[PATCH v2 0/7] SPL fixes for STM32F7 MCUs
This series is fixing issues in SPL boot mode: - SPL binary size over 0x8000 bytes for STM32F746-disco, STM32F769-DISCO and STM32746G-EVAL boards - fix embedded flash size for STM32F769-DISCO - fix CONFIG_SYS_SPL_ARGS_ADDR for STM32F746-DISCO and STM32746G-EVAL
Changes in v2: - Remove SYS_UBOOT_FLAG from stm32f746-disco.h
Patrice Chotard (7): configs: stm32f746-disco: Fix SPL boot configs: stm32f769-disco: Fix SPL boot configs: stm32746g-eval: Fix SPL boot configs: stm32f746-disco: Fix CONFIG_SYS_SPL_ARGS_ADDR configs: stm32746g-eval: Fix CONFIG_SYS_SPL_ARGS_ADDR config: stm32f769-disco: Fix internal flash size configs: stm32f746-disco: Remove CONFIG_SYS_UBOOT_START flag
arch/arm/include/asm/arch-stm32f7/stm32.h | 6 +++--- configs/stm32746g-eval_spl_defconfig | 9 +++++---- configs/stm32f746-disco_spl_defconfig | 9 +++++---- configs/stm32f769-disco_defconfig | 2 +- configs/stm32f769-disco_spl_defconfig | 9 +++++---- include/configs/stm32f746-disco.h | 1 - 6 files changed, 19 insertions(+), 17 deletions(-)
Commit 'b4b9a00ed593 ("Convert CONFIG_SYS_SPL_ARGS_ADDR to Kconfig")' replaces CONFIG_SYS_FDT_BASE by CONFIG_SYS_SPL_ARGS_ADDR. As CONFIG_SYS_SPL_ARGS_ADDR enables additional code when enable, it increases SPL size over the initial 0x8000 limit. Increase the SPL size to 0x9000 to fix SPL boot. Set SPL_SIZE_LIMIT to 0x9000 to avoid similar issue in the future.
Fixes 'b4b9a00ed593 ("Convert CONFIG_SYS_SPL_ARGS_ADDR to Kconfig")'
Signed-off-by: Patrice Chotard patrice.chotard@foss.st.com ---
(no changes since v1)
configs/stm32f746-disco_spl_defconfig | 7 ++++--- 1 file changed, 4 insertions(+), 3 deletions(-)
diff --git a/configs/stm32f746-disco_spl_defconfig b/configs/stm32f746-disco_spl_defconfig index e7b1acc433..5e8a8aaf3c 100644 --- a/configs/stm32f746-disco_spl_defconfig +++ b/configs/stm32f746-disco_spl_defconfig @@ -1,6 +1,6 @@ CONFIG_ARM=y CONFIG_ARCH_STM32=y -CONFIG_SYS_TEXT_BASE=0x08008000 +CONFIG_SYS_TEXT_BASE=0x08009000 CONFIG_SYS_MALLOC_LEN=0x100000 CONFIG_SYS_MALLOC_F_LEN=0xE00 CONFIG_SPL_GPIO=y @@ -13,10 +13,11 @@ CONFIG_SPL_TEXT_BASE=0x8000000 CONFIG_SYS_PROMPT="U-Boot > " CONFIG_SPL_SERIAL=y CONFIG_SPL_DRIVERS_MISC=y +CONFIG_SPL_SIZE_LIMIT=0x9000 CONFIG_STM32F7=y CONFIG_TARGET_STM32F746_DISCO=y CONFIG_SPL=y -CONFIG_SYS_LOAD_ADDR=0x8008000 +CONFIG_SYS_LOAD_ADDR=0x8009000 CONFIG_BUILD_TARGET="u-boot-with-spl.bin" CONFIG_DISTRO_DEFAULTS=y CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y @@ -29,7 +30,7 @@ CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200 earlyprintk consoleblank=0 ignore_loglevel" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_BOARD_LATE_INIT=y -CONFIG_SPL_PAD_TO=0x8000 +CONFIG_SPL_PAD_TO=0x9000 CONFIG_SPL_NO_BSS_LIMIT=y CONFIG_SPL_BOARD_INIT=y CONFIG_SPL_SYS_MALLOC_SIMPLE=y
Reviewed-by: Patrick Delaunay patrick.delaunay@foss.st.com
Thanks Patrick
Thanks Patrick
Applied to u-boot-stm32/next
Thanks
configs/stm32f769-disco_spl_defconfig | 7 ++++--- 1 file changed, 4 insertions(+), 3 deletions(-)
diff --git a/configs/stm32f769-disco_spl_defconfig b/configs/stm32f769-disco_spl_defconfig index 19d2c24abb..b56d88f9f6 100644 --- a/configs/stm32f769-disco_spl_defconfig +++ b/configs/stm32f769-disco_spl_defconfig @@ -1,6 +1,6 @@ CONFIG_ARM=y CONFIG_ARCH_STM32=y -CONFIG_SYS_TEXT_BASE=0x08008000 +CONFIG_SYS_TEXT_BASE=0x08009000 CONFIG_SYS_MALLOC_LEN=0x100000 CONFIG_SYS_MALLOC_F_LEN=0xE00 CONFIG_SPL_GPIO=y @@ -13,10 +13,11 @@ CONFIG_SPL_TEXT_BASE=0x8000000 CONFIG_SYS_PROMPT="U-Boot > " CONFIG_SPL_SERIAL=y CONFIG_SPL_DRIVERS_MISC=y +CONFIG_SPL_SIZE_LIMIT=0x9000 CONFIG_STM32F7=y CONFIG_TARGET_STM32F746_DISCO=y CONFIG_SPL=y -CONFIG_SYS_LOAD_ADDR=0x8008000 +CONFIG_SYS_LOAD_ADDR=0x8009000 CONFIG_BUILD_TARGET="u-boot-with-spl.bin" CONFIG_DISTRO_DEFAULTS=y CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y @@ -28,7 +29,7 @@ CONFIG_AUTOBOOT_STOP_STR=" " CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200 earlyprintk consoleblank=0 ignore_loglevel" # CONFIG_DISPLAY_CPUINFO is not set -CONFIG_SPL_PAD_TO=0x8000 +CONFIG_SPL_PAD_TO=0x9000 CONFIG_SPL_NO_BSS_LIMIT=y CONFIG_SPL_BOARD_INIT=y CONFIG_SPL_SYS_MALLOC_SIMPLE=y
Thanks Patrick
Thanks Patrick
Thanks
configs/stm32746g-eval_spl_defconfig | 7 ++++--- 1 file changed, 4 insertions(+), 3 deletions(-)
diff --git a/configs/stm32746g-eval_spl_defconfig b/configs/stm32746g-eval_spl_defconfig index a3b7146454..d8d55c2d3c 100644 --- a/configs/stm32746g-eval_spl_defconfig +++ b/configs/stm32746g-eval_spl_defconfig @@ -1,6 +1,6 @@ CONFIG_ARM=y CONFIG_ARCH_STM32=y -CONFIG_SYS_TEXT_BASE=0x08008000 +CONFIG_SYS_TEXT_BASE=0x08009000 CONFIG_SYS_MALLOC_LEN=0x100000 CONFIG_SYS_MALLOC_F_LEN=0xE00 CONFIG_SPL_GPIO=y @@ -13,10 +13,11 @@ CONFIG_SPL_TEXT_BASE=0x8000000 CONFIG_SYS_PROMPT="U-Boot > " CONFIG_SPL_SERIAL=y CONFIG_SPL_DRIVERS_MISC=y +CONFIG_SPL_SIZE_LIMIT=0x9000 CONFIG_STM32F7=y CONFIG_TARGET_STM32F746_DISCO=y CONFIG_SPL=y -CONFIG_SYS_LOAD_ADDR=0x8008000 +CONFIG_SYS_LOAD_ADDR=0x8009000 CONFIG_BUILD_TARGET="u-boot-with-spl.bin" CONFIG_DISTRO_DEFAULTS=y CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y @@ -29,7 +30,7 @@ CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200 earlyprintk consoleblank=0 ignore_loglevel" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_BOARD_LATE_INIT=y -CONFIG_SPL_PAD_TO=0x8000 +CONFIG_SPL_PAD_TO=0x9000 CONFIG_SPL_NO_BSS_LIMIT=y CONFIG_SPL_BOARD_INIT=y CONFIG_SPL_SYS_MALLOC_SIMPLE=y
Thanks Patrick
Thanks Patrick
Thanks
STM32F746 embeds 1 MB of internal flash [0x08000000-0x080fffff], fix CONFIG_SYS_SPL_ARGS_ADDR accordingly It solves hard fault when jumping from SPL to U-Boot.
configs/stm32f746-disco_spl_defconfig | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/configs/stm32f746-disco_spl_defconfig b/configs/stm32f746-disco_spl_defconfig index 5e8a8aaf3c..d4a65bde24 100644 --- a/configs/stm32f746-disco_spl_defconfig +++ b/configs/stm32f746-disco_spl_defconfig @@ -36,7 +36,7 @@ CONFIG_SPL_BOARD_INIT=y CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_MTD_SUPPORT=y CONFIG_SPL_XIP_SUPPORT=y -CONFIG_SYS_SPL_ARGS_ADDR=0x81c0000 +CONFIG_SYS_SPL_ARGS_ADDR=0x80c0000 CONFIG_SPL_DM_RESET=y CONFIG_SYS_PBSIZE=1050 CONFIG_CMD_GPT=y
Thanks Patrick
Thanks Patrick
Thanks
configs/stm32746g-eval_spl_defconfig | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/configs/stm32746g-eval_spl_defconfig b/configs/stm32746g-eval_spl_defconfig index d8d55c2d3c..28f522b15e 100644 --- a/configs/stm32746g-eval_spl_defconfig +++ b/configs/stm32746g-eval_spl_defconfig @@ -36,7 +36,7 @@ CONFIG_SPL_BOARD_INIT=y CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_MTD_SUPPORT=y CONFIG_SPL_XIP_SUPPORT=y -CONFIG_SYS_SPL_ARGS_ADDR=0x81c0000 +CONFIG_SYS_SPL_ARGS_ADDR=0x80c0000 CONFIG_SPL_DM_RESET=y CONFIG_SYS_PBSIZE=1050 CONFIG_CMD_GPT=y
Thanks Patrick
Thanks Patrick
Thanks
arch-stm32f7/stm32.h file is shared between STM32F746 and STM32F769 MCUs. But STM32F769 embeds 2MB of internal flash instead of 1MB for STM32F746. The flash layout is quite similar between the 2 SoCs :
STM32F746 STM32F769 4 * 32KB sectors 4 * 32KB sectors 1 * 128KB sector 1 * 128KB sector 3 * 256KB sectors 7 * 256KB sectors
Update sect_sz_kb[] structure and SYS_MAX_FLASH_SECT accordingly.
arch/arm/include/asm/arch-stm32f7/stm32.h | 6 +++--- configs/stm32f769-disco_defconfig | 2 +- configs/stm32f769-disco_spl_defconfig | 2 +- 3 files changed, 5 insertions(+), 5 deletions(-)
diff --git a/arch/arm/include/asm/arch-stm32f7/stm32.h b/arch/arm/include/asm/arch-stm32f7/stm32.h index 3451e74a3d..57db839e8d 100644 --- a/arch/arm/include/asm/arch-stm32f7/stm32.h +++ b/arch/arm/include/asm/arch-stm32f7/stm32.h @@ -10,9 +10,9 @@ #include <asm/arch-stm32/stm32f.h>
static const u32 sect_sz_kb[CONFIG_SYS_MAX_FLASH_SECT] = { - [0 ... 3] = 32 * 1024, - [4] = 128 * 1024, - [5 ... 7] = 256 * 1024 + [0 ... 3] = 32 * 1024, + [4] = 128 * 1024, + [5 ... CONFIG_SYS_MAX_FLASH_SECT - 1] = 256 * 1024 };
#endif /* _ASM_ARCH_HARDWARE_H */ diff --git a/configs/stm32f769-disco_defconfig b/configs/stm32f769-disco_defconfig index 423af7446a..5b5307ca1d 100644 --- a/configs/stm32f769-disco_defconfig +++ b/configs/stm32f769-disco_defconfig @@ -41,7 +41,7 @@ CONFIG_MTD=y CONFIG_DM_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_STM32_FLASH=y -CONFIG_SYS_MAX_FLASH_SECT=8 +CONFIG_SYS_MAX_FLASH_SECT=12 CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH_MACRONIX=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/stm32f769-disco_spl_defconfig b/configs/stm32f769-disco_spl_defconfig index b56d88f9f6..b5d54b48ec 100644 --- a/configs/stm32f769-disco_spl_defconfig +++ b/configs/stm32f769-disco_spl_defconfig @@ -63,7 +63,7 @@ CONFIG_MTD=y CONFIG_DM_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_STM32_FLASH=y -CONFIG_SYS_MAX_FLASH_SECT=8 +CONFIG_SYS_MAX_FLASH_SECT=12 CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH_MACRONIX=y CONFIG_SPI_FLASH_STMICRO=y
Changes in v2:
- [4] = 128 * 1024,
[4] = 128 * 1024,
Thanks Patrick
diff --git a/arch/arm/include/asm/arch-stm32f7/stm32.h b/arch/arm/include/asm/arch-stm32f7/stm32.h index 3451e74a3d..57db839e8d 100644 --- a/arch/arm/include/asm/arch-stm32f7/stm32.h +++ b/arch/arm/include/asm/arch-stm32f7/stm32.h @@ -10,9 +10,9 @@ #include <asm/arch-stm32/stm32f.h> static const u32 sect_sz_kb[CONFIG_SYS_MAX_FLASH_SECT] = { - [0 ... 3] = 32 * 1024, - [4] = 128 * 1024, - [5 ... 7] = 256 * 1024 + [0 ... 3] = 32 * 1024, + [4] = 128 * 1024, + [5 ... CONFIG_SYS_MAX_FLASH_SECT - 1] = 256 * 1024 }; #endif /* _ASM_ARCH_HARDWARE_H */ diff --git a/configs/stm32f769-disco_defconfig b/configs/stm32f769-disco_defconfig index 423af7446a..5b5307ca1d 100644 --- a/configs/stm32f769-disco_defconfig +++ b/configs/stm32f769-disco_defconfig @@ -41,7 +41,7 @@ CONFIG_MTD=y CONFIG_DM_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_STM32_FLASH=y -CONFIG_SYS_MAX_FLASH_SECT=8 +CONFIG_SYS_MAX_FLASH_SECT=12 CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH_MACRONIX=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/stm32f769-disco_spl_defconfig b/configs/stm32f769-disco_spl_defconfig index b56d88f9f6..b5d54b48ec 100644 --- a/configs/stm32f769-disco_spl_defconfig +++ b/configs/stm32f769-disco_spl_defconfig @@ -63,7 +63,7 @@ CONFIG_MTD=y CONFIG_DM_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_STM32_FLASH=y -CONFIG_SYS_MAX_FLASH_SECT=8 +CONFIG_SYS_MAX_FLASH_SECT=12 CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH_MACRONIX=y CONFIG_SPI_FLASH_STMICRO=y
Thanks Patrick
Thanks
By pressing "c" key during SPL execution, we force U-boot execution instead of a kernel XIP image.
This fixes a hard fault when booting stm32f746-disco in SPL with "c" key pressed during SPL execution.
U-Boot SPL 2022.10-rc5-00009-g40d02baa91 (Sep 20 2022 - 17:21:21 +0200) Trying to boot from XIP Hard fault pc : 080083fc lr : 08000d1b xPSR : 21000000 r12 : 2004f108 r3 : 080083fd r2 : 00000028 r1 : 2004f0c8 r0 : 2004f0e4 Resetting CPU ...
This is due to SYS_UBOOT_START flag set to 0x080083FD which is not correct. If unset, SYS_UBOOT_START is set by default to CONFIG_SYS_TEXT_BASE which match with our requirement.
include/configs/stm32f746-disco.h | 1 - 1 file changed, 1 deletion(-)
diff --git a/include/configs/stm32f746-disco.h b/include/configs/stm32f746-disco.h index 64c1bc7d43..b0ec226114 100644 --- a/include/configs/stm32f746-disco.h +++ b/include/configs/stm32f746-disco.h @@ -34,7 +34,6 @@ BOOTENV
#define CONFIG_SYS_MONITOR_LEN (512 * 1024) -#define CONFIG_SYS_UBOOT_START 0x080083FD #define CONFIG_SYS_UBOOT_BASE (CONFIG_SYS_FLASH_BASE + \ CONFIG_SPL_PAD_TO)
Thanks Patrick
diff --git a/include/configs/stm32f746-disco.h b/include/configs/stm32f746-disco.h index 64c1bc7d43..b0ec226114 100644 --- a/include/configs/stm32f746-disco.h +++ b/include/configs/stm32f746-disco.h @@ -34,7 +34,6 @@ BOOTENV #define CONFIG_SYS_MONITOR_LEN (512 * 1024) -#define CONFIG_SYS_UBOOT_START 0x080083FD #define CONFIG_SYS_UBOOT_BASE (CONFIG_SYS_FLASH_BASE + \ CONFIG_SPL_PAD_TO)
Thanks Patrick
Thanks
Hi Patrice, Patrice Chotard wrote,
Changes in v2:
I tested this series and all is working fine now. Both defconfigs and with or without Falcon mode. Thanks.
Tested-by: Waldemar Brodkorb wbx@openadk.org
best regards Waldemar
Patrice CHOTARD
Patrice Chotard
Patrick DELAUNAY
Waldemar Brodkorb
