[U-Boot] [PATCH-v2] at91sam9261ek: make operational again
Since U-boot v2010.12 the support for the at91sam9261ek board is broken. This patch solves this issue. This change has been tested on this board.
Note: It requires that the 1st stage bootloader (like Atmel at91-bootstrap) to load U-boot at a different address compared to previous releases of U-boot due to conflicts in the BSS area during relocation. (0x23f00000 -> -0x23e00000)
Signed-off-by: Remy Bohmer linux@bohmer.net --- V2: Reworked comments from Albert ARIBAUD: - Do not replace constants by SZ_ constants - Do not move $(SOBJS) in Makefile
board/atmel/at91sam9261ek/Makefile | 6 +++--- board/atmel/at91sam9261ek/at91sam9261ek.c | 7 ++++--- board/atmel/at91sam9261ek/config.mk | 1 - include/configs/at91sam9261ek.h | 21 ++++++++++++++++++--- 4 files changed, 25 insertions(+), 10 deletions(-) delete mode 100644 board/atmel/at91sam9261ek/config.mk
diff --git a/board/atmel/at91sam9261ek/Makefile b/board/atmel/at91sam9261ek/Makefile index 9d20ba0..3351493 100644 --- a/board/atmel/at91sam9261ek/Makefile +++ b/board/atmel/at91sam9261ek/Makefile @@ -29,13 +29,13 @@ include $(TOPDIR)/config.mk
LIB = $(obj)lib$(BOARD).o
-COBJS-y += at91sam9261ek.o +COBJS-y += $(BOARD).o COBJS-y += led.o COBJS-$(CONFIG_HAS_DATAFLASH) += partition.o
-SRCS := $(SOBJS:.o=.S) $(COBJS-y:.o=.c) +SRCS := $(SOBJS-y:.o=.S) $(COBJS-y:.o=.c) OBJS := $(addprefix $(obj),$(COBJS-y)) -SOBJS := $(addprefix $(obj),$(SOBJS)) +SOBJS := $(addprefix $(obj),$(SOBJS-y))
$(LIB): $(obj).depend $(OBJS) $(SOBJS) $(call cmd_link_o_target, $(OBJS) $(SOBJS)) diff --git a/board/atmel/at91sam9261ek/at91sam9261ek.c b/board/atmel/at91sam9261ek/at91sam9261ek.c index de5cfae..25c181e 100644 --- a/board/atmel/at91sam9261ek/at91sam9261ek.c +++ b/board/atmel/at91sam9261ek/at91sam9261ek.c @@ -246,7 +246,7 @@ int board_init(void) gd->bd->bi_arch_number = MACH_TYPE_AT91SAM9261EK; #endif /* adress of boot parameters */ - gd->bd->bi_boot_params = PHYS_SDRAM + 0x100; + gd->bd->bi_boot_params = CONFIG_SYS_SDRAM_BASE + 0x100;
at91_serial_hw_init(); #ifdef CONFIG_CMD_NAND @@ -273,8 +273,9 @@ int board_eth_init(bd_t *bis)
int dram_init(void) { - gd->bd->bi_dram[0].start = PHYS_SDRAM; - gd->bd->bi_dram[0].size = PHYS_SDRAM_SIZE; + /* dram_init must store complete ramsize in gd->ram_size */ + gd->ram_size = get_ram_size((volatile long *)CONFIG_SYS_SDRAM_BASE, + CONFIG_SYS_SDRAM_SIZE); return 0; }
diff --git a/board/atmel/at91sam9261ek/config.mk b/board/atmel/at91sam9261ek/config.mk deleted file mode 100644 index e554a45..0000000 --- a/board/atmel/at91sam9261ek/config.mk +++ /dev/null @@ -1 +0,0 @@ -CONFIG_SYS_TEXT_BASE = 0x23f00000 diff --git a/include/configs/at91sam9261ek.h b/include/configs/at91sam9261ek.h index 401478b..b547c04 100644 --- a/include/configs/at91sam9261ek.h +++ b/include/configs/at91sam9261ek.h @@ -39,6 +39,7 @@ #else #define CONFIG_AT91SAM9261 1 /* It's an Atmel AT91SAM9261 SoC*/ #endif +#define CONFIG_AT91FAMILY #define CONFIG_ARCH_CPU_INIT #undef CONFIG_USE_IRQ /* we don't need IRQ/FIQ stuff */
@@ -105,11 +106,21 @@ #define CONFIG_CMD_DHCP 1 #define CONFIG_CMD_NAND 1 #define CONFIG_CMD_USB 1 +#define CONFIG_CMD_CACHE 1
/* SDRAM */ #define CONFIG_NR_DRAM_BANKS 1 -#define PHYS_SDRAM 0x20000000 -#define PHYS_SDRAM_SIZE 0x04000000 /* 64 megs */ +#define CONFIG_SYS_SDRAM_BASE 0x20000000 +#define CONFIG_SYS_SDRAM_SIZE 0x04000000 /* 64 megs */ + +/* + * AT91-bootstrap expects that U-boot needs to be loaded at 0x23f00000 + * but since U-boot is now being relocated to the end of RAM which is + * almost in the same area, there will be an overlap in the BSS segment + * resulting in a lockup during boot. So, we need to tell the + * AT91-bootstrap code to load it at a lower address, namely 0x23e00000 + */ +#define CONFIG_SYS_TEXT_BASE 0x23e00000
/* DataFlash */ #define CONFIG_ATMEL_DATAFLASH_SPI @@ -168,7 +179,7 @@
#define CONFIG_SYS_LOAD_ADDR 0x22000000 /* load address */
-#define CONFIG_SYS_MEMTEST_START PHYS_SDRAM +#define CONFIG_SYS_MEMTEST_START CONFIG_SYS_SDRAM_BASE #define CONFIG_SYS_MEMTEST_END 0x23e00000
#ifdef CONFIG_SYS_USE_DATAFLASH_CS0 @@ -231,6 +242,10 @@ */ #define CONFIG_SYS_MALLOC_LEN ROUND(3 * CONFIG_ENV_SIZE + 128*1024, 0x1000)
+/* size in bytes reserved for initial data */ +#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_SDRAM_BASE + 0x1000 \ + - GENERATED_GBL_DATA_SIZE) + #define CONFIG_STACKSIZE (32*1024) /* regular stack */
#ifdef CONFIG_USE_IRQ
Remy Bohmer
