 based):
=> dm tree^M Class Index Probed Driver Name^M -----------------------------------------------------------^M root 0 [ + ] root_driver root_driver^M simple_bus 0 [ + ] generic_simple_bus |-- soc8360@e0000000^M serial 0 [ + ] ns16550_serial | |-- serial@4500^M pinctrl 0 [ + ] par-io-pinctrl | |-- par_io@1400^M simple_bus 1 [ + ] generic_simple_bus | `-- qe@100000^M eth 0 [ ] ucc_geth | |-- ucc@2000^M eth 1 [ ] ucc_geth | |-- ucc@3000^M eth 2 [ + ] ucc_geth | |-- ucc@3200^M eth 3 [ ] ucc_geth | |-- ucc@2400^M eth 4 [ ] ucc_geth | |-- ucc@3400^M eth 5 [ ] ucc_geth | |-- ucc@2600^M eth 6 [ ] ucc_geth | `-- ucc@3600^M simple_bus 2 [ ] generic_simple_bus `-- localbus@e0005000^M =>
Hmm... hard to say, you may enable debug output in ./drivers/core/root.c
bye, Heiko
On 23/09/2020 07.02, Heiko Schocher wrote:
Hi Rasmus,
Important here:
That helped, thanks. In our linux device tree we just have "fsl,qe", which works because linux has an actual driver for that. Is there a reason you didn't just include the "simple-bus" string in the .dtsi files, instead of fixing it in each .dts that includes the .dtsi?
Looks good...
So, I also added CONFIG_PHY_FIXED, and changed from the deprecated old-style
(which I can't find any U-Boot code that would parse) to the new-style
fixed-link { speed = <100>; full-duplex; };
Perhaps I need to explain a little more about the board: It has a marvell 88e6250 switch, the above fixed-link is from one of the cpu's ethernet devices to the switch's cpu port. In order to get traffic flowing, we used to manually do a few mii commands to instruct the switch to open the cpu port and one specific outwards port, i.e. we have something like
phy1_up=mii write 17 19 3100; mii write 17 18 9620; mii write 19 04 007F cpu_up=mii write 1D 01 0033; mii write 1D 04 007F prep_switch=mii device UEC2; run phy1_up cpu_up ...
So I used to be able to do
=> run prep_switch => ping $serverip UEC: PHY is Fixed PHY (ffffffff) UEC0: Full Duplex UEC0: Speed 100BT UEC0: Link is up Using UEC0 device host 192.168.174.2 is alive
Now, I've updated the prep_switch etc. commands to use "mdio write mdio@2120 ...", and that part I think works - when I run the phy1_up, the link LED does get lit, and using mdio read I can read back both the registers I wrote as well as the switch's identification registers, so I'm pretty sure I'm talking to the right thing. But when I then try the ping command, nothing:
=> ping $serverip ping failed; host 192.168.174.2 is not alive
Any hints?
Thanks, Rasmus
Hello Rasmus,
Am 24.09.2020 um 08:55 schrieb Rasmus Villemoes:
Hi Rasmus,
Important here:
No, seems there is more room for optimizations :-)
Looks good...
Ok!
phy1_up=mii write 17 19 3100; mii write 17 18 9620; mii write 19 04 007F cpu_up=mii write 1D 01 0033; mii write 1D 04 007F > prep_switch=mii device UEC2; run phy1_up cpu_up ...
Why not adding this into a phy driver?
Any hints?
So, you see that your ethernet and so also mdio driver is probed?
Can you post a "dm tree" output?
Without looking onto hardware it is hard to say ... you need to debug into ethernet driver, may compare register setup with old driver....
May a problem with pinsetup? Or clock setup?
bye, Heiko
Hello Rasmus,
just for your information...
I had the chance to test current next branch on the MPC8360 based kmcoge5ne board ... I hope to get this board into my automated testsetup soon...
Here the logs:
U-Boot 2020.10-rc4-00088-gc428a44124-dirty (Sep 30 2020 - 12:06:01 +0200)
Reset Status:
CPU: e300c1, MPC8360A, Rev: 2.1 at 528 MHz, CSB: 264 MHz Model: kmcoge5ne Board: ABB kmcoge5ne with PIGGY. I2C: ready DRAM: 512 MiB (DDR2, 64-bit, ECC off, 264 MHz) POST memory PASSED Flash: 64 MiB NAND: 128 MiB Loading Environment from Flash... OK In: serial@4500 Out: serial@4500 Err: serial@4500 Net: eth0: ucc@3200 Hit <SPACE> key to stop autoboot in 2s =>
=> setenv serverip 192.168.1.2 => setenv ipaddr 192.168.1.1 => bd boot_params = 0x00000000 DRAM bank = 0x00000000 -> start = 0x00000000 -> size = 0x20000000 flashstart = 0xf0000000 flashsize = 0x04000000 flashoffset = 0x00073000 baudrate = 115200 bps relocaddr = 0x1ff83000 reloc off = 0x2ff83000 Build = 32-bit current eth = ucc@3200 ethaddr = 00:e0:df:6e:34:80 IP addr = 192.168.1.1 fdt_blob = 0x1fb7cea0 new_fdt = 0x1fb7cea0 fdt_size = 0x00002000 lmb_dump_all: memory.cnt = 0x1 memory.size = 0x0 memory.reg[0x0].base = 0x0 .size = 0x20000000
reserved.cnt = 0x1 reserved.size = 0x0 reserved.reg[0x0].base = 0x1fb7bb90 .size = 0x484470 busfreq = 264 MHz bootflags = 0x00000000 intfreq = 528 MHz => dm tree Class Index Probed Driver Name ----------------------------------------------------------- root 0 [ + ] root_driver root_driver simple_bus 0 [ + ] simple_bus |-- soc8360@e0000000 serial 0 [ + ] ns16550_serial | |-- serial@4500 pinctrl 0 [ + ] par-io-pinctrl | |-- par_io@1400 simple_bus 1 [ + ] simple_bus | `-- qe@100000 bootcount 0 [ + ] bootcount-mem | |-- bootcount@0x1bff8 eth 0 [ + ] ucc_geth | |-- ucc@3200 mdio 0 [ + ] qe_uec_mdio | `-- mdio@3320 simple_bus 2 [ ] simple_bus `-- localbus@e0005000 => dm dm - Driver model low level access
Usage: dm tree Dump driver model tree ('*' = activated) dm uclass Dump list of instances for each uclass dm devres Dump list of device resources for each device dm drivers Dump list of drivers with uclass and instances dm compat Dump list of drivers with compatibility strings dm static Dump list of drivers with static platform data => dm uclass uclass 0: root 0 * root_driver @ 1fb7f028, seq 0, (req -1)
uclass 23: bootcount 0 * bootcount@0x1bff8 @ 1fb7f2b0, seq 0, (req -1)
uclass 33: eth 0 * ucc@3200 @ 1fb7f338, seq 0, (req 0)
uclass 34: eth_phy_generic uclass 51: mdio 0 * mdio@3320 @ 1fb7f3d0, seq 0, (req -1)
uclass 57: nop uclass 69: pinctrl 0 * par_io@1400 @ 1fb7f1c0, seq 0, (req -1)
uclass 81: serial 0 * serial@4500 @ 1fb7f128, seq 0, (req 0)
uclass 82: simple_bus 0 * soc8360@e0000000 @ 1fb7f0a0, seq 0, (req -1) 1 * qe@100000 @ 1fb7f228, seq 1, (req -1) 2 localbus@e0005000 @ 1fb7f428
=> dm devres => dm drivers Driver uid uclass Devices ---------------------------------------------------------- bootcount-mem 023 bootcount bootcount@0x1bff8 eth_phy_generic_drv 034 eth_phy_generic <none> ucc_geth 033 eth ucc@3200 qe_uec_mdio 051 mdio mdio@3320 ns16550_serial 081 serial serial@4500 par-io-pinctrl 069 pinctrl par_io@1400 root_driver 000 root root_driver simple_bus 082 simple_bus soc8360@e0000000 qe@100000 localbus@e0005000 => dm compat Driver Compatible -------------------------------- bootcount-mem u-boot,bootcount eth_phy_generic_drv ucc_geth ucc_geth qe_uec_mdio fsl,ucc-mdio ns16550_serial ns16550 ns16550a ingenic,jz4780-uart nvidia,tegra20-uart snps,dw-apb-uart par-io-pinctrl fsl,mpc8360-par_io root_driver simple_bus simple-bus simple-mfd => dm static Driver Address --------------------------------- => bd boot_params = 0x00000000 DRAM bank = 0x00000000 -> start = 0x00000000 -> size = 0x20000000 flashstart = 0xf0000000 flashsize = 0x04000000 flashoffset = 0x00073000 baudrate = 115200 bps relocaddr = 0x1ff83000 reloc off = 0x2ff83000 Build = 32-bit current eth = ucc@3200 ethaddr = 00:e0:df:6e:34:80 IP addr = 192.168.1.1 fdt_blob = 0x1fb7cea0 new_fdt = 0x1fb7cea0 fdt_size = 0x00002000 lmb_dump_all: memory.cnt = 0x1 memory.size = 0x0 memory.reg[0x0].base = 0x0 .size = 0x20000000
reserved.cnt = 0x1 reserved.size = 0x0 reserved.reg[0x0].base = 0x1fb7bb90 .size = 0x484470 busfreq = 264 MHz bootflags = 0x00000000 intfreq = 528 MHz => tftp 100000 kmcoge5ne/20200930/u-boot.bin Using ucc@3200 device TFTP from server 192.168.1.2; our IP address is 192.168.1.1 Filename 'kmcoge5ne/20200930/u-boot.bin'. Load address: 0x100000 Loading: ################################# 1.9 MiB/s done Bytes transferred = 475739 (7425b hex) => md 100000 00100000: 04040404 04040404 04040404 04040404 ................ 00100010: 00000000 00000000 86868686 86868686 ................ 00100020: 00000000 00000000 60606060 60606060 ........```````` 00100030: 00000000 00000000 06060606 06060606 ................ 00100040: 27051956 552d426f 6f742032 3032302e '..VU-Boot 2020. 00100050: 31302d72 63342d30 30303838 2d676334 10-rc4-00088-gc4 00100060: 32386134 34313234 2d646972 74792028 28a44124-dirty ( 00100070: 53657020 33302032 30323020 2d203132 Sep 30 2020 - 12 00100080: 3a30363a 3031202b 30323030 29000000 :06:01 +0200)... 00100090: 7ca000a6 60a50030 7ca00124 4c00012c |...`..0|..$L.., 001000a0: 4e800020 7c8802a6 7c6000a6 70600030 N.. |...|`..p`.0 001000b0: 4d820020 7c630078 7c9a03a6 7c7b03a6 M.. |c.x|...|{.. 001000c0: 4c000064 00000000 00000000 00000000 L..d............ 001000d0: 00000000 00000000 00000000 00000000 ................ 001000e0: 00000000 00000000 00000000 00000000 ................ 001000f0: 00000000 00000000 00000000 00000000 ................ => 00100100: 3c80ff40 60000000 7ca000a6 48000005 <..@`...|...H... 00100110: 7ce802a6 3c60e000 60630000 80c40000 |...<`..`c...... 00100120: 4c00012c 90640000 80c70000 4c00012c L..,.d......L.., 00100130: 80c30000 4c00012c 48003041 48003611 ....L..,H.0AH.6. 00100140: 3c80f000 60840000 38a40154 7ca803a6 <...`...8..T|... 00100150: 4e800020 48003645 48003099 7c0004ac N.. H.6EH.0.|... 00100160: 4bffff31 7c0004ac 4800327d 7c0004ac K..1|...H.2}|... 00100170: 4800355d 7c0004ac 3c60e600 60630f00 H.5]|...<`..`c.. 00100180: 38830100 38000000 3884ffff 98040000 8...8...8....... 00100190: 7c032040 4082fff4 3863fc00 906400ac |. @@...8c...d.. 001001a0: 38000000 9403fffc 9403fffc 7c611b78 8...........|a.x 001001b0: 48000005 7d8802a6 800c3654 7d806214 H...}.....6T}.b. 001001c0: 480686f9 7fc802a6 3c60e000 48003bbd H.......<`..H.;. 001001d0: 38600000 48015b95 00000000 00000000 8`..H.[......... 001001e0: 00000000 00000000 00000000 00000000 ................ 001001f0: 00000000 00000000 00000000 00000000 ................ =>
bye, Heiko
Heiko Schocher
Rasmus Villemoes
