[U-Boot] [PATCH v2 0/8] x86: quark: Add ACPI support
This series adds basic ACPI support to Intel Quark platform, enables the support on the Intel Galileo board.
Testing was performed by booting Linux kernel from an SD card. All interrupts are routed to I/O APIC based on information provided in the ACPI tables, and typing 'reboot' from shell can successfully reboot to U-Boot.
This series is available at u-boot-x86/quark-acpi.
Changes in v2: - Use __ASSEMBLY__ define - Use __ASSEMBLY__ in device.h
Bin Meng (8): x86: acpi: Create a common irqlinks ASL file x86: acpi: Make irqroute.asl common acpi: Pass -D__ASSEMBLY__ when compiling ASL files x86: quark: Prepare device.h for inclusion by ASL x86: quark: Add platform ASL files x86: quark: Generate ACPI FADT/MADT tables x86: galileo: Enable ACPI table generation x86: baytrail: acpi: Fix I/O APIC ID in the MADT table
arch/x86/cpu/baytrail/acpi.c | 2 +- arch/x86/cpu/quark/Makefile | 1 + arch/x86/cpu/quark/acpi.c | 163 ++++++++++++++++++ .../asm/{arch-baytrail => }/acpi/irq_helper.h | 2 +- .../asm/{arch-baytrail => }/acpi/irqlinks.asl | 33 ++-- .../asm/{arch-baytrail => }/acpi/irqroute.asl | 0 arch/x86/include/asm/arch-baytrail/acpi/lpc.asl | 23 ++- .../asm/arch-baytrail/acpi/southcluster.asl | 2 +- arch/x86/include/asm/arch-quark/acpi/irqroute.h | 15 ++ arch/x86/include/asm/arch-quark/acpi/lpc.asl | 125 ++++++++++++++ arch/x86/include/asm/arch-quark/acpi/platform.asl | 33 ++++ .../include/asm/arch-quark/acpi/sleepstates.asl | 10 ++ .../include/asm/arch-quark/acpi/southcluster.asl | 184 +++++++++++++++++++++ arch/x86/include/asm/arch-quark/device.h | 21 ++- arch/x86/include/asm/arch-quark/iomap.h | 47 ++++++ arch/x86/include/asm/arch-quark/irq.h | 19 +++ board/intel/galileo/.gitignore | 3 + board/intel/galileo/Makefile | 1 + board/intel/galileo/acpi/mainboard.asl | 11 ++ board/intel/galileo/dsdt.asl | 14 ++ configs/galileo_defconfig | 1 + doc/README.x86 | 5 +- scripts/Makefile.lib | 2 +- 23 files changed, 685 insertions(+), 32 deletions(-) create mode 100644 arch/x86/cpu/quark/acpi.c rename arch/x86/include/asm/{arch-baytrail => }/acpi/irq_helper.h (98%) rename arch/x86/include/asm/{arch-baytrail => }/acpi/irqlinks.asl (92%) rename arch/x86/include/asm/{arch-baytrail => }/acpi/irqroute.asl (100%) create mode 100644 arch/x86/include/asm/arch-quark/acpi/irqroute.h create mode 100644 arch/x86/include/asm/arch-quark/acpi/lpc.asl create mode 100644 arch/x86/include/asm/arch-quark/acpi/platform.asl create mode 100644 arch/x86/include/asm/arch-quark/acpi/sleepstates.asl create mode 100644 arch/x86/include/asm/arch-quark/acpi/southcluster.asl create mode 100644 arch/x86/include/asm/arch-quark/iomap.h create mode 100644 arch/x86/include/asm/arch-quark/irq.h create mode 100644 board/intel/galileo/.gitignore create mode 100644 board/intel/galileo/acpi/mainboard.asl create mode 100644 board/intel/galileo/dsdt.asl
Move the irqlinks.asl file currently in the BayTrail directory to a common place to be shared among all x86 platforms. As the PIRQ routing control programming interface is common to Intel chipsets, leave the common part in the common file, and move the platform specific part to the platform files.
Signed-off-by: Bin Meng bmeng.cn@gmail.com Reviewed-by: Simon Glass sjg@chromium.org ---
Changes in v2: None
.../asm/{arch-baytrail => }/acpi/irqlinks.asl | 33 +++++++++------------- arch/x86/include/asm/arch-baytrail/acpi/lpc.asl | 23 ++++++++++++++- 2 files changed, 35 insertions(+), 21 deletions(-) rename arch/x86/include/asm/{arch-baytrail => }/acpi/irqlinks.asl (92%)
diff --git a/arch/x86/include/asm/arch-baytrail/acpi/irqlinks.asl b/arch/x86/include/asm/acpi/irqlinks.asl similarity index 92% rename from arch/x86/include/asm/arch-baytrail/acpi/irqlinks.asl rename to arch/x86/include/asm/acpi/irqlinks.asl index 0affa23..84c1e53 100644 --- a/arch/x86/include/asm/arch-baytrail/acpi/irqlinks.asl +++ b/arch/x86/include/asm/acpi/irqlinks.asl @@ -7,26 +7,19 @@ * SPDX-License-Identifier: GPL-2.0+ */
-Scope () -{ - /* Intel Legacy Block */ - OperationRegion(ILBS, SystemMemory, ILB_BASE_ADDRESS, ILB_BASE_SIZE) - Field(ILBS, AnyAcc, NoLock, Preserve) { - Offset (0x8), - PRTA, 8, - PRTB, 8, - PRTC, 8, - PRTD, 8, - PRTE, 8, - PRTF, 8, - PRTG, 8, - PRTH, 8, - Offset (0x88), - , 3, - UI3E, 1, - UI4E, 1 - } -} +/* + * Intel chipset PIRQ routing control ASL description + * + * The programming interface is common to most Intel chipsets. But the PRTx + * registers may be mapped to different blocks. Some chipsets map them to LPC + * device (00:1f:00) PCI configuration space (like TunnelCreek, Quark), while + * some newer Atom SoCs (like BayTrail, Braswell) map them to Intel Legacy + * Block (ILB) memory space. + * + * This file defines 8 PCI IRQ link devices which corresponds to 8 PIRQ lines + * PIRQ A/B/C/D/E/F/G/H. To incorperate this file, the PRTx registers must be + * defined somewhere else in the platform's ASL files. + */
Device (LNKA) { diff --git a/arch/x86/include/asm/arch-baytrail/acpi/lpc.asl b/arch/x86/include/asm/arch-baytrail/acpi/lpc.asl index 385671c..22f0d68 100644 --- a/arch/x86/include/asm/arch-baytrail/acpi/lpc.asl +++ b/arch/x86/include/asm/arch-baytrail/acpi/lpc.asl @@ -10,6 +10,27 @@
/* Intel LPC Bus Device - 0:1f.0 */
+Scope () +{ + /* Intel Legacy Block */ + OperationRegion(ILBS, SystemMemory, ILB_BASE_ADDRESS, ILB_BASE_SIZE) + Field(ILBS, AnyAcc, NoLock, Preserve) { + Offset (0x8), + PRTA, 8, + PRTB, 8, + PRTC, 8, + PRTD, 8, + PRTE, 8, + PRTF, 8, + PRTG, 8, + PRTH, 8, + Offset (0x88), + , 3, + UI3E, 1, + UI4E, 1 + } +} + Device (LPCB) { Name(_ADR, 0x001f0000) @@ -23,7 +44,7 @@ Device (LPCB) Offset(0x84) }
- #include "irqlinks.asl" + #include <asm/acpi/irqlinks.asl>
/* Firmware Hub */ Device (FWH)
Changes in v2: None
applied to u-boot-x86, thanks!
The irqroute.asl file is already common enough to all x86 platforms. Platform ASL files need only provide a irqroute.h to describe how internal PCI devices and PCIe downstream port devices' INTx pins are routed to which PIRQ pin.
Changes in v2: None
arch/x86/include/asm/{arch-baytrail => }/acpi/irq_helper.h | 2 +- arch/x86/include/asm/{arch-baytrail => }/acpi/irqroute.asl | 0 arch/x86/include/asm/arch-baytrail/acpi/southcluster.asl | 2 +- 3 files changed, 2 insertions(+), 2 deletions(-) rename arch/x86/include/asm/{arch-baytrail => }/acpi/irq_helper.h (98%) rename arch/x86/include/asm/{arch-baytrail => }/acpi/irqroute.asl (100%)
diff --git a/arch/x86/include/asm/arch-baytrail/acpi/irq_helper.h b/arch/x86/include/asm/acpi/irq_helper.h similarity index 98% rename from arch/x86/include/asm/arch-baytrail/acpi/irq_helper.h rename to arch/x86/include/asm/acpi/irq_helper.h index 2c3585a..f0b3a6b 100644 --- a/arch/x86/include/asm/arch-baytrail/acpi/irq_helper.h +++ b/arch/x86/include/asm/acpi/irq_helper.h @@ -108,4 +108,4 @@ Device (prefix_ ## 0 ## func_) \ }
/* SoC specific PIRQ route configuration */ -#include "irqroute.h" +#include <asm/arch/acpi/irqroute.h> diff --git a/arch/x86/include/asm/arch-baytrail/acpi/irqroute.asl b/arch/x86/include/asm/acpi/irqroute.asl similarity index 100% rename from arch/x86/include/asm/arch-baytrail/acpi/irqroute.asl rename to arch/x86/include/asm/acpi/irqroute.asl diff --git a/arch/x86/include/asm/arch-baytrail/acpi/southcluster.asl b/arch/x86/include/asm/arch-baytrail/acpi/southcluster.asl index 34d3951..e89ff26 100644 --- a/arch/x86/include/asm/arch-baytrail/acpi/southcluster.asl +++ b/arch/x86/include/asm/arch-baytrail/acpi/southcluster.asl @@ -207,5 +207,5 @@ Device (PCI0) #include "xhci.asl"
/* IRQ routing for each PCI device */ - #include "irqroute.asl" + #include <asm/acpi/irqroute.asl> }
Changes in v2: None
ASL files may include various U-Boot header files, but IASL compiler does not understand any C language embedded in these header files. To reuse those header files for ASL compiling, use __ASSEMBLY__ in the header files to exclude everything that is not liked by IASL.
scripts/Makefile.lib | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/scripts/Makefile.lib b/scripts/Makefile.lib index 97a09a2..e720562 100644 --- a/scripts/Makefile.lib +++ b/scripts/Makefile.lib @@ -325,7 +325,7 @@ $(obj)/%.S: $(src)/%.ttf # --------------------------------------------------------------------------- quiet_cmd_acpi_c_asl= ASL $< cmd_acpi_c_asl= \ - $(CPP) -x assembler-with-cpp -P $(UBOOTINCLUDE) -o $<.tmp $<; \ + $(CPP) -x assembler-with-cpp -D__ASSEMBLY__ -P $(UBOOTINCLUDE) -o $<.tmp $<; \ iasl -p $< -tc $<.tmp $(if $(KBUILD_VERBOSE:1=), >/dev/null); \ mv $(patsubst %.asl,%.hex,$<) $@
Changes in v2:
There is a device.h for quark on-chip devices, mainly for definitions of internal PCI device numbers, but it's not ready to be included by ASL files. Update to use hex numbers for PCI dev and __ASSEMBLY__.
Changes in v2: - Use __ASSEMBLY__ in device.h
arch/x86/include/asm/arch-quark/device.h | 21 +++++++++++++++------ 1 file changed, 15 insertions(+), 6 deletions(-)
diff --git a/arch/x86/include/asm/arch-quark/device.h b/arch/x86/include/asm/arch-quark/device.h index 7882f33..4760aa2 100644 --- a/arch/x86/include/asm/arch-quark/device.h +++ b/arch/x86/include/asm/arch-quark/device.h @@ -7,12 +7,17 @@ #ifndef _QUARK_DEVICE_H_ #define _QUARK_DEVICE_H_
-#include <pci.h> +/* + * Internal PCI device numbers within the SoC. + * + * Note it must start with 0x_ prefix, as the device number macro will be + * included in the ACPI ASL files (see irq_helper.h and irq_route.h). + */
-#define QUARK_HOST_BRIDGE_DEV 0 +#define QUARK_HOST_BRIDGE_DEV 0x00 #define QUARK_HOST_BRIDGE_FUNC 0
-#define QUARK_DEV_20 20 +#define QUARK_DEV_20 0x14 #define QUARK_MMC_SDIO_FUNC 0 #define QUARK_UART0_FUNC 1 #define QUARK_USB_DEVICE_FUNC 2 @@ -22,18 +27,21 @@ #define QUARK_EMAC0_FUNC 6 #define QUARK_EMAC1_FUNC 7
-#define QUARK_DEV_21 21 +#define QUARK_DEV_21 0x15 #define QUARK_SPI0_FUNC 0 #define QUARK_SPI1_FUNC 1 #define QUARK_I2C_GPIO_FUNC 2
-#define QUARK_DEV_23 23 +#define QUARK_DEV_23 0x17 #define QUARK_PCIE0_FUNC 0 #define QUARK_PCIE1_FUNC 1
-#define QUARK_LGC_BRIDGE_DEV 31 +#define QUARK_LGC_BRIDGE_DEV 0x1f #define QUARK_LGC_BRIDGE_FUNC 0
+#ifndef __ASSEMBLY__ +#include <pci.h> + #define QUARK_HOST_BRIDGE \ PCI_BDF(0, QUARK_HOST_BRIDGE_DEV, QUARK_HOST_BRIDGE_FUNC) #define QUARK_MMC_SDIO \ @@ -64,5 +72,6 @@ PCI_BDF(0, QUARK_DEV_23, QUARK_PCIE1_FUNC) #define QUARK_LEGACY_BRIDGE \ PCI_BDF(0, QUARK_LGC_BRIDGE_DEV, QUARK_LGC_BRIDGE_FUNC) +#endif /* __ASSEMBLY__ */
#endif /* _QUARK_DEVICE_H_ */
Changes in v2:
This adds basic quark platform ASL files. They are intended to be included in dsdt.asl of any board that is based on this platform.
Changes in v2: None
arch/x86/include/asm/arch-quark/acpi/irqroute.h | 15 ++ arch/x86/include/asm/arch-quark/acpi/lpc.asl | 125 ++++++++++++++ arch/x86/include/asm/arch-quark/acpi/platform.asl | 33 ++++ .../include/asm/arch-quark/acpi/sleepstates.asl | 10 ++ .../include/asm/arch-quark/acpi/southcluster.asl | 184 +++++++++++++++++++++ arch/x86/include/asm/arch-quark/iomap.h | 47 ++++++ arch/x86/include/asm/arch-quark/irq.h | 19 +++ 7 files changed, 433 insertions(+) create mode 100644 arch/x86/include/asm/arch-quark/acpi/irqroute.h create mode 100644 arch/x86/include/asm/arch-quark/acpi/lpc.asl create mode 100644 arch/x86/include/asm/arch-quark/acpi/platform.asl create mode 100644 arch/x86/include/asm/arch-quark/acpi/sleepstates.asl create mode 100644 arch/x86/include/asm/arch-quark/acpi/southcluster.asl create mode 100644 arch/x86/include/asm/arch-quark/iomap.h create mode 100644 arch/x86/include/asm/arch-quark/irq.h
diff --git a/arch/x86/include/asm/arch-quark/acpi/irqroute.h b/arch/x86/include/asm/arch-quark/acpi/irqroute.h new file mode 100644 index 0000000..5ba31da --- /dev/null +++ b/arch/x86/include/asm/arch-quark/acpi/irqroute.h @@ -0,0 +1,15 @@ +/* + * Copyright (C) 2016, Bin Meng bmeng.cn@gmail.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <asm/arch/device.h> + +#define PCI_DEV_PIRQ_ROUTES \ + PCI_DEV_PIRQ_ROUTE(QUARK_DEV_20, E, F, G, H), \ + PCI_DEV_PIRQ_ROUTE(QUARK_DEV_21, E, F, G, H), \ + PCI_DEV_PIRQ_ROUTE(QUARK_DEV_23, A, B, C, D) + +#define PCIE_BRIDGE_IRQ_ROUTES \ + PCIE_BRIDGE_DEV(RP, QUARK_DEV_23, A, B, C, D) diff --git a/arch/x86/include/asm/arch-quark/acpi/lpc.asl b/arch/x86/include/asm/arch-quark/acpi/lpc.asl new file mode 100644 index 0000000..c3b0b1d --- /dev/null +++ b/arch/x86/include/asm/arch-quark/acpi/lpc.asl @@ -0,0 +1,125 @@ +/* + * Copyright (C) 2016, Bin Meng bmeng.cn@gmail.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +/* Intel LPC Bus Device - 0:1f.0 */ + +Device (LPCB) +{ + Name(_ADR, 0x001f0000) + + OperationRegion(PRTX, PCI_Config, 0x60, 8) + Field(PRTX, AnyAcc, NoLock, Preserve) { + PRTA, 8, + PRTB, 8, + PRTC, 8, + PRTD, 8, + PRTE, 8, + PRTF, 8, + PRTG, 8, + PRTH, 8, + } + + #include <asm/acpi/irqlinks.asl> + + /* Firmware Hub */ + Device (FWH) + { + Name(_HID, EISAID("INT0800")) + Name(_CRS, ResourceTemplate() + { + Memory32Fixed(ReadOnly, 0xff000000, 0x01000000) + }) + } + + /* 8259 Interrupt Controller */ + Device (PIC) + { + Name(_HID, EISAID("PNP0000")) + Name(_CRS, ResourceTemplate() + { + IO(Decode16, 0x20, 0x20, 0x01, 0x02) + IO(Decode16, 0x24, 0x24, 0x01, 0x02) + IO(Decode16, 0x28, 0x28, 0x01, 0x02) + IO(Decode16, 0x2c, 0x2c, 0x01, 0x02) + IO(Decode16, 0x30, 0x30, 0x01, 0x02) + IO(Decode16, 0x34, 0x34, 0x01, 0x02) + IO(Decode16, 0x38, 0x38, 0x01, 0x02) + IO(Decode16, 0x3c, 0x3c, 0x01, 0x02) + IO(Decode16, 0xa0, 0xa0, 0x01, 0x02) + IO(Decode16, 0xa4, 0xa4, 0x01, 0x02) + IO(Decode16, 0xa8, 0xa8, 0x01, 0x02) + IO(Decode16, 0xac, 0xac, 0x01, 0x02) + IO(Decode16, 0xb0, 0xb0, 0x01, 0x02) + IO(Decode16, 0xb4, 0xb4, 0x01, 0x02) + IO(Decode16, 0xb8, 0xb8, 0x01, 0x02) + IO(Decode16, 0xbc, 0xbc, 0x01, 0x02) + IO(Decode16, 0x4d0, 0x4d0, 0x01, 0x02) + IRQNoFlags () { 2 } + }) + } + + /* 8254 timer */ + Device (TIMR) + { + Name(_HID, EISAID("PNP0100")) + Name(_CRS, ResourceTemplate() + { + IO(Decode16, 0x40, 0x40, 0x01, 0x04) + IO(Decode16, 0x50, 0x50, 0x10, 0x04) + IRQNoFlags() { 0 } + }) + } + + /* HPET */ + Device (HPET) + { + Name(_HID, EISAID("PNP0103")) + Name(_CID, 0x010CD041) + Name(_CRS, ResourceTemplate() + { + Memory32Fixed(ReadOnly, HPET_BASE_ADDRESS, HPET_BASE_SIZE) + }) + + Method(_STA) + { + Return (STA_VISIBLE) + } + } + + /* Real Time Clock */ + Device (RTC) + { + Name(_HID, EISAID("PNP0B00")) + Name(_CRS, ResourceTemplate() + { + IO(Decode16, 0x70, 0x70, 1, 8) + IRQNoFlags() { 8 } + }) + } + + /* LPC device: Resource consumption */ + Device (LDRC) + { + Name(_HID, EISAID("PNP0C02")) + Name(_UID, 2) + + Name(RBUF, ResourceTemplate() + { + IO(Decode16, 0x61, 0x61, 0x1, 0x01) /* NMI Status */ + IO(Decode16, 0x63, 0x63, 0x1, 0x01) /* CPU Reserved */ + IO(Decode16, 0x65, 0x65, 0x1, 0x01) /* CPU Reserved */ + IO(Decode16, 0x67, 0x67, 0x1, 0x01) /* CPU Reserved */ + IO(Decode16, 0x80, 0x80, 0x1, 0x01) /* Port 80 Post */ + IO(Decode16, 0x92, 0x92, 0x1, 0x01) /* CPU Reserved */ + IO(Decode16, 0xb2, 0xb2, 0x1, 0x02) /* SWSMI */ + }) + + Method(_CRS, 0, NotSerialized) + { + Return (RBUF) + } + } +} diff --git a/arch/x86/include/asm/arch-quark/acpi/platform.asl b/arch/x86/include/asm/arch-quark/acpi/platform.asl new file mode 100644 index 0000000..bd72842 --- /dev/null +++ b/arch/x86/include/asm/arch-quark/acpi/platform.asl @@ -0,0 +1,33 @@ +/* + * Copyright (C) 2016, Bin Meng bmeng.cn@gmail.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <asm/acpi/statdef.asl> +#include <asm/arch/iomap.h> +#include <asm/arch/irq.h> + +/* + * The _PTS method (Prepare To Sleep) is called before the OS is + * entering a sleep state. The sleep state number is passed in Arg0. + */ +Method(_PTS, 1) +{ +} + +/* The _WAK method is called on system wakeup */ +Method(_WAK, 1) +{ + Return (Package() {0, 0}) +} + +/* TODO: add CPU ASL support */ + +Scope (_SB) +{ + #include "southcluster.asl" +} + +/* Chipset specific sleep states */ +#include "sleepstates.asl" diff --git a/arch/x86/include/asm/arch-quark/acpi/sleepstates.asl b/arch/x86/include/asm/arch-quark/acpi/sleepstates.asl new file mode 100644 index 0000000..63c82fa --- /dev/null +++ b/arch/x86/include/asm/arch-quark/acpi/sleepstates.asl @@ -0,0 +1,10 @@ +/* + * Copyright (C) 2016, Bin Meng bmeng.cn@gmail.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +Name(_S0, Package() {0x0, 0x0, 0x0, 0x0}) +Name(_S3, Package() {0x5, 0x0, 0x0, 0x0}) +Name(_S4, Package() {0x6, 0x0, 0x0, 0x0}) +Name(_S5, Package() {0x7, 0x0, 0x0, 0x0}) diff --git a/arch/x86/include/asm/arch-quark/acpi/southcluster.asl b/arch/x86/include/asm/arch-quark/acpi/southcluster.asl new file mode 100644 index 0000000..a89cfaf --- /dev/null +++ b/arch/x86/include/asm/arch-quark/acpi/southcluster.asl @@ -0,0 +1,184 @@ +/* + * Copyright (C) 2016, Bin Meng bmeng.cn@gmail.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +Device (PCI0) +{ + Name(_HID, EISAID("PNP0A08")) /* PCIe */ + Name(_CID, EISAID("PNP0A03")) /* PCI */ + + Name(_ADR, 0) + Name(_BBN, 0) + + Name(MCRS, ResourceTemplate() + { + /* Bus Numbers */ + WordBusNumber(ResourceProducer, MinFixed, MaxFixed, PosDecode, + 0x0000, 0x0000, 0x00ff, 0x0000, 0x0100, , , PB00) + + /* IO Region 0 */ + WordIO(ResourceProducer, MinFixed, MaxFixed, PosDecode, EntireRange, + 0x0000, 0x0000, 0x0cf7, 0x0000, 0x0cf8, , , PI00) + + /* PCI Config Space */ + IO(Decode16, 0x0cf8, 0x0cf8, 0x0001, 0x0008) + + /* IO Region 1 */ + WordIO(ResourceProducer, MinFixed, MaxFixed, PosDecode, EntireRange, + 0x0000, 0x0d00, 0xffff, 0x0000, 0xf300, , , PI01) + + /* VGA memory (0xa0000-0xbffff) */ + DWordMemory(ResourceProducer, PosDecode, MinFixed, MaxFixed, + Cacheable, ReadWrite, + 0x00000000, 0x000a0000, 0x000bffff, 0x00000000, + 0x00020000, , , ASEG) + + /* OPROM reserved (0xc0000-0xc3fff) */ + DWordMemory(ResourceProducer, PosDecode, MinFixed, MaxFixed, + Cacheable, ReadWrite, + 0x00000000, 0x000c0000, 0x000c3fff, 0x00000000, + 0x00004000, , , OPR0) + + /* OPROM reserved (0xc4000-0xc7fff) */ + DWordMemory(ResourceProducer, PosDecode, MinFixed, MaxFixed, + Cacheable, ReadWrite, + 0x00000000, 0x000c4000, 0x000c7fff, 0x00000000, + 0x00004000, , , OPR1) + + /* OPROM reserved (0xc8000-0xcbfff) */ + DWordMemory(ResourceProducer, PosDecode, MinFixed, MaxFixed, + Cacheable, ReadWrite, + 0x00000000, 0x000c8000, 0x000cbfff, 0x00000000, + 0x00004000, , , OPR2) + + /* OPROM reserved (0xcc000-0xcffff) */ + DWordMemory(ResourceProducer, PosDecode, MinFixed, MaxFixed, + Cacheable, ReadWrite, + 0x00000000, 0x000cc000, 0x000cffff, 0x00000000, + 0x00004000, , , OPR3) + + /* OPROM reserved (0xd0000-0xd3fff) */ + DWordMemory(ResourceProducer, PosDecode, MinFixed, MaxFixed, + Cacheable, ReadWrite, + 0x00000000, 0x000d0000, 0x000d3fff, 0x00000000, + 0x00004000, , , OPR4) + + /* OPROM reserved (0xd4000-0xd7fff) */ + DWordMemory(ResourceProducer, PosDecode, MinFixed, MaxFixed, + Cacheable, ReadWrite, + 0x00000000, 0x000d4000, 0x000d7fff, 0x00000000, + 0x00004000, , , OPR5) + + /* OPROM reserved (0xd8000-0xdbfff) */ + DWordMemory(ResourceProducer, PosDecode, MinFixed, MaxFixed, + Cacheable, ReadWrite, + 0x00000000, 0x000d8000, 0x000dbfff, 0x00000000, + 0x00004000, , , OPR6) + + /* OPROM reserved (0xdc000-0xdffff) */ + DWordMemory(ResourceProducer, PosDecode, MinFixed, MaxFixed, + Cacheable, ReadWrite, + 0x00000000, 0x000dc000, 0x000dffff, 0x00000000, + 0x00004000, , , OPR7) + + /* BIOS Extension (0xe0000-0xe3fff) */ + DWordMemory(ResourceProducer, PosDecode, MinFixed, MaxFixed, + Cacheable, ReadWrite, + 0x00000000, 0x000e0000, 0x000e3fff, 0x00000000, + 0x00004000, , , ESG0) + + /* BIOS Extension (0xe4000-0xe7fff) */ + DWordMemory(ResourceProducer, PosDecode, MinFixed, MaxFixed, + Cacheable, ReadWrite, + 0x00000000, 0x000e4000, 0x000e7fff, 0x00000000, + 0x00004000, , , ESG1) + + /* BIOS Extension (0xe8000-0xebfff) */ + DWordMemory(ResourceProducer, PosDecode, MinFixed, MaxFixed, + Cacheable, ReadWrite, + 0x00000000, 0x000e8000, 0x000ebfff, 0x00000000, + 0x00004000, , , ESG2) + + /* BIOS Extension (0xec000-0xeffff) */ + DWordMemory(ResourceProducer, PosDecode, MinFixed, MaxFixed, + Cacheable, ReadWrite, + 0x00000000, 0x000ec000, 0x000effff, 0x00000000, + 0x00004000, , , ESG3) + + /* System BIOS (0xf0000-0xfffff) */ + DWordMemory(ResourceProducer, PosDecode, MinFixed, MaxFixed, + Cacheable, ReadWrite, + 0x00000000, 0x000f0000, 0x000fffff, 0x00000000, + 0x00010000, , , FSEG) + + /* PCI Memory Region (TOLM-CONFIG_MMCONF_BASE_ADDRESS) */ + DWordMemory(ResourceProducer, PosDecode, MinFixed, MaxFixed, + Cacheable, ReadWrite, + 0x00000000, 0x00000000, 0x00000000, 0x00000000, + 0x00000000, , , PMEM) + }) + + Method(_CRS, 0, Serialized) + { + /* Update PCI resource area */ + CreateDwordField(MCRS, ^PMEM._MIN, PMIN) + CreateDwordField(MCRS, ^PMEM._MAX, PMAX) + CreateDwordField(MCRS, ^PMEM._LEN, PLEN) + + /* + * Hardcode TOLM to 2GB for now (see DRAM_MAX_SIZE in quark.h) + * + * TODO: for generic usage, read TOLM value from register, or + * from global NVS (not implemented by U-Boot yet). + */ + Store(0x80000000, PMIN) + Store(Subtract(MCFG_BASE_ADDRESS, 1), PMAX) + Add(Subtract(PMAX, PMIN), 1, PLEN) + + Return (MCRS) + } + + /* Device Resource Consumption */ + Device (PDRC) + { + Name(_HID, EISAID("PNP0C02")) + Name(_UID, 1) + + Name(PDRS, ResourceTemplate() { + Memory32Fixed(ReadWrite, CONFIG_ESRAM_BASE, 0x80000) + Memory32Fixed(ReadWrite, MCFG_BASE_ADDRESS, MCFG_BASE_SIZE) + Memory32Fixed(ReadWrite, RCBA_BASE_ADDRESS, RCBA_BASE_SIZE) + IO(Decode16, SPI_DMA_BASE_ADDRESS, SPI_DMA_BASE_ADDRESS, 0x0010, SPI_DMA_BASE_SIZE) + IO(Decode16, GPIO_BASE_ADDRESS, GPIO_BASE_ADDRESS, 0x0080, GPIO_BASE_SIZE) + IO(Decode16, WDT_BASE_ADDRESS, WDT_BASE_ADDRESS, 0x0040, WDT_BASE_SIZE) + }) + + /* Current Resource Settings */ + Method(_CRS, 0, Serialized) + { + Return (PDRS) + } + } + + Method(_OSC, 4) + { + /* Check for proper GUID */ + If (LEqual(Arg0, ToUUID("33DB4D5B-1FF7-401C-9657-7441C03DD766"))) { + /* Let OS control everything */ + Return (Arg3) + } Else { + /* Unrecognized UUID */ + CreateDWordField(Arg3, 0, CDW1) + Or(CDW1, 4, CDW1) + Return (Arg3) + } + } + + /* LPC Bridge 0:1f.0 */ + #include "lpc.asl" + + /* IRQ routing for each PCI device */ + #include <asm/acpi/irqroute.asl> +} diff --git a/arch/x86/include/asm/arch-quark/iomap.h b/arch/x86/include/asm/arch-quark/iomap.h new file mode 100644 index 0000000..fd1ef98 --- /dev/null +++ b/arch/x86/include/asm/arch-quark/iomap.h @@ -0,0 +1,47 @@ +/* + * Copyright (C) 2016 Bin Meng bmeng.cn@gmail.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef _QUARK_IOMAP_H_ +#define _QUARK_IOMAP_H_ + +/* Memory Mapped IO bases */ + +/* ESRAM */ +#define ESRAM_BASE_ADDRESS CONFIG_ESRAM_BASE +#define ESRAM_BASE_SIZE ESRAM_SIZE + +/* PCI Configuration Space */ +#define MCFG_BASE_ADDRESS CONFIG_PCIE_ECAM_BASE +#define MCFG_BASE_SIZE 0x10000000 + +/* High Performance Event Timer */ +#define HPET_BASE_ADDRESS 0xfed00000 +#define HPET_BASE_SIZE 0x400 + +/* Root Complex Base Address */ +#define RCBA_BASE_ADDRESS CONFIG_RCBA_BASE +#define RCBA_BASE_SIZE 0x4000 + +/* IO Port bases */ +#define ACPI_PM1_BASE_ADDRESS CONFIG_ACPI_PM1_BASE +#define ACPI_PM1_BASE_SIZE 0x10 + +#define ACPI_PBLK_BASE_ADDRESS CONFIG_ACPI_PBLK_BASE +#define ACPI_PBLK_BASE_SIZE 0x10 + +#define SPI_DMA_BASE_ADDRESS CONFIG_SPI_DMA_BASE +#define SPI_DMA_BASE_SIZE 0x10 + +#define GPIO_BASE_ADDRESS CONFIG_GPIO_BASE +#define GPIO_BASE_SIZE 0x80 + +#define ACPI_GPE0_BASE_ADDRESS CONFIG_ACPI_GPE0_BASE +#define ACPI_GPE0_BASE_SIZE 0x40 + +#define WDT_BASE_ADDRESS CONFIG_WDT_BASE +#define WDT_BASE_SIZE 0x40 + +#endif /* _QUARK_IOMAP_H_ */ diff --git a/arch/x86/include/asm/arch-quark/irq.h b/arch/x86/include/asm/arch-quark/irq.h new file mode 100644 index 0000000..21e6830 --- /dev/null +++ b/arch/x86/include/asm/arch-quark/irq.h @@ -0,0 +1,19 @@ +/* + * Copyright (C) 2016 Bin Meng bmeng.cn@gmail.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef _QUARK_IRQ_H_ +#define _QUARK_IRQ_H_ + +#define PIRQA_APIC_IRQ 16 +#define PIRQB_APIC_IRQ 17 +#define PIRQC_APIC_IRQ 18 +#define PIRQD_APIC_IRQ 19 +#define PIRQE_APIC_IRQ 20 +#define PIRQF_APIC_IRQ 21 +#define PIRQG_APIC_IRQ 22 +#define PIRQH_APIC_IRQ 23 + +#endif /* _QUARK_IRQ_H_ */
Changes in v2: None
Generate quark platform-specific FADT/MADT tables.
Changes in v2: None
arch/x86/cpu/quark/Makefile | 1 + arch/x86/cpu/quark/acpi.c | 163 ++++++++++++++++++++++++++++++++++++++++++++ 2 files changed, 164 insertions(+) create mode 100644 arch/x86/cpu/quark/acpi.c
diff --git a/arch/x86/cpu/quark/Makefile b/arch/x86/cpu/quark/Makefile index 6d670d7..93ce412 100644 --- a/arch/x86/cpu/quark/Makefile +++ b/arch/x86/cpu/quark/Makefile @@ -6,3 +6,4 @@
obj-y += car.o dram.o irq.o msg_port.o quark.o obj-y += mrc.o mrc_util.o hte.o smc.o +obj-$(CONFIG_GENERATE_ACPI_TABLE) += acpi.o diff --git a/arch/x86/cpu/quark/acpi.c b/arch/x86/cpu/quark/acpi.c new file mode 100644 index 0000000..8f69829 --- /dev/null +++ b/arch/x86/cpu/quark/acpi.c @@ -0,0 +1,163 @@ +/* + * Copyright (C) 2016, Bin Meng bmeng.cn@gmail.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/acpi_table.h> +#include <asm/ioapic.h> +#include <asm/mpspec.h> +#include <asm/tables.h> +#include <asm/arch/iomap.h> + +void acpi_create_fadt(struct acpi_fadt *fadt, struct acpi_facs *facs, + void *dsdt) +{ + struct acpi_table_header *header = &(fadt->header); + u16 pmbase = ACPI_PM1_BASE_ADDRESS; + + memset((void *)fadt, 0, sizeof(struct acpi_fadt)); + + acpi_fill_header(header, "FACP"); + header->length = sizeof(struct acpi_fadt); + header->revision = 4; + + fadt->firmware_ctrl = (u32)facs; + fadt->dsdt = (u32)dsdt; + fadt->preferred_pm_profile = ACPI_PM_UNSPECIFIED; + fadt->sci_int = 9; + fadt->smi_cmd = 0; + fadt->acpi_enable = 0; + fadt->acpi_disable = 0; + fadt->s4bios_req = 0; + fadt->pstate_cnt = 0; + fadt->pm1a_evt_blk = pmbase; + fadt->pm1b_evt_blk = 0x0; + fadt->pm1a_cnt_blk = pmbase + 0x4; + fadt->pm1b_cnt_blk = 0x0; + fadt->pm2_cnt_blk = 0x0; + fadt->pm_tmr_blk = pmbase + 0x8; + fadt->gpe0_blk = ACPI_GPE0_BASE_ADDRESS; + fadt->gpe1_blk = 0; + fadt->pm1_evt_len = 4; + fadt->pm1_cnt_len = 2; + fadt->pm2_cnt_len = 0; + fadt->pm_tmr_len = 4; + fadt->gpe0_blk_len = 8; + fadt->gpe1_blk_len = 0; + fadt->gpe1_base = 0; + fadt->cst_cnt = 0; + fadt->p_lvl2_lat = ACPI_FADT_C2_NOT_SUPPORTED; + fadt->p_lvl3_lat = ACPI_FADT_C3_NOT_SUPPORTED; + fadt->flush_size = 0; + fadt->flush_stride = 0; + fadt->duty_offset = 1; + fadt->duty_width = 3; + fadt->day_alrm = 0x00; + fadt->mon_alrm = 0x00; + fadt->century = 0x00; + fadt->iapc_boot_arch = ACPI_FADT_LEGACY_DEVICES; + fadt->flags = ACPI_FADT_WBINVD | ACPI_FADT_C1_SUPPORTED | + ACPI_FADT_POWER_BUTTON | ACPI_FADT_SLEEP_BUTTON | + ACPI_FADT_S4_RTC_WAKE | ACPI_FADT_RESET_REGISTER | + ACPI_FADT_PLATFORM_CLOCK; + + fadt->reset_reg.space_id = ACPI_ADDRESS_SPACE_IO; + fadt->reset_reg.bit_width = 8; + fadt->reset_reg.bit_offset = 0; + fadt->reset_reg.access_size = ACPI_ACCESS_SIZE_BYTE_ACCESS; + fadt->reset_reg.addrl = IO_PORT_RESET; + fadt->reset_reg.addrh = 0; + fadt->reset_value = SYS_RST | RST_CPU; + + fadt->x_firmware_ctl_l = (u32)facs; + fadt->x_firmware_ctl_h = 0; + fadt->x_dsdt_l = (u32)dsdt; + fadt->x_dsdt_h = 0; + + fadt->x_pm1a_evt_blk.space_id = ACPI_ADDRESS_SPACE_IO; + fadt->x_pm1a_evt_blk.bit_width = fadt->pm1_evt_len * 8; + fadt->x_pm1a_evt_blk.bit_offset = 0; + fadt->x_pm1a_evt_blk.access_size = ACPI_ACCESS_SIZE_DWORD_ACCESS; + fadt->x_pm1a_evt_blk.addrl = fadt->pm1a_evt_blk; + fadt->x_pm1a_evt_blk.addrh = 0x0; + + fadt->x_pm1b_evt_blk.space_id = ACPI_ADDRESS_SPACE_IO; + fadt->x_pm1b_evt_blk.bit_width = 0; + fadt->x_pm1b_evt_blk.bit_offset = 0; + fadt->x_pm1b_evt_blk.access_size = 0; + fadt->x_pm1b_evt_blk.addrl = 0x0; + fadt->x_pm1b_evt_blk.addrh = 0x0; + + fadt->x_pm1a_cnt_blk.space_id = ACPI_ADDRESS_SPACE_IO; + fadt->x_pm1a_cnt_blk.bit_width = fadt->pm1_cnt_len * 8; + fadt->x_pm1a_cnt_blk.bit_offset = 0; + fadt->x_pm1a_cnt_blk.access_size = ACPI_ACCESS_SIZE_WORD_ACCESS; + fadt->x_pm1a_cnt_blk.addrl = fadt->pm1a_cnt_blk; + fadt->x_pm1a_cnt_blk.addrh = 0x0; + + fadt->x_pm1b_cnt_blk.space_id = ACPI_ADDRESS_SPACE_IO; + fadt->x_pm1b_cnt_blk.bit_width = 0; + fadt->x_pm1b_cnt_blk.bit_offset = 0; + fadt->x_pm1b_cnt_blk.access_size = 0; + fadt->x_pm1b_cnt_blk.addrl = 0x0; + fadt->x_pm1b_cnt_blk.addrh = 0x0; + + fadt->x_pm2_cnt_blk.space_id = ACPI_ADDRESS_SPACE_IO; + fadt->x_pm2_cnt_blk.bit_width = fadt->pm2_cnt_len * 8; + fadt->x_pm2_cnt_blk.bit_offset = 0; + fadt->x_pm2_cnt_blk.access_size = ACPI_ACCESS_SIZE_BYTE_ACCESS; + fadt->x_pm2_cnt_blk.addrl = fadt->pm2_cnt_blk; + fadt->x_pm2_cnt_blk.addrh = 0x0; + + fadt->x_pm_tmr_blk.space_id = ACPI_ADDRESS_SPACE_IO; + fadt->x_pm_tmr_blk.bit_width = fadt->pm_tmr_len * 8; + fadt->x_pm_tmr_blk.bit_offset = 0; + fadt->x_pm_tmr_blk.access_size = ACPI_ACCESS_SIZE_DWORD_ACCESS; + fadt->x_pm_tmr_blk.addrl = fadt->pm_tmr_blk; + fadt->x_pm_tmr_blk.addrh = 0x0; + + fadt->x_gpe0_blk.space_id = ACPI_ADDRESS_SPACE_IO; + fadt->x_gpe0_blk.bit_width = fadt->gpe0_blk_len * 8; + fadt->x_gpe0_blk.bit_offset = 0; + fadt->x_gpe0_blk.access_size = ACPI_ACCESS_SIZE_DWORD_ACCESS; + fadt->x_gpe0_blk.addrl = fadt->gpe0_blk; + fadt->x_gpe0_blk.addrh = 0x0; + + fadt->x_gpe1_blk.space_id = ACPI_ADDRESS_SPACE_IO; + fadt->x_gpe1_blk.bit_width = 0; + fadt->x_gpe1_blk.bit_offset = 0; + fadt->x_gpe1_blk.access_size = 0; + fadt->x_gpe1_blk.addrl = 0x0; + fadt->x_gpe1_blk.addrh = 0x0; + + header->checksum = table_compute_checksum(fadt, header->length); +} + +static int acpi_create_madt_irq_overrides(u32 current) +{ + struct acpi_madt_irqoverride *irqovr; + u16 sci_flags = MP_IRQ_TRIGGER_LEVEL | MP_IRQ_POLARITY_HIGH; + int length = 0; + + irqovr = (void *)current; + length += acpi_create_madt_irqoverride(irqovr, 0, 0, 2, 0); + + irqovr = (void *)(current + length); + length += acpi_create_madt_irqoverride(irqovr, 0, 9, 9, sci_flags); + + return length; +} + +u32 acpi_fill_madt(u32 current) +{ + current += acpi_create_madt_lapics(current); + + current += acpi_create_madt_ioapic((struct acpi_madt_ioapic *)current, + io_apic_read(IO_APIC_ID) >> 24, IO_APIC_ADDR, 0); + + current += acpi_create_madt_irq_overrides(current); + + return current; +}
Changes in v2: None
Enable ACPI table generation by creating a DSDT table.
Changes in v2: None
board/intel/galileo/.gitignore | 3 +++ board/intel/galileo/Makefile | 1 + board/intel/galileo/acpi/mainboard.asl | 11 +++++++++++ board/intel/galileo/dsdt.asl | 14 ++++++++++++++ configs/galileo_defconfig | 1 + doc/README.x86 | 5 ++++- 6 files changed, 34 insertions(+), 1 deletion(-) create mode 100644 board/intel/galileo/.gitignore create mode 100644 board/intel/galileo/acpi/mainboard.asl create mode 100644 board/intel/galileo/dsdt.asl
diff --git a/board/intel/galileo/.gitignore b/board/intel/galileo/.gitignore new file mode 100644 index 0000000..6eb8a54 --- /dev/null +++ b/board/intel/galileo/.gitignore @@ -0,0 +1,3 @@ +dsdt.aml +dsdt.asl.tmp +dsdt.c diff --git a/board/intel/galileo/Makefile b/board/intel/galileo/Makefile index 8356df1..bbe2f8b 100644 --- a/board/intel/galileo/Makefile +++ b/board/intel/galileo/Makefile @@ -5,3 +5,4 @@ #
obj-y += galileo.o start.o +obj-$(CONFIG_GENERATE_ACPI_TABLE) += dsdt.o diff --git a/board/intel/galileo/acpi/mainboard.asl b/board/intel/galileo/acpi/mainboard.asl new file mode 100644 index 0000000..21785ea --- /dev/null +++ b/board/intel/galileo/acpi/mainboard.asl @@ -0,0 +1,11 @@ +/* + * Copyright (C) 2016, Bin Meng bmeng.cn@gmail.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +/* Power Button */ +Device (PWRB) +{ + Name(_HID, EISAID("PNP0C0C")) +} diff --git a/board/intel/galileo/dsdt.asl b/board/intel/galileo/dsdt.asl new file mode 100644 index 0000000..6042011 --- /dev/null +++ b/board/intel/galileo/dsdt.asl @@ -0,0 +1,14 @@ +/* + * Copyright (C) 2016, Bin Meng bmeng.cn@gmail.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +DefinitionBlock("dsdt.aml", "DSDT", 2, "U-BOOT", "U-BOOTBL", 0x00010000) +{ + /* platform specific */ + #include <asm/arch/acpi/platform.asl> + + /* board specific */ + #include "acpi/mainboard.asl" +} diff --git a/configs/galileo_defconfig b/configs/galileo_defconfig index f8d3c3b..080c2ed 100644 --- a/configs/galileo_defconfig +++ b/configs/galileo_defconfig @@ -5,6 +5,7 @@ CONFIG_TARGET_GALILEO=y CONFIG_ENABLE_MRC_CACHE=y CONFIG_GENERATE_PIRQ_TABLE=y CONFIG_GENERATE_MP_TABLE=y +CONFIG_GENERATE_ACPI_TABLE=y CONFIG_FIT=y CONFIG_BOOTSTAGE=y CONFIG_BOOTSTAGE_REPORT=y diff --git a/doc/README.x86 b/doc/README.x86 index 4d50feb..a548b54 100644 --- a/doc/README.x86 +++ b/doc/README.x86 @@ -1028,12 +1028,15 @@ Features that are optional: those legacy stuff into U-Boot. ACPI spec allows a system that does not support SMI (a legacy-free system).
-So far ACPI is enabled on BayTrail based boards. Testing was done by booting +ACPI was initially enabled on BayTrail based boards. Testing was done by booting a pre-installed Ubuntu 14.04 from a SATA drive. Installing Ubuntu 14.04 and Windows 8.1/10 to a SATA drive and booting from there is also tested. Most devices seem to work correctly and the board can respond a reboot/shutdown command from the OS.
+For other platform boards, ACPI support status can be checked by examining their +board defconfig files to see if CONFIG_GENERATE_ACPI_TABLE is set to y. + TODO List --------- - Audio
Changes in v2: None
So far this is hardcoded to 2, but it should really be read from the I/O APIC register.
Changes in v2: None
arch/x86/cpu/baytrail/acpi.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/x86/cpu/baytrail/acpi.c b/arch/x86/cpu/baytrail/acpi.c index 1d54f7d..5ee4868 100644 --- a/arch/x86/cpu/baytrail/acpi.c +++ b/arch/x86/cpu/baytrail/acpi.c @@ -155,7 +155,7 @@ u32 acpi_fill_madt(u32 current) current += acpi_create_madt_lapics(current);
current += acpi_create_madt_ioapic((struct acpi_madt_ioapic *)current, - 2, IO_APIC_ADDR, 0); + io_apic_read(IO_APIC_ID) >> 24, IO_APIC_ADDR, 0);
Changes in v2: None
Bin Meng
