[U-Boot] [v3] mmc: fsl_esdhc: set Abort command type for CMD12
According to SD spec, CMD12, CMD52 for writing I/O abort in CCCR need to be set an Abort command type when they are sent. So, we remove all chip-specific #ifdefs and make it available for all platforms.
Signed-off-by: Yangbo Lu yangbo.lu@nxp.com --- Changes for v2: - Removed fix for T4160 because other patch had done that Changes for v3: - Removed all #ifdefs --- drivers/mmc/fsl_esdhc.c | 5 +---- 1 file changed, 1 insertion(+), 4 deletions(-)
diff --git a/drivers/mmc/fsl_esdhc.c b/drivers/mmc/fsl_esdhc.c index c5054d6..f78dcc2 100644 --- a/drivers/mmc/fsl_esdhc.c +++ b/drivers/mmc/fsl_esdhc.c @@ -105,12 +105,9 @@ static uint esdhc_xfertyp(struct mmc_cmd *cmd, struct mmc_data *data) else if (cmd->resp_type & MMC_RSP_PRESENT) xfertyp |= XFERTYP_RSPTYP_48;
-#if defined(CONFIG_MX53) || defined(CONFIG_PPC_T4240) || \ - defined(CONFIG_LS102XA) || defined(CONFIG_FSL_LAYERSCAPE) || \ - defined(CONFIG_PPC_T4160) if (cmd->cmdidx == MMC_CMD_STOP_TRANSMISSION) xfertyp |= XFERTYP_CMDTYP_ABORT; -#endif + return XFERTYP_CMD(cmd->cmdidx) | xfertyp; }
Changes for v2:
Changes for v3:
Applied to u-boot-fsl-qoriq master. Awaiting upstream.
Thanks.
York
Yangbo Lu
york sun
