[PATCH v3 1/2] timer: mpc83xx_timer: fix build with CONFIG_{HW_, }WATCHDOG
The code, which is likely copied from arch/powerpc/lib/interrupts.c, lacks a fallback definition of CONFIG_SYS_WATCHDOG_FREQ and refers to a non-existing timestamp variable - obviously priv->timestamp is meant.
Signed-off-by: Rasmus Villemoes rasmus.villemoes@prevas.dk --- drivers/timer/mpc83xx_timer.c | 6 +++++- 1 file changed, 5 insertions(+), 1 deletion(-)
diff --git a/drivers/timer/mpc83xx_timer.c b/drivers/timer/mpc83xx_timer.c index 72cb58b693..da516c9d74 100644 --- a/drivers/timer/mpc83xx_timer.c +++ b/drivers/timer/mpc83xx_timer.c @@ -16,6 +16,10 @@
DECLARE_GLOBAL_DATA_PTR;
+#ifndef CONFIG_SYS_WATCHDOG_FREQ +#define CONFIG_SYS_WATCHDOG_FREQ (CONFIG_SYS_HZ / 2) +#endif + /** * struct mpc83xx_timer_priv - Private data structure for MPC83xx timer driver * @decrementer_count: Value to which the decrementer register should be re-set @@ -167,7 +171,7 @@ void timer_interrupt(struct pt_regs *regs) priv->timestamp++;
#if defined(CONFIG_WATCHDOG) || defined(CONFIG_HW_WATCHDOG) - if ((timestamp % (CONFIG_SYS_WATCHDOG_FREQ)) == 0) + if ((priv->timestamp % (CONFIG_SYS_WATCHDOG_FREQ)) == 0) WATCHDOG_RESET(); #endif /* CONFIG_WATCHDOG || CONFIG_HW_WATCHDOG */
When using CONFIG_(SPL_)WDT, the watchdog_reset function is a lot more complicated than just poking a few SOC-specific registers - it involves accessing all kinds of global data, and if the interrupt happens at the wrong time (say, in the middle of an WATCHDOG_RESET() call from ordinary code), that can end up corrupting said global data.
Also, having WATCHDOG_RESET() called automatically from the timer interrupt runs counter to the idea of a watchdog device - if the board runs into an infinite loops with interrupts still enabled, the watchdog will never fire.
Allow the board to opt out of this behaviour by setting CONFIG_SYS_WATCHDOG_FREQ to 0 - as that setting is currently nonsensical, it cannot affect any existing boards.
Add documentation for both the existing and extended meaning of CONFIG_SYS_WATCHDOG_FREQ.
Signed-off-by: Rasmus Villemoes rasmus.villemoes@prevas.dk --- README | 9 +++++++++ arch/m68k/lib/time.c | 2 +- arch/powerpc/lib/interrupts.c | 2 +- drivers/timer/mpc83xx_timer.c | 2 +- 4 files changed, 12 insertions(+), 3 deletions(-)
diff --git a/README b/README index 8cfa92fac9..79e8da4adc 100644 --- a/README +++ b/README @@ -768,6 +768,15 @@ The following options need to be configured: SoC, then define this variable and provide board specific code for the "hw_watchdog_reset" function.
+ CONFIG_SYS_WATCHDOG_FREQ + Some platforms automatically call WATCHDOG_RESET() + from the timer interrupt handler every + CONFIG_SYS_WATCHDOG_FREQ interrupts. If not set by the + board configuration file, a default of CONFIG_SYS_HZ/2 + (i.e. 500) is used. Setting CONFIG_SYS_WATCHDOG_FREQ + to 0 disables calling WATCHDOG_RESET() from the timer + interrupt. + - Real-Time Clock:
When CONFIG_CMD_DATE is selected, the type of the RTC diff --git a/arch/m68k/lib/time.c b/arch/m68k/lib/time.c index bde1f4c228..038019ff36 100644 --- a/arch/m68k/lib/time.c +++ b/arch/m68k/lib/time.c @@ -68,7 +68,7 @@ void dtimer_interrupt(void *not_used) timestamp++;
#if defined(CONFIG_WATCHDOG) || defined (CONFIG_HW_WATCHDOG) - if ((timestamp % (CONFIG_SYS_WATCHDOG_FREQ)) == 0) { + if (CONFIG_SYS_WATCHDOG_FREQ && (timestamp % (CONFIG_SYS_WATCHDOG_FREQ)) == 0) { WATCHDOG_RESET (); } #endif /* CONFIG_WATCHDOG || CONFIG_HW_WATCHDOG */ diff --git a/arch/powerpc/lib/interrupts.c b/arch/powerpc/lib/interrupts.c index 64ee0cc210..23ac5bca1e 100644 --- a/arch/powerpc/lib/interrupts.c +++ b/arch/powerpc/lib/interrupts.c @@ -79,7 +79,7 @@ void timer_interrupt(struct pt_regs *regs) timestamp++;
#if defined(CONFIG_WATCHDOG) || defined (CONFIG_HW_WATCHDOG) - if ((timestamp % (CONFIG_SYS_WATCHDOG_FREQ)) == 0) + if (CONFIG_SYS_WATCHDOG_FREQ && (timestamp % (CONFIG_SYS_WATCHDOG_FREQ)) == 0) WATCHDOG_RESET (); #endif /* CONFIG_WATCHDOG || CONFIG_HW_WATCHDOG */
diff --git a/drivers/timer/mpc83xx_timer.c b/drivers/timer/mpc83xx_timer.c index da516c9d74..b85f10ad99 100644 --- a/drivers/timer/mpc83xx_timer.c +++ b/drivers/timer/mpc83xx_timer.c @@ -171,7 +171,7 @@ void timer_interrupt(struct pt_regs *regs) priv->timestamp++;
#if defined(CONFIG_WATCHDOG) || defined(CONFIG_HW_WATCHDOG) - if ((priv->timestamp % (CONFIG_SYS_WATCHDOG_FREQ)) == 0) + if (CONFIG_SYS_WATCHDOG_FREQ && (priv->timestamp % (CONFIG_SYS_WATCHDOG_FREQ)) == 0) WATCHDOG_RESET(); #endif /* CONFIG_WATCHDOG || CONFIG_HW_WATCHDOG */
Dear Rasmus,
Could you _please_ get used to add some patch histroy below this line "---", too? I. e. some information so we can see easily what has changed between patch version and and 2, and between version 2 and 3?
Thanks.
On 20/03/2020 12.22, Wolfgang Denk wrote:
Dear Rasmus,
Sorry about that. When this changed from a single patch to multiple ones I should have prepended a cover letter as well.
FWIW, patch 1/2 is new in v3, while 2/2 has been extended with documentation of both the existing meaning of CONFIG_SYS_WATCHDOG_FREQ as well as the semantics of setting that to 0, while also making it consistent across (the two implementations on) ppc and m68k.
Can I get you to review v3 as is, or should I rebase to master and resend a v4?
Thanks, Rasmus
Rasmus Villemoes
